I try to import files from my cameras. I get the message:
Import Results The following files were not imported because they could not read (607)
Object 1-100 etc.
What's wrong?
How can this be corrected?
[Moved from the Lounge (which is where you can "connect with your peers" from across all of Adobe's products for conversations that don't directly relate to help and support) to a product-specific support forum - moderator]
99% of the time this "cannot read" message means that your destination folder does not have READ and WRITE access.
In the Import dialog, open the Destinations panel and verify that it is point where you want it to.
Using Mac Finder or Windows File Explorer, verify that your destination folder and its parent folder have both READ and WRITE access for your user account.
What Adobe program are you using?
This is the the Non technical Lounge forum. Please state what program you are using and I'll move it to the correct forum.
I use Lightroom
Are you using Photoshop, Lightroom, Camera Raw or something else?
Nancy
I use Lightroom
