I am taking an on-line class on PS. THere are a few lessons where they present creating an action (actually a conditional action) in PS.
She then went to Bridge, selected a bunch of files and the "batched" them to PS, where the action was performed.
Is there a way to do something similar from LR?
Basicallly the actions were rather simple. It would resize to a fixed image size and in one it added a pattern to the bottom of a horizontal picture. ANother pattern was applied to a vertical picture, that is where the conditional was applied.
ANother example it would resize the image, and then place a template over the image, so the final result was a fixed page size with a border (for printing to a book).
So (for now) just looking to do something similar, could that be done just in LR via presets? Since it involved masks and layers in PS, I would think not.
TIA
Frank
Sorry for the brief answers - I'm doing this from my memory - but I may have misled you slightly. In any case, I always have to figure out this each time I set one up!
But it may be that you need to put a Save step in the action, and maybe a Close. That will record the resolution.
In the droplet you then specify the destination folder, and ensure you check the Override Action Save As Commands. This is confusing - because I think it actually respects Save commands in the action. But you'll have to
...Copy link to clipboard
You do this by saving the Photoshop action as a droplet, which you do in Photoshop. Then take the droplet and put it in the Export Actions folder - you find this in the Export dialog in the Post Processing steps - and call it up as part of an export from Lightroom. Alternatively, you can set up the droplet as an external editor - that's in Lr's Preferences, External Editing.
Okay, so how does a one create a droplet?
From PS, I went to help online help, then searched on create droplet. The following are the "results" displayed. The first one is a link to a video but shows exporting via batch from Bridge (which is what I've seen and started this inquiry). The second is a a description on basic action panel in PS, No where does it say how to create a droplet. Only mention of droplets is the following: In Photoshop, actions are the basis for droplets, which are small applications that automatically process all files that are dragged onto their icon.
Yet another follow-up.
By downloading and reading the Photoshop reference manual I found that you create a droplet
File -> Automate -> Create Droplet.
This created a .exe file.
When I place this in C:\Users\frank\AppData\Roaming\Adobe\Lightroom\Export Presets\User Presets It doesn't show up, Looking at C:\Users\frank\AppData\Roaming\Adobe\Lightroom\Export Presets\Lightroom Presets the file extensions are lrpresets.
I also placed this droplet both
C:\Users\frank\AppData\Roaming\Adobe\Lightroom\Export Actions
C:\Users\frank\AppData\Roaming\Adobe\Lightroom\External Editor Presets
Now at the bottom of LR export, it appears as a post processing after action and then when I run, it opens up the files in PS does what is expected, but would now need to "save" the results.
Where am I going wrong?
You need to include saving in the droplet. In the Create Droplet dialog box, there's a section called Destination.
Okay, that "almost" worked. Now when it goes to save (since they are going to jpeg) for each picture, I get the save windown where I have to select the resolution and then click okay. Is there a way to eliminate that?
In the droplet you then specify the destination folder, and ensure you check the Override Action Save As Commands. This is confusing - because I think it actually respects Save commands in the action. But you'll have to experiment.
