I am trying to burn a short DVD. When I select burn DVD, just at the end I get internal software error:/Vobulator/BlockPlanner/ Block Planner cpp.line 215 If I save to file as MPEG and burn I get the same errror. If I take off the Menu I have set up , it works OK If I clear the menu and use a different menu, its still the same. The video is very simple with main menu marker at start, end marker, no scene markers, my own shot as picture for menu, which is resized, and simple audio track I am working in parallel on another longer video and this still burns Ok, It is longer and has a menu OK
Ok Fixed now....Removed End marker. And it all works fine now. Hope other will find this useful. Chris
Sorry, should have said....Premiere Elements 12 on Windows 7 system.
Further info. I have determined the following adding a menu to the project causes the error changing the menu template has no effect removing the sound on the menu has no effect changing the picture to an unused elsewhere shot has no effect This is getting hard. Whats left? Chris
