Is first a.obj placed in Plexus? Ore do I need another program for implementing an 3D object into Plexus?
I’m a little stock in this.
How should I begin to get a result like this?
Greetings,
Microsoft OneDrive - Access files anywhere. Create docs with free Office Online.
<img src="https://ubbzea-dm2305.files.1drv.com/y4mahKhN3xj8bDjMeMFfVVwP-fdtgGnTnh_lfkLGLhg_GMzKZm2b8w8qbDaE0We..." width="1200" height="1500" />
Yes, it's simply an OBJ imported into the effect. The rest is just finding suitable settings for the line renderer and using multiple instances of it.
Mylenium
Is this the wright place to do?
Because in this drop-down menu isn't the option to select?
....ore do we need to use plugin? (ProAnimator).
Hi Blueship,
you need first to have an obj object, which you can download from the web or create one using Cinema4D for example. An obj is a 3d object (in your case the deer).
Then, import that obj file into after effect and place it in your composition.
Now in the drop down menu you can select your obj.
Hi Blueship,
Are you still facing this problem with this issue with Plexus? If not, let us know how you solved it. If so, please let us know so we can assist you further.
Kevin
