I am running CC 2017 and have not found a working way to edit the script to remove the numbers at the beginning of the file name when exporting layers to files. I did this for CS6, but every tutorial I find does not show me how to do it in CC 2017. I keep finding tutorials for CC 2015, but the line numbers given in every tutorial I have found does not match the line numbers in the .jsx file I have on my system.
Line 2179 - fileNameBody += "";
Line 2181 - fileNameBody += "" + layerName;
Line 2215 - fileNameBody += "";
Once again, this doesn't match the "Export Layers To Files.jsx" I have on my system. The document I have only goes up to Line 1330.
Strange because im using cc2017, .. What you should do is either use Dreamweaver or download Atom or w.e program your using and search for those lines and make the adjustments. I was searching for a solution just like you yesterday but didn't find an answer. That's the solution that I had to do. also make sure your not looking at the layer comps to files .jsx
I'm currently using dream weaver. I'll do a search for those specific lines and see if I can work something out.
If you still cant find it let me know id be more than happy to look at the file for you if you duplicate it.
