CS5 - Error 22:Window does not have a constructor
Apr 22, 2010 Apr 22, 2010
I've been experimenting with some old sccripts on the Photoshop CS5 pre-release and they seem to work fine except any that have a user interface.Scripts that run fine on CS2, CS3 and CS4 throw a "Error 22:Window does not have a constructor" error message. I was wondering if anyone else had noticed this and if they were aware of any changes as regards to scripting with CS5 and also how to correct the issue.
CJ
Actions and scripting
200.0K
Community Beginner , Nov 13, 2010 Nov 13, 2010
Dear All,
I have been bothered by this same  Photoshop error 22 when trying to use the Photomerge feature or any  other of the Automate features in CS5.
My computer is a  Windows 7 32bit machine but this should definitely apply to Windows  64bit machines and possibly the same logic may apply to Mac but I do not  know.
I didnt find a permanent solution but I did find  a temporary fix which will at least allow you to use the function for  one opening of the program however if you close and reopen pho
Adobe
Guru ,
That question is better asked in the prerelease forum, but scripts with dialogs are working in the latest build.
Thank you for the reply, its good to hear that the dialog issue isn't there on the latest version
- what is the latest version number BTW? Sorry if I entered the question in the wrong forum, I wasn't aware there was a pre-release section.
Thanks again,
CJ
Dear All,
I didnt find a permanent solution but I did find  a temporary fix which will at least allow you to use the function for  one opening of the program however if you close and reopen photoshop the  problem returns.
Temporary Fix Instructions:
1.  Locate the file "Adobe Photoshop CS5 Prefs.psp" on your computer and delete it or move it elsewhere.  (I assume by  doing this you may lose ass of your photoshop preferences but it will  allow you to use photomerge and HDR so you choose)
2. On Windows this file can be found in the User folder under C:\**USER NAME**\AppData\Roaming\Adobe\Adobe Photoshop CS5\Adobe Photoshop CS5 Settings\ (Replace **USER NAME** with the Windows 7 account user name)
3.  After deleting this file or temporarily moving it out of that folder  you can then open Photoshop CS5 and use the Photomerge feature as much  as you'd like.
4. As soon as you close Photoshop CS5 the program automatically makes a new Adobe Photoshop CS5 Prefs.psp file so when you try to reopen the program it will not work again.
I  hope this may be helpful to some people and I hope that Adobe can fix  this issue, I have not and dont plan on submitting this as a bug report  to Adobe, being that I do not personally own the program (still in 30  day trial) but anyone who would like to, please feel free to do so.
Advisor ,
Nov 14, 2010 Nov 14, 2010
It's easier to just reset the preferences on startup:
"Hold down Shift+Ctrl+Alt (Win) / Shift+Command+Option (Mac) when you start up Photoshop to reset the preferences."
Very nice solution!!
Yes, pressing ctrl+shift+alt when opening Phoshop CS5 does accomplish the same result and is much easier for most people, I was unaware of this.
Thank you!
Apr 09, 2023 Apr 09, 2023
hello, I'm currently experiencing the error 22. I don't know what is the alternative way to use the contact sheet II option. Do you have any suggestion? thank you.
Jul 12, 2014 Jul 12, 2014
Yes pressing ctrl+shift+alt when opening Phoshop CS5 was for me the solution too (mac)
Apr 02, 2017 Apr 02, 2017
It hasn't helped me. same error message and this:
Line: 388
->   var w = new Window(res);
Advisor ,
Apr 06, 2017 Apr 06, 2017
The only other time I see this happen is if you are running the script from ESTK and the target app is not PS.
-X
Jun 17, 2019 Jun 17, 2019
It hasnt Helped me too. My error is at
Line 10701
var win = new Window('dialog', self.title, rectToBounds(wrect),
                       self.windowCreationProperties);
Advocate ,
Which OS?
Which Photoshop?
Which script?
Jan 11, 2021 Jan 11, 2021
hi everybody Iam not any pro or anything but i know few programming
so this issue comes when you use portable version of photoshop
i dont know how to fix the problem but it comes when yu go to file>scripts>load files into stack
but instead use file>scripts>load multiple dicom files the reality is that  the option are the same.
Sep 03, 2022 Sep 03, 2022
Man you are absolutely right. I actually needed a Portable version and I've been experiencing same Error 22. But putting the solution you wrote to test it worked. Thank you.
