Hello,everyone! I've got a problem... My flash player don't want to work... I downloaded it handred times... made a cleaning, deleted everything and download new, but without succesfull. Did somebody have the simiular problem exactly with WEBFREER???
Thank you for any answer. advises!
WebFreer is a Chromium-based browser and uses the PPAPI plugin, however, WebFreer doesn't automatically detect Flash Player to load it when launching the browser. You need to launch the browser from the command-line using the --ppapi-flash-path and --ppapi-flash-version parameters to tell WebFreer where the Flash plugin is and what version it is. For example, on a 64-bit Windows system, you would launch WebFreer from the command-line as follows:
C:\Users\labuser>"C:\Program Files (x86)\WebFreer\webfreer.exe" --ppapi-flash-path=C:\Windows\SysWOW64\Macromed\Flash\pepflashplayer32_25_0_0_127.dll --pappi-flash-version=25.0.0.127
Alternatively, you can create a WebFreer shortcut and add the parameters to the shortcut target.
If you're on a 32-bit system, the command launch command is:
C:\Users\labuser>"C:\Program Files\WebFreer\webfreer.exe" --ppapi-flash-path=C:\Windows\System32\Macromed\Flash\pepflashplayer32_25_0_0_127.dll --pappi-flash-version=25.0.0.127
The version number in both of these parameters would need to be updated with each Flash Player release.
