Can't get past the new "open/new" screen
Apr 07, 2017 Apr 07, 2017
I'm also unable to open any image when I right click, "open in photoshop" with an error.
This is after I did the new download of the 2017 version of photoshop.
I can't do anything past the error, or the new "open/new" option in the new version.
Please advise.
-Michael
648
Adobe Employee , Apr 07, 2017 Apr 07, 2017
I kicked up a Win7 SP1 machine here and I can create new documents on it. I don't see anything obvious from your system info, either. The video card driver does seems at bit old, so you may want to update that and see it if makes any difference. (Drivers | GeForce )
Another thing to try: 1) Quit Ps
2) Go to C:\Users\user_name\AppData\Roaming\Adobe\Adobe Photoshop CC 2017\Adobe Photoshop CC 2017 Settings and move that directory and its contents to your desktop
3) relaunch Ps
Maybe something in tho
Adobe
Adobe Employee ,
Can you post a screen capture of the error? And what OS version are you using? Did you have the previous Ps CC 2017.0.1 version working, or were you using Ps CC 2015.5?
regards,
steve
Steve,
I was unable to duplicate the error message. I'm only able to view this screen I've attached either by opening it, or by opening an image "open in photoshop". It has about a half second delay like it's wanting to go to the image chosen only to return to this screen.2017ps.png
I believe I was using the 2015 version prior. I just uploaded the newest 2017 version today.
Michael
Adobe Employee ,
Hi Michael,
Can you go to Help> System Info... and copy paste the text from that dialog into a reply?
Also, try going to Edit> Preferences> General and turning on the option to 'Use Legacy "New Document" Interface (fourth option down on the left side). Click OK, then see if you get the familiar New dialog to display and work.
thx,
steve
Steve,
Adobe Photoshop Version: 2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877  x64
Number of Launches: 5
Version: 7 SP1
System architecture: Intel CPU Family:6, Model:14, Stepping:4 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, HyperThreading
Physical processor count: 6
Logical processor count: 12
Processor speed: 3399 MHz
Built-in memory: 32717 MB
Free memory: 2 MB
Memory available to Photoshop: 29569 MB
Memory used by Photoshop: 60 %
History Thumbnails: Enabled.
Touch Bar: Enabled.
Alias Layers: Disabled.
Modifier Palette: Disabled.
Highbeam: Enabled.
Image tile size: 1024K
Image cache levels: 4
Font Preview: Medium
TextComposer: Latin
Display: 1
Display Bounds: top=0, left=0, bottom=1080, right=1920
OpenGL Drawing: Enabled.
OpenGL Allow Old GPUs: Not Detected.
OpenGL Drawing Mode: Advanced
OpenGL Allow Normal Mode: True.
OpenGL Allow Advanced Mode: True.
AIFCoreInitialized=1
AIFOGLInitialized=1
OGLContextCreated=1
NumGLGPUs=1
NumCLGPUs=1
NumNativeGPUs=0
glgpu[0].GLVersion="4.1"
glgpu[0].IsIntegratedGLGPU=0
glgpu[0].GLMemoryMB=4096
glgpu[0].GLName="NVIDIA GeForce GTX 770"
glgpu[0].GLVendor="NVIDIA Corporation"
glgpu[0].GLVendorID=4318
glgpu[0].GLDriverVersion="9.18.13.3788"
glgpu[0].GLRectTextureSize=16384
glgpu[0].GLRenderer="GeForce GTX 770/PCIe/SSE2"
glgpu[0].GLRendererID=4484
glgpu[0].HasGLNPOTSupport=1
glgpu[0].GLDriver="nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um"
glgpu[0].GLDriverDate="20140519000000.000000-000"
glgpu[0].CanCompileProgramGLSL=1
glgpu[0].GLFrameBufferOK=1
glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="4.40 NVIDIA via Cg compiler"
glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[16384]
glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[4]
glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[192]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[32]
glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[32]
glgpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[2048]
glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[124]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
glgpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
clgpu[0].CLPlatformVersion="1.1"
clgpu[0].CLDeviceVersion="1.1 CUDA"
clgpu[0].IsIntegratedCLGPU=0
clgpu[0].CLMemoryMB=4096
clgpu[0].CLName="GeForce GTX 770"
clgpu[0].CLVendor="NVIDIA Corporation"
clgpu[0].CLVendorID=4318
clgpu[0].CLDriverVersion="337.88"
clgpu[0].CLBandwidth=1.78886e+11
clgpu[0].CLCompute=852.471
License Type: Subscription
Serial number: [removed by moderator—this is a public forum]
GUIDBucket:nu
  bucket: 241
  test: DocumentPanel
Application folder: C:\Program Files\Adobe\Adobe Photoshop CC 2017\
Temporary file path: C:\Users\AUNIQU~1\AppData\Local\Temp\
Photoshop scratch has async I/O enabled
Scratch volume(s):
  C:\, 223.5G, 3.87G free
Required Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\Plug-ins\
Primary Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\
Installed components:
   A3DLIBS.dll   A3DLIB Dynamic Link Library   9.2.0.112
   ACE.dll   ACE 2017/01/26-01:10:02   79.579975   79.579975
   AdbePM.dll   PatchMatch 2016/11/03:19:48:57   1.578146   1.578146
   AdobeLinguistic.dll   Adobe Linguisitc Library   10.0.0
   AdobeOwl.dll   Adobe Owl   5.2.11
   AdobePDFL.dll   PDFL 2016/08/10-16:53:20   79.195992   79.195992
   AdobePIP.dll   Adobe Product Improvement Program   7.4.1.60.45263
   AdobeSVGAGM.dll   AdobeSVGAGM   79.579975   79.579975
   AdobeXMP.dll   Adobe XMP Core 2016/09/14-01:09:01   79.159824   79.159824
   AdobeXMPFiles.dll   Adobe XMP Files 2016/09/14-01:09:01   79.159824   79.159824
   AdobeXMPScript.dll   Adobe XMP Script 2016/09/14-01:09:01   79.159824   79.159824
   adobe_caps.dll   Adobe CAPS   10,0,0,6
   AGM.dll   AGM 2017/01/26-01:10:02   79.579975   79.579975
   ahclient.dll    AdobeHelp Dynamic Link Library   2.2.0.1
   AIDE.dll   AIDE 2016/05/27-01:08:49   79.574279   79.574279
   amtlib.dll   AMTLib (64 Bit)   10.0.0.119 BuildVersion: 10.0; BuildDate: Thu Dec 22 2016 3:0:7)   1.000000
   ARE.dll   ARE 2017/01/26-01:10:02   79.579975   79.579975
   AXE8SharedExpat.dll   AXE8SharedExpat 2015/03/13-23:40:54   79.562390   79.562390
   AXEDOMCore.dll   AXEDOMCore 2015/03/13-23:40:54   79.562390   79.562390
   Bib.dll   BIB 2017/01/26-01:10:02   79.579975   79.579975
   BIBUtils.dll   BIBUtils 2017/01/26-01:10:02   79.579975   79.579975
   boost_date_time.dll   photoshopdva   10.0.0
   boost_signals.dll   photoshopdva   10.0.0
   boost_system.dll   photoshopdva   10.0.0
   boost_threads.dll   photoshopdva   10.0.0
   cg.dll   NVIDIA Cg Runtime   3.0.00007
   cgGL.dll   NVIDIA Cg Runtime   3.0.00007
   CITThreading.dll   Adobe CITThreading   2.1.0.1   2.1.0.1
   CoolType.dll   CoolType 2017/01/26-01:10:02   79.579975   79.579975
   dnssd.dll   Bonjour   3,0,0,2
   dvaaudiodevice.dll   photoshopdva   10.0.0
   dvacore.dll   photoshopdva   10.0.0
   dvacrashhandler.dll   Adobe Audition CC 2017   10.0.0
   dvamarshal.dll   photoshopdva   10.0.0
   dvamediatypes.dll   photoshopdva   10.0.0
   dvametadata.dll   photoshopdva   10.0.0
   dvametadataapi.dll   photoshopdva   10.0.0
   dvametadataui.dll   photoshopdva   10.0.0
   dvaplayer.dll   photoshopdva   10.0.0
   dvatransport.dll   photoshopdva   10.0.0
   dvaui.dll   photoshopdva   10.0.0
   dvaunittesting.dll   photoshopdva   10.0.0
   dynamiclink.dll   photoshopdva   10.0.0
   ExtendScript.dll   ExtendScript 2016/12/13-13:10:33   80.1089815   80.1089815
   icucnv40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
   icudt40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
   icuuc40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
   igestep30.dll   IGES Reader   9.3.0.113
   imslib.dll   IMSLib DLL   10.0.0.11
   JP2KLib.dll   JP2KLib 2016/05/26-01:08:58   79.262945   79.262945
   libifcoremd.dll   Intel(r) Visual Fortran Compiler   10.0 (Update A)
   libiomp5md.dll   Intel(R) OpenMP* Runtime Library   5.0
   libmmd.dll   Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler   12.0
   LogSession.dll   LogSession   7.4.1.60.45263
   mediacoreif.dll   photoshopdva   10.0.0
   MPS.dll   MPS 2016/09/14-15:20:26   79.577269   79.577269
   pdfsettings.dll   Adobe PDFSettings   1.04
   Photoshop.dll   Adobe Photoshop CC 2017   18.1.0
   Plugin.dll   Adobe Photoshop CC 2017   18.1.0
   PlugPlugExternalObject.dll   Adobe(R) CEP PlugPlugExternalObject Standard Dll (64 bit)   7.0.0
   PlugPlugOwl.dll   Adobe(R) CSXS PlugPlugOwl Standard Dll (64 bit)   7.0.0.67
   PSArt.dll   Adobe Photoshop CC 2017   18.1.0
   PSViews.dll   Adobe Photoshop CC 2017   18.1.0
   SCCore.dll   ScCore 2016/12/13-13:10:33   80.1089815   80.1089815
   SVGRE.dll   SVGRE   79.579975   79.579975
   svml_dispmd.dll   Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler   12.0
   tbb.dll   Intel(R) Threading Building Blocks for Windows   4, 4, 2016, 0412
   tbbmalloc.dll   Intel(R) Threading Building Blocks for Windows   4, 4, 2016, 0412
   TfFontMgr.dll   FontMgr   9.3.0.113
   TfKernel.dll   Kernel   9.3.0.113
   TFKGEOM.dll   Kernel Geom   9.3.0.113
   TFUGEOM.dll   Adobe, UGeom©   9.3.0.113
   updaternotifications.dll   Adobe Updater Notifications Library   10.0.0.1 (BuildVersion: 1.0; BuildDate: BUILDDATETIME)   10.0.0.1
   VulcanControl.dll   Vulcan Application Control Library   5.3.0.16
   VulcanMessage5.dll   Vulcan Message Library   5.3.0.16
   WRServices.dll   WRServices Thu Jan 07 2016 04:50:10   Build 0.21960   0.21960
   wu3d.dll   U3D Writer   9.3.0.113
Required plug-ins:
   3D Studio 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “U3D”
   Accented Edges 18.1.0 - from the file “Filter Gallery”
   Adaptive Wide Angle 18.1.0 - from the file “Adaptive Wide Angle”
   Angled Strokes 18.1.0 - from the file “Filter Gallery”
   Average 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “Average”
   Bas Relief 18.1.0 - from the file “Filter Gallery”
   BMP 18.1.0 - from the file “Standard MultiPlugin”
   Camera Raw 9.9 - from the file “Camera Raw”
   Camera Raw Filter 9.9 - from the file “Camera Raw”
   Chalk && Charcoal 18.1.0 - from the file “Filter Gallery”
   Chrome 18.1.0 - from the file “Filter Gallery”
   Cineon 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “Cineon”
   Clouds 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “Clouds”
   Collada 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “U3D”
   Color Halftone 18.1.0 - from the file “Standard MultiPlugin”
   Colored Pencil 18.1.0 - from the file “Filter Gallery”
   CompuServe GIF 18.1.0 - from the file “Standard MultiPlugin”
   Conté Crayon 18.1.0 - from the file “Filter Gallery”
   Craquelure 18.1.0 - from the file “Filter Gallery”
   Crop and Straighten Photos 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “CropPhotosAuto”
   Crop and Straighten Photos Filter 18.1.0 - from the file “Standard MultiPlugin”
   Crosshatch 18.1.0 - from the file “Filter Gallery”
   Crystallize 18.1.0 - from the file “Standard MultiPlugin”
   Cutout 18.1.0 - from the file “Filter Gallery”
   Dark Strokes 18.1.0 - from the file “Filter Gallery”
   De-Interlace 18.1.0 - from the file “Standard MultiPlugin”
   Dicom 18.1.0 - from the file “Dicom”
   Difference Clouds 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “Clouds”
   Diffuse Glow 18.1.0 - from the file “Filter Gallery”
   Displace 18.1.0 - from the file “Standard MultiPlugin”
   Dry Brush 18.1.0 - from the file “Filter Gallery”
   Eazel Acquire 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “EazelAcquire”
   Entropy 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “statistics”
   Export Color Lookup Tables 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “Export3DLUT”
   Extrude 18.1.0 - from the file “Standard MultiPlugin”
   FastCore Routines 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “FastCore”
   Fibers 18.1.0 - from the file “Standard MultiPlugin”
   Film Grain 18.1.0 - from the file “Filter Gallery”
   Filter Gallery 18.1.0 - from the file “Filter Gallery”
   Flash 3D 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “U3D”
   Fresco 18.1.0 - from the file “Filter Gallery”
   Glass 18.1.0 - from the file “Filter Gallery”
   Glowing Edges 18.1.0 - from the file “Filter Gallery”
   Google Earth 4 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “U3D”
   Graphic Pen 18.1.0 - from the file “Filter Gallery”
   Halftone Pattern 18.1.0 - from the file “Filter Gallery”
   HDRMergeUI 18.1.0 - from the file “HDRMergeUI”
   HSB/HSL 18.1.0 - from the file “Standard MultiPlugin”
   IFF Format 18.1.0 - from the file “Standard MultiPlugin”
   IGES 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “U3D”
   Ink Outlines 18.1.0 - from the file “Filter Gallery”
   JPEG 2000 18.1.0 - from the file “JPEG2000”
   Kurtosis 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “statistics”
   Lens Blur 18.1.0 - from the file “Lens Blur”
   Lens Correction 18.1.0 - from the file “Lens Correction”
   Lens Flare 18.1.0 - from the file “Standard MultiPlugin”
   Liquify 18.1.0 - from the file “Liquify”
   Matlab Operation 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “ChannelPort”
   Maximum 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “statistics”
   Mean 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “statistics”
   Measurement Core 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “MeasurementCore.8me”
   Median 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “statistics”
   Mezzotint 18.1.0 - from the file “Standard MultiPlugin”
   Minimum 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “statistics”
   MMXCore Routines 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “MMXCore”
   Mosaic Tiles 18.1.0 - from the file “Filter Gallery”
   Multiprocessor Support 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “MultiProcessor Support”
   Neon Glow 18.1.0 - from the file “Filter Gallery”
   Note Paper 18.1.0 - from the file “Filter Gallery”
   NTSC Colors 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “NTSC Colors”
   Ocean Ripple 18.1.0 - from the file “Filter Gallery”
   OpenEXR 18.1.0 - from the file “Standard MultiPlugin”
   Paint Daubs 18.1.0 - from the file “Filter Gallery”
   Palette Knife 18.1.0 - from the file “Filter Gallery”
   Patchwork 18.1.0 - from the file “Filter Gallery”
   Paths to Illustrator 18.1.0 - from the file “Standard MultiPlugin”
   PCX 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “PCX”
   Photocopy 18.1.0 - from the file “Filter Gallery”
   Photoshop 3D Engine 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “Photoshop3DEngine”
   Photoshop Touch 14.0 - from the file “PSDX”
   Picture Package Filter 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “ChannelPort”
   Pinch 18.1.0 - from the file “Standard MultiPlugin”
   Pixar 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “Pixar”
   Plaster 18.1.0 - from the file “Filter Gallery”
   Plastic Wrap 18.1.0 - from the file “Filter Gallery”
   PLY 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “U3D”
   PNG 18.1.0 - from the file “Standard MultiPlugin”
   Pointillize 18.1.0 - from the file “Standard MultiPlugin”
   Polar Coordinates 18.1.0 - from the file “Standard MultiPlugin”
   Portable Bit Map 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “PBM”
   Poster Edges 18.1.0 - from the file “Filter Gallery”
   PRC 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “U3D”
   Radial Blur 18.1.0 - from the file “Standard MultiPlugin”
   Radiance 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “Radiance”
   Range 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “statistics”
   Render Color Lookup Grid 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “Export3DLUT”
   Reticulation 18.1.0 - from the file “Filter Gallery”
   Ripple 18.1.0 - from the file “Standard MultiPlugin”
   Rough Pastels 18.1.0 - from the file “Filter Gallery”
   Save for Web 18.1.0 - from the file “Save for Web”
   ScriptingSupport 18.1.0 - from the file “ScriptingSupport”
   Shake Reduction 18.1.0 - from the file “Shake Reduction”
   Shear 18.1.0 - from the file “Standard MultiPlugin”
   Skewness 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “statistics”
   Smart Blur 18.1.0 - from the file “Standard MultiPlugin”
   Smudge Stick 18.1.0 - from the file “Filter Gallery”
   Solarize 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “Solarize”
   Spaces 18.1.0 - from the file “Spaces”
   Spatter 18.1.0 - from the file “Filter Gallery”
   Spherize 18.1.0 - from the file “Standard MultiPlugin”
   Sponge 18.1.0 - from the file “Filter Gallery”
   Sprayed Strokes 18.1.0 - from the file “Filter Gallery”
   Stained Glass 18.1.0 - from the file “Filter Gallery”
   Stamp 18.1.0 - from the file “Filter Gallery”
   Standard Deviation 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “statistics”
   STL 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “U3D”
   Sumi-e 18.1.0 - from the file “Filter Gallery”
   Summation 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “statistics”
   Targa 18.1.0 - from the file “Standard MultiPlugin”
   Texturizer 18.1.0 - from the file “Filter Gallery”
   Tiles 18.1.0 - from the file “Standard MultiPlugin”
   Torn Edges 18.1.0 - from the file “Filter Gallery”
   Twirl 18.1.0 - from the file “Standard MultiPlugin”
   U3D 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “U3D”
   Underpainting 18.1.0 - from the file “Filter Gallery”
   Vanishing Point 18.1.0 - from the file “VanishingPoint”
   Variance 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “statistics”
   Virtual Reality Modeling Language | VRML 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “U3D”
   Water Paper 18.1.0 - from the file “Filter Gallery”
   Watercolor 18.1.0 - from the file “Filter Gallery”
   Wave 18.1.0 - from the file “Standard MultiPlugin”
   Wavefront|OBJ 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “U3D”
   WIA Support 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “WIASupport”
   Wind 18.1.0 - from the file “Standard MultiPlugin”
   Wireless Bitmap 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “WBMP”
   ZigZag 18.1.0 - from the file “Standard MultiPlugin”
Optional and third party plug-ins: NONE
Duplicate and Disabled plug-ins: NONE
Plug-ins that failed to load: NONE
Extensions:
   com.adobe.inapp.purchase  2.7.122 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.DesignLibraryPanel.html\purchase.html”
   Recent Files  1.4.2 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CCX_START_EXTENSION_1_4_2_009\index.html”
   Libraries  2.7.122 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.DesignLibraryPanel.html\index.html”
   New Document  1.4.2 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CCX_START_EXTENSION_1_4_2_009\fnft.html”
   Start  1.4.2 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CCX_START_EXTENSION_1_4_2_009\index.html”
   com.adobe.experimentation.extension  2.0.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.experimentation.extension\index.html”
   Adobe Color Themes  6.1.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.KulerPanel.html\index.html”
   Export As  3.0.8 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.photoshop.crema\PSPanel\dialog.html”
   Device Preview  1.3.1 - from the file “C:\Program Files\Common Files\Adobe\CEP\extensions\com.adobe.previewHD\PSPanel\panel.html”
   com.adobe.preview.loader  1.3.1 - from the file “C:\Program Files\Common Files\Adobe\CEP\extensions\com.adobe.previewHD\PSLoader\loader.html”
Installed TWAIN devices: NONE
I chose the "Use legeacy new document" and click ok and nothing changes.
Adobe Employee ,
So Ctrl+N doesn't bring up any dialog or alert?
It brings up the "NEW" dialogue box. But, the screen image I sent to you earlier remains no matter what I choose or do.
Adobe Employee ,
So when you try to create a new document, the Start workspace (that's what we call the view) doesn't go away, and you never get a blank document?
What happens when you click on the Creative Cloud icon in your Task bar at the bottom? Is there an alert there?
steve
Steve,
That is correct. I never get a blank document.
There was a red alert in the creative cloud, but, it might be for the other updates that I haven't started yet. No other indications showing once I open the CC icon.
-Michael
Adobe Employee ,
Very odd. Can you try to turn off the workspace and relaunch Ps? Back in Edit> Preferences> General... Show "Start" Workspace When No Documents Are Open, uncheck the option and click OK.
steve
Steve,
I did that. It got rid of the the Start workplace screen. But, I'm still unable to open an image or start a new blank document. Nothing happens on either command.2017ps2.png
Adobe Employee ,
3) relaunch Ps
Maybe something in those prefs. is not quite right.
regards,
steve
