Editing a file uploaded via Lightroom in Photoshop. Edits got intense, lots of layers, so I threw a save at it and made the brilliant mistake
of saving as a PSD. Now I can't get it back to Lightroom with his brothers and sisters.
Is there a way to get this psd back into Lightroom?
Thanks in advance!
Lightroom supports PSD with a few caveats. Exactly what problem are you having with trying to import it into Lightroom?
If you saved it in the same folder using the "Save As" command, then just go to the library module and right-click on the folder and synchronize the folder. Lightroom should see that there is another image that needs to be added to the catalog.
Thank you both for answering. I realized I was over thinking the process and fixed it with a simple import from the folder where I saved it.
Too many photos to edit, too little sleep
Just for future reference, Jim's suggestion is the most efficient way to resolve this if it happens again. The Synchronize feature is designed just for this process of importing new files from existing folders.
