How to get the property on frame
Apr 07, 2017 Apr 07, 2017
Hi All,
I recently upgraded to Indesign 2017.0. I have noted this strange thing in my document. When i select a frame i see this tiny oval in a small box which on click shows some properties that are applied to contents in frame. The issue is, i see this oval in small box in only some frames. In others, I do not see. The only solution is to select the contents and then see the oval in small box and apply property.
Please tell me how to get this oval on all frames as it is very helpful.
I am on Mac Os 10.12 and using InDesign since last 3 years.
Thanks for any help
480
Adobe Employee , Apr 07, 2017 Apr 07, 2017
Do correct me if I am wrong but the "oval" you mention is the one i have shown below?
This oval is seen only when your frame is Non Threaded. To check if a frame is threaded or not do the following:
1. Goto view menu
2. From extras enable "Show text threads"
If it is threaded(linked) to another frame it is called a threaded text frame.
You are not seeing the "oval" most likely because it is a threaded text frame. You can still apply all the properties that are shown on clicking the oval from the c
OpenType fonts can include a wide variety of typographic features. The oval is the OpenType adornment, and clicking it opens a contextual menu showing a list of applicable OpenType attributes. If you are not using OpenType fonts in that text frame you will get this message:
You can see the type of font you are using by opening up the the Font list in the control panel. O=OpenType, TT is TrueType and won't offer OpenType options.
Thanks Barb. But i do not see the OpenType adornment.
Adobe Employee ,
1. Goto view menu
You are not seeing the "oval" most likely because it is a threaded text frame. You can still apply all the properties that are shown on clicking the oval from the character panel menu (OpenType properties)
OR
You can select the entire text by multiple click and then apply the property that are shown on clicking the oval. The results are same. The "oval" appears on text selection appears in all scenarios.
Do let me know if this is the scenario.
Also, as BarbBinder​ showed, are you seeing that message on clicking on "oval" or you dont see the "oval" at all?
-Aman
Thanks Aman.
Can there be any way i can see the OpenType adornment?
Adobe Employee ,
At present with the latest release CC 2017.1 you cannot see the adornment on threaded frames.
But you can submit a feature request at Feature Request/Bug Report Form
Do mention OpenType in your feature title.
-Aman
Thanks. I will do that
