I am having trouble getting InDesign CS6 to properly render certain Asian TrueType and OpenType fonts.
This is on a PC running Windows 10 Enterprise.
Am placing text into InDesign files from Microsoft Word documents using these fonts. They render in Word, but not in InDesign.
Have checked the bottom of my InDesign font list for Asian fonts, and the fonts are not among them.
So obtained legal files and installed the fonts in my Windows 10 Fonts control panel.
For a Laotian version, our partners require me to use the font
Am required to use these exact fonts in Khmer and Lao translations of a fact sheet,
For the Laotian fact sheet, am required to use the font Saysettha Lao (TTF).
Was using Phetsarath (OT) but am told it does not render the text correctly.
When I switch to Saysthetta, nothing but boxes appear in the InDesign text frame.
For the Khmer fact sheet, am required to use the font Khmer OS Content.TTF.
Am having better luck with it, but certain glyphs are dropping out.
But the font renders all glyphs in Microsoft Word 2016 for Windows
Am trying to find versions of these fonts that InDesign CS 6 will load.
Thanks in advance
You should be aware that CS6 is not supported under Windows 10 so there’s no assurance that anything will work, but there are some things you can try.
Put the fonts into the InDesign fonts folder
Use a Document fonts folder for specific documents
Run InDesign in Windows 7 compatibility mode.
Good luck.
As InDesign always has used its own internal OpenType engine, I doubt it's a question of compatibility. (Unless you are sure that these same fonts render correctly on an older system!)
InDesign CS6 just does not support all possible OpenType functionality, esp. those that are required to render scripts such as these. Even with the very latest version -- download the trial and test -- it'll be anyone's guess.
We had the same font issue under Windows 7, but will try running InDesign with Windows 7 compatibility mode (need to figure out how to do that).
The gears are slowly turning to switch to Creative Cloud in my particular workgroup. But the fact sheets need to be done before thathappens, so will give this one last shot before laying out the two translations in Microsoft Publisher 😞
