Below is an image of what I'm trying to accomplish. I attempted to make the graphic as simple as possible although I have some more complex instances of this in a fairly complex book layout.
Notes:
Ideally I could set a "negative" space in the space after panel for the head style, but I don't think this is doable.
Any suggestions?
I think you would need to create separate styles (e.g. "BodyText" and "BodyTextFollowingHeading") which is what I do all the time.
Then, to actually apply the styles, it's best with a script. There are both free scripts and paid ones that will do this:
Free:
https://indesignsecrets.com/find-change-the-next-paragraph-style-with-a-script.php
Or my own paid version:
https://www.id-extras.com/products/change-consecutive-paragraphs
(In the comments section I also mention the "Pro" version, which lets you s
...Copy link to clipboard
Is this the desired outcome? More space between Body paragraphs but less under the Heads?
Yes.
Ok! I set up two paragraph styles—one for the Heading and one for the Body paragraphs.
In the Body paragraph, I set the space after to 1p0 in Indents and Spacing.
For the Heading paragraph, I set the space after to 0p2 also in Indents and Spacing.
You can, of course, use any numbers that you like.
Thank you for taking the time to interact with me. If you read my original post I acknowledged that I'm a "space before" person whereas others are "space after" designers. It's really relative as far as I can tell because if you solve my problem using "space after," I will have the same problem in reverse.
On your first screenshot it occurred to me that perhaps I need to assign BOTH a "space before" and "space after" for my various styles.
Of course, I wish my book design consisted of only a couple styles, but because it's a curriculum it has probably 25 styles. I'm thinking it will probably be worth my while to spend the time to fine-tune all of this.
Ideally, I would be able to assign "conditions" to paragraph styles. So, for example, If "body" is preceded by "head" then over-ride the primary spacing and using conditional spacing.
That would be ideal, but it's not a feature of InDesign styles.
And yes, I did see your preference, but selected the approach that would meet your stated needs. Using just space before can't get you to what you showed in your screen shot.
Out of curiosity, why aren't you a "doing it efficiently" person instead of insisting on using one method that may involve more effort and time? I mean this politely, because I really don't understand.
I'm all about being efficient, hence the reason for my post. I will gladly learn any new technique or use any unknown feature to make my work better and faster. You'll notice that I greatly appreciated Ariel pointing me to a script that will save me lots of time.
My point about being a "space before" versus "space after" is because it's one of those dumb designer identifiers (for fun) between me and some fellow InDesign users. Just geek stuff. It's entirely a very minor preference and doesn't make a bit of difference, I was just trying to pre-empt the obvious answer that you change your space after to solve my problem, because while that would solve the problem initially it would introduce the same problem in reverse.
Free:
(In the comments section I also mention the "Pro" version, which lets you save all these replacements so they can be run automatically the next time you create a similar document).
Ariel
Ariel, The way you suggested of creating a separate paragraph style is how I've been doing it. The manual process of assigning those styles is what my post was in response to. I was looking for a better way
The script you have looks perfect! I will run the trial and if it works well I will purchase the paid version. This could be a huge timesaver for me with various projects.
Great. I'm a typesetter myself (well, at least part time) so all these scripts are workhorses -- put to daily, real-world use...
There is another option! You only need two styles, Head and Body.
Yes, for your Head Style, you will have to use "Space After" as well as "Space Before"—but the benefit is that your Head Style will be the only style defining the space between Head and Body content, and won't be affected by the space between your Body paragraphs.
Just to note, this thread was originally posted over five years ago, and that was not an option at the time.
