Help with UI: Script execution order when selecting Radio and Checkbox options
Engaged ,
Apr 05, 2017 Apr 05, 2017
I need to modify a dialog box that contains Radio and Checkbox options to run two different events on the same task, however, I'm having a huge Difficulty in defining the order of execution of events: The script contains two groups: "Group 1 (Radio)" and "Group2 (Checkbox)". I would like the events to run in the following order: "Group 1 (Radio)" = Second Event "Group 2 (Checkbox)" = First Event (main event). Run all selected events after clicking OK button.
Could some friend as a greater knowledge help me?
Thank you. It would be a reversal in the order of running the events of this script:
var w = new Window ("dialog", " My ScriptUI");
    w.orientation = "column";
    w.alignChildren = "top";  // insert this line
var g1 = w.add('group')
    g1.orientation = 'row';
    var radio_group  = g1.add ('panel', undefined, "Group1");
    // Radio
        radio_group.alignChildren = "left";
        radio_group.add ("radiobutton", undefined, "Radio1");
        radio_group.add ("radiobutton", undefined, "Radio2");
        radio_group.add ("radiobutton", undefined, "Radio3");
    var btnGroup = g1.add("group");
        btnGroup.orientation = "column";
        btnGroup.alignment = ['left','top'];
        btnGroup.add ('button', {x:90, y:125, width:80, height:25}, 'Ok', {name:'ok'});
        btnGroup.add ('button', {x:240, y:125, width:80, height:25}, 'Cancel', {name:'cancel'});
var g2 = w.add('group')
    g2.orientation = 'row';
    g2.alignment = ['left','top'];
    // Checkbox
    var check_gp = g2.add('panel',undefined,'Group2');
        check_gp.orientation = 'row';
        check_gp.alignChildren = ['left','top'];
        var check1 = check_gp.add('checkbox',undefined,'checkbox');
        check1.value = false;
// set dialog defaults
radio_group.children[0].value = true;
radio_group.addEventListener('click', function(evt) {
    for (var i = 0, _len = radio_group2.children.length; i < _len; i++) {
        radio_group2.children.value = false;
function selected_rbutton (rbuttons) {
    for (var i = 0; i < rbuttons.children.length; i++) {
        if (rbuttons.children.value == true) {
            return rbuttons.children.text;
    return false;
// Linkar com os Scrips.jsx
if (w.show () == 1) {
    var chosenRadioButton = selected_rbutton(radio_group) || selected_rbutton(radio_group2) || selected_rbutton(radio_group3);
    switch (chosenRadioButton) {
     case "Radio1":
     alert("This is the Radio 1 script");
     break;
     case "Radio2":
     alert("This is the Radio 2 script");
     break;
if(check1.value){alert('checkbox (main event)')}
//else{alert('checkbox 1 is not checked')}
Actions and scripting
1.6K
Community Expert , Apr 06, 2017 Apr 06, 2017
You would put in after line 53. Line 52 checks to see if the okay button pressed and runs code accordingly.
Adobe
UI's are just a way to collect values. The order of what the script does is based on the order you list the processes that are derived from the values in the UI. If you want something to show before something else in the ui, you need to have that line of code first. Same for what the script does once you click the okay button. In the above script you have what the radio buttons do first, so naturally, they're going to display their alert first. There is a part of the script that adds an eventListener. I'm not sure what that's suppose to do. It throws an error for me, and it looks like it tries to set all the radio buttons to false. By nature, if you click on a radio button, other within the same group will turn to false, so I don't know what point that part of the code serves.
Engaged ,
Hi Chuck Uebele! Our just add the line of code from the first event before! As for the eventListener, I also do not know what it is for, I found this script on the internet, here it does not generate error for me, but I'll eliminate delete it and test, then I go back
Engaged ,
In order for the checkbox alert to run first, I understood that I have to put above the code lines of the radio buttons: To work correctly, what line should I add this event to?
If (check1.value) {alert ('checkbox (main event)')}
I put in line 31 but it did not work:
Chuck Uebele Please, would you have any idea? It's not easy for me.
Would you have a simple and small example of yours for the same purpose? Thank you
Engaged ,
Apr 07, 2017 Apr 07, 2017
Chuck Uebele, thanks to his tip, now yes, it worked perfectly. Once again thank you very much for your attention and this huge help.
