Clicking on Help>Updates indicates that I have an update to install to give me 2015.9. Clicking on the update button gives a pop-up screen which says I have to save my work and close Adobe Lightroom before continuing. I am not sure what I have to do to "save my work", and if I close Lightroom how can I continue with the update as I am out of Lightroom?
The answer is probably simple, but I am baffled. Grateful for any help!
Lightroom has to be closed when an update is installed - you can't update a program when it is running.
The update will be downloaded and installed after you have closed Lightroom. (it may take a few minutes)
If it doesn't work, you download the 6.9 update from here: Download Photoshop Lightroom
Ligtroom needs to be closed when the update is installed.
And your work is saved automatically to the catalog without any action on your part, so just close Lightroom.
Dear Per,
Thanks for your quick reply. If Lightroom is closed, how do I install the update? should I go to the Lightroom website, find the update and download it?
Again, thanks for your help!
Many thanks, Per, problem solved!
