This is an image of what i see when i use the brush tool:
I want it to be a normal stroke as i draw with it.
After i let go it is a normal brush stroke:
How do i fix this?
Moved from the Forum Comments forum (which is for discussing issues with these forums themselves) and into a product-specific, support forum - moderator]
You got to change the smoothing to 0
The smoothing in what you're drawing takes some time to calculate and would be constantly changing as you draw. That would be distracting and also take away CPU time from following the line you are drawing.
If you want to trade off line accuracy for instant smoothing you could send in a feature request here:
i have had an older version of animate(flash) and the lines did not appear then.
also i have seen videos on youtube of people using animate CC and there are no lines going through the brush
