I inserted page numbers in a 2-page .pdf document created by "print to PDF" from Excel file. The page numbers appear to be of different fonts on pages 1 and 2. Checking Appearance Options>Keep position and sizes constant doesn't help. How can I make the page numbers appear the same size. Thanks!
Hi irinas74951609,
Sorry for the delay in response.
Ideally, that shouldn't happen is it possible you may share the file with us?
If you try to insert the page numbers again and choose a different font this time, are you still able to reproduce the issue?
Can you try to reproduce the issue with a different file? If you are able to reproduce the issue, please help us with the exact steps you have used. Will try to reproduce the bahavior.
-Tariq Dar.
