I have recently updated to InDesign 2015.4. As part of a regular workflow I use the SplitStory script in from the JavaScript folder to unlink text threads. Since updating this script no longer works for me, (neither does the AppleScript equivalent). Please see the attached screenshots. Any help greatly appreciated.
Ah.
I can replicate the error message, if the story contains one container with text on a path.
Uwe
at least the JavaScript version of the script should work.
Just tested that with CC 2017.1 12.1.0.56.
Can you do a test with just a story where two simple text frames are threaded?
If that is not working I recommend to restart your computer and try again.
Uwe
Ah.
Uwe
Thank you! You were right, there was text on a path in the documents causing me problems.
