Lightroom CC 2015.9 on MBP 2016 crashes repeatedly when importing iPhone images
Mar 30, 2017 Mar 30, 2017
Can somebody help me?
I cannot resolve this issue which has happened consistently for the last dozen times I have tried to import photos into LR from my iPhone 5S.
I have a matchbook pro 15inch late 2016 with touch bar, 2.9Ghz i7 CPU, graphics card and 16GB RAM.
Lightroom CC 2015.9 constantly freezes and fails to import and freezes when I try to import pictures taken with the iPhone. This happens if I try to import directly from the iPhone or indirectly via a folder on my Desktop which I have previously imported/copied photos to using a separate program called Image capture.  I have not had this issue until recently.  I usually select "Copy... New photos" in the process of importing. (On a separate issue, I find that the iPhone is frequently not recognised by the LR program, so I often have to resort to restarting both LR and reconnecting the iPhone)
Just to clarify, I can see the preview thumbnails of iPhone images in the import window before I commence the LR import, but the import freezes without any photos actually being imported into LR.
I have disabled all LR plug ins and reset preferences to defaults. This does not rectify the issue. Each time it freezes, I have to Force Quit LR to close the program.
Strangely, I can import photos from an SD card used in my camera  (Canon DSLR) without any problems.
Thanks.
If anyone is interested, I have copied the error report generated after the I have restarted the LR program following a Forced Quit. I can paste it into another message if anyone wants to look at it (It is very long!)
My MBP is running a current version of Sierra 10.12.3 with software updates etc.
If I cannot get a resolution on this problem, I will likely abandon the program. This is a shame as LR has served me well for years.
Kunwar
1.3K
I don't know why it freezes but have you tried simply using the mobile LR app and import there? log on with your CC account on both the iPhone and on your laptop and it will sync to your laptop without connecting the cable. LR/mobile can even shoot raw (although probably not on the 5s). This works quite reliably for me and I have not connected my phone to a computer for years.
That said, you should be able to import using the cable. No clue why it doesn't work.
Adobe Employee ,
Hi kunwarb,
Have you tried turning off 1:1 previews on import? also, turn off the GPU from the Lightroom preferences and check if that helps.
Open Lightroom > Edit menu > Preferences > Performance tab > Uncheck the GPU > Restart.
Mohit
Adobe Employee ,
Hi Kunwar,
When Lightroom Crashes, you would see the crash log from Apple. Please send us the report with your email mentioned in the form. Also please share the logs here.
Smit Keniya
Smit | Lightroom Classic Team
Apr 01, 2017 Apr 01, 2017
Hi, I have been trying some of the above suggestions including disable the discrete GPU and turning off 1:1 previews. Still no success. Not familiar with how to sync photos from lightroom mobile.
Here is a crash report generated when I had to Force Quit LR after it hung during an import attempt. Restarting LR showed that no images were imported.
Any more suggestions?
Date/Time:       2017-04-01 22:03:49 +0100
OS Version:      Mac OS X 10.12.4 (Build 16E195)
Architecture:    x86_64h
Report Version:  25
Data Source:     Stackshots
Command:         Adobe Lightroom
Path:            /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/MacOS/Adobe Lightroom
Version:         Adobe Lightroom [1106920] (6.9)
Parent:          launchd [1]
PID:             5438
Event:           hang
Duration:        1.00s (process was unresponsive for 171 seconds before sampling)
Steps:           10 (100ms sampling interval)
Hardware model:  MacBookPro13,3
Active cpus:     8
Fan speed:       2618 rpm
Timeline format: stacks are sorted chronologically
Use -i and -heavy to re-report with count sorting
Heaviest stack for the main thread of the target process:
  10  start + 1 (libdyld.dylib + 21045) [0x7fff976e2235]
  10  main + 1095 (Adobe Lightroom + 7079) [0x109b96ba7]
  10  NSApplicationMain + 1237 (AppKit + 25054) [0x7fff7fa3b1de]
  10  -[NSApplication run] + 926 (AppKit + 243627) [0x7fff7fa707ab]
  10  -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 2796 (AppKit + 8136798) [0x7fff801f785e]
  10  _DPSNextEvent + 1120 (AppKit + 290340) [0x7fff7fa7be24]
  10  _BlockUntilNextEventMatchingListInModeWithFilter + 71 (HIToolbox + 199462) [0x7fff814e0b26]
  10  ReceiveNextEventCommon + 184 (HIToolbox + 199673) [0x7fff814e0bf9]
  10  RunCurrentEventLoopInMode + 240 (HIToolbox + 200380) [0x7fff814e0ebc]
  10  CFRunLoopRunSpecific + 420 (CoreFoundation + 553412) [0x7fff81f7f1c4]
  10  __CFRunLoopRun + 917 (CoreFoundation + 554933) [0x7fff81f7f7b5]
  10  __CFRunLoopDoBlocks + 356 (CoreFoundation + 557108) [0x7fff81f80034]
  10  __CFRUNLOOP_IS_CALLING_OUT_TO_A_BLOCK__ + 12 (CoreFoundation + 684572) [0x7fff81f9f21c]
  10  __52-[NSApplication(NSAppleEventHandling) _handleAEQuit]_block_invoke + 46 (AppKit + 4457620) [0x7fff7fe75494]
  10  -[NSApplication _terminateFromSender:askIfShouldTerminate:saveWindows:] + 224 (AppKit + 4457966) [0x7fff7fe755ee]
  10  -[NSApplication terminate:] + 1662 (AppKit + 2390933) [0x7fff7fc7cb95]
  10  -[NSNotificationCenter postNotificationName:object:userInfo:] + 66 (Foundation + 27031) [0x7fff83975997]
  10  _CFXNotificationPost + 604 (CoreFoundation + 366044) [0x7fff81f515dc]
  10  -[_CFXNotificationRegistrar find:object:observer:enumerator:] + 1827 (CoreFoundation + 370083) [0x7fff81f525a3]
  10  ___CFXNotificationPost_block_invoke + 50 (CoreFoundation + 643442) [0x7fff81f95172]
  10  _CFXRegistrationPost + 427 (CoreFoundation + 644107) [0x7fff81f9540b]
  10  __CFNOTIFICATIONCENTER_IS_CALLING_OUT_TO_AN_OBSERVER__ + 12 (CoreFoundation + 644364) [0x7fff81f9550c]
  10  ??? (Adobe Lightroom + 15032) [0x109b98ab8]
  10  ??? (<B5A2691C-C7C2-3F81-8F41-3BF90D4BF6DB> + 422445) [0x109e0622d]
  10  ??? (<EA22D365-4FEB-3119-AA45-4A0814D2A1A5> + 81416) [0x109ea5e08]
  10  ??? (<552408AE-9F72-3E5A-8157-7690BEBAEC93> + 8433) [0x109d560f1]
  10  ??? (<552408AE-9F72-3E5A-8157-7690BEBAEC93> + 41185) [0x109d5e0e1]
  10  ??? (<552408AE-9F72-3E5A-8157-7690BEBAEC93> + 99677) [0x109d6c55d]
  10  ??? (<552408AE-9F72-3E5A-8157-7690BEBAEC93> + 40469) [0x109d5de15]
  10  ??? (<552408AE-9F72-3E5A-8157-7690BEBAEC93> + 16070) [0x109d57ec6]
  10  ??? (<552408AE-9F72-3E5A-8157-7690BEBAEC93> + 8562) [0x109d56172]
  10  ??? (<552408AE-9F72-3E5A-8157-7690BEBAEC93> + 41789) [0x109d5e33d]
  10  ??? (<552408AE-9F72-3E5A-8157-7690BEBAEC93> + 38782) [0x109d5d77e]
  10  ??? (<552408AE-9F72-3E5A-8157-7690BEBAEC93> + 135929) [0x109d752f9]
  10  ??? (<552408AE-9F72-3E5A-8157-7690BEBAEC93> + 133207) [0x109d74857]
  10  ??? (<552408AE-9F72-3E5A-8157-7690BEBAEC93> + 159188) [0x109d7add4]
  10  __psynch_cvwait + 10 (libsystem_kernel.dylib + 105458) [0x7fff97810bf2]
*10  psynch_cvcontinue + 0 (pthread + 38973) [0xffffff7f8135f83d]
Process:         Adobe Lightroom (Lightroom) [5438]
Parent:          launchd [1]
UID:             503
Task size:       4438.57 MB
CPU Time:        <0.001
Note:            Unresponsive for 171 seconds before sampling
Note:            3 idle work queue threads omitted
  Thread 0x200d3            DispatchQueue 1           10 samples (1-10)         priority 47 (base 47)
  <process frontmost, thread QoS user interactive (requested user interactive), process unclamped, process received importance donation from WindowServer [165], process received importance donation from EmojiFunctionRowIM_Extension [487], IO tier 0>
  10  start + 1 (libdyld.dylib + 21045) [0x7fff976e2235] 1-10
    10  main + 1095 (Adobe Lightroom + 7079) [0x109b96ba7] 1-10
      10  NSApplicationMain + 1237 (AppKit + 25054) [0x7fff7fa3b1de] 1-10
        10  -[NSApplication run] + 926 (AppKit + 243627) [0x7fff7fa707ab] 1-10
          10  -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 2796 (AppKit + 8136798) [0x7fff801f785e] 1-10
            10  _DPSNextEvent + 1120 (AppKit + 290340) [0x7fff7fa7be24] 1-10
              10  _BlockUntilNextEventMatchingListInModeWithFilter + 71 (HIToolbox + 199462) [0x7fff814e0b26] 1-10
                10  ReceiveNextEventCommon + 184 (HIToolbox + 199673) [0x7fff814e0bf9] 1-10
                  10  RunCurrentEventLoopInMode + 240 (HIToolbox + 200380) [0x7fff814e0ebc] 1-10
                    10  CFRunLoopRunSpecific + 420 (CoreFoundation + 553412) [0x7fff81f7f1c4] 1-10
                      10  __CFRunLoopRun + 917 (CoreFoundation + 554933) [0x7fff81f7f7b5] 1-10
                        10  __CFRunLoopDoBlocks + 356 (CoreFoundation + 557108) [0x7fff81f80034] 1-10
                          10  __CFRUNLOOP_IS_CALLING_OUT_TO_A_BLOCK__ + 12 (CoreFoundation + 684572) [0x7fff81f9f21c] 1-10
                            10  __52-[NSApplication(NSAppleEventHandling) _handleAEQuit]_block_invoke + 46 (AppKit + 4457620) [0x7fff7fe75494] 1-10
                              10  -[NSApplication _terminateFromSender:askIfShouldTerminate:saveWindows:] + 224 (AppKit + 4457966) [0x7fff7fe755ee] 1-10
                                10  -[NSApplication terminate:] + 1662 (AppKit + 2390933) [0x7fff7fc7cb95] 1-10
                                  10  -[NSNotificationCenter postNotificationName:object:userInfo:] + 66 (Foundation + 27031) [0x7fff83975997] 1-10
                                    10  _CFXNotificationPost + 604 (CoreFoundation + 366044) [0x7fff81f515dc] 1-10
                                      10  -[_CFXNotificationRegistrar find:object:observer:enumerator:] + 1827 (CoreFoundation + 370083) [0x7fff81f525a3] 1-10
                                        10  ___CFXNotificationPost_block_invoke + 50 (CoreFoundation + 643442) [0x7fff81f95172] 1-10
                                          10  _CFXRegistrationPost + 427 (CoreFoundation + 644107) [0x7fff81f9540b] 1-10
                                            10  __CFNOTIFICATIONCENTER_IS_CALLING_OUT_TO_AN_OBSERVER__ + 12 (CoreFoundation + 644364) [0x7fff81f9550c] 1-10
                                              10  ??? (Adobe Lightroom + 15032) [0x109b98ab8] 1-10
                                                10  ??? (<B5A2691C-C7C2-3F81-8F41-3BF90D4BF6DB> + 422445) [0x109e0622d] 1-10
                                                  10  ??? (<EA22D365-4FEB-3119-AA45-4A0814D2A1A5> + 81416) [0x109ea5e08] 1-10
                                                    10  ??? (<552408AE-9F72-3E5A-8157-7690BEBAEC93> + 8433) [0x109d560f1] 1-10
                                                      10  ??? (<552408AE-9F72-3E5A-8157-7690BEBAEC93> + 41185) [0x109d5e0e1] 1-10
                                                        10  ??? (<552408AE-9F72-3E5A-8157-7690BEBAEC93> + 99677) [0x109d6c55d] 1-10
                                                          10  ??? (<552408AE-9F72-3E5A-8157-7690BEBAEC93> + 40469) [0x109d5de15] 1-10
                                                            10  ??? (<552408AE-9F72-3E5A-8157-7690BEBAEC93> + 16070) [0x109d57ec6] 1-10
                                                              10  ??? (<552408AE-9F72-3E5A-8157-7690BEBAEC93> + 8562) [0x109d56172] 1-10
        10  ??? (<552408AE-9F72-3E5A-8157-7690BEBAEC93> + 41789) [0x109d5e33d] 1-10
        10  ??? (<552408AE-9F72-3E5A-8157-7690BEBAEC93> + 38782) [0x109d5d77e] 1-10
        10  ??? (<552408AE-9F72-3E5A-8157-7690BEBAEC93> + 135929) [0x109d752f9] 1-10
        10  ??? (<552408AE-9F72-3E5A-8157-7690BEBAEC93> + 133207) [0x109d74857] 1-10
        10  ??? (<552408AE-9F72-3E5A-8157-7690BEBAEC93> + 159188) [0x109d7add4] 1-10
        10  __psynch_cvwait + 10 (libsystem_kernel.dylib + 105458) [0x7fff97810bf2] 1-10
        *10  psynch_cvcontinue + 0 (pthread + 38973) [0xffffff7f8135f83d] 1-10
  Thread 0x2012b            Thread name "cr_scratch"  10 samples (1-10)         priority 31 (base 31)
  <process frontmost, thread QoS default (requested default), process unclamped, process received importance donation from WindowServer [165], process received importance donation from EmojiFunctionRowIM_Extension [487], IO tier 0>
  10  <truncated backtrace> 1-10
  Thread 0x201c3            Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 47 (base 47)
  10  thread_start + 13 (libsystem_pthread.dylib + 12545) [0x7fff978fb101] 1-10
    10  _pthread_start + 286 (libsystem_pthread.dylib + 14587) [0x7fff978fb8fb] 1-10
      10  _pthread_body + 180 (libsystem_pthread.dylib + 14767) [0x7fff978fb9af] 1-10
        10  _NSEventThread + 205 (AppKit + 1655506) [0x7fff7fbc92d2] 1-10
            10  __CFRunLoopRun + 1361 (CoreFoundation + 555377) [0x7fff81f7f971] 1-10
              10  __CFRunLoopServiceMachPort + 212 (CoreFoundation + 558308) [0x7fff81f804e4] 1-10
                10  mach_msg_trap + 10 (libsystem_kernel.dylib + 74570) [0x7fff9780934a] 1-10
                 *10  ipc_mqueue_receive_continue + 0 (kernel + 862304) [0xffffff80002d2860] 1-10
  Thread 0x201c5            Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 31 (base 31)
        10  __NSThread__start__ + 1243 (Foundation + 207821) [0x7fff839a1bcd] 1-10
          10  +[NSURLConnection(Loader) _resourceLoadLoop:] + 313 (CFNetwork + 26116) [0x7fff810bd604] 1-10
  Thread 0x201c9            10 samples (1-10)         priority 31 (base 31)     cpu time <0.001
        10  ??? (<2116CCCF-BA38-366C-8BCE-91827BA52E6D> + 1403241) [0x116c2d969] 1-10
          10  ??? (<2116CCCF-BA38-366C-8BCE-91827BA52E6D> + 867579) [0x116baacfb] 1-10
            10  ??? (<2116CCCF-BA38-366C-8BCE-91827BA52E6D> + 1069145) [0x116bdc059] 1-10
              10  ??? (<2116CCCF-BA38-366C-8BCE-91827BA52E6D> + 1406447) [0x116c2e5ef] 1-10
                10  ??? (<2116CCCF-BA38-366C-8BCE-91827BA52E6D> + 1412300) [0x116c2fccc] 1-10
  Thread 0x201d5            Thread name "com.apple.CFSocket.private"            10 samples (1-10)         priority 47 (base 47)
        10  __select + 10 (libsystem_kernel.dylib + 106166) [0x7fff97810eb6] 1-10
         *10  ??? (kernel + 5801776) [0xffffff8000788730] 1-10
  Thread 0x202f1            10 samples (1-10)         priority 31 (base 31)
  Thread 0x202f2            10 samples (1-10)         priority 31 (base 31)
        10  ??? (<D9194969-C41E-37DF-A816-9CFA013C632B> + 6085) [0x1146a87c5] 1-10
          10  ??? (<12E3207D-9B3A-37A8-B20F-8D584742797E> + 105673) [0x115869cc9] 1-10
            10  ??? (<12E3207D-9B3A-37A8-B20F-8D584742797E> + 107314) [0x11586a332] 1-10
              10  ??? (<12E3207D-9B3A-37A8-B20F-8D584742797E> + 178264) [0x11587b858] 1-10
                10  ??? (<12E3207D-9B3A-37A8-B20F-8D584742797E> + 179436) [0x11587bcec] 1-10
                  10  kevent + 10 (libsystem_kernel.dylib + 109974) [0x7fff97811d96] 1-10
                   *10  ??? (kernel + 5627984) [0xffffff800075e050] 1-10
  Thread 0x202fb            10 samples (1-10)         priority 31 (base 31)
  Thread 0x202fc            10 samples (1-10)         priority 31 (base 31)
  Thread 0x202fd            10 samples (1-10)         priority 31 (base 31)
  Thread 0x202fe            10 samples (1-10)         priority 31 (base 31)
  Thread 0x31b8c            Thread name "Protected Background Thread"           10 samples (1-10)         priority 31 (base 31)
          10  ??? (<EA22D365-4FEB-3119-AA45-4A0814D2A1A5> + 78703) [0x109ea536f] 1-10
                        10  ??? (<EA22D365-4FEB-3119-AA45-4A0814D2A1A5> + 130233) [0x109eb1cb9] 1-10
                            10  ??? (<552408AE-9F72-3E5A-8157-7690BEBAEC93> + 41168) [0x109d5e0d0] 1-10
                                                            10  ??? (<35D1FB78-7295-3206-BD04-6A6245227F6B> + 16468) [0x114432054] 1-10
                                                              10  ??? (<35D1FB78-7295-3206-BD04-6A6245227F6B> + 8149) [0x11442ffd5] 1-10
        10  -[NSCondition wait] + 240 (Foundation + 208171) [0x7fff839a1d2b] 1-10
  Binary Images:
           0x109b95000 -        0x109bb0fff  com.adobe.Lightroom6 Adobe Lightroom [1106920] (6.9) <7A685660-150F-3A23-B64A-6AEE19D3D338>  /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/MacOS/Adobe Lightroom
           0x109d54000 -                ???  ???                                                  <552408AE-9F72-3E5A-8157-7690BEBAEC93>
           0x109d9f000 -                ???  ???                                                  <B5A2691C-C7C2-3F81-8F41-3BF90D4BF6DB>
           0x109e92000 -                ???  ???                                                  <EA22D365-4FEB-3119-AA45-4A0814D2A1A5>
           0x11442e000 -                ???  ???                                                  <35D1FB78-7295-3206-BD04-6A6245227F6B>
           0x1146a7000 -                ???  ???                                                  <D9194969-C41E-37DF-A816-9CFA013C632B>
           0x115850000 -                ???  ???                                                  <12E3207D-9B3A-37A8-B20F-8D584742797E>
           0x116ad7000 -                ???  ???                                                  <2116CCCF-BA38-366C-8BCE-91827BA52E6D>
        0x7fff7fa35000 -     0x7fff8080efff  com.apple.AppKit 6.9 (1504.82.104)                   <C295FF09-9984-34C3-953B-B263EF2107AB>  /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
        0x7fff810b7000 -     0x7fff81491fff  com.apple.CFNetwork 811.4.18 (811.4.18)              <9CE329E8-6177-3474-976D-F5C63FC875CD>  /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
        0x7fff814b0000 -     0x7fff817b9fff  com.apple.HIToolbox 2.1.1 (857.8)                    <40254D9A-E477-3F33-B2A2-807D399BF71C>  /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
        0x7fff81ef8000 -     0x7fff82391fff  com.apple.CoreFoundation 6.9 (1349.65)               <F79384D1-FA3F-38CA-A847-B2625EBB790E>  /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
        0x7fff8396f000 -     0x7fff83d15fff  com.apple.Foundation 6.9 (1349.64)                   <49C8DA40-9E5B-33F9-B092-F50115B59E95>  /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
        0x7fff976dd000 -     0x7fff976e2fff  libdyld.dylib (433.5)                                <129D3B44-FB21-3750-9A68-48B5C3DC632B>  /usr/lib/system/libdyld.dylib
        0x7fff977f7000 -     0x7fff97819fff  libsystem_kernel.dylib (3789.51.2)                   <FC51D7B0-8292-3F6A-9231-64340B237EB7>  /usr/lib/system/libsystem_kernel.dylib
        0x7fff978f8000 -     0x7fff97902fff  libsystem_pthread.dylib (218.51.1)                   <62A84A68-431D-3B54-A7B6-31367CCF2884>  /usr/lib/system/libsystem_pthread.dylib
   *0xffffff7f81356000 - 0xffffff7f81361fff  com.apple.kec.pthread 1.0 (1)                        <4EFF2F70-C9B9-3176-BF83-F1B660C42135>  /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread
   *0xffffff8000200000 - 0xffffff80009fffff  kernel (3789.51.2)                                   <06F94FD7-451F-34A1-B13C-D68FF7EDE0A0>  /System/Library/Kernels/kernel
Process:         1PasswordAgent [458]
Path:            /Users/USER/Library/Application Support/1Password/*/1PasswordAgent.app/Contents/MacOS/1PasswordAgent
Parent:          launchd [1]
UID:             503
Task size:       56.77 MB
Process:         AccessMenuBarApps (☯) [1557]
Path:            /Applications/AccessMenuBarApps.app/Contents/MacOS/AccessMenuBarApps
Parent:          launchd [1]
UID:             503
Task size:       36.60 MB
CPU Time:        0.001
Process:         accountsd [333]
Path:            /System/Library/Frameworks/Accounts.framework/Versions/A/Support/accountsd
Parent:          launchd [1]
UID:             503
Sudden Term:     Tracked (allows idle exit)
Task size:       60.17 MB
Note:            5 idle work queue threads omitted
  Thread 0xbad              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
  <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2>
    10  ??? (accountsd + 2602) [0x10383fa2a] 1-10
  Thread 0x76d6             Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x10383f000 -        0x10383ffff  accountsd (640.0.19)                   <C9C497BB-575F-31BA-B4EF-4108EB9389D5>  /System/Library/Frameworks/Accounts.framework/Versions/A/Support/accountsd
Process:         Adobe CEF Helper [811]
Path:            /Library/Application Support/Adobe/*/Adobe CEF Helper.app/Contents/MacOS/Adobe CEF Helper
Architecture:    i386
Parent:          Creative Cloud [449]
Responsible:     Creative Cloud [449]
UID:             503
Task size:       32.24 MB (+4096  B)
CPU Time:        0.002
Process:         Adobe CEF Helper [818]
Architecture:    i386
UID:             503
Task size:       43.39 MB
Process:         Adobe CEF Helper [851]
Architecture:    i386
UID:             503
Task size:       44.91 MB
CPU Time:        0.004
Process:         Adobe Desktop Service [815]
Path:            /Library/Application Support/Adobe/*/Adobe Desktop Service.app/Contents/MacOS/Adobe Desktop Service
Architecture:    i386
Parent:          launchd [1]
UID:             503
Task size:       26.22 MB
CPU Time:        0.005
Process:         Adobe QT32 Server [5475]
Path:            /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Helpers/DynamicLinkMediaServer/application/dynamiclinkmediaserver.app/Contents/Adobe QT32 Server.app/Contents/MacOS/Adobe QT32 Server
Architecture:    i386
Parent:          launchd [1]
UID:             503
Task size:       11.49 MB
Process:         AdobeCrashDaemon [5442]
Path:            /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashDaemon.app/Contents/MacOS/AdobeCrashDaemon
Parent:          Adobe Lightroom (Lightroom) [5438]
Responsible:     Adobe Lightroom (Lightroom) [5438]
UID:             503
Task size:       12.94 MB
CPU Time:        0.002
Process:         AdobeCRDaemon [800]
Path:            /Applications/Utilities/Adobe Creative Cloud/*/Creative Cloud.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCRDaemon.app/Contents/MacOS/AdobeCRDaemon
UID:             503
Task size:       14.73 MB
CPU Time:        0.002
Process:         AdobeCRDaemon [819]
Path:            /Library/Application Support/Adobe/*/Adobe Desktop Service.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCRDaemon.app/Contents/MacOS/AdobeCRDaemon
Parent:          Adobe Desktop Service [815]
Responsible:     Adobe Desktop Service [815]
UID:             503
Task size:       14.70 MB
CPU Time:        0.002
Process:         AdobeCRDaemon [852]
Path:            /Applications/Utilities/Adobe Creative Cloud/*/Core Sync.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCRDaemon.app/Contents/MacOS/AdobeCRDaemon
Parent:          Core Sync [844]
Responsible:     Core Sync [844]
UID:             503
Task size:       14.73 MB
CPU Time:        0.002
Process:         AdobeIPCBroker [687]
Path:            /Applications/Utilities/Adobe Application Manager/*/AdobeIPCBroker.app/Contents/MacOS/AdobeIPCBroker
Architecture:    i386
Parent:          launchd [1]
UID:             503
Task size:       5888 KB
CPU Time:        0.002
Process:         AdobeUpdateDaemon [103]
Path:            /Library/Application Support/Adobe/*/AdobeUpdateDaemon
Architecture:    i386
Parent:          launchd [1]
UID:             0
Task size:       5264 KB
CPU Time:        0.002
Note:            1 idle work queue threads omitted
  Thread 0x2c2              DispatchQueue 1           10 samples (1-10)         priority 20 (base 20)     cpu time 0.002
  <thread QoS utility (requested utility), timers tier 3 (coalesced), IO tier 1>
  10  start + 53 (AdobeUpdateDaemon + 5637) [0xa0605] 1-10
    10  ??? (AdobeUpdateDaemon + 9431) [0xa14d7] 1-10
      10  ??? (AdobeUpdateDaemon + 8905) [0xa12c9] 1-10
        10  ??? (AdobeUpdateDaemon + 11733) [0xa1dd5] 1-10
          10  CommBridgeImpl::initCommBridge(CommunicationBridge::PipeContext, std::string const&, bool, unsigned int, void (*)(void*), void*) + 1173 (AdobeUpdateDaemon + 67893) [0xaf935] 1-10
            10  usleep$UNIX2003 + 55 (libsystem_c.dylib + 496305) [0xa17542b1] 1-10
              10  __semwait_signal + 10 (libsystem_kernel.dylib + 112370) [0xa17d56f2] 1-10
               *10  semaphore_wait_continue + 0 (kernel + 1118912) [0xffffff80003112c0] 1-10
  Thread 0x1a7b             10 samples (1-10)         priority 20 (base 20)
  <thread QoS utility (requested default), timers tier 3 (coalesced), IO tier 1>
    10  __read + 10 (libsystem_kernel.dylib + 118022) [0xa17d6d06] 1-10
     *10  hndl_unix_scall + 216 (kernel + 645688) [0xffffff800029da38] 1-10
       *10  unix_syscall + 561 (kernel + 6443777) [0xffffff8000825301] 1-10
         *10  read_nocancel + 115 (kernel + 5884291) [0xffffff800079c983] 1-10
           *10  ??? (kernel + 5884954) [0xffffff800079cc1a] 1-10
             *10  ??? (kernel + 3393726) [0xffffff800053c8be] 1-10
               *10  fifo_read + 146 (kernel + 3493906) [0xffffff8000555012] 1-10
                 *10  soreceive + 2209 (kernel + 6080001) [0xffffff80007cc601] 1-10
                   *10  sbwait + 370 (kernel + 6119186) [0xffffff80007d5f12] 1-10
                     *10  msleep + 98 (kernel + 5802402) [0xffffff80007889a2] 1-10
                       *10  ??? (kernel + 5801187) [0xffffff80007884e3] 1-10
                         *10  lck_mtx_sleep + 132 (kernel + 1026980) [0xffffff80002faba4] 1-10
                           *10  thread_block_reason + 222 (kernel + 1069422) [0xffffff800030516e] 1-10
                             *10  ??? (kernel + 1073995) [0xffffff800030634b] 1-10
                               *10  machine_switch_context + 206 (kernel + 2082766) [0xffffff80003fc7ce] 1-10
  Thread 0x1a7c             10 samples (1-10)         priority 20 (base 20)
    10  __psynch_cvwait + 10 (libsystem_kernel.dylib + 111374) [0xa17d530e] 1-10
  Binary Images:
               0x9f000 -           0x167fff  AdobeUpdateDaemon                  <C496393C-CFD1-3934-95F5-C1DDC73747AD>  /Library/Application Support/Adobe/*/AdobeUpdateDaemon
            0xa16db000 -         0xa1769fff  libsystem_c.dylib (1158.50.2)      <2252D116-215B-3C01-A85F-0AAC10DB36CC>  /usr/lib/system/libsystem_c.dylib
            0xa17ba000 -         0xa17dbfff  libsystem_kernel.dylib (3789.51.2) <50D0E6F1-6F9C-303F-BCD6-F72AD4485B6E>  /usr/lib/system/libsystem_kernel.dylib
Process:         AGSService [90]
Path:            /Library/Application Support/Adobe/*/AGSService
Parent:          launchd [1]
UID:             0
Task size:       26.08 MB
  Thread 0x2b9              DispatchQueue 1           10 samples (1-10)         priority 20 (base 20)
  10  start + 52 (AGSService + 5412) [0x100001524] 1-10
    10  ??? (AGSService + 30627) [0x1000077a3] 1-10
      10  ??? (AGSService + 105425) [0x100019bd1] 1-10
        10  -[NSRunLoop(NSRunLoop) run] + 76 (Foundation + 140362) [0x7fff8399144a] 1-10
          10  -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 277 (Foundation + 140658) [0x7fff83991572] 1-10
  Thread 0x58c              10 samples (1-10)         priority 20 (base 20)
        10  ??? (AGSService + 30325) [0x100007675] 1-10
          10  sleep + 42 (libsystem_c.dylib + 526803) [0x7fff977979d3] 1-10
            10  __semwait_signal + 10 (libsystem_kernel.dylib + 106310) [0x7fff97810f46] 1-10
  Thread 0x23f7a            Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 20 (base 20)
  Thread 0x23f7b            Thread name "com.apple.CFSocket.private"            10 samples (1-10)         priority 20 (base 20)
  Binary Images:
           0x100000000 -        0x10023ffff  AGSService                             <4EE77B93-276B-3660-BC65-BB91D37D6FAF>  /Library/Application Support/Adobe/*/AGSService
        0x7fff97717000 -     0x7fff977a4fff  libsystem_c.dylib (1158.50.2)          <B03F8915-1E9B-3C84-AED5-68E2E0031630>  /usr/lib/system/libsystem_c.dylib
Process:         AirPlayUIAgent [447]
Path:            /System/Library/CoreServices/AirPlayUIAgent.app/Contents/MacOS/AirPlayUIAgent
Parent:          launchd [1]
UID:             503
Task size:       30.16 MB
  Thread 0xfe1              DispatchQueue 1           10 samples (1-10)         priority 46 (base 46)
  <thread QoS user interactive (requested user interactive), process sudden termination clean, process unclamped, IO tier 0>
              10  ReceiveNextEventCommon + 432 (HIToolbox + 199921) [0x7fff814e0cf1] 1-10
                         *8  ipc_mqueue_receive_continue + 0 (kernel + 862304) [0xffffff80002d2860] 1-8
  <process clamped>
                         *2  ipc_mqueue_receive_continue + 0 (kernel + 862304) [0xffffff80002d2860] 9-10
  Thread 0x11f6             Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 46 (base 46)
  <process clamped>
  Thread 0x28cbe            10 samples (1-10)         priority 31 (base 31)
  <process sudden termination clean, process unclamped, IO tier 0>
*8  wq_unpark_continue + 0 (pthread + 15190) [0xffffff7f81359b56] 1-8
  <process clamped>
*2  wq_unpark_continue + 0 (pthread + 15190) [0xffffff7f81359b56] 9-10
  Binary Images:
           0x104e38000 -        0x104e42fff  com.apple.AirPlayUIAgent 2.0 (320.18)  <3F810C5B-8F96-3408-8567-B4225FF7F76E>  /System/Library/CoreServices/AirPlayUIAgent.app/Contents/MacOS/AirPlayUIAgent
Process:         AirPlayXPCHelper [129]
Path:            /usr/libexec/AirPlayXPCHelper
Parent:          launchd [1]
UID:             0
Task size:       20.77 MB
  Thread 0x6ce              DispatchQueue 11          10 samples (1-10)         priority 20 (base 20)
  10  _dispatch_sig_thread + 41 (libdispatch.dylib + 62031) [0x7fff976ba24f] 1-10
    10  __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 106982) [0x7fff978111e6] 1-10
  Binary Images:
           0x102539000 -        0x10253afff  AirPlayXPCHelper (320.18)          <A2A06D93-12D1-30A2-959B-6D9ED81B0205>  /usr/libexec/AirPlayXPCHelper
        0x7fff976ab000 -     0x7fff976dcfff  libdispatch.dylib (703.50.37)      <D122E712-9593-31CA-BAC4-4A54410BF4A0>  /usr/lib/system/libdispatch.dylib
Process:         airportd [72]
Path:            /usr/libexec/airportd
Parent:          launchd [1]
UID:             0
Task size:       32.09 MB
  Thread 0x2e4              DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
  <thread QoS default (requested default), process sudden termination dirty, process unclamped, process received importance donation from sharingd [411], process received importance donation from WiFiProxy [528], IO tier 0>
    10  ??? (airportd + 298142) [0x10830fc9e] 1-10
  Thread 0x6b5              Thread name "com.apple.CFSocket.private"            10 samples (1-10)         priority 31 (base 31)
  Binary Images:
           0x1082c7000 -        0x1083e2fff  airportd (1200.46)                     <1A52D6C7-F435-359B-A14B-23FCB2EBFEEA>  /usr/libexec/airportd
Process:         akd [253]
Path:            /System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/Support/akd
Parent:          launchd [1]
UID:             0
Task size:       21.16 MB
  Thread 0x7e8              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  ??? (akd + 102357) [0x10ac44fd5] 1-10
  Thread 0x7f4              Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x10ac2c000 -        0x10acacfff  akd (141.0.1)                          <E8D1B327-73BF-3198-9DF3-E647964A26F9>  /System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/Support/akd
Process:         akd [354]
Parent:          launchd [1]
UID:             503
Task size:       28.16 MB
Note:            4 idle work queue threads omitted
  Thread 0xca2              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  ??? (akd + 102357) [0x10d558fd5] 1-10
  Thread 0xcec              Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x10d540000 -        0x10d5c0fff  akd (141.0.1)                           <E8D1B327-73BF-3198-9DF3-E647964A26F9>  /System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/Support/akd
Process:         amfid [130]
Path:            /usr/libexec/amfid
Parent:          launchd [1]
UID:             0
Task size:       19.06 MB
  Thread 0x38d              DispatchQueue 11          10 samples (1-10)         priority 31 (base 31)
  <thread QoS default (requested default), process sudden termination clean, IO tier 0>
  Binary Images:
           0x10efc3000 -        0x10efc9fff  amfid (225.50.12)                  <B6C62BC3-D705-354C-9A1B-68BB01970323>  /usr/libexec/amfid
Process:         AppActivity [452]
Path:            /Users/USER/Library/Application Support/AppPolicy/AppActivity
Parent:          launchd [1]
UID:             503
Task size:       14.44 MB
  Thread 0xfe4              DispatchQueue 1           10 samples (1-10)         priority 20 (base 20)
  10  start + 52 (AppActivity + 4548) [0x1000011c4] 1-10
    10  main + 7127 (AppActivity + 173127) [0x10002a447] 1-10
  Binary Images:
           0x100000000 -        0x100041fff  AppActivity                            <55420A9F-ADC1-338F-A565-DFF617E08BE6>  /Users/USER/Library/Application Support/AppPolicy/AppActivity
Process:         apple.DevicePropertyReader [5466]
Path:            /System/Library/Image Capture/Devices/PTPCamera.app/Contents/XPCServices/apple.DevicePropertyReader.xpc/Contents/MacOS/apple.DevicePropertyReader
Parent:          launchd [1]
Responsible:     PTPCamera [5463]
UID:             503
Task size:       15.89 MB
  Thread 0x20288            10 samples (1-10)         priority 4 (base 4)
  Binary Images:
Process:         appleeventsd [57]
Path:            /System/Library/CoreServices/appleeventsd
Parent:          launchd [1]
UID:             55
Task size:       13.99 MB
  Thread 0x4fb              DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
  <thread QoS background (requested default), thread darwinbg, process darwinbg, IO tier 2>
  Binary Images:
           0x1000c2000 -        0x1000c2fff  appleeventsd (712.5)               <04BA7041-9063-3F04-B0BB-5DE3ECB6C013>  /System/Library/CoreServices/appleeventsd
Process:         AppleIDAuthAgent [355]
Path:            /System/Library/CoreServices/AppleIDAuthAgent
Parent:          launchd [1]
UID:             503
Task size:       30.95 MB
  Thread 0xca3              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
  <thread QoS background (requested default), process sudden termination dirty, thread darwinbg, process darwinbg, IO tier 2>
    10  ??? (AppleIDAuthAgent + 10824) [0x107643a48] 1-10
      10  CFRunLoopRun + 97 (CoreFoundation + 814129) [0x7fff81fbec31] 1-10
  Thread 0x1470             DispatchQueue 18          10 samples (1-10)         priority 4 (base 4)
  <thread QoS background (requested default, override user initiated), process sudden termination dirty, thread darwinbg, process darwinbg, IO tier 2>
  10  start_wqthread + 13 (libsystem_pthread.dylib + 12529) [0x7fff978fb0f1] 1-10
    10  _pthread_wqthread + 1299 (libsystem_pthread.dylib + 13846) [0x7fff978fb616] 1-10
      10  _dispatch_worker_thread3 + 99 (libdispatch.dylib + 13452) [0x7fff976ae48c] 1-10
        10  _dispatch_root_queue_drain + 476 (libdispatch.dylib + 14005) [0x7fff976ae6b5] 1-10
          10  _dispatch_queue_invoke + 1046 (libdispatch.dylib + 41734) [0x7fff976b5306] 1-10
            10  _dispatch_queue_serial_drain + 443 (libdispatch.dylib + 96219) [0x7fff976c27db] 1-10
              10  _dispatch_source_invoke + 1248 (libdispatch.dylib + 16699) [0x7fff976af13b] 1-10
                10  _dispatch_source_latch_and_call + 194 (libdispatch.dylib + 51820) [0x7fff976b7a6c] 1-10
                  10  _dispatch_continuation_pop + 533 (libdispatch.dylib + 92694) [0x7fff976c1a16] 1-10
                    10  _dispatch_client_callout + 8 (libdispatch.dylib + 6396) [0x7fff976ac8fc] 1-10
                      10  ??? (AppleIDAuthAgent + 25705) [0x107647469] 1-10
                        10  _dispatch_semaphore_wait_slow + 58 (libdispatch.dylib + 43108) [0x7fff976b5864] 1-10
                          10  semaphore_timedwait_trap + 10 (libsystem_kernel.dylib + 74654) [0x7fff9780939e] 1-10
  Thread 0x14f2             10 samples (1-10)         priority 4 (base 4)
  Thread 0x166c             Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x107641000 -        0x107684fff  AppleIDAuthAgent (775.19)               <B4035FFE-7812-3E21-B2F5-02CEBDFC8171>  /System/Library/CoreServices/AppleIDAuthAgent
Process:         AppleSpell [2689]
Path:            /System/Library/Services/AppleSpell.service/Contents/MacOS/AppleSpell
Parent:          launchd [1]
UID:             503
Task size:       81.16 MB
  Thread 0xc830             DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
    10  ??? (AppleSpell + 8648) [0x1098fb1c8] 1-10
      10  -[NSSpellServer run] + 73 (Foundation + 2086692) [0x7fff83b6c724] 1-10
  Binary Images:
           0x1098f9000 -        0x1099f8fff  com.apple.AppleSpell 2.4 (389)         <00AE3ABF-3C83-33BF-8A49-17C38946F37F>  /System/Library/Services/AppleSpell.service/Contents/MacOS/AppleSpell
Process:         AppStatus [459]
Path:            /Users/USER/Library/Application Support/AppCommon/AppStatus
Parent:          launchd [1]
UID:             503
Task size:       18.56 MB
  Thread 0xfe6              DispatchQueue 1           10 samples (1-10)         priority 20 (base 20)
  10  start + 52 (AppStatus + 6948) [0x100001b24] 1-10
    10  main + 12591 (AppStatus + 451647) [0x10006e43f] 1-10
  Thread 0x4653             Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 20 (base 20)
  Binary Images:
           0x100000000 -        0x1000dafff  AppStatus                              <EC2E7301-9F78-3D8A-8C20-9FE1079414B4>  /Users/USER/Library/Application Support/AppCommon/AppStatus
Process:         apsd [101]
Path:            /System/Library/PrivateFrameworks/ApplePushService.framework/apsd
Parent:          launchd [1]
UID:             0
Task size:       49.00 MB
  Thread 0x2bd              DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
  <thread QoS default (requested default), IO tier 0>
    10  ??? (apsd + 389558) [0x1054e31b6] 1-10
  Thread 0xe76              Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 31 (base 31)
  Thread 0x4f0b             10 samples (1-10)         priority 37 (base 37)
  <thread QoS user initiated (requested user interactive), IO tier 0>
  Thread 0x7185             Thread name "com.apple.CFSocket.private"            10 samples (1-10)         priority 31 (base 31)
  Binary Images:
           0x105484000 -        0x10554efff  apsd (305.1)                            <818B3867-774D-3408-B919-7F6346DAD6EA>  /System/Library/PrivateFrameworks/ApplePushService.framework/apsd
Process:         ARDAgent [345]
Path:            /System/Library/CoreServices/RemoteManagement/ARDAgent.app/Contents/MacOS/ARDAgent
Parent:          launchd [1]
UID:             503
Task size:       21.22 MB
  Thread 0xc18              DispatchQueue 1           10 samples (1-10)         priority 20 (base 20)
    10  ??? (ARDAgent + 6081) [0x1093f57c1] 1-10
  Thread 0xc4f              10 samples (1-10)         priority 20 (base 20)
  Thread 0xc51              10 samples (1-10)         priority 97 (base 97)
  <thread QoS utility, timers tier 3 (coalesced), IO tier 1>
  Thread 0x11ee             10 samples (1-10)         priority 20 (base 20)
        10  ??? (ARDAgent + 49751) [0x109400257] 1-10
          10  _dispatch_semaphore_wait_slow + 103 (libdispatch.dylib + 43153) [0x7fff976b5891] 1-10
            10  semaphore_wait_trap + 10 (libsystem_kernel.dylib + 74630) [0x7fff97809386] 1-10
  Thread 0x11f1             10 samples (1-10)         priority 20 (base 20)
        10  ??? (ARDAgent + 53009) [0x109400f11] 1-10
  Thread 0x11f2             10 samples (1-10)         priority 20 (base 20)
        10  __accept + 10 (libsystem_kernel.dylib + 102594) [0x7fff978100c2] 1-10
         *10  hndl_unix_scall64 + 22 (kernel + 646470) [0xffffff800029dd46] 1-10
           *10  unix_syscall64 + 597 (kernel + 6444693) [0xffffff8000825695] 1-10
             *10  accept_nocancel + 482 (kernel + 6133394) [0xffffff80007d9692] 1-10
  Thread 0x32d19            10 samples (1-10)         priority 20 (base 20)
*10  wq_unpark_continue + 0 (pthread + 15190) [0xffffff7f81359b56] 1-10
  Binary Images:
           0x1093f4000 -        0x1094f7fff  com.apple.RemoteDesktopAgent 3.9.2 (3.9.2) <57C03F35-34ED-3521-ACD3-4B6A76423EAD>  /System/Library/CoreServices/RemoteManagement/ARDAgent.app/Contents/MacOS/ARDAgent
Process:         askpermissiond [359]
Path:            /System/Library/PrivateFrameworks/AskPermission.framework/Versions/A/Resources/askpermissiond
Parent:          launchd [1]
UID:             503
Task size:       21.27 MB
  Thread 0xca4              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  ??? (askpermissiond + 52455) [0x1001ebce7] 1-10
  Binary Images:
           0x1001df000 -        0x1001f9fff  askpermissiond (78)                    <1A812667-3249-33DD-B3AE-9F2C2E054177>  /System/Library/PrivateFrameworks/AskPermission.framework/Versions/A/Resources/askpermissiond
Process:         aslmanager [144]
Path:            /usr/sbin/aslmanager
Parent:          launchd [1]
UID:             0
Task size:       8548 KB
  Thread 0x3aa              DispatchQueue 11          10 samples (1-10)         priority 31 (base 31)
  <thread QoS default (requested default), process sudden termination clean, IO tier 3>
  Binary Images:
           0x10bee1000 -        0x10beeafff  aslmanager (349.50.5)              <3D79D9F7-A61E-33FB-A878-611D0123F7FA>  /usr/sbin/aslmanager
Process:         AssetCache [377]
Path:            /usr/libexec/AssetCache/AssetCache
Parent:          launchd [1]
UID:             235
Task size:       17.28 MB
  Thread 0xd11              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  ??? (AssetCache + 6119) [0x10a9eb7e7] 1-10
      10  ??? (AssetCache + 76716) [0x10a9fcbac] 1-10
        10  ??? (AssetCache + 79432) [0x10a9fd648] 1-10
  Binary Images:
           0x10a9ea000 -        0x10ad1bfff  AssetCache (170)                       <192D7EAD-1094-3C68-A51A-C1CF04899F1A>  /usr/libexec/AssetCache/AssetCache
Process:         AssetCacheLocatorService [943]
Path:            /System/Library/PrivateFrameworks/AssetCacheServices.framework/Versions/A/XPCServices/AssetCacheLocatorService.xpc/Contents/MacOS/AssetCacheLocatorService
Parent:          launchd [1]
UID:             503
Task size:       11.78 MB
  Thread 0x1ec2             DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  main + 71 (AssetCacheLocatorService + 34884) [0x1060c1844] 1-10
      10  -[AssetCacheLocatorService start] + 626 (AssetCacheLocatorService + 57455) [0x1060c706f] 1-10
  Binary Images:
           0x1060b9000 -        0x1060f3fff  com.apple.AssetCacheLocatorService 48.3 (48.3) <6FD939E9-7C1D-37B8-9DB8-8850F5E1D431>  /System/Library/PrivateFrameworks/AssetCacheServices.framework/Versions/A/XPCServices/AssetCacheLocatorService.xpc/Contents/MacOS/AssetCacheLocatorService
Process:         assistant_service [1942]
Path:            /System/Library/PrivateFrameworks/AssistantServices.framework/assistant_service
Parent:          launchd [1]
UID:             503
Task size:       96.44 MB
  Thread 0x780e             DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  ??? (assistant_service + 5509) [0x1036ca585] 1-10
  Thread 0x33e98            10 samples (1-10)         priority 4 (base 4)
  <thread QoS background, process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2>
  Binary Images:
           0x1036c9000 -        0x1036d3fff  assistant_service (1394.57)            <5740FA7A-C79C-3B98-B9B9-411330E05521>  /System/Library/PrivateFrameworks/AssistantServices.framework/assistant_service
Process:         assistantd [420]
Path:            /System/Library/PrivateFrameworks/AssistantServices.framework/assistantd
Parent:          launchd [1]
UID:             503
Task size:       75.89 MB
  Thread 0x14d3             DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  ??? (assistantd + 31052) [0x101cc594c] 1-10
      10  ??? (assistantd + 32861) [0x101cc605d] 1-10
  Thread 0x7260             Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4 (base 4)
  Thread 0x77f5             Thread name "com.apple.CFStream.LegacyThread"       10 samples (1-10)         priority 4 (base 4)
        10  _legacyStreamRunLoop_workThread + 261 (CoreFoundation + 1435189) [0x7fff82056635] 1-10
  Thread 0x1ff8f            Thread name "AVVC Rec Queue RunLoop"                10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x101cbe000 -        0x102067fff  assistantd (1394.57)                    <F039C269-B2F8-3262-9E6A-085B0BDDC644>  /System/Library/PrivateFrameworks/AssistantServices.framework/assistantd
Process:         authd [140]
Path:            /System/Library/Frameworks/Security.framework/Versions/A/XPCServices/authd.xpc/Contents/MacOS/authd
Parent:          launchd [1]
UID:             0
Task size:       17.16 MB
  Thread 0x375              DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
  Thread 0x376              DispatchQueue 10          10 samples (1-10)         priority 4 (base 4)
        10  _dispatch_root_queue_drain + 917 (libdispatch.dylib + 14446) [0x7fff976ae86e] 1-10
            10  _dispatch_call_block_and_release + 12 (libdispatch.dylib + 42276) [0x7fff976b5524] 1-10
              10  ??? (authd + 13476) [0x104cc44a4] 1-10
                10  au_sdev_read_aia + 569 (libbsm.0.dylib + 60343) [0x7fff96262bb7] 1-10
                  10  fgetc + 52 (libsystem_c.dylib + 253401) [0x7fff97754dd9] 1-10
                    10  __srget + 14 (libsystem_c.dylib + 280754) [0x7fff9775b8b2] 1-10
                      10  __srefill1 + 24 (libsystem_c.dylib + 280471) [0x7fff9775b797] 1-10
                        10  __read_nocancel + 10 (libsystem_kernel.dylib + 105926) [0x7fff97810dc6] 1-10
                                   *10  spec_read + 201 (kernel + 3497273) [0xffffff8000555d39] 1-10
                                     *10  ??? (kernel + 5438740) [0xffffff800072fd14] 1-10
  Binary Images:
           0x104cc1000 -        0x104cd8fff  com.apple.authd 1.0 ()             <D7484BAE-15D5-31A4-8C05-C4C939362366>  /System/Library/Frameworks/Security.framework/Versions/A/XPCServices/authd.xpc/Contents/MacOS/authd
        0x7fff96254000 -     0x7fff96264fff  libbsm.0.dylib (34)                <20084796-B04D-3B35-A003-EA11459557A9>  /usr/lib/libbsm.0.dylib
Process:         autofsd [115]
Path:            /usr/libexec/autofsd
Parent:          launchd [1]
UID:             0
Task size:       7688 KB
  Thread 0x406              DispatchQueue 11          10 samples (1-10)         priority 20 (base 20)
  <thread QoS utility (requested default), process sudden termination clean, timers tier 3 (coalesced), IO tier 1>
  Binary Images:
           0x108a58000 -        0x108a58fff  autofsd (259.30.2)                 <36268EDC-126D-39D6-82FC-C9DADF0F6227>  /usr/libexec/autofsd
Process:         awacsd [206]
Path:            /usr/libexec/awacsd
Parent:          launchd [1]
UID:             0
Task size:       26.18 MB
  Thread 0x572              DispatchQueue 11          10 samples (1-10)         priority 20 (base 20)
  <thread QoS utility (requested default), process sudden termination dirty, timers tier 3 (coalesced), IO tier 1>
  Thread 0x5f5              Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 20 (base 20)
  Thread 0x7bbe             Thread name "com.apple.CFSocket.private"            10 samples (1-10)         priority 20 (base 20)
  <thread QoS utility (requested utility), process sudden termination dirty, timers tier 3 (coalesced), IO tier 1>
  Thread 0x355d0            10 samples (1-10)         priority 20 (base 20)
  <thread QoS utility, process sudden termination dirty, timers tier 3 (coalesced), IO tier 1>
  Binary Images:
           0x10842a000 -        0x1084a4fff  awacsd (118.20.1)                       <B125474E-010F-39C5-8A33-9A9854234F8A>  /usr/libexec/awacsd
Process:         awdd [233]
Path:            /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Support/awdd
Parent:          launchd [1]
UID:             0
Task size:       15.82 MB
  Thread 0x6b2              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  ??? (awdd + 21475) [0x1086493e3] 1-10
  Binary Images:
           0x108644000 -        0x108729fff  awdd (869)                             <F49410F8-D2A5-366E-8D18-7FAA5BB521C6>  /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Support/awdd
Process:         bash [69]
Path:            /bin/bash
Parent:          launchd [1]
UID:             0
Task size:       2476 KB
  Thread 0x2d4              DispatchQueue 1           10 samples (1-10)         priority 20 (base 20)
    10  ??? (bash + 7616) [0x1043a8dc0] 1-10
      10  ??? (bash + 116303) [0x1043c364f] 1-10
        10  ??? (bash + 117276) [0x1043c3a1c] 1-10
          10  ??? (bash + 129203) [0x1043c68b3] 1-10
            10  ??? (bash + 157036) [0x1043cd56c] 1-10
              10  __wait4 + 10 (libsystem_kernel.dylib + 107502) [0x7fff978113ee] 1-10
  Binary Images:
           0x1043a7000 -        0x10442afff  bash (103.50.1)                    <E16744EF-F6E7-3AAD-9D54-3CCE90F8ABA1>  /bin/bash
Process:         BetterTouchTool [3528]
Path:            /Applications/BetterTouchTool.app/Contents/MacOS/BetterTouchTool
Parent:          launchd [1]
UID:             503
Task size:       65.75 MB
CPU Time:        <0.001
Process:         biokitaggdd [256]
Path:            /usr/libexec/biokitaggdd
Parent:          launchd [1]
UID:             0
Task size:       9212 KB
  Thread 0x81a              10 samples (1-10)         priority 4 (base 4)
  <thread QoS background (requested background), thread darwinbg, process darwinbg, IO tier 2>
  Binary Images:
           0x106440000 -        0x106446fff  biokitaggdd (5.50.1)               <5A3BD8E8-F140-34C5-97F2-3852AD0C5767>  /usr/libexec/biokitaggdd
Process:         biometrickitd [227]
Path:            /usr/libexec/biometrickitd
Parent:          launchd [1]
UID:             0
Task size:       22.40 MB
Note:            2 idle work queue threads omitted
  Thread 0x662              DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
    10  ??? (biometrickitd + 312949) [0x1029d1675] 1-10
  Binary Images:
           0x102985000 -        0x102a06fff  biometrickitd (424.16)                 <D9177D22-1466-34D4-98E4-72434F11E7CF>  /usr/libexec/biometrickitd
Process:         bird [328]
Path:            /System/Library/PrivateFrameworks/CloudDocsDaemon.framework/Versions/A/Support/bird
Parent:          launchd [1]
UID:             503
Task size:       32.82 MB
  Thread 0xb8f              DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
  <thread QoS default (requested default), process sudden termination dirty, process unclamped, process received importance donation from Finder [325], IO tier 0>
    10  ??? (bird + 6002) [0x1008b5772] 1-10
  Binary Images:
           0x1008b4000 -        0x1008b5fff  bird (486.28)                          <4361594B-F3A5-3534-9E92-BAC5C54B6433>  /System/Library/PrivateFrameworks/CloudDocsDaemon.framework/Versions/A/Support/bird
Process:         blued [114]
Path:            /usr/sbin/blued
Parent:          launchd [1]
UID:             0
Task size:       17.96 MB
  Thread 0x2cb              DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
    10  ??? (blued + 187775) [0x106af2d7f] 1-10
  Thread 0x731              Thread name "com.apple.CFSocket.private"            10 samples (1-10)         priority 31 (base 31)
  Binary Images:
           0x106ac5000 -        0x106b98fff  blued (5004.4.18)                      <0675C360-4485-3399-A0D5-F7EBAB1DF761>  /usr/sbin/blued
Process:         BTTRelaunch [3530]
Path:            /Applications/BetterTouchTool.app/Contents/Resources/BTTRelaunch.app/Contents/MacOS/BTTRelaunch
Parent:          launchd [1]
UID:             503
Task size:       24.24 MB
Process:         CalendarAgent [445]
Path:            /System/Library/PrivateFrameworks/CalendarAgent.framework/Executables/CalendarAgent
Parent:          launchd [1]
UID:             503
Task size:       68.07 MB
  Thread 0x12a7             DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  ??? (CalendarAgent + 6233) [0x109af8859] 1-10
  Thread 0x1e1d             Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x109af7000 -        0x109af8fff  CalendarAgent (386)                     <0EAFB1E4-7D3B-3122-AF64-2CD36B4CAA26>  /System/Library/PrivateFrameworks/CalendarAgent.framework/Executables/CalendarAgent
Process:         CallHistoryPluginHelper [544]
Path:            /System/Library/PrivateFrameworks/CallHistory.framework/Support/CallHistoryPluginHelper
Parent:          launchd [1]
UID:             503
Task size:       26.20 MB
  Thread 0x134b             DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  ??? (CallHistoryPluginHelper + 5507) [0x10180a583] 1-10
  Binary Images:
           0x101809000 -        0x10180afff  CallHistoryPluginHelper (676)          <65E39669-058F-3925-A072-FE0D4254EE09>  /System/Library/PrivateFrameworks/CallHistory.framework/Support/CallHistoryPluginHelper
Process:         CallHistorySyncHelper [358]
Path:            /System/Library/PrivateFrameworks/CallHistory.framework/Support/CallHistorySyncHelper
Parent:          launchd [1]
UID:             503
Task size:       27.29 MB
  Thread 0xca8              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  ??? (CallHistorySyncHelper + 70400) [0x10ea57300] 1-10
  Binary Images:
           0x10ea46000 -        0x10ea66fff  CallHistorySyncHelper (676)            <13886907-B5B0-31D8-A466-75AB561E6B08>  /System/Library/PrivateFrameworks/CallHistory.framework/Support/CallHistorySyncHelper
Process:         callservicesd [327]
Path:            /System/Library/PrivateFrameworks/TelephonyUtilities.framework/callservicesd
Parent:          launchd [1]
UID:             503
Task size:       53.48 MB
  Thread 0xb8b              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  ??? (callservicesd + 914458) [0x10475e41a] 1-10
  Binary Images:
           0x10467f000 -        0x1047c2fff  callservicesd (838.3.7)                <2447A0E6-3C5B-3415-842E-845B910A7195>  /System/Library/PrivateFrameworks/TelephonyUtilities.framework/callservicesd
Process:         CalNCService [536]
Path:            /System/Library/PrivateFrameworks/CalendarNotification.framework/Versions/A/XPCServices/CalNCService.xpc/Contents/MacOS/CalNCService
Parent:          launchd [1]
Responsible:     CalendarAgent [445]
UID:             503
Task size:       49.80 MB
  Thread 0x12dc             DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  main + 111 (CalNCService + 45654) [0x10ba90256] 1-10
      10  -[NSXPCListener resume] + 165 (Foundation + 524571) [0x7fff839ef11b] 1-10
        10  xpc_main + 494 (libxpc.dylib + 62180) [0x7fff9793a2e4] 1-10
          10  _xpc_objc_main + 731 (libxpc.dylib + 67739) [0x7fff9793b89b] 1-10
  Binary Images:
           0x10ba85000 -        0x10ba93fff  com.apple.CalendarNotification.CalNCService 1.0 (507.6) <18ED1256-D076-3514-A4DD-132269BDA25B>  /System/Library/PrivateFrameworks/CalendarNotification.framework/Versions/A/XPCServices/CalNCService.xpc/Contents/MacOS/CalNCService
        0x7fff9792b000 -     0x7fff97954fff  libxpc.dylib (972.50.27)                                <ABC45890-DA23-3A4A-B50B-1384BD4CBBDF>  /usr/lib/system/libxpc.dylib
Process:         captiveagent [951]
Path:            /usr/libexec/captiveagent
Parent:          launchd [1]
UID:             258
Task size:       13.32 MB
  Thread 0x1f1a             DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
  <thread QoS default (requested default), process sudden termination clean, process unclamped, process received importance donation from configd [58], IO tier 0>
  Thread 0x1f1e             Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 31 (base 31)
  Thread 0x70dc             Thread name "com.apple.CFSocket.private"            10 samples (1-10)         priority 31 (base 31)
  Binary Images:
           0x10834e000 -        0x108355fff  captiveagent (346.50.1)            <3DF3F257-09F4-302E-8ED2-81164EE81D86>  /usr/libexec/captiveagent
Process:         cfprefsd [135]
Path:            /usr/sbin/cfprefsd
Parent:          launchd [1]
UID:             0
Task size:       9276 KB
CPU Time:        <0.001
  Thread 0x33f              DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x10db26000 -        0x10db26fff  cfprefsd (1349.65)                 <1A1890FC-5C36-3055-A293-C955B09CBAB3>  /usr/sbin/cfprefsd
Process:         cfprefsd [312]
Parent:          launchd [1]
UID:             503
Task size:       14.58 MB
CPU Time:        <0.001
Note:            6 idle work queue threads omitted
  Thread 0xa54              DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x101ee2000 -        0x101ee2fff  cfprefsd (1349.65)                 <1A1890FC-5C36-3055-A293-C955B09CBAB3>  /usr/sbin/cfprefsd
Process:         Citations [473]
Path:            /Applications/Papers.app/Contents/SharedSupport/Citations.app/Contents/MacOS/Citations
Parent:          launchd [1]
UID:             503
Task size:       65.59 MB
Process:         CleanApp Daemon [3686]
Path:            /Library/Application Support/CleanApp/CleanApp Daemon.app/Contents/MacOS/CleanApp Daemon
Architecture:    i386
Parent:          launchd [1]
UID:             0
Task size:       18.85 MB
CPU Time:        <0.001
Process:         cloudd [350]
Path:            /System/Library/PrivateFrameworks/CloudKitDaemon.framework/Support/cloudd
Parent:          launchd [1]
UID:             503
Task size:       44.93 MB
Note:            10 idle work queue threads omitted
  Thread 0xc59              DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
  <thread QoS default (requested default), process sudden termination clean, process unclamped, process received importance donation from Safari [4589], IO tier 0>
    10  ??? (cloudd + 10716) [0x10d02f9dc] 1-10
  Thread 0x1d7e             Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 31 (base 31)
  Thread 0x7678             Thread name "com.apple.CFStream.LegacyThread"       10 samples (1-10)         priority 31 (base 31)
  Binary Images:
           0x10d02d000 -        0x10d032fff  cloudd (651.14)                        <E0EF61B8-731F-3698-9707-0F2297737232>  /System/Library/PrivateFrameworks/CloudKitDaemon.framework/Support/cloudd
Process:         CloudKeychainProxy [402]
Path:            /System/Library/Frameworks/Security.framework/Versions/A/Resources/CloudKeychainProxy.bundle/Contents/MacOS/CloudKeychainProxy
Parent:          launchd [1]
UID:             503
Task size:       21.36 MB
  Thread 0xe5d              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  ??? (CloudKeychainProxy + 48371) [0x109638cf3] 1-10
  Binary Images:
           0x10962d000 -        0x109641fff  com.apple.security.cloudkeychainproxy3 10.0 () <6A636FFB-2181-3E94-85AD-EB677C09D7F2>  /System/Library/Frameworks/Security.framework/Versions/A/Resources/CloudKeychainProxy.bundle/Contents/MacOS/CloudKeychainProxy
Process:         cloudpaird [448]
Path:            /System/Library/CoreServices/cloudpaird
Parent:          launchd [1]
UID:             503
Task size:       26.18 MB
  Thread 0x14e2             DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  ??? (cloudpaird + 64917) [0x1071d2d95] 1-10
  Binary Images:
           0x1071c3000 -        0x1071e0fff  cloudpaird (5004.4.18)                 <AD97547C-2247-31C1-A4EA-2264E11ADA53>  /System/Library/CoreServices/cloudpaird
Process:         cloudphotosd [347]
Path:            /System/Library/CoreServices/cloudphotosd.app/Contents/MacOS/cloudphotosd
Parent:          launchd [1]
UID:             503
Task size:       55.80 MB
  Thread 0xc56              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  main + 115 (cloudphotosd + 738778) [0x105da25da] 1-10
  Thread 0xf6d              Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 4 (base 4)
  <thread QoS background (requested user interactive), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2>
  Thread 0x1eba             10 samples (1-10)         priority 4 (base 4)
  Thread 0x1ebd             10 samples (1-10)         priority 4 (base 4)
  Thread 0x1ec5             Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x105cee000 -        0x105de0fff  com.apple.cloudphotosd 2.0 (3150.4.120) <1C223A5B-85FC-32B2-8E0F-D4A67FACE558>  /System/Library/CoreServices/cloudphotosd.app/Contents/MacOS/cloudphotosd
Process:         com.apple.accessibility.mediaaccessibilityd [1932]
Path:            /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/XPCServices/com.apple.accessibility.mediaaccessibilityd.xpc/Contents/MacOS/com.apple.accessibility.mediaaccessibilityd
Parent:          launchd [1]
UID:             503
Task size:       7672 KB
  Thread 0x7789             DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x10b20b000 -        0x10b20cfff  com.apple.accessibility.mediaaccessibilityd 1.0 (1) <98ACFA8C-EC73-3497-9644-32A817DC96A8>  /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/XPCServices/com.apple.accessibility.mediaaccessibilityd.xpc/Contents/MacOS/com.apple.accessibility.mediaaccessibilityd
Process:         com.apple.AccountPolicyHelper [290]
Path:            /System/Library/PrivateFrameworks/AccountPolicy.framework/XPCServices/com.apple.AccountPolicyHelper.xpc/Contents/MacOS/com.apple.AccountPolicyHelper
Parent:          launchd [1]
UID:             0
Task size:       8196 KB
  Thread 0x941              DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x1001f5000 -        0x1001fefff  com.apple.AccountPolicyHelper 1.0 (1) <5A295718-2EDC-307E-A73F-FEF88E7427EB>  /System/Library/PrivateFrameworks/AccountPolicy.framework/XPCServices/com.apple.AccountPolicyHelper.xpc/Contents/MacOS/com.apple.AccountPolicyHelper
Process:         com.apple.AmbientDisplayAgent [254]
Path:            /System/Library/PrivateFrameworks/AmbientDisplay.framework/Versions/A/XPCServices/com.apple.AmbientDisplayAgent.xpc/Contents/MacOS/com.apple.AmbientDisplayAgent
Parent:          launchd [1]
UID:             0
Task size:       15.45 MB
  Thread 0x7f6              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  main + 312 (com.apple.AmbientDisplayAgent + 8932) [0x10ee302e4] 1-10
  Thread 0x873              10 samples (1-10)         priority 4 (base 4)
        10  ??? (com.apple.AmbientDisplayAgent + 10552) [0x10ee30938] 1-10
  Binary Images:
           0x10ee2e000 -        0x10ee34fff  com.apple.AmbientDisplayAgent 1.0 (1)  <13CCDBE2-0ED7-37A4-A05C-9662D6ED9280>  /System/Library/PrivateFrameworks/AmbientDisplay.framework/Versions/A/XPCServices/com.apple.AmbientDisplayAgent.xpc/Contents/MacOS/com.apple.AmbientDisplayAgent
Process:         com.apple.audio.ComponentHelper [5431]
Path:            /System/Library/Frameworks/AudioToolbox.framework/XPCServices/com.apple.audio.ComponentHelper.xpc/Contents/MacOS/com.apple.audio.ComponentHelper
Parent:          launchd [1]
Responsible:     assistantd [420]
UID:             503
Task size:       9324 KB
  Thread 0x1ff78            10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x10a015000 -        0x10a016fff  com.apple.audio.ComponentHelper 1.0.1 (1) <10948385-A27A-3918-8095-EBAFA2E5B0D2>  /System/Library/Frameworks/AudioToolbox.framework/XPCServices/com.apple.audio.ComponentHelper.xpc/Contents/MacOS/com.apple.audio.ComponentHelper
Process:         com.apple.audio.DriverHelper [216]
Path:            /System/Library/Frameworks/CoreAudio.framework/Versions/A/XPCServices/com.apple.audio.DriverHelper.xpc/Contents/MacOS/com.apple.audio.DriverHelper
Parent:          launchd [1]
Responsible:     coreaudiod [212]
UID:             202
Task size:       9768 KB
  Thread 0x5dd              DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x1085da000 -        0x1085dcfff  com.apple.audio.DriverHelper 1.0 (1) <D25F3404-3146-39B9-A8BA-0ED1F4D0CF0C>  /System/Library/Frameworks/CoreAudio.framework/Versions/A/XPCServices/com.apple.audio.DriverHelper.xpc/Contents/MacOS/com.apple.audio.DriverHelper
Process:         com.apple.audio.SandboxHelper [295]
Path:            /System/Library/Frameworks/AudioToolbox.framework/XPCServices/com.apple.audio.SandboxHelper.xpc/Contents/MacOS/com.apple.audio.SandboxHelper
Parent:          launchd [1]
Responsible:     systemsoundserverd [292]
UID:             0
Task size:       11.80 MB
  Thread 0x95a              DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x10ddc8000 -        0x10ddccfff  com.apple.audio.SandboxHelper 1.0.1 (1) <4C1181EF-4313-3FDE-B8F9-F1D29E990E41>  /System/Library/Frameworks/AudioToolbox.framework/XPCServices/com.apple.audio.SandboxHelper.xpc/Contents/MacOS/com.apple.audio.SandboxHelper
Process:         com.apple.audio.SandboxHelper [623]
Parent:          launchd [1]
UID:             503
Task size:       11.91 MB
  Thread 0x1627             DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x1032a6000 -        0x1032aafff  com.apple.audio.SandboxHelper 1.0.1 (1) <4C1181EF-4313-3FDE-B8F9-F1D29E990E41>  /System/Library/Frameworks/AudioToolbox.framework/XPCServices/com.apple.audio.SandboxHelper.xpc/Contents/MacOS/com.apple.audio.SandboxHelper
Process:         com.apple.audio.SandboxHelper [4703]
Parent:          launchd [1]
Responsible:     Mail [1964]
UID:             503
Task size:       11.34 MB
  Thread 0x1a825            DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x10ba32000 -        0x10ba36fff  com.apple.audio.SandboxHelper 1.0.1 (1) <4C1181EF-4313-3FDE-B8F9-F1D29E990E41>  /System/Library/Frameworks/AudioToolbox.framework/XPCServices/com.apple.audio.SandboxHelper.xpc/Contents/MacOS/com.apple.audio.SandboxHelper
Process:         com.apple.audio.SandboxHelper [4896]
Parent:          launchd [1]
Responsible:     Safari [4589]
UID:             503
Task size:       11.43 MB
  Thread 0x1bfe4            DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x10ddb9000 -        0x10ddbdfff  com.apple.audio.SandboxHelper 1.0.1 (1) <4C1181EF-4313-3FDE-B8F9-F1D29E990E41>  /System/Library/Frameworks/AudioToolbox.framework/XPCServices/com.apple.audio.SandboxHelper.xpc/Contents/MacOS/com.apple.audio.SandboxHelper
Process:         com.apple.audio.SandboxHelper [5097]
Parent:          launchd [1]
UID:             503
Task size:       11.37 MB
  Thread 0x1d974            DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x103e6d000 -        0x103e71fff  com.apple.audio.SandboxHelper 1.0.1 (1) <4C1181EF-4313-3FDE-B8F9-F1D29E990E41>  /System/Library/Frameworks/AudioToolbox.framework/XPCServices/com.apple.audio.SandboxHelper.xpc/Contents/MacOS/com.apple.audio.SandboxHelper
Process:         com.apple.audio.SandboxHelper [5434]
Parent:          launchd [1]
Responsible:     com.apple.speech.speechsynthesisd [5432]
UID:             503
Task size:       11.20 MB
  Thread 0x2004f            10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x101241000 -        0x101245fff  com.apple.audio.SandboxHelper 1.0.1 (1) <4C1181EF-4313-3FDE-B8F9-F1D29E990E41>  /System/Library/Frameworks/AudioToolbox.framework/XPCServices/com.apple.audio.SandboxHelper.xpc/Contents/MacOS/com.apple.audio.SandboxHelper
Process:         com.apple.audio.SandboxHelper [7740]
Parent:          launchd [1]
UID:             503
Task size:       11.81 MB
  Thread 0x30ddb            DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x100847000 -        0x10084bfff  com.apple.audio.SandboxHelper 1.0.1 (1) <4C1181EF-4313-3FDE-B8F9-F1D29E990E41>  /System/Library/Frameworks/AudioToolbox.framework/XPCServices/com.apple.audio.SandboxHelper.xpc/Contents/MacOS/com.apple.audio.SandboxHelper
Process:         com.apple.CharacterPicker.FileService [490]
Path:            /System/Library/PrivateFrameworks/CharacterPicker.framework/Versions/A/XPCServices/com.apple.CharacterPicker.FileService.xpc/Contents/MacOS/com.apple.CharacterPicker.FileService
Parent:          launchd [1]
UID:             503
Task size:       15.55 MB
  Thread 0x1115             DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  main + 16 (com.apple.CharacterPicker.FileService + 6174) [0x103b4781e] 1-10
  Binary Images:
           0x103b46000 -        0x103b4ffff  com.apple.CharacterPicker.FileService 1.0 (1) <71F01DD8-93D0-332D-9CA4-C3AD6EE25CC0>  /System/Library/PrivateFrameworks/CharacterPicker.framework/Versions/A/XPCServices/com.apple.CharacterPicker.FileService.xpc/Contents/MacOS/com.apple.CharacterPicker.FileService
Process:         com.apple.CloudPhotosConfiguration [417]
Path:            /System/Library/PrivateFrameworks/CloudPhotoServices.framework/Versions/A/Frameworks/CloudPhotosConfigurationXPC.framework/Versions/A/XPCServices/com.apple.CloudPhotosConfiguration.xpc/Contents/MacOS/com.apple.CloudPhotosConfiguration
Parent:          launchd [1]
UID:             503
Task size:       27.11 MB
  Thread 0xf66              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  main + 24 (com.apple.CloudPhotosConfiguration + 9956) [0x10b9486e4] 1-10
      10  +[CPSConfigurationService run] + 53 (com.apple.CloudPhotosConfiguration + 10276) [0x10b948824] 1-10
        10  -[CPSConfigurationService run] + 199 (com.apple.CloudPhotosConfiguration + 10488) [0x10b9488f8] 1-10
  Binary Images:
           0x10b946000 -        0x10b957fff  com.apple.CloudPhotosConfiguration 2.0 (3150.4.120) <468A73D0-DF3D-3E6C-83EC-C24BABCCD66A>  /System/Library/PrivateFrameworks/CloudPhotoServices.framework/Versions/A/Frameworks/CloudPhotosConfigurationXPC.framework/Versions/A/XPCServices/com.apple.CloudPhotosConfiguration.xpc/Contents/MacOS/com.apple.CloudPhotosConfiguration
Process:         com.apple.CodeSigningHelper [262]
Path:            /System/Library/Frameworks/Security.framework/Versions/A/XPCServices/com.apple.CodeSigningHelper.xpc/Contents/MacOS/com.apple.CodeSigningHelper
Parent:          launchd [1]
UID:             0
Task size:       10028 KB
  Thread 0x863              DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x10874f000 -        0x108750fff  com.apple.CodeSigningHelper 1.0 (1) <E659A190-F50B-3EAF-98A8-E69CD340B0EB>  /System/Library/Frameworks/Security.framework/Versions/A/XPCServices/com.apple.CodeSigningHelper.xpc/Contents/MacOS/com.apple.CodeSigningHelper
Process:         com.apple.ColorSyncXPCAgent [8010]
Path:            /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/XPCServices/com.apple.ColorSyncXPCAgent.xpc/Contents/MacOS/com.apple.ColorSyncXPCAgent
Parent:          launchd [1]
UID:             503
Task size:       6704 KB
  Thread 0x32d46            DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
  Thread 0x32d4b            10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x104c1b000 -        0x104c1dfff  com.apple.ColorSyncXPCAgent 1.0 (1) <A0E01710-46FE-338E-AAE4-55E4CFD5B873>  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/XPCServices/com.apple.ColorSyncXPCAgent.xpc/Contents/MacOS/com.apple.ColorSyncXPCAgent
Process:         com.apple.CommerceKit.TransactionService [521]
Path:            /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/XPCServices/com.apple.CommerceKit.TransactionService.xpc/Contents/MacOS/com.apple.CommerceKit.TransactionService
Parent:          launchd [1]
Responsible:     storeaccountd [389]
UID:             503
Task size:       21.62 MB
  Thread 0x1257             DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x102bdf000 -        0x102dbffff  com.apple.CommerceKit.TransactionService 1.0 (582.5) <F53996E7-9B29-32CD-962F-3BAC16B9C8DA>  /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/XPCServices/com.apple.CommerceKit.TransactionService.xpc/Contents/MacOS/com.apple.CommerceKit.TransactionService
Process:         com.apple.ctkpcscd [147]
Path:            /System/Library/Frameworks/PCSC.framework/Versions/A/XPCServices/com.apple.ctkpcscd.xpc/Contents/MacOS/com.apple.ctkpcscd
Parent:          launchd [1]
Responsible:     securityd [108]
UID:             0
Task size:       12.14 MB
  Thread 0x3d6              DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x10d631000 -        0x10d63bfff  com.apple.ctkpcscd 1.0 (1)         <850303B0-91C7-33D5-98A2-43B2FE07DD42>  /System/Library/Frameworks/PCSC.framework/Versions/A/XPCServices/com.apple.ctkpcscd.xpc/Contents/MacOS/com.apple.ctkpcscd
Process:         com.apple.DFRSystemExtra.InputMenu [547]
Path:            /System/Library/CoreServices/ControlStrip.app/Contents/XPCServices/com.apple.DFRSystemExtra.InputMenu.xpc/Contents/MacOS/com.apple.DFRSystemExtra.InputMenu
Parent:          launchd [1]
Responsible:     ControlStrip [415]
UID:             503
Task size:       27.06 MB
  Thread 0x13b4             DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
  <thread QoS default (requested user interactive), process sudden termination clean, process unclamped, IO tier 0>
    10  main + 21 (com.apple.DFRSystemExtra.InputMenu + 16051) [0x1041f7eb3] 1-10
      10  DFRSystemExtraMain + 254 (DFRFoundation + 7633) [0x7fff8df7add1] 1-10
          10  _xpc_objc_main + 775 (libxpc.dylib + 67783) [0x7fff9793b8c7] 1-10
  <process clamped>
  Thread 0x13ee             Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 31 (base 31)
  <process clamped>
  Thread 0x29282            10 samples (1-10)         priority 31 (base 31)
  <process clamped>
  Binary Images:
           0x1041f4000 -        0x1041fafff  com.apple.DFRSystemExtra.InputMenu 1.0 (1)     <7CE861D7-5801-3E6C-9395-22474A8C160F>  /System/Library/CoreServices/ControlStrip.app/Contents/XPCServices/com.apple.DFRSystemExtra.InputMenu.xpc/Contents/MacOS/com.apple.DFRSystemExtra.InputMenu
        0x7fff8df79000 -     0x7fff8df83fff  com.apple.framework.DFRFoundation 1.0 (104.25) <A509BF55-7829-3633-A500-EF0B4E21F46B>  /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation
Process:         com.apple.DFRSystemExtra.Siri [5424]
Path:            /System/Library/CoreServices/ControlStrip.app/Contents/XPCServices/com.apple.DFRSystemExtra.Siri.xpc/Contents/MacOS/com.apple.DFRSystemExtra.Siri
Parent:          launchd [1]
UID:             503
Task size:       21.58 MB
  Thread 0x1ff31            10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x1083d8000 -        0x1083d9fff  com.apple.DFRSystemExtra.Siri 1.0 (1) <31B13320-9F1F-3B49-B2C6-889E523BDE56>  /System/Library/CoreServices/ControlStrip.app/Contents/XPCServices/com.apple.DFRSystemExtra.Siri.xpc/Contents/MacOS/com.apple.DFRSystemExtra.Siri
Process:         com.apple.DictionaryServiceHelper [947]
Path:            /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/XPCServices/com.apple.DictionaryServiceHelper.xpc/Contents/MacOS/com.apple.DictionaryServiceHelper
Architecture:    x86_64
Parent:          launchd [1]
UID:             503
Task size:       7556 KB
  Thread 0x1ef2             10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x10e641000 -        0x10e646fff  com.apple.DictionaryServiceHelper 1.0 (1) <A061ECBD-D1F9-3BFE-A1A4-DC8F6C3AC8A1>  /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/XPCServices/com.apple.DictionaryServiceHelper.xpc/Contents/MacOS/com.apple.DictionaryServiceHelper
Process:         com.apple.dock.extra [517]
Path:            /System/Library/CoreServices/Dock.app/Contents/XPCServices/com.apple.dock.extra.xpc/Contents/MacOS/com.apple.dock.extra
Parent:          launchd [1]
Responsible:     Dock [322]
UID:             503
Task size:       46.21 MB
  Thread 0x11bf             DispatchQueue 1           10 samples (1-10)         priority 46 (base 46)
  <thread QoS user interactive (requested user interactive), process sudden termination dirty, process unclamped, IO tier 0>
    10  ??? (com.apple.dock.extra + 4131) [0x103d27023] 1-10
  <process clamped>
  Thread 0x1334             Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 46 (base 46)
  <process clamped>
  Thread 0x28cbf            10 samples (1-10)         priority 31 (base 31)
  <process sudden termination dirty, process unclamped, IO tier 0>
  <process clamped>
  Binary Images:
           0x103d26000 -        0x103d29fff  com.apple.dock.extra 1.0 (1)           <1EC94376-9485-3284-BE07-E89BF598D04D>  /System/Library/CoreServices/Dock.app/Contents/XPCServices/com.apple.dock.extra.xpc/Contents/MacOS/com.apple.dock.extra
Process:         com.apple.geod [407]
Path:            /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/XPCServices/com.apple.geod.xpc/Contents/MacOS/com.apple.geod
Parent:          launchd [1]
UID:             503
Task size:       31.59 MB
  Thread 0xead              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  main + 1148 (com.apple.geod + 72697) [0x10fe9fbf9] 1-10
  Thread 0xed4              Thread name "NetworkLoad" 10 samples (1-10)         priority 4 (base 4)
        10  _runNetworkThread + 445 (GeoServices + 4445674) [0x7fff903715ea] 1-10
  Thread 0xedd              Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x10fe8e000 -        0x10fea4fff  com.apple.geod 1.0 (1228.24.9.30.34)        <FDF600BB-B52A-3AE8-A5D1-51474AB17023>  /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/XPCServices/com.apple.geod.xpc/Contents/MacOS/com.apple.geod
        0x7fff8ff34000 -     0x7fff905e6fff  com.apple.GeoServices 1.0 (1228.24.9.30.34) <B482AFD6-8E27-3204-A5AA-FD73A1F32B32>  /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/GeoServices
Process:         com.apple.geod [1157]
Parent:          launchd [1]
UID:             0
Task size:       22.79 MB
  Thread 0x2ddf             DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  main + 1148 (com.apple.geod + 72697) [0x10498dbf9] 1-10
  Thread 0x2df4             Thread name "NetworkLoad" 10 samples (1-10)         priority 4 (base 4)
  Thread 0x2dfc             Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x10497c000 -        0x104992fff  com.apple.geod 1.0 (1228.24.9.30.34)    <FDF600BB-B52A-3AE8-A5D1-51474AB17023>  /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/XPCServices/com.apple.geod.xpc/Contents/MacOS/com.apple.geod
Process:         com.apple.GSSCred [298]
Path:            /System/Library/Frameworks/GSS.framework/Helpers/com.apple.GSSCred
Parent:          launchd [1]
UID:             0
Task size:       7204 KB
  Thread 0x996              DispatchQueue 8           10 samples (1-10)         priority 20 (base 20)
  <thread QoS utility (requested utility), process sudden termination clean, timers tier 3 (coalesced), IO tier 1>
              10  ??? (com.apple.GSSCred + 11079) [0x103959b47] 1-10
  Thread 0x998              DispatchQueue 11          10 samples (1-10)         priority 20 (base 20)
  Binary Images:
           0x103957000 -        0x10395efff  com.apple.GSSCred (498.50.8)       <33AAE98E-BF59-3C7E-819E-3B9B02C60AC4>  /System/Library/Frameworks/GSS.framework/Helpers/com.apple.GSSCred
Process:         com.apple.hiservices-xpcservice [899]
Path:            /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/XPCServices/com.apple.hiservices-xpcservice.xpc/Contents/MacOS/com.apple.hiservices-xpcservice
Parent:          launchd [1]
UID:             503
Task size:       11.48 MB
  Thread 0x1c69             DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x105f7b000 -        0x105f7ffff  com.apple.hiservices-xpcservice 1.22 (591) <99A12FDF-2CB2-352E-88A3-C7B93308B79A>  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/XPCServices/com.apple.hiservices-xpcservice.xpc/Contents/MacOS/com.apple.hiservices-xpcservice
Process:         com.apple.iCloudHelper [6081]
Path:            /System/Library/PrivateFrameworks/AOSKit.framework/Versions/A/XPCServices/com.apple.iCloudHelper.xpc/Contents/MacOS/com.apple.iCloudHelper
Parent:          launchd [1]
UID:             503
Task size:       24.66 MB
  Thread 0x246ac            DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x1052f2000 -        0x105304fff  com.apple.iCloudHelper 1.07 (245)  <587F020C-5AC5-3D42-B619-64FC1228BF97>  /System/Library/PrivateFrameworks/AOSKit.framework/Versions/A/XPCServices/com.apple.iCloudHelper.xpc/Contents/MacOS/com.apple.iCloudHelper
Process:         com.apple.ifdreader [225]
Path:            /System/Library/CryptoTokenKit/com.apple.ifdreader.slotd/Contents/MacOS/com.apple.ifdreader
Parent:          launchd [1]
UID:             0
Task size:       12.54 MB
  Thread 0x660              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
  10  start + 1 (libdyld.dylib + 21045) [0x7fff976e2235] 1-10
    10  main + 1179 (com.apple.ifdreader + 5165) [0x10f11c42d] 1-10
          10  CFRunLoopRunSpecific + 420 (CoreFoundation + 553412) [0x7fff81f7f1c4] 1-10
  Binary Images:
           0x10f11b000 -        0x10f126fff  com.apple.ifdreader 1.0 (1)            <BD2FF633-DB68-3DB3-8B13-FBFB9D410CD1>  /System/Library/CryptoTokenKit/com.apple.ifdreader.slotd/Contents/MacOS/com.apple.ifdreader
Process:         com.apple.iTunesLibraryService [621]
Path:            /Library/Frameworks/iTunesLibrary.framework/Versions/A/XPCServices/com.apple.iTunesLibraryService.xpc/Contents/MacOS/com.apple.iTunesLibraryService
Parent:          launchd [1]
UID:             503
Task size:       20.19 MB
  Thread 0x161d             DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x104704000 -        0x1047c3fff  com.apple.iTunesLibraryService 12.6 (12.6.0) <A29FB373-FACB-3BD9-8014-A3042EC25704>  /Library/Frameworks/iTunesLibrary.framework/Versions/A/XPCServices/com.apple.iTunesLibraryService.xpc/Contents/MacOS/com.apple.iTunesLibraryService
Process:         com.apple.iTunesLibraryService [1944]
Parent:          launchd [1]
Responsible:     assistant_service [1942]
UID:             503
Task size:       17.11 MB
  Thread 0x7825             DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x10ca60000 -        0x10cb1ffff  com.apple.iTunesLibraryService 12.6 (12.6.0) <A29FB373-FACB-3BD9-8014-A3042EC25704>  /Library/Frameworks/iTunesLibrary.framework/Versions/A/XPCServices/com.apple.iTunesLibraryService.xpc/Contents/MacOS/com.apple.iTunesLibraryService
Process:         com.apple.notificationcenterui.WeatherSummary [520]
Path:            /System/Library/CoreServices/NotificationCenter.app/Contents/XPCServices/com.apple.notificationcenterui.WeatherSummary.xpc/Contents/MacOS/com.apple.notificationcenterui.WeatherSummary
Parent:          launchd [1]
Responsible:     NotificationCenter (Notification Center) [432]
UID:             503
Task size:       18.99 MB
  Thread 0x121e             DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  main + 147 (com.apple.notificationcenterui.WeatherSummary + 6316) [0x1049fd8ac] 1-10
  Binary Images:
           0x1049fc000 -        0x1049fefff  com.apple.notificationcenterui.WeatherSummary 1.0 (552.27) <BFCC76C3-A7E0-359C-AB2C-41920F28997D>  /System/Library/CoreServices/NotificationCenter.app/Contents/XPCServices/com.apple.notificationcenterui.WeatherSummary.xpc/Contents/MacOS/com.apple.notificationcenterui.WeatherSummary
Process:         com.apple.PerformanceAnalysis.animationperfd [246]
Path:            /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/XPCServices/com.apple.PerformanceAnalysis.animationperfd.xpc/Contents/MacOS/com.apple.PerformanceAnalysis.animationperfd
Parent:          launchd [1]
UID:             0
Task size:       15.54 MB (-40 KB)
CPU Time:        <0.001
Note:            3 idle work queue threads omitted
  Thread 0x7b3              DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x103af8000 -        0x103b01fff  com.apple.PerformanceAnalysis.animationperfd 1.2 (2) <E1044B93-AC85-3D33-AF9A-9FD17D274584>  /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/XPCServices/com.apple.PerformanceAnalysis.animationperfd.xpc/Contents/MacOS/com.apple.PerformanceAnalysis.animationperfd
Process:         com.apple.PhotoIngestService [938]
Path:            /System/Library/PrivateFrameworks/PhotoLibrary.framework/Versions/A/XPCServices/com.apple.PhotoIngestService.xpc/Contents/MacOS/com.apple.PhotoIngestService
Parent:          launchd [1]
Responsible:     cloudphotosd [347]
UID:             503
Task size:       20.68 MB
  Thread 0x1eb7             DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
  10  <truncated backtrace> 1-10
  Binary Images:
           0x109225000 -        0x10922dfff  com.apple.PhotoIngestService 2.0 (3150.4.120) <EC18FB2E-5E2E-36AD-B976-4D52E040A633>  /System/Library/PrivateFrameworks/PhotoLibrary.framework/Versions/A/XPCServices/com.apple.PhotoIngestService.xpc/Contents/MacOS/com.apple.PhotoIngestService
Process:         com.apple.photomoments [935]
Path:            /System/Library/PrivateFrameworks/PhotoLibraryPrivate.framework/Versions/A/Frameworks/PhotoLibraryServices.framework/Versions/A/XPCServices/com.apple.photomoments.xpc/Contents/MacOS/com.apple.photomoments
Parent:          launchd [1]
Responsible:     photolibraryd [573]
UID:             503
Task size:       29.39 MB
  Thread 0x1e62             DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  main + 502 (com.apple.photomoments + 6307) [0x10f7838a3] 1-10
                  10  __CFRunLoopRun + 1361 (CoreFoundation + 555377) [0x7fff81f7f971] 1-10
                    10  __CFRunLoopServiceMachPort + 212 (CoreFoundation + 558308) [0x7fff81f804e4] 1-10
                      10  mach_msg_trap + 10 (libsystem_kernel.dylib + 74570) [0x7fff9780934a] 1-10
                       *10  ipc_mqueue_receive_continue + 0 (kernel + 862304) [0xffffff80002d2860] 1-10
  Thread 0x1e98             Thread name "NetworkLoad" 10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x10f782000 -        0x10f787fff  com.apple.photomoments 2.0 (3150.4.120) <B4C51E10-772C-3A4A-9601-11FF55EC3E23>  /System/Library/PrivateFrameworks/PhotoLibraryPrivate.framework/Versions/A/Frameworks/PhotoLibraryServices.framework/Versions/A/XPCServices/com.apple.photomoments.xpc/Contents/MacOS/com.apple.photomoments
Process:         com.apple.quicklook.ThumbnailsAgent [372]
Path:            /System/Library/PrivateFrameworks/QuickLookThumbnailing.framework/Support/com.apple.quicklook.ThumbnailsAgent
Parent:          launchd [1]
UID:             503
Task size:       13.89 MB
  Thread 0xd1e              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  ??? (com.apple.quicklook.ThumbnailsAgent + 41096) [0x104696088] 1-10
  Binary Images:
           0x10468c000 -        0x10469bfff  com.apple.quicklook.ThumbnailsAgent (14.1) <D0787288-3D64-37FE-8AA0-AC62958E5D9E>  /System/Library/PrivateFrameworks/QuickLookThumbnailing.framework/Support/com.apple.quicklook.ThumbnailsAgent
Process:         com.apple.Safari.History [877]
Path:            /System/Library/PrivateFrameworks/SafariShared.framework/Versions/A/XPCServices/com.apple.Safari.History.xpc/Contents/MacOS/com.apple.Safari.History
Parent:          launchd [1]
Responsible:     Spotlight [463]
UID:             503
Task size:       26.36 MB
  Thread 0x1bc9             DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
  Thread 0x1d36             10 samples (1-10)         priority 4 (base 4)
    10  __psynch_cvwait + 10 (libsystem_kernel.dylib + 105458) [0x7fff97810bf2] 1-10
     *10  psynch_cvcontinue + 0 (pthread + 38973) [0xffffff7f8135f83d] 1-10
  Binary Images:
           0x10de3b000 -        0x10de3bfff  com.apple.Safari.History 12603 (12603.1.30.0.34) <59A2B232-DC88-3409-8987-09DDEC59B2A4>  /System/Library/PrivateFrameworks/SafariShared.framework/Versions/A/XPCServices/com.apple.Safari.History.xpc/Contents/MacOS/com.apple.Safari.History
Process:         com.apple.Safari.ImageDecoder [4662]
Path:            /System/Library/PrivateFrameworks/SafariShared.framework/Versions/A/XPCServices/com.apple.Safari.ImageDecoder.xpc/Contents/MacOS/com.apple.Safari.ImageDecoder
Parent:          launchd [1]
UID:             503
Task size:       29.77 MB
  Thread 0x1a47d            DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  ??? (com.apple.Safari.ImageDecoder + 6550) [0x1028da996] 1-10
  Binary Images:
           0x1028d9000 -        0x1028dafff  com.apple.Safari.ImageDecoder 12603 (12603.1.30.0.34) <9D41229D-27CE-33E5-8C94-F3D790B03B5A>  /System/Library/PrivateFrameworks/SafariShared.framework/Versions/A/XPCServices/com.apple.Safari.ImageDecoder.xpc/Contents/MacOS/com.apple.Safari.ImageDecoder
        0x7fff81ef8000 -     0x7fff82391fff  com.apple.CoreFoundation 6.9 (1349.65)                <F79384D1-FA3F-38CA-A847-B2625EBB790E>  /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
        0x7fff8396f000 -     0x7fff83d15fff  com.apple.Foundation 6.9 (1349.64)                    <49C8DA40-9E5B-33F9-B092-F50115B59E95>  /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
        0x7fff976dd000 -     0x7fff976e2fff  libdyld.dylib (433.5)                                 <129D3B44-FB21-3750-9A68-48B5C3DC632B>  /usr/lib/system/libdyld.dylib
        0x7fff977f7000 -     0x7fff97819fff  libsystem_kernel.dylib (3789.51.2)                    <FC51D7B0-8292-3F6A-9231-64340B237EB7>  /usr/lib/system/libsystem_kernel.dylib
   *0xffffff8000200000 - 0xffffff80009fffff  kernel (3789.51.2)                                    <06F94FD7-451F-34A1-B13C-D68FF7EDE0A0>  /System/Library/Kernels/kernel
Process:         com.apple.Safari.SafeBrowsing.Service [922]
Path:            /System/Library/PrivateFrameworks/SafariSafeBrowsing.framework/Versions/A/com.apple.Safari.SafeBrowsing.Service
Parent:          launchd [1]
UID:             503
Sudden Term:     Tracked (allows idle exit)
Task size:       26.60 MB
  Thread 0x1d4d             10 samples (1-10)         priority 4 (base 4)
  <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2>
     *10  ??? (kernel + 5801776) [0xffffff8000788730] 1-10
  Thread 0x15510            Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4 (base 4)
  10  thread_start + 13 (libsystem_pthread.dylib + 12545) [0x7fff978fb101] 1-10
    10  _pthread_start + 286 (libsystem_pthread.dylib + 14587) [0x7fff978fb8fb] 1-10
      10  _pthread_body + 180 (libsystem_pthread.dylib + 14767) [0x7fff978fb9af] 1-10
        10  __NSThread__start__ + 1243 (Foundation + 207821) [0x7fff839a1bcd] 1-10
          10  +[NSURLConnection(Loader) _resourceLoadLoop:] + 313 (CFNetwork + 26116) [0x7fff810bd604] 1-10
  Binary Images:
           0x106457000 -        0x106457fff  com.apple.Safari.SafeBrowsing.Service (7603.1.30.0.34) <850386CF-46C1-3F7F-9680-B22A722454D5>  /System/Library/PrivateFrameworks/SafariSafeBrowsing.framework/Versions/A/com.apple.Safari.SafeBrowsing.Service
        0x7fff810b7000 -     0x7fff81491fff  com.apple.CFNetwork 811.4.18 (811.4.18)                <9CE329E8-6177-3474-976D-F5C63FC875CD>  /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
        0x7fff978f8000 -     0x7fff97902fff  libsystem_pthread.dylib (218.51.1)                     <62A84A68-431D-3B54-A7B6-31367CCF2884>  /usr/lib/system/libsystem_pthread.dylib
Process:         com.apple.Safari.SearchHelper [4671]
Path:            /System/Library/PrivateFrameworks/SafariShared.framework/Versions/A/XPCServices/com.apple.Safari.SearchHelper.xpc/Contents/MacOS/com.apple.Safari.SearchHelper
Parent:          launchd [1]
UID:             503
Task size:       36.59 MB
Note:            5 idle work queue threads omitted
  Thread 0x1a4d3            DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  ??? (com.apple.Safari.SearchHelper + 7075) [0x10a46aba3] 1-10
  Thread 0x1a4d7            Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x10a469000 -        0x10a46ffff  com.apple.Safari.SearchHelper 12603 (12603.1.30.0.34) <121B875A-6877-33AA-ACFA-9DB882C04611>  /System/Library/PrivateFrameworks/SafariShared.framework/Versions/A/XPCServices/com.apple.Safari.SearchHelper.xpc/Contents/MacOS/com.apple.Safari.SearchHelper
Process:         com.apple.SafariServices [879]
Path:            /System/Library/Frameworks/SafariServices.framework/Versions/A/XPCServices/com.apple.SafariServices.xpc/Contents/MacOS/com.apple.SafariServices
Parent:          launchd [1]
UID:             503
Task size:       28.73 MB
  Thread 0x1bdd             10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x107d7d000 -        0x107d7ffff  com.apple.SafariServices 12603 (12603.1.30.0.34) <497E71C7-F37B-3995-A51D-B23AFA0B66BF>  /System/Library/Frameworks/SafariServices.framework/Versions/A/XPCServices/com.apple.SafariServices.xpc/Contents/MacOS/com.apple.SafariServices
Process:         com.apple.sbd [1928]
Path:            /System/Library/PrivateFrameworks/CloudServices.framework/Versions/A/XPCServices/com.apple.sbd.xpc/Contents/MacOS/com.apple.sbd
Parent:          launchd [1]
UID:             503
Task size:       28.57 MB
Note:            1 idle work queue threads omitted
  Thread 0x775f             DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  ??? (com.apple.sbd + 205787) [0x10e3b23db] 1-10
  Binary Images:
           0x10e380000 -        0x10e3cafff  com.apple.sbd 1.0 (222.51.1)           <BC39E313-2FC1-3C24-AEDC-617165CE605E>  /System/Library/PrivateFrameworks/CloudServices.framework/Versions/A/XPCServices/com.apple.sbd.xpc/Contents/MacOS/com.apple.sbd
Process:         com.apple.speech.speechsynthesisd [5432]
Path:            /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/Resources/com.apple.speech.speechsynthesisd
Parent:          launchd [1]
UID:             503
Task size:       20.64 MB
  Thread 0x1ff8e            10 samples (1-10)         priority 31 (base 31)
  Binary Images:
           0x10c393000 -        0x10c3a4fff  com.apple.speech.speechsynthesisd (6.3.3) <4F06A371-5B76-3B08-8F4E-1396325EBBA3>  /System/Library/Frameworks/ApplicationServices.framework/Frameworks/SpeechSynthesis.framework/Resources/com.apple.speech.speechsynthesisd
Process:         com.apple.spotlight.IndexAgent [893]
Path:            /System/Library/PrivateFrameworks/CoreSpotlight.framework/Support/com.apple.spotlight.IndexAgent
Parent:          launchd [1]
UID:             503
Task size:       12.88 MB
  Thread 0x1c79             DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
  <thread QoS background (requested background), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2>
  Binary Images:
           0x101eaa000 -        0x101eabfff  com.apple.spotlight.IndexAgent (144) <A9703E1E-BB4A-374B-8D67-52EB6E24BBDA>  /System/Library/PrivateFrameworks/CoreSpotlight.framework/Support/com.apple.spotlight.IndexAgent
Process:         com.apple.WeatherKitService [937]
Path:            /System/Library/PrivateFrameworks/WeatherKit.framework/Versions/A/XPCServices/com.apple.WeatherKitService.xpc/Contents/MacOS/com.apple.WeatherKitService
Parent:          launchd [1]
UID:             503
Task size:       24.58 MB
  Thread 0x1e85             10 samples (1-10)         priority 4 (base 4)
  Thread 0x1e8f             Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x10fd83000 -        0x10fda1fff  com.apple.WeatherKitService 2.0 (153)  <9842A92C-1EC6-35E7-AEED-97F9A2D2D34F>  /System/Library/PrivateFrameworks/WeatherKit.framework/Versions/A/XPCServices/com.apple.WeatherKitService.xpc/Contents/MacOS/com.apple.WeatherKitService
Process:         com.apple.WebKit.Databases [4604]
Path:            /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.Databases.xpc/Contents/MacOS/com.apple.WebKit.Databases
Parent:          launchd [1]
UID:             503
Task size:       18.54 MB
  Thread 0x19e4f            DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
  <thread QoS default (requested default), process sudden termination dirty, process unclamped, process received importance donation from Safari [4589], IO tier 0>
    10  ??? (com.apple.WebKit.Databases + 6050) [0x1046667a2] 1-10
          10  -[NSRunLoop(NSRunLoop) run] + 76 (Foundation + 140362) [0x7fff8399144a] 1-10
            10  -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 277 (Foundation + 140658) [0x7fff83991572] 1-10
  Thread 0x19e56            10 samples (1-10)         priority 37 (base 37)
  <thread QoS user initiated (requested user interactive), process sudden termination dirty, process unclamped, process received importance donation from Safari [4589], IO tier 0>
        10  void* std::__1::__thread_proxy<std::__1::tuple<void (*)(bmalloc::AsyncTask<bmalloc::Heap, void (bmalloc::Heap::*)()>*), bmalloc::AsyncTask<bmalloc::Heap, void (bmalloc::Heap::*)()>*> >(void*) + 93 (JavaScriptCore + 12002381) [0x7fff84f8844d] 1-10
          10  bmalloc::AsyncTask<bmalloc::Heap, void (bmalloc::Heap::*)()>::threadEntryPoint(bmalloc::AsyncTask<bmalloc::Heap, void (bmalloc::Heap::*)()>*) + 29 (JavaScriptCore + 12001693) [0x7fff84f8819d] 1-10
            10  bmalloc::AsyncTask<bmalloc::Heap, void (bmalloc::Heap::*)()>::threadRunLoop() + 155 (JavaScriptCore + 12001995) [0x7fff84f882cb] 1-10
              10  void std::__1::condition_variable_any::wait<std::__1::unique_lock<bmalloc::Mutex> >(std::__1::unique_lock<bmalloc::Mutex>&) + 108 (JavaScriptCore + 12002124) [0x7fff84f8834c] 1-10
                10  std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 47 (libc++.1.dylib + 29901) [0x7fff9627b4cd] 1-10
  Thread 0x19e5c            Thread name "IndexedDatabase Server"                10 samples (1-10)         priority 37 (base 37)
  <thread QoS user initiated (requested user initiated), process sudden termination dirty, process unclamped, process received importance donation from Safari [4589], IO tier 0>
        10  WTF::wtfThreadEntryPoint(void*) + 15 (JavaScriptCore + 14367) [0x7fff8441981f] 1-10
          10  WTF::threadEntryPoint(void*) + 178 (JavaScriptCore + 14578) [0x7fff844198f2] 1-10
            10  WebCore::IDBServer::IDBServer::databaseThreadEntry(void*) + 9 (WebCore + 7262937) [0x7fff894362d9] 1-10
              10  WebCore::IDBServer::IDBServer::databaseRunLoop() + 101 (WebCore + 7269701) [0x7fff89437d45] 1-10
                10  WTF::CrossThreadQueue<WTF::CrossThreadTask>::waitForMessage() + 95 (WebCore + 7269839) [0x7fff89437dcf] 1-10
                  10  bool WTF::ConditionBase::waitUntil<WTF::Lock>(WTF::Lock&, WTF::TimeWithDynamicClockType const&) + 150 (WebCore + 2704406) [0x7fff88fdd416] 1-10
                    10  WTF::ParkingLot::parkConditionallyImpl(void const*, WTF::ScopedLambda<bool ()> const&, WTF::ScopedLambda<void ()> const&, WTF::TimeWithDynamicClockType const&) + 2706 (JavaScriptCore + 11901778) [0x7fff84f6fb52] 1-10
                      10  WTF::ThreadCondition::timedWait(WTF::Mutex&, double) + 63 (JavaScriptCore + 47103) [0x7fff844217ff] 1-10
  Thread 0x343cc            10 samples (1-10)         priority 31 (base 31)
  <process sudden termination dirty, process unclamped, process received importance donation from Safari [4589], IO tier 0>
  Binary Images:
           0x104665000 -        0x104666fff  com.apple.WebKit.Databases 12603 (12603.1.30.0.34) <7E736085-35E9-34DF-9562-DC20DBD00230>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.Databases.xpc/Contents/MacOS/com.apple.WebKit.Databases
        0x7fff84416000 -     0x7fff8501efff  com.apple.JavaScriptCore 12603 (12603.1.30.0.34)   <42993DA4-E18A-3A41-86F8-23A6656273F9>  /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
        0x7fff88d49000 -     0x7fff8a0cffff  com.apple.WebCore 12603 (12603.1.30.0.34)          <57038A29-AC92-33FE-A4D6-DCDD95B88A88>  /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore
        0x7fff96274000 -     0x7fff962cafff  libc++.1.dylib (307.5)                             <0B43BB5D-E6EB-3464-8DE9-B41AC8ED9D1C>  /usr/lib/libc++.1.dylib
   *0xffffff7f81356000 - 0xffffff7f81361fff  com.apple.kec.pthread 1.0 (1)                      <4EFF2F70-C9B9-3176-BF83-F1B660C42135>  /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread
Process:         com.apple.WebKit.Networking [881]
Path:            /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.Networking.xpc/Contents/MacOS/com.apple.WebKit.Networking
Parent:          launchd [1]
UID:             503
Task size:       28.09 MB
  Thread 0x1beb             DispatchQueue 1           10 samples (1-10)         priority 37 (base 37)
  <thread QoS user initiated (requested user initiated), process sudden termination dirty, process unclamped, process received importance donation from Spotlight [463], IO tier 0>
    10  ??? (com.apple.WebKit.Networking + 6050) [0x102f257a2] 1-10
  Thread 0x1bf2             10 samples (1-10)         priority 37 (base 37)
  <thread QoS user initiated (requested user interactive), process sudden termination dirty, process unclamped, process received importance donation from Spotlight [463], IO tier 0>
  Thread 0x1bfd             Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 37 (base 37)
  Thread 0x142b7            Thread name "com.apple.CFNetwork.CustomProtocols"   10 samples (1-10)         priority 31 (base 31)
  <thread QoS default (requested default), process sudden termination dirty, process unclamped, process received importance donation from Spotlight [463], IO tier 0>
  Binary Images:
           0x102f24000 -        0x102f25fff  com.apple.WebKit.Networking 12603 (12603.1.30.0.34) <571EFBD1-6B28-3968-8AAE-14C61BBD30B1>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.Networking.xpc/Contents/MacOS/com.apple.WebKit.Networking
Process:         com.apple.WebKit.Networking [1970]
Parent:          launchd [1]
UID:             503
Task size:       37.71 MB
  Thread 0x7b09             DispatchQueue 1           10 samples (1-10)         priority 37 (base 37)
  <thread QoS user initiated (requested user initiated), process sudden termination dirty, process unclamped, process received importance donation from Mail [1964], IO tier 0>
    10  ??? (com.apple.WebKit.Networking + 6050) [0x10ee0b7a2] 1-10
  Thread 0x7b13             10 samples (1-10)         priority 37 (base 37)
  <thread QoS user initiated (requested user interactive), process sudden termination dirty, process unclamped, process received importance donation from Mail [1964], IO tier 0>
  Thread 0x7b24             Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 37 (base 37)
  Thread 0x7b41             Thread name "com.apple.CFNetwork.CustomProtocols"   10 samples (1-10)         priority 31 (base 31)
  <thread QoS default (requested default), process sudden termination dirty, process unclamped, process received importance donation from Mail [1964], IO tier 0>
  Binary Images:
           0x10ee0a000 -        0x10ee0bfff  com.apple.WebKit.Networking 12603 (12603.1.30.0.34) <571EFBD1-6B28-3968-8AAE-14C61BBD30B1>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.Networking.xpc/Contents/MacOS/com.apple.WebKit.Networking
Process:         com.apple.WebKit.Networking [4593]
Parent:          launchd [1]
UID:             503
Task size:       63.79 MB
  Thread 0x19dbf            DispatchQueue 1           10 samples (1-10)         priority 37 (base 37)
    10  ??? (com.apple.WebKit.Networking + 6050) [0x1073307a2] 1-10
  Thread 0x19dcf            10 samples (1-10)         priority 37 (base 37)
  Thread 0x19de1            Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 37 (base 37)
  Thread 0x1b281            Thread name "com.apple.CFNetwork.CustomProtocols"   10 samples (1-10)         priority 31 (base 31)
        10  _privateRunloopEmulationSet(void*) + 258 (CFNetwork + 2423154) [0x7fff81306972] 1-10
  Binary Images:
           0x10732f000 -        0x107330fff  com.apple.WebKit.Networking 12603 (12603.1.30.0.34) <571EFBD1-6B28-3968-8AAE-14C61BBD30B1>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.Networking.xpc/Contents/MacOS/com.apple.WebKit.Networking
Process:         com.apple.WebKit.WebContent [1971]
Path:            /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
Parent:          launchd [1]
UID:             503
Task size:       85.89 MB
  Thread 0x7b0a             DispatchQueue 1           10 samples (1-10)         priority 46 (base 46)
    10  ??? (com.apple.WebKit.WebContent + 6050) [0x109eaf7a2] 1-10
          10  NSApplicationMain + 1237 (AppKit + 25054) [0x7fff7fa3b1de] 1-10
            10  -[NSApplication run] + 926 (AppKit + 243627) [0x7fff7fa707ab] 1-10
              10  -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 2796 (AppKit + 8136798) [0x7fff801f785e] 1-10
                10  _DPSNextEvent + 1120 (AppKit + 290340) [0x7fff7fa7be24] 1-10
                  10  _BlockUntilNextEventMatchingListInModeWithFilter + 71 (HIToolbox + 199462) [0x7fff814e0b26] 1-10
                    10  ReceiveNextEventCommon + 432 (HIToolbox + 199921) [0x7fff814e0cf1] 1-10
                      10  RunCurrentEventLoopInMode + 240 (HIToolbox + 200380) [0x7fff814e0ebc] 1-10
                               *8  ipc_mqueue_receive_continue + 0 (kernel + 862304) [0xffffff80002d2860] 1-8
  <process clamped>
                               *2  ipc_mqueue_receive_continue + 0 (kernel + 862304) [0xffffff80002d2860] 9-10
  Thread 0x7b26             Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 46 (base 46)
        10  _NSEventThread + 205 (AppKit + 1655506) [0x7fff7fbc92d2] 1-10
  <process clamped>
  Thread 0x7b27             10 samples (1-10)         priority 46 (base 46)
                   *8  psynch_cvcontinue + 0 (pthread + 38973) [0xffffff7f8135f83d] 1-8
  <process clamped>
                   *2  psynch_cvcontinue + 0 (pthread + 38973) [0xffffff7f8135f83d] 9-10
  Thread 0x7b2c             Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 37 (base 37)
  <thread QoS user initiated (requested user initiated), process sudden termination dirty, process unclamped, IO tier 0>
  <process clamped>
  Thread 0x7b36             Thread name "WebCore: Scrolling"                    10 samples (1-10)         priority 46 (base 46)
  <process clamped>
  Binary Images:
           0x109eae000 -        0x109eaffff  com.apple.WebKit.WebContent 12603 (12603.1.30.0.34) <2F32DA20-F06C-340B-8F8A-A3FC8F85C19F>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
        0x7fff7fa35000 -     0x7fff8080efff  com.apple.AppKit 6.9 (1504.82.104)                  <C295FF09-9984-34C3-953B-B263EF2107AB>  /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
        0x7fff814b0000 -     0x7fff817b9fff  com.apple.HIToolbox 2.1.1 (857.8)                   <40254D9A-E477-3F33-B2A2-807D399BF71C>  /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
Process:         com.apple.WebKit.WebContent [3148]
Parent:          launchd [1]
UID:             503
Task size:       114.20 MB
  Thread 0x1001f            DispatchQueue 1           10 samples (1-10)         priority 46 (base 46)
    10  ??? (com.apple.WebKit.WebContent + 6050) [0x10da7b7a2] 1-10
  <process clamped>
  Thread 0x10034            Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 46 (base 46)
  <process clamped>
  Thread 0x10037            10 samples (1-10)         priority 46 (base 46)
  <process clamped>
  Thread 0x1003d            Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 37 (base 37)
  <process clamped>
  Thread 0x10040            Thread name "WebCore: Scrolling"                    10 samples (1-10)         priority 46 (base 46)
            10  WebCore::ScrollingThread::initializeRunLoop() + 253 (WebCore + 330957) [0x7fff88d99ccd] 1-10
              10  CFRunLoopRun + 97 (CoreFoundation + 814129) [0x7fff81fbec31] 1-10
  <process clamped>
  Binary Images:
           0x10da7a000 -        0x10da7bfff  com.apple.WebKit.WebContent 12603 (12603.1.30.0.34) <2F32DA20-F06C-340B-8F8A-A3FC8F85C19F>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
Process:         com.apple.WebKit.WebContent [4685]
Parent:          launchd [1]
UID:             503
Task size:       519.34 MB
  Thread 0x1a612            DispatchQueue 1           10 samples (1-10)         priority 4-46 (base 4-46)
  <thread QoS user interactive (requested user interactive), process sudden termination dirty, process unclamped, IO tier 0, priority 46 (46)>
    10  ??? (com.apple.WebKit.WebContent + 6050) [0x104a807a2] 1-10
  <process clamped, process suppressed, timers tier 5 (throttled), IO tier 1, priority 4 (4)>
  Thread 0x1a61f            Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 4-46 (base 4-46)
  Thread 0x1a620            10 samples (1-10)         priority 4-46 (base 4-46)
  Thread 0x1a624            Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4-37 (base 4-37)
  <thread QoS user initiated (requested user initiated), process sudden termination dirty, process unclamped, IO tier 0, priority 37 (37)>
  Thread 0x1a625            Thread name "WebCore: Scrolling"                    10 samples (1-10)         priority 4-46 (base 4-46)
  Thread 0x1bfe1            Thread name "Audio Decoder"                         10 samples (1-10)         priority 4-37 (base 4-37)
  Thread 0x1bfec            Thread name "Audio Decoder"                         10 samples (1-10)         priority 4-37 (base 4-37)
  Thread 0x1bffc            Thread name "Audio Decoder"                         10 samples (1-10)         priority 4-37 (base 4-37)
  Thread 0x1c006            Thread name "Audio Decoder"                         10 samples (1-10)         priority 4-37 (base 4-37)
  Thread 0x1c00e            Thread name "Audio Decoder"                         10 samples (1-10)         priority 4-37 (base 4-37)
  Thread 0x1c044            Thread name "com.apple.coremedia.asyncio"           10 samples (1-10)         priority 4-52 (base 4-52)
  <process sudden termination dirty, process unclamped, IO tier 0, priority 52 (52)>
        10  figThreadMain + 277 (CoreMedia + 277470) [0x7fff82d02bde] 1-10
          10  ??? (MediaToolbox + 177348) [0x7fff853084c4] 1-10
            10  FigSemaphoreWaitRelative + 153 (CoreMedia + 274121) [0x7fff82d01ec9] 1-10
              10  WaitOnCondition + 14 (CoreMedia + 275007) [0x7fff82d0223f] 1-10
  Thread 0x1c066            Thread name "com.apple.coreaudio.AQClient"          10 samples (1-10)         priority 4-60 (base 4-60)
  <process sudden termination dirty, process unclamped, IO tier 0, priority 60 (60)>
  Binary Images:
           0x104a7f000 -        0x104a80fff  com.apple.WebKit.WebContent 12603 (12603.1.30.0.34) <2F32DA20-F06C-340B-8F8A-A3FC8F85C19F>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
        0x7fff82cbf000 -     0x7fff82d70fff  com.apple.CoreMedia 1.0 (1907.58)                   <9A25B3CA-A006-39D2-A405-194F2BBF9061>  /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
        0x7fff852dd000 -     0x7fff85816fff  com.apple.MediaToolbox 1.0 (1907.58)                <2BF8A414-F33A-333B-97F1-97D3807F96EB>  /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
Process:         com.apple.WebKit.WebContent [4782]
Parent:          launchd [1]
UID:             503
Task size:       288.58 MB
CPU Time:        <0.001
  Thread 0x1b1d7            DispatchQueue 1           10 samples (1-10)         priority 4-46 (base 4-46) cpu time <0.001
    10  ??? (com.apple.WebKit.WebContent + 6050) [0x104f137a2] 1-10
  Thread 0x1b20b            Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 4-46 (base 4-46)
  Thread 0x1b20f            10 samples (1-10)         priority 4-46 (base 4-46)
  Thread 0x1b212            Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4-37 (base 4-37)
  Thread 0x1b21f            Thread name "WebCore: Scrolling"                    10 samples (1-10)         priority 4-46 (base 4-46)
  Binary Images:
           0x104f12000 -        0x104f13fff  com.apple.WebKit.WebContent 12603 (12603.1.30.0.34) <2F32DA20-F06C-340B-8F8A-A3FC8F85C19F>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
Process:         com.apple.WebKit.WebContent [5092]
Parent:          launchd [1]
UID:             503
Task size:       240.80 MB
CPU Time:        <0.001
Note:            4 idle work queue threads omitted
  Thread 0x1d903            DispatchQueue 1           10 samples (1-10)         priority 4-46 (base 4-46) cpu time <0.001
    10  ??? (com.apple.WebKit.WebContent + 6050) [0x10113e7a2] 1-10
  Thread 0x1d91e            Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 4-46 (base 4-46)
  Thread 0x1d920            10 samples (1-10)         priority 4-46 (base 4-46)
  Thread 0x1d925            Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4-37 (base 4-37)
  Thread 0x1d926            Thread name "WebCore: Scrolling"                    10 samples (1-10)         priority 4-46 (base 4-46)
  Binary Images:
           0x10113d000 -        0x10113efff  com.apple.WebKit.WebContent 12603 (12603.1.30.0.34) <2F32DA20-F06C-340B-8F8A-A3FC8F85C19F>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
Process:         com.apple.WebKit.WebContent [5561]
Parent:          launchd [1]
UID:             503
Task size:       93.69 MB
  Thread 0x20922            DispatchQueue 1           10 samples (1-10)         priority 4-46 (base 4-46)
    10  ??? (com.apple.WebKit.WebContent + 6050) [0x106de37a2] 1-10
  Thread 0x2092c            Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 4-46 (base 4-46)
  Thread 0x2092d            10 samples (1-10)         priority 4-46 (base 4-46)
  Thread 0x20932            Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4-37 (base 4-37)
  Thread 0x20935            Thread name "WebCore: Scrolling"                    10 samples (1-10)         priority 4-46 (base 4-46)
  Binary Images:
           0x106de2000 -        0x106de3fff  com.apple.WebKit.WebContent 12603 (12603.1.30.0.34) <2F32DA20-F06C-340B-8F8A-A3FC8F85C19F>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
Process:         com.apple.WebKit.WebContent [5583]
Parent:          launchd [1]
UID:             503
Task size:       166.38 MB
  Thread 0x20a86            DispatchQueue 1           10 samples (1-10)         priority 4-46 (base 4-46)
    10  ??? (com.apple.WebKit.WebContent + 6050) [0x10c3ac7a2] 1-10
  Thread 0x20a99            Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 4-46 (base 4-46)
  Thread 0x20a9d            10 samples (1-10)         priority 4-46 (base 4-46)
  Thread 0x20aa2            Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4-37 (base 4-37)
  Thread 0x20aa3            Thread name "WebCore: Scrolling"                    10 samples (1-10)         priority 4-46 (base 4-46)
  Binary Images:
           0x10c3ab000 -        0x10c3acfff  com.apple.WebKit.WebContent 12603 (12603.1.30.0.34) <2F32DA20-F06C-340B-8F8A-A3FC8F85C19F>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
Process:         com.apple.WebKit.WebContent [5595]
Parent:          launchd [1]
UID:             503
Task size:       138.90 MB
  Thread 0x20eef            DispatchQueue 1           10 samples (1-10)         priority 4-46 (base 4-46)
    10  ??? (com.apple.WebKit.WebContent + 6050) [0x10a7357a2] 1-10
  Thread 0x20ef9            Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 4-46 (base 4-46)
  Thread 0x20efd            10 samples (1-10)         priority 4-46 (base 4-46)
  Thread 0x20f01            Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4-37 (base 4-37)
  Thread 0x20f0a            Thread name "WebCore: Scrolling"                    10 samples (1-10)         priority 4-46 (base 4-46)
  Binary Images:
           0x10a734000 -        0x10a735fff  com.apple.WebKit.WebContent 12603 (12603.1.30.0.34) <2F32DA20-F06C-340B-8F8A-A3FC8F85C19F>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
Process:         com.apple.WebKit.WebContent [7730]
Parent:          launchd [1]
UID:             503
Task size:       378.81 MB
CPU Time:        <0.001
  Thread 0x30be9            DispatchQueue 1           10 samples (1-10)         priority 4-46 (base 4-46) cpu time <0.001
    10  ??? (com.apple.WebKit.WebContent + 6050) [0x10b9ed7a2] 1-10
  Thread 0x30c04            Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 4-46 (base 4-46)
  Thread 0x30c08            10 samples (1-10)         priority 4-46 (base 4-46)
  Thread 0x30c0c            Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4-37 (base 4-37)
  Thread 0x30c10            Thread name "WebCore: Scrolling"                    10 samples (1-10)         priority 4-46 (base 4-46)
  Binary Images:
           0x10b9ec000 -        0x10b9edfff  com.apple.WebKit.WebContent 12603 (12603.1.30.0.34) <2F32DA20-F06C-340B-8F8A-A3FC8F85C19F>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
Process:         com.apple.WebKit.WebContent [7787]
Parent:          launchd [1]
UID:             503
Task size:       214.39 MB
CPU Time:        <0.001
  Thread 0x3125c            DispatchQueue 1           10 samples (1-10)         priority 46 (base 46)     cpu time <0.001
    10  ??? (com.apple.WebKit.WebContent + 6050) [0x10e2d07a2] 1-10
  <process clamped>
  Thread 0x3126b            Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 46 (base 46)
  <process clamped>
  Thread 0x3126c            10 samples (1-10)         priority 46 (base 46)
  <process clamped>
  Thread 0x31270            Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 37 (base 37)
  <process clamped>
  Thread 0x31271            Thread name "WebCore: Scrolling"                    10 samples (1-10)         priority 46 (base 46)
  <process clamped>
  Binary Images:
           0x10e2cf000 -        0x10e2d0fff  com.apple.WebKit.WebContent 12603 (12603.1.30.0.34) <2F32DA20-F06C-340B-8F8A-A3FC8F85C19F>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
Process:         com.apple.WebKit.WebContent [7798]
Parent:          launchd [1]
UID:             503
Task size:       148.27 MB
  Thread 0x31430            DispatchQueue 1           10 samples (1-10)         priority 4-46 (base 4-46)
    10  ??? (com.apple.WebKit.WebContent + 6050) [0x1007237a2] 1-10
  Thread 0x31452            Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 4-46 (base 4-46)
  Thread 0x31455            10 samples (1-10)         priority 4-46 (base 4-46)
  Thread 0x31460            Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4-37 (base 4-37)
  Thread 0x31463            Thread name "WebCore: Scrolling"                    10 samples (1-10)         priority 4-46 (base 4-46)
  Binary Images:
           0x100722000 -        0x100723fff  com.apple.WebKit.WebContent 12603 (12603.1.30.0.34) <2F32DA20-F06C-340B-8F8A-A3FC8F85C19F>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
Process:         com.apple.WebKit.WebContent [7803]
Parent:          launchd [1]
UID:             503
Task size:       152.50 MB
  Thread 0x3148f            DispatchQueue 1           10 samples (1-10)         priority 4-46 (base 4-46)
    10  ??? (com.apple.WebKit.WebContent + 6050) [0x1037247a2] 1-10
  Thread 0x3149d            Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 4-46 (base 4-46)
  Thread 0x3149e            10 samples (1-10)         priority 4-46 (base 4-46)
  Thread 0x314a2            Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4-37 (base 4-37)
  Thread 0x314a3            Thread name "WebCore: Scrolling"                    10 samples (1-10)         priority 4-46 (base 4-46)
  Binary Images:
           0x103723000 -        0x103724fff  com.apple.WebKit.WebContent 12603 (12603.1.30.0.34) <2F32DA20-F06C-340B-8F8A-A3FC8F85C19F>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
Process:         com.apple.WebKit.WebContent [8152]
Parent:          launchd [1]
UID:             503
Task size:       145.92 MB
CPU Time:        <0.001
  Thread 0x33e48            DispatchQueue 1           10 samples (1-10)         priority 4-46 (base 4-46) cpu time <0.001
    10  ??? (com.apple.WebKit.WebContent + 6050) [0x1020077a2] 1-10
  Thread 0x33e68            Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 4-46 (base 4-46)
  Thread 0x33e6a            10 samples (1-10)         priority 4-46 (base 4-46)
  Thread 0x33e6f            Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4-37 (base 4-37)
  Thread 0x33e71            Thread name "WebCore: Scrolling"                    10 samples (1-10)         priority 4-46 (base 4-46)
  Binary Images:
           0x102006000 -        0x102007fff  com.apple.WebKit.WebContent 12603 (12603.1.30.0.34) <2F32DA20-F06C-340B-8F8A-A3FC8F85C19F>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
Process:         CommCenter [318]
Path:            /System/Library/Frameworks/CoreTelephony.framework/Support/CommCenter
Parent:          launchd [1]
UID:             503
Task size:       46.16 MB
  Thread 0xb3c              DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
  <thread QoS default (requested default), process sudden termination clean, IO tier 0>
    10  ??? (CommCenter + 537998) [0x10c85a58e] 1-10
      10  ??? (CommCenter + 539288) [0x10c85aa98] 1-10
  Thread 0xb5d              10 samples (1-10)         priority 31 (base 31)
        10  ATCSThreadStartStub(void*) + 30 (libATCommandStudioDynamic.dylib + 16638) [0x10d4280fe] 1-10
          10  ATCSTimerDriver::startATCSTimerDispatcher(void*) + 9 (libATCommandStudioDynamic.dylib + 19445) [0x10d428bf5] 1-10
            10  ATCSTimerDriver::timerDispatcher() + 57 (libATCommandStudioDynamic.dylib + 19765) [0x10d428d35] 1-10
              10  ATCSCondition::wait(ATCSMutex*, int) + 142 (libATCommandStudioDynamic.dylib + 17566) [0x10d42849e] 1-10
  Thread 0xb87              10 samples (1-10)         priority 31 (base 31)
        10  ??? (CommCenter + 4446480) [0x10cc14910] 1-10
          10  ??? (CommCenter + 4446993) [0x10cc14b11] 1-10
  Thread 0xb91              10 samples (1-10)         priority 31 (base 31)
        10  ??? (CommCenter + 4740276) [0x10cc5c4b4] 1-10
  Thread 0xb92              10 samples (1-10)         priority 31 (base 31)
        10  ??? (CommCenter + 734555) [0x10c88a55b] 1-10
  Binary Images:
           0x10c7d7000 -        0x10cf6afff  CommCenter (4961)                      <12316096-12CC-36C2-BDFB-B1F9F5B2BCBC>  /System/Library/Frameworks/CoreTelephony.framework/Support/CommCenter
           0x10d424000 -        0x10d474fff  libATCommandStudioDynamic.dylib (1902) <D9D9EF52-13B8-32FA-96E0-B004C6BE6323>  /usr/lib/libATCommandStudioDynamic.dylib
Process:         configd [58]
Path:            /usr/libexec/configd
Parent:          launchd [1]
UID:             0
Task size:       19.91 MB
  Thread 0x2a4              DispatchQueue 1           Thread name "SCDynamicStore"                        10 samples (1-10)         priority 37 (base 37)
  <thread QoS user initiated (requested user initiated), process sudden termination clean, IO tier 0>
    10  ??? (configd + 12818) [0x10fff5212] 1-10
      10  ??? (configd + 17813) [0x10fff6595] 1-10
  Thread 0x31f              Thread name "Main plugin thread"                    10 samples (1-10)         priority 31 (base 31)
        10  ??? (configd + 20747) [0x10fff710b] 1-10
  Thread 0x32f              Thread name "InterfaceNamer thread"                 10 samples (1-10)         priority 31 (base 31)
        10  ??? (configd + 74950) [0x1100044c6] 1-10
  Thread 0x3c6              10 samples (1-10)         priority 31 (base 31)
        10  pppcntl_run_thread + 717 (PPPController + 56727) [0x11018dd97] 1-10
  Thread 0x3c8              Thread name "com.apple.CFSocket.private"            10 samples (1-10)         priority 31 (base 31)
        10  __select + 10 (libsystem_kernel.dylib + 106166) [0x7fff97810eb6] 1-10
  Thread 0x3cb              10 samples (1-10)         priority 31 (base 31)
        10  captived_thread + 266 (CaptiveNetworkSupport + 18419) [0x1101527f3] 1-10
  Thread 0x3dc              10 samples (1-10)         priority 31 (base 31)
        10  ??? (EAPOLController + 19056) [0x1100e8a70] 1-10
  Binary Images:
           0x10fff2000 -        0x110043fff  configd (888.51.2)                                               <D2407749-46E2-3BB0-B3FA-1AB531F772EA>  /usr/libexec/configd
           0x1100e4000 -        0x1100eafff  com.apple.SystemConfiguration.EAPOLController 14.0.0 (14.0)      <A61C1CE8-230E-345E-9671-3CC2A7DBE116>  /System/Library/SystemConfiguration/EAPOLController.bundle/Contents/MacOS/EAPOLController
           0x11014e000 -        0x11016efff  com.apple.SystemConfiguration.CaptiveNetworkSupport 16.0.0 (1.0) <5EE013AE-4C0F-32F6-B49E-44FCEE22C07D>  /System/Library/SystemConfiguration/CaptiveNetworkSupport.bundle/Contents/MacOS/CaptiveNetworkSupport
           0x110180000 -        0x1101bdfff  com.apple.SystemConfiguration.PPPController 1.10 (1.10)          <21A0E815-45FD-3C37-9FF9-BD119D87D201>  /System/Library/SystemConfiguration/PPPController.bundle/Contents/MacOS/PPPController
Process:         ContactsAccountsService [339]
Path:            /System/Library/Frameworks/AddressBook.framework/Executables/ContactsAccountsService
Parent:          launchd [1]
UID:             503
Task size:       21.35 MB
  Thread 0xbdc              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  ??? (ContactsAccountsService + 13664) [0x10018f560] 1-10
  Binary Images:
           0x10018c000 -        0x100193fff  ContactsAccountsService (1756.20)      <86A1BE6F-1113-3151-B706-A82385FFDFE9>  /System/Library/Frameworks/AddressBook.framework/Executables/ContactsAccountsService
Process:         ContactsAgent [930]
Path:            /System/Library/PrivateFrameworks/ContactsAgent.framework/Executables/ContactsAgent
Parent:          launchd [1]
UID:             503
Task size:       21.84 MB
  Thread 0x1e25             DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  main + 102 (ContactsAgent + 12039) [0x1073f2f07] 1-10
  Binary Images:
           0x1073e7000 -        0x1073e7fff  ContactsAgent (10)                     <10E17EFD-F0F4-3F5E-BF4E-BF8D4B517B06>  /System/Library/PrivateFrameworks/ContactsAgent.framework/Executables/ContactsAgent
           0x1073f0000 -        0x107407fff  com.apple.ContactsAgent 1.0 (1)        <8362ACAF-3807-322E-9741-669D9354CFB1>  /System/Library/PrivateFrameworks/ContactsAgent.framework/Versions/A/ContactsAgent
Process:         ControlStrip [415]
Path:            /System/Library/CoreServices/ControlStrip.app/Contents/MacOS/ControlStrip
Parent:          launchd [1]
UID:             503
Task size:       52.82 MB
  Thread 0xf46              DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
  <thread QoS default (requested user interactive), process unclamped, IO tier 0>
    10  ??? (ControlStrip + 10025) [0x1021e9729] 1-10
  <process clamped>
  Thread 0x1348             Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 31 (base 31)
  <process clamped>
  Binary Images:
           0x1021e7000 -        0x102288fff  com.apple.controlstrip 1.0 (104.25)    <B0667090-5F42-32CF-A75B-6DCA8901CD70>  /System/Library/CoreServices/ControlStrip.app/Contents/MacOS/ControlStrip
Process:         CopyPaste Pro [470]
Path:            /Applications/CopyPaste Pro.app/Contents/MacOS/CopyPaste Pro
Parent:          launchd [1]
UID:             503
Task size:       68.51 MB (+4096  B)
CPU Time:        0.002
Process:         Core Sync [844]
Path:            /Applications/Utilities/Adobe Creative Cloud/*/Core Sync.app/Contents/MacOS/Core Sync
Parent:          launchd [1]
UID:             503
Task size:       36.68 MB
CPU Time:        <0.001
Process:         coreaudiod [212]
Path:            /usr/sbin/coreaudiod
Parent:          launchd [1]
UID:             202
Task size:       25.48 MB
  Thread 0x5a2              DispatchQueue 1           10 samples (1-10)         priority 63 (base 63)
  <process sudden termination dirty, IO tier 0>
    10  ??? (coreaudiod + 162247) [0x1070fe9c7] 1-10
  Thread 0x6c3              Thread name "SystemSoundServer"                     10 samples (1-10)         priority 61 (base 61)
        10  CAPThread::Entry(CAPThread*) + 85 (AudioToolbox + 71531) [0x7fff80d5276b] 1-10
          10  GenericRunLoopThread::Entry(void*) + 189 (AudioToolbox + 71897) [0x7fff80d528d9] 1-10
  Binary Images:
           0x1070d7000 -        0x107229fff  coreaudiod (55.12)                               <B319AFF5-1A11-3AFB-AB8F-768D93658E7D>  /usr/sbin/coreaudiod
        0x7fff80d41000 -     0x7fff80f4dfff  com.apple.audio.toolbox.AudioToolbox 1.14 (1.14) <6EEF498D-8233-3622-B34B-49FDD9D4DF14>  /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
Process:         coreauthd [301]
Path:            /System/Library/Frameworks/LocalAuthentication.framework/Support/coreauthd
Parent:          launchd [1]
UID:             0
Task size:       16.30 MB
  Thread 0x9c1              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  ??? (coreauthd + 44537) [0x109978df9] 1-10
  Binary Images:
           0x10996e000 -        0x10999dfff  coreauthd (240.50.25)                  <6826CA0F-F4A7-369A-84F8-75A39EA1169A>  /System/Library/Frameworks/LocalAuthentication.framework/Support/coreauthd
Process:         coreauthd [399]
Parent:          launchd [1]
UID:             503
Task size:       15.23 MB
  Thread 0xe4b              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  ??? (coreauthd + 44537) [0x10beb9df9] 1-10
  Binary Images:
           0x10beaf000 -        0x10bedefff  coreauthd (240.50.25)                  <6826CA0F-F4A7-369A-84F8-75A39EA1169A>  /System/Library/Frameworks/LocalAuthentication.framework/Support/coreauthd
Process:         corebrightnessd [128]
Path:            /usr/libexec/corebrightnessd
Parent:          launchd [1]
UID:             0
Task size:       17.41 MB
  Thread 0x322              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
  Thread 0x57b              10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x107a0f000 -        0x107a10fff  corebrightnessd (452.50.49)        <CD1B6F14-DE44-38ED-9DF8-2957C07D2BEE>  /usr/libexec/corebrightnessd
Process:         coreduetd [88]
Path:            /usr/libexec/coreduetd
Parent:          launchd [1]
UID:             0
Task size:       50.35 MB
  Thread 0x2e7              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  ??? (coreduetd + 238664) [0x10a001448] 1-10
  Binary Images:
           0x109fc7000 -        0x10a060fff  coreduetd (687.50.20)                  <F013B069-4DCC-332D-8594-F53C2DC26167>  /usr/libexec/coreduetd
Process:         coreservicesd [143]
Path:            /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/Support/coreservicesd
Parent:          launchd [1]
UID:             0
Task size:       14.89 MB
  Thread 0x391              DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
    10  _CoreServicesServerMain + 706 (CarbonCore + 579053) [0x7fff82e9d5ed] 1-10
  Thread 0x3ac              10 samples (1-10)         priority 31 (base 31)
        10  fmodWatchConsumer + 333 (CarbonCore + 313879) [0x7fff82e5ca17] 1-10
  Thread 0x3ad              10 samples (1-10)         priority 31 (base 31)
        10  read + 10 (libsystem_kernel.dylib + 111174) [0x7fff97812246] 1-10
         *10  hndl_unix_scall64 + 22 (kernel + 646470) [0xffffff800029dd46] 1-10
           *10  unix_syscall64 + 597 (kernel + 6444693) [0xffffff8000825695] 1-10
             *10  read_nocancel + 115 (kernel + 5884291) [0xffffff800079c983] 1-10
               *10  ??? (kernel + 5884954) [0xffffff800079cc1a] 1-10
                 *10  ??? (kernel + 3479568) [0xffffff8000551810] 1-10
                   *10  ??? (kernel + 5801314) [0xffffff8000788562] 1-10
                     *10  thread_block_reason + 222 (kernel + 1069422) [0xffffff800030516e] 1-10
                       *10  ??? (kernel + 1073995) [0xffffff800030634b] 1-10
                         *10  machine_switch_context + 206 (kernel + 2082766) [0xffffff80003fc7ce] 1-10
  Binary Images:
           0x106ada000 -        0x106adafff  coreservicesd (1159.6)                            <6B67A648-F14D-390D-9CF2-A0F66D5749B1>  /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/Support/coreservicesd
        0x7fff82e10000 -     0x7fff830ebfff  com.apple.CoreServices.CarbonCore 1159.6 (1159.6) <08AC074C-965B-3EDF-8E45-0707C8DE9EAD>  /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
Process:         CoreServicesUIAgent [670]
Path:            /System/Library/CoreServices/CoreServicesUIAgent.app/Contents/MacOS/CoreServicesUIAgent
Parent:          launchd [1]
UID:             503
Task size:       30.71 MB
  Thread 0x1773             DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
  Thread 0x1797             Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 37 (base 37)
  <thread QoS user initiated (requested user interactive), process sudden termination clean, IO tier 0>
  Thread 0x326d5            10 samples (1-10)         priority 31 (base 31)
  <process sudden termination clean, IO tier 0>
*10  wq_unpark_continue + 0 (pthread + 15190) [0xffffff7f81359b56] 1-10
  Binary Images:
           0x10d2e8000 -        0x10d314fff  com.apple.coreservices.uiagent 168.3 (168.3) <BB0FBFA8-A85F-3E9B-8DF3-F6A7BDD05AB0>  /System/Library/CoreServices/CoreServicesUIAgent.app/Contents/MacOS/CoreServicesUIAgent
Process:         corestoraged [223]
Path:            /usr/libexec/corestoraged
Parent:          launchd [1]
UID:             0
Task size:       11.01 MB
  Thread 0x63e              DispatchQueue 1           10 samples (1-10)         priority 20 (base 20)
  <thread QoS utility (requested utility), timers tier 3 (coalesced), IO tier 1>
    10  ??? (corestoraged + 7983) [0x102672f2f] 1-10
  Binary Images:
           0x102671000 -        0x102678fff  corestoraged (540.30.1)                <1C1A0DAF-1E13-3188-ABC6-C3BC71CB3D1F>  /usr/libexec/corestoraged
Process:         coresymbolicationd [245]
Path:            /System/Library/PrivateFrameworks/CoreSymbolication.framework/coresymbolicationd
Parent:          launchd [1]
UID:             0
Task size:       9516 KB
  Thread 0x77e              DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
  10  _dispatch_sig_thread + 41 (libdispatch.dylib + 62031) [0x7fff976ba24f] 1-10
    10  __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 106982) [0x7fff978111e6] 1-10
  Binary Images:
           0x109b11000 -        0x109b1cfff  coresymbolicationd (62046)         <7B7E8269-3D00-32BD-BF3D-47C6F95CBFCB>  /System/Library/PrivateFrameworks/CoreSymbolication.framework/coresymbolicationd
        0x7fff976ab000 -     0x7fff976dcfff  libdispatch.dylib (703.50.37)      <D122E712-9593-31CA-BAC4-4A54410BF4A0>  /usr/lib/system/libdispatch.dylib
Process:         CrashReporterSupportHelper [218]
Path:            /System/Library/CoreServices/CrashReporterSupportHelper
Parent:          launchd [1]
UID:             0
Task size:       9648 KB
  Thread 0x5eb              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  ??? (CrashReporterSupportHelper + 8618) [0x10c5961aa] 1-10
  Binary Images:
           0x10c594000 -        0x10c596fff  CrashReporterSupportHelper (823)       <87FD7AA9-4545-344D-883C-A70CC590D42E>  /System/Library/CoreServices/CrashReporterSupportHelper
Process:         Creative Cloud [449]
Path:            /Applications/Utilities/Adobe Creative Cloud/*/Creative Cloud.app/Contents/MacOS/Creative Cloud
Architecture:    i386
Parent:          launchd [1]
UID:             503
Task size:       32.31 MB
CPU Time:        0.004
Process:         ctkahp (Smartcard Agent) [288]
Path:            /System/Library/Frameworks/CryptoTokenKit.framework/ctkahp.bundle/Contents/MacOS/ctkahp
Parent:          launchd [1]
UID:             0
Task size:       12.05 MB
  Thread 0x92a              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  main + 460 (ctkahp + 6861) [0x106bcaacd] 1-10
  Binary Images:
           0x106bc9000 -        0x106bdefff  com.apple.ctkahp 1.0 (1)               <7F3206EA-1810-3F96-B5A5-A5F4CB02BA01>  /System/Library/Frameworks/CryptoTokenKit.framework/ctkahp.bundle/Contents/MacOS/ctkahp
Process:         ctkahp (Smartcard Agent) [404]
Parent:          launchd [1]
UID:             503
Task size:       12.47 MB
  Thread 0xe87              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  main + 460 (ctkahp + 6861) [0x108c15acd] 1-10
  Binary Images:
           0x108c14000 -        0x108c29fff  com.apple.ctkahp 1.0 (1)               <7F3206EA-1810-3F96-B5A5-A5F4CB02BA01>  /System/Library/Frameworks/CryptoTokenKit.framework/ctkahp.bundle/Contents/MacOS/ctkahp
Process:         ctkd [152]
Path:            /System/Library/Frameworks/CryptoTokenKit.framework/ctkd
Parent:          launchd [1]
UID:             259
Task size:       13.42 MB
  Thread 0x3ff              DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x10c1d1000 -        0x10c1ddfff  ctkd (196.50.16)                   <734E50F1-6E22-3D6E-ACCF-8B457295ABDE>  /System/Library/Frameworks/CryptoTokenKit.framework/ctkd
Process:         ctkd [405]
Parent:          launchd [1]
UID:             503
Task size:       14.30 MB
  Thread 0xe90              DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x101000000 -        0x10100cfff  ctkd (196.50.16)                   <734E50F1-6E22-3D6E-ACCF-8B457295ABDE>  /System/Library/Frameworks/CryptoTokenKit.framework/ctkd
Process:         cupsd [221]
Path:            /usr/sbin/cupsd
Parent:          launchd [1]
UID:             0
Task size:       9792 KB
  Thread 0x6d6              10 samples (1-10)         priority 4 (base 4)
    10  ??? (cupsd + 97809) [0x102e99e11] 1-10
      10  kevent + 10 (libsystem_kernel.dylib + 109974) [0x7fff97811d96] 1-10
       *10  ??? (kernel + 5627984) [0xffffff800075e050] 1-10
  Thread 0x9b7              10 samples (1-10)         priority 4 (base 4)
        10  ??? (cupsd + 272372) [0x102ec47f4] 1-10
  Binary Images:
           0x102e82000 -        0x102ed7fff  cupsd (450)                            <75B677CA-F944-3801-8A6F-F4D72C990C00>  /usr/sbin/cupsd
Process:         CVMServer [259]
Path:            /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/CVMServer
Parent:          launchd [1]
UID:             0
Task size:       5304 KB
  Thread 0x84d              DispatchQueue 11          10 samples (1-10)         priority 31 (base 31)
  <thread QoS default (requested default), process sudden termination dirty, IO tier 0>
  Binary Images:
           0x1054ff000 -        0x105508fff  CVMServer (156.3)                  <6914E9F7-9E57-31D0-9F34-E5B5F7DBD15B>  /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/CVMServer
Process:         dbfseventsd [2180]
Path:            /Library/DropboxHelperTools/*/dbfseventsd
Architecture:    i386
Parent:          Dropbox [476]
Responsible:     Dropbox [476]
UID:             0
Task size:       1520 KB
CPU Time:        <0.001
  Thread 0x921f             10 samples (1-10)         priority 31 (base 31)     cpu time <0.001
  10  __read_nocancel + 10 (libsystem_kernel.dylib + 111922) [0xa17d5532] 1-10
   *10  hndl_unix_scall + 216 (kernel + 645688) [0xffffff800029da38] 1-10
     *10  unix_syscall + 561 (kernel + 6443777) [0xffffff8000825301] 1-10
  Binary Images:
                0x1000 -             0x8fff  dbfseventsd                        <6E6421C9-0E72-73AF-1821-754B84B964AF>  /Library/DropboxHelperTools/*/dbfseventsd
            0xa17ba000 -         0xa17dbfff  libsystem_kernel.dylib (3789.51.2) <50D0E6F1-6F9C-303F-BCD6-F72AD4485B6E>  /usr/lib/system/libsystem_kernel.dylib
Process:         dbfseventsd [2181]
Architecture:    i386
Parent:          dbfseventsd [2180]
UID:             0
Task size:       3692 KB
CPU Time:        <0.001
  Thread 0x9221             10 samples (1-10)         priority 31 (base 31)     cpu time <0.001
  <IO tier 0>
  10  ??? (dbfseventsd + 30069) [0x8575] 1-10
    10  __select_nocancel + 10 (libsystem_kernel.dylib + 112230) [0xa17d5666] 1-10
  Binary Images:
Process:         dbfseventsd [2182]
Architecture:    i386
Parent:          dbfseventsd [2181]
UID:             503
Task size:       668 KB
CPU Time:        <0.001
  Thread 0x9223             10 samples (1-10)         priority 31 (base 31)     cpu time <0.001
  <IO tier 0>
           *10  ??? (kernel + 5904888) [0xffffff80007a19f8] 1-10
             *10  ??? (kernel + 5801187) [0xffffff80007884e3] 1-10
               *10  lck_mtx_sleep + 132 (kernel + 1026980) [0xffffff80002faba4] 1-10
  Binary Images:
Process:         Default Folder X Agent [837]
Path:            /Users/USER/Library/PreferencePanes/Default Folder X.prefPane/Contents/Resources/Default Folder X.bundle/Contents/Resources/Default Folder X Agent
Parent:          Default Folder X Helper [467]
Responsible:     Default Folder X Helper [467]
UID:             503
Task size:       24.21 MB
  Thread 0x1a59             DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
  10  start + 52 (Default Folder X Agent + 4376) [0x100001118] 1-10
    10  main + 141 (Default Folder X Agent + 4525) [0x1000011ad] 1-10
      10  -[DFXAgent run] + 205 (Default Folder X Agent + 8189) [0x100001ffd] 1-10
  <process clamped>
  Thread 0x1a60             Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 31 (base 31)
  <process clamped>
  Thread 0x31658            10 samples (1-10)         priority 31 (base 31)
  <process unclamped, IO tier 0>
*8  wq_unpark_continue + 0 (pthread + 15190) [0xffffff7f81359b56] 1-8
  <process clamped>
*2  wq_unpark_continue + 0 (pthread + 15190) [0xffffff7f81359b56] 9-10
  Binary Images:
           0x100000000 -        0x100003fff  Default Folder X Agent                 <33D144E4-EEB7-30C9-811F-4EA81D5DBEA9>  /Users/USER/Library/PreferencePanes/Default Folder X.prefPane/Contents/Resources/Default Folder X.bundle/Contents/Resources/Default Folder X Agent
Process:         Default Folder X Helper [467]
Path:            /Users/USER/Library/PreferencePanes/Default Folder X.prefPane/Contents/Resources/Default Folder X Helper.app/Contents/MacOS/Default Folder X Helper
Architecture:    i386
Parent:          launchd [1]
UID:             503
Task size:       28.99 MB
CPU Time:        <0.001
Process:         deleted [366]
Path:            /System/Library/PrivateFrameworks/CacheDelete.framework/deleted
Parent:          launchd [1]
UID:             503
Task size:       16.10 MB
  Thread 0xcdb              DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x108f6f000 -        0x108f99fff  deleted (156.50.10)                <AF9E1B77-6FE8-3BD0-B407-ACDC4FC6ABFE>  /System/Library/PrivateFrameworks/CacheDelete.framework/deleted
Process:         DEVONthink Sorter [503]
Path:            /Applications/DEVONthink Pro.app/Contents/PlugIns/SorterPlugin.bundle/Contents/MacOS/DEVONthink Sorter.app/Contents/MacOS/DEVONthink Sorter
Parent:          launchd [1]
UID:             503
Task size:       50.42 MB
Process:         diagnostics_agent [455]
Path:            /System/Library/CoreServices/diagnostics_agent
Parent:          launchd [1]
UID:             503
Task size:       23.88 MB
  Thread 0x14d0             DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
  <thread QoS background (requested background), thread darwinbg, process darwinbg, IO tier 3>
    10  ??? (diagnostics_agent + 20710) [0x10a0d30e6] 1-10
  Binary Images:
           0x10a0ce000 -        0x10a0e9fff  diagnostics_agent (823)                <07F1CF09-5943-3784-A54C-F315D046B2F9>  /System/Library/CoreServices/diagnostics_agent
Process:         diskarbitrationd [85]
Path:            /usr/libexec/diskarbitrationd
Architecture:    x86_64
Parent:          launchd [1]
UID:             0
Task size:       8244 KB
  Thread 0x2b3              DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
    10  ??? (diskarbitrationd + 30576) [0x102967770] 1-10
  Binary Images:
           0x102960000 -        0x102977fff  diskarbitrationd (288.50.4)            <1DEA5F38-DF44-347F-B9DF-5E0AB9330A33>  /usr/libexec/diskarbitrationd
Process:         diskmanagementd [172]
Path:            /usr/libexec/diskmanagementd
Parent:          launchd [1]
UID:             0
Task size:       13.50 MB
  Thread 0x424              DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
  <thread QoS default (requested default), IO tier 0>
    10  ??? (diskmanagementd + 37127) [0x103349107] 1-10
  Thread 0x842              10 samples (1-10)         priority 31 (base 31)
          10  ??? (diskmanagementd + 48753) [0x10334be71] 1-10
  Thread 0xe1c              10 samples (1-10)         priority 31 (base 31)
  Thread 0x139e             10 samples (1-10)         priority 31 (base 31)
  Binary Images:
           0x103340000 -        0x10340dfff  diskmanagementd (1112)                 <C2862E97-04C7-3C09-B142-71BE9449764A>  /usr/libexec/diskmanagementd
Process:         diskspaced [1296]
Path:            /System/Library/PrivateFrameworks/StorageManagement.framework/Versions/A/Resources/diskspaced
Parent:          launchd [1]
UID:             503
Task size:       12.91 MB
  Thread 0x4e37             10 samples (1-10)         priority 20 (base 20)
  <thread QoS utility (requested default), process sudden termination clean, timers tier 3 (coalesced), IO tier 1>
  Binary Images:
           0x10bbfb000 -        0x10bbfffff  diskspaced (60)                    <B19F2C91-9D88-3652-8EF8-0D87D942DA74>  /System/Library/PrivateFrameworks/StorageManagement.framework/Resources/diskspaced
Process:         displaypolicyd [113]
Path:            /usr/libexec/displaypolicyd
Parent:          launchd [1]
UID:             244
Task size:       10.02 MB
  Thread 0x2ed              10 samples (1-10)         priority 4 (base 4)
  <thread QoS background (requested default), thread darwinbg, process darwinbg, IO tier 2>
    10  ??? (displaypolicyd + 8869) [0x10f3962a5] 1-10
  Thread 0x787              10 samples (1-10)         priority 4 (base 4)
    10  __sigwait + 10 (libsystem_kernel.dylib + 107006) [0x7fff978111fe] 1-10
         *10  __sigwait_nocancel + 459 (kernel + 5786907) [0xffffff8000784d1b] 1-10
  Thread 0x9b4              10 samples (1-10)         priority 4 (base 4)
  Thread 0x9b5              10 samples (1-10)         priority 4 (base 4)
  Thread 0x9b6              10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x10f394000 -        0x10f3b7fff  displaypolicyd (3.14.41)               <AD6BDA34-C94F-3638-BD93-EFE174101647>  /usr/libexec/displaypolicyd
Process:         distnoted [133]
Path:            /usr/sbin/distnoted
Parent:          launchd [1]
UID:             241
Task size:       5744 KB
  Thread 0x485              DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
    10  ??? (distnoted + 17309) [0x10ee8939d] 1-10
  Binary Images:
           0x10ee85000 -        0x10ee8dfff  distnoted (1349.65)                    <BAE1CD83-54CA-3A70-9397-936FF24156AF>  /usr/sbin/distnoted
Process:         distnoted [315]
Parent:          launchd [1]
UID:             503
Task size:       9352 KB
Note:            7 idle work queue threads omitted
  Thread 0xb2e              DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
    10  ??? (distnoted + 17309) [0x109f4339d] 1-10
  Binary Images:
           0x109f3f000 -        0x109f47fff  distnoted (1349.65)                    <BAE1CD83-54CA-3A70-9397-936FF24156AF>  /usr/sbin/distnoted
Process:         distnoted [1083]
Parent:          launchd [1]
UID:             89
Task size:       3992 KB
  Thread 0x251a             DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
  Binary Images:
           0x10fbd0000 -        0x10fbd8fff  distnoted (1349.65)                <BAE1CD83-54CA-3A70-9397-936FF24156AF>  /usr/sbin/distnoted
Process:         distnoted [1161]
Parent:          launchd [1]
UID:             0
Task size:       3624 KB
  Thread 0x2e0a             10 samples (1-10)         priority 31 (base 31)
  Binary Images:
           0x109a32000 -        0x109a3afff  distnoted (1349.65)                <BAE1CD83-54CA-3A70-9397-936FF24156AF>  /usr/sbin/distnoted
Process:         Dock [322]
Path:            /System/Library/CoreServices/Dock.app/Contents/MacOS/Dock
Parent:          launchd [1]
UID:             503
Task size:       116.40 MB
CPU Time:        0.005
Note:            2 idle work queue threads omitted
  Thread 0xb62              DispatchQueue 1           10 samples (1-10)         priority 47 (base 47)
  <process frontmost, thread QoS user interactive (requested user interactive), process unclamped, process received importance donation from WindowServer [165], IO tier 0>
    10  ??? (Dock + 23727) [0x109dc1caf] 1-10
      10  _TF10ObjectiveC15autoreleasepoolFFT_T_T_ + 38 (libswiftObjectiveC.dylib + 12614) [0x7fff944dd146] 1-10
        10  ??? (Dock + 1790250) [0x109f7112a] 1-10
  Thread 0x1101             10 samples (1-10)         priority 31 (base 31)     cpu time 0.005
  <process frontmost, thread QoS default (requested default), process unclamped, process received importance donation from WindowServer [165], IO tier 0>
        3  clock_sleep_trap + 10 (libsystem_kernel.dylib + 74846) [0x7fff9780945e] 1-3
         *3  hndl_mach_scall64 + 22 (kernel + 646502) [0xffffff800029dd66] 1-3
           *3  mach_call_munger64 + 456 (kernel + 2019544) [0xffffff80003ed0d8] 1-3
             *3  clock_sleep_trap + 626 (kernel + 957250) [0xffffff80002e9b42] 1-3
               *3  thread_block_reason + 222 (kernel + 1069422) [0xffffff800030516e] 1-3
                 *3  ??? (kernel + 1073995) [0xffffff800030634b] 1-3
                   *3  machine_switch_context + 206 (kernel + 2082766) [0xffffff80003fc7ce] 1-3
        7  ??? (Dock + 144319) [0x109ddf3bf] 4-10
          7  __psynch_cvwait + 10 (libsystem_kernel.dylib + 105458) [0x7fff97810bf2] 4-10
           *7  psynch_cvcontinue + 0 (pthread + 38973) [0xffffff7f8135f83d] 4-10
  Binary Images:
           0x109dbc000 -        0x10a2bcfff  com.apple.dock 1.8 (1738.14)           <E431D90D-EF7C-397E-88C8-AC38FEEA87ED>  /System/Library/CoreServices/Dock.app/Contents/MacOS/Dock
        0x7fff944da000 -     0x7fff944e0fff  libswiftObjectiveC.dylib (800.8.18.31) <D5AC1394-CCEB-305F-B33B-BF78BF38FF4C>  /System/Library/PrivateFrameworks/Swift/libswiftObjectiveC.dylib
Process:         Dropbox [476]
Path:            /Applications/Dropbox.app/Contents/MacOS/Dropbox
Parent:          launchd [1]
UID:             503
Task size:       201.46 MB
CPU Time:        0.005
Process:         duet [466]
Path:            /Applications/Duet.app/Contents/MacOS/duet
Parent:          launchd [1]
UID:             503
Task size:       54.39 MB
CPU Time:        0.003
Process:         DuetHeuristic-BM [112]
Path:            /usr/libexec/DuetHeuristic-BM
Parent:          launchd [1]
UID:             0
Task size:       20.49 MB (-24 KB)
CPU Time:        <0.001
  Thread 0x2ea              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
  10  start + 1 (libdyld.dylib + 21045) [0x7fff976e2235] 1-10
    10  ??? (DuetHeuristic-BM + 5459) [0x104e96553] 1-10
        10  CFRunLoopRunSpecific + 420 (CoreFoundation + 553412) [0x7fff81f7f1c4] 1-10
  Binary Images:
           0x104e95000 -        0x104e96fff  DuetHeuristic-BM (532.50.16)           <46AB7B91-EACE-3EFF-90AF-CD53E286E728>  /usr/libexec/DuetHeuristic-BM
Process:         dynamiclinkmanager [5473]
Path:            /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Helpers/DynamicLinkSupport/support/common/dynamiclink/dynamiclinkmanager.app/Contents/MacOS/dynamiclinkmanager
Architecture:    i386
Parent:          launchd [1]
UID:             503
Task size:       6520 KB
Process:         dynamiclinkmediaserver [5474]
Path:            /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Helpers/DynamicLinkMediaServer/application/dynamiclinkmediaserver.app/Contents/MacOS/dynamiclinkmediaserver
Parent:          launchd [1]
UID:             503
Task size:       39.20 MB
Process:         EmbeddedOSInstallService [257]
Path:            /System/Library/PrivateFrameworks/EmbeddedOSInstall.framework/Versions/A/XPCServices/EmbeddedOSInstallService.xpc/Contents/MacOS/EmbeddedOSInstallService
Parent:          launchd [1]
UID:             0
Task size:       34.41 MB
  Thread 0x827              DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x10984b000 -        0x109855fff  com.apple.EmbeddedOSInstallService 1.0 (1) <66305ADB-8755-3E26-948D-F61938FF356D>  /System/Library/PrivateFrameworks/EmbeddedOSInstall.framework/Versions/A/XPCServices/EmbeddedOSInstallService.xpc/Contents/MacOS/EmbeddedOSInstallService
Process:         EmojiFunctionRowIM_Extension [487]
Path:            /System/Library/Input Methods/EmojiFunctionRowIM.app/Contents/PlugIns/EmojiFunctionRowIM_Extension.appex/Contents/MacOS/EmojiFunctionRowIM_Extension
Parent:          launchd [1]
UID:             503
Task size:       37.82 MB
  Thread 0x10e7             DispatchQueue 1           10 samples (1-10)         priority 46 (base 46)
  <thread QoS user interactive (requested user interactive), process sudden termination dirty, process unclamped, IO tier 0>
    10  NSExtensionMain + 51 (Foundation + 2236412) [0x7fff83b90ffc] 1-10
      10  +[PKService _defaultRun:arguments:] + 17 (PlugInKit + 79121) [0x7fff92af7511] 1-10
        10  +[PKService main] + 55 (PlugInKit + 78046) [0x7fff92af70de] 1-10
          10  -[PKService run] + 733 (PlugInKit + 79085) [0x7fff92af74ed] 1-10
            10  -[NSXPCListener resume] + 165 (Foundation + 524571) [0x7fff839ef11b] 1-10
              10  xpc_main + 494 (libxpc.dylib + 62180) [0x7fff9793a2e4] 1-10
                10  _xpc_objc_main + 775 (libxpc.dylib + 67783) [0x7fff9793b8c7] 1-10
                      10  -[NSViewServiceApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 100 (ViewBridge + 47432) [0x7fff95814948] 1-10
  <process clamped>
  Thread 0x1107             Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 46 (base 46)
  <process clamped>
  Binary Images:
           0x10de92000 -        0x10de94fff  com.apple.inputmethod.EmojiFunctionRowItem 1.0 (1) <F01CBF5B-4071-35C9-B1BE-38F74427F0CE>  /System/Library/Input Methods/EmojiFunctionRowIM.app/Contents/PlugIns/EmojiFunctionRowIM_Extension.appex/Contents/MacOS/EmojiFunctionRowIM_Extension
        0x7fff92ae4000 -     0x7fff92b06fff  com.apple.pluginkit.framework 1.0 (1)              <775E1168-9A28-34EC-AACD-B73803B9DDD4>  /System/Library/PrivateFrameworks/PlugInKit.framework/Versions/A/PlugInKit
        0x7fff95809000 -     0x7fff958c9fff  com.apple.ViewBridge 282 (282)                     <71C6F456-E63F-3465-BCC7-377D29CF817D>  /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
        0x7fff9792b000 -     0x7fff97954fff  libxpc.dylib (972.50.27)                           <ABC45890-DA23-3A4A-B50B-1384BD4CBBDF>  /usr/lib/system/libxpc.dylib
Process:         eoshostd [226]
Path:            /usr/libexec/eoshostd
Parent:          launchd [1]
UID:             0
Task size:       6476 KB
  Thread 0x661              DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
    10  ??? (eoshostd + 13029) [0x10ecc92e5] 1-10
          10  __CFRunLoopRun + 1361 (CoreFoundation + 555377) [0x7fff81f7f971] 1-10
            10  __CFRunLoopServiceMachPort + 212 (CoreFoundation + 558308) [0x7fff81f804e4] 1-10
              10  mach_msg_trap + 10 (libsystem_kernel.dylib + 74570) [0x7fff9780934a] 1-10
               *10  ipc_mqueue_receive_continue + 0 (kernel + 862304) [0xffffff80002d2860] 1-10
  Binary Images:
           0x10ecc6000 -        0x10eccbfff  eoshostd (59.50.6)                     <3953038B-4808-3DFF-9C03-80135E8E9210>  /usr/libexec/eoshostd
Process:         EscrowSecurityAlert [1926]
Path:            /System/Library/CoreServices/EscrowSecurityAlert.app/Contents/MacOS/EscrowSecurityAlert
Parent:          launchd [1]
UID:             503
Task size:       23.18 MB
  Thread 0x774b             DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  ??? (EscrowSecurityAlert + 18299) [0x104b6e77b] 1-10
  Binary Images:
           0x104b6a000 -        0x104b6ffff  com.apple.EscrowSecurityAlert 1.0 (1)  <887BFB28-A248-3CA9-84E0-C7413CEF4D15>  /System/Library/CoreServices/EscrowSecurityAlert.app/Contents/MacOS/EscrowSecurityAlert
Process:         ExpressVPN [525]
Path:            /Applications/ExpressVPN.app/Contents/MacOS/ExpressVPN
Parent:          launchd [1]
UID:             503
Task size:       100.40 MB
CPU Time:        0.012
Process:         expressvpnd [532]
Path:            /Applications/ExpressVPN.app/Contents/MacOS/expressvpnd
Parent:          ExpressVPN [525]
Responsible:     ExpressVPN [525]
UID:             0
Task size:       38.55 MB
  Thread 0x12a6             10 samples (1-10)         priority 31 (base 31)
  <thread QoS default (requested user interactive), IO tier 0>
  10  <truncated backtrace> 1-10
   *10  semaphore_wait_continue + 0 (kernel + 1118912) [0xffffff80003112c0] 1-10
  Thread 0x12d0             10 samples (1-10)         priority 31 (base 31)
        10  ??? [0x62173d] 1-10
          10  ??? [0x300f4] 1-10
            10  ??? [0x3021e] 1-10
              10  ??? [0x36e9c] 1-10
                10  ??? [0xf805] 1-10
                  10  ??? [0xf5f2] 1-10
                    10  ??? [0x5903b] 1-10
                      10  ??? [0x52d63] 1-10
                        10  ??? [0x5cf93] 1-10
  Thread 0x12d1             10 samples (1-10)         priority 31 (base 31)
    10  ??? [0x5cf7b] 1-10
  Thread 0x12d2             10 samples (1-10)         priority 31 (base 31)
  10  ??? [0x32ec3] 1-10
    10  ??? [0x32b4c] 1-10
      10  ??? [0x31fd8] 1-10
        10  ??? [0x311cd] 1-10
          10  ??? [0xf4df] 1-10
  Thread 0x1300             10 samples (1-10)         priority 31 (base 31)
  Thread 0x1308             10 samples (1-10)         priority 31 (base 31)
  Thread 0x1311             10 samples (1-10)         priority 31 (base 31)
  Thread 0x131b             10 samples (1-10)         priority 31 (base 31)
  Thread 0x131c             10 samples (1-10)         priority 31 (base 31)
  Thread 0x131d             10 samples (1-10)         priority 31 (base 31)
  Thread 0x131e             10 samples (1-10)         priority 31 (base 31)
  Thread 0x131f             10 samples (1-10)         priority 31 (base 31)
  10  ??? [0x439f8] 1-10
    10  ??? [0x33116] 1-10
      10  ??? [0x33030] 1-10
        10  ??? [0x32b10] 1-10
          10  ??? [0x31b7a] 1-10
  Thread 0x1320             10 samples (1-10)         priority 31 (base 31)
  Thread 0x1321             10 samples (1-10)         priority 31 (base 31)
  Thread 0x13db             10 samples (1-10)         priority 31 (base 31)
  Thread 0x13dc             10 samples (1-10)         priority 31 (base 31)
  Thread 0x13e2             10 samples (1-10)         priority 31 (base 31)
      10  ??? [0x3203c] 1-10
        10  ??? [0x5d063] 1-10
  Thread 0x13e3             10 samples (1-10)         priority 31 (base 31)
  Thread 0x13e4             10 samples (1-10)         priority 31 (base 31)
  Thread 0x20cfe            10 samples (1-10)         priority 31 (base 31)
  <IO tier 0>
  Binary Images:
             0x3b46000 -          0x3b83fff  dyld (433.5)                       <8239D0D7-66F6-3C44-A77F-586F74525DA3>  /usr/lib/dyld
Process:         Fantastical [485]
Path:            /Applications/Fantastical.app/Contents/MacOS/Fantastical
Parent:          launchd [1]
UID:             503
Task size:       108.10 MB
CPU Time:        <0.001
Process:         filecoordinationd [346]
Path:            /usr/sbin/filecoordinationd
Parent:          launchd [1]
UID:             0
Task size:       10.93 MB
  Thread 0xc36              DispatchQueue 11          10 samples (1-10)         priority 31 (base 31)
  Binary Images:
           0x10340f000 -        0x10340ffff  filecoordinationd (1349.64)        <48603EBB-6FF6-345B-AA69-5879CB254BEE>  /usr/sbin/filecoordinationd
        0x7fff977f7000 -     0x7fff97819fff  libsystem_kernel.dylib (3789.51.2) <FC51D7B0-8292-3F6A-9231-64340B237EB7>  /usr/lib/system/libsystem_kernel.dylib
   *0xffffff8000200000 - 0xffffff80009fffff  kernel (3789.51.2)                 <06F94FD7-451F-34A1-B13C-D68FF7EDE0A0>  /System/Library/Kernels/kernel
Process:         Finder [325]
Path:            /System/Library/CoreServices/Finder.app/Contents/MacOS/Finder
Parent:          launchd [1]
UID:             503
Sudden Term:     Tracked
Task size:       274.37 MB
CPU Time:        <0.001
  Thread 0xb6b              DispatchQueue 1           10 samples (1-10)         priority 46 (base 46)     cpu time <0.001
    10  ??? (Finder + 25198) [0x10cbb926e] 1-10
  <process clamped>
  Thread 0xf8a              Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 46 (base 46)
  10  thread_start + 13 (libsystem_pthread.dylib + 12545) [0x7fff978fb101] 1-10
    10  _pthread_start + 286 (libsystem_pthread.dylib + 14587) [0x7fff978fb8fb] 1-10
      10  _pthread_body + 180 (libsystem_pthread.dylib + 14767) [0x7fff978fb9af] 1-10
  <process clamped>
  Thread 0x9c19             Thread name "com.apple.coreanimation.render-server" 10 samples (1-10)         priority 55 (base 55)
  <process sudden termination dirty, process unclamped, IO tier 0>
  <process clamped>
  Thread 0x336c0            10 samples (1-10)         priority 31 (base 31)
  <thread QoS default (requested default), process sudden termination dirty, process unclamped, IO tier 0>
        10  DRThreadObject::SymbolRoutine(DRThreadObject*) + 9 (DiscRecording + 11211) [0x7fff8371bbcb] 1-10
          10  DRThreadObject::StartRoutine(DRThreadObject*) + 120 (DiscRecording + 11588) [0x7fff8371bd44] 1-10
            10  DRWorkLoop::WorkLoopEntry(DRWorkLoop*) + 9 (DiscRecording + 12405) [0x7fff8371c075] 1-10
              10  DRWorkLoop::WorkLoop() + 228 (DiscRecording + 12652) [0x7fff8371c16c] 1-10
  <process clamped>
  Thread 0x35459            10 samples (1-10)         priority 31 (base 31)
        10  ??? (Finder + 30117) [0x10cbba5a5] 1-10
          10  ??? (Finder + 2264034) [0x10cddbbe2] 1-10
            10  ??? (Finder + 303362) [0x10cbfd102] 1-10
              10  ??? (Finder + 147405) [0x10cbd6fcd] 1-10
                10  __psynch_cvwait + 10 (libsystem_kernel.dylib + 105458) [0x7fff97810bf2] 1-10
  <process clamped>
  Binary Images:
           0x10cbb3000 -        0x10d1f1fff  com.apple.finder 10.12.5 (10.12.5)       <E8365DC6-0848-31DA-8247-FE466760E83E>  /System/Library/CoreServices/Finder.app/Contents/MacOS/Finder
        0x7fff81ef8000 -     0x7fff82391fff  com.apple.CoreFoundation 6.9 (1349.65)   <F79384D1-FA3F-38CA-A847-B2625EBB790E>  /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
        0x7fff83719000 -     0x7fff837d7fff  com.apple.DiscRecording 9.0.3 (9030.4.5) <88544E99-217A-33D9-8AC7-F54D2716658D>  /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
        0x7fff976dd000 -     0x7fff976e2fff  libdyld.dylib (433.5)                    <129D3B44-FB21-3750-9A68-48B5C3DC632B>  /usr/lib/system/libdyld.dylib
        0x7fff978f8000 -     0x7fff97902fff  libsystem_pthread.dylib (218.51.1)       <62A84A68-431D-3B54-A7B6-31367CCF2884>  /usr/lib/system/libsystem_pthread.dylib
Process:         findmydeviced [208]
Path:            /usr/libexec/findmydeviced
Parent:          launchd [1]
UID:             0
Sudden Term:     Tracked (allows idle exit)
Task size:       34.88 MB
  Thread 0x561              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
  <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2>
    10  ??? (findmydeviced + 65619) [0x103213053] 1-10
      10  -[FMDaemon run] + 133 (FMCore + 19384) [0x7fff8e3d7bb8] 1-10
  Thread 0x7e6              Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x103203000 -        0x10325bfff  findmydeviced (226.1.10)               <E8D17BA2-C9CB-3EC2-8E8D-2977E0A10447>  /usr/libexec/findmydeviced
        0x7fff8396f000 -     0x7fff83d15fff  com.apple.Foundation 6.9 (1349.64)     <49C8DA40-9E5B-33F9-B092-F50115B59E95>  /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
        0x7fff8e3d3000 -     0x7fff8e3f0fff  com.apple.icloud.FMCore 1.0 (1)        <41A7B19E-0909-3141-874D-AFC451CF862B>  /System/Library/PrivateFrameworks/FMCore.framework/Versions/A/FMCore
Process:         FindMyMacd [211]
Path:            /System/Library/PrivateFrameworks/FindMyMac.framework/Versions/A/Resources/FindMyMacd
Parent:          launchd [1]
UID:             0
Task size:       11.07 MB
Note:            1 idle work queue threads omitted
  Thread 0x595              DispatchQueue 1           10 samples (1-10)         priority 20 (base 20)
  <thread QoS utility (requested utility), process sudden termination clean, timers tier 3 (coalesced), IO tier 1>
    10  ??? (FindMyMacd + 16319) [0x1083f3fbf] 1-10
  Binary Images:
           0x1083f0000 -        0x108401fff  FindMyMacd (54)                        <09F8D904-7E2B-3724-9F92-9CCD4B513F5C>  /System/Library/PrivateFrameworks/FindMyMac.framework/Versions/A/Resources/FindMyMacd
Process:         fmfd [361]
Path:            /usr/libexec/fmfd
Parent:          launchd [1]
UID:             503
Task size:       32.83 MB
Note:            5 idle work queue threads omitted
  Thread 0xca5              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  ??? (fmfd + 22730) [0x10a13a8ca] 1-10
      10  ??? (fmfd + 114571) [0x10a150f8b] 1-10
  Binary Images:
           0x10a135000 -        0x10a188fff  fmfd (245)                             <2A91A859-2274-3EB2-A7F3-6A1FB3D4F3EE>  /usr/libexec/fmfd
Process:         FolderActionsDispatcher [421]
Path:            /System/Library/CoreServices/FolderActionsDispatcher.app/Contents/MacOS/FolderActionsDispatcher
Parent:          launchd [1]
UID:             503
Task size:       24.09 MB
  Thread 0x14c9             DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
  Thread 0x16de             Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 4 (base 4)
  <thread QoS background (requested user interactive), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2>
  Thread 0x28c53            10 samples (1-10)         priority 4 (base 4)
  <thread QoS background, process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2>
  Binary Images:
           0x104b53000 -        0x104b5ffff  com.apple.FolderActionsDispatcher 1.0 (1) <2E023A4C-4BCD-3D6A-A775-0F7AA8C2E65A>  /System/Library/CoreServices/FolderActionsDispatcher.app/Contents/MacOS/FolderActionsDispatcher
Process:         followupd [4024]
Path:            /System/Library/PrivateFrameworks/CoreFollowUp.framework/Versions/A/Support/followupd
Parent:          launchd [1]
UID:             503
Task size:       15.45 MB
  Thread 0x15506            DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
  <thread QoS background (requested default), process sudden termination dirty, thread darwinbg, process darwinbg, IO tier 2>
    10  ??? (followupd + 58481) [0x10ffd7471] 1-10
  Binary Images:
           0x10ffc9000 -        0x10ffdcfff  followupd (43)                         <431F2DA2-BAFF-3293-9D20-D16BB38E1EFD>  /System/Library/PrivateFrameworks/CoreFollowUp.framework/Versions/A/Support/followupd
Process:         fontd [416]
Path:            /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Support/fontd
Parent:          launchd [1]
UID:             503
Task size:       20.51 MB
  Thread 0xf4f              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  main_handler + 4905 (libATSServer.dylib + 527116) [0x7fff80910b0c] 1-10
  Binary Images:
           0x10207e000 -        0x102081fff  fontd (422.2)                          <BE083B3E-B5A9-32C5-B3FF-11F7E836F850>  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Support/fontd
        0x7fff80890000 -     0x7fff80928fff  libATSServer.dylib (422.2)             <97DB261A-EB5E-3808-AA6F-D99F31EB01ED>  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libATSServer.dylib
Process:         fseventsd [50]
Path:            /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/Support/fseventsd
Parent:          launchd [1]
UID:             0
Task size:       9476 KB
CPU Time:        <0.001
  Thread 0x29d              DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
    10  ??? (fseventsd + 8400) [0x10b7c40d0] 1-10
      10  mach_msg_server + 441 (libsystem_kernel.dylib + 73867) [0x7fff9780908b] 1-10
  Thread 0x2f1              10 samples (1-10)         priority 49 (base 49)     cpu time <0.001
  <IO tier 0>
        10  ??? (fseventsd + 51388) [0x10b7ce8bc] 1-10
          10  ??? (fseventsd + 50200) [0x10b7ce418] 1-10
             *10  psynch_cvcontinue + 0 (pthread + 38973) [0xffffff7f8135f83d] 1-10
  Thread 0x2f9              10 samples (1-10)         priority 31 (base 31)
  <thread QoS default (requested default), IO tier 0 and passive>
        10  ??? (fseventsd + 16923) [0x10b7c621b] 1-10
  Thread 0x2fc              10 samples (1-10)         priority 50 (base 50)     cpu time <0.001
  <IO tier 0>
  Thread 0x2fe              10 samples (1-10)         priority 31 (base 31)
        10  ??? (fseventsd + 35411) [0x10b7caa53] 1-10
  Thread 0xd1a              10 samples (1-10)         priority 31 (base 31)     cpu time <0.001
        10  ??? (fseventsd + 35485) [0x10b7caa9d] 1-10
  Thread 0x1051             10 samples (1-10)         priority 31 (base 31)     cpu time <0.001
  Thread 0x145aa            10 samples (1-10)         priority 31 (base 31)     cpu time <0.001
  Binary Images:
           0x10b7c2000 -        0x10b7d2fff  fseventsd (1230.50.1)                  <ECD8E0B9-3308-3AE3-995A-3B550567114C>  /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/Support/fseventsd
Process:         gamed [360]
Path:            /System/Library/PrivateFrameworks/GameCenterFoundation.framework/Versions/A/gamed
Parent:          launchd [1]
UID:             503
Task size:       42.49 MB
  Thread 0xca7              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  ??? (gamed + 9608) [0x10a161588] 1-10
      10  -[NSRunLoop(NSRunLoop) run] + 76 (Foundation + 140362) [0x7fff8399144a] 1-10
        10  -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 277 (Foundation + 140658) [0x7fff83991572] 1-10
  Thread 0xdfc              Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x10a15f000 -        0x10a544fff  gamed (471.7.2)                        <76C69C41-544E-3049-B0E5-E6C91DE077E2>  /System/Library/PrivateFrameworks/GameCenterFoundation.framework/Versions/A/gamed
Process:         garcon [682]
Path:            /Applications/Dropbox.app/Contents/PlugIns/garcon.appex/Contents/MacOS/garcon
Parent:          launchd [1]
UID:             503
Task size:       30.30 MB
Process:         geodMachServiceBridge [376]
Path:            /System/Library/PrivateFrameworks/GeoServices.framework/geodMachServiceBridge
Parent:          launchd [1]
UID:             503
Task size:       11.57 MB
  Thread 0xd23              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  ??? (geodMachServiceBridge + 3938) [0x10a096f62] 1-10
  Binary Images:
           0x10a096000 -        0x10a096fff  geodMachServiceBridge (1228.24.9.30.34) <B16EE990-F7BE-35F5-AE49-F589BF260321>  /System/Library/PrivateFrameworks/GeoServices.framework/geodMachServiceBridge
Process:         hidd [127]
Path:            /usr/libexec/hidd
Parent:          launchd [1]
UID:             261
Task size:       12.48 MB
Note:            3 idle work queue threads omitted
  Thread 0x37c              DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
    10  ??? (hidd + 3739) [0x1059b4e9b] 1-10
  Thread 0x433              Thread name "IOHIDService - RunLoopCompatibilityThread"                       10 samples (1-10)         priority 63 (base 63)
        10  __IOHIDServiceRunLoopCompatibilityThread + 310 (IOKit + 307147) [0x7fff83f20fcb] 1-10
  Thread 0x12274            10 samples (1-10)         priority 31 (base 31)
        10  void* std::__1::__thread_proxy<std::__1::tuple<AppleUSBALS::scheduleWithDispatchQueue(dispatch_queue_s*)::$_0> >(void*) + 61 (AppleHIDALS + 29607) [0x105b3d3a7] 1-10
          10  AppleUSBALS::scheduleWithDispatchQueue(dispatch_queue_s*)::$_0::operator()() const + 328 (AppleHIDALS + 30074) [0x105b3d57a] 1-10
  Thread 0x35126            10 samples (1-10)         priority 63 (base 63)
        10  _dispatch_worker_thread + 275 (libdispatch.dylib + 21136) [0x7fff976b0290] 1-10
          10  _dispatch_semaphore_wait_slow + 58 (libdispatch.dylib + 43108) [0x7fff976b5864] 1-10
            10  semaphore_timedwait_trap + 10 (libsystem_kernel.dylib + 74654) [0x7fff9780939e] 1-10
  Thread 0x354d9            10 samples (1-10)         priority 63 (base 63)
  Binary Images:
           0x1059b4000 -        0x1059b4fff  hidd (870.50.33)                               <F2A9A1B1-A2C5-373A-BF0B-3B9220EA13D6>  /usr/libexec/hidd
           0x105b36000 -        0x105b3efff  com.apple.hid.AppleHIDALSServicePlugin 1.0 (1) <A922E078-6FBF-3C7A-BA67-C8C4CA9352E8>  /System/Library/Extensions/AppleHIDALSService.kext/Contents/PlugIns/AppleHIDALS.plugin/Contents/MacOS/AppleHIDALS
        0x7fff83ed6000 -     0x7fff83f6bfff  com.apple.framework.IOKit 2.0.2 (1324.50.21)   <BA7DC917-35A9-3D1B-BBEC-ADF4495A166D>  /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
Process:         icdd [437]
Path:            /System/Library/Image Capture/Support/icdd
Parent:          launchd [1]
UID:             503
Task size:       106.55 MB
  Thread 0xfd0              DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
    10  ??? (icdd + 73739) [0x10b14a00b] 1-10
  Thread 0x20f4b            10 samples (1-10)         priority 31 (base 31)
  <IO tier 0>
  Binary Images:
           0x10b138000 -        0x10b16afff  icdd (1126)                            <3CFED2ED-8EB6-33F1-BC6E-AEC898BFCC5C>  /System/Library/Image Capture/Support/icdd
   *0xffffff7f81356000 - 0xffffff7f81361fff  com.apple.kec.pthread 1.0 (1)          <4EFF2F70-C9B9-3176-BF83-F1B660C42135>  /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread
Process:         iconservicesagent [83]
Path:            /System/Library/CoreServices/iconservicesagent
Parent:          launchd [1]
UID:             0
Task size:       6732 KB
  Thread 0x586              DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
     *10  ??? (kernel + 5801776) [0xffffff8000788730] 1-10
  Binary Images:
           0x10b307000 -        0x10b307fff  iconservicesagent (74.4)           <4CE9FFBB-ACAA-36B3-B03A-6FFF07918CD7>  /System/Library/CoreServices/iconservicesagent
Process:         iconservicesagent [440]
Parent:          launchd [1]
UID:             503
Task size:       33.58 MB
  Thread 0x1108             DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x10ebcf000 -        0x10ebcffff  iconservicesagent (74.4)           <4CE9FFBB-ACAA-36B3-B03A-6FFF07918CD7>  /System/Library/CoreServices/iconservicesagent
Process:         iconservicesd [82]
Path:            /System/Library/CoreServices/iconservicesd
Parent:          launchd [1]
UID:             240
Task size:       13.12 MB
  Thread 0x544              DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
  <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 3>
  Binary Images:
           0x10b378000 -        0x10b378fff  iconservicesd (74.4)               <ABF71AF4-C2B9-34FB-9D90-F4A94CD481DD>  /System/Library/CoreServices/iconservicesd
Process:         identityservicesd [334]
Path:            /System/Library/PrivateFrameworks/IDS.framework/identityservicesd.app/Contents/MacOS/identityservicesd
Parent:          launchd [1]
UID:             503
Task size:       44.01 MB
  Thread 0xbaf              DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
    10  ??? (identityservicesd + 342831) [0x10d366b2f] 1-10
  Thread 0xd6a              Thread name "TransportThread Primary"               10 samples (1-10)         priority 31 (base 31)
  Thread 0xd6b              Thread name "TransportThread URGENT"                10 samples (1-10)         priority 31 (base 31)
  Thread 0xd6c              Thread name "TransportThread Default"               10 samples (1-10)         priority 31 (base 31)
  Thread 0xd6d              Thread name "TransportThread Sync"                  10 samples (1-10)         priority 31 (base 31)
  Binary Images:
           0x10d313000 -        0x10d9c0fff  com.apple.identityservicesd 10.0 (1000) <44848F51-D11D-3284-BE57-24CDD693F592>  /System/Library/PrivateFrameworks/IDS.framework/identityservicesd.app/Contents/MacOS/identityservicesd
Process:         imagent [335]
Path:            /System/Library/PrivateFrameworks/IMCore.framework/imagent.app/Contents/MacOS/imagent
Parent:          launchd [1]
UID:             503
Task size:       33.54 MB
  Thread 0xbb1              DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
    10  ??? (imagent + 38733) [0x102f3374d] 1-10
  Binary Images:
           0x102f2a000 -        0x102f7afff  com.apple.imagent 10.0 (1000)          <799A7BEE-D1D3-339A-BC9F-4474C9CA8F9A>  /System/Library/PrivateFrameworks/IMCore.framework/imagent.app/Contents/MacOS/imagent
Process:         IMDPersistenceAgent [337]
Path:            /System/Library/PrivateFrameworks/IMDPersistence.framework/XPCServices/IMDPersistenceAgent.xpc/Contents/MacOS/IMDPersistenceAgent
Parent:          launchd [1]
UID:             503
Task size:       23.71 MB
  Thread 0xbd9              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  ??? (IMDPersistenceAgent + 3398) [0x10fe42d46] 1-10
        10  _xpc_objc_main + 731 (libxpc.dylib + 67739) [0x7fff9793b89b] 1-10
  Binary Images:
           0x10fe42000 -        0x10fe56fff  com.apple.imdpersistence.IMDPersistenceAgent 10.0 (1000) <EAA50603-F28E-33A4-AEC6-97AB736B1E9E>  /System/Library/PrivateFrameworks/IMDPersistence.framework/XPCServices/IMDPersistenceAgent.xpc/Contents/MacOS/IMDPersistenceAgent
Process:         imklaunchagent [433]
Path:            /System/Library/Frameworks/InputMethodKit.framework/Versions/A/Resources/imklaunchagent
Parent:          launchd [1]
UID:             503
Task size:       25.61 MB
  Thread 0xfca              DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
    10  ??? (imklaunchagent + 29012) [0x101a03154] 1-10
  Thread 0x2a46d            10 samples (1-10)         priority 31 (base 31)
  Binary Images:
           0x1019fc000 -        0x101a09fff  imklaunchagent (312.1)                 <718A5CD2-C62B-3168-9F46-900871DC6C99>  /System/Library/Frameworks/InputMethodKit.framework/Versions/A/Resources/imklaunchagent
Process:         IMRemoteURLConnectionAgent [954]
Path:            /System/Library/PrivateFrameworks/IMFoundation.framework/XPCServices/IMRemoteURLConnectionAgent.xpc/Contents/MacOS/IMRemoteURLConnectionAgent
Parent:          launchd [1]
Responsible:     identityservicesd [334]
UID:             503
Task size:       23.82 MB
  Thread 0x2010             DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
  <thread QoS default (requested default), process sudden termination dirty, process unclamped, process received importance donation from identityservicesd [334], IO tier 0>
  Thread 0x201c             Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 31 (base 31)
  Thread 0x4fc9             10 samples (1-10)         priority 37 (base 37)
  <thread QoS user initiated (requested user interactive), process sudden termination dirty, process unclamped, process received importance donation from identityservicesd [334], IO tier 0>
  Binary Images:
           0x100d57000 -        0x100d60fff  com.apple.imfoundation.IMRemoteURLConnectionAgent 10.0 (1000) <36685745-CE50-34BF-8CD1-2239CE90B1A7>  /System/Library/PrivateFrameworks/IMFoundation.framework/XPCServices/IMRemoteURLConnectionAgent.xpc/Contents/MacOS/IMRemoteURLConnectionAgent
Process:         IMRemoteURLConnectionAgent [956]
Parent:          launchd [1]
Responsible:     callservicesd [327]
UID:             503
Task size:       7392 KB
  Thread 0x202c             DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  ??? (IMRemoteURLConnectionAgent + 5024) [0x1039863a0] 1-10
  Binary Images:
           0x103985000 -        0x10398efff  com.apple.imfoundation.IMRemoteURLConnectionAgent 10.0 (1000) <36685745-CE50-34BF-8CD1-2239CE90B1A7>  /System/Library/PrivateFrameworks/IMFoundation.framework/XPCServices/IMRemoteURLConnectionAgent.xpc/Contents/MacOS/IMRemoteURLConnectionAgent
Process:         installd [374]
Path:            /System/Library/PrivateFrameworks/PackageKit.framework/Versions/A/Resources/installd
Parent:          launchd [1]
UID:             0
Task size:       9656 KB
  Thread 0xd0e              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  ??? (installd + 6979) [0x10c705b43] 1-10
      10  CFRunLoopRun + 97 (CoreFoundation + 814129) [0x7fff81fbec31] 1-10
  Binary Images:
           0x10c704000 -        0x10c705fff  installd (629)                         <B46741AC-5400-348B-8B82-B0FDAAE64DC8>  /System/Library/PrivateFrameworks/PackageKit.framework/Versions/A/Resources/installd
Process:         installerdiagd [1270]
Path:            /System/Library/PrivateFrameworks/InstallerDiagnostics.framework/Versions/A/Resources/installerdiagd
Parent:          launchd [1]
UID:             0
Task size:       6800 KB
  Thread 0x428b             DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x1027a0000 -        0x1027a0fff  installerdiagd (27)                <7ECE44BB-3129-398C-9A05-35332194F82B>  /System/Library/PrivateFrameworks/InstallerDiagnostics.framework/Versions/A/Resources/installerdiagd
Process:         installerdiagwatcher [62]
Path:            /System/Library/PrivateFrameworks/InstallerDiagnostics.framework/Versions/A/Resources/installerdiagwatcher
Parent:          launchd [1]
UID:             0
Task size:       9248 KB
  Thread 0x2eb              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x1036c2000 -        0x1036c8fff  installerdiagwatcher (27)              <D93F117F-4538-33D7-99F5-A8524573AED3>  /System/Library/PrivateFrameworks/InstallerDiagnostics.framework/Versions/A/Resources/installerdiagwatcher
Process:         iStat Menus Notifications [431]
Path:            /Library/Application Support/iStat Menus 5/iStat Menus Notifications.app/Contents/MacOS/iStat Menus Notifications
Parent:          launchd [1]
UID:             503
Task size:       29 MB
Process:         iStat Menus Status [453]
Path:            /Library/Application Support/iStat Menus 5/iStat Menus Status.app/Contents/MacOS/iStat Menus Status
Parent:          launchd [1]
UID:             503
Task size:       82.59 MB
CPU Time:        0.008
Process:         iStatMenusAgent [439]
Path:            /Library/Application Support/iStat Menus 5/iStatMenusAgent.app/Contents/MacOS/iStatMenusAgent
Parent:          launchd [1]
UID:             503
Task size:       37.96 MB
Process:         iStatMenusDaemon [59]
Path:            /Library/Application Support/iStat Menus 5/iStatMenusDaemon
Parent:          launchd [1]
UID:             0
Task size:       28.31 MB
  Thread 0x52e              DispatchQueue 11          10 samples (1-10)         priority 20 (base 20)
  <thread QoS utility (requested default), timers tier 3 (coalesced), IO tier 1>
  Binary Images:
           0x102809000 -        0x102877fff  iStatMenusDaemon (0)               <4C4F6E06-E422-3E80-8D31-A3BA8DF09438>  /Library/Application Support/iStat Menus 5/iStatMenusDaemon
Process:         iTunesHelper (iTunes Helper) [468]
Path:            /Applications/iTunes.app/Contents/MacOS/iTunesHelper.app/Contents/MacOS/iTunesHelper
Parent:          launchd [1]
UID:             503
Task size:       18.39 MB
  Thread 0x1031             DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
    10  ??? (iTunesHelper + 56451) [0x1078b9c83] 1-10
  Thread 0x1034             DispatchQueue 10          10 samples (1-10)         priority 31 (base 31)
  <thread QoS default (requested user initiated), IO tier 0>
  10  start_wqthread + 13 (libsystem_pthread.dylib + 12529) [0x7fff978fb0f1] 1-10
    10  _pthread_wqthread + 1299 (libsystem_pthread.dylib + 13846) [0x7fff978fb616] 1-10
      10  _dispatch_worker_thread3 + 99 (libdispatch.dylib + 13452) [0x7fff976ae48c] 1-10
        10  _dispatch_root_queue_drain + 476 (libdispatch.dylib + 14005) [0x7fff976ae6b5] 1-10
          10  _dispatch_queue_override_invoke + 743 (libdispatch.dylib + 65942) [0x7fff976bb196] 1-10
            10  _dispatch_client_callout + 8 (libdispatch.dylib + 6396) [0x7fff976ac8fc] 1-10
              10  __thr_AMRegisterForCallbacks + 426 (MobileDevice + 863388) [0x7fff91a18c9c] 1-10
  Thread 0x1044             Thread name "com.apple.CFSocket.private"            10 samples (1-10)         priority 31 (base 31)
  Thread 0x231c2            10 samples (1-10)         priority 31 (base 31)
  <IO tier 0>
  Binary Images:
           0x1078ac000 -        0x1078c6fff  com.apple.iTunesHelper 12.6 (12.6.0)       <0AEABF68-8FDA-388F-B5A9-7123C2048BA5>  /Applications/iTunes.app/Contents/MacOS/iTunesHelper.app/Contents/MacOS/iTunesHelper
        0x7fff91946000 -     0x7fff91a8ffff  com.apple.mobiledevice 905.60.1 (905.60.1) <CB2E61B2-2378-350D-A3C5-81ECFD6B6985>  /System/Library/PrivateFrameworks/MobileDevice.framework/Versions/A/MobileDevice
Process:         kdc [117]
Path:            /System/Library/PrivateFrameworks/Heimdal.framework/Helpers/kdc
Parent:          launchd [1]
UID:             0
Task size:       13.89 MB
  Thread 0x589              DispatchQueue 11          10 samples (1-10)         priority 20 (base 20)
  Binary Images:
           0x107ba5000 -        0x107bd8fff  kdc (498.50.8)                     <845D7753-2842-3E31-AB3F-5C717FA01F41>  /System/Library/PrivateFrameworks/Heimdal.framework/Helpers/kdc
Process:         KernelEventAgent [123]
Path:            /usr/sbin/KernelEventAgent
Parent:          launchd [1]
UID:             0
Task size:       3676 KB
  Thread 0x2cd              DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
    10  main + 1373 (KernelEventAgent + 6320) [0x10d9658b0] 1-10
  Thread 0x2f7              Thread name "com.apple.CFSocket.private"            10 samples (1-10)         priority 31 (base 31)
  Binary Images:
           0x10d964000 -        0x10d969fff  KernelEventAgent (97.50.1)             <5C842B41-C5A0-38FB-8273-F47017184D57>  /usr/sbin/KernelEventAgent
Process:         kextd [49]
Path:            /usr/libexec/kextd
Parent:          launchd [1]
UID:             0
Task size:       25.68 MB
  Thread 0x2a0              DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
    10  ??? (kextd + 7603) [0x103fb3db3] 1-10
  Binary Images:
           0x103fb2000 -        0x103fd1fff  kextd (460.50.8)                       <4EFA3385-F5A5-3AF9-86D9-8C6CD990F539>  /usr/libexec/kextd
Process:         keyboardservicesd [356]
Path:            /usr/libexec/keyboardservicesd
Parent:          launchd [1]
UID:             503
Task size:       28.09 MB
Note:            4 idle work queue threads omitted
  Thread 0xca1              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  ??? (keyboardservicesd + 2904) [0x103943b58] 1-10
  Thread 0x206a             Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x103943000 -        0x103943fff  keyboardservicesd (67.3.7)             <7C79FE05-5D51-3083-AADD-5F1E8BC50A3E>  /usr/libexec/keyboardservicesd
Process:         KeychainSyncingOverIDSProxy [401]
Path:            /System/Library/Frameworks/Security.framework/Versions/A/Resources/KeychainSyncingOverIDSProxy.bundle/Contents/MacOS/KeychainSyncingOverIDSProxy
Parent:          launchd [1]
UID:             503
Task size:       16.37 MB
  Thread 0xe5b              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  ??? (KeychainSyncingOverIDSProxy + 20872) [0x10c107188] 1-10
      10  ??? (KeychainSyncingOverIDSProxy + 20647) [0x10c1070a7] 1-10
  Binary Images:
           0x10c102000 -        0x10c117fff  com.apple.security.keychainsyncingoveridsproxy 1.0 () <4FC08983-8C67-325A-8BF9-23CABD8B7DE8>  /System/Library/Frameworks/Security.framework/Versions/A/Resources/KeychainSyncingOverIDSProxy.bundle/Contents/MacOS/KeychainSyncingOverIDSProxy
Process:         LaterAgent [871]
Path:            /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Resources/LaterAgent.app/Contents/MacOS/LaterAgent
Parent:          launchd [1]
UID:             503
Task size:       30.05 MB
  Thread 0x1b92             DispatchQueue 1           10 samples (1-10)         priority 20 (base 20)
    10  ??? (LaterAgent + 7099) [0x10cb65bbb] 1-10
      10  NSApplicationMain + 1237 (AppKit + 25054) [0x7fff7fa3b1de] 1-10
        10  -[NSApplication run] + 926 (AppKit + 243627) [0x7fff7fa707ab] 1-10
          10  -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 2796 (AppKit + 8136798) [0x7fff801f785e] 1-10
            10  _DPSNextEvent + 1120 (AppKit + 290340) [0x7fff7fa7be24] 1-10
              10  _BlockUntilNextEventMatchingListInModeWithFilter + 71 (HIToolbox + 199462) [0x7fff814e0b26] 1-10
                10  ReceiveNextEventCommon + 432 (HIToolbox + 199921) [0x7fff814e0cf1] 1-10
                  10  RunCurrentEventLoopInMode + 240 (HIToolbox + 200380) [0x7fff814e0ebc] 1-10
  Thread 0x1bdb             Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 20 (base 20)
  <thread QoS utility (requested user interactive), process sudden termination clean, timers tier 3 (coalesced), IO tier 1>
        10  _NSEventThread + 205 (AppKit + 1655506) [0x7fff7fbc92d2] 1-10
  Thread 0x28a81            10 samples (1-10)         priority 20 (base 20)
  <thread QoS utility, process sudden termination clean, timers tier 3 (coalesced), IO tier 1>
  Binary Images:
           0x10cb64000 -        0x10cb6ffff  com.apple.lateragent 1.0 (582.5)       <1162DAE1-2C7E-3D9F-8494-116E056F4992>  /System/Library/PrivateFrameworks/CommerceKit.framework/Resources/LaterAgent.app/Contents/MacOS/LaterAgent
        0x7fff7fa35000 -     0x7fff8080efff  com.apple.AppKit 6.9 (1504.82.104)     <C295FF09-9984-34C3-953B-B263EF2107AB>  /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
        0x7fff814b0000 -     0x7fff817b9fff  com.apple.HIToolbox 2.1.1 (857.8)      <40254D9A-E477-3F33-B2A2-807D399BF71C>  /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
Process:         launchd [1]
Path:            /sbin/launchd
Parent:          kernel_task [0]
UID:             0
Task size:       18.28 MB
CPU Time:        0.001
  Thread 0x1fe              DispatchQueue 38          Thread name "system shutdown has not yet begun"     10 samples (1-10)         priority 37 (base 37)
  <thread QoS user initiated (requested user initiated, override user initiated), IO tier 0>
          10  _dispatch_queue_override_invoke + 369 (libdispatch.dylib + 65568) [0x7fff976bb020] 1-10
            10  _dispatch_queue_invoke + 1046 (libdispatch.dylib + 41734) [0x7fff976b5306] 1-10
              10  _dispatch_queue_serial_drain + 896 (libdispatch.dylib + 96672) [0x7fff976c29a0] 1-10
                  10  ??? (launchd + 105825) [0x10bb88d61] 1-10
                    10  _dispatch_semaphore_wait_slow + 103 (libdispatch.dylib + 43153) [0x7fff976b5891] 1-10
                      10  semaphore_wait_trap + 10 (libsystem_kernel.dylib + 74630) [0x7fff97809386] 1-10
  Thread 0x1ff              DispatchQueue 11          10 samples (1-10)         priority 31 (base 31)
  Binary Images:
           0x10bb6f000 -        0x10bbb2fff  launchd (972.50.27)                <22A1A952-D186-3371-8E10-1C7AAA0FFCA8>  /sbin/launchd
Process:         launchservicesd [105]
Path:            /System/Library/CoreServices/launchservicesd
Parent:          launchd [1]
UID:             0
Task size:       19.64 MB (+4096  B)
CPU Time:        <0.001
  Thread 0x387              DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x104dd1000 -        0x104ddcfff  launchservicesd (775.19)           <495CBA3C-66D2-374E-968E-E8A33D1EB107>  /System/Library/CoreServices/launchservicesd
Process:         Little Snitch Agent [331]
Path:            /Library/Little Snitch/Little Snitch Agent.app/Contents/MacOS/Little Snitch Agent
Parent:          launchd [1]
UID:             503
Task size:       57.54 MB
CPU Time:        <0.001
Process:         Little Snitch Daemon [86]
Path:            /Library/Little Snitch/Little Snitch Daemon.bundle/Contents/MacOS/Little Snitch Daemon
Parent:          launchd [1]
UID:             0
Task size:       32.84 MB
CPU Time:        0.001
Process:         Little Snitch Network Monitor [624]
Path:            /Library/Little Snitch/Little Snitch Network Monitor.app/Contents/MacOS/Little Snitch Network Monitor
Parent:          launchd [1]
UID:             503
Task size:       41.86 MB
CPU Time:        0.001
Process:         locationd [110]
Path:            /usr/libexec/locationd
Parent:          launchd [1]
UID:             205
Task size:       31.11 MB
  Thread 0x455              DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
  <thread QoS default (requested default), process unclamped, process received importance donation from airportd [72], IO tier 0>
    10  ??? (locationd + 27666) [0x10cf5ac12] 1-10
      10  ??? (locationd + 19882) [0x10cf58daa] 1-10
        10  ??? (locationd + 17940) [0x10cf58614] 1-10
  Thread 0x7a2              10 samples (1-10)         priority 31 (base 31)
        10  ??? (locationd + 281837) [0x10cf98ced] 1-10
  Thread 0x7a3              10 samples (1-10)         priority 31 (base 31)
        10  ??? (locationd + 281851) [0x10cf98cfb] 1-10
          10  ??? (locationd + 286165) [0x10cf99dd5] 1-10
            10  ??? (locationd + 272222) [0x10cf9675e] 1-10
              10  ??? (locationd + 273519) [0x10cf96c6f] 1-10
  Thread 0x7a4              10 samples (1-10)         priority 31 (base 31)
        10  ??? (locationd + 281865) [0x10cf98d09] 1-10
  Thread 0x1999             Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 31 (base 31)
        10  __NSThread__start__ + 1243 (Foundation + 207821) [0x7fff839a1bcd] 1-10
          10  +[NSURLConnection(Loader) _resourceLoadLoop:] + 313 (CFNetwork + 26116) [0x7fff810bd604] 1-10
  Binary Images:
           0x10cf54000 -        0x10d3d8fff  locationd (2101.0.62)                   <93F73643-3C80-3A84-B2D2-3BF1FEC15B98>  /usr/libexec/locationd
        0x7fff810b7000 -     0x7fff81491fff  com.apple.CFNetwork 811.4.18 (811.4.18) <9CE329E8-6177-3474-976D-F5C63FC875CD>  /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
Process:         logd [67]
Path:            /usr/libexec/logd
Parent:          launchd [1]
UID:             0
Task size:       22.89 MB (+16 KB)
CPU Time:        <0.001
  Thread 0x312              DispatchQueue 11          10 samples (1-10)         priority 31 (base 31)
  Binary Images:
           0x10239f000 -        0x1023befff  logd (518.51.1)                    <1FF63FF5-C32E-3D37-881E-E19B39AFA57E>  /usr/libexec/logd
Process:         logind [122]
Path:            /System/Library/CoreServices/logind
Parent:          launchd [1]
UID:             0
Task size:       9388 KB
  Thread 0x2d0              DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
    10  ??? (logind + 6089) [0x10ab9c7c9] 1-10
  Binary Images:
           0x10ab9b000 -        0x10aba5fff  logind (33)                            <2C59731F-9CBC-35DB-B80D-D0B2DF86BA96>  /System/Library/CoreServices/logind
Process:         LOGINserver [438]
Path:            /Library/Printers/Brother/Utilities/Server/LOGINserver.app/Contents/MacOS/LOGINserver
Architecture:    i386
Parent:          launchd [1]
UID:             503
Task size:       7492 KB
Process:         loginwindow [121]
Path:            /System/Library/CoreServices/loginwindow.app/Contents/MacOS/loginwindow
Parent:          launchd [1]
UID:             503
Task size:       79.91 MB
CPU Time:        <0.001
  Thread 0x2cc              DispatchQueue 1           10 samples (1-10)         priority 47 (base 47)     cpu time <0.001
  <thread QoS user interactive (requested user interactive), process unclamped, IO tier 0>
    10  ??? (loginwindow + 22733) [0x1048ca8cd] 1-10
                         *8  ipc_mqueue_receive_continue + 0 (kernel + 862304) [0xffffff80002d2860] 1-8
  <process clamped>
                         *2  ipc_mqueue_receive_continue + 0 (kernel + 862304) [0xffffff80002d2860] 9-10
  Binary Images:
           0x1048c5000 -        0x1049b0fff  com.apple.loginwindow 9.0 (1745.3.1)   <6AD7A03D-0503-3412-ACDC-E5A4CC0E7378>  /System/Library/CoreServices/loginwindow.app/Contents/MacOS/loginwindow
Process:         lsd [209]
Path:            /usr/libexec/lsd
Parent:          launchd [1]
UID:             0
Task size:       26.46 MB (+28 KB)
CPU Time:        <0.001
  Thread 0x56c              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  _LSServerMain + 619 (LaunchServices + 241840) [0x7fff831640b0] 1-10
  Binary Images:
           0x10105d000 -        0x10105dfff  lsd (775.19)                             <19DA45F4-AF24-32EB-A93A-6B89EA4A07CD>  /usr/libexec/lsd
        0x7fff83129000 -     0x7fff83295fff  com.apple.LaunchServices 775.19 (775.19) <1CF81B5F-BA1A-3FC6-B4F9-E0A319AE94D0>  /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
Process:         lsd [320]
Parent:          launchd [1]
UID:             503
Task size:       29.75 MB
  Thread 0xb47              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x107078000 -        0x107078fff  lsd (775.19)                             <19DA45F4-AF24-32EB-A93A-6B89EA4A07CD>  /usr/libexec/lsd
Process:         Mail [1964]
Path:            /Applications/Mail.app/Contents/MacOS/Mail
Parent:          launchd [1]
UID:             503
Task size:       249.78 MB
CPU Time:        0.001
  Thread 0x7a47             DispatchQueue 1           10 samples (1-10)         priority 46 (base 46)     cpu time 0.001
  <thread QoS user interactive (requested user interactive), process sudden termination clean, process unclamped, IO tier 0>
  <process clamped>
  Thread 0x7aab             10 samples (1-10)         priority 46 (base 46)
        10  void* std::__1::__thread_proxy<std::__1::tuple<void (*)(bmalloc::AsyncTask<bmalloc::Heap, void (bmalloc::Heap::*)()>*), bmalloc::AsyncTask<bmalloc::Heap, void (bmalloc::Heap::*)()>*> >(void*) + 93 (JavaScriptCore + 12002381) [0x7fff84f8844d] 1-10
          10  bmalloc::AsyncTask<bmalloc::Heap, void (bmalloc::Heap::*)()>::threadEntryPoint(bmalloc::AsyncTask<bmalloc::Heap, void (bmalloc::Heap::*)()>*) + 29 (JavaScriptCore + 12001693) [0x7fff84f8819d] 1-10
            10  bmalloc::AsyncTask<bmalloc::Heap, void (bmalloc::Heap::*)()>::threadRunLoop() + 155 (JavaScriptCore + 12001995) [0x7fff84f882cb] 1-10
              10  void std::__1::condition_variable_any::wait<std::__1::unique_lock<bmalloc::Mutex> >(std::__1::unique_lock<bmalloc::Mutex>&) + 108 (JavaScriptCore + 12002124) [0x7fff84f8834c] 1-10
                10  std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 47 (libc++.1.dylib + 29901) [0x7fff9627b4cd] 1-10
                   *8  psynch_cvcontinue + 0 (pthread + 38973) [0xffffff7f8135f83d] 1-8
  <process clamped>
                   *2  psynch_cvcontinue + 0 (pthread + 38973) [0xffffff7f8135f83d] 9-10
  Thread 0x7abe             Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 31 (base 31)
  <thread QoS default (requested default), process sudden termination clean, process unclamped, IO tier 0>
  <process clamped>
  Thread 0x7ad8             Thread name "com.apple.CFSocket.private"            10 samples (1-10)         priority 46 (base 46)
        10  __select + 10 (libsystem_kernel.dylib + 106166) [0x7fff97810eb6] 1-10
         *8  ??? (kernel + 5801776) [0xffffff8000788730] 1-8
  <process clamped>
         *2  ??? (kernel + 5801776) [0xffffff8000788730] 9-10
  Thread 0x7af7             Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 46 (base 46)
  <process clamped>
  Thread 0x7b03             Thread name "com.apple.coreanimation.render-server" 10 samples (1-10)         priority 55 (base 55)
  <process sudden termination clean, process unclamped, IO tier 0>
  <process clamped>
  Thread 0x7b42             Thread name "com.apple.CFNetwork.CustomProtocols"   10 samples (1-10)         priority 31 (base 31)
  <process clamped>
  Binary Images:
           0x1010ba000 -        0x10149dfff  com.apple.mail 10.3 (3273)                       <4F65E4CB-6A2B-34BA-B6D4-43AA25BA156C>  /Applications/Mail.app/Contents/MacOS/Mail
        0x7fff84416000 -     0x7fff8501efff  com.apple.JavaScriptCore 12603 (12603.1.30.0.34) <42993DA4-E18A-3A41-86F8-23A6656273F9>  /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
        0x7fff96274000 -     0x7fff962cafff  libc++.1.dylib (307.5)                           <0B43BB5D-E6EB-3464-8DE9-B41AC8ED9D1C>  /usr/lib/libc++.1.dylib
Process:         mapspushd [351]
Path:            /System/Library/CoreServices/mapspushd
Parent:          launchd [1]
UID:             503
Task size:       28.56 MB
  Thread 0xc58              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  main + 210 (mapspushd + 4563) [0x10b3b51d3] 1-10
      10  -[MapsPushDaemonLocalProxy runServer] + 171 (mapspushd + 53232) [0x10b3c0ff0] 1-10
  Thread 0xeab              Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x10b3b4000 -        0x10b3cafff  mapspushd (1983.24.9.30.35)             <91E17B56-8440-3369-B2AB-A0B36FDA1E69>  /System/Library/CoreServices/mapspushd
Process:         mdflagwriter [924]
Path:            /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Support/mdflagwriter
Parent:          launchd [1]
UID:             0
Task size:       2092 KB
  Thread 0x1d69             10 samples (1-10)         priority 31 (base 31)
  <thread QoS default (requested default), process sudden termination clean, IO tier 0>
  Binary Images:
           0x109b99000 -        0x109b99fff  mdflagwriter (1075.40)             <2A44C154-7E66-3261-8598-63703D074B98>  /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/A/Support/mdflagwriter
Process:         mdflagwriter [929]
Parent:          launchd [1]
UID:             503
Task size:       2276 KB
  Thread 0x1de9             10 samples (1-10)         priority 31 (base 31)
  Binary Images:
           0x10bb3d000 -        0x10bb3dfff  mdflagwriter (1075.40)             <2A44C154-7E66-3261-8598-63703D074B98>  /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/A/Support/mdflagwriter
Process:         mDNSResponder [200]
Path:            /usr/sbin/mDNSResponder
Parent:          launchd [1]
UID:             65
Task size:       15.99 MB
CPU Time:        <0.001
  Thread 0x4f3              DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
    10  main + 1770 (mDNSResponder + 9548) [0x10f3a254c] 1-10
  Thread 0x55e              10 samples (1-10)         priority 31 (base 31)     cpu time <0.001
  Binary Images:
           0x10f3a0000 -        0x10f44efff  mDNSResponder (765.50.9)               <B68C20C8-B2A4-3332-B86C-B496464BD6DF>  /usr/sbin/mDNSResponder
Process:         mDNSResponderHelper [201]
Path:            /usr/sbin/mDNSResponderHelper
Parent:          launchd [1]
UID:             0
Task size:       8388 KB
CPU Time:        <0.001
  Thread 0x53a              DispatchQueue 11          10 samples (1-10)         priority 31 (base 31)
  Thread 0x543              10 samples (1-10)         priority 31 (base 31)     cpu time <0.001
        10  idletimer + 72 (mDNSResponderHelper + 29994) [0x108e5152a] 1-10
          10  sleep + 42 (libsystem_c.dylib + 526803) [0x7fff977979d3] 1-10
            10  __semwait_signal + 10 (libsystem_kernel.dylib + 106310) [0x7fff97810f46] 1-10
  Binary Images:
           0x108e4a000 -        0x108e56fff  mDNSResponderHelper (765.50.9)     <3A4A9505-CE9C-33DF-9B2F-AD674F436A64>  /usr/sbin/mDNSResponderHelper
        0x7fff97717000 -     0x7fff977a4fff  libsystem_c.dylib (1158.50.2)      <B03F8915-1E9B-3C84-AED5-68E2E0031630>  /usr/lib/system/libsystem_c.dylib
Process:         mds [75]
Path:            /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Support/mds
Parent:          launchd [1]
UID:             0
Task size:       51.45 MB
CPU Time:        <0.001
  Thread 0x2ae              DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
    10  ??? (mds + 49081) [0x10a214fb9] 1-10
  Thread 0x564              10 samples (1-10)         priority 50 (base 50)     cpu time <0.001
  <IO tier 0 and passive>
        10  read + 10 (libsystem_kernel.dylib + 111174) [0x7fff97812246] 1-10
         *10  hndl_unix_scall64 + 22 (kernel + 646470) [0xffffff800029dd46] 1-10
           *10  unix_syscall64 + 597 (kernel + 6444693) [0xffffff8000825695] 1-10
             *10  read_nocancel + 115 (kernel + 5884291) [0xffffff800079c983] 1-10
               *10  ??? (kernel + 5884954) [0xffffff800079cc1a] 1-10
                 *10  ??? (kernel + 3479568) [0xffffff8000551810] 1-10
                   *10  ??? (kernel + 5801314) [0xffffff8000788562] 1-10
                     *10  thread_block_reason + 222 (kernel + 1069422) [0xffffff800030516e] 1-10
                       *10  ??? (kernel + 1073995) [0xffffff800030634b] 1-10
                         *10  machine_switch_context + 206 (kernel + 2082766) [0xffffff80003fc7ce] 1-10
  Thread 0x68f              10 samples (1-10)         priority 31 (base 31)
        10  _handleExceptions + 280 (SpotlightIndex + 1165717) [0x7fff93f5d995] 1-10
  Binary Images:
           0x10a209000 -        0x10a3bffff  mds (1075.40)                              <723E90DB-AB03-3041-8382-8EFC1F05511B>  /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Support/mds
        0x7fff93e41000 -     0x7fff940c3fff  com.apple.spotlight.index 10.7.0 (1075.40) <47702E88-6008-3608-8E12-85B56EAEC9EC>  /System/Library/PrivateFrameworks/SpotlightIndex.framework/Versions/A/SpotlightIndex
Process:         mds_stores [217]
Path:            /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Support/mds_stores
Parent:          launchd [1]
UID:             0
Task size:       123.43 MB
  Thread 0x5e2              DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
  <thread QoS default (requested default), process sudden termination dirty, IO tier 0 and passive>
    10  ??? (mds_stores + 16637) [0x1034120fd] 1-10
  Thread 0x620              10 samples (1-10)         priority 31 (base 31)
  Binary Images:
           0x10340e000 -        0x103460fff  mds_stores (1075.40)                       <8BE5A0C1-1CC1-3D32-A2F7-FFF99CBCF0AA>  /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Support/mds_stores
Process:         mdworker [957]
Path:            /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Support/mdworker
Parent:          launchd [1]
UID:             503
Task size:       46.78 MB
  Thread 0x2046             DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  ??? (mdworker + 41075) [0x1052f3073] 1-10
  Thread 0x2065             10 samples (1-10)         priority 4 (base 4)
  <thread QoS background (requested background), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2>
        10  ??? (mdworker + 49181) [0x1052f501d] 1-10
          10  ??? (mdworker + 64347) [0x1052f8b5b] 1-10
  Thread 0x206b             10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x1052e9000 -        0x105355fff  mdworker (1075.40)                     <2DF77B8C-E999-384C-B15D-9AFE38E2F634>  /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/A/Support/mdworker
Process:         mdworker [958]
Parent:          launchd [1]
UID:             503
Task size:       37.13 MB
  Thread 0x2047             DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  ??? (mdworker + 41075) [0x10bb67073] 1-10
  Thread 0x2063             10 samples (1-10)         priority 4 (base 4)
        10  ??? (mdworker + 49181) [0x10bb6901d] 1-10
          10  ??? (mdworker + 64347) [0x10bb6cb5b] 1-10
  Thread 0x24ba             10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x10bb5d000 -        0x10bbc9fff  mdworker (1075.40)                     <2DF77B8C-E999-384C-B15D-9AFE38E2F634>  /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/A/Support/mdworker
Process:         mdworker [959]
Parent:          launchd [1]
UID:             503
Task size:       35.73 MB
  Thread 0x2048             DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  ??? (mdworker + 41075) [0x103b52073] 1-10
  Thread 0x2066             10 samples (1-10)         priority 4 (base 4)
        10  ??? (mdworker + 49181) [0x103b5401d] 1-10
          10  ??? (mdworker + 64347) [0x103b57b5b] 1-10
  Thread 0x2f7a             10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x103b48000 -        0x103bb4fff  mdworker (1075.40)                     <2DF77B8C-E999-384C-B15D-9AFE38E2F634>  /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/A/Support/mdworker
Process:         mdworker [960]
Parent:          launchd [1]
UID:             503
Task size:       33.14 MB
  Thread 0x2049             DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  ??? (mdworker + 41075) [0x10a8f5073] 1-10
  Thread 0x2064             10 samples (1-10)         priority 4 (base 4)
        10  ??? (mdworker + 49181) [0x10a8f701d] 1-10
          10  ??? (mdworker + 64347) [0x10a8fab5b] 1-10
  Thread 0x2f79             10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x10a8eb000 -        0x10a957fff  mdworker (1075.40)                     <2DF77B8C-E999-384C-B15D-9AFE38E2F634>  /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/A/Support/mdworker
Process:         mdworker [3964]
Parent:          launchd [1]
UID:             503
Task size:       23.84 MB
CPU Time:        0.588
  Thread 0x14da9            DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
  <thread QoS background, process sudden termination dirty, thread darwinbg, process darwinbg, IO tier 3>
    10  ??? (mdworker + 41075) [0x101281073] 1-10
  Thread 0x20239            DispatchQueue 31          10 samples (1-10)         priority 4 (base 4)       cpu time 0.588
  <thread QoS maintenance (requested maintenance), process sudden termination dirty, thread darwinbg, process darwinbg, IO tier 3>
                10  _dispatch_call_block_and_release + 12 (libdispatch.dylib + 42276) [0x7fff976b5524] 1-10
                  10  ??? (mdworker + 164767) [0x10129f39f] 1-10
                    10  ??? (mdworker + 143244) [0x101299f8c] 1-10
                      10  _NodeSizing + 67 (DesktopServicesPriv + 507478) [0x7fff8e12ae56] 1-10
                        10  _NodeSizingV2 + 536 (DesktopServicesPriv + 508056) [0x7fff8e12b098] 1-10
                          10  TOperationSizer::ComputeSize() + 422 (DesktopServicesPriv + 204828) [0x7fff8e0e101c] 1-10
                            8  TOperationSizer::StartSizing() + 283 (DesktopServicesPriv + 208333) [0x7fff8e0e1dcd] 1-8
                              8  TDeepCFURLIterator::Next(TRef<TCFURLInfo*, TInternalRefCountPolicy<TCFURLInfo> >&, int&, int&, bool&, TRef<TCFURLInfo*, TInternalRefCountPolicy<TCFURLInfo> >&, bool&, TRef<TCFURLInfo*, TInternalRefCountPolicy<TCFURLInfo> >&) + 71 (DesktopServicesPriv + 665147) [0x7fff8e15163b] 1-8
                                8  TDeepCFURLIterator::NextInternal(TRef<TCFURLInfo*, TInternalRefCountPolicy<TCFURLInfo> >&, int&, int&, bool&, TRef<TCFURLInfo*, TInternalRefCountPolicy<TCFURLInfo> >&, bool&, TRef<TCFURLInfo*, TInternalRefCountPolicy<TCFURLInfo> >&) + 161 (DesktopServicesPriv + 665743) [0x7fff8e15188f] 1-8
                                  8  TCFURLIterator::Next(TRef<TCFURLInfo*, TInternalRefCountPolicy<TCFURLInfo> >&) + 84 (DesktopServicesPriv + 638142) [0x7fff8e14acbe] 1-8
                                    1  TCFURLIterator::NextRaw(TRef<TCFURLInfo*, TInternalRefCountPolicy<TCFURLInfo> >&) + 102 (DesktopServicesPriv + 659788) [0x7fff8e15014c] 1
                                      1  TCFURLInfo::Initialize(__CFURL const*, bool, bool) + 223 (DesktopServicesPriv + 25951) [0x7fff8e0b555f] 1
                                        1  TCFURLInfo::FetchProperties(bool) + 653 (DesktopServicesPriv + 26641) [0x7fff8e0b5811] 1
                                          1  TCFURLInfo::GetBooleanProperty(__CFURL const*, __CFString const*) + 30 (DesktopServicesPriv + 28546) [0x7fff8e0b5f82] 1
                                            1  CFURLCopyResourcePropertyForKey + 238 (CoreFoundation + 441454) [0x7fff81f63c6e] 1
                                              1  _FSURLCopyResourcePropertyForKeyInternal(__CFURL const*, __CFString const*, void*, void*, __CFError**, unsigned char) + 199 (CoreServicesInternal + 82025) [0x7fff8d8f6069] 1
                                                1  prepareValuesForBitmap(__CFURL const*, __FileCache*, _FilePropertyBitmap*, __CFError**) + 227 (CoreServicesInternal + 91057) [0x7fff8d8f83b1] 1
                                                  1  __getattrlist + 10 (libsystem_kernel.dylib + 103466) [0x7fff9781042a] 1
                                                   *1  hndl_unix_scall64 + 22 (kernel + 646470) [0xffffff800029dd46] 1
                                                     *1  unix_syscall64 + 597 (kernel + 6444693) [0xffffff8000825695] 1
                                                       *1  getattrlist + 119 (kernel + 3118039) [0xffffff80004f93d7] 1
                                                         *1  ??? (kernel + 3118351) [0xffffff80004f950f] 1
                                                           *1  ??? (kernel + 3109170) [0xffffff80004f7132] 1
                                                             *1  ??? (kernel + 3099416) [0xffffff80004f4b18] 1
                                                               *1  mac_vnode_check_access + 207 (kernel + 7491615) [0xffffff800092501f] 1
        *1  hook_vnode_check_access + 172 (Sandbox + 21622) [0xffffff7f81331476] 1
        *1  sb_evaluate + 418 (Sandbox + 51206) [0xffffff7f81338806] 1
        *1  eval + 343 (Sandbox + 52060) [0xffffff7f81338b5c] 1
        *1  eval_filter + 477 (Sandbox + 53181) [0xffffff7f81338fbd] 1
        *1  derive_vnode_path + 103 (Sandbox + 48606) [0xffffff7f81337dde] 1
        *1  sandbox_normalize_string + 353 (Sandbox + 67735) [0xffffff7f8133c897] 1
        *1  utf8_encodelen + 181 (kernel + 3386837) [0xffffff800053add5] (running) 1
                                    4  TCFURLIterator::NextRaw(TRef<TCFURLInfo*, TInternalRefCountPolicy<TCFURLInfo> >&) + 42 (DesktopServicesPriv + 659728) [0x7fff8e150110] 2-5
                                      4  _URLEnumeratorGetNextURL + 167 (CoreServicesInternal + 149258) [0x7fff8d90670a] 2-5
                                        1  _GetDirectoryURLs(_CFURLEnumerator*) + 666 (CoreServicesInternal + 152091) [0x7fff8d90721b] 2
                                          1  _FSURLCreateWithPathAndAttributes + 165 (CoreServicesInternal + 102448) [0x7fff8d8fb030] 2
                                            1  createBaseCacheWithPathAndAttributes(__CFAllocator const*, unsigned char const*, unsigned int, unsigned char, unsigned char, attrlist const*, void const*, void**, __CFError**) + 219 (CoreServicesInternal + 103204) [0x7fff8d8fb324] 2
                                              1  parseAttributeBuffer(__CFAllocator const*, unsigned char const*, unsigned char, attrlist const*, void const*, void**, _FileAttributes*, unsigned int*) + 360 (CoreServicesInternal + 130476) [0x7fff8d901dac] 2
                                                1  CFStringCreateWithBytes + 0 (CoreFoundation + 82784) [0x7fff81f0c360] (running) 2
                                        1  _GetDirectoryURLs(_CFURLEnumerator*) + 1275 (CoreServicesInternal + 152700) [0x7fff8d90747c] 3
                                          1  __open + 10 (libsystem_kernel.dylib + 105022) [0x7fff97810a3e] 3
                                           *1  hndl_unix_scall64 + 22 (kernel + 646470) [0xffffff800029dd46] 3
                                             *1  unix_syscall64 + 597 (kernel + 6444693) [0xffffff8000825695] 3
                                               *1  open + 415 (kernel + 3314367) [0xffffff80005292bf] 3
                                                 *1  open1 + 254 (kernel + 3311518) [0xffffff800052879e] 3
                                                   *1  ??? (kernel + 5591127) [0xffffff8000755057] (running) 3
                                        1  _GetDirectoryURLs(_CFURLEnumerator*) + 666 (CoreServicesInternal + 152091) [0x7fff8d90721b] 4
                                          1  _FSURLCreateWithPathAndAttributes + 356 (CoreServicesInternal + 102639) [0x7fff8d8fb0ef] 4
                                            1  _CFURLCreateWithFileSystemRepresentation + 249 (CoreFoundation + 121673) [0x7fff81f15b49] 4
                                              1  CreateStringFromFileSystemRepresentationByAddingPercentEscapes + 512 (CoreFoundation + 82480) [0x7fff81f0c230] (running) 4
                                        1  _GetDirectoryURLs(_CFURLEnumerator*) + 150 (CoreServicesInternal + 151575) [0x7fff8d907017] 5
                                          1  _platform_bzero$VARIANT$Haswell + 89 (libsystem_platform.dylib + 27641) [0x7fff978f5bf9] (running) 5
                                    2  TCFURLIterator::NextRaw(TRef<TCFURLInfo*, TInternalRefCountPolicy<TCFURLInfo> >&) + 102 (DesktopServicesPriv + 659788) [0x7fff8e15014c] 6-7
                                      2  TCFURLInfo::Initialize(__CFURL const*, bool, bool) + 223 (DesktopServicesPriv + 25951) [0x7fff8e0b555f] 6-7
                                        2  TCFURLInfo::FetchProperties(bool) + 653 (DesktopServicesPriv + 26641) [0x7fff8e0b5811] 6-7
                                          2  TCFURLInfo::GetBooleanProperty(__CFURL const*, __CFString const*) + 30 (DesktopServicesPriv + 28546) [0x7fff8e0b5f82] 6-7
                                            2  CFURLCopyResourcePropertyForKey + 238 (CoreFoundation + 441454) [0x7fff81f63c6e] 6-7
                                              2  _FSURLCopyResourcePropertyForKeyInternal(__CFURL const*, __CFString const*, void*, void*, __CFError**, unsigned char) + 199 (CoreServicesInternal + 82025) [0x7fff8d8f6069] 6-7
                                                2  prepareValuesForBitmap(__CFURL const*, __FileCache*, _FilePropertyBitmap*, __CFError**) + 227 (CoreServicesInternal + 91057) [0x7fff8d8f83b1] 6-7
                                                  1  pathURLPropertyProviderPrepareValues(__CFURL const*, __FileCache*, __CFString const* const*, void const**, long, void const*, __CFError**) + 792 (CoreServicesInternal + 136380) [0x7fff8d9034bc] 6
                                                    1  _FileCacheSetPropertyValueForKey + 118 (CoreServicesInternal + 80608) [0x7fff8d8f5ae0] 6
                                                      1  CFDictionaryCreateMutable + 207 (CoreFoundation + 41807) [0x7fff81f0234f] 6
                                                        1  CFBasicHashCreate + 191 (CoreFoundation + 10575) [0x7fff81efa94f] (running) 6
                                                  1  __getattrlist + 10 (libsystem_kernel.dylib + 103466) [0x7fff9781042a] 7
                                                   *1  hndl_unix_scall64 + 22 (kernel + 646470) [0xffffff800029dd46] 7
                                                     *1  unix_syscall64 + 597 (kernel + 6444693) [0xffffff8000825695] 7
                                                       *1  getattrlist + 119 (kernel + 3118039) [0xffffff80004f93d7] 7
                                                         *1  ??? (kernel + 3118351) [0xffffff80004f950f] 7
                                                           *1  ??? (kernel + 3107115) [0xffffff80004f692b] 7
                                                             *1  mac_vnode_check_getattrlist + 207 (kernel + 7496991) [0xffffff800092651f] 7
                                                               *1  hook_vnode_check_getattrlist + 94 (Sandbox + 23137) [0xffffff7f81331a61] 7
        *1  cred_sb_evaluate + 46 (Sandbox + 11890) [0xffffff7f8132ee72] 7
        *1  sb_evaluate + 418 (Sandbox + 51206) [0xffffff7f81338806] 7
        *1  eval + 260 (Sandbox + 51977) [0xffffff7f81338b09] (running) 7
                                    1  TCFURLIterator::NextRaw(TRef<TCFURLInfo*, TInternalRefCountPolicy<TCFURLInfo> >&) + 42 (DesktopServicesPriv + 659728) [0x7fff8e150110] 8
                                      1  _URLEnumeratorGetNextURL + 167 (CoreServicesInternal + 149258) [0x7fff8d90670a] 8
                                        1  _GetDirectoryURLs(_CFURLEnumerator*) + 269 (CoreServicesInternal + 151694) [0x7fff8d90708e] (running) 8
                            1  TOperationSizer::StartSizing() + 392 (DesktopServicesPriv + 208442) [0x7fff8e0e1e3a] 9
                              1  TOperationSizer::AccumulateSize(TRef<TCFURLInfo*, TInternalRefCountPolicy<TCFURLInfo> > const&, bool, TRef<TCFURLInfo*, TInternalRefCountPolicy<TCFURLInfo> > const&) + 807 (DesktopServicesPriv + 826507) [0x7fff8e178c8b] (running) 9
                            1  TOperationSizer::StartSizing() + 283 (DesktopServicesPriv + 208333) [0x7fff8e0e1dcd] 10
                              1  TDeepCFURLIterator::Next(TRef<TCFURLInfo*, TInternalRefCountPolicy<TCFURLInfo> >&, int&, int&, bool&, TRef<TCFURLInfo*, TInternalRefCountPolicy<TCFURLInfo> >&, bool&, TRef<TCFURLInfo*, TInternalRefCountPolicy<TCFURLInfo> >&) + 71 (DesktopServicesPriv + 665147) [0x7fff8e15163b] 10
                                1  TDeepCFURLIterator::NextInternal(TRef<TCFURLInfo*, TInternalRefCountPolicy<TCFURLInfo> >&, int&, int&, bool&, TRef<TCFURLInfo*, TInternalRefCountPolicy<TCFURLInfo> >&, bool&, TRef<TCFURLInfo*, TInternalRefCountPolicy<TCFURLInfo> >&) + 161 (DesktopServicesPriv + 665743) [0x7fff8e15188f] 10
                                  1  TCFURLIterator::Next(TRef<TCFURLInfo*, TInternalRefCountPolicy<TCFURLInfo> >&) + 84 (DesktopServicesPriv + 638142) [0x7fff8e14acbe] 10
                                    1  TCFURLIterator::NextRaw(TRef<TCFURLInfo*, TInternalRefCountPolicy<TCFURLInfo> >&) + 102 (DesktopServicesPriv + 659788) [0x7fff8e15014c] 10
                                      1  TCFURLInfo::Initialize(__CFURL const*, bool, bool) + 223 (DesktopServicesPriv + 25951) [0x7fff8e0b555f] 10
                                        1  TCFURLInfo::FetchProperties(bool) + 653 (DesktopServicesPriv + 26641) [0x7fff8e0b5811] 10
                                          1  TCFURLInfo::GetBooleanProperty(__CFURL const*, __CFString const*) + 30 (DesktopServicesPriv + 28546) [0x7fff8e0b5f82] 10
                                            1  CFURLCopyResourcePropertyForKey + 238 (CoreFoundation + 441454) [0x7fff81f63c6e] 10
                                              1  _FSURLCopyResourcePropertyForKeyInternal(__CFURL const*, __CFString const*, void*, void*, __CFError**, unsigned char) + 199 (CoreServicesInternal + 82025) [0x7fff8d8f6069] 10
                                                1  prepareValuesForBitmap(__CFURL const*, __FileCache*, _FilePropertyBitmap*, __CFError**) + 227 (CoreServicesInternal + 91057) [0x7fff8d8f83b1] 10
                                                  1  LSPropertyProviderPrepareValues(__CFURL const*, __FileCache*, __CFString const* const*, void const**, long, void const*, __CFError**) + 502 (LaunchServices + 52754) [0x7fff83135e12] 10
                                                    1  prepareBasicFlags(_LSOnDemandContext&, FSNode*, __FileCache*, __CFString const*, __CFError**) + 863 (LaunchServices + 54021) [0x7fff83136305] 10
                                                      1  _LSCanSetExtensionHidden + 689 (LaunchServices + 66578) [0x7fff83139412] 10
                                                        1  _LSCanHideExtension + 46 (LaunchServices + 125548) [0x7fff83147a6c] 10
                                                          1  _LSNodeIsPackage + 64 (LaunchServices + 66844) [0x7fff8313951c] 10
                                                            1  FSNodeHasPackageBit + 64 (LaunchServices + 345855) [0x7fff8317d6ff] 10
                                                              1  FSNodeCopyResourcePropertyForKey + 370 (LaunchServices + 47650) [0x7fff83134a22] 10
        1  _CFURLCopyResourcePropertyForKeyFromCache + 222 (CoreFoundation + 442766) [0x7fff81f6418e] 10
        1  _FSURLCopyResourcePropertyForKeyInternal(__CFURL const*, __CFString const*, void*, void*, __CFError**, unsigned char) + 126 (CoreServicesInternal + 81952) [0x7fff8d8f6020] 10
        1  corePropertyProviderCopyValues(__CFURL const*, __FileCache const*, __CFString const* const*, void const**, void const**, long, void const*) + 125 (CoreServicesInternal + 121270) [0x7fff8d8ff9b6] 10
        1  CFDictionaryGetValueIfPresent + 129 (CoreFoundation + 152865) [0x7fff81f1d521] 10
        1  CFBasicHashFindBucket + 1066 (CoreFoundation + 48874) [0x7fff81f03eea] (running) 10
  Binary Images:
           0x101277000 -        0x1012e3fff  mdworker (1075.40)                           <2DF77B8C-E999-384C-B15D-9AFE38E2F634>  /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/A/Support/mdworker
        0x7fff8d8e2000 -     0x7fff8d912fff  com.apple.CoreServicesInternal 276.2 (276.2) <05EB7D45-DD4C-3A0F-AC63-A0C2A68E6481>  /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
        0x7fff8e0af000 -     0x7fff8e1c0fff  com.apple.desktopservices 1.11.5 (1.11.5)    <5712EC1F-FD2B-3F88-9549-DE167A5FEDE4>  /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
        0x7fff976ab000 -     0x7fff976dcfff  libdispatch.dylib (703.50.37)                <D122E712-9593-31CA-BAC4-4A54410BF4A0>  /usr/lib/system/libdispatch.dylib
        0x7fff978ef000 -     0x7fff978f7fff  libsystem_platform.dylib (126.50.8)          <5940EAB7-84D6-34DC-9B38-111648B2B589>  /usr/lib/system/libsystem_platform.dylib
   *0xffffff7f8132c000 - 0xffffff7f81344fff  com.apple.security.sandbox 300.0 (300.0)     <CDBEAC20-BD05-3DF5-B7D3-51C3E8DCF872>  /System/Library/Extensions/Sandbox.kext/Contents/MacOS/Sandbox
Process:         mdwrite [1982]
Path:            /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Support/mdwrite
Architecture:    x86_64
Parent:          launchd [1]
UID:             503
Task size:       14.66 MB
  Thread 0x7b9f             DispatchQueue 11          10 samples (1-10)         priority 20 (base 20)
  <thread QoS utility (requested default), process sudden termination clean, timers tier 3 (coalesced), IO tier 1>
    10  __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 106982) [0x7fff978111e6] 1-10
  Binary Images:
           0x10300a000 -        0x10301cfff  mdwrite (1075.40)                  <3821EC81-F02E-3810-AC16-31B3CB0D3633>  /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/A/Support/mdwrite
Process:         mediaremoteagent [409]
Path:            /System/Library/PrivateFrameworks/MediaRemote.framework/Support/mediaremoteagent
Parent:          launchd [1]
UID:             503
Task size:       9256 KB
  Thread 0xeb4              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
  10  start + 1 (libdyld.dylib + 21045) [0x7fff976e2235] 1-10
    10  ??? (mediaremoteagent + 6368) [0x102c228e0] 1-10
          10  CFRunLoopRunSpecific + 420 (CoreFoundation + 553412) [0x7fff81f7f1c4] 1-10
  Binary Images:
           0x102c21000 -        0x102c22fff  mediaremoteagent (693.17)              <620CD9E6-A83E-3EFF-A5BD-CEAFD08B9D4E>  /System/Library/PrivateFrameworks/MediaRemote.framework/Support/mediaremoteagent
Process:         mediaremoted [52]
Path:            /System/Library/PrivateFrameworks/MediaRemote.framework/Support/mediaremoted
Parent:          launchd [1]
UID:             0
Task size:       27.32 MB
  Thread 0x2db              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  ??? (mediaremoted + 20689) [0x10b1f80d1] 1-10
  Binary Images:
           0x10b1f3000 -        0x10b248fff  mediaremoted (693.17)                  <31B3DC3A-AACF-3810-B118-22D58D606CB1>  /System/Library/PrivateFrameworks/MediaRemote.framework/Support/mediaremoted
Process:         mobileassetd [61]
Path:            /usr/libexec/mobileassetd
Parent:          launchd [1]
UID:             0
Task size:       16.12 MB
  Thread 0x2e6              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  mach_msg_trap + 10 (libsystem_kernel.dylib + 74570) [0x7fff9780934a] 1-10
     *10  ipc_mqueue_receive_continue + 0 (kernel + 862304) [0xffffff80002d2860] 1-10
  Binary Images:
           0x10410f000 -        0x10414cfff  mobileassetd (339.51.1)            <6A3D3A42-308A-3B5F-B41C-98AC04961BFC>  /usr/libexec/mobileassetd
Process:         Moom [492]
Path:            /Applications/Moom.app/Contents/MacOS/Moom
Parent:          launchd [1]
UID:             503
Task size:       43.50 MB
Process:         MTLCompilerService [1975]
Path:            /System/Library/Frameworks/Metal.framework/Versions/A/XPCServices/MTLCompilerService.xpc/Contents/MacOS/MTLCompilerService
Parent:          launchd [1]
Responsible:     Mail [1964]
UID:             503
Task size:       21.42 MB
  Thread 0x7b45             10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x1067e2000 -        0x1067e3fff  com.apple.MTLCompilerService 87.18 (87.18) <B9396943-2A6A-3C3C-AC60-ECFF9A422F59>  /System/Library/Frameworks/Metal.framework/Versions/A/XPCServices/MTLCompilerService.xpc/Contents/MacOS/MTLCompilerService
Process:         MTLCompilerService [4790]
Parent:          launchd [1]
Responsible:     Safari [4589]
UID:             503
Task size:       22.86 MB
  Thread 0x1b287            DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x10fbc4000 -        0x10fbc5fff  com.apple.MTLCompilerService 87.18 (87.18) <B9396943-2A6A-3C3C-AC60-ECFF9A422F59>  /System/Library/Frameworks/Metal.framework/Versions/A/XPCServices/MTLCompilerService.xpc/Contents/MacOS/MTLCompilerService
Process:         MTLCompilerService [4901]
Parent:          launchd [1]
UID:             503
Task size:       15.38 MB
  Thread 0x1c03e            10 samples (1-10)         priority 4 (base 4)
  10  <truncated backtrace> 1-10
  Binary Images:
           0x101996000 -        0x101997fff  com.apple.MTLCompilerService 87.18 (87.18) <B9396943-2A6A-3C3C-AC60-ECFF9A422F59>  /System/Library/Frameworks/Metal.framework/Versions/A/XPCServices/MTLCompilerService.xpc/Contents/MacOS/MTLCompilerService
Process:         MTLCompilerService [5099]
Parent:          launchd [1]
UID:             503
Task size:       26.38 MB
  Thread 0x1d9a3            DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x102174000 -        0x102175fff  com.apple.MTLCompilerService 87.18 (87.18) <B9396943-2A6A-3C3C-AC60-ECFF9A422F59>  /System/Library/Frameworks/Metal.framework/Versions/A/XPCServices/MTLCompilerService.xpc/Contents/MacOS/MTLCompilerService
Process:         MTLCompilerService [5428]
Parent:          launchd [1]
Responsible:     Siri [434]
UID:             503
Task size:       16.93 MB
  Thread 0x1ff5c            10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x10f659000 -        0x10f65afff  com.apple.MTLCompilerService 87.18 (87.18) <B9396943-2A6A-3C3C-AC60-ECFF9A422F59>  /System/Library/Frameworks/Metal.framework/Versions/A/XPCServices/MTLCompilerService.xpc/Contents/MacOS/MTLCompilerService
Process:         MTLCompilerService [5629]
Parent:          launchd [1]
UID:             503
Task size:       23.07 MB
  Thread 0x212f5            10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x100ce0000 -        0x100ce1fff  com.apple.MTLCompilerService 87.18 (87.18) <B9396943-2A6A-3C3C-AC60-ECFF9A422F59>  /System/Library/Frameworks/Metal.framework/Versions/A/XPCServices/MTLCompilerService.xpc/Contents/MacOS/MTLCompilerService
Process:         MTLCompilerService [7973]
Parent:          launchd [1]
Responsible:     Dock [322]
UID:             503
Task size:       24.24 MB
  Thread 0x328ea            DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
  10  _dispatch_sig_thread + 41 (libdispatch.dylib + 62031) [0x7fff976ba24f] 1-10
  Binary Images:
           0x10812a000 -        0x10812bfff  com.apple.MTLCompilerService 87.18 (87.18) <B9396943-2A6A-3C3C-AC60-ECFF9A422F59>  /System/Library/Frameworks/Metal.framework/Versions/A/XPCServices/MTLCompilerService.xpc/Contents/MacOS/MTLCompilerService
        0x7fff977f7000 -     0x7fff97819fff  libsystem_kernel.dylib (3789.51.2)         <FC51D7B0-8292-3F6A-9231-64340B237EB7>  /usr/lib/system/libsystem_kernel.dylib
   *0xffffff8000200000 - 0xffffff80009fffff  kernel (3789.51.2)                         <06F94FD7-451F-34A1-B13C-D68FF7EDE0A0>  /System/Library/Kernels/kernel
Process:         nbagent [450]
Path:            /System/Library/PrivateFrameworks/Noticeboard.framework/Versions/A/Resources/nbagent.app/Contents/MacOS/nbagent
Parent:          launchd [1]
UID:             503
Task size:       37.29 MB
CPU Time:        <0.001
  Thread 0x14ce             DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)       cpu time <0.001
                    10  __CFRunLoopRun + 1361 (CoreFoundation + 555377) [0x7fff81f7f971] 1-10
                      10  __CFRunLoopServiceMachPort + 212 (CoreFoundation + 558308) [0x7fff81f804e4] 1-10
  Thread 0x16c1             Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 4 (base 4)
  10  thread_start + 13 (libsystem_pthread.dylib + 12545) [0x7fff978fb101] 1-10
    10  _pthread_start + 286 (libsystem_pthread.dylib + 14587) [0x7fff978fb8fb] 1-10
      10  _pthread_body + 180 (libsystem_pthread.dylib + 14767) [0x7fff978fb9af] 1-10
  Thread 0x15514            Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x106f53000 -        0x106f5ffff  com.apple.nbagent 1.0 (1)               <B8932973-9918-3EE8-9193-8B395AF1D5BF>  /System/Library/PrivateFrameworks/Noticeboard.framework/Versions/A/Resources/nbagent.app/Contents/MacOS/nbagent
Process:         nbstated [104]
Path:            /System/Library/PrivateFrameworks/Noticeboard.framework/Versions/A/Resources/nbstated
Parent:          launchd [1]
UID:             0
Task size:       5692 KB
  Thread 0x2e8              10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x10b437000 -        0x10b438fff  nbstated (20)                      <41B3AD16-19C1-3306-9B73-C072AB034E64>  /System/Library/PrivateFrameworks/Noticeboard.framework/Versions/A/Resources/nbstated
Process:         nehelper [222]
Path:            /usr/libexec/nehelper
Parent:          launchd [1]
UID:             0
Task size:       17.76 MB
  Thread 0x618              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  ??? (nehelper + 110963) [0x10fc72173] 1-10
  Binary Images:
           0x10fc57000 -        0x10fc7bfff  nehelper (563.50.32)                   <0E98F1E5-BC2B-3D19-9D19-C890AA7584B6>  /usr/libexec/nehelper
        0x7fff81ef8000 -     0x7fff82391fff  com.apple.CoreFoundation 6.9 (1349.65) <F79384D1-FA3F-38CA-A847-B2625EBB790E>  /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
Process:         netbiosd [3748]
Path:            /usr/sbin/netbiosd
Parent:          launchd [1]
UID:             222
Task size:       15.03 MB
  Thread 0x1382b            DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
  <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, timers tier 3 (coalesced), IO tier 3>
  Binary Images:
           0x1023c3000 -        0x10240afff  netbiosd (378.20.1)                <C36C8570-A5D5-38F2-A652-95A6CF5D23D8>  /usr/sbin/netbiosd
Process:         NETserver [712]
Path:            /Library/Printers/Brother/Utilities/Server/NETserver.app/Contents/MacOS/NETserver
Architecture:    i386
Parent:          launchd [1]
UID:             503
Task size:       3596 KB
CPU Time:        <0.001
Process:         networkserviceproxy [343]
Path:            /usr/libexec/networkserviceproxy
Parent:          launchd [1]
UID:             503
Sudden Term:     Tracked (allows idle exit)
Task size:       24.97 MB
  Thread 0xc0c              DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
    10  ??? (networkserviceproxy + 89458) [0x109f27d72] 1-10
  Binary Images:
           0x109f12000 -        0x109f2efff  networkserviceproxy (109.50.70)        <298850E2-3F91-3D52-917C-63A54FFAD625>  /usr/libexec/networkserviceproxy
        0x7fff976dd000 -     0x7fff976e2fff  libdyld.dylib (433.5)                  <129D3B44-FB21-3750-9A68-48B5C3DC632B>  /usr/lib/system/libdyld.dylib
Process:         nfcd [371]
Path:            /usr/libexec/nfcd
Parent:          launchd [1]
UID:             260
Task size:       14.17 MB
  Thread 0xcf1              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  ??? (nfcd + 193502) [0x10bc223de] 1-10
  Binary Images:
           0x10bbf3000 -        0x10bc7efff  nfcd (274.17)                          <06662F2A-7F9B-32BB-A8C6-6BE2B87A9341>  /usr/libexec/nfcd
Process:         No-IP DUC [488]
Path:            /Applications/No-IP DUC.app/Contents/MacOS/No-IP DUC
Architecture:    i386
Parent:          launchd [1]
UID:             503
Task size:       33.50 MB
CPU Time:        0.006
Process:         node [846]
Path:            /Applications/Utilities/Adobe Creative Cloud/*/CCXProcess.app/Contents/libs/node
Parent:          launchd [1]
UID:             503
Task size:       28.57 MB
CPU Time:        <0.001
Note:            1 idle work queue threads omitted
  Thread 0x1a85             10 samples (1-10)         priority 46 (base 46)     cpu time <0.001
  10  start + 52 (node + 5428) [0x100001534] 1-10
    10  node::Start(int, char**) + 583 (node + 6592068) [0x100649644] 1-10
      10  uv_run + 321 (node + 7787447) [0x10076d3b7] 1-10
        10  kevent + 10 (libsystem_kernel.dylib + 109974) [0x7fff97811d96] 1-10
         *10  ??? (kernel + 5627984) [0xffffff800075e050] 1-10
  Thread 0x1a8d             Thread name "V8 WorkerThread"                       10 samples (1-10)         priority 31 (base 31)
  <thread QoS default (requested default), process unclamped, IO tier 0>
        10  v8::base::ThreadEntry(void*) + 87 (node + 7867943) [0x100780e27] 1-10
          10  v8::platform::WorkerThread::Run() + 43 (node + 6970971) [0x1006a5e5b] 1-10
            10  v8::platform::TaskQueue::GetNext() + 57 (node + 6970457) [0x1006a5c59] 1-10
               *10  semaphore_wait_continue + 0 (kernel + 1118912) [0xffffff80003112c0] 1-10
  Thread 0x1a8e             Thread name "V8 WorkerThread"                       10 samples (1-10)         priority 31 (base 31)
  Thread 0x1a8f             Thread name "V8 WorkerThread"                       10 samples (1-10)         priority 31 (base 31)
  Thread 0x1a90             Thread name "V8 WorkerThread"                       10 samples (1-10)         priority 31 (base 31)
  Thread 0x1ad1             10 samples (1-10)         priority 31 (base 31)
    10  __psynch_cvwait + 10 (libsystem_kernel.dylib + 105458) [0x7fff97810bf2] 1-10
  Thread 0x1ad2             10 samples (1-10)         priority 31 (base 31)
  Thread 0x1ad3             10 samples (1-10)         priority 31 (base 31)
  Thread 0x1ad4             10 samples (1-10)         priority 31 (base 31)
  Thread 0x1adc             10 samples (1-10)         priority 31 (base 31)     cpu time <0.001
        10  vcfoundation::thread::Thread::ThreadProc(void*) + 9 (VulcanMessage5.dylib + 121849) [0x101f9fbf9] 1-10
          10  vcfoundation::thread::AbstractThread::Run() + 50 (VulcanMessage5.dylib + 114904) [0x101f9e0d8] 1-10
            10  adobe::vulcan::servicemgr::RegisterForEventsRequest::Run() + 1005 (VulcanMessage5.dylib + 59247) [0x101f9076f] 1-10
              10  adobe::vulcan::servicemgr::CSIRequest::Execute() + 50 (VulcanMessage5.dylib + 56502) [0x101f8fcb6] 1-10
                10  vcfoundation::ncomm::NCService::Execute(vcfoundation::ncomm::INCRequest*) + 29 (VulcanMessage5.dylib + 110253) [0x101f9cead] 1-10
                  10  vcfoundation::ncomm::NCService::Execute(vcfoundation::ncomm::INCRequest*, vcfoundation::ncomm::INCListener&) + 166 (VulcanMessage5.dylib + 110426) [0x101f9cf5a] 1-10
                    10  vcfoundation::ncomm::NCService::ReadResponse(vcfoundation::ncomm::INCRequest*, vcfoundation::ncomm::INCListener&, vcfoundation::ncomm::NCService::ConRef&) + 37 (VulcanMessage5.dylib + 111321) [0x101f9d2d9] 1-10
                      10  vcfoundation::ncomm::Connection::ReadIn() + 22 (VulcanMessage5.dylib + 112050) [0x101f9d5b2] 1-10
                        10  vcfoundation::io::Serializer::Deserialize() + 9 (VulcanMessage5.dylib + 96045) [0x101f9972d] 1-10
                          10  vcfoundation::io::Serializer::InternalDeserialize() + 30 (VulcanMessage5.dylib + 96134) [0x101f99786] 1-10
                            10  vcfoundation::io::IVCChannel::ReadFully(void*, unsigned long) + 46 (VulcanMessage5.dylib + 94952) [0x101f992e8] 1-10
                              10  vcfoundation::io::BufferedReader::Read(void*, unsigned long) + 50 (VulcanMessage5.dylib + 116542) [0x101f9e73e] 1-10
                                10  vcfoundation::io::BufferedReader::InternalRead(char*, long) + 82 (VulcanMessage5.dylib + 116744) [0x101f9e808] 1-10
                                  10  vcfoundation::io::BSDNamedPipe::Read(void*, unsigned long) + 21 (VulcanMessage5.dylib + 119885) [0x101f9f44d] 1-10
                                    10  __recvfrom + 10 (libsystem_kernel.dylib + 105974) [0x7fff97810df6] 1-10
                                         *10  recvfrom_nocancel + 234 (kernel + 6144810) [0xffffff80007dc32a] 1-10
                                           *10  ??? (kernel + 6145317) [0xffffff80007dc525] 1-10
                                             *10  soreceive + 2209 (kernel + 6080001) [0xffffff80007cc601] 1-10
                                               *10  sbwait + 370 (kernel + 6119186) [0xffffff80007d5f12] 1-10
                                                 *10  msleep + 98 (kernel + 5802402) [0xffffff80007889a2] 1-10
                                                   *10  ??? (kernel + 5801187) [0xffffff80007884e3] 1-10
                                                     *10  lck_mtx_sleep + 132 (kernel + 1026980) [0xffffff80002faba4] 1-10
  Thread 0x1b1a             10 samples (1-10)         priority 37 (base 37)
  <thread QoS user initiated (requested user initiated), process unclamped, IO tier 0>
  Binary Images:
           0x100000000 -        0x100e17fff  node                               <77B964CF-C5AD-343F-B912-2186CF942FBF>  /Applications/Utilities/Adobe Creative Cloud/*/CCXProcess.app/Contents/libs/node
           0x101f82000 -        0x101fbafff  VulcanMessage5.dylib (1)           <1D3CED35-E99B-3AAB-9C60-C6F853ED3BFB>  /Applications/Utilities/Adobe Creative Cloud/*/CCXProcess.app/Contents/js/node_modules/node-vulcanjs/build/Release/VulcanMessage5.dylib
        0x7fff978f8000 -     0x7fff97902fff  libsystem_pthread.dylib (218.51.1) <62A84A68-431D-3B54-A7B6-31367CCF2884>  /usr/lib/system/libsystem_pthread.dylib
Process:         NotificationCenter (Notification Center) [432]
Path:            /System/Library/CoreServices/NotificationCenter.app/Contents/MacOS/NotificationCenter
Parent:          launchd [1]
UID:             503
Task size:       75.39 MB
  Thread 0xfc8              DispatchQueue 1           10 samples (1-10)         priority 46 (base 46)
    10  ??? (NotificationCenter + 11249) [0x103956bf1] 1-10
      10  _TF10ObjectiveC15autoreleasepoolFFT_T_T_ + 38 (libswiftObjectiveC.dylib + 12614) [0x7fff944dd146] 1-10
        10  ??? (NotificationCenter + 509344) [0x1039d05a0] 1-10
  <process clamped>
  Thread 0x1083             10 samples (1-10)         priority 31 (base 31)
          10  -[BrightnessSystemClientInternal main] + 758 (CoreBrightness + 5829) [0x7fff8d3e56c5] 1-10
            10  -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 277 (Foundation + 140658) [0x7fff83991572] 1-10
  <process clamped>
  Thread 0x10e3             Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 46 (base 46)
  <process clamped>
  Binary Images:
           0x103954000 -        0x103a38fff  com.apple.notificationcenterui 1.0 (552.27) <C2C2F91E-5696-374A-A4E4-6DE579A81AC4>  /System/Library/CoreServices/NotificationCenter.app/Contents/MacOS/NotificationCenter
        0x7fff8396f000 -     0x7fff83d15fff  com.apple.Foundation 6.9 (1349.64)          <49C8DA40-9E5B-33F9-B092-F50115B59E95>  /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
        0x7fff8d3e4000 -     0x7fff8d407fff  com.apple.corebrightness 1.0 (1)            <4779D7FD-EBF4-3E3D-BF89-EAF23BE48162>  /System/Library/PrivateFrameworks/CoreBrightness.framework/Versions/A/CoreBrightness
        0x7fff944da000 -     0x7fff944e0fff  libswiftObjectiveC.dylib (800.8.18.31)      <D5AC1394-CCEB-305F-B33B-BF78BF38FF4C>  /System/Library/PrivateFrameworks/Swift/libswiftObjectiveC.dylib
Process:         notifyd [131]
Path:            /usr/sbin/notifyd
Parent:          launchd [1]
UID:             0
Task size:       4108 KB
CPU Time:        0.003
Note:            3 idle work queue threads omitted
  Thread 0x2f0              DispatchQueue 11          10 samples (1-10)         priority 31 (base 31)
  Binary Images:
           0x101320000 -        0x10132cfff  notifyd (165.20.1)                 <DF3EB19F-A321-3415-AF2D-63D8A95C7C81>  /usr/sbin/notifyd
Process:         nsurlsessiond [219]
Path:            /usr/libexec/nsurlsessiond
Parent:          launchd [1]
UID:             242
Task size:       28.08 MB
Note:            5 idle work queue threads omitted
  Thread 0x611              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
  <thread QoS background (requested default), process sudden termination dirty, thread darwinbg, process darwinbg, IO tier 2>
    10  main + 551 (nsurlsessiond + 20219) [0x1023d4efb] 1-10
      10  -[NSRunLoop(NSRunLoop) run] + 76 (Foundation + 140362) [0x7fff8399144a] 1-10
  Thread 0x240e             Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x1023d0000 -        0x102425fff  nsurlsessiond (811.4.18)               <460ACF4C-2548-3305-9817-54CFC76587F9>  /usr/libexec/nsurlsessiond
Process:         nsurlsessiond [342]
Parent:          launchd [1]
UID:             503
Task size:       43.38 MB
  Thread 0xc08              DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
  <thread QoS default (requested default), process sudden termination dirty, process unclamped, process received importance donation from cloudd [350], process received importance donation from parsecd [484], IO tier 0>
    10  main + 551 (nsurlsessiond + 20219) [0x10b450efb] 1-10
  Thread 0xd19              Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 31 (base 31)
  Thread 0x4fd7             10 samples (1-10)         priority 37 (base 37)
  <thread QoS user initiated (requested user interactive), process sudden termination dirty, process unclamped, process received importance donation from cloudd [350], process received importance donation from parsecd [484], IO tier 0>
     *10  psynch_cvcontinue + 0 (pthread + 38973) [0xffffff7f8135f83d] 1-10
  Thread 0x76a9             Thread name "com.apple.CFSocket.private"            10 samples (1-10)         priority 31 (base 31)
  Binary Images:
           0x10b44c000 -        0x10b4a1fff  nsurlsessiond (811.4.18)                <460ACF4C-2548-3305-9817-54CFC76587F9>  /usr/libexec/nsurlsessiond
   *0xffffff7f81356000 - 0xffffff7f81361fff  com.apple.kec.pthread 1.0 (1)           <4EFF2F70-C9B9-3176-BF83-F1B660C42135>  /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread
Process:         nsurlstoraged [368]
Path:            /usr/libexec/nsurlstoraged
Parent:          launchd [1]
UID:             503
Task size:       26.10 MB
  Thread 0xcd0              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
  <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2>
    10  _nsurlstoraged_main + 614 (CFNetwork + 289346) [0x7fff810fda42] 1-10
  Binary Images:
           0x101ea9000 -        0x101ebdfff  nsurlstoraged (811.4.18)                <118DBC29-9581-389A-B04D-A4DAB61A0B9A>  /usr/libexec/nsurlstoraged
Process:         nsurlstoraged [709]
Parent:          launchd [1]
UID:             243
Task size:       9852 KB
  Thread 0x183b             10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x107a15000 -        0x107a29fff  nsurlstoraged (811.4.18)           <118DBC29-9581-389A-B04D-A4DAB61A0B9A>  /usr/libexec/nsurlstoraged
Process:         ntpd [220]
Path:            /usr/sbin/ntpd
Parent:          launchd [1]
UID:             0
Task size:       4716 KB
CPU Time:        <0.001
  Thread 0x1a6e             DispatchQueue 10          10 samples (1-10)         priority 20 (base 20)     cpu time <0.001
  <thread QoS utility (requested utility, override utility), process sudden termination clean, timers tier 3 (coalesced), IO tier 1>
                10  ??? (ntpd + 165335) [0x1046e35d7] 1-10
                  10  ??? (ntpd + 167278) [0x1046e3d6e] 1-10
                    10  __sigsuspend + 10 (libsystem_kernel.dylib + 106958) [0x7fff978111ce] 1-10
                     *10  ??? (kernel + 5801776) [0xffffff8000788730] 1-10
  Thread 0x1a6f             DispatchQueue 11          10 samples (1-10)         priority 20 (base 20)
  Binary Images:
           0x1046bb000 -        0x104725fff  ntpd (124.50.4)                    <B55F76F0-7DE2-33D4-8FB8-2CD659930914>  /usr/sbin/ntpd
Process:         ocspd [154]
Path:            /usr/sbin/ocspd
Parent:          launchd [1]
UID:             0
Task size:       15.36 MB
  Thread 0x3eb              DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
    10  ??? (ocspd + 19766) [0x109a90d36] 1-10
      10  ??? (ocspd + 65519) [0x109a9bfef] 1-10
        10  ??? (ocspd + 66386) [0x109a9c352] 1-10
          10  mach_msg_overwrite_trap + 10 (libsystem_kernel.dylib + 74582) [0x7fff97809356] 1-10
  Thread 0x23f26            Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 31 (base 31)
  Binary Images:
           0x109a8c000 -        0x109aa7fff  ocspd (55134.50.1)                 <DDF83418-49C6-3869-B53F-135B6A93E5E8>  /usr/sbin/ocspd
Process:         opendirectoryd [97]
Path:            /usr/libexec/opendirectoryd
Parent:          launchd [1]
UID:             0
Task size:       23.67 MB
CPU Time:        <0.001
  Thread 0x306              DispatchQueue 10          10 samples (1-10)         priority 31 (base 31)
  <thread QoS default (requested default), process sudden termination dirty, IO tier 0>
        10  _dispatch_root_queue_drain + 917 (libdispatch.dylib + 14446) [0x7fff976ae86e] 1-10
              10  __systemcache_mig_initialize_block_invoke + 39 (SystemCache + 148333) [0x10152836d] 1-10
                10  mach_msg_server + 441 (libsystem_kernel.dylib + 73867) [0x7fff9780908b] 1-10
  Thread 0x30a              DispatchQueue 10          10 samples (1-10)         priority 31 (base 31)
              10  ??? (opendirectoryd + 148635) [0x1002d849b] 1-10
  Thread 0x333              DispatchQueue 10          10 samples (1-10)         priority 31 (base 31)
              10  __systemcache_mig_initialize_block_invoke_2 + 39 (SystemCache + 148542) [0x10152843e] 1-10
  Thread 0x30c              DispatchQueue 11          10 samples (1-10)         priority 31 (base 31)
  Thread 0x335              DispatchQueue 735         10 samples (1-10)         priority 31 (base 31)
          10  _dispatch_async_redirect_invoke + 734 (libdispatch.dylib + 56782) [0x7fff976b8dce] 1-10
            10  _dispatch_continuation_pop + 533 (libdispatch.dylib + 92694) [0x7fff976c1a16] 1-10
                  10  __identitysvc + 10 (libsystem_kernel.dylib + 103870) [0x7fff978105be] 1-10
  Binary Images:
           0x1002b4000 -        0x100314fff  opendirectoryd (417.50.4)                                    <95569B69-9148-375F-A2A7-ECDF9C5368F9>  /usr/libexec/opendirectoryd
           0x101504000 -        0x101533fff  com.apple.opendirectoryd.module.SystemCache 10.12 (417.50.4) <567B8777-DF44-379A-AC20-638BA7D9EA36>  /System/Library/OpenDirectory/Modules/SystemCache.bundle/Contents/MacOS/SystemCache
Process:         org.serviio.MediaServer [207]
Path:            /Library/Application Support/Serviio/*/java
Parent:          bash [69]
Responsible:     bash [69]
UID:             0
Task size:       121.67 MB (+4096  B)
CPU Time:        <0.001
  Thread 0x55d              DispatchQueue 1           10 samples (1-10)         priority 20 (base 20)
  <thread QoS utility (requested utility), timers tier 3 (coalesced), IO tier 1>
  Thread 0x68b              10 samples (1-10)         priority 20 (base 20)
        10  apple_main + 92 (java + 24866) [0x10652d122] 1-10
          10  main + 101 (java + 34029) [0x10652f4ed] 1-10
            10  JLI_Launch + 4837 (java + 11617) [0x106529d61] 1-10
              10  JVMInit + 315 (java + 22629) [0x10652c865] 1-10
                10  ContinueInNewThread + 201 (java + 12259) [0x106529fe3] 1-10
                  10  ContinueInNewThread0 + 102 (java + 23184) [0x10652ca90] 1-10
  Thread 0x69c              10 samples (1-10)         priority 20 (base 20)
        10  JavaMain + 805 (java + 13090) [0x10652a322] 1-10
          10  jni_DestroyJavaVM + 254 (libjvm.dylib + 3235791) [0x1068b9fcf] 1-10
            10  Threads::destroy_vm() + 80 (libjvm.dylib + 5544302) [0x106aed96e] 1-10
              10  Monitor::wait(bool, long, bool) + 246 (libjvm.dylib + 4493490) [0x1069ed0b2] 1-10
                10  Monitor::IWait(Thread*, long) + 168 (libjvm.dylib + 4493002) [0x1069ececa] 1-10
                  10  ParkCommon(ParkEvent*, long) + 42 (libjvm.dylib + 4490740) [0x1069ec5f4] 1-10
                    10  os::PlatformEvent::park() + 192 (libjvm.dylib + 4630692) [0x106a0e8a4] 1-10
  Thread 0x6dd              10 samples (1-10)         priority 20 (base 20)
        10  java_start(Thread*) + 246 (libjvm.dylib + 4647566) [0x106a12a8e] 1-10
          10  GangWorker::loop() + 179 (libjvm.dylib + 5921331) [0x106b49a33] 1-10
            10  Monitor::wait(bool, long, bool) + 375 (libjvm.dylib + 4493619) [0x1069ed133] 1-10
  Thread 0x6de              10 samples (1-10)         priority 20 (base 20)
  Thread 0x6df              10 samples (1-10)         priority 20 (base 20)
  Thread 0x6e0              10 samples (1-10)         priority 20 (base 20)
  Thread 0x6e1              10 samples (1-10)         priority 20 (base 20)
  Thread 0x6e2              10 samples (1-10)         priority 20 (base 20)
  Thread 0x6e3              10 samples (1-10)         priority 20 (base 20)
  Thread 0x6e4              10 samples (1-10)         priority 20 (base 20)
  Thread 0x6e5              10 samples (1-10)         priority 20 (base 20)     cpu time <0.001
          10  ConcurrentG1RefineThread::run() + 52 (libjvm.dylib + 1810748) [0x10675e13c] 1-10
            10  ConcurrentG1RefineThread::run_young_rs_sampling() + 64 (libjvm.dylib + 1811966) [0x10675e5fe] 1-10
                  10  os::PlatformEvent::park(long) + 404 (libjvm.dylib + 4634510) [0x106a0f78e] 1-10
  Thread 0x6e6              10 samples (1-10)         priority 20 (base 20)
          10  ConcurrentG1RefineThread::run() + 90 (libjvm.dylib + 1810786) [0x10675e162] 1-10
            10  ConcurrentG1RefineThread::wait_for_completed_buffers() + 65 (libjvm.dylib + 1811705) [0x10675e4f9] 1-10
  Thread 0x6e7              10 samples (1-10)         priority 20 (base 20)
  Thread 0x6e8              10 samples (1-10)         priority 20 (base 20)
  Thread 0x6e9              10 samples (1-10)         priority 20 (base 20)
  Thread 0x6ea              10 samples (1-10)         priority 20 (base 20)
  Thread 0x6eb              10 samples (1-10)         priority 20 (base 20)
  Thread 0x6ec              10 samples (1-10)         priority 20 (base 20)
  Thread 0x6ed              10 samples (1-10)         priority 20 (base 20)
  Thread 0x6ee              10 samples (1-10)         priority 20 (base 20)
          10  ConcurrentMarkThread::run() + 117 (libjvm.dylib + 1920443) [0x106778dbb] 1-10
            10  ConcurrentMarkThread::sleepBeforeNextCycle() + 57 (libjvm.dylib + 1922137) [0x106779459] 1-10
  Thread 0x6f0              10 samples (1-10)         priority 20 (base 20)
  Thread 0x6f1              10 samples (1-10)         priority 20 (base 20)
  Thread 0x702              10 samples (1-10)         priority 20 (base 20)     cpu time <0.001
          10  VMThread::run() + 121 (libjvm.dylib + 5849941) [0x106b38355] 1-10
            10  VMThread::loop() + 444 (libjvm.dylib + 5851338) [0x106b388ca] 1-10
  Thread 0x703              Thread name "Java: Reference Handler"               10 samples (1-10)         priority 20 (base 20)
          10  JavaThread::run() + 450 (libjvm.dylib + 5550528) [0x106aef1c0] 1-10
            10  JavaThread::thread_main_inner() + 155 (libjvm.dylib + 5544655) [0x106aedacf] 1-10
              10  thread_entry(JavaThread*, Thread*) + 124 (libjvm.dylib + 3355113) [0x1068d71e9] 1-10
                10  JavaCalls::call_virtual(JavaValue*, Handle, KlassHandle, Symbol*, Symbol*, Thread*) + 74 (libjvm.dylib + 3017896) [0x106884ca8] 1-10
                  10  JavaCalls::call_virtual(JavaValue*, KlassHandle, Symbol*, Symbol*, JavaCallArguments*, Thread*) + 356 (libjvm.dylib + 3017468) [0x106884afc] 1-10
                    10  JavaCalls::call_helper(JavaValue*, methodHandle*, JavaCallArguments*, Thread*) + 1710 (libjvm.dylib + 3015534) [0x10688436e] 1-10
                      10  ??? [0x10caf77a7] 1-10
                        10  ??? [0x10cafec4d] 1-10
                            10  ??? [0x10d2319a8] 1-10
                              10  JVM_MonitorWait + 156 (libjvm.dylib + 3382178) [0x1068ddba2] 1-10
                                10  ObjectSynchronizer::wait(Handle, long, Thread*) + 202 (libjvm.dylib + 5339736) [0x106abba58] 1-10
                                  10  ObjectMonitor::wait(long, bool, Thread*) + 748 (libjvm.dylib + 4598338) [0x106a06a42] 1-10
  Thread 0x704              Thread name "Java: Finalizer"                       10 samples (1-10)         priority 20 (base 20)
  <thread QoS utility (requested default), timers tier 3 (coalesced), IO tier 1>
                        10  ??? [0x10ccfd6f4] 1-10
  Thread 0x71c              Thread name "Java: Surrogate Locker Thread (Concurrent GC)"                   10 samples (1-10)         priority 20 (base 20)
              10  SurrogateLockerThread::loop() + 141 (libjvm.dylib + 1812513) [0x10675e821] 1-10
                10  Monitor::wait(bool, long, bool) + 222 (libjvm.dylib + 4493466) [0x1069ed09a] 1-10
  Thread 0x720              Thread name "Java: Signal Dispatcher"               10 samples (1-10)         priority 20 (base 20)
              10  signal_thread_entry(JavaThread*, Thread*) + 57 (libjvm.dylib + 4626741) [0x106a0d935] 1-10
  Thread 0x721              Thread name "Java: C2 CompilerThread0"              10 samples (1-10)         priority 20 (base 20)
              10  CompileBroker::compiler_thread_loop() + 376 (libjvm.dylib + 1779788) [0x10675684c] 1-10
                10  CompileQueue::get() + 122 (libjvm.dylib + 1779242) [0x10675662a] 1-10
  Thread 0x725              Thread name "Java: C2 CompilerThread1"              10 samples (1-10)         priority 20 (base 20)
  Thread 0x72b              Thread name "Java: C2 CompilerThread2"              10 samples (1-10)         priority 20 (base 20)
  Thread 0x72c              Thread name "Java: C1 CompilerThread3"              10 samples (1-10)         priority 20 (base 20)
  Thread 0x72d              Thread name "Java: Service Thread"                  10 samples (1-10)         priority 20 (base 20)
              10  ServiceThread::service_thread_entry(JavaThread*, Thread*) + 132 (libjvm.dylib + 4996130) [0x106a67c22] 1-10
  Thread 0x72e              10 samples (1-10)         priority 20 (base 20)     cpu time <0.001
          10  WatcherThread::run() + 243 (libjvm.dylib + 5549621) [0x106aeee35] 1-10
            10  WatcherThread::sleep() const + 126 (libjvm.dylib + 5545890) [0x106aedfa2] 1-10
  Thread 0x807              Thread name "Java: Instance checker"                10 samples (1-10)         priority 20 (base 20)
                        10  ??? [0x10cafec92] 1-10
                          10  ??? [0x10cafe9d0] 1-10
                                  10  ??? [0x10cb0c9d4] 1-10
                                    10  Java_java_net_PlainSocketImpl_socketAccept + 452 (libnet.dylib + 35917) [0x11e4b5c4d] 1-10
  Thread 0x80b              Thread name "Java: FileManager: Thread-1"           10 samples (1-10)         priority 20 (base 20)
                            10  ??? [0x10d204c31] 1-10
                              10  JVM_Sleep + 269 (libjvm.dylib + 3353698) [0x1068d6c62] 1-10
                                10  os::sleep(Thread*, long, bool) + 216 (libjvm.dylib + 4646134) [0x106a124f6] 1-10
  Thread 0x80c              Thread name "Java: ActionDistributor: Thread-2"     10 samples (1-10)         priority 20 (base 20)
  10  ??? [0x10d3e7538] 1-10
    10  ??? [0x10d222032] 1-10
  Thread 0x80d              Thread name "Java: ActionDistributor: Thread-3"     10 samples (1-10)         priority 20 (base 20)
  Thread 0x816              Thread name "Java: ActionDistributor: Thread-5"     10 samples (1-10)         priority 20 (base 20)
  Thread 0x81d              Thread name "Java: FileManager: Thread-6"           10 samples (1-10)         priority 20 (base 20)
  Thread 0x81e              Thread name "Java: ActionDistributor: Thread-7"     10 samples (1-10)         priority 20 (base 20)
  Thread 0x81f              Thread name "Java: ActionDistributor: Thread-8"     10 samples (1-10)         priority 20 (base 20)
  Thread 0x820              Thread name "Java: ActionDistributor: Thread-10"    10 samples (1-10)         priority 20 (base 20)
  Thread 0x826              Thread name "Java: Timer-0"                         10 samples (1-10)         priority 20 (base 20)
  Thread 0x840              Thread name "Java: derby.rawStoreDaemon"            10 samples (1-10)         priority 20 (base 20)
                          10  ??? [0x10d357434] 1-10
                                  10  ObjectMonitor::wait(long, bool, Thread*) + 765 (libjvm.dylib + 4598355) [0x106a06a53] 1-10
  Thread 0x969              Thread name "Java: Timer-1"                         10 samples (1-10)         priority 20 (base 20)
  Thread 0x97e              Thread name "Java: Thread-14"                       10 samples (1-10)         priority 20 (base 20)
                              10  ??? [0x10cafeaa4] 1-10
                                  10  ??? [0x10cafe7a5] 1-10
                                          10  Unsafe_Park + 126 (libjvm.dylib + 5635282) [0x106b03cd2] 1-10
                                            10  Parker::park(bool, long) + 512 (libjvm.dylib + 4633964) [0x106a0f56c] 1-10
  Thread 0x20d9             Thread name "Java: ElementEventQueue.QProcessor-1"  10 samples (1-10)         priority 20 (base 20)
  Thread 0x20e0             Thread name "Java: ServioThread-1-CDS library notifier"                       10 samples (1-10)         priority 20 (base 20)
                          10  ??? [0x10d3190f4] 1-10
  Thread 0x20e1             Thread name "Java: PluginCompilerThread"            10 samples (1-10)         priority 20 (base 20)
  Thread 0x20e2             Thread name "Java: pool-6-thread-1"                 10 samples (1-10)         priority 20 (base 20)
                                        10  ??? [0x10cc35c6a] 1-10
  Thread 0x20ee             Thread name "Java: WebServer"                       10 samples (1-10)         priority 20 (base 20)
  Thread 0x20f4             Thread name "Java: ServioThread-7-null"             10 samples (1-10)         priority 20 (base 20)
                            10  ??? [0x10d3972cc] 1-10
  Thread 0x20fe             Thread name "Java: pool-7-thread-1"                 10 samples (1-10)         priority 20 (base 20)
                            10  ??? [0x10d2657cc] 1-10
                                  10  Parker::park(bool, long) + 495 (libjvm.dylib + 4633947) [0x106a0f55b] 1-10
  Thread 0x20ff             Thread name "Java: pool-7-thread-2"                 10 samples (1-10)         priority 20 (base 20)
  Thread 0x2100             Thread name "Java: pool-7-thread-3"                 10 samples (1-10)         priority 20 (base 20)
  Thread 0x22f3             Thread name "Java: pool-7-thread-4"                 10 samples (1-10)         priority 20 (base 20)
  Thread 0x22f4             Thread name "Java: pool-7-thread-5"                 10 samples (1-10)         priority 20 (base 20)
  Thread 0x2317             Thread name "Java: pool-7-thread-6"                 10 samples (1-10)         priority 20 (base 20)
  Thread 0x24cb             Thread name "Java: pool-7-thread-7"                 10 samples (1-10)         priority 20 (base 20)
  Thread 0x24cc             Thread name "Java: pool-7-thread-8"                 10 samples (1-10)         priority 20 (base 20)
  Thread 0x24cd             Thread name "Java: pool-7-thread-9"                 10 samples (1-10)         priority 20 (base 20)
  Thread 0x27eb             Thread name "Java: FeedUpdaterThread"               10 samples (1-10)         priority 20 (base 20)
  Thread 0x28c1             Thread name "Java: ServioThread-9-CDS library notifier"                       10 samples (1-10)         priority 20 (base 20)
  Thread 0x28c7             Thread name "Java: RepositoryStatusThread"          10 samples (1-10)         priority 20 (base 20)
  Thread 0x28c8             Thread name "Java: Thread-29"                       10 samples (1-10)         priority 20 (base 20)
                          10  ??? [0x10d14a15c] 1-10
  Thread 0x28c9             Thread name "Java: Thread-30"                       10 samples (1-10)         priority 20 (base 20)
  Thread 0x28d6             Thread name "Java: Thread-31"                       10 samples (1-10)         priority 20 (base 20)
  Thread 0x28d7             Thread name "Java: Thread-32"                       10 samples (1-10)         priority 20 (base 20)
  Thread 0x28d8             Thread name "Java: PlaylistMaintainerThread"        10 samples (1-10)         priority 20 (base 20)
  Thread 0x28e7             Thread name "Java: pool-7-thread-10"                10 samples (1-10)         priority 20 (base 20)
  Thread 0x68d8             Thread name "Java: ServioThread-17-DiscoveryNotifier"                         10 samples (1-10)         priority 20 (base 20)
  Thread 0x120e2            Thread name "Java: ServioThread-21-DiscoveryNotifier"                         10 samples (1-10)         priority 20 (base 20)
  Thread 0x1276f            Thread name "Java: ServioThread-22-DiscoverySSDPMessageListener"              10 samples (1-10)         priority 20 (base 20)     cpu time <0.001
                          10  ??? [0x10d2edfa5] 1-10
                            10  ??? [0x10cbf3525] 1-10
                              10  Runtime1::monitorenter(JavaThread*, oopDesc*, BasicObjectLock*) + 164 (libjvm.dylib + 1297608) [0x1066e0cc8] 1-10
                                10  ObjectMonitor::enter(Thread*) + 472 (libjvm.dylib + 4597238) [0x106a065f6] 1-10
                                  10  ObjectMonitor::EnterI(Thread*) + 532 (libjvm.dylib + 4594096) [0x106a059b0] 1-10
  Thread 0x12770            Thread name "Java: ServioThread-23-SubscriptionExpiryChecker"                 10 samples (1-10)         priority 20 (base 20)
  Thread 0x12771            Thread name "Java: ServioThread-24-DiscoverySSDPMessageListener"              10 samples (1-10)         priority 20 (base 20)
                          10  ??? [0x10d2f0e04] 1-10
                            10  ??? [0x10d2ea88a] 1-10
                              10  Java_java_net_PlainDatagramSocketImpl_receive0 + 605 (libnet.dylib + 30277) [0x11e4b4645] 1-10
  Thread 0x12772            Thread name "Java: ServioThread-25-EventDispatcher" 10 samples (1-10)         priority 20 (base 20)     cpu time <0.001
                        10  ??? [0x10d404ffc] 1-10
  Thread 0x12773            Thread name "Java: ServioThread-27-DiscoveryNotifier"                         10 samples (1-10)         priority 20 (base 20)
  Thread 0x12774            Thread name "Java: ServioThread-26-SubscriptionExpiryChecker"                 10 samples (1-10)         priority 20 (base 20)
  Thread 0x12775            Thread name "Java: ServioThread-28-EventDispatcher" 10 samples (1-10)         priority 20 (base 20)     cpu time <0.001
  Thread 0x12776            Thread name "Java: ServioThread-29-DiscoveryNotifier"                         10 samples (1-10)         priority 20 (base 20)
  Binary Images:
           0x106527000 -        0x106538fff  java                               <FB3190B8-E93F-3E1D-B897-48D408FCCE9E>  /Library/Application Support/Serviio/*/java
           0x1065a4000 -        0x106d88fff  libjvm.dylib (1)                   <18BDD0E2-A145-30B7-B0D0-90BA75E62E10>  /Library/Application Support/Serviio/*/libjvm.dylib
           0x11e4ad000 -        0x11e4bcfff  libnet.dylib (1)                   <758369D3-87B5-3B31-B39E-75E51C72446F>  /Library/Application Support/Serviio/*/libnet.dylib
Process:         Parallels Toolbox [516]
Path:            /Applications/Parallels Toolbox.app/Contents/MacOS/Parallels Toolbox
Parent:          launchd [1]
UID:             503
Task size:       68.53 MB
Process:         ParallelsIM [486]
Path:            /Library/Input Methods/ParallelsIM.app/Contents/MacOS/ParallelsIM
Parent:          launchd [1]
UID:             503
Task size:       25.43 MB
Process:         parsecd [484]
Path:            /System/Library/PrivateFrameworks/CoreParsec.framework/parsecd
Parent:          launchd [1]
UID:             503
Task size:       45.84 MB
  Thread 0x10d4             DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
  <thread QoS default (requested default), process sudden termination dirty, process unclamped, process received importance donation from Safari [4589], IO tier 0>
    10  main + 1976 (parsecd + 199659) [0x110024beb] 1-10
  Thread 0x1b7b             Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 31 (base 31)
  Binary Images:
           0x10fff4000 -        0x110056fff  parsecd (101.3.23)                     <2C300DE0-E53E-39A5-8A59-40558E888B34>  /System/Library/PrivateFrameworks/CoreParsec.framework/parsecd
Process:         passd [363]
Path:            /System/Library/PrivateFrameworks/PassKitCore.framework/passd
Parent:          launchd [1]
UID:             503
Task size:       37.92 MB
Note:            4 idle work queue threads omitted
  Thread 0xca9              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  ??? (passd + 6017) [0x10df6a781] 1-10
  Thread 0xf52              Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x10df69000 -        0x10e056fff  passd (1319.4.5)                       <3EB16643-F9B0-3FFF-A57A-5F8551A2CFF8>  /System/Library/PrivateFrameworks/PassKitCore.framework/passd
Process:         pboard [369]
Path:            /usr/libexec/pboard
Parent:          launchd [1]
UID:             503
Task size:       8648 KB
  Thread 0xcd1              DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
    10  ??? (pboard + 3420) [0x10957cd5c] 1-10
      10  CFRunLoopRun + 97 (CoreFoundation + 814129) [0x7fff81fbec31] 1-10
  Binary Images:
           0x10957c000 -        0x10957cfff  pboard (1349.65)                       <770717C1-6768-3203-AB32-1ED27ADB4912>  /usr/libexec/pboard
Process:         pbs [412]
Path:            /System/Library/CoreServices/pbs
Parent:          launchd [1]
UID:             503
Task size:       14.45 MB
  Thread 0xf1e              DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x1090b4000 -        0x1090c6fff  pbs (294.10)                       <49B0207D-A590-30BB-A93B-633F93D21628>  /System/Library/CoreServices/pbs
Process:         photoanalysisd [4026]
Path:            /System/Library/PrivateFrameworks/PhotoAnalysis.framework/Versions/A/Support/photoanalysisd
Parent:          launchd [1]
UID:             503
Task size:       46.99 MB
  Thread 0x15501            DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  main + 397 (photoanalysisd + 6294) [0x10ed5a896] 1-10
  Binary Images:
           0x10ed59000 -        0x10ed5afff  photoanalysisd (3150.2.200)            <39013176-8D5D-3336-801E-3238B52317B8>  /System/Library/PrivateFrameworks/PhotoAnalysis.framework/Versions/A/Support/photoanalysisd
Process:         photolibraryd [573]
Path:            /System/Library/PrivateFrameworks/PhotoLibraryPrivate.framework/Versions/A/Support/photolibraryd
Parent:          launchd [1]
UID:             503
Task size:       28.67 MB
  Thread 0x14cd             DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x10ea1c000 -        0x10ec97fff  photolibraryd (3150.4.120)         <37ABF833-DEF7-3FB3-B49D-7697E34593F7>  /System/Library/PrivateFrameworks/PhotoLibraryPrivate.framework/Versions/A/Support/photolibraryd
Process:         pkd [370]
Path:            /usr/libexec/pkd
Parent:          launchd [1]
UID:             503
Task size:       22.16 MB
  Thread 0xcdf              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  ??? (pkd + 14411) [0x1092bb84b] 1-10
  Thread 0x34b27            10 samples (1-10)         priority 4 (base 4)
  <thread QoS background, process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2>
*10  wq_unpark_continue + 0 (pthread + 15190) [0xffffff7f81359b56] 1-10
  Binary Images:
           0x1092b8000 -        0x1092d9fff  pkd (171.50.6)                         <C1547FEF-7BE3-35AE-8239-656007ACA290>  /usr/libexec/pkd
Process:         PowerChime [446]
Path:            /System/Library/CoreServices/PowerChime.app/Contents/MacOS/PowerChime
Parent:          launchd [1]
UID:             503
Task size:       38.25 MB
  Thread 0xfdd              DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
    10  NSApplicationMain + 1237 (AppKit + 25054) [0x7fff7fa3b1de] 1-10
      10  -[NSApplication run] + 926 (AppKit + 243627) [0x7fff7fa707ab] 1-10
        10  -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 2796 (AppKit + 8136798) [0x7fff801f785e] 1-10
          10  _DPSNextEvent + 1120 (AppKit + 290340) [0x7fff7fa7be24] 1-10
            10  _BlockUntilNextEventMatchingListInModeWithFilter + 71 (HIToolbox + 199462) [0x7fff814e0b26] 1-10
              10  ReceiveNextEventCommon + 432 (HIToolbox + 199921) [0x7fff814e0cf1] 1-10
                10  RunCurrentEventLoopInMode + 240 (HIToolbox + 200380) [0x7fff814e0ebc] 1-10
  Thread 0x10f8             Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 37 (base 37)
  <thread QoS user initiated (requested user interactive), process sudden termination clean, IO tier 0>
        10  _NSEventThread + 205 (AppKit + 1655506) [0x7fff7fbc92d2] 1-10
  Binary Images:
           0x10f263000 -        0x10f276fff  com.apple.PowerChime 1.0 (1)           <04BB4056-B2EC-384D-9DF1-E7458032F37A>  /System/Library/CoreServices/PowerChime.app/Contents/MacOS/PowerChime
        0x7fff7fa35000 -     0x7fff8080efff  com.apple.AppKit 6.9 (1504.82.104)     <C295FF09-9984-34C3-953B-B263EF2107AB>  /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
        0x7fff814b0000 -     0x7fff817b9fff  com.apple.HIToolbox 2.1.1 (857.8)      <40254D9A-E477-3F33-B2A2-807D399BF71C>  /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
Process:         powerd [60]
Path:            /System/Library/CoreServices/powerd.bundle/powerd
Parent:          launchd [1]
UID:             0
Task size:       10.70 MB
  Thread 0x2a5              DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
  <thread QoS default (requested default), IO tier 0>
    10  main + 1747 (powerd + 21327) [0x10d05134f] 1-10
  Binary Images:
           0x10d04c000 -        0x10d080fff  powerd (637.50.9)                      <8EF1BF5F-F498-3382-89A8-F456A0E77A2F>  /System/Library/CoreServices/powerd.bundle/powerd
Process:         PrintUITool [622]
Path:            /System/Library/PrivateFrameworks/PrintingPrivate.framework/Versions/A/PrintUITool
Parent:          launchd [1]
UID:             503
Task size:       18.79 MB
  Thread 0x1622             DispatchQueue 1           10 samples (1-10)         priority 20 (base 20)
  <thread QoS utility (requested utility), process sudden termination clean, timers tier 3 (coalesced), IO tier 1>
    10  ??? (PrintUITool + 11993) [0x101dd4ed9] 1-10
  Binary Images:
           0x101dd2000 -        0x101ddefff  PrintUITool (171.1)                    <B7C69C6E-D341-3DEE-9BFA-2ED7A7A272B6>  /System/Library/PrivateFrameworks/PrintingPrivate.framework/Versions/A/PrintUITool
Process:         prl_deskctl_agent (Parallels Access Agent) [344]
Path:            /Applications/Parallels Access.app/Contents/MacOS/Parallels Access Agent.app/Contents/MacOS/prl_deskctl_agent
Parent:          launchd [1]
UID:             503
Task size:       61.18 MB
CPU Time:        <0.001
Process:         prl_deskctl_wizard (Parallels Access) [436]
Path:            /Applications/Parallels Access.app/Contents/MacOS/prl_deskctl_wizard
Parent:          launchd [1]
UID:             503
Task size:       73.98 MB
Process:         prl_pm_service (Parallels Service) [106]
Path:            /Applications/Parallels Access.app/Contents/MacOS/Parallels Access Dispatcher Service.app/Contents/MacOS/prl_pm_service
Parent:          launchd [1]
UID:             0
Task size:       44.86 MB
Process:         PTPCamera [5463]
Path:            /System/Library/Image Capture/Devices/PTPCamera.app/Contents/MacOS/PTPCamera
Parent:          launchd [1]
UID:             503
Task size:       96.00 MB
  Thread 0x2026e            DispatchQueue 1           10 samples (1-10)         priority 46 (base 46)
  <thread QoS user interactive (requested user interactive), process sudden termination dirty, process unclamped, IO tier 0>
    10  ??? (<A0C3F6E1-C8AA-39E1-AC68-62ECC4507D91> + 44639) [0x10877ce5f] 1-10
      10  ??? (<A0C3F6E1-C8AA-39E1-AC68-62ECC4507D91> + 6779) [0x108773a7b] 1-10
                           *8  ipc_mqueue_receive_continue + 0 (kernel + 862304) [0xffffff80002d2860] 1-8
  <process clamped>
                           *2  ipc_mqueue_receive_continue + 0 (kernel + 862304) [0xffffff80002d2860] 9-10
  Thread 0x20281            Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 46 (base 46)
  <process clamped>
  Thread 0x20282            10 samples (1-10)         priority 31 (base 31)
  <thread QoS default (requested default), process sudden termination dirty, process unclamped, IO tier 0>
        10  -[PTPTransport callbackThreadFunction] + 291 (PTPCamera + 14349) [0x10871380d] 1-10
  <process clamped>
  Binary Images:
           0x108710000 -        0x108745fff  com.apple.PTPCamera 10.1 (10.1)        <6570F991-4D1F-3799-B743-E314BE79B20E>  /System/Library/Image Capture/Devices/PTPCamera.app/Contents/MacOS/PTPCamera
           0x108772000 -                ???  ???                                    <A0C3F6E1-C8AA-39E1-AC68-62ECC4507D91>
Process:         quicklookd (Quick Look Helper) [7741]
Path:            /System/Library/Frameworks/QuickLook.framework/Versions/A/Resources/quicklookd.app/Contents/MacOS/quicklookd
Parent:          launchd [1]
UID:             503
Task size:       30.82 MB
  Thread 0x30de6            DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  ??? (quicklookd + 16861) [0x10a6c41dd] 1-10
  Thread 0x30dec            10 samples (1-10)         priority 4 (base 4)
        10  __NSThread__start__ + 1243 (Foundation + 207821) [0x7fff839a1bcd] 1-10
          10  ??? (quicklookd + 30680) [0x10a6c77d8] 1-10
  Thread 0x30e06            10 samples (1-10)         priority 4 (base 4)
          10  ??? (quicklookd + 231943) [0x10a6f8a07] 1-10
  Binary Images:
           0x10a6c0000 -        0x10a719fff  com.apple.QuickLookDaemon 5.0 (720.7)  <8F4BB098-5EDE-3A4B-8D28-44703A13049A>  /System/Library/Frameworks/QuickLook.framework/Versions/A/Resources/quicklookd.app/Contents/MacOS/quicklookd
Process:         QuickLookSatellite [8066]
Path:            /System/Library/Frameworks/QuickLook.framework/Versions/A/Resources/quicklookd.app/Contents/XPCServices/QuickLookSatellite.xpc/Contents/MacOS/QuickLookSatellite
Parent:          launchd [1]
Responsible:     quicklookd (Quick Look Helper) [7741]
UID:             503
Task size:       33.60 MB
  Thread 0x33412            DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  main + 95 (QuickLookSatellite + 7090) [0x10c202bb2] 1-10
      10  xpc_service_main + 413 (XPCService + 5575) [0x7fff95d155c7] 1-10
  Binary Images:
           0x10c201000 -        0x10c207fff  com.apple.quicklook.satellite 5.0 (521.1) <54D6476A-3DCA-30C3-AE2A-33B090CF70D9>  /System/Library/Frameworks/QuickLook.framework/Versions/A/Resources/quicklookd.app/Contents/XPCServices/QuickLookSatellite.xpc/Contents/MacOS/QuickLookSatellite
        0x7fff95d14000 -     0x7fff95d1afff  com.apple.XPCService 2.0 (1)              <4B28B225-2105-33F4-9ED0-F04288FF4FB1>  /System/Library/PrivateFrameworks/XPCService.framework/Versions/A/XPCService
Process:         racoon [2004]
Path:            /usr/sbin/racoon
Parent:          launchd [1]
UID:             0
Task size:       9632 KB
  Thread 0x7d18             10 samples (1-10)         priority 31 (base 31)
  Binary Images:
           0x104d62000 -        0x104e2cfff  racoon (305.20.1)                  <0F14923A-031F-3A47-8308-59D1396F12D8>  /usr/sbin/racoon
Process:         rcd [1938]
Path:            /System/Library/CoreServices/rcd.app/Contents/MacOS/rcd
Parent:          launchd [1]
UID:             503
Task size:       23.79 MB
  Thread 0x77c1             DispatchQueue 1           10 samples (1-10)         priority 20 (base 20)
  Binary Images:
           0x10635f000 -        0x10636afff  com.apple.rcd 341.2 (341.2)        <066597C0-06C0-3AED-9535-618E9AE96B00>  /System/Library/CoreServices/rcd.app/Contents/MacOS/rcd
Process:         RealPlayer Downloader Agent [514]
Path:            /Users/USER/Library/Application Support/RealNetworks/RealPlayer Downloader Agent.app/Contents/MacOS/RealPlayer Downloader Agent
Architecture:    i386
Parent:          launchd [1]
UID:             503
Task size:       8624 KB
CPU Time:        0.017
Process:         recentsd [886]
Path:            /System/Library/PrivateFrameworks/CoreRecents.framework/Versions/A/Support/recentsd
Parent:          launchd [1]
UID:             503
Task size:       31.05 MB
  Thread 0x1c0c             DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  ??? (recentsd + 10915) [0x1051b9aa3] 1-10
  Binary Images:
           0x1051b7000 -        0x1051defff  recentsd (133.2.1)                     <2D0E5231-84A1-3B76-8298-CD40E76C5AF9>  /System/Library/PrivateFrameworks/CoreRecents.framework/Versions/A/Support/recentsd
Process:         reversetemplated [1981]
Path:            /System/Library/PrivateFrameworks/CoreSuggestions.framework/Versions/A/Support/reversetemplated
Parent:          launchd [1]
UID:             503
Task size:       39.29 MB
  Thread 0x7b81             DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  ??? (reversetemplated + 5274) [0x10476e49a] 1-10
  Thread 0x7b86             10 samples (1-10)         priority 4 (base 4)
  <thread QoS background (requested user interactive), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2>
  Binary Images:
           0x10476d000 -        0x10476efff  reversetemplated (508.34)              <FC3C1770-9EA9-3705-A746-1F7FE7499CA4>  /System/Library/PrivateFrameworks/CoreSuggestions.framework/Versions/A/Support/reversetemplated
Process:         revisiond [120]
Path:            /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/Support/revisiond
Parent:          launchd [1]
UID:             0
Task size:       13.86 MB
  Thread 0x2f6              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  ??? (revisiond + 48779) [0x10181ee8b] 1-10
      10  ??? (revisiond + 47732) [0x10181ea74] 1-10
  Thread 0x7a8              10 samples (1-10)         priority 4 (base 4)
    10  read + 10 (libsystem_kernel.dylib + 111174) [0x7fff97812246] 1-10
     *10  hndl_unix_scall64 + 22 (kernel + 646470) [0xffffff800029dd46] 1-10
       *10  unix_syscall64 + 597 (kernel + 6444693) [0xffffff8000825695] 1-10
         *10  read_nocancel + 115 (kernel + 5884291) [0xffffff800079c983] 1-10
           *10  ??? (kernel + 5884954) [0xffffff800079cc1a] 1-10
             *10  ??? (kernel + 3393726) [0xffffff800053c8be] 1-10
               *10  spec_read + 201 (kernel + 3497273) [0xffffff8000555d39] 1-10
                 *10  ??? (AppleFSCompressionTypeDataless + 5539) [0xffffff7f833d05a3] 1-10
                         *10  thread_block_reason + 222 (kernel + 1069422) [0xffffff800030516e] 1-10
                           *10  ??? (kernel + 1073995) [0xffffff800030634b] 1-10
                             *10  machine_switch_context + 206 (kernel + 2082766) [0xffffff80003fc7ce] 1-10
  Binary Images:
           0x101813000 -        0x101852fff  revisiond (267.1)                                                             <8A1097C8-688B-34F0-8939-EDBDE1B82500>  /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/Support/revisiond
   *0xffffff7f833cf000 - 0xffffff7f833d0fff  com.apple.AppleFSCompression.AppleFSCompressionTypeDataless 88.50.3 (1.0.0d1) <13DD449C-FA18-3584-92A1-F91CAED7746A>  /System/Library/Extensions/AppleFSCompressionTypeDataless.kext/Contents/MacOS/AppleFSCompressionTypeDataless
Process:         RPDLAgentHelperJ [531]
Path:            /Users/USER/Library/Application Support/RealNetworks/RPDLAgentHelperJ
Architecture:    i386
Parent:          RealPlayer Downloader Agent [514]
Responsible:     RealPlayer Downloader Agent [514]
UID:             503
Task size:       13.18 MB
  Thread 0x1285             DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
  <thread QoS default (requested user interactive), process unclamped, IO tier 0>
  10  start + 41 (RPDLAgentHelperJ + 5497) [0x2579] 1-10
    10  _start + 209 (RPDLAgentHelperJ + 5707) [0x264b] 1-10
      10  main + 461 (RPDLAgentHelperJ + 7584) [0x2da0] 1-10
        10  sleep + 42 (libsystem_c.dylib + 522598) [0xa175a966] 1-10
          10  mach_wait_until + 10 (libsystem_kernel.dylib + 80482) [0xa17cda62] 1-10
           *10  ??? (kernel + 952384) [0xffffff80002e8840] 1-10
  Binary Images:
                0x1000 -             0x3fff  RPDLAgentHelperJ                   <271BC968-A557-0711-D4F9-68EE527221AC>  /Users/USER/Library/Application Support/RealNetworks/RPDLAgentHelperJ
            0xa16db000 -         0xa1769fff  libsystem_c.dylib (1158.50.2)      <2252D116-215B-3C01-A85F-0AAC10DB36CC>  /usr/lib/system/libsystem_c.dylib
            0xa17ba000 -         0xa17dbfff  libsystem_kernel.dylib (3789.51.2) <50D0E6F1-6F9C-303F-BCD6-F72AD4485B6E>  /usr/lib/system/libsystem_kernel.dylib
Process:         rtcreportingd [1271]
Path:            /usr/libexec/rtcreportingd
Parent:          launchd [1]
UID:             0
Task size:       13.96 MB
  Thread 0x428e             DispatchQueue 1           10 samples (1-10)         priority 20 (base 20)
  Thread 0x4295             Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 20 (base 20)
  Binary Images:
           0x106341000 -        0x106359fff  rtcreportingd (8.39.11)            <FBE6B450-4E24-3204-A822-08629B883556>  /usr/libexec/rtcreportingd
Process:         RXAgentService [125]
Path:            /Library/Application Support/com.nulana.rxagentmac/RXAgentService
Parent:          launchd [1]
UID:             0
Task size:       22.41 MB
CPU Time:        <0.001
  Thread 0x2d3              DispatchQueue 1           10 samples (1-10)         priority 20 (base 20)     cpu time <0.001
  10  ??? (RXAgentService + 9012) [0x107124334] 1-10
    10  ??? (RXAgentService + 440189) [0x10718d77d] 1-10
      10  -[NSRunLoop(NSRunLoop) runUntilDate:] + 111 (Foundation + 731877) [0x7fff83a21ae5] 1-10
  Thread 0x706              Thread name "NRPCServer"  10 samples (1-10)         priority 20 (base 20)
        10  ??? (RXAgentService + 228924) [0x107159e3c] 1-10
          10  ??? (RXAgentService + 238197) [0x10715c275] 1-10
            10  ??? (RXAgentService + 666053) [0x1071c49c5] 1-10
              10  ??? (RXAgentService + 597904) [0x1071b3f90] 1-10
  Thread 0x708              Thread name "RXAgentServer"                         10 samples (1-10)         priority 20 (base 20)
            10  ??? (RXAgentService + 62327) [0x107131377] 1-10
  Thread 0x70a              Thread name "com.apple.CFSocket.private"            10 samples (1-10)         priority 20 (base 20)
        10  __select + 10 (libsystem_kernel.dylib + 106166) [0x7fff97810eb6] 1-10
  Thread 0x353ac            Thread name "NHTTPSimpleConnection"                 10 samples (1-10)         priority 20 (base 20)
            10  ??? (RXAgentService + 503335) [0x10719ce27] 1-10
              10  ??? (RXAgentService + 506583) [0x10719dad7] 1-10
                10  ??? (RXAgentService + 460647) [0x107192767] 1-10
                  10  ??? (RXAgentService + 298986) [0x10716afea] 1-10
                    10  ??? (RXAgentService + 563787) [0x1071aba4b] 1-10
                      10  ??? (RXAgentService + 426571) [0x10718a24b] 1-10
                        10  poll + 10 (libsystem_kernel.dylib + 111006) [0x7fff9781219e] 1-10
                             *10  poll_nocancel + 1048 (kernel + 5896616) [0xffffff800079f9a8] 1-10
                               *10  kqueue_scan + 494 (kernel + 5625326) [0xffffff800075d5ee] 1-10
  Binary Images:
           0x107122000 -        0x107409fff  RXAgentService                         <2BFDF283-E533-3B0D-8170-A56E9DBC1FA8>  /Library/Application Support/com.nulana.rxagentmac/RXAgentService
Process:         Safari [4589]
Path:            /Applications/Safari.app/Contents/MacOS/Safari
Parent:          launchd [1]
UID:             503
Task size:       179.57 MB
CPU Time:        <0.001
  Thread 0x19cf1            DispatchQueue 1           10 samples (1-10)         priority 46 (base 46)     cpu time <0.001
  <thread QoS user interactive (requested user interactive), process unclamped, IO tier 0>
        10  -[BrowserApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 252 (Safari + 697990) [0x7fff92d58686] 1-10
  <process clamped>
  Thread 0x19cf7            10 samples (1-10)         priority 46 (base 46)
        10  void* std::__1::__thread_proxy<std::__1::tuple<void (*)(bmalloc::AsyncTask<bmalloc::Heap, void (bmalloc::Heap::*)()>*), bmalloc::AsyncTask<bmalloc::Heap, void (bmalloc::Heap::*)()>*> >(void*) + 93 (JavaScriptCore + 12002381) [0x7fff84f8844d] 1-10
          10  bmalloc::AsyncTask<bmalloc::Heap, void (bmalloc::Heap::*)()>::threadEntryPoint(bmalloc::AsyncTask<bmalloc::Heap, void (bmalloc::Heap::*)()>*) + 29 (JavaScriptCore + 12001693) [0x7fff84f8819d] 1-10
            10  bmalloc::AsyncTask<bmalloc::Heap, void (bmalloc::Heap::*)()>::threadRunLoop() + 155 (JavaScriptCore + 12001995) [0x7fff84f882cb] 1-10
              10  void std::__1::condition_variable_any::wait<std::__1::unique_lock<bmalloc::Mutex> >(std::__1::unique_lock<bmalloc::Mutex>&) + 108 (JavaScriptCore + 12002124) [0x7fff84f8834c] 1-10
                10  std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 47 (libc++.1.dylib + 29901) [0x7fff9627b4cd] 1-10
                   *8  psynch_cvcontinue + 0 (pthread + 38973) [0xffffff7f8135f83d] 1-8
  <process clamped>
                   *2  psynch_cvcontinue + 0 (pthread + 38973) [0xffffff7f8135f83d] 9-10
  Thread 0x19d05            Thread name "WebCore: IconDatabase"                 10 samples (1-10)         priority 37 (base 37)
        10  WTF::wtfThreadEntryPoint(void*) + 15 (JavaScriptCore + 14367) [0x7fff8441981f] 1-10
          10  WTF::threadEntryPoint(void*) + 178 (JavaScriptCore + 14578) [0x7fff844198f2] 1-10
            10  WebCore::IconDatabase::iconDatabaseSyncThread() + 385 (WebCore + 17633) [0x7fff88d4d4e1] 1-10
              10  WebCore::IconDatabase::syncThreadMainLoop() + 621 (WebCore + 27197) [0x7fff88d4fa3d] 1-10
                10  bool WTF::ConditionBase::waitUntil<WTF::Lock>(WTF::Lock&, WTF::TimeWithDynamicClockType const&) + 150 (WebCore + 2704406) [0x7fff88fdd416] 1-10
                  10  WTF::ParkingLot::parkConditionallyImpl(void const*, WTF::ScopedLambda<bool ()> const&, WTF::ScopedLambda<void ()> const&, WTF::TimeWithDynamicClockType const&) + 2706 (JavaScriptCore + 11901778) [0x7fff84f6fb52] 1-10
                    10  WTF::ThreadCondition::timedWait(WTF::Mutex&, double) + 63 (JavaScriptCore + 47103) [0x7fff844217ff] 1-10
  <process clamped>
  Thread 0x19d09            Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 37 (base 37)
          10  +[NSURLConnection(Loader) _resourceLoadLoop:] + 313 (CFNetwork + 26116) [0x7fff810bd604] 1-10
  <process clamped>
  Thread 0x19d0d            Thread name "com.apple.coreanimation.render-server" 10 samples (1-10)         priority 55 (base 55)
  <process unclamped, IO tier 0>
  <process clamped>
  Thread 0x19dab            Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 46 (base 46)
  <process clamped>
  Thread 0x19db9            Thread name "com.apple.CFNetwork.CustomProtocols"   10 samples (1-10)         priority 31 (base 31)
  <process clamped>
  Binary Images:
           0x10d818000 -        0x10d818fff  com.apple.Safari 10.1 (12603.1.30.0.34)            <CA6164AD-28C7-3937-9AA8-734547325481>  /Applications/Safari.app/Contents/MacOS/Safari
        0x7fff810b7000 -     0x7fff81491fff  com.apple.CFNetwork 811.4.18 (811.4.18)            <9CE329E8-6177-3474-976D-F5C63FC875CD>  /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
        0x7fff84416000 -     0x7fff8501efff  com.apple.JavaScriptCore 12603 (12603.1.30.0.34)   <42993DA4-E18A-3A41-86F8-23A6656273F9>  /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
        0x7fff88d49000 -     0x7fff8a0cffff  com.apple.WebCore 12603 (12603.1.30.0.34)          <57038A29-AC92-33FE-A4D6-DCDD95B88A88>  /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore
        0x7fff92cae000 -     0x7fff93506fff  com.apple.Safari.framework 12603 (12603.1.30.0.34) <490FC525-5972-3235-88CD-B98452EAC332>  /System/Library/PrivateFrameworks/Safari.framework/Versions/A/Safari
        0x7fff96274000 -     0x7fff962cafff  libc++.1.dylib (307.5)                             <0B43BB5D-E6EB-3464-8DE9-B41AC8ED9D1C>  /usr/lib/libc++.1.dylib
Process:         SafariCloudHistoryPushAgent [357]
Path:            /usr/libexec/SafariCloudHistoryPushAgent
Parent:          launchd [1]
UID:             503
Task size:       24.36 MB
CPU Time:        <0.001
  Thread 0xca6              DispatchQueue 1           10 samples (1-10)         priority 20 (base 20)     cpu time <0.001
    10  ??? (SafariCloudHistoryPushAgent + 3081) [0x108845c09] 1-10
      10  WBSCloudHistoryPushAgentMain() + 347 (SafariShared + 638454) [0x7fff935eedf6] 1-10
  Binary Images:
           0x108845000 -        0x108845fff  SafariCloudHistoryPushAgent (7603.1.30.0.34)    <D55E5B78-96EC-3180-B1B7-6A2DAC932384>  /usr/libexec/SafariCloudHistoryPushAgent
        0x7fff93553000 -     0x7fff93892fff  com.apple.Safari.Shared 12603 (12603.1.30.0.34) <57945A48-56AD-315D-8747-036EC9A76E0C>  /System/Library/PrivateFrameworks/SafariShared.framework/Versions/A/SafariShared
Process:         SafariNotificationAgent [914]
Path:            /usr/libexec/SafariNotificationAgent
Parent:          launchd [1]
UID:             503
Task size:       32.73 MB
  Thread 0x1cff             DispatchQueue 1           10 samples (1-10)         priority 20 (base 20)
  Thread 0x1d27             10 samples (1-10)         priority 20 (base 20)
  <thread QoS utility (requested user interactive), process sudden termination clean, timers tier 3 (coalesced), IO tier 1>
  Binary Images:
           0x10cbc0000 -        0x10cbc2fff  SafariNotificationAgent (7603.1.30.0.34) <1391F834-706C-3EEE-A3FF-35BF1AC23923>  /usr/libexec/SafariNotificationAgent
Process:         sandboxd [186]
Path:            /usr/libexec/sandboxd
Parent:          launchd [1]
UID:             0
Task size:       19.78 MB
  Thread 0x44a              DispatchQueue 11          10 samples (1-10)         priority 31 (base 31)
  <thread QoS default (requested default), process sudden termination clean, IO tier 0>
  Thread 0x7ad              10 samples (1-10)         priority 31 (base 31)
        10  SpotlightQueryThread(void*) + 478 (DebugSymbols + 8718) [0x7fff8e07120e] 1-10
  Binary Images:
           0x1062f4000 -        0x106300fff  sandboxd (592.50.47)                   <9DC1262B-675B-31C1-A29D-1378D434734D>  /usr/libexec/sandboxd
        0x7fff8e06f000 -     0x7fff8e0aefff  com.apple.DebugSymbols 137 (137)       <58A70B66-2628-3CFE-B103-2200D95FC5F7>  /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
Process:         ScopedBookmarkAgent [574]
Path:            /System/Library/CoreServices/ScopedBookmarkAgent
Parent:          launchd [1]
UID:             503
Task size:       13.13 MB
  Thread 0x14dd             DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x1044ef000 -        0x1044f3fff  ScopedBookmarkAgent (276.2)        <7F550EA2-4D97-3F67-B454-3AC1C5F38EEF>  /System/Library/CoreServices/ScopedBookmarkAgent
Process:         secd [326]
Path:            /usr/libexec/secd
Parent:          launchd [1]
UID:             503
Task size:       13.73 MB
Note:            2 idle work queue threads omitted
  Thread 0xb7f              DispatchQueue 11          10 samples (1-10)         priority 31 (base 31)
  Binary Images:
           0x108922000 -        0x108a08fff  secd (57740.51.3)                  <B236A1BA-189D-3D61-98D8-AC524CF62113>  /usr/libexec/secd
Process:         secinitd [289]
Path:            /usr/libexec/secinitd
Parent:          launchd [1]
UID:             0
Task size:       20.83 MB
  Thread 0x92f              DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x10b863000 -        0x10b868fff  secinitd (24.50.4)                 <FEB183DF-C4BC-362F-A8E9-0622848471D7>  /usr/libexec/secinitd
Process:         secinitd [340]
Parent:          launchd [1]
UID:             503
Task size:       22.83 MB
  Thread 0xc15              DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x100276000 -        0x10027bfff  secinitd (24.50.4)                 <FEB183DF-C4BC-362F-A8E9-0622848471D7>  /usr/libexec/secinitd
Process:         secinitd [1158]
Parent:          launchd [1]
UID:             0
Task size:       17.62 MB
  Thread 0x2de4             DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x10f0b8000 -        0x10f0bdfff  secinitd (24.50.4)                 <FEB183DF-C4BC-362F-A8E9-0622848471D7>  /usr/libexec/secinitd
Process:         securityd [108]
Path:            /usr/sbin/securityd
Parent:          launchd [1]
UID:             0
Task size:       18.62 MB
  Thread 0x2c4              DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
    10  ??? (securityd + 92850) [0x10a153ab2] 1-10
      10  ??? (securityd + 490911) [0x10a1b4d9f] 1-10
        10  ??? (securityd + 29714) [0x10a144412] 1-10
  Thread 0x300              10 samples (1-10)         priority 31 (base 31)
        10  ??? (securityd + 28304) [0x10a143e90] 1-10
          10  ??? (securityd + 329601) [0x10a18d781] 1-10
            10  au_sdev_read_aia + 569 (libbsm.0.dylib + 60343) [0x7fff96262bb7] 1-10
              10  fgetc + 52 (libsystem_c.dylib + 253401) [0x7fff97754dd9] 1-10
                10  __srget + 14 (libsystem_c.dylib + 280754) [0x7fff9775b8b2] 1-10
                  10  __srefill1 + 24 (libsystem_c.dylib + 280471) [0x7fff9775b797] 1-10
                    10  __read_nocancel + 10 (libsystem_kernel.dylib + 105926) [0x7fff97810dc6] 1-10
                                 *10  ??? (kernel + 5438740) [0xffffff800072fd14] 1-10
  Thread 0x3bf              10 samples (1-10)         priority 31 (base 31)
          10  ??? (securityd + 187921) [0x10a16ae11] 1-10
            10  ??? (securityd + 481647) [0x10a1b296f] 1-10
              10  SCardGetStatusChange + 460 (PCSC + 7313) [0x7fff86f47c91] 1-10
                10  _dispatch_semaphore_wait_slow + 103 (libdispatch.dylib + 43153) [0x7fff976b5891] 1-10
                  10  semaphore_wait_trap + 10 (libsystem_kernel.dylib + 74630) [0x7fff97809386] 1-10
  Thread 0x2ccb3            10 samples (1-10)         priority 31 (base 31)
          10  ??? (securityd + 28582) [0x10a143fa6] 1-10
  Binary Images:
           0x10a13d000 -        0x10a209fff  securityd (57740.51.3)             <D165A3E9-DCE2-3D83-AE7A-117CC5F63C39>  /usr/sbin/securityd
        0x7fff86f46000 -     0x7fff86f50fff  com.apple.pcsc 8.0 (1)             <0DDA8F7A-3D35-3EC0-95DC-5B8CA6BD2959>  /System/Library/Frameworks/PCSC.framework/Versions/A/PCSC
        0x7fff96254000 -     0x7fff96264fff  libbsm.0.dylib (34)                <20084796-B04D-3B35-A003-EA11459557A9>  /usr/lib/libbsm.0.dylib
        0x7fff976ab000 -     0x7fff976dcfff  libdispatch.dylib (703.50.37)      <D122E712-9593-31CA-BAC4-4A54410BF4A0>  /usr/lib/system/libdispatch.dylib
        0x7fff97717000 -     0x7fff977a4fff  libsystem_c.dylib (1158.50.2)      <B03F8915-1E9B-3C84-AED5-68E2E0031630>  /usr/lib/system/libsystem_c.dylib
Process:         securityd_service [304]
Path:            /usr/libexec/securityd_service
Architecture:    x86_64
Parent:          launchd [1]
UID:             0
Task size:       5312 KB
  Thread 0x9ed              DispatchQueue 11          10 samples (1-10)         priority 20 (base 20)
  <thread QoS utility (requested default), process sudden termination clean, timers tier 3 (coalesced), IO tier 1>
    10  __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 106982) [0x7fff978111e6] 1-10
  Binary Images:
           0x101a24000 -        0x101a30fff  securityd_service (57740.51.3)     <29CA11FA-075A-3A6C-A164-BC038537CB36>  /usr/libexec/securityd_service
Process:         seld [408]
Path:            /usr/libexec/seld
Parent:          launchd [1]
UID:             260
Task size:       13.17 MB
  Thread 0xeac              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
  10  start + 1 (libdyld.dylib + 21045) [0x7fff976e2235] 1-10
    10  ??? (seld + 5271) [0x107609497] 1-10
        10  CFRunLoopRunSpecific + 420 (CoreFoundation + 553412) [0x7fff81f7f1c4] 1-10
  Binary Images:
           0x107608000 -        0x10762ffff  seld (274.17)                          <165F2577-32A1-3DF1-8582-35FB569CA7E5>  /usr/libexec/seld
Process:         sharedfilelistd [283]
Path:            /System/Library/CoreServices/sharedfilelistd
Parent:          launchd [1]
UID:             0
Task size:       18.20 MB
  Thread 0x8f3              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
  <thread QoS background (requested default), thread darwinbg, process darwinbg, IO tier 2>
    10  ??? (sharedfilelistd + 7830) [0x106f81e96] 1-10
                10  mach_msg_trap + 10 (libsystem_kernel.dylib + 74570) [0x7fff9780934a] 1-10
                 *10  ipc_mqueue_receive_continue + 0 (kernel + 862304) [0xffffff80002d2860] 1-10
  Binary Images:
           0x106f80000 -        0x106f93fff  sharedfilelistd (38)                   <61E48376-10BD-352F-83D3-515FF9AEBC57>  /System/Library/CoreServices/sharedfilelistd
Process:         sharedfilelistd [349]
Parent:          launchd [1]
UID:             503
Task size:       18.85 MB
  Thread 0xc4c              DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x10745c000 -        0x10746ffff  sharedfilelistd (38)               <61E48376-10BD-352F-83D3-515FF9AEBC57>  /System/Library/CoreServices/sharedfilelistd
Process:         sharingd [411]
Path:            /usr/libexec/sharingd
Parent:          launchd [1]
UID:             503
Task size:       47.06 MB
  Thread 0xec8              DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
  <thread QoS default (requested default), process sudden termination dirty, process unclamped, process received importance donation from Finder [325], IO tier 0>
    10  main + 646 (sharingd + 1072661) [0x1019bae15] 1-10
  Thread 0xeed              Thread name "com.apple.CFSocket.private"            10 samples (1-10)         priority 31 (base 31)
  Binary Images:
           0x1018b5000 -        0x101a3ffff  sharingd (696.2.67)                    <A07C7B08-D7F3-3EBE-A3E6-27F04283ACD2>  /usr/libexec/sharingd
Process:         Siri [434]
Path:            /System/Library/CoreServices/Siri.app/Contents/MacOS/Siri
Parent:          launchd [1]
UID:             503
Task size:       38.80 MB
  Thread 0xfcb              DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
    10  ??? (Siri + 5778) [0x10fb71692] 1-10
  Thread 0x109f             Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 37 (base 37)
  <thread QoS user initiated (requested user interactive), IO tier 0>
  Thread 0x338ec            10 samples (1-10)         priority 31 (base 31)
  <IO tier 0>
  Binary Images:
           0x10fb70000 -        0x10fb79fff  com.apple.Siri 111.3.13 (111.3.13)     <0A716409-7503-348C-828C-8423437BBBBE>  /System/Library/CoreServices/Siri.app/Contents/MacOS/Siri
Process:         SiriNCService [5425]
Path:            /System/Library/CoreServices/Siri.app/Contents/XPCServices/SiriNCService.xpc/Contents/MacOS/SiriNCService
Parent:          launchd [1]
Responsible:     Siri [434]
UID:             503
Task size:       72.37 MB
  Thread 0x1ff39            DispatchQueue 1           10 samples (1-10)         priority 4-46 (base 4-46)
  <thread QoS user interactive (requested user interactive), process sudden termination clean, process unclamped, IO tier 0, priority 46 (46)>
    10  main + 180 (SiriNCService + 7311) [0x10089ec8f] 1-10
      10  NSViewServiceApplicationMain + 2985 (ViewBridge + 67126) [0x7fff95819636] 1-10
        10  -[NSXPCSharedListener resume] + 16 (ViewBridge + 221093) [0x7fff9583efa5] 1-10
          10  xpc_main + 494 (libxpc.dylib + 62180) [0x7fff9793a2e4] 1-10
            10  _xpc_objc_main + 775 (libxpc.dylib + 67783) [0x7fff9793b8c7] 1-10
                  10  -[NSViewServiceApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 100 (ViewBridge + 47432) [0x7fff95814948] 1-10
  <process clamped, process suppressed, timers tier 5 (throttled), IO tier 1, priority 4 (4)>
  Thread 0x1ff4b            Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 4-46 (base 4-46)
  Binary Images:
           0x10089d000 -        0x1008abfff  com.apple.SiriNCService 111.3.13 (111.3.13) <A8F3A7FD-C429-30C4-8FA1-512086AED53E>  /System/Library/CoreServices/Siri.app/Contents/XPCServices/SiriNCService.xpc/Contents/MacOS/SiriNCService
        0x7fff95809000 -     0x7fff958c9fff  com.apple.ViewBridge 282 (282)              <71C6F456-E63F-3465-BCC7-377D29CF817D>  /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
        0x7fff977f7000 -     0x7fff97819fff  libsystem_kernel.dylib (3789.51.2)          <FC51D7B0-8292-3F6A-9231-64340B237EB7>  /usr/lib/system/libsystem_kernel.dylib
        0x7fff9792b000 -     0x7fff97954fff  libxpc.dylib (972.50.27)                    <ABC45890-DA23-3A4A-B50B-1384BD4CBBDF>  /usr/lib/system/libxpc.dylib
   *0xffffff8000200000 - 0xffffff80009fffff  kernel (3789.51.2)                          <06F94FD7-451F-34A1-B13C-D68FF7EDE0A0>  /System/Library/Kernels/kernel
Process:         SmartwareDriveService [118]
Path:            /Library/Application Support/WD SmartWare Services/SmartwareDriveService
Architecture:    i386
Parent:          launchd [1]
UID:             0
Task size:       2376 KB
  Thread 0x2ca              DispatchQueue 1           10 samples (1-10)         priority 20 (base 20)
  10  start + 40 (SmartwareDriveService + 3880) [0x1f28] 1-10
    10  _start + 209 (SmartwareDriveService + 4090) [0x1ffa] 1-10
      10  main + 400 (SmartwareDriveService + 75531) [0x1370b] 1-10
        10  CFRunLoopRun + 129 (CoreFoundation + 812881) [0x942a0751] 1-10
          10  CFRunLoopRunSpecific + 506 (CoreFoundation + 544794) [0x9425f01a] 1-10
            10  __CFRunLoopRun + 1576 (CoreFoundation + 546984) [0x9425f8a8] 1-10
              10  __CFRunLoopServiceMachPort + 214 (CoreFoundation + 550006) [0x94260476] 1-10
                10  mach_msg_trap + 10 (libsystem_kernel.dylib + 80158) [0xa17cd91e] 1-10
  Thread 0xa0c              Thread name "com.apple.CFSocket.private"            10 samples (1-10)         priority 20 (base 20)
  10  thread_start + 34 (libsystem_pthread.dylib + 14454) [0xa18b8876] 1-10
    10  _pthread_start + 243 (libsystem_pthread.dylib + 16315) [0xa18b8fbb] 1-10
      10  _pthread_body + 184 (libsystem_pthread.dylib + 16499) [0xa18b9073] 1-10
        10  __select + 10 (libsystem_kernel.dylib + 112202) [0xa17d564a] 1-10
  Binary Images:
                0x1000 -            0x17fff  SmartwareDriveService                  <1FD055F2-9EC8-30FD-A7E0-37CBFE212B15>  /Library/Application Support/WD SmartWare Services/SmartwareDriveService
            0x941da000 -         0x9467afff  com.apple.CoreFoundation 6.9 (1349.65) <2DAF2AD5-0755-3438-819F-CB4B3D25A828>  /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
            0xa18b5000 -         0xa18befff  libsystem_pthread.dylib (218.51.1)     <71D501C2-F2CB-32C0-86B8-70AF68ACDC5F>  /usr/lib/system/libsystem_pthread.dylib
Process:         SmartwareServiceApp [98]
Path:            /Library/Application Support/WD SmartWare Services/SmartwareServiceApp.app/Contents/MacOS/SmartwareServiceApp
Architecture:    i386
Parent:          launchd [1]
UID:             0
Task size:       4756 KB
CPU Time:        <0.001
Process:         soagent [460]
Path:            /System/Library/PrivateFrameworks/MessagesKit.framework/Versions/A/Resources/soagent.app/Contents/MacOS/soagent
Parent:          launchd [1]
UID:             503
Task size:       50.62 MB
  Thread 0x133d             DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  ??? (soagent + 6459) [0x10193193b] 1-10
            10  __CFRunLoopRun + 1361 (CoreFoundation + 555377) [0x7fff81f7f971] 1-10
              10  __CFRunLoopServiceMachPort + 212 (CoreFoundation + 558308) [0x7fff81f804e4] 1-10
  Binary Images:
           0x101930000 -        0x101931fff  com.apple.soagent 7.0 (5500)           <55E4AE8F-D107-372A-99DA-7754908FFAA1>  /System/Library/PrivateFrameworks/MessagesKit.framework/Versions/A/Resources/soagent.app/Contents/MacOS/soagent
        0x7fff81ef8000 -     0x7fff82391fff  com.apple.CoreFoundation 6.9 (1349.65) <F79384D1-FA3F-38CA-A847-B2625EBB790E>  /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
Process:         SocialPushAgent [426]
Path:            /System/Library/CoreServices/SocialPushAgent.app/Contents/MacOS/SocialPushAgent
Parent:          launchd [1]
UID:             503
Task size:       15.51 MB
  Thread 0x14ca             DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  ??? (SocialPushAgent + 18613) [0x10aa6c8b5] 1-10
  Binary Images:
           0x10aa68000 -        0x10aa7efff  com.apple.SocialPushAgent 58 (58)      <63F80E63-E664-3393-BF09-136516220715>  /System/Library/CoreServices/SocialPushAgent.app/Contents/MacOS/SocialPushAgent
        0x7fff976dd000 -     0x7fff976e2fff  libdyld.dylib (433.5)                  <129D3B44-FB21-3750-9A68-48B5C3DC632B>  /usr/lib/system/libdyld.dylib
Process:         socketfilterfw [229]
Path:            /usr/libexec/ApplicationFirewall/socketfilterfw
Parent:          launchd [1]
UID:             0
Sudden Term:     Tracked
Task size:       19.22 MB
  Thread 0x667              DispatchQueue 1           10 samples (1-10)         priority 20 (base 20)
    10  ??? (socketfilterfw + 28330) [0x10269ceaa] 1-10
      10  ??? (socketfilterfw + 22676) [0x10269b894] 1-10
  Thread 0x6ef              Thread name "com.apple.CFSocket.private"            10 samples (1-10)         priority 20 (base 20)
  10  thread_start + 13 (libsystem_pthread.dylib + 12545) [0x7fff978fb101] 1-10
    10  _pthread_start + 286 (libsystem_pthread.dylib + 14587) [0x7fff978fb8fb] 1-10
      10  _pthread_body + 180 (libsystem_pthread.dylib + 14767) [0x7fff978fb9af] 1-10
  Binary Images:
           0x102696000 -        0x1026a7fff  socketfilterfw (170.21.1)              <F6023676-A3AE-3BAC-A185-16C99DC4E8E0>  /usr/libexec/ApplicationFirewall/socketfilterfw
Process:         softwareupdate_notify_agent [766]
Path:            /System/Library/CoreServices/Software Update.app/Contents/Resources/softwareupdate_notify_agent
Parent:          launchd [1]
UID:             503
Sudden Term:     Tracked (allows idle exit)
Task size:       12.60 MB
Note:            1 idle work queue threads omitted
  Thread 0x18f9             10 samples (1-10)         priority 20 (base 20)
  10  <truncated backtrace> 1-10
  Binary Images:
           0x102c08000 -        0x102c0afff  softwareupdate_notify_agent (976.16) <231DFDA2-245D-3DB9-8310-950778BDFD53>  /System/Library/CoreServices/Software Update.app/Contents/Resources/softwareupdate_notify_agent
Process:         softwareupdated [767]
Path:            /System/Library/CoreServices/Software Update.app/Contents/Resources/softwareupdated
Parent:          launchd [1]
UID:             200
Task size:       15.93 MB
  Thread 0x1903             DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x108654000 -        0x108655fff  softwareupdated (976.16)           <02FF9E96-92DE-3738-9FAD-64598A7061D0>  /System/Library/CoreServices/Software Update.app/Contents/Resources/softwareupdated
Process:         spindump [635]
Path:            /usr/sbin/spindump
Parent:          launchd [1]
UID:             0
Task size:       35.88 MB (+2120 KB)
Pageins:         22 pages
CPU Time:        0.101
  Thread 0x16ac             DispatchQueue 11          10 samples (1-10)         priority 31 (base 31)
  10  _dispatch_sig_thread + 41 (libdispatch.dylib + 62031) [0x7fff976ba24f] 1-10
  Thread 0x35625            10 samples (1-10)         priority 63 (base 63)     cpu time 0.027
  <process sudden termination dirty, IO tier 0>
        10  ??? (spindump + 205353) [0x103c0b229] 1-10
          10  __stack_snapshot_with_config + 10 (libsystem_kernel.dylib + 107054) [0x7fff9781122e] 1-10
               *10  stack_snapshot_with_config + 161 (kernel + 5868705) [0xffffff8000798ca1] 1-10
                 *10  kern_stack_snapshot_internal + 709 (kernel + 793701) [0xffffff80002c1c65] 1-10
                   *10  DebuggerWithCallback + 65 (kernel + 2150433) [0xffffff800040d021] (running) 1-10
  Thread 0x35623            DispatchQueue 206         1 sample (1)              priority 31 (base 31)
  1  start_wqthread + 13 (libsystem_pthread.dylib + 12529) [0x7fff978fb0f1] 1
    1  _pthread_wqthread + 1299 (libsystem_pthread.dylib + 13846) [0x7fff978fb616] 1
      1  _dispatch_worker_thread3 + 99 (libdispatch.dylib + 13452) [0x7fff976ae48c] 1
        1  _dispatch_root_queue_drain + 476 (libdispatch.dylib + 14005) [0x7fff976ae6b5] 1
          1  _dispatch_queue_invoke + 1046 (libdispatch.dylib + 41734) [0x7fff976b5306] 1
            1  _dispatch_queue_serial_drain + 896 (libdispatch.dylib + 96672) [0x7fff976c29a0] 1
              1  _dispatch_client_callout + 8 (libdispatch.dylib + 6396) [0x7fff976ac8fc] 1
                1  _dispatch_call_block_and_release + 12 (libdispatch.dylib + 42276) [0x7fff976b5524] 1
                  1  SLSRegisterUpdateInformationHandler + 187 (SkyLight + 831638) [0x7fff93abb096] 1
                    1  SLSMainConnectionID + 388 (SkyLight + 474568) [0x7fff93a63dc8] 1
                      1  dispatch_once_f + 38 (libdispatch.dylib + 6329) [0x7fff976ac8b9] 1
                          1  __SLSInitialize_block_invoke + 72 (SkyLight + 691316) [0x7fff93a98c74] 1
                            1  CGSDisplayInitialize + 131 (SkyLight + 286719) [0x7fff93a35fff] 1
                             *1  hndl_alltraps + 229 (kernel + 644181) [0xffffff800029d455] 1
                               *1  user_trap + 164 (kernel + 2102276) [0xffffff8000401404] (running) 1
  Binary Images:
           0x103bd9000 -        0x103c20fff  spindump (231.3)                    <26B8DE69-1487-3BD4-AA9D-180F410A63CE>  /usr/sbin/spindump
        0x7fff939f0000 -     0x7fff93c56fff  com.apple.SkyLight 1.600.0 (160.40) <BA7B7ACC-1B91-3E87-92EC-1C2969EF7088>  /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
Process:         spindump_agent [423]
Path:            /usr/libexec/spindump_agent
Parent:          launchd [1]
UID:             503
Task size:       12.36 MB (+16 KB)
CPU Time:        0.008
  Thread 0x1558             DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x10a2e6000 -        0x10a2eafff  spindump_agent (231.3)             <EA9F938B-4A56-3C9E-BC53-C5CF171E58AB>  /usr/libexec/spindump_agent
Process:         Spotlight [463]
Path:            /System/Library/CoreServices/Spotlight.app/Contents/MacOS/Spotlight
Parent:          launchd [1]
UID:             503
Task size:       131.75 MB
  Thread 0xff7              DispatchQueue 1           10 samples (1-10)         priority 4-46 (base 4-46)
  <thread QoS user interactive (requested user interactive), process unclamped, IO tier 0, priority 46 (46)>
  <process clamped, process suppressed, timers tier 4 (throttled), IO tier 1, priority 4 (4)>
  Thread 0x1011             10 samples (1-10)         priority 4-31 (base 4-31)
  <thread QoS default (requested default), process unclamped, IO tier 0, priority 31 (31)>
          10  ??? (Spotlight + 277061) [0x10b36da45] 1-10
  Thread 0x10cf             Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4-31 (base 4-31)
  Thread 0x12a2             Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 4-46 (base 4-46)
  Thread 0x1be4             10 samples (1-10)         priority 4-46 (base 4-46)
    10  __psynch_cvwait + 10 (libsystem_kernel.dylib + 105458) [0x7fff97810bf2] 1-10
  Thread 0x1be5             Thread name "com.apple.coreanimation.render-server" 10 samples (1-10)         priority 4-55 (base 4-55)
  <process unclamped, IO tier 0, priority 55 (55)>
  Thread 0x142bf            Thread name "com.apple.CFNetwork.CustomProtocols"   10 samples (1-10)         priority 4-31 (base 4-31)
  Binary Images:
           0x10b32a000 -        0x10b3aefff  com.apple.Spotlight 1.0 (1075.40)       <38757956-E133-3B43-B12C-F6252DABC59F>  /System/Library/CoreServices/Spotlight.app/Contents/MacOS/Spotlight
        0x7fff8396f000 -     0x7fff83d15fff  com.apple.Foundation 6.9 (1349.64)      <49C8DA40-9E5B-33F9-B092-F50115B59E95>  /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
        0x7fff978f8000 -     0x7fff97902fff  libsystem_pthread.dylib (218.51.1)      <62A84A68-431D-3B54-A7B6-31367CCF2884>  /usr/lib/system/libsystem_pthread.dylib
Process:         storagekitd [258]
Path:            /System/Library/PrivateFrameworks/StorageKit.framework/Versions/A/Resources/storagekitd
Parent:          launchd [1]
UID:             0
Task size:       21.38 MB
CPU Time:        <0.001
  Thread 0x835              DispatchQueue 28          10 samples (1-10)         priority 4 (base 4)
  10  start_wqthread + 13 (libsystem_pthread.dylib + 12529) [0x7fff978fb0f1] 1-10
    10  _pthread_wqthread + 1299 (libsystem_pthread.dylib + 13846) [0x7fff978fb616] 1-10
      10  _dispatch_worker_thread3 + 99 (libdispatch.dylib + 13452) [0x7fff976ae48c] 1-10
        10  _dispatch_root_queue_drain + 476 (libdispatch.dylib + 14005) [0x7fff976ae6b5] 1-10
          10  _dispatch_queue_invoke + 1046 (libdispatch.dylib + 41734) [0x7fff976b5306] 1-10
            10  _dispatch_queue_serial_drain + 896 (libdispatch.dylib + 96672) [0x7fff976c29a0] 1-10
              10  _dispatch_client_callout + 8 (libdispatch.dylib + 6396) [0x7fff976ac8fc] 1-10
                10  _dispatch_call_block_and_release + 12 (libdispatch.dylib + 42276) [0x7fff976b5524] 1-10
                  10  ??? (storagekitd + 140780) [0x10015e5ec] 1-10
                      10  -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 277 (Foundation + 140658) [0x7fff83991572] 1-10
  Thread 0x836              DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
  Thread 0x839              Thread name "Storage Kit Work Thread"               10 samples (1-10)         priority 4 (base 4)       cpu time <0.001
          10  ??? (storagekitd + 141236) [0x10015e7b4] 1-10
  Thread 0x83a              Thread name "Storage Kit Disk Eject Thread"         10 samples (1-10)         priority 4 (base 4)       cpu time <0.001
          10  ??? (storagekitd + 141614) [0x10015e92e] 1-10
  Binary Images:
           0x10013c000 -        0x1001a7fff  storagekitd (297)                      <E967349F-9BF1-3608-AE38-68D29352B7FF>  /System/Library/PrivateFrameworks/StorageKit.framework/Versions/A/Resources/storagekitd
Process:         storeaccountd [389]
Path:            /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Resources/storeaccountd
Parent:          launchd [1]
UID:             503
Task size:       35.86 MB
  Thread 0xdc3              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
  <thread QoS background (requested utility), process sudden termination clean, thread darwinbg, process darwinbg, timers tier 3 (coalesced), IO tier 2>
    10  ??? (storeaccountd + 37079) [0x1006df0d7] 1-10
  Thread 0x1201             Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4 (base 4)
  <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, timers tier 3 (coalesced), IO tier 2>
  Binary Images:
           0x1006d6000 -        0x10077afff  storeaccountd (582.5)                   <CC274F80-0E8B-3AFF-8533-22D772A9F76A>  /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Resources/storeaccountd
Process:         storeassetd [493]
Path:            /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Resources/storeassetd
Parent:          launchd [1]
UID:             503
Task size:       30.66 MB
  Thread 0x113f             DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  ??? (storeassetd + 250924) [0x10a6cd42c] 1-10
  Binary Images:
           0x10a690000 -        0x10a798fff  storeassetd (582.5)                    <8A459E60-0D08-397B-8C26-97758E044965>  /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Resources/storeassetd
Process:         storedownloadd [375]
Path:            /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Resources/storedownloadd
Parent:          launchd [1]
UID:             503
Task size:       25.36 MB
  Thread 0xd21              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  ??? (storedownloadd + 115933) [0x10f50a4dd] 1-10
  Binary Images:
           0x10f4ee000 -        0x10f678fff  storedownloadd (582.5)                 <4B856646-4950-30FE-86BB-8C0D9C637A56>  /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Resources/storedownloadd
Process:         storeinstalld [813]
Path:            /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Resources/storeinstalld
Parent:          launchd [1]
UID:             0
Task size:       16.09 MB
  Thread 0x19d2             DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
  <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2>
    10  ??? (storeinstalld + 7494) [0x1091cdd46] 1-10
  Binary Images:
           0x1091cc000 -        0x1091d1fff  storeinstalld (582.5)                  <D0DA2610-5D94-31C3-90CB-FE96962E3939>  /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Resources/storeinstalld
Process:         storelegacy [796]
Path:            /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Resources/storelegacy
Parent:          launchd [1]
UID:             503
Task size:       17.73 MB
  Thread 0x196c             DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  ??? (storelegacy + 6334) [0x10e82b8be] 1-10
  Binary Images:
           0x10e82a000 -        0x10e82ffff  storelegacy (582.5)                    <CC37013A-C39E-33CA-BA6F-16EA289242A9>  /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Resources/storelegacy
Process:         SubmitDiagInfo [637]
Path:            /System/Library/CoreServices/SubmitDiagInfo
Parent:          launchd [1]
UID:             0
Task size:       13.45 MB
  Thread 0x16c3             DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
  <thread QoS background (requested background), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 3>
  Binary Images:
           0x108d32000 -        0x108d53fff  SubmitDiagInfo (823)               <1B751A7B-EB8E-3278-9DFB-CB533FC38A93>  /System/Library/CoreServices/SubmitDiagInfo
Process:         suggestd [911]
Path:            /System/Library/PrivateFrameworks/CoreSuggestions.framework/Versions/A/Support/suggestd
Parent:          launchd [1]
UID:             503
Task size:       71.68 MB
  Thread 0x1ccd             DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
  <thread QoS default (requested default), process sudden termination clean, process unclamped, process received importance donation from Mail [1964], IO tier 0>
    10  ??? (suggestd + 12891) [0x1088eb25b] 1-10
  Binary Images:
           0x1088e8000 -        0x1088eefff  suggestd (508.34)                      <E254F706-ADB6-36A8-B28C-55AF464A6AE4>  /System/Library/PrivateFrameworks/CoreSuggestions.framework/Versions/A/Support/suggestd
Process:         suhelperd [768]
Path:            /System/Library/PrivateFrameworks/SoftwareUpdate.framework/Versions/A/Resources/suhelperd
Parent:          launchd [1]
UID:             0
Task size:       12.86 MB
  Thread 0x1908             10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x102937000 -        0x10295cfff  suhelperd (976.16)                 <52568A40-3400-3750-B76C-3DEE25A946A9>  /System/Library/PrivateFrameworks/SoftwareUpdate.framework/Resources/suhelperd
Process:         swcd [414]
Path:            /usr/libexec/swcd
Parent:          launchd [1]
UID:             503
Task size:       16.00 MB
Note:            3 idle work queue threads omitted
  Thread 0xf23              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  ??? (swcd + 5729) [0x103154661] 1-10
      10  -[NSRunLoop(NSRunLoop) run] + 76 (Foundation + 140362) [0x7fff8399144a] 1-10
  Binary Images:
           0x103153000 -        0x103154fff  swcd (160.1)                           <CA14575C-D3B8-30A9-8095-137C507A2336>  /usr/libexec/swcd
Process:         symptomsd [240]
Path:            /usr/libexec/symptomsd
Parent:          launchd [1]
UID:             24
Task size:       24.58 MB
  Thread 0x736              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
  <thread QoS background (requested default), process sudden termination dirty, thread darwinbg, process darwinbg, IO tier 2>
    10  ??? (symptomsd + 6186) [0x10b03c82a] 1-10
  Binary Images:
           0x10b03b000 -        0x10b03cfff  symptomsd (532.50.47)                  <62CEF18F-1D16-3328-93F1-3AC92670287C>  /usr/libexec/symptomsd
Process:         syncdefaultsd [8163]
Path:            /System/Library/PrivateFrameworks/SyncedDefaults.framework/Support/syncdefaultsd
Parent:          launchd [1]
UID:             503
Task size:       37.61 MB
Note:            5 idle work queue threads omitted
  Thread 0x340eb            DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  ??? (syncdefaultsd + 35660) [0x1011e0b4c] 1-10
  Thread 0x3411e            Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x1011d8000 -        0x101232fff  syncdefaultsd (261.3)                   <05A22A85-50A6-305C-9EB3-710CD8F38C15>  /System/Library/PrivateFrameworks/SyncedDefaults.framework/Support/syncdefaultsd
Process:         syslogd [45]
Path:            /usr/sbin/syslogd
Parent:          launchd [1]
UID:             0
Task size:       3008 KB
CPU Time:        <0.001
  Thread 0x393              DispatchQueue 10          10 samples (1-10)         priority 4 (base 4)       cpu time <0.001
  <thread QoS background (requested default), process sudden termination dirty, thread darwinbg, process darwinbg, IO tier 2 and passive>
        10  _dispatch_root_queue_drain + 917 (libdispatch.dylib + 14446) [0x7fff976ae86e] 1-10
              10  ??? (syslogd + 34255) [0x107ad45cf] 1-10
  Thread 0x395              DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
     *10  ??? (kernel + 5801776) [0xffffff8000788730] 1-10
  Binary Images:
           0x107acc000 -        0x107ae4fff  syslogd (349.50.5)                 <2284DE48-A7DC-3963-A94B-B5C8050915E6>  /usr/sbin/syslogd
Process:         sysmond [247]
Path:            /usr/libexec/sysmond
Parent:          launchd [1]
UID:             0
Task size:       8384 KB
  Thread 0x7bc              DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x108ea1000 -        0x108ea7fff  sysmond (92.50.5)                  <EE713154-AEC3-3516-B31A-54E840173CA2>  /usr/libexec/sysmond
Process:         syspolicyd [3859]
Path:            /usr/libexec/syspolicyd
Parent:          launchd [1]
UID:             0
Task size:       6576 KB
  Thread 0x142c7            10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x105d88000 -        0x105d8dfff  syspolicyd (12.50.1)               <17A2AF71-C1E0-37E8-B4F7-8C61C2B547C4>  /usr/libexec/syspolicyd
Process:         system_installd [378]
Path:            /System/Library/PrivateFrameworks/PackageKit.framework/Versions/A/Resources/system_installd
Parent:          launchd [1]
UID:             0
Task size:       9700 KB
  Thread 0xd12              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  ??? (system_installd + 6850) [0x1008f7ac2] 1-10
  Binary Images:
           0x1008f6000 -        0x1008f7fff  system_installd (629)                  <3F11A0C2-F4F9-3293-BD04-64D9E50EC694>  /System/Library/PrivateFrameworks/PackageKit.framework/Versions/A/Resources/system_installd
Process:         system_profiler [8342]
Path:            /usr/sbin/system_profiler
Parent:          duet [466]
Responsible:     duet [466]
UID:             503
Task size:       13.12 MB
CPU Time:        0.013
  Thread 0x3562b            1 sample (7)              priority 31 (base 31)     cpu time 0.010
  <Thread not seen for 6 samples, thread QoS default (requested user interactive), IO tier 0>
  1  start + 1 (libdyld.dylib + 21045) [0x7fff976e2235] 7
    1  ??? (system_profiler + 19028) [0x102c58a54] 7
      1  dispatch_main + 110 (libdispatch.dylib + 61781) [0x7fff976ba155] 7
        1  pthread_exit + 30 (libsystem_pthread.dylib + 23724) [0x7fff978fdcac] 7
          1  _pthread_exit + 152 (libsystem_pthread.dylib + 20813) [0x7fff978fd14d] 7
            1  _pthread_tsd_cleanup + 544 (libsystem_pthread.dylib + 21523) [0x7fff978fd413] 7
              1  _dispatch_queue_cleanup2 + 113 (libdispatch.dylib + 61934) [0x7fff976ba1ee] 7
                1  sleep$NOCANCEL + 42 (libsystem_c.dylib + 192291) [0x7fff97745f23] 7
                  1  __semwait_signal_nocancel + 10 (libsystem_kernel.dylib + 106334) [0x7fff97810f5e] 7
                   *1  semaphore_wait_continue + 0 (kernel + 1118912) [0xffffff80003112c0] 7
  Thread 0x3562c            DispatchQueue 10          1 sample (7)              priority 31 (base 31)     cpu time 0.002
  <DispatchQueue not seen for 6 samples, thread QoS default (requested user interactive), IO tier 0>
  1  start_wqthread + 13 (libsystem_pthread.dylib + 12529) [0x7fff978fb0f1] 7
    1  _pthread_wqthread + 1299 (libsystem_pthread.dylib + 13846) [0x7fff978fb616] 7
      1  _dispatch_worker_thread3 + 99 (libdispatch.dylib + 13452) [0x7fff976ae48c] 7
        1  _dispatch_root_queue_drain + 476 (libdispatch.dylib + 14005) [0x7fff976ae6b5] 7
          1  _dispatch_queue_override_invoke + 369 (libdispatch.dylib + 65568) [0x7fff976bb020] 7
            1  _dispatch_queue_invoke + 1046 (libdispatch.dylib + 41734) [0x7fff976b5306] 7
              1  _dispatch_queue_serial_drain + 896 (libdispatch.dylib + 96672) [0x7fff976c29a0] 7
                1  _dispatch_client_callout + 8 (libdispatch.dylib + 6396) [0x7fff976ac8fc] 7
                  1  _dispatch_call_block_and_release + 12 (libdispatch.dylib + 42276) [0x7fff976b5524] 7
                    1  ??? (system_profiler + 19096) [0x102c58a98] 7
                      1  ??? (system_profiler + 18550) [0x102c58876] 7
                        1  -[SPDocument xmlPropertyListRepresentationForDataTypes:] + 27 (SPSupport + 36303) [0x102c6edcf] 7
                          1  -[SPDocument reportsForDataTypes:] + 231 (SPSupport + 22486) [0x102c6b7d6] 7
                            1  dispatch_apply_f + 345 (libdispatch.dylib + 54418) [0x7fff976b8492] 7
                              1  _dispatch_sync_function_invoke + 74 (libdispatch.dylib + 94077) [0x7fff976c1f7d] 7
                                  1  _dispatch_apply_serial + 110 (libdispatch.dylib + 70387) [0x7fff976bc2f3] 7
                                    1  _dispatch_client_callout2 + 8 (libdispatch.dylib + 55544) [0x7fff976b88f8] 7
                                      1  __34-[SPDocument reportsForDataTypes:]_block_invoke + 68 (SPSupport + 22938) [0x102c6b99a] 7
                                        1  -[SPDocument reportForDataType:] + 178 (SPSupport + 22219) [0x102c6b6cb] 7
                                          1  -[SPDocument _reportFromHelperToolForDataType:] + 473 (SPSupport + 21217) [0x102c6b2e1] 7
                                            1  -[NSConcreteFileHandle readDataOfLength:] + 498 (Foundation + 804908) [0x7fff83a3382c] 7
                                              1  read + 10 (libsystem_kernel.dylib + 111174) [0x7fff97812246] 7
                                               *1  hndl_unix_scall64 + 22 (kernel + 646470) [0xffffff800029dd46] 7
                                                 *1  unix_syscall64 + 597 (kernel + 6444693) [0xffffff8000825695] 7
                                                   *1  read_nocancel + 115 (kernel + 5884291) [0xffffff800079c983] 7
                                                     *1  ??? (kernel + 5884954) [0xffffff800079cc1a] 7
                                                       *1  ??? (kernel + 5904888) [0xffffff80007a19f8] 7
                                                         *1  ??? (kernel + 5801187) [0xffffff80007884e3] 7
                                                           *1  lck_mtx_sleep + 132 (kernel + 1026980) [0xffffff80002faba4] 7
                                                             *1  thread_block_reason + 222 (kernel + 1069422) [0xffffff800030516e] 7
                                                               *1  ??? (kernel + 1073995) [0xffffff800030634b] 7
        *1  machine_switch_context + 206 (kernel + 2082766) [0xffffff80003fc7ce] 7
  Thread 0x3562d            DispatchQueue 11          1 sample (7)              priority 31 (base 31)     cpu time <0.001
  <DispatchQueue not seen for 6 samples, thread QoS default (requested default), IO tier 0>
  1  _dispatch_sig_thread + 41 (libdispatch.dylib + 62031) [0x7fff976ba24f] 7
    1  __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 106982) [0x7fff978111e6] 7
     *1  ??? (kernel + 5801776) [0xffffff8000788730] 7
  Binary Images:
           0x102c54000 -        0x102c59fff  system_profiler (1127)                    <9A409191-A019-3FB0-9DBC-FFD189B33E75>  /usr/sbin/system_profiler
           0x102c66000 -        0x102c72fff  com.apple.framework.SPSupport 10.12 (915) <D77C111D-13F3-327F-A802-05B2D9A77F12>  /System/Library/PrivateFrameworks/SPSupport.framework/Versions/A/SPSupport
Process:         system_profiler [8343]
Parent:          system_profiler [8342]
UID:             503
Task size:       17.81 MB
CPU Time:        0.043
  Thread 0x35631            1 sample (7)              priority 31 (base 31)     cpu time 0.009
    1  ??? (system_profiler + 19028) [0x109ba1a54] 7
  Thread 0x35632            DispatchQueue 10          1 sample (7)              priority 31 (base 31)     cpu time 0.033
                    1  ??? (system_profiler + 19096) [0x109ba1a98] 7
                      1  ??? (system_profiler + 18550) [0x109ba1876] 7
                        1  -[SPDocument xmlPropertyListRepresentationForDataTypes:] + 27 (SPSupport + 36303) [0x109bb1dcf] 7
                          1  -[SPDocument reportsForDataTypes:] + 231 (SPSupport + 22486) [0x109bae7d6] 7
                                      1  __34-[SPDocument reportsForDataTypes:]_block_invoke + 68 (SPSupport + 22938) [0x109bae99a] 7
                                        1  -[SPDocument reportForDataType:] + 178 (SPSupport + 22219) [0x109bae6cb] 7
                                          1  -[SPDocument _reportFromBundlesForDataType:] + 547 (SPSupport + 20429) [0x109badfcd] 7
                                            1  ??? (<F39A0019-864F-3603-A0FD-3756288AC902> + 13160) [0x109c79368] 7
                                              1  ??? (<F39A0019-864F-3603-A0FD-3756288AC902> + 3626) [0x109c76e2a] 7
                                                1  MakeOneStringProp + 99 (IOKit + 23367) [0x7fff83edbb47] 7
                                                  1  CFDictionarySetValue + 221 (CoreFoundation + 43709) [0x7fff81f02abd] 7
                                                    1  __CFBasicHashAddValue + 103 (CoreFoundation + 39335) [0x7fff81f019a7] 7
                                                      1  __CFBasicHashRehash + 288 (CoreFoundation + 14048) [0x7fff81efb6e0] 7
                                                        1  malloc_zone_malloc + 107 (libsystem_malloc.dylib + 8834) [0x7fff97864282] 7
                                                          1  szone_malloc_should_clear + 72 (libsystem_malloc.dylib + 9002) [0x7fff9786432a] (running) 7
  Thread 0x35633            DispatchQueue 11          1 sample (7)              priority 31 (base 31)     cpu time <0.001
  Binary Images:
           0x109b9d000 -        0x109ba2fff  system_profiler (1127)                       <9A409191-A019-3FB0-9DBC-FFD189B33E75>  /usr/sbin/system_profiler
           0x109ba9000 -        0x109bb5fff  com.apple.framework.SPSupport 10.12 (915)    <D77C111D-13F3-327F-A802-05B2D9A77F12>  /System/Library/PrivateFrameworks/SPSupport.framework/Versions/A/SPSupport
           0x109c76000 -                ???  ???                                          <F39A0019-864F-3603-A0FD-3756288AC902>
        0x7fff83ed6000 -     0x7fff83f6bfff  com.apple.framework.IOKit 2.0.2 (1324.50.21) <BA7DC917-35A9-3D1B-BBEC-ADF4495A166D>  /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
        0x7fff97862000 -     0x7fff97880fff  libsystem_malloc.dylib (116.50.8)            <48D1BBA3-914E-3C65-AF70-C33B4A1B5233>  /usr/lib/system/libsystem_malloc.dylib
Process:         systemsoundserverd [292]
Path:            /usr/sbin/systemsoundserverd
Parent:          launchd [1]
UID:             0
Task size:       15.05 MB
  Thread 0x94c              DispatchQueue 11          10 samples (1-10)         priority 31 (base 31)
  Binary Images:
           0x1026fb000 -        0x10271bfff  systemsoundserverd (892.3.29)      <BB1DCBA2-A126-39EF-8A83-6AC3AADC0D47>  /usr/sbin/systemsoundserverd
Process:         systemstats [215]
Path:            /usr/sbin/systemstats
Parent:          launchd [1]
UID:             0
Task size:       10056 KB
  Thread 0x5d9              DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x10e764000 -        0x10e843fff  systemstats (293.51.1)             <678CA712-3B76-3FEF-B15C-A396AA280D76>  /usr/sbin/systemstats
Process:         SystemUIServer [324]
Path:            /System/Library/CoreServices/SystemUIServer.app/Contents/MacOS/SystemUIServer
Parent:          launchd [1]
UID:             503
Task size:       96.20 MB
  Thread 0xb66              DispatchQueue 1           10 samples (1-10)         priority 46 (base 46)
  <thread QoS user interactive (requested user interactive), process sudden termination dirty, process unclamped, process received importance donation from WiFiProxy [528], IO tier 0>
    10  ??? (SystemUIServer + 19030) [0x1098dda56] 1-10
  Thread 0xf49              Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 46 (base 46)
  Binary Images:
           0x1098d9000 -        0x109922fff  com.apple.systemuiserver 1.7 (455.2)   <970D14E2-5501-32B1-B018-18D0B9C304DC>  /System/Library/CoreServices/SystemUIServer.app/Contents/MacOS/SystemUIServer
Process:         taskgated [132]
Path:            /usr/libexec/taskgated
Parent:          launchd [1]
UID:             0
Task size:       16.53 MB
  Thread 0x2d8              DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
    10  ??? (taskgated + 4180) [0x10af7a054] 1-10
      10  ??? (taskgated + 14623) [0x10af7c91f] 1-10
        10  ??? (taskgated + 15414) [0x10af7cc36] 1-10
          10  mach_msg_overwrite_trap + 10 (libsystem_kernel.dylib + 74582) [0x7fff97809356] 1-10
  Binary Images:
           0x10af79000 -        0x10af82fff  taskgated (55170)                  <9EB80DEE-3E01-34AB-8868-6C3C8C45CFAB>  /usr/libexec/taskgated
Process:         TBLoopDriveParams [80]
Path:            /Library/Application Support/Seagate/TBLoopDriveParams
Parent:          launchd [1]
UID:             0
Task size:       10.88 MB
  Thread 0x2b2              DispatchQueue 1           10 samples (1-10)         priority 20 (base 20)
  <thread QoS utility (requested utility), timers tier 3 (coalesced), IO tier 1>
  10  start + 52 (TBLoopDriveParams + 6304) [0x1000018a0] 1-10
    10  main + 90 (TBLoopDriveParams + 8808) [0x100002268] 1-10
  Binary Images:
           0x100000000 -        0x100006fff  TBLoopDriveParams                      <E63B2131-2F43-C6E5-6C08-8593C9918F8A>  /Library/Application Support/Seagate/TBLoopDriveParams
Process:         tccd [302]
Path:            /System/Library/PrivateFrameworks/TCC.framework/Versions/A/Resources/tccd
Parent:          launchd [1]
UID:             0
Task size:       19.69 MB
  Thread 0x9d4              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  ??? (tccd + 10703) [0x10063f9cf] 1-10
  Binary Images:
           0x10063d000 -        0x100651fff  tccd (193.50.2)                        <AF85F44B-D0AE-3262-956D-82B5602CAD73>  /System/Library/PrivateFrameworks/TCC.framework/Versions/A/Resources/tccd
Process:         tccd [336]
Parent:          launchd [1]
UID:             503
Task size:       20.18 MB
  Thread 0xbb5              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  ??? (tccd + 10703) [0x10361d9cf] 1-10
  Binary Images:
           0x10361b000 -        0x10362ffff  tccd (193.50.2)                        <AF85F44B-D0AE-3262-956D-82B5602CAD73>  /System/Library/PrivateFrameworks/TCC.framework/Versions/A/Resources/tccd
Process:         thermald [241]
Path:            /usr/libexec/thermald
Parent:          launchd [1]
UID:             0
Task size:       12.34 MB
  Thread 0x74a              DispatchQueue 1           10 samples (1-10)         priority 63 (base 63)
    10  ??? (thermald + 25356) [0x100c3430c] 1-10
      10  __ioctl + 10 (libsystem_kernel.dylib + 103918) [0x7fff978105ee] 1-10
           *10  ioctl + 1411 (kernel + 5889907) [0xffffff800079df73] 1-10
             *10  fo_ioctl + 123 (kernel + 5584027) [0xffffff800075349b] 1-10
               *10  ??? (kernel + 3395876) [0xffffff800053d124] 1-10
                 *10  VNOP_IOCTL + 366 (kernel + 3455102) [0xffffff800054b87e] 1-10
                   *10  spec_ioctl + 163 (kernel + 3498963) [0xffffff80005563d3] 1-10
                     *10  xcpm_cpu_control + 1482 (kernel + 2227338) [0xffffff800041fc8a] 1-10
                       *10  ??? (kernel + 5801187) [0xffffff80007884e3] 1-10
                         *10  lck_mtx_sleep + 132 (kernel + 1026980) [0xffffff80002faba4] 1-10
  Binary Images:
           0x100c2e000 -        0x100c38fff  thermald (79)                      <71DCB69F-FFCD-3F07-AF9A-D3DE24A1B4EA>  /usr/libexec/thermald
Process:         TMCacheDelete [373]
Path:            /System/Library/CoreServices/backupd.bundle/Contents/Resources/TMCacheDelete
Parent:          launchd [1]
UID:             0
Task size:       27.29 MB
  Thread 0xd6f              DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x10d460000 -        0x10d461fff  TMCacheDelete (121)                <D9A33114-0BA1-37B8-9B5A-FFB6DB93D280>  /System/Library/CoreServices/backupd.bundle/Contents/Resources/TMCacheDelete
Process:         TouchBarAgent [317]
Path:            /System/Library/CoreServices/ControlStrip.app/Contents/MacOS/TouchBarAgent
Parent:          launchd [1]
UID:             503
Task size:       19.44 MB
  Thread 0xb30              DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
  <thread QoS default (requested user interactive), IO tier 0>
    10  ??? (TouchBarAgent + 9178) [0x10e0663da] 1-10
      10  _TF10ObjectiveC15autoreleasepoolFFT_T_T_ + 38 (libswiftObjectiveC.dylib + 12614) [0x7fff944dd146] 1-10
  Binary Images:
           0x10e064000 -        0x10e10afff  TouchBarAgent (104.25)                 <98DEEF24-BEE4-3910-AAD1-F0114130CC7D>  /System/Library/CoreServices/ControlStrip.app/Contents/MacOS/TouchBarAgent
        0x7fff944da000 -     0x7fff944e0fff  libswiftObjectiveC.dylib (800.8.18.31) <D5AC1394-CCEB-305F-B33B-BF78BF38FF4C>  /System/Library/PrivateFrameworks/Swift/libswiftObjectiveC.dylib
Process:         TouchBarUserDevice [281]
Path:            /System/Library/CoreServices/ControlStrip.app/Contents/MacOS/TouchBarUserDevice
Parent:          launchd [1]
UID:             0
Task size:       10.92 MB
  Thread 0x8e1              DispatchQueue 11          10 samples (1-10)         priority 31 (base 31)
  Binary Images:
           0x10ab42000 -        0x10ab66fff  TouchBarUserDevice (104.25)        <3E1F0DC0-614E-30F5-9BCF-2F9F0E090A40>  /System/Library/CoreServices/ControlStrip.app/Contents/MacOS/TouchBarUserDevice
Process:         Tresorit [469]
Path:            /Applications/Tresorit.app/Contents/MacOS/Tresorit
Parent:          launchd [1]
UID:             503
Task size:       92.39 MB (+4096  B)
CPU Time:        0.001
Process:         TresoritExtension [711]
Path:            /Applications/Tresorit.app/Contents/MacOS/TresoritExtension.app/Contents/MacOS/TresoritExtension
Parent:          launchd [1]
UID:             503
Task size:       24.72 MB
Process:         trustd [150]
Path:            /usr/libexec/trustd
Parent:          launchd [1]
UID:             0
Task size:       20.12 MB
  Thread 0x3dd              DispatchQueue 11          10 samples (1-10)         priority 31 (base 31)
  Thread 0x3e0              10 samples (1-10)         priority 31 (base 31)
        10  SecTrustOSXCFRunloop(void*) + 119 (Security + 1926342) [0x7fff883d44c6] 1-10
          10  CFRunLoopRun + 97 (CoreFoundation + 814129) [0x7fff81fbec31] 1-10
  Thread 0x56d              Thread name "com.apple.CFStream.LegacyThread"       10 samples (1-10)         priority 31 (base 31)
        10  _legacyStreamRunLoop_workThread + 261 (CoreFoundation + 1435189) [0x7fff82056635] 1-10
  Thread 0x56e              Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 31 (base 31)
  Thread 0x14409            Thread name "com.apple.CFSocket.private"            10 samples (1-10)         priority 31 (base 31)
  Binary Images:
           0x103411000 -        0x1034c3fff  trustd (57740.51.3)                     <61915E86-0A9F-3229-9FDF-5A2A779E35B2>  /usr/libexec/trustd
        0x7fff881fe000 -     0x7fff884fffff  com.apple.security 7.0 (57740.51.3)     <E8E40839-4F2C-3954-9870-9F9BA185BC81>  /System/Library/Frameworks/Security.framework/Versions/A/Security
Process:         trustd [319]
Parent:          launchd [1]
UID:             503
Task size:       24.41 MB
  Thread 0xb4c              DispatchQueue 11          10 samples (1-10)         priority 31 (base 31)
  Thread 0xb4e              10 samples (1-10)         priority 31 (base 31)
  Thread 0x7c55             Thread name "com.apple.CFStream.LegacyThread"       10 samples (1-10)         priority 31 (base 31)
  Thread 0x7c56             Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 31 (base 31)
  Thread 0x7ccd             Thread name "com.apple.CFSocket.private"            10 samples (1-10)         priority 31 (base 31)
  Binary Images:
           0x10fc03000 -        0x10fcb5fff  trustd (57740.51.3)                    <61915E86-0A9F-3229-9FDF-5A2A779E35B2>  /usr/libexec/trustd
Process:         trustd [1088]
Parent:          launchd [1]
UID:             89
Task size:       10.01 MB
  Thread 0x25a3             10 samples (1-10)         priority 31 (base 31)
  Thread 0x25a6             10 samples (1-10)         priority 31 (base 31)
  Binary Images:
           0x107b4b000 -        0x107bfdfff  trustd (57740.51.3)                <61915E86-0A9F-3229-9FDF-5A2A779E35B2>  /usr/libexec/trustd
Process:         uninstalld [48]
Path:            /System/Library/PrivateFrameworks/Uninstall.framework/Versions/A/Resources/uninstalld
Parent:          launchd [1]
UID:             0
Task size:       11.57 MB
  Thread 0x29f              DispatchQueue 1           10 samples (1-10)         priority 20 (base 20)
  <thread QoS utility (requested utility), timers tier 3 (coalesced), IO tier 3>
    10  ??? (uninstalld + 12320) [0x10a0f6020] 1-10
  Binary Images:
           0x10a0f3000 -        0x10a0fcfff  uninstalld (221)                       <68BA7C1B-F5B0-3667-9859-A31BA1826CF7>  /System/Library/PrivateFrameworks/Uninstall.framework/Versions/A/Resources/uninstalld
Process:         universalAccessAuthWarn [533]
Path:            /System/Library/PrivateFrameworks/UniversalAccess.framework/Versions/A/Resources/universalAccessAuthWarn.app/Contents/MacOS/universalAccessAuthWarn
Parent:          launchd [1]
UID:             503
Task size:       45.75 MB
  Thread 0x12ad             DispatchQueue 1           10 samples (1-10)         priority 46 (base 46)
    10  NSApplicationMain + 1237 (AppKit + 25054) [0x7fff7fa3b1de] 1-10
      10  -[NSApplication run] + 926 (AppKit + 243627) [0x7fff7fa707ab] 1-10
        10  -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 2796 (AppKit + 8136798) [0x7fff801f785e] 1-10
          10  _DPSNextEvent + 1120 (AppKit + 290340) [0x7fff7fa7be24] 1-10
            10  _BlockUntilNextEventMatchingListInModeWithFilter + 71 (HIToolbox + 199462) [0x7fff814e0b26] 1-10
              10  ReceiveNextEventCommon + 432 (HIToolbox + 199921) [0x7fff814e0cf1] 1-10
                10  RunCurrentEventLoopInMode + 240 (HIToolbox + 200380) [0x7fff814e0ebc] 1-10
  <process clamped>
  Thread 0x12ca             Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 46 (base 46)
        10  _NSEventThread + 205 (AppKit + 1655506) [0x7fff7fbc92d2] 1-10
  <process clamped>
  Thread 0x29b4a            10 samples (1-10)         priority 31 (base 31)
  <process sudden termination dirty, process unclamped, IO tier 0>
*8  wq_unpark_continue + 0 (pthread + 15190) [0xffffff7f81359b56] 1-8
  <process clamped>
*2  wq_unpark_continue + 0 (pthread + 15190) [0xffffff7f81359b56] 9-10
  Binary Images:
           0x101881000 -        0x101885fff  com.apple.accessibility.universalAccessAuthWarn 1.0 (304.30.3) <C67B9777-46AB-3B61-857C-9D0A70F69F80>  /System/Library/PrivateFrameworks/UniversalAccess.framework/Versions/A/Resources/universalAccessAuthWarn.app/Contents/MacOS/universalAccessAuthWarn
        0x7fff7fa35000 -     0x7fff8080efff  com.apple.AppKit 6.9 (1504.82.104)                             <C295FF09-9984-34C3-953B-B263EF2107AB>  /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
        0x7fff814b0000 -     0x7fff817b9fff  com.apple.HIToolbox 2.1.1 (857.8)                              <40254D9A-E477-3F33-B2A2-807D399BF71C>  /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
   *0xffffff7f81356000 - 0xffffff7f81361fff  com.apple.kec.pthread 1.0 (1)                                  <4EFF2F70-C9B9-3176-BF83-F1B660C42135>  /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread
Process:         USBAgent [1281]
Path:            /usr/libexec/USBAgent
Parent:          launchd [1]
UID:             503
Task size:       10.48 MB
  Thread 0x4d38             10 samples (1-10)         priority 20 (base 20)
  Binary Images:
           0x10da31000 -        0x10da34fff  USBAgent (892.50.4)                <0B42BDFB-E17A-358A-BCCC-87169AF0D2A2>  /usr/libexec/USBAgent
Process:         usbd [224]
Path:            /usr/libexec/usbd
Parent:          launchd [1]
UID:             0
Task size:       16.38 MB
  Thread 0x663              DispatchQueue 1           10 samples (1-10)         priority 20 (base 20)
    10  ??? (usbd + 6109) [0x10d7587dd] 1-10
  Binary Images:
           0x10d757000 -        0x10d767fff  usbd (892.50.4)                        <628187EC-694A-3CE5-B461-F34ACDCFB3B5>  /usr/libexec/usbd
Process:         usbmuxd [107]
Path:            /System/Library/PrivateFrameworks/MobileDevice.framework/Versions/A/Resources/usbmuxd
Parent:          launchd [1]
UID:             213
Task size:       11.69 MB
CPU Time:        0.002
  Thread 0x443              DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)     cpu time 0.002
    10  ??? (usbmuxd + 9725) [0x10024a5fd] 1-10
  Thread 0x495              Thread name "com.apple.CFSocket.private"            10 samples (1-10)         priority 31 (base 31)     cpu time <0.001
  Binary Images:
           0x100248000 -        0x100262fff  usbmuxd (374.913)                      <C4AFC5EA-A1E9-3091-8A15-58B0FA23F671>  /System/Library/PrivateFrameworks/MobileDevice.framework/Versions/A/Resources/usbmuxd
Process:         USBserver [689]
Path:            /Library/Printers/Brother/Utilities/Server/USBserver.app/Contents/MacOS/USBserver
Architecture:    i386
Parent:          launchd [1]
UID:             503
Task size:       3584 KB
Process:         useractivityd [410]
Path:            /System/Library/PrivateFrameworks/UserActivity.framework/Agents/useractivityd
Parent:          launchd [1]
UID:             503
Task size:       21.14 MB
  Thread 0xec3              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  ??? (useractivityd + 82669) [0x10649f2ed] 1-10
  Binary Images:
           0x10648b000 -        0x106559fff  useractivityd (63.25)                  <097DCE5D-45E0-31BD-83ED-9D23162B5FB9>  /System/Library/PrivateFrameworks/UserActivity.framework/Agents/useractivityd
Process:         UserEventAgent [44]
Path:            /usr/libexec/UserEventAgent
Parent:          launchd [1]
UID:             0
Task size:       43.64 MB
CPU Time:        <0.001
  Thread 0x29b              DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
    10  ??? (UserEventAgent + 6168) [0x101e1a818] 1-10
  Thread 0x7af              10 samples (1-10)         priority 31 (base 31)
        10  __NSThread__start__ + 1243 (Foundation + 207821) [0x7fff839a1bcd] 1-10
          10  -[BrightnessSystemClientInternal main] + 758 (CoreBrightness + 5829) [0x7fff8d3e56c5] 1-10
  Binary Images:
           0x101e19000 -        0x101e1bfff  UserEventAgent (204.50.1)              <7D1BD8C5-F0A5-3782-911F-BA9C21ECE66E>  /usr/libexec/UserEventAgent
        0x7fff8d3e4000 -     0x7fff8d407fff  com.apple.corebrightness 1.0 (1)       <4779D7FD-EBF4-3E3D-BF89-EAF23BE48162>  /System/Library/PrivateFrameworks/CoreBrightness.framework/Versions/A/CoreBrightness
Process:         UserEventAgent [313]
Parent:          launchd [1]
UID:             503
Task size:       40.12 MB
  Thread 0xb2c              DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
    10  ??? (UserEventAgent + 6168) [0x10b580818] 1-10
  Thread 0xb56              Thread name "com.apple.CFSocket.private"            10 samples (1-10)         priority 31 (base 31)
  Binary Images:
           0x10b57f000 -        0x10b581fff  UserEventAgent (204.50.1)              <7D1BD8C5-F0A5-3782-911F-BA9C21ECE66E>  /usr/libexec/UserEventAgent
Process:         usernoted [341]
Path:            /usr/sbin/usernoted
Parent:          launchd [1]
UID:             503
Task size:       33.64 MB
  Thread 0xc06              DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
  <thread QoS default (requested default), IO tier 0>
    10  ??? (usernoted + 6298) [0x10171d89a] 1-10
  Binary Images:
           0x10171c000 -        0x101820fff  usernoted (552.27)                     <30DE6787-B07C-3179-A4BF-813659EF705B>  /usr/sbin/usernoted
Process:         VDCAssistant [228]
Path:            /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/Resources/VDC.plugin/Contents/Resources/VDCAssistant
Parent:          launchd [1]
UID:             0
Task size:       17.43 MB
  Thread 0x856              DispatchQueue 11          10 samples (1-10)         priority 31 (base 31)
  Thread 0x12261            10 samples (1-10)         priority 97 (base 97)
  <process sudden termination clean, IO tier 0>
  Binary Images:
           0x10d849000 -        0x10d8d2fff  VDCAssistant (4932)                <94CD72E5-B61A-3290-B907-CDA8305971F9>  /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/Resources/VDC.plugin/Contents/Resources/VDCAssistant
Process:         videosubscriptionsd [413]
Path:            /usr/libexec/videosubscriptionsd
Parent:          launchd [1]
UID:             503
Task size:       13.83 MB
  Thread 0xf27              DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x1022e3000 -        0x1022e3fff  videosubscriptionsd (110.45)       <13FBD042-C7B7-38CD-81F1-3184BC4AD990>  /usr/libexec/videosubscriptionsd
Process:         ViewBridgeAuxiliary [491]
Path:            /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/XPCServices/ViewBridgeAuxiliary.xpc/Contents/MacOS/ViewBridgeAuxiliary
Parent:          launchd [1]
UID:             503
Task size:       19.62 MB
CPU Time:        <0.001
Note:            4 idle work queue threads omitted
  Thread 0x1116             DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)       cpu time <0.001
    10  ViewBridgeAuxiliaryMain + 29 (ViewBridge + 443560) [0x7fff958754a8] 1-10
          10  _xpc_objc_main + 731 (libxpc.dylib + 67739) [0x7fff9793b89b] 1-10
  Binary Images:
           0x10ac44000 -        0x10ac44fff  com.apple.ViewBridgeAuxiliary (282)    <0BD01D74-F6EA-302B-83D7-9DFF806BDC89>  /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/XPCServices/ViewBridgeAuxiliary.xpc/Contents/MacOS/ViewBridgeAuxiliary
Process:         VTDecoderXPCService [4904]
Path:            /System/Library/Frameworks/VideoToolbox.framework/Versions/A/XPCServices/VTDecoderXPCService.xpc/Contents/MacOS/VTDecoderXPCService
Parent:          launchd [1]
Responsible:     Safari [4589]
UID:             503
Task size:       18.65 MB
  Thread 0x1c06d            10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x10a94e000 -        0x10a94efff  com.apple.coremedia.videodecoder 1.0 (1) <B4726EE7-01DE-304E-AD81-EDF1BC3110D9>  /System/Library/Frameworks/VideoToolbox.framework/Versions/A/XPCServices/VTDecoderXPCService.xpc/Contents/MacOS/VTDecoderXPCService
Process:         warmd [74]
Path:            /usr/libexec/warmd
Parent:          launchd [1]
UID:             0
Task size:       16.05 MB
  Thread 0x3a3              10 samples (1-10)         priority 31 (base 31)
        10  kevent + 10 (libsystem_kernel.dylib + 109974) [0x7fff97811d96] 1-10
         *10  ??? (kernel + 5627984) [0xffffff800075e050] 1-10
  Thread 0xf84              DispatchQueue 11          10 samples (1-10)         priority 31 (base 31)
  Binary Images:
           0x10b4aa000 -        0x10b4c1fff  warmd (59)                         <22C3230C-76C2-3939-BFD4-CA41F1A36E43>  /usr/libexec/warmd
Process:         watchdogd [400]
Path:            /usr/libexec/watchdogd
Parent:          launchd [1]
UID:             0
Task size:       5780 KB
  Thread 0xe53              DispatchQueue 1           Thread name "com.apple.watchdogd.main-thread"       10 samples (1-10)         priority 31 (base 31)
    10  ??? (watchdogd + 4479) [0x10205f17f] 1-10
  Thread 0x12319            Thread name "com.apple.watchdogd.service-thread"    10 samples (1-10)         priority 31 (base 31)
        10  ??? (watchdogd + 6148) [0x10205f804] 1-10
           *10  psynch_cvcontinue + 0 (pthread + 38973) [0xffffff7f8135f83d] 1-10
  Thread 0x1231a            Thread name "com.apple.watchdogd.watchdog-thread"   10 samples (1-10)         priority 97 (base 97)
  <IO tier 0>
        10  ??? (watchdogd + 6574) [0x10205f9ae] 1-10
  Binary Images:
           0x10205e000 -        0x102060fff  watchdogd (22.1.1)                     <2EF8958F-F3E2-3D74-8F6D-C57D734A181B>  /usr/libexec/watchdogd
Process:         wdhelper [91]
Path:            /usr/libexec/wdhelper
Parent:          launchd [1]
UID:             0
Task size:       13.26 MB
  Thread 0x2de              10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x1061cb000 -        0x106226fff  wdhelper (700.101)                 <3B36CF83-53B8-3C03-8F62-144307D0AF29>  /usr/libexec/wdhelper
Process:         WDQuickView (WD Quick View) [465]
Path:            /Volumes/VOLUME/*/WDQuickView.app/Contents/MacOS/WDQuickView
Architecture:    i386
Parent:          launchd [1]
UID:             503
Task size:       58.92 MB
Note:            Translocated
Process:         WDSecurityHelper [527]
Path:            /private/var/folders/*/WDSecurityHelper.app/Contents/MacOS/WDSecurityHelper
Parent:          launchd [1]
UID:             503
Task size:       16.95 MB
Process:         WiFiAgent [454]
Path:            /System/Library/CoreServices/WiFiAgent.app/Contents/MacOS/WiFiAgent
Parent:          launchd [1]
UID:             503
Task size:       32.78 MB
  Thread 0x14d4             DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
  Thread 0x16c2             Thread name "Cloud Sync Engine"                     10 samples (1-10)         priority 4 (base 4)
          10  ??? (WiFiAgent + 7794) [0x10aafee72] 1-10
            10  -[NSRunLoop(NSRunLoop) runUntilDate:] + 111 (Foundation + 731877) [0x7fff83a21ae5] 1-10
  Thread 0x16c4             Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 4 (base 4)
  <thread QoS background (requested user interactive), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2>
  Thread 0x2a112            10 samples (1-10)         priority 4 (base 4)
  <thread QoS background, process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2>
*10  wq_unpark_continue + 0 (pthread + 15190) [0xffffff7f81359b56] 1-10
  Binary Images:
           0x10aafd000 -        0x10ab0efff  com.apple.wifi.WiFiAgent 12.0 (1200.46) <9390FBA0-18CA-3C20-AF2A-4AD0C150FFFB>  /System/Library/CoreServices/WiFiAgent.app/Contents/MacOS/WiFiAgent
Process:         WiFiProxy [528]
Path:            /System/Library/PrivateFrameworks/CoreWLANKit.framework/Versions/A/XPCServices/WiFiProxy.xpc/Contents/MacOS/WiFiProxy
Parent:          launchd [1]
Responsible:     SystemUIServer [324]
UID:             503
Task size:       24.59 MB
  Thread 0x1264             DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
  <thread QoS default (requested default), process sudden termination dirty, process unclamped, process received importance donation from SystemUIServer [324], IO tier 0>
    10  main + 413 (WiFiProxy + 20571) [0x109c5405b] 1-10
      10  -[NSXPCListener resume] + 165 (Foundation + 524571) [0x7fff839ef11b] 1-10
  Binary Images:
           0x109c4f000 -        0x109c55fff  com.apple.WiFiProxy 12.0 (1200.46)     <9B05E3C5-7878-3932-988C-C2C2019D89D4>  /System/Library/PrivateFrameworks/CoreWLANKit.framework/Versions/A/XPCServices/WiFiProxy.xpc/Contents/MacOS/WiFiProxy
Process:         WiFiVelocityAgent [769]
Path:            /usr/libexec/WiFiVelocityAgent
Parent:          launchd [1]
UID:             503
Task size:       27.51 MB
  Thread 0x190e             DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x10a700000 -        0x10a746fff  WiFiVelocityAgent (48.3)           <E7BA98C6-C140-3A7E-B15F-0264246DEF77>  /usr/libexec/WiFiVelocityAgent
Process:         wifivelocityd [770]
Path:            /usr/libexec/wifivelocityd
Parent:          launchd [1]
UID:             0
Task size:       14.24 MB
  Thread 0x1915             DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x102976000 -        0x102a09fff  wifivelocityd (48.3)               <D4467C8E-8ACE-3E63-A635-F51F600FFF74>  /usr/libexec/wifivelocityd
Process:         WindowServer [165]
Path:            /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/Resources/WindowServer
Parent:          launchd [1]
UID:             88
Task size:       382.68 MB
CPU Time:        0.043
  Thread 0x415              DispatchQueue 1           10 samples (1-10)         priority 79 (base 79)     cpu time 0.040
  <IO tier 0>
    10  ??? (WindowServer + 3550) [0x103fbadde] 1-10
      10  SLXServer + 3843 (SkyLight + 1789922) [0x7fff93ba4fe2] 1-10
        10  CGXRunOneServicesPass + 356 (SkyLight + 1784071) [0x7fff93ba3907] 1-10
          3  run_one_server_pass + 335 (SkyLight + 1784603) [0x7fff93ba3b1b] 1-3
            3  mach_msg_trap + 10 (libsystem_kernel.dylib + 74570) [0x7fff9780934a] 1-3
             *3  ipc_mqueue_receive_continue + 0 (kernel + 862304) [0xffffff80002d2860] 1-3
          3  run_one_server_pass + 275 (SkyLight + 1784543) [0x7fff93ba3adf] 4-6
            3  mach_msg_overwrite_trap + 10 (libsystem_kernel.dylib + 74582) [0x7fff97809356] 4-6
             *3  ipc_mqueue_receive_continue + 0 (kernel + 862304) [0xffffff80002d2860] 4-6
          1  run_one_server_pass + 335 (SkyLight + 1784603) [0x7fff93ba3b1b] 7
            1  mach_msg_trap + 10 (libsystem_kernel.dylib + 74570) [0x7fff9780934a] 7
             *1  ipc_mqueue_receive_continue + 0 (kernel + 862304) [0xffffff80002d2860] 7
          3  run_one_server_pass + 275 (SkyLight + 1784543) [0x7fff93ba3adf] 8-10
            3  mach_msg_overwrite_trap + 10 (libsystem_kernel.dylib + 74582) [0x7fff97809356] 8-10
             *3  ipc_mqueue_receive_continue + 0 (kernel + 862304) [0xffffff80002d2860] 8-10
  Thread 0x75f              10 samples (1-10)         priority 31 (base 31)
        10  void* std::__1::__thread_proxy<std::__1::tuple<void (CoreDisplay::Mach::Server::*)(), CoreDisplay::Mach::Server*> >(void*) + 113 (CoreDisplay + 549645) [0x7fff81ed130d] 1-10
          10  CoreDisplay::Mach::Server::Start() + 132 (CoreDisplay + 546440) [0x7fff81ed0688] 1-10
  Thread 0x803              10 samples (1-10)         priority 37 (base 37)
        10  DFRDisplayRunloopThread + 55 (DFRDisplay + 13814) [0x1041575f6] 1-10
  Thread 0x8dc              Thread name "com.apple.coreanimation.render-server" 10 samples (1-10)         priority 79 (base 79)     cpu time 0.003
  <IO tier 0>
        10  thread_fun + 25 (QuartzCore + 1536979) [0x7fff87c0e3d3] 1-10
          10  CA::Render::Server::server_thread(void*) + 272 (QuartzCore + 814088) [0x7fff87b5dc08] 1-10
  Binary Images:
           0x103fba000 -        0x103fbafff  WindowServer (15)                      <719E9679-9EC1-3C42-B63B-9CDC68029956>  /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/Resources/WindowServer
           0x104154000 -        0x10415bfff  com.apple.DFRDisplay 1.0 (1)           <ED710F11-C320-3876-A205-D914E2AE4E86>  /System/Library/PrivateFrameworks/DFRDisplay.framework/DFRDisplay
        0x7fff81e4b000 -     0x7fff81ef7fff  com.apple.CoreDisplay 1.0 (1)          <461540AF-14C1-38F4-8F85-FD96BD51C856>  /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
        0x7fff87a97000 -     0x7fff87c97fff  com.apple.QuartzCore 1.11 (453.38)     <8B771CD0-F78A-30EA-AD88-F65960528A5B>  /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
Process:         wirelessproxd [99]
Path:            /usr/sbin/wirelessproxd
Parent:          launchd [1]
UID:             0
Task size:       12.38 MB
  Thread 0x2e9              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  ??? (wirelessproxd + 77222) [0x1064bfda6] 1-10
  Binary Images:
           0x1064ad000 -        0x1064e7fff  wirelessproxd (149.7)                  <ECD8200F-C910-33C9-8D0D-A5623C7D3B6A>  /usr/sbin/wirelessproxd
Process:         WirelessRadioManagerd [329]
Path:            /usr/sbin/WirelessRadioManagerd
Parent:          launchd [1]
UID:             0
Task size:       14.93 MB
  Thread 0xb93              DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
    10  ??? (WirelessRadioManagerd + 31814) [0x10e39dc46] 1-10
  Binary Images:
           0x10e396000 -        0x10e3e7fff  WirelessRadioManagerd (511.2)          <1050E85E-98C1-3BCE-A09A-A79A7B6AC454>  /usr/sbin/WirelessRadioManagerd
Process:         writeconfig [1072]
Path:            /System/Library/PrivateFrameworks/SystemAdministration.framework/XPCServices/writeconfig.xpc/Contents/MacOS/writeconfig
Parent:          launchd [1]
UID:             0
Task size:       9880 KB
  Thread 0x2462             10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x10e341000 -        0x10e35afff  com.apple.systemadministration.writeconfig 1.0 (1) <B3FC4937-6605-35E5-BB8D-D2DA6685E1BC>  /System/Library/PrivateFrameworks/SystemAdministration.framework/XPCServices/writeconfig.xpc/Contents/MacOS/writeconfig
Process:         xartstorageremoted [126]
Path:            /usr/libexec/xartstorageremoted
Parent:          launchd [1]
UID:             0
Task size:       9028 KB
  Thread 0x305              DispatchQueue 11          10 samples (1-10)         priority 31 (base 31)
  Binary Images:
           0x10e0f0000 -        0x10e0f4fff  xartstorageremoted (176.50.45)     <55E79D4C-2A15-3836-9305-2A28DF4045FD>  /usr/libexec/xartstorageremoted
Process:         XprotectService [3858]
Path:            /System/Library/PrivateFrameworks/XprotectFramework.framework/Versions/A/XPCServices/XprotectService.xpc/Contents/MacOS/XprotectService
Parent:          launchd [1]
Responsible:     CoreServicesUIAgent [670]
UID:             503
Task size:       15.23 MB
  Thread 0x142b0            10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x104124000 -        0x104131fff  com.apple.XprotectFramework.AnalysisService 1.0 (1) <A407FEF0-5893-3138-93F1-E9A2F94B27E8>  /System/Library/PrivateFrameworks/XprotectFramework.framework/Versions/A/XPCServices/XprotectService.xpc/Contents/MacOS/XprotectService
Process:         kernel_task [0]
Path:            /System/Library/Kernels/kernel
UID:             0
Version:         Darwin Kernel Version 16.5.0: Fri Mar  3 16:52:33 PST 2017; root:xnu-3789.51.2~3/RELEASE_X86_64
Task size:       2536.81 MB (+444 KB)
CPU Time:        0.028
  Thread 0x65               10 samples (1-10)         priority 92 (base 92)
  <IO tier 0>
*10  vm_pageout_continue + 0 (kernel + 1666640) [0xffffff8000396e50] 1-10
  Thread 0x66               10 samples (1-10)         priority 0 (base 0)       idle time 0.531
  <IO tier 0>
*1  call_continuation + 23 (kernel + 633079) [0xffffff800029a8f7] 1
   *1  idle_thread + 32 (kernel + 1088032) [0xffffff8000309a20] 1
     *1  processor_idle + 237 (kernel + 1086525) [0xffffff800030943d] 1
       *1  machine_idle + 727 (kernel + 2109735) [0xffffff8000403127] (runnable) 1
*1  idle_thread + 0 (kernel + 1088000) [0xffffff8000309a00] (runnable) 2
*1  call_continuation + 23 (kernel + 633079) [0xffffff800029a8f7] 3
   *1  idle_thread + 32 (kernel + 1088032) [0xffffff8000309a20] 3
     *1  processor_idle + 237 (kernel + 1086525) [0xffffff800030943d] 3
       *1  machine_idle + 727 (kernel + 2109735) [0xffffff8000403127] (runnable) 3
*7  idle_thread + 0 (kernel + 1088000) [0xffffff8000309a00] (runnable) 4-10
  Thread 0x67               Thread name "sched_maintenance_thread"              10 samples (1-10)         priority 95 (base 95)     cpu time <0.001
  <IO tier 0>
*10  sched_timeshare_maintenance_continue + 0 (kernel + 1074928) [0xffffff80003066f0] 1-10
  Thread 0x68               10 samples (1-10)         priority 80 (base 80)     cpu time <0.001
  <IO tier 0>
*10  ??? (kernel + 1176416) [0xffffff800031f360] 1-10
  Thread 0x69               10 samples (1-10)         priority 93 (base 93)
  <IO tier 0>
*10  ??? (kernel + 1177664) [0xffffff800031f840] 1-10
  Thread 0x6a               10 samples (1-10)         priority 80 (base 80)
  <IO tier 0>
*10  ??? (kernel + 1178384) [0xffffff800031fb10] 1-10
  Thread 0x6b               10 samples (1-10)         priority 95 (base 95)
  <IO tier 0>
*10  call_continuation + 23 (kernel + 633079) [0xffffff800029a8f7] 1-10
   *10  ??? (kernel + 1268221) [0xffffff80003359fd] 1-10
     *10  thread_block_reason + 222 (kernel + 1069422) [0xffffff800030516e] 1-10
       *10  ??? (kernel + 1073995) [0xffffff800030634b] 1-10
         *10  machine_switch_context + 206 (kernel + 2082766) [0xffffff80003fc7ce] 1-10
  Thread 0x6c               10 samples (1-10)         priority 95 (base 95)
  <IO tier 0>
  Thread 0x6d               10 samples (1-10)         priority 94 (base 94)
  <IO tier 0>
*10  ??? (kernel + 1198752) [0xffffff8000324aa0] 1-10
  Thread 0x6e               10 samples (1-10)         priority 95 (base 95)
  <IO tier 0>
   *10  mapping_replenish + 83 (kernel + 2013235) [0xffffff80003eb833] 1-10
  Thread 0x6f               Thread name "AppleCredentialManager"                10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
*10  IOWorkLoop::threadMain() + 0 (kernel + 7056864) [0xffffff80008bade0] 1-10
  Thread 0x71               Thread name "AppleVTD"    10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
  Thread 0x73               Thread name "IOPMrootDomain"                        10 samples (1-10)         priority 81 (base 81)     cpu time <0.001
  <IO tier 0>
  Thread 0x7e               Thread name "AppleUSBHostRequestCompleter"          10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
  Thread 0x83               10 samples (1-10)         priority 95 (base 95)
  <IO tier 0>
*10  ??? (kernel + 1608208) [0xffffff8000388a10] 1-10
  Thread 0x84               10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
  Thread 0x87               Thread name "AppleKeyStore"                         10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
  Thread 0x8a               10 samples (1-10)         priority 0 (base 0)       idle time 0.727
  <IO tier 0>
*1  idle_thread + 0 (kernel + 1088000) [0xffffff8000309a00] (runnable) 1
*1  call_continuation + 23 (kernel + 633079) [0xffffff800029a8f7] 2
   *1  idle_thread + 32 (kernel + 1088032) [0xffffff8000309a20] 2
     *1  processor_idle + 237 (kernel + 1086525) [0xffffff800030943d] 2
       *1  machine_idle + 727 (kernel + 2109735) [0xffffff8000403127] (runnable) 2
*1  idle_thread + 0 (kernel + 1088000) [0xffffff8000309a00] (runnable) 3
*1  call_continuation + 23 (kernel + 633079) [0xffffff800029a8f7] 4
   *1  idle_thread + 32 (kernel + 1088032) [0xffffff8000309a20] 4
     *1  processor_idle + 237 (kernel + 1086525) [0xffffff800030943d] 4
       *1  machine_idle + 727 (kernel + 2109735) [0xffffff8000403127] (runnable) 4
*1  idle_thread + 0 (kernel + 1088000) [0xffffff8000309a00] (runnable) 5
*3  call_continuation + 23 (kernel + 633079) [0xffffff800029a8f7] 6-8
   *3  idle_thread + 32 (kernel + 1088032) [0xffffff8000309a20] 6-8
     *3  processor_idle + 237 (kernel + 1086525) [0xffffff800030943d] 6-8
       *3  machine_idle + 727 (kernel + 2109735) [0xffffff8000403127] (runnable) 6-8
*1  idle_thread + 0 (kernel + 1088000) [0xffffff8000309a00] (runnable) 9
*1  call_continuation + 23 (kernel + 633079) [0xffffff800029a8f7] 10
   *1  idle_thread + 32 (kernel + 1088032) [0xffffff8000309a20] 10
     *1  processor_idle + 237 (kernel + 1086525) [0xffffff800030943d] 10
       *1  machine_idle + 727 (kernel + 2109735) [0xffffff8000403127] (runnable) 10
  Thread 0x8d               10 samples (1-10)         priority 0 (base 0)       idle time 0.722
  <IO tier 0>
*2  idle_thread + 0 (kernel + 1088000) [0xffffff8000309a00] (runnable) 1-2
*4  call_continuation + 23 (kernel + 633079) [0xffffff800029a8f7] 3-6
   *4  idle_thread + 32 (kernel + 1088032) [0xffffff8000309a20] 3-6
     *4  processor_idle + 237 (kernel + 1086525) [0xffffff800030943d] 3-6
       *4  machine_idle + 727 (kernel + 2109735) [0xffffff8000403127] (runnable) 3-6
*1  idle_thread + 0 (kernel + 1088000) [0xffffff8000309a00] (runnable) 7
*3  call_continuation + 23 (kernel + 633079) [0xffffff800029a8f7] 8-10
   *3  idle_thread + 32 (kernel + 1088032) [0xffffff8000309a20] 8-10
     *3  processor_idle + 237 (kernel + 1086525) [0xffffff800030943d] 8-10
       *3  machine_idle + 727 (kernel + 2109735) [0xffffff8000403127] (runnable) 8-10
  Thread 0x90               10 samples (1-10)         priority 0 (base 0)       idle time 0.689
  <IO tier 0>
*2  call_continuation + 23 (kernel + 633079) [0xffffff800029a8f7] 2-3
   *2  idle_thread + 32 (kernel + 1088032) [0xffffff8000309a20] 2-3
     *2  processor_idle + 237 (kernel + 1086525) [0xffffff800030943d] 2-3
       *2  machine_idle + 727 (kernel + 2109735) [0xffffff8000403127] (runnable) 2-3
*1  idle_thread + 0 (kernel + 1088000) [0xffffff8000309a00] (runnable) 4
*1  call_continuation + 23 (kernel + 633079) [0xffffff800029a8f7] 5
   *1  idle_thread + 32 (kernel + 1088032) [0xffffff8000309a20] 5
     *1  processor_idle + 237 (kernel + 1086525) [0xffffff800030943d] 5
       *1  machine_idle + 727 (kernel + 2109735) [0xffffff8000403127] (runnable) 5
*3  idle_thread + 0 (kernel + 1088000) [0xffffff8000309a00] (runnable) 6-8
*1  call_continuation + 23 (kernel + 633079) [0xffffff800029a8f7] 9
   *1  idle_thread + 32 (kernel + 1088032) [0xffffff8000309a20] 9
     *1  processor_idle + 237 (kernel + 1086525) [0xffffff800030943d] 9
       *1  machine_idle + 727 (kernel + 2109735) [0xffffff8000403127] (runnable) 9
*1  idle_thread + 0 (kernel + 1088000) [0xffffff8000309a00] (runnable) 10
  Thread 0x93               10 samples (1-10)         priority 0 (base 0)       idle time 0.899
  <IO tier 0>
   *10  idle_thread + 32 (kernel + 1088032) [0xffffff8000309a20] 1-10
     *10  processor_idle + 237 (kernel + 1086525) [0xffffff800030943d] 1-10
       *10  machine_idle + 727 (kernel + 2109735) [0xffffff8000403127] (runnable) 1-10
  Thread 0x96               10 samples (1-10)         priority 0 (base 0)       idle time 0.897
  <IO tier 0>
  Thread 0x99               10 samples (1-10)         priority 0 (base 0)       idle time 0.898
  <IO tier 0>
  Thread 0x9c               10 samples (1-10)         priority 0 (base 0)       idle time 0.893
  <IO tier 0>
*2  call_continuation + 23 (kernel + 633079) [0xffffff800029a8f7] 1-2
   *2  idle_thread + 32 (kernel + 1088032) [0xffffff8000309a20] 1-2
     *2  processor_idle + 237 (kernel + 1086525) [0xffffff800030943d] 1-2
       *2  machine_idle + 727 (kernel + 2109735) [0xffffff8000403127] (runnable) 1-2
*7  call_continuation + 23 (kernel + 633079) [0xffffff800029a8f7] 4-10
   *7  idle_thread + 32 (kernel + 1088032) [0xffffff8000309a20] 4-10
     *7  processor_idle + 237 (kernel + 1086525) [0xffffff800030943d] 4-10
       *7  machine_idle + 727 (kernel + 2109735) [0xffffff8000403127] (runnable) 4-10
  Thread 0xa1               Thread name "AppleACPIEC" 10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
  Thread 0xc1               Thread name "AppleACPIButton"                       10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
  Thread 0xcc               Thread name "AppleUSBHostResources"                 10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
  Thread 0xdb               Thread name "AppleIntelLpssI2C"                     10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
  Thread 0xdd               Thread name "AppleUSBXHCISPT"                       10 samples (1-10)         priority 81 (base 81)     cpu time <0.001
  <IO tier 0>
  Thread 0xde               Thread name "AppleIntelLpssI2CController"           10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
  Thread 0xe3               Thread name "AppleUSB20XHCITypeCPort"               10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
  Thread 0xe6               Thread name "AppleUSB20XHCIPort"                    10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
  Thread 0xe8               Thread name "AppleUSB20XHCIPort"                    10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
  Thread 0xea               Thread name "AppleUSB20XHCITypeCPort"               10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
  Thread 0xec               Thread name "AppleUSB20XHCITypeCPort"               10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
  Thread 0xee               Thread name "AppleUSB20XHCITypeCPort"               10 samples (1-10)         priority 81 (base 81)     cpu time <0.001
  <IO tier 0>
  Thread 0xf0               Thread name "AppleUSB30XHCIPort"                    10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
  Thread 0x107              Thread name "AppleThunderboltHAL"                   10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
  Thread 0x113              Thread name "AppleUSBXHCIAR"                        10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
  Thread 0x115              Thread name "AppleUSBXHCIAR"                        10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
  Thread 0x11a              Thread name "AppleThunderboltHAL"                   10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
  Thread 0x12b              Thread name "AppleUSB30XHCITypeCPort"               10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
  Thread 0x12e              Thread name "AppleUSB30XHCITypeCPort"               10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
  Thread 0x130              Thread name "AppleUSB30XHCITypeCPort"               10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
  Thread 0x135              Thread name "AppleUSB30XHCITypeCPort"               10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
  Thread 0x138              Thread name "AppleIntelLpssGspi"                    10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
  Thread 0x13a              Thread name "IONVMeController"                      10 samples (1-10)         priority 81 (base 81)     cpu time <0.001
  <IO tier 0>
   *10  IOWorkLoop::threadMain() + 379 (kernel + 7057243) [0xffffff80008baf5b] 1-10
  Thread 0x13b              Thread name "AppleIntelLpssSpiController"           10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
  Thread 0x13c              10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
  Thread 0x177              Thread name "AppleHSSPIHIDDriver"                   10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
  Thread 0x182              Thread name "AppleHSSPIHIDDriver"                   10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
  Thread 0x189              Thread name "AppleHSSPIHIDDriver"                   10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
  Thread 0x18e              10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
  Thread 0x18f              Thread name "AppleHSSPIHIDDriver"                   10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
  Thread 0x194              Thread name "AppleActuatorDevice"                   10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
  Thread 0x197              Thread name "AppleHSSPIHIDDriver"                   10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
  Thread 0x19d              Thread name "AppleUSBController"                    10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
  Thread 0x19e              Thread name "AppleUSBRootHubDevice"                 10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
  Thread 0x1a4              10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
*10  ??? (kernel + 3239504) [0xffffff8000516e50] 1-10
  Thread 0x1a6              10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
*10  ??? (kernel + 6012912) [0xffffff80007bbff0] 1-10
  Thread 0x1a7              10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
*10  ??? (kernel + 5451568) [0xffffff8000732f30] 1-10
  Thread 0x1a8              10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
*10  ??? (kernel + 5513712) [0xffffff80007421f0] 1-10
  Thread 0x1a9              10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
  Thread 0x1aa              10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
  Thread 0x1ab              10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
  Thread 0x1ac              10 samples (1-10)         priority 81 (base 81)     cpu time <0.001
  <IO tier 0>
  Thread 0x1ad              10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
  Thread 0x1ae              10 samples (1-10)         priority 81 (base 81)     cpu time <0.001
  <IO tier 0>
   *10  ??? (kernel + 3658335) [0xffffff800057d25f] 1-10
  Thread 0x1af              10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
  Thread 0x1b0              10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
  Thread 0x1b1              10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
  Thread 0x1b2              10 samples (1-10)         priority 95 (base 95)
  <IO tier 0>
*10  ??? (kernel + 5827952) [0xffffff800078ed70] 1-10
  Thread 0x1b5              10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
*10  sockwall_gc_thread + 0 (ALF + 23908) [0xffffff7f84220d64] 1-10
  Thread 0x1ba              Thread name "IOHIDResourceDeviceUserClient"         10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
  Thread 0x1bc              Thread name "IOHIDSystem" 10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
  Thread 0x1be              Thread name "AirPort_Brcm4360"                      10 samples (1-10)         priority 82 (base 82)     cpu time 0.002
  <IO tier 0>
  Thread 0x1ce              Thread name "CoreStorageGroup"                      10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
  Thread 0x1d2              10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
   *10  _cs_thread_create_int(thread_wrapper*) + 28 (CoreStorage + 539806) [0xffffff7f82789c9e] 1-10
     *10  txg_sync_thread(void*) + 232 (CoreStorage + 252113) [0xffffff7f827438d1] 1-10
       *10  _cv_wait + 63 (CoreStorage + 539156) [0xffffff7f82789a14] 1-10
         *10  msleep + 98 (kernel + 5802402) [0xffffff80007889a2] 1-10
  Thread 0x1d3              10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
     *10  lfs_clean_thread(void*) + 67 (CoreStorage + 201934) [0xffffff7f827374ce] 1-10
  Thread 0x1d8              10 samples (1-10)         priority 46 (base 46)     cpu time <0.001
  <IO tier 0>
   *10  CoreStorageDaemon::cryptoDaemon() + 96 (CoreStorage + 527990) [0xffffff7f82786e76] 1-10
  Thread 0x1d9              10 samples (1-10)         priority 46 (base 46)     cpu time <0.001
  <IO tier 0>
  Thread 0x1da              10 samples (1-10)         priority 46 (base 46)     cpu time <0.001
  <IO tier 0>
  Thread 0x1db              10 samples (1-10)         priority 46 (base 46)     cpu time <0.001
  <IO tier 0>
  Thread 0x1f0              10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
   *10  ??? (kernel + 6292570) [0xffffff800080045a] 1-10
     *10  mach_msg_receive + 167 (kernel + 926887) [0xffffff80002e24a7] 1-10
       *10  ipc_mqueue_receive + 119 (kernel + 862647) [0xffffff80002d29b7] 1-10
  Thread 0x1f2              10 samples (1-10)         priority 92 (base 92)
  <IO tier 2>
*10  ??? (kernel + 1669856) [0xffffff8000397ae0] 1-10
  Thread 0x1f3              10 samples (1-10)         priority 31 (base 31)
  <IO tier 0>
*10  ??? (kernel + 1665152) [0xffffff8000396880] 1-10
  Thread 0x1f4              10 samples (1-10)         priority 31 (base 31)
  <IO tier 0>
*10  vm_pressure_thread + 0 (kernel + 1666240) [0xffffff8000396cc0] 1-10
  Thread 0x1f5              10 samples (1-10)         priority 92 (base 92)
  <IO tier 0>
*10  ??? (kernel + 1608608) [0xffffff8000388ba0] 1-10
  Thread 0x1f6              10 samples (1-10)         priority 92 (base 92)
  <IO tier 0>
*10  ??? (kernel + 1412192) [0xffffff8000358c60] 1-10
  Thread 0x1f7              10 samples (1-10)         priority 92 (base 92)
  <IO tier 0>
*10  ??? (kernel + 1671616) [0xffffff80003981c0] 1-10
  Thread 0x1f8              10 samples (1-10)         priority 92 (base 92)
  <IO tier 0>
  Thread 0x1f9              10 samples (1-10)         priority 92 (base 92)
  <IO tier 2 and passive>
*10  ??? (kernel + 1434832) [0xffffff800035e4d0] 1-10
  Thread 0x1fa              10 samples (1-10)         priority 92 (base 92)     cpu time <0.001
  <IO tier 0>
*10  ??? (kernel + 1436640) [0xffffff800035ebe0] 1-10
  Thread 0x1fb              10 samples (1-10)         priority 92 (base 92)
*10  ??? (kernel + 1437264) [0xffffff800035ee50] 1-10
  Thread 0x1fd              10 samples (1-10)         priority 81 (base 81)     cpu time <0.001
  <IO tier 0>
*10  ??? (kernel + 1199376) [0xffffff8000324d10] 1-10
  Thread 0x244              10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
   *10  ??? (kernel + 6233132) [0xffffff80007f1c2c] 1-10
  Thread 0x3b8              Thread name "dlil_input_en0"                        10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
   *10  ??? (kernel + 3661983) [0xffffff800057e09f] 1-10
  Thread 0x3b9              Thread name "ifnet_start_en0"                       10 samples (1-10)         priority 82 (base 82)     cpu time <0.001
  <IO tier 0>
   *10  ??? (kernel + 3692980) [0xffffff80005859b4] 1-10
  Thread 0x47d              Thread name "IOGraphicsWorkLoop"                    10 samples (1-10)         priority 81 (base 81)     cpu time <0.001
  <IO tier 0>
  Thread 0x487              Thread name "dlil_input_en2"                        10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
  Thread 0x488              Thread name "ifnet_start_en2"                       10 samples (1-10)         priority 82 (base 82)
  <IO tier 0>
  Thread 0x48a              Thread name "dlil_input_en4"                        10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
  Thread 0x48b              Thread name "ifnet_start_en4"                       10 samples (1-10)         priority 82 (base 82)
  <IO tier 0>
  Thread 0x48d              Thread name "AppleSMC"    10 samples (1-10)         priority 81 (base 81)     cpu time <0.001
  <IO tier 0>
  Thread 0x491              Thread name "X86PlatformPlugin"                     10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
  Thread 0x492              Thread name "AppleEmbeddedOSSupportHost"            10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
  Thread 0x497              Thread name "AppleHDAController"                    10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
  Thread 0x499              Thread name "AppleGraphicsControlBacklight"         10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
  Thread 0x4a1              Thread name "AppleIntelLpssUARTv1"                  10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
  Thread 0x4a5              10 samples (1-10)         priority 97 (base 97)
  <IO tier 0>
   *10  AppleOSXWatchdog::watchdogMainThread() + 120 (AppleOSXWatchdog + 5680) [0xffffff7f82b3e630] 1-10
  Thread 0x4a8              Thread name "AppleIntelLpssUARTv1"                  10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
  Thread 0x4ac              Thread name "dlil_input_en1"                        10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
  Thread 0x4ad              Thread name "ifnet_start_en1"                       10 samples (1-10)         priority 82 (base 82)
  <IO tier 0>
  Thread 0x4af              Thread name "dlil_input_en3"                        10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
  Thread 0x4b0              Thread name "ifnet_start_en3"                       10 samples (1-10)         priority 82 (base 82)
  <IO tier 0>
  Thread 0x4b2              Thread name "AppleIntelLpssUARTv1"                  10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
  Thread 0x4c7              Thread name "AppleMCCSParameterHandler"             10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
  Thread 0x4c8              Thread name "com_cycling74_driver_SoundflowerDevice"                          10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
  Thread 0x4c9              Thread name "com_globaldelight_driver_Boom2Device"  10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
  Thread 0x4ca              Thread name "AppleIntelSlowAdaptiveClockingManager" 10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
  Thread 0x4f6              Thread name "AppleHDAController"                    10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
  Thread 0x500              Thread name "AppleHDADriver"                        10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
  Thread 0x50c              Thread name "IOBluetoothHCIController"              10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
  Thread 0x50e              Thread name "IOBluetoothSerialManager"              10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
  Thread 0x511              Thread name "IOSurfaceRoot"                         10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
  Thread 0x513              10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
  Thread 0x515              Thread name "AMDRadeonX4100_AMDAccelEventMachine"   10 samples (1-10)         priority 81 (base 81)     cpu time <0.001
  <IO tier 0>
  Thread 0x516              Thread name "AMDRadeonX4100_AMDBaffinGraphicsAccelerator"                     10 samples (1-10)         priority 81 (base 81)     cpu time <0.001
  <IO tier 0>
  Thread 0x517              Thread name "IOAccelFenceMachine"                   10 samples (1-10)         priority 81 (base 81)     cpu time <0.001
  <IO tier 0>
  Thread 0x51a              Thread name "AMDRadeonX4100_AMDCPEvent"             10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
  Thread 0x534              Thread name "com_kairos_driver_DuetDisplayFramebuffer"                        10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
  Thread 0x550              Thread name "AppleIntelMEIDriver"                   10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
  Thread 0x581              Thread name "AppleHDADriver"                        10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
  Thread 0x5ae              Thread name "IGAccelEventMachine"                   10 samples (1-10)         priority 81 (base 81)     cpu time <0.001
  <IO tier 0>
  Thread 0x5af              Thread name "IntelAccelerator"                      10 samples (1-10)         priority 81 (base 81)     cpu time 0.001
  <IO tier 0>
  Thread 0x5b0              Thread name "IOAccelFenceMachine"                   10 samples (1-10)         priority 81 (base 81)     cpu time <0.001
  <IO tier 0>
  Thread 0x5e6              Thread name "com_parallels_kext_virtual_sound_device"                         10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
  Thread 0x6f9              Thread name "dlil_input_p2p0"                       10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
  Thread 0x6fa              Thread name "ifnet_start_p2p0"                      10 samples (1-10)         priority 82 (base 82)
  <IO tier 0>
  Thread 0x6fc              Thread name "dlil_input_awdl0"                      10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
  Thread 0x6fd              Thread name "ifnet_start_awdl0"                     10 samples (1-10)         priority 82 (base 82)
  <IO tier 0>
  Thread 0x73f              Thread name "X86PlatformShim"                       10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
  Thread 0x740              10 samples (1-10)         priority 95 (base 95)
  <IO tier 0>
   *10  ??? (kernel + 2189663) [0xffffff800041695f] 1-10
  Thread 0x741              10 samples (1-10)         priority 95 (base 95)
  <IO tier 0>
   *10  ??? (kernel + 2191202) [0xffffff8000416f62] 1-10
  Thread 0x742              10 samples (1-10)         priority 95 (base 95)
  <IO tier 0>
  Thread 0x743              10 samples (1-10)         priority 95 (base 95)
  <IO tier 0>
  Thread 0x744              10 samples (1-10)         priority 95 (base 95)
  <IO tier 0>
  Thread 0x745              10 samples (1-10)         priority 95 (base 95)
  <IO tier 0>
  Thread 0x746              10 samples (1-10)         priority 95 (base 95)
  <IO tier 0>
  Thread 0x747              10 samples (1-10)         priority 95 (base 95)
  <IO tier 0>
  Thread 0x76d              Thread name "AMDRadeonX4100_AMDAccelDisplayPipe"    10 samples (1-10)         priority 81 (base 81)     cpu time 0.002
  <IO tier 0>
  Thread 0x76e              Thread name "AMDRadeonX4100_AMDAccelDisplayPipe"    10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
  Thread 0x76f              Thread name "AMDRadeonX4100_AMDAccelDisplayPipe"    10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
  Thread 0x770              Thread name "AMDRadeonX4100_AMDAccelDisplayPipe"    10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
  Thread 0x771              Thread name "AMDRadeonX4100_AMDAccelDisplayPipe"    10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
  Thread 0x772              Thread name "AMDFramebuffer"                        10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
  Thread 0x7ea              Thread name "com_kairos_driver_DuetDisplayFramebuffer"                        10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
  Thread 0x7ec              Thread name "AppleIntelFramebuffer"                 10 samples (1-10)         priority 81 (base 81)     cpu time <0.001
  <IO tier 0>
  Thread 0x846              10 samples (1-10)         priority 93 (base 93)
  <IO tier 0>
  Thread 0xb5c              Thread name "IGAccelDisplayPipe"                    10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
  Thread 0xd96              Thread name "ifnet_start_utun0"                     10 samples (1-10)         priority 82 (base 82)
  <IO tier 0>
  Thread 0x7c02             Thread name "ifnet_start_utun2"                     10 samples (1-10)         priority 82 (base 82)
  <IO tier 0>
  Thread 0x9d67             10 samples (1-10)         priority 46 (base 46)
  <IO tier 0>
   *10  CoreStorageDaemon::partialRequestDaemon() + 139 (CoreStorage + 528275) [0xffffff7f82786f93] 1-10
  Thread 0x12266            Thread name "KernelRelayHost"                       10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
  Thread 0x12267            10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
   *10  IOSlaveProcessorRelay::_dispatchThreadFunction(OSObject*, int) + 74 (KernelRelayHost + 7044) [0xffffff7f8138db84] 1-10
     *10  IOCommandPool::getCommand(bool) + 57 (kernel + 7075289) [0xffffff80008bf5d9] 1-10
       *10  IOCommandGate::runAction(int (*)(OSObject*, void*, void*, void*, void*), void*, void*, void*, void*) + 314 (kernel + 7070378) [0xffffff80008be2aa] 1-10
         *10  KRActionCommandPool::gatedGetCommand(IOCommand**, bool) + 61 (KernelRelayHost + 16353) [0xffffff7f8138ffe1] 1-10
           *10  IOEventSource::sleepGate(void*, unsigned int) + 76 (kernel + 7064764) [0xffffff80008bccbc] 1-10
             *10  IOWorkLoop::sleepGate(void*, unsigned int) + 123 (kernel + 7058795) [0xffffff80008bb56b] 1-10
  Thread 0x12277            Thread name "dlil_input_en12"                       10 samples (1-10)         priority 81 (base 81)
  <IO tier 0>
  Thread 0x12278            Thread name "ifnet_start_en12"                      10 samples (1-10)         priority 82 (base 82)
  <IO tier 0>
  Thread 0x137de            10 samples (1-10)         priority 93 (base 93)     cpu time 0.002
  <IO tier 0>
  Thread 0x18656            10 samples (1-10)         priority 93 (base 93)     cpu time 0.008
  <IO tier 0>
  Thread 0x21eef            10 samples (1-10)         priority 93 (base 93)     cpu time 0.005
  <IO tier 0>
  Thread 0x32499            10 samples (1-10)         priority 93 (base 93)     cpu time 0.006
  <IO tier 0>
  Binary Images:
   *0xffffff7f8138c000 - 0xffffff7f81391fff  com.apple.driver.KernelRelayHost 1.0.0 (1)       <2941E0C2-A610-3526-88F7-A3767933D469>  /System/Library/Extensions/KernelRelayHost.kext/Contents/MacOS/KernelRelayHost
   *0xffffff7f82706000 - 0xffffff7f827b8fff  com.apple.driver.CoreStorage 540.30.1 (540.30.1) <0E033F13-4AF3-38EB-966E-7FACAAFA222D>  /System/Library/Extensions/CoreStorage.kext/Contents/MacOS/CoreStorage
   *0xffffff7f82b3d000 - 0xffffff7f82b3efff  com.apple.driver.AppleOSXWatchdog 1.0 (1)        <9B1AC3B0-A459-3D88-B43D-428EA39DDB8A>  /System/Library/Extensions/AppleOSXWatchdog.kext/Contents/MacOS/AppleOSXWatchdog
   *0xffffff7f8421b000 - 0xffffff7f84221fff  com.apple.nke.applicationfirewall 5.0 (172)      <87563A26-608B-3C95-8476-CAA6E1271FBF>  /System/Library/Extensions/ALF.kext/Contents/MacOS/ALF
   *0xffffff8000200000 - 0xffffff80009fffff  kernel (3789.51.2)                               <06F94FD7-451F-34A1-B13C-D68FF7EDE0A0>  /System/Library/Kernels/kernel
Kextstat:
Index Refs Address            Size       Wired      Name (Version) UUID <Linked Against>
    1  102 0xffffff7f80a18000 0x9d90     0x9d90     com.apple.kpi.bsd (16.5.0) D4161E07-43B8-4D47-ABFE-7DF2D693ED9A
    2    8 0xffffff7f81214000 0x3940     0x3940     com.apple.kpi.dsep (16.5.0) 6B33C49C-82D8-4830-AC91-ECF9B9EE3A8C
    3  130 0xffffff7f80a2c000 0x21040    0x21040    com.apple.kpi.iokit (16.5.0) E2BA46F4-C06A-4ACE-81E5-D9A4B6E061AA
    4  137 0xffffff7f80a00000 0xd200     0xd200     com.apple.kpi.libkern (16.5.0) 21ABA52A-C45A-4A1B-8824-F6EB5295ADDE
    5  123 0xffffff7f80a14000 0x3dd0     0x3dd0     com.apple.kpi.mach (16.5.0) E18B885B-776C-4F3A-88D4-C823FAFE12A1
    6   60 0xffffff7f80a4e000 0xbbf0     0xbbf0     com.apple.kpi.private (16.5.0) F0CD0AC2-92DF-4FF9-80A5-21B68641D28E
    7   78 0xffffff7f80a0e000 0x5890     0x5890     com.apple.kpi.unsupported (16.5.0) 4AE97C68-EB51-4545-A2EB-007EE5A66503
    8    1 0xffffff7f80f23000 0xb000     0xb000     com.apple.kec.Libm (1) 968CBFF1-925D-321E-A5E0-0C5C563BF08C <4>
    9    6 0xffffff7f81267000 0xa9000    0xa9000    com.apple.kec.corecrypto (1.0) E3701C61-A548-3181-9F3E-C90DF8327185 <7 6 5 4 3 1>
   10    0 0xffffff7f81356000 0xf000     0xf000     com.apple.kec.pthread (1) 4EFF2F70-C9B9-3176-BF83-F1B660C42135 <7 6 5 4 1>
   11   35 0xffffff7f80b65000 0x9000     0x9000     com.apple.iokit.IOACPIFamily (1.4) 4F7FB6AD-2498-3F71-827C-ED7AA4BF2511 <7 6 4 3>
   12   36 0xffffff7f80b2a000 0x35000    0x35000    com.apple.iokit.IOPCIFamily (2.9) C6E3195E-A0D7-3B71-B5F4-9EE9E182D4FC <7 6 5 4 3>
   13    2 0xffffff7f83431000 0x60000    0x60000    com.apple.driver.AppleACPIPlatform (5.0) 65E05472-6AE7-3308-8CC8-FA6CB0DB2AEE <12 11 7 6 5 4 3 1>
   14    1 0xffffff7f81460000 0xb000     0xb000     com.apple.driver.AppleFDEKeyStore (28.30) EA5D0966-E8EA-337A-98EB-195806E8F723 <9 7 6 5 4 3 1>
   15    5 0xffffff7f818a4000 0x7000     0x7000     com.apple.iokit.IOReportFamily (31) B14DC3D3-7250-3DA3-BF50-C666EBEDAF4C <5 4 3>
   16    4 0xffffff7f80a5a000 0x27000    0x27000    com.apple.iokit.IOStorageFamily (2.1) F908D7F5-4F54-3B89-8657-57F06350F4DB <7 6 5 4 3 1>
   17    0 0xffffff7f8195a000 0x19000    0x19000    com.apple.driver.DiskImages (444.50.16) 0038C2CD-46A9-3967-945B-3E1F2D6C3EA5 <16 7 6 5 4 3 1>
   18    1 0xffffff7f80b6e000 0xd000     0xd000     com.apple.driver.AppleBusPowerController (1.0) DB526B45-1A45-3A81-A0C1-57F826CADEDF <11 5 4 3>
   19   16 0xffffff7f80b7b000 0x69000    0x69000    com.apple.iokit.IOUSBHostFamily (1.1) 96FD82D0-CFF5-3EDE-971A-456CB10DBEBF <18 7 6 5 4 3 1>
   20    3 0xffffff7f8138c000 0x11000    0x11000    com.apple.driver.KernelRelayHost (1) 2941E0C2-A610-3526-88F7-A3767933D469 <19 5 4 3>
   21    1 0xffffff7f82b96000 0x24000    0x24000    com.apple.driver.AppleCredentialManager (1.0) 669D7D3F-EAE5-3D46-81BD-D7B264D0B111 <20 9 7 6 5 4 3 1>
   22    4 0xffffff7f81310000 0x17000    0x17000    com.apple.driver.AppleMobileFileIntegrity (1.0.5) 200413CD-2982-3EA4-9AFF-B20285024E83 <9 7 6 5 4 3 2 1>
   23    0 0xffffff7f82bba000 0x50000    0x50000    com.apple.driver.AppleKeyStore (2) 6151B0A4-170B-3ED4-9463-A8A6CA122D60 <22 21 20 9 7 6 5 4 3 1>
   24    0 0xffffff7f81218000 0x2000     0x2000     com.apple.security.TMSafetyNet (8) B87D3377-617E-3F24-993B-D70AE269A837 <7 6 5 4 2 1>
   25    2 0xffffff7f81327000 0x5000     0x5000     com.apple.kext.AppleMatch (1.0.0d1) 3B280DAB-903F-33DC-8110-525A1154B11E <4 1>
   26    1 0xffffff7f8132c000 0x20000    0x20000    com.apple.security.sandbox (300.0) CDBEAC20-BD05-3DF5-B7D3-51C3E8DCF872 <25 22 16 7 6 5 4 3 2 1>
   27    0 0xffffff7f8134c000 0x9000     0x9000     com.apple.security.quarantine (3) 1486A49E-2D3F-3D7E-B07A-D2008F327113 <26 25 7 6 5 4 2 1>
   28    0 0xffffff7f8421b000 0x8000     0x8000     com.apple.nke.applicationfirewall (172) 87563A26-608B-3C95-8476-CAA6E1271FBF <7 6 5 4 3 1>
   29    0 0xffffff7f833ff000 0x3000     0x3000     com.apple.driver.AppleAPIC (1.7) BC2E6D01-BCBB-3525-BF38-BF99C3F1EC46 <4 3>
   30    3 0xffffff7f81841000 0x4000     0x4000     com.apple.iokit.IOSMBusFamily (1.1) 185F0EBF-0262-3370-BD47-8FE4C8AA726E <5 4 3>
   31    0 0xffffff7f83497000 0x7000     0x7000     com.apple.driver.AppleACPIEC (5.0) C2873EC3-4194-3C09-B16B-FE63BF4C2EAF <30 13 11 5 4 3>
   32    0 0xffffff7f82ab1000 0x4000     0x4000     com.apple.driver.AppleSMBIOS (2.1) 9BB02681-4B47-3592-AD62-71FB0BF56965 <7 4 3>
   33    0 0xffffff7f82ade000 0x8000     0x8000     com.apple.driver.AppleRTC (2.0) 3FD1BCF4-8AFC-3CE6-A36E-26410544AD14 <11 5 4 3 1>
   34    7 0xffffff7f8146b000 0x7a000    0x7a000    com.apple.iokit.IOHIDFamily (2.0.0) BB7E26B3-36DF-3BB1-B09D-C8496FE63DFE <14 7 6 5 4 3 2 1>
   35    0 0xffffff7f834a1000 0x4000     0x4000     com.apple.driver.AppleACPIButtons (5.0) 6EA42B65-0CD7-3678-87D5-E002D2CDA2D5 <34 15 13 11 7 6 5 4 3 1>
   36    1 0xffffff7f81900000 0x5000     0x5000     com.apple.driver.AppleEFIRuntime (2.0) D927DF0B-03B7-3685-9AE2-18998208BE8A <7 6 5 4 3>
   37    0 0xffffff7f82ab7000 0x8000     0x8000     com.apple.driver.AppleSmartBatteryManager (161.0.0) 2AECFF74-DF1A-338C-BABC-39DE725DE3B9 <30 11 5 4 3 1>
   38    2 0xffffff7f81905000 0xb000     0xb000     com.apple.driver.AppleEFINVRAM (2.1) 529AA525-378A-3E1F-9BD8-19F3D7ACFE23 <36 7 6 5 4 3 2 1>
   39    3 0xffffff7f80bec000 0x9a000    0x9a000    com.apple.iokit.IOUSBFamily (900.4.1) 616CA05C-34A4-393E-8A17-93C7FC67BBDF <19 12 7 5 4 3 1>
   40    0 0xffffff7f8164e000 0x5000     0x5000     com.apple.driver.usb.AppleUSBHostPacketFilter (1.0) 8D179FD3-0359-3296-A6EF-45303F6DE8CC <19 7 6 5 4 3 1>
   41    1 0xffffff7f81505000 0x41000    0x41000    com.apple.driver.usb.AppleUSBXHCI (1.1) A3AEBA01-C5CC-3478-960E-620C58FDD6F7 <19 11 7 5 4 3 1>
   42    0 0xffffff7f8154c000 0x2d000    0x2d000    com.apple.driver.usb.AppleUSBXHCIPCI (1.1) 6BBD2ED9-E37F-3330-841A-831D458613CB <41 19 12 11 7 5 4 3 1>
   43    1 0xffffff7f82fec000 0xb000     0xb000     com.apple.driver.AppleIntelLpssGspi (3.0.60) 181C062F-B834-35A7-899D-034D7C5E939C <12 11 7 5 4 3>
   44    1 0xffffff7f8300d000 0xa000     0xa000     com.apple.driver.AppleIntelLpssI2C (3.0.60) 0C9DCD18-9FED-363B-9893-C77B876E6063 <12 11 7 5 4 3>
   45    4 0xffffff7f82fcb000 0x8000     0x8000     com.apple.driver.AppleIntelLpssDmac (3.0.60) CC87B7B0-B1AB-3084-979F-66967FA9CEF3 <12 11 5 4 3>
   46    1 0xffffff7f83017000 0x19000    0x19000    com.apple.driver.AppleIntelLpssI2CController (3.0.60) D9149887-88AE-32F0-BD7E-2B24F54F1662 <45 44 11 7 5 4 3>
   47    6 0xffffff7f8171e000 0xea000    0xea000    com.apple.iokit.IOThunderboltFamily (6.5.6) 35C44B63-5D7B-38FE-9655-0D6DAB2229CD <5 4 3 1>
   48    0 0xffffff7f8309e000 0xe000     0xe000     com.apple.driver.AppleHPM (3.0.9) 7EAF54AE-2AC3-3D4B-9AE8-77D2310450F1 <47 46 11 5 4 3 1>
   49    0 0xffffff7f829b3000 0x1d000    0x1d000    com.apple.driver.AppleThunderboltNHI (4.5.3) 031DD493-1F5A-3E48-8B0C-AA6BE2FB8BE6 <47 12 11 6 5 4 3 1>
   50    2 0xffffff7f81bd6000 0x29000    0x29000    com.apple.driver.corecapture (1.0.4) C269B594-3CE8-3AC8-AC81-ADDCC1C9074A <7 6 5 4 3 1>
   51    7 0xffffff7f813ec000 0x2d000    0x2d000    com.apple.iokit.IONetworkingFamily (3.2) 6326DB88-5330-3F0C-91F6-D478AB5E7503 <7 6 5 4 3 1>
   52    1 0xffffff7f81c08000 0x8000     0x8000     com.apple.driver.mDNSOffloadUserClient (1.0.1b8) D94E3C3A-2977-37BD-872A-9F07AC1310C8 <51 4 3 1>
   53    1 0xffffff7f81c10000 0xe6000    0xe6000    com.apple.iokit.IO80211Family (1200.12.2) D678720C-68BC-35DE-B9A2-97D8A0A6E916 <51 50 22 9 7 6 5 4 3 1>
   54    0 0xffffff7f81d00000 0x7bd000   0x7bd000   com.apple.driver.AirPort.Brcm4360 (1150.9.1a2) 70F61B13-755A-3D7B-B356-C7F310D75AA2 <53 52 51 50 12 7 6 5 4 3 1>
   55    0 0xffffff7f81910000 0x34000    0x34000    com.apple.iokit.IONVMeFamily (2.1.0) CF5F20D9-F8D5-3753-9F8A-F6BE0ED3A01D <38 22 16 15 12 7 6 5 4 3 1>
   56    1 0xffffff7f82ff7000 0x14000    0x14000    com.apple.driver.AppleIntelLpssSpiController (3.0.60) DACC2150-D583-3BA7-A9E5-67E6039D7C79 <45 43 11 5 4 3>
   57    1 0xffffff7f8307b000 0x17000    0x17000    com.apple.driver.AppleHSSPISupport (49) D0CEF220-8473-3914-A524-77659C4AA707 <56 11 5 4 3 1>
   58    0 0xffffff7f80af9000 0x2b000    0x2b000    com.apple.iokit.IOSCSIArchitectureModelFamily (394.50.1) 82139727-96EE-3990-B7E3-950D3F9799F5 <6 5 4 3 1>
   64    0 0xffffff7f829a1000 0x5000     0x5000     com.apple.driver.AppleThunderboltPCIDownAdapter (2.1.2) 7F24773F-C4EB-3C65-AA68-97396119588F <47 12 5 4 3 1>
   65    1 0xffffff7f829f2000 0x10000    0x10000    com.apple.driver.AppleThunderboltDPAdapterFamily (5.0.2) 5F867CCE-311D-3E36-B2B1-83D6FBF65DF3 <47 11 5 4 3 1>
   66    0 0xffffff7f82a1c000 0x6000     0x6000     com.apple.driver.AppleThunderboltDPInAdapter (5.0.2) AD4F2FF4-5051-3C80-8EEE-FA7ED7BDA995 <65 47 5 4 3 1>
   67    0 0xffffff7f83095000 0x9000     0x9000     com.apple.driver.AppleHSSPIHIDDriver (49) AC0BB7ED-34EF-316B-BA9D-6C7310338181 <57 34 5 4 3 1>
   68    1 0xffffff7f828ea000 0x12000    0x12000    com.apple.driver.AppleInputDeviceSupport (76.6) 8F0D13B2-A27E-3EC1-B948-0A919E731FE5 <5 4 3 1>
   69    1 0xffffff7f828ff000 0x36000    0x36000    com.apple.driver.AppleMultitouchDriver (368.14) 49DC0F0C-AB4D-3EE7-8B0C-F24C89167797 <68 34 15 7 5 4 3 1>
   70    0 0xffffff7f8294b000 0xa000     0xa000     com.apple.driver.AppleTopCaseHIDEventDriver (114) E9D4B570-08A9-3403-97D9-C9D7367AFF64 <69 34 6 5 4 3 1>
   71    0 0xffffff7f8293d000 0xa000     0xa000     com.apple.driver.AppleHIDKeyboard (199) FDE5FF00-45B5-3460-BC9A-ED934B50A1AE <34 5 4 3>
   72    2 0xffffff7f81653000 0x4000     0x4000     com.apple.driver.AppleUSBHostMergeProperties (1.1) A34E051F-4159-3DD3-AF90-4A21331C8F1E <4 3 1>
   73    3 0xffffff7f81657000 0x8000     0x8000     com.apple.driver.usb.AppleUSBHostCompositeDevice (1.1) 2F817338-A6EC-34D6-8776-3B21E8C901FC <19 5 4 3 1>
   74    4 0xffffff7f82869000 0x8000     0x8000     com.apple.driver.usb.networking (5.0.0) 3389A3F9-A0CE-3E20-A6AC-0F667AE39B57 <19 5 4 3 1>
   75    3 0xffffff7f82871000 0x9000     0x9000     com.apple.driver.usb.cdc (5.0.0) 2A794684-2709-317B-8A2E-50780486594E <74 73 19 5 4 3 1>
   76    0 0xffffff7f8289e000 0x5000     0x5000     com.apple.driver.usb.AppleUSBiBridge (1.0) E004EB5F-D179-36AD-91AF-F0393CF784AB <19 7 6 5 4 3 1>
   77    0 0xffffff7f80dd4000 0x4b000    0x4b000    at.obdev.nke.LittleSnitch (4718) 715E9654-C3FB-39A4-9514-C770F749EE8E <7 5 4 3 1>
   78    1 0xffffff7f82689000 0x7000     0x7000     com.apple.filesystems.hfs.encodings.kext (1) 18EED417-E0C7-3AE6-8EBB-CB081566B738 <7 6 5 4 3 1>
   79    0 0xffffff7f82690000 0x69000    0x69000    com.apple.filesystems.hfs.kext (366.50.19) 0DD51F29-270C-3A03-8125-A68E4D5AB22B <78 7 6 5 4 3 1>
   80    0 0xffffff7f82802000 0xa000     0xa000     com.apple.BootCache (40) 06D08FFE-3FB9-37A0-A0AE-BDDCDA4184D6 <7 6 5 4 3 1>
   81    0 0xffffff7f833c7000 0x6000     0x6000     com.apple.AppleFSCompression.AppleFSCompressionTypeZlib (1.0.0) A8B584B1-03DF-3780-923B-4FD6FF942049 <6 4 3 2 1>
   82    0 0xffffff7f833cf000 0x3000     0x3000     com.apple.AppleFSCompression.AppleFSCompressionTypeDataless (1.0.0d1) 13DD449C-FA18-3584-92A1-F91CAED7746A <7 6 4 3 2 1>
   84    0 0xffffff7f82706000 0xdc000    0xdc000    com.apple.driver.CoreStorage (540.30.1) 0E033F13-4AF3-38EB-966E-7FACAAFA222D <16 7 6 5 4 3 1>
   86    0 0xffffff7f8287a000 0xf000     0xf000     com.apple.driver.usb.cdc.ncm (5.0.0) 4FD9B634-CB1A-382F-BC9A-0543E8C9082E <75 74 73 51 19 5 4 3 1>
   87    6 0xffffff7f8121b000 0xe000     0xe000     com.apple.iokit.IOSerialFamily (11) 272855EE-C816-329B-927C-383C40F83F1A <7 6 5 4 3 1>
   90   18 0xffffff7f80eb8000 0x3c000    0x3c000    com.apple.iokit.IOGraphicsFamily (514.10) E197EF14-F55B-3B9C-B903-91258C9CA382 <12 7 5 4 3 1>
   91    1 0xffffff7f82b4a000 0xf000     0xf000     com.apple.driver.AppleSMBusController (1.0.18d1) C90534F9-E82B-347A-B4CB-9D3303F4653C <30 12 11 5 4 3>
   92    6 0xffffff7f81241000 0x1a000    0x1a000    com.apple.driver.AppleSMC (3.1.9) 28A9D81B-DBAE-3C07-8C48-C9450F7B90C6 <12 11 7 5 4 3 1>
   93    0 0xffffff7f82b5c000 0xe000     0xe000     com.apple.driver.AppleMCCSControl (1.3.1) 2C85AB9D-DB18-3E02-9327-E93D419CAFED <92 91 90 12 11 7 5 4 3 1>
   94    3 0xffffff7f8194a000 0x10000    0x10000    com.apple.iokit.IONDRVSupport (514.10) 79375D6E-7C89-3F2B-8AE2-186CAE5C2801 <90 12 7 5 4 3>
   95    1 0xffffff7f8338c000 0x5000     0x5000     com.apple.driver.AppleBacklightExpert (1.1.0) D25516DE-78B7-3C89-915C-447DEDAEFA56 <94 92 90 12 5 4 3>
   99    0 0xffffff7f829d5000 0x13000    0x13000    com.apple.driver.AppleThunderboltIP (3.0.8) 25237AB0-13B7-3D9A-8C6F-074B0A9394B1 <51 47 12 5 4 3 1>
  100    3 0xffffff7f82c1b000 0x90000    0x90000    com.apple.iokit.IOAcceleratorFamily2 (311.11) 41BE9F49-4998-3297-9EF6-9972DD38B09E <90 12 7 6 5 4 3 1>
  101    4 0xffffff7f82cba000 0xa000     0xa000     com.apple.AppleGraphicsDeviceControl (3.14.41) 781CA97C-27C8-35C2-BDF3-44C535394021 <7 6 5 4 3 1>
  102    0 0xffffff7f82cc6000 0x1cb000   0x1cb000   com.apple.driver.AppleIntelSKLGraphicsFramebuffer (10.2.4) AC8B18BD-271B-3170-BA8C-8D41466A9C4A <101 100 90 15 12 11 7 6 5 4 3 1>
  104    1 0xffffff7f82fd3000 0x13000    0x13000    com.apple.driver.AppleIntelLpssUARTCommon (3.0.60) F7DDC3FA-7D65-3FD5-9216-093C8FFDAF24 <87 45 12 11 7 5 4 3 1>
  105    0 0xffffff7f82fe8000 0x4000     0x4000     com.apple.driver.AppleIntelLpssUARTv1 (3.0.60) 74354B60-B201-3B52-B189-4463CBDCFA90 <104 87 45 12 11 7 5 4 3 1>
  106    4 0xffffff7f818ab000 0xa000     0xa000     com.apple.driver.IOPlatformPluginFamily (6.0.0d8) 15B66A1C-63D8-3415-9635-A10039B4F0D1 <11 7 6 5 4 3>
  107    1 0xffffff7f818b5000 0x17000    0x17000    com.apple.driver.X86PlatformPlugin (1.0.0) 4D7C495F-B088-3BC7-BE0B-86C0E7978CC0 <106 92 39 19 11 7 6 5 4 3 1>
  110    0 0xffffff7f833dc000 0x6000     0x6000     com.apple.driver.AppleEmbeddedOSSupportHost (1) 9E94B445-9B8F-3797-A3E0-2D29D1D4FCAD <11 6 5 4 3 1>
  111    1 0xffffff7f81845000 0x5000     0x5000     com.apple.iokit.IOSlowAdaptiveClockingFamily (1.0.0) CE7B6D9D-0577-3683-8410-CA8707BBDA4B <7 6 5 4 3 1>
  112    0 0xffffff7f82c17000 0x2000     0x2000     com.apple.driver.AppleIntelSlowAdaptiveClocking (4.0.0) 6FE984DD-A1FE-309E-83CF-B346989A6F17 <111 4 3>
  113    2 0xffffff7f80f2e000 0x95000    0x95000    com.apple.vecLib.kext (1.2.0) C0ABF85C-CA30-3F02-9E1E-06F3BA5047A8 <8 6 5 4 3>
  114    7 0xffffff7f80fc3000 0x3f000    0x3f000    com.apple.iokit.IOAudioFamily (205.15) 62BD3696-A3B8-3938-B01D-8F6CE2AFD1D5 <113 5 4 3 1>
  115    2 0xffffff7f830ca000 0xc000     0xc000     com.apple.iokit.IOHDAFamily (279.48) E332A19C-33F1-3F25-B9FC-982F769BF17A <5 4 3 1>
  116    1 0xffffff7f830dd000 0x1d000    0x1d000    com.apple.driver.AppleHDAController (279.48) ED51F180-19C8-3DE1-AF81-0E389D98ADDE <115 114 90 12 7 6 5 4 3 1>
  117    0 0xffffff7f8125d000 0x7000     0x7000     com.apple.driver.SMCMotionSensor (3.0.4d1) E693702A-F3B3-37EC-B28D-7DC5C623655D <92 5 4 3>
  118    2 0xffffff7f83389000 0x3000     0x3000     com.apple.driver.AppleGraphicsControl (3.14.41) 36E87B0A-B4FB-3072-AFF8-29BA084E38D8 <7 5 4 3 1>
  119    0 0xffffff7f83391000 0x15000    0x15000    com.apple.driver.AppleMuxControl (3.14.41) 7D69C554-B5D7-364C-8C83-096AD30B49FF <118 95 90 12 11 7 6 5 4 3 1>
  120    0 0xffffff7f814fa000 0xb000     0xb000     com.apple.driver.usb.IOUSBHostHIDDevice (1.1) 6282D225-42BD-3742-A5CB-97A769B3B4AE <34 19 5 4 3 1>
  121    0 0xffffff7f82b3d000 0x4000     0x4000     com.apple.driver.AppleOSXWatchdog (1) 9B1AC3B0-A459-3D88-B43D-428EA39DDB8A <12 7 6 5 4 3 1>
  123    2 0xffffff7f83548000 0x156000   0x156000   com.apple.kext.AMDSupport (1.5.0) 429D49FB-7C8C-3D8A-AE21-F828F3899754 <101 90 12 11 7 5 4 3 1>
  124    0 0xffffff7f83f55000 0x1dc000   0x1dc000   com.apple.kext.AMD9510Controller (1.5.0) 69437314-9593-3CF8-9D3B-1D3C99ED2444 <123 90 12 11 5 4 3 1>
  125    0 0xffffff7f82fc6000 0x3000     0x3000     com.apple.driver.AppleIntelPCHPMC (1.1) E7CFE09B-8A79-3A2C-A942-43F81011A557 <106 12 5 4 3>
  126    0 0xffffff7f8306b000 0xa000     0xa000     com.apple.driver.AppleHV (1) 86C220DD-F35A-304C-A5AC-35D7EC4FDC90 <7 6 5 4 3 1>
  127    2 0xffffff7f81827000 0x18000    0x18000    com.apple.iokit.IOSurface (159.6) 85BD985C-2B78-3C1A-9606-6A6B0CB77E24 <7 6 5 4 3 1>
  128    0 0xffffff7f82ebb000 0xc6000    0xc6000    com.apple.driver.AppleIntelSKLGraphics (10.2.4) 14FFDBC7-2133-3040-973F-06C23621069F <127 100 90 12 7 6 5 4 3 1>
  129    0 0xffffff7f82aa4000 0xa000     0xa000     com.apple.driver.AppleSSE (1.0) D88AFA94-440B-3316-ACFE-407133893EF0 <20 7 5 4 3 1>
  130    0 0xffffff7f836ad000 0x76e000   0x76e000   com.apple.kext.AMDRadeonX4100 (1.5.0) AA5D6413-A7E3-3230-B1E1-F3D761005FDB <127 100 90 12 7 5 4 3 1>
  131    0 0xffffff7f82700000 0x5000     0x5000     com.apple.Dont_Steal_Mac_OS_X (7.0.0) 7B7DB739-3DAA-3E7A-BA9E-38C3256D15B6 <92 9 7 4 3 1>
  132    0 0xffffff7f830c6000 0x2000     0x2000     com.apple.driver.AppleHIDALSService (1) 3F30A46A-E6EA-3E9D-B9E9-1FADDC938FDC <19 4 3>
  133    2 0xffffff7f81a12000 0xe4000    0xe4000    com.apple.iokit.IOBluetoothFamily (5.0.4f18) 478E889D-01B6-38B1-8731-B9FF92D8BCF3 <15 7 5 4 3 1>
  134    0 0xffffff7f81a02000 0xa000     0xa000     com.apple.iokit.IOBluetoothSerialManager (5.0.4f18) 6B32977C-5658-31A3-ABC3-4B860318B49D <87 7 5 4 3 1>
  135    0 0xffffff7f81420000 0x6000     0x6000     com.apple.iokit.IOUserEthernet (1.0.1) 32E2019A-799D-3E86-9F40-7D9AB4500A9D <51 6 5 4 3 1>
  136    0 0xffffff7f83f1a000 0x27000    0x27000    com.apple.kext.AMDFramebuffer (1.5.0) 26FC86CE-635B-349C-9333-6386F0C78741 <123 90 12 11 7 5 4 3 1>
  137    0 0xffffff7f81365000 0xf000     0xf000     com.apple.driver.pmtelemetry (1) 963D5479-A74A-35FA-AFAA-6D61989DAD4D <7 6 5 4 3>
  138    0 0xffffff7f81237000 0x5000     0x5000     com.Cycling74.driver.Soundflower (1.6.6) 34C01614-4A29-C12F-C1EB-6278397B5BFE <114 5 4 3>
  139    0 0xffffff7f8100a000 0x4000     0x4000     com.globaldelight.driver.Boom2Device (1.1) 7F7523A6-5BE4-3452-9713-BBC88EA4BED3 <114 5 4 3 1>
  140    0 0xffffff7f828e1000 0x5000     0x5000     com.apple.driver.AppleUpstreamUserClient (3.6.4) F39509A4-191C-35DA-B7D9-08F95E5AB8BC <90 12 11 7 5 4 3 1>
  141    0 0xffffff7f80f00000 0x7000     0x7000     com.kairos.driver.DuetDisplay (2) 16A01CC6-F7E5-369E-B07D-DEE78FE2F41B <90 5 4 3>
  142    0 0xffffff7f833af000 0x13000    0x13000    com.apple.driver.AppleGraphicsDevicePolicy (3.14.41) 20BE8882-6D0C-3F92-AFE3-80F0E44AB5AF <118 101 90 12 11 7 6 5 4 3 1>
  143    1 0xffffff7f81b0a000 0xb000     0xb000     com.apple.iokit.IOBluetoothHostControllerTransport (5.0.4f18) AD9E2FF8-6B37-3DE9-B1FE-E143239FD783 <133 19 12 11 7 6 5 4 3 1>
  144    0 0xffffff7f81b15000 0x7000     0x7000     com.apple.iokit.IOBluetoothHostControllerUARTTransport (5.0.4f18) E379BA62-67F6-3BCB-9FC3-92FDD288E0AD <143 133 87 12 11 5 4 3>
  145    1 0xffffff7f830fa000 0x13000    0x13000    com.apple.kext.OSvKernDSPLib (525) D0421B4D-7B97-3102-BC42-3684344DB5E6 <5 4>
  146    1 0xffffff7f8310d000 0x147000   0x147000   com.apple.driver.DspFuncLib (279.48) F6771373-D27C-36AA-B87E-5038F235C536 <145 114 113 38 6 5 4 3 1>
  147    0 0xffffff7f8325f000 0xb5000    0xb5000    com.apple.driver.AppleHDA (279.48) 806B8C17-50CA-3C6B-90B3-195F38D8FB89 <146 116 115 114 94 90 6 5 4 3 1>
  149    0 0xffffff7f8281e000 0x5000     0x5000     com.apple.driver.AudioAUUC (1.70) DA1CA792-7C22-3F41-B64E-4E01C8679031 <114 90 12 11 7 5 4 3 1>
  150    0 0xffffff7f84225000 0x7000     0x7000     com.parallels.virtualsound (1.0.36 36) E9131806-D073-8482-AC46-B4AAE55EA6FE <114 5 4 3 1>
  151    0 0xffffff7f80a22000 0x7000     0x7000     expressvpn.tun (1.0) 95DD963D-E23D-3B0F-8DE8-A4D2F6BFA5CC <7 5 4 1>
  152    1 0xffffff7f818cc000 0x7000     0x7000     com.apple.driver.X86PlatformShim (1.0.0) D6D4635C-98C0-31C0-AE82-20D003A58ECF <107 106 92 7 4 3>
  153    0 0xffffff7f82b36000 0x4000     0x4000     com.apple.driver.ApplePlatformEnabler (2.7.0d0) 24BC0CD9-98BD-380E-BA21-3599C1B3B4A9 <7 5 4 3>
  154    0 0xffffff7f83368000 0x18000    0x18000    com.apple.driver.AGPM (110.23.17) 3E92E313-274C-3175-A659-2CB88F03A707 <106 101 94 90 12 6 5 4 3>
  155    1 0xffffff7f8280e000 0x5000     0x5000     com.apple.kext.triggers (1.0) 3EAB29BE-4C7C-3D6C-B20B-B48707426005 <7 6 5 4 3 1>
  156    0 0xffffff7f82813000 0x9000     0x9000     com.apple.filesystems.autofs (3.0) E79E1801-8AB8-3BB1-A1F2-3CA5F9C7C648 <155 7 6 5 4 3 1>
  157    0 0xffffff7f8422c000 0x5000     0x5000     com.parallels.virtualhid (1.0.3 3) B0C355DF-4268-359B-9654-0A67F4305F7B <34 5 4 3 1>
  162    0 0xffffff7f84231000 0x7000     0x7000     com.apple.driver.TestDeviceVCOMACMData (1.0.0) 278263C6-906F-35FA-91F8-9022DDA028C6 <87 39 5 4 3>
  163    0 0xffffff7f84238000 0xc000     0xc000     com.apple.driver.usb.cdc.ecm (5.0.0) DC848CD0-9C23-3E14-AD6F-206BB325A523 <75 74 72 51 19 5 4 3 1>
  164    0 0xffffff7f84244000 0xe000     0xe000     com.apple.driver.usb.cdc.acm (5.0.0) 609779D5-B27E-3307-BBE5-86335226D235 <87 75 74 73 19 5 4 3 1>
  165    0 0xffffff7f84252000 0x3000     0x3000     com.apple.driver.AppleUSBMergeNub (900.4.1) 7A70FBD3-A00F-3EFE-9FD7-3305D997A62A <72 39 4 3 1>
----FPS Report Legend:-----
Raw Instantaneous FPS:
    30FPS delimiter:    '|'
    10FPS delimiter:    '+'
    1FPS delimiter:     '-'
Defer+Work Instantaneous FPS:                'X'
Work Instantaneous FPS:                      '^'
Equal Work and Defer+Work Instantaneous FPS: '*'
====Frame Rate Report:====
   Frame Length [SampleRange] WS Wait Length [SampleRange]   Defer Length [SampleRange] WS Work Length [SampleRange]      Frame Rate
         2.66 ms[ No samples]         0.00 ms[ No samples]         1.67 ms[ No samples]         0.99 ms[ No samples]      376.01 FPS|---------+---------+---------|---------+---------+---------*
        16.98 ms[ No samples]         5.73 ms[ No samples]         9.90 ms[ No samples]         1.35 ms[ No samples]       58.89 FPS|---------+---------+---------|---------+---------+---------*
        17.68 ms[ No samples]         0.34 ms[ No samples]        15.98 ms[ No samples]         1.36 ms[ No samples]       56.57 FPS|---------+---------+---------|---------+---------+-------X ^
        16.82 ms[ No samples]         0.17 ms[ No samples]        15.02 ms[ No samples]         1.63 ms[ No samples]       59.45 FPS|---------+---------+---------|---------+---------+---------*
        15.08 ms[ No samples]         4.11 ms[ No samples]        10.01 ms[ No samples]         0.96 ms[ No samples]       66.32 FPS|---------+---------+---------|---------+---------+---------*
        17.89 ms[      2    ]         9.74 ms[      2    ]         6.88 ms[ No samples]         1.28 ms[ No samples]       55.89 FPS|---------+---------+---------|---------+---------+------   *
        16.22 ms[ No samples]         0.25 ms[ No samples]        14.27 ms[ No samples]         1.70 ms[ No samples]       61.65 FPS|---------+---------+---------|---------+---------+---------*
        16.73 ms[ No samples]         3.92 ms[ No samples]        11.25 ms[ No samples]         1.56 ms[ No samples]       59.77 FPS|---------+---------+---------|---------+---------+---------*
        17.23 ms[ No samples]         7.85 ms[ No samples]         8.04 ms[ No samples]         1.35 ms[ No samples]       58.03 FPS|---------+---------+---------|---------+---------+-------- *
        16.72 ms[ No samples]         0.68 ms[ No samples]        14.37 ms[ No samples]         1.68 ms[ No samples]       59.80 FPS|---------+---------+---------|---------+---------+---------*
        15.86 ms[ No samples]         2.87 ms[ No samples]        11.93 ms[ No samples]         1.07 ms[ No samples]       63.03 FPS|---------+---------+---------|---------+---------+---------*
        16.90 ms[      3    ]         5.52 ms[ No samples]        10.12 ms[      3    ]         1.25 ms[ No samples]       59.19 FPS|---------+---------+---------|---------+---------+---------*
        16.79 ms[ No samples]         0.13 ms[ No samples]        15.22 ms[ No samples]         1.45 ms[ No samples]       59.54 FPS|---------+---------+---------|---------+---------+---------*
        16.40 ms[ No samples]         1.14 ms[ No samples]        13.86 ms[ No samples]         1.40 ms[ No samples]       60.98 FPS|---------+---------+---------|---------+---------+---------*
        16.11 ms[ No samples]         4.89 ms[ No samples]        10.15 ms[ No samples]         1.07 ms[ No samples]       62.07 FPS|---------+---------+---------|---------+---------+---------*
WS Idle: 123.80ms
       133.83 ms[      4    ]       123.80 ms[      4    ]         9.03 ms[ No samples]         1.00 ms[ No samples]        7.47 FPS                                                            *
        33.28 ms[      5    ]        19.11 ms[      5    ]        13.29 ms[ No samples]         0.89 ms[ No samples]       30.04 FPS|---------+---------+---------|                             *
Model: MacBookPro13,3, BootROM MBP133.0226.B15, 4 processors, Intel Core i7, 2.9 GHz, 16 GB, SMC 2.38f7
Graphics: Intel HD Graphics 530, Intel HD Graphics 530, Built-In
Graphics: Radeon Pro 460, AMD Radeon Pro 460, PCIe, 4096 MB
Memory Module: BANK 0/DIMM0, 8 GB, LPDDR3, 2133 MHz, 0x80CE, 0x4B3445424533303445422D45474347202020
Memory Module: BANK 1/DIMM0, 8 GB, LPDDR3, 2133 MHz, 0x80CE, 0x4B3445424533303445422D45474347202020
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x15A), Broadcom BCM43xx 1.0 (7.21.171.124.1a2)
Bluetooth: Version 5.0.4f18, 3 services, 17 devices, 1 incoming serial ports
Network Service: Thunderbolt FireWire, FireWire, fw0
Network Service: Wi-Fi, AirPort, en0
USB Device: USB 3.0 Bus
USB Device: iPhone
USB Device: iBridge
Thunderbolt Bus: MacBook Pro, Apple Inc., 15.12
Apr 01, 2017 Apr 01, 2017
Thanks, I have started to look at the sync function on LR mobile and like several aspects. I was able to sync the photos from my phone into LR desktop.
Do you know if it can detect and avoid duplicates that are already in the catalog (similar to the import function)?
A major issue with the sync method is that I typically rename all photos that I import into LR from SD cards, mobile devices etc. The renaming comprises the capture date as yyyy-mm-dd format which is appended to the original capture file name so img1234 becomes 2017-04-01_img1234. Each photo is also placed into a named subfolder according to the capture date. This previously happened during the import dialog easily with a renaming preset and subfolder check box that I checked.
To my understanding, syncing between LR mobile and LR on desktop does not apply any file naming. I have found that I can rename batches of photos after they are synched using the rename function in the LR Library drop down menu, but I cannot move batches of photos simply into multiple folders which are arranged by capture date within the LR program (I would have to do this manually for each capture date).
Any suggestions?
Adobe Employee ,
Apr 03, 2017 Apr 03, 2017
Hi Kunwar,
Thanks for share the logs with us. We are looking at them. Meanwhile, could you share the crash log via the dialog that appears after the crash. When you share the logs that to Apple that way, we get more details.
Here is what the dialog should be:
Please click OK and follow the next dialog.
Smit | Lightroom Classic Team
LR  seems to delay indefinitely on the "importing files.... screenshot (see below)" without ever importing them rather than crash. I can still access the program. I end up cancelling the import by either quitting the LR or the import dialog (bottom screenshot)
Hope this helps.
Kunwar
Screen Shot 2017-04-04 at 7.18.08 AM.pngScreen Shot 2017-04-04 at 7.18.44 AM.pngScreen Shot 2017-04-04 at 7.20.04 AM.png
I
Apr 04, 2017 Apr 04, 2017
Looking at your folder structure there is one very strange thing, which is that you have a volumes subfolder at your hard disk's root level with 86k pictures in it. This is probably an external disk that is somehow mounted in the wrong location. It should have its own header at the same level as "Macintosh HD". Can you try unmounting this hard disk and importing to your internal hard disk in your pictures folder? These hangs might be caused by a bad connection to your external disk. I would also run disk utility repair on that disk. Is it at least formatted hfs+ and not some windows format?
Apr 05, 2017 Apr 05, 2017
Thanks. Not sure why this appears like this. Just to clarify, I have an external hard disk with 88K pictures (>500GB) and the LR catalog for this is on my MBP internal disk. I typically import any new photos from my iPhone or camera SD card directly to the internal disk initially (including with import renaming dialogue at this stage), then cull and edit them, and finally export them to the external disk. The import step used to happen smoothly with no glitches. I cannot keep the actual photos (mostly RAWs) on my internal disk as there is not enough disk space. So I only perform edits of old archived photos when my external hard disk is reconnected (by cable).
I will check if I can resolve this quirk and get back to you. I will check the file format for the hard disk but I am pretty sure it is Mac format or FAT32.  Please be patient as I am quite busy in the next few days.
I would like to add that I usually "move" the photos for archiving from within the LR program (perhaps not technically an "export" in LR lexicon) so that LR links to the photos are maintained.  The folder naming structure of the archived photos is the same on both the internal and external disk, namely "  YYYY-MM-DD".
Apr 08, 2017 Apr 08, 2017
HI again,
I tried to import 4 photos from my iPhone to a new folder on my MBP internal disk into a completely new catalog. The import failed again, and as before the LR program displayed the importing dialog indefinitely without actually importing. I had to cancel the import process by pressing the little cross on the right side of the import progress bar, and then the program became unresponsive so I had to Force Quit to close  LR.
Below is the dialog that appeared that stated that I forced LR to quit.
Date/Time:       2017-04-08 21:42:48 +0100
OS Version:      Mac OS X 10.12.4 (Build 16E195)
Architecture:    x86_64h
Report Version:  25
Data Source:     Stackshots
Command:         Adobe Lightroom
Path:            /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/MacOS/Adobe Lightroom
Version:         Adobe Lightroom [1106920] (6.9)
Parent:          launchd [1]
PID:             99846
Event:           hang
Duration:        1.00s (process was unresponsive for 177 seconds before sampling)
Steps:           10 (100ms sampling interval)
Hardware model:  MacBookPro13,3
Active cpus:     8
Fan speed:       2160 rpm
Timeline format: stacks are sorted chronologically
Use -i and -heavy to re-report with count sorting
Heaviest stack for the main thread of the target process:
  10  start + 1 (libdyld.dylib + 21045) [0x7fffe55cd235]
  10  main + 1095 (Adobe Lightroom + 7079) [0x10a0a2ba7]
  10  NSApplicationMain + 1237 (AppKit + 25054) [0x7fffcd9261de]
  10  -[NSApplication run] + 926 (AppKit + 243627) [0x7fffcd95b7ab]
  10  -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 963 (AppKit + 8134965) [0x7fffce0e2135]
  10  _DPSEventHandledByCarbon + 54 (AppKit + 4463082) [0x7fffcdd619ea]
  10  _NSHandleCarbonMenuEvent + 239 (AppKit + 1865528) [0x7fffcdae7738]
  10  _HandleMenuSelection2 + 460 (HIToolbox + 614246) [0x7fffcf430f66]
  10  MenuSelectCore(MenuData*, Point, double, unsigned int, OpaqueMenuRef**, unsigned short*) + 702 (HIToolbox + 615095) [0x7fffcf4312b7]
  10  FinishMenuSelection(SelectionData*, MenuResult*, MenuResult*) + 96 (HIToolbox + 612477) [0x7fffcf43087d]
  10  SendMenuItemSelectedEvent + 188 (HIToolbox + 612778) [0x7fffcf4309aa]
  10  SendMenuCommandWithContextAndModifiers + 59 (HIToolbox + 612859) [0x7fffcf4309fb]
  10  SendHICommandEvent(unsigned int, HICommand const*, unsigned int, unsigned int, unsigned char, void const*, OpaqueEventTargetRef*, OpaqueEventTargetRef*, OpaqueEventRef**) + 411 (HIToolbox + 435174) [0x7fffcf4053e6]
  10  SendEventToEventTarget + 40 (HIToolbox + 122132) [0x7fffcf3b8d14]
  10  SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 428 (HIToolbox + 32758) [0x7fffcf3a2ff6]
  10  DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1708 (HIToolbox + 36229) [0x7fffcf3a3d85]
  10  NSSLMMenuEventHandler + 986 (AppKit + 1931600) [0x7fffcdaf7950]
  10  -[NSCarbonMenuImpl _carbonCommandProcessEvent:handlerCallRef:] + 107 (AppKit + 3279421) [0x7fffcdc40a3d]
  10  -[NSMenu _internalPerformActionForItemAtIndex:] + 94 (AppKit + 3279888) [0x7fffcdc40c10]
  10  -[NSMenu performActionForItemAtIndex:] + 121 (AppKit + 3280025) [0x7fffcdc40c99]
  10  _os_activity_initiate_impl + 53 (libsystem_trace.dylib + 13223) [0x7fffe57ff3a7]
  10  -[NSCarbonMenuImpl performActionWithHighlightingForItemAtIndex:] + 114 (AppKit + 2717454) [0x7fffcdbb770e]
  10  -[NSMenuItem _corePerformAction] + 324 (AppKit + 2718114) [0x7fffcdbb79a2]
  10  -[NSApplication(NSResponder) sendAction:to:from:] + 456 (AppKit + 8144785) [0x7fffce0e4791]
  10  -[NSApplication terminate:] + 1662 (AppKit + 2390933) [0x7fffcdb67b95]
  10  -[NSNotificationCenter postNotificationName:object:userInfo:] + 66 (Foundation + 27031) [0x7fffd1860997]
  10  _CFXNotificationPost + 604 (CoreFoundation + 366044) [0x7fffcfe3c5dc]
  10  -[_CFXNotificationRegistrar find:object:observer:enumerator:] + 1827 (CoreFoundation + 370083) [0x7fffcfe3d5a3]
  10  ___CFXNotificationPost_block_invoke + 50 (CoreFoundation + 643442) [0x7fffcfe80172]
  10  _CFXRegistrationPost + 427 (CoreFoundation + 644107) [0x7fffcfe8040b]
  10  __CFNOTIFICATIONCENTER_IS_CALLING_OUT_TO_AN_OBSERVER__ + 12 (CoreFoundation + 644364) [0x7fffcfe8050c]
  10  ??? (Adobe Lightroom + 15032) [0x10a0a4ab8]
  10  ??? (<B5A2691C-C7C2-3F81-8F41-3BF90D4BF6DB> + 422445) [0x10a31322d]
  10  ??? (<EA22D365-4FEB-3119-AA45-4A0814D2A1A5> + 81416) [0x10a3b1e08]
  10  ??? (<552408AE-9F72-3E5A-8157-7690BEBAEC93> + 8433) [0x10a2620f1]
  10  ??? (<552408AE-9F72-3E5A-8157-7690BEBAEC93> + 41185) [0x10a26a0e1]
  10  ??? (<552408AE-9F72-3E5A-8157-7690BEBAEC93> + 99677) [0x10a27855d]
  10  ??? (<552408AE-9F72-3E5A-8157-7690BEBAEC93> + 40469) [0x10a269e15]
  10  ??? (<552408AE-9F72-3E5A-8157-7690BEBAEC93> + 16070) [0x10a263ec6]
  10  ??? (<552408AE-9F72-3E5A-8157-7690BEBAEC93> + 8562) [0x10a262172]
  10  ??? (<552408AE-9F72-3E5A-8157-7690BEBAEC93> + 41789) [0x10a26a33d]
  10  ??? (<552408AE-9F72-3E5A-8157-7690BEBAEC93> + 38782) [0x10a26977e]
  10  ??? (<552408AE-9F72-3E5A-8157-7690BEBAEC93> + 135929) [0x10a2812f9]
  10  ??? (<552408AE-9F72-3E5A-8157-7690BEBAEC93> + 133207) [0x10a280857]
  10  ??? (<552408AE-9F72-3E5A-8157-7690BEBAEC93> + 159188) [0x10a286dd4]
  10  __psynch_cvwait + 10 (libsystem_kernel.dylib + 105458) [0x7fffe56fbbf2]
*10  psynch_cvcontinue + 0 (pthread + 38973) [0xffffff7f8135f83d]
Process:         Adobe Lightroom (Lightroom) [99846]
Parent:          launchd [1]
UID:             503
Task size:       1041.00 MB
Note:            Unresponsive for 177 seconds before sampling
Note:            2 idle work queue threads omitted
  Thread 0x259f60           DispatchQueue 1           Thread name "CrBrowserMain"                         10 samples (1-10)         priority 42 (base 42)
  <process frontmost, process unclamped, process received importance donation from WindowServer [198], process received importance donation from icdd [459], process received importance donation from EmojiFunctionRowIM_Extension [585], IO tier 0>
  10  start + 1 (libdyld.dylib + 21045) [0x7fffe55cd235] 1-10
    10  main + 1095 (Adobe Lightroom + 7079) [0x10a0a2ba7] 1-10
      10  NSApplicationMain + 1237 (AppKit + 25054) [0x7fffcd9261de] 1-10
        10  -[NSApplication run] + 926 (AppKit + 243627) [0x7fffcd95b7ab] 1-10
          10  -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 963 (AppKit + 8134965) [0x7fffce0e2135] 1-10
            10  _DPSEventHandledByCarbon + 54 (AppKit + 4463082) [0x7fffcdd619ea] 1-10
              10  _NSHandleCarbonMenuEvent + 239 (AppKit + 1865528) [0x7fffcdae7738] 1-10
                10  _HandleMenuSelection2 + 460 (HIToolbox + 614246) [0x7fffcf430f66] 1-10
                  10  MenuSelectCore(MenuData*, Point, double, unsigned int, OpaqueMenuRef**, unsigned short*) + 702 (HIToolbox + 615095) [0x7fffcf4312b7] 1-10
                    10  FinishMenuSelection(SelectionData*, MenuResult*, MenuResult*) + 96 (HIToolbox + 612477) [0x7fffcf43087d] 1-10
                      10  SendMenuItemSelectedEvent + 188 (HIToolbox + 612778) [0x7fffcf4309aa] 1-10
                        10  SendMenuCommandWithContextAndModifiers + 59 (HIToolbox + 612859) [0x7fffcf4309fb] 1-10
                          10  SendHICommandEvent(unsigned int, HICommand const*, unsigned int, unsigned int, unsigned char, void const*, OpaqueEventTargetRef*, OpaqueEventTargetRef*, OpaqueEventRef**) + 411 (HIToolbox + 435174) [0x7fffcf4053e6] 1-10
                            10  SendEventToEventTarget + 40 (HIToolbox + 122132) [0x7fffcf3b8d14] 1-10
                              10  SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 428 (HIToolbox + 32758) [0x7fffcf3a2ff6] 1-10
                                10  DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1708 (HIToolbox + 36229) [0x7fffcf3a3d85] 1-10
                                  10  NSSLMMenuEventHandler + 986 (AppKit + 1931600) [0x7fffcdaf7950] 1-10
                                    10  -[NSCarbonMenuImpl _carbonCommandProcessEvent:handlerCallRef:] + 107 (AppKit + 3279421) [0x7fffcdc40a3d] 1-10
                                      10  -[NSMenu _internalPerformActionForItemAtIndex:] + 94 (AppKit + 3279888) [0x7fffcdc40c10] 1-10
                                        10  -[NSMenu performActionForItemAtIndex:] + 121 (AppKit + 3280025) [0x7fffcdc40c99] 1-10
                                          10  _os_activity_initiate_impl + 53 (libsystem_trace.dylib + 13223) [0x7fffe57ff3a7] 1-10
                                            10  -[NSCarbonMenuImpl performActionWithHighlightingForItemAtIndex:] + 114 (AppKit + 2717454) [0x7fffcdbb770e] 1-10
                                              10  -[NSMenuItem _corePerformAction] + 324 (AppKit + 2718114) [0x7fffcdbb79a2] 1-10
                                                10  -[NSApplication(NSResponder) sendAction:to:from:] + 456 (AppKit + 8144785) [0x7fffce0e4791] 1-10
                                                    10  -[NSApplication terminate:] + 1662 (AppKit + 2390933) [0x7fffcdb67b95] 1-10
                                                      10  -[NSNotificationCenter postNotificationName:object:userInfo:] + 66 (Foundation + 27031) [0x7fffd1860997] 1-10
                                                        10  _CFXNotificationPost + 604 (CoreFoundation + 366044) [0x7fffcfe3c5dc] 1-10
                                                          10  -[_CFXNotificationRegistrar find:object:observer:enumerator:] + 1827 (CoreFoundation + 370083) [0x7fffcfe3d5a3] 1-10
                                                            10  ___CFXNotificationPost_block_invoke + 50 (CoreFoundation + 643442) [0x7fffcfe80172] 1-10
                                                              10  _CFXRegistrationPost + 427 (CoreFoundation + 644107) [0x7fffcfe8040b] 1-10
        10  __CFNOTIFICATIONCENTER_IS_CALLING_OUT_TO_AN_OBSERVER__ + 12 (CoreFoundation + 644364) [0x7fffcfe8050c] 1-10
        10  ??? (Adobe Lightroom + 15032) [0x10a0a4ab8] 1-10
        10  ??? (<B5A2691C-C7C2-3F81-8F41-3BF90D4BF6DB> + 422445) [0x10a31322d] 1-10
        10  ??? (<EA22D365-4FEB-3119-AA45-4A0814D2A1A5> + 81416) [0x10a3b1e08] 1-10
        10  ??? (<552408AE-9F72-3E5A-8157-7690BEBAEC93> + 8433) [0x10a2620f1] 1-10
        10  ??? (<552408AE-9F72-3E5A-8157-7690BEBAEC93> + 41185) [0x10a26a0e1] 1-10
        10  ??? (<552408AE-9F72-3E5A-8157-7690BEBAEC93> + 99677) [0x10a27855d] 1-10
        10  ??? (<552408AE-9F72-3E5A-8157-7690BEBAEC93> + 40469) [0x10a269e15] 1-10
        10  ??? (<552408AE-9F72-3E5A-8157-7690BEBAEC93> + 16070) [0x10a263ec6] 1-10
        10  ??? (<552408AE-9F72-3E5A-8157-7690BEBAEC93> + 8562) [0x10a262172] 1-10
        10  ??? (<552408AE-9F72-3E5A-8157-7690BEBAEC93> + 41789) [0x10a26a33d] 1-10
        10  ??? (<552408AE-9F72-3E5A-8157-7690BEBAEC93> + 38782) [0x10a26977e] 1-10
        10  ??? (<552408AE-9F72-3E5A-8157-7690BEBAEC93> + 135929) [0x10a2812f9] 1-10
        10  ??? (<552408AE-9F72-3E5A-8157-7690BEBAEC93> + 133207) [0x10a280857] 1-10
        10  ??? (<552408AE-9F72-3E5A-8157-7690BEBAEC93> + 159188) [0x10a286dd4] 1-10
        10  __psynch_cvwait + 10 (libsystem_kernel.dylib + 105458) [0x7fffe56fbbf2] 1-10
        *10  psynch_cvcontinue + 0 (pthread + 38973) [0xffffff7f8135f83d] 1-10
  Thread 0x261d8e           DispatchQueue 1034        10 samples (1-10)         priority 31 (base 31)
  <process frontmost, thread QoS default (requested default), process unclamped, process received importance donation from WindowServer [198], process received importance donation from icdd [459], process received importance donation from EmojiFunctionRowIM_Extension [585], IO tier 0>
  10  start_wqthread + 13 (libsystem_pthread.dylib + 12529) [0x7fffe57e60f1] 1-10
    10  _pthread_wqthread + 1299 (libsystem_pthread.dylib + 13846) [0x7fffe57e6616] 1-10
      10  _dispatch_worker_thread3 + 99 (libdispatch.dylib + 13452) [0x7fffe559948c] 1-10
        10  _dispatch_root_queue_drain + 476 (libdispatch.dylib + 14005) [0x7fffe55996b5] 1-10
          10  _dispatch_queue_invoke + 1046 (libdispatch.dylib + 41734) [0x7fffe55a0306] 1-10
            10  _dispatch_queue_serial_drain + 896 (libdispatch.dylib + 96672) [0x7fffe55ad9a0] 1-10
              10  _dispatch_client_callout + 8 (libdispatch.dylib + 6396) [0x7fffe55978fc] 1-10
                10  _dispatch_call_block_and_release + 12 (libdispatch.dylib + 42276) [0x7fffe55a0524] 1-10
                  10  -[ICCommandCenter handleNotificationEvent:] + 147 (ImageCaptureCore + 19104) [0x7fffd1e62aa0] 1-10
                    10  ICPerformBlockOnMainThread + 356 (ImageCaptureCore + 25642) [0x7fffd1e6442a] 1-10
                      10  _dispatch_semaphore_wait_slow + 103 (libdispatch.dylib + 43153) [0x7fffe55a0891] 1-10
                        10  semaphore_wait_trap + 10 (libsystem_kernel.dylib + 74630) [0x7fffe56f4386] 1-10
                         *10  semaphore_wait_continue + 0 (kernel + 1118912) [0xffffff80003112c0] 1-10
  Thread 0x259fee           Thread name "cr_scratch"  10 samples (1-10)         priority 31 (base 31)
  10  thread_start + 13 (libsystem_pthread.dylib + 12545) [0x7fffe57e6101] 1-10
    10  _pthread_start + 286 (libsystem_pthread.dylib + 14587) [0x7fffe57e68fb] 1-10
      10  _pthread_body + 180 (libsystem_pthread.dylib + 14767) [0x7fffe57e69af] 1-10
        10  ??? (<4B9A5DA2-7880-31B3-851B-29BC2A27E8E1> + 1426945) [0x110fb7601] 1-10
          10  ??? (<4B9A5DA2-7880-31B3-851B-29BC2A27E8E1> + 3847323) [0x11120649b] 1-10
            10  ??? (<4B9A5DA2-7880-31B3-851B-29BC2A27E8E1> + 1660747) [0x110ff074b] 1-10
  Thread 0x25a044           Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 31 (base 31)
        10  __NSThread__start__ + 1243 (Foundation + 207821) [0x7fffd188cbcd] 1-10
          10  +[NSURLConnection(Loader) _resourceLoadLoop:] + 313 (CFNetwork + 26116) [0x7fffcefa8604] 1-10
            10  CFRunLoopRunSpecific + 420 (CoreFoundation + 553412) [0x7fffcfe6a1c4] 1-10
              10  __CFRunLoopRun + 1361 (CoreFoundation + 555377) [0x7fffcfe6a971] 1-10
                10  __CFRunLoopServiceMachPort + 212 (CoreFoundation + 558308) [0x7fffcfe6b4e4] 1-10
                  10  mach_msg_trap + 10 (libsystem_kernel.dylib + 74570) [0x7fffe56f434a] 1-10
                   *10  ipc_mqueue_receive_continue + 0 (kernel + 862304) [0xffffff80002d2860] 1-10
  Thread 0x25a047           Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 47 (base 47)
  <process frontmost, thread QoS user interactive (requested user interactive), process unclamped, process received importance donation from WindowServer [198], process received importance donation from icdd [459], process received importance donation from EmojiFunctionRowIM_Extension [585], IO tier 0>
        10  _NSEventThread + 205 (AppKit + 1655506) [0x7fffcdab42d2] 1-10
  Thread 0x25a056           Thread name "com.apple.CFSocket.private"            10 samples (1-10)         priority 47 (base 47)
        10  __select + 10 (libsystem_kernel.dylib + 106166) [0x7fffe56fbeb6] 1-10
         *10  ??? (kernel + 5801776) [0xffffff8000788730] 1-10
  Thread 0x25a057           10 samples (1-10)         priority 31 (base 31)
        10  ??? (<2116CCCF-BA38-366C-8BCE-91827BA52E6D> + 1403241) [0x114891969] 1-10
          10  ??? (<2116CCCF-BA38-366C-8BCE-91827BA52E6D> + 867579) [0x11480ecfb] 1-10
            10  ??? (<2116CCCF-BA38-366C-8BCE-91827BA52E6D> + 1069145) [0x114840059] 1-10
              10  ??? (<2116CCCF-BA38-366C-8BCE-91827BA52E6D> + 1406447) [0x1148925ef] 1-10
                10  ??? (<2116CCCF-BA38-366C-8BCE-91827BA52E6D> + 1412300) [0x114893ccc] 1-10
  Thread 0x25a296           10 samples (1-10)         priority 31 (base 31)
        10  ??? (<D9194969-C41E-37DF-A816-9CFA013C632B> + 6085) [0x1154bd7c5] 1-10
          10  ??? (<45892F28-4EF2-3FB8-9EF9-129C7C2E6B87> + 1229830) [0x1170d3406] 1-10
            10  ??? (<45892F28-4EF2-3FB8-9EF9-129C7C2E6B87> + 1243704) [0x1170d6a38] 1-10
              10  ??? (<45892F28-4EF2-3FB8-9EF9-129C7C2E6B87> + 1255128) [0x1170d96d8] 1-10
                10  MPWaitOnQueue + 192 (CarbonCore + 510752) [0x7fffd0d77b20] 1-10
                  10  TSWaitOnConditionTimedRelative + 171 (CarbonCore + 670108) [0x7fffd0d9e99c] 1-10
                    10  TSWaitOnCondition + 108 (CarbonCore + 669597) [0x7fffd0d9e79d] 1-10
  Thread 0x25a297           10 samples (1-10)         priority 31 (base 31)
          10  ??? (<12E3207D-9B3A-37A8-B20F-8D584742797E> + 105673) [0x117486cc9] 1-10
            10  ??? (<12E3207D-9B3A-37A8-B20F-8D584742797E> + 107314) [0x117487332] 1-10
              10  ??? (<12E3207D-9B3A-37A8-B20F-8D584742797E> + 178264) [0x117498858] 1-10
                10  ??? (<12E3207D-9B3A-37A8-B20F-8D584742797E> + 179436) [0x117498cec] 1-10
                  10  kevent + 10 (libsystem_kernel.dylib + 109974) [0x7fffe56fcd96] 1-10
                   *10  ??? (kernel + 5627984) [0xffffff800075e050] 1-10
  Thread 0x25a2a4           10 samples (1-10)         priority 31 (base 31)
        10  ??? (<12E3207D-9B3A-37A8-B20F-8D584742797E> + 182371) [0x117499863] 1-10
          10  ??? (<12E3207D-9B3A-37A8-B20F-8D584742797E> + 177658) [0x1174985fa] 1-10
              10  ??? (<12E3207D-9B3A-37A8-B20F-8D584742797E> + 179595) [0x117498d8b] 1-10
  Thread 0x25a2a5           10 samples (1-10)         priority 31 (base 31)
  Thread 0x25a2a6           10 samples (1-10)         priority 31 (base 31)
  Thread 0x25a2a7           10 samples (1-10)         priority 31 (base 31)
  Thread 0x25b9d1           Thread name "Protected Background Thread"           10 samples (1-10)         priority 31 (base 31)
          10  ??? (<EA22D365-4FEB-3119-AA45-4A0814D2A1A5> + 78703) [0x10a3b136f] 1-10
                        10  ??? (<EA22D365-4FEB-3119-AA45-4A0814D2A1A5> + 130233) [0x10a3bdcb9] 1-10
                            10  ??? (<552408AE-9F72-3E5A-8157-7690BEBAEC93> + 41168) [0x10a26a0d0] 1-10
                                                            10  ??? (<35D1FB78-7295-3206-BD04-6A6245227F6B> + 16468) [0x114581054] 1-10
                                                              10  ??? (<35D1FB78-7295-3206-BD04-6A6245227F6B> + 8149) [0x11457efd5] 1-10
        10  -[NSCondition wait] + 240 (Foundation + 208171) [0x7fffd188cd2b] 1-10
  Thread 0x260cb1           10 samples (1-10)         priority 31 (base 31)
        10  ??? (<7E427337-65A2-3B49-AD70-9C9BE02F4C01> + 8346379) [0x1224d8b0b] 1-10
          10  ??? (<7E427337-65A2-3B49-AD70-9C9BE02F4C01> + 15832063) [0x122bfc3ff] 1-10
  Thread 0x262dcb           10 samples (1-10)         priority 31 (base 31)
*10  wq_unpark_continue + 0 (pthread + 15190) [0xffffff7f81359b56] 1-10
  Binary Images:
           0x10a0a1000 -        0x10a0bcfff  com.adobe.Lightroom6 Adobe Lightroom [1106920] (6.9) <7A685660-150F-3A23-B64A-6AEE19D3D338>  /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/MacOS/Adobe Lightroom
           0x10a260000 -                ???  ???                                                  <552408AE-9F72-3E5A-8157-7690BEBAEC93>
           0x10a2ac000 -                ???  ???                                                  <B5A2691C-C7C2-3F81-8F41-3BF90D4BF6DB>
           0x10a39e000 -                ???  ???                                                  <EA22D365-4FEB-3119-AA45-4A0814D2A1A5>
           0x110e5b000 -                ???  ???                                                  <4B9A5DA2-7880-31B3-851B-29BC2A27E8E1>
           0x11457d000 -                ???  ???                                                  <35D1FB78-7295-3206-BD04-6A6245227F6B>
           0x11473b000 -                ???  ???                                                  <2116CCCF-BA38-366C-8BCE-91827BA52E6D>
           0x1154bc000 -                ???  ???                                                  <D9194969-C41E-37DF-A816-9CFA013C632B>
           0x116fa7000 -                ???  ???                                                  <45892F28-4EF2-3FB8-9EF9-129C7C2E6B87>
           0x11746d000 -                ???  ???                                                  <12E3207D-9B3A-37A8-B20F-8D584742797E>
           0x121ce3000 -                ???  ???                                                  <7E427337-65A2-3B49-AD70-9C9BE02F4C01>
        0x7fffcd920000 -     0x7fffce6f9fff  com.apple.AppKit 6.9 (1504.82.104)                   <C295FF09-9984-34C3-953B-B263EF2107AB>  /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
        0x7fffcefa2000 -     0x7fffcf37cfff  com.apple.CFNetwork 811.4.18 (811.4.18)              <9CE329E8-6177-3474-976D-F5C63FC875CD>  /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
        0x7fffcf39b000 -     0x7fffcf6a4fff  com.apple.HIToolbox 2.1.1 (857.8)                    <40254D9A-E477-3F33-B2A2-807D399BF71C>  /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
        0x7fffcfde3000 -     0x7fffd027cfff  com.apple.CoreFoundation 6.9 (1349.65)               <F79384D1-FA3F-38CA-A847-B2625EBB790E>  /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
        0x7fffd0cfb000 -     0x7fffd0fd6fff  com.apple.CoreServices.CarbonCore 1159.6 (1159.6)    <08AC074C-965B-3EDF-8E45-0707C8DE9EAD>  /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
        0x7fffd185a000 -     0x7fffd1c00fff  com.apple.Foundation 6.9 (1349.64)                   <49C8DA40-9E5B-33F9-B092-F50115B59E95>  /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
        0x7fffd1e5e000 -     0x7fffd1eaffff  com.apple.ImageCaptureCore 7.0 (7.0)                 <22A35555-6025-3EB8-993B-B91141668C6A>  /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
        0x7fffe5596000 -     0x7fffe55c7fff  libdispatch.dylib (703.50.37)                        <D122E712-9593-31CA-BAC4-4A54410BF4A0>  /usr/lib/system/libdispatch.dylib
        0x7fffe55c8000 -     0x7fffe55cdfff  libdyld.dylib (433.5)                                <129D3B44-FB21-3750-9A68-48B5C3DC632B>  /usr/lib/system/libdyld.dylib
        0x7fffe56e2000 -     0x7fffe5704fff  libsystem_kernel.dylib (3789.51.2)                   <FC51D7B0-8292-3F6A-9231-64340B237EB7>  /usr/lib/system/libsystem_kernel.dylib
        0x7fffe57e3000 -     0x7fffe57edfff  libsystem_pthread.dylib (218.51.1)                   <62A84A68-431D-3B54-A7B6-31367CCF2884>  /usr/lib/system/libsystem_pthread.dylib
        0x7fffe57fc000 -     0x7fffe580ffff  libsystem_trace.dylib (518.51.1)                     <E1D540D8-CC88-3901-92BA-FC4B802FE0E8>  /usr/lib/system/libsystem_trace.dylib
   *0xffffff7f81356000 - 0xffffff7f81361fff  com.apple.kec.pthread 1.0 (1)                        <4EFF2F70-C9B9-3176-BF83-F1B660C42135>  /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread
Process:         2BUA8C4S2C.com.agilebits.onepassword4-helper (1Password mini) [96773]
Path:            /Applications/1Password 6.app/Contents/Library/LoginItems/2BUA8C4S2C.com.agilebits.onepassword4-helper.app/Contents/MacOS/2BUA8C4S2C.com.agilebits.onepassword4-helper
Parent:          launchd [1]
UID:             503
Sudden Term:     Tracked
Task size:       19.84 MB
Process:         AccessMenuBarApps (☯) [1690]
Path:            /Applications/AccessMenuBarApps.app/Contents/MacOS/AccessMenuBarApps
Parent:          launchd [1]
UID:             503
Task size:       69.68 MB
Process:         accountsd [361]
Path:            /System/Library/Frameworks/Accounts.framework/Versions/A/Support/accountsd
Parent:          launchd [1]
UID:             503
Sudden Term:     Tracked (allows idle exit)
Task size:       16.12 MB
Note:            3 idle work queue threads omitted
  Thread 0xca0              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
  <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2>
    10  ??? (accountsd + 2602) [0x10da97a2a] 1-10
  Thread 0x26ef             Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x10da97000 -        0x10da97fff  accountsd (640.0.19)                    <C9C497BB-575F-31BA-B4EF-4108EB9389D5>  /System/Library/Frameworks/Accounts.framework/Versions/A/Support/accountsd
Process:         Activity Monitor [688]
Path:            /Applications/Utilities/Activity Monitor.app/Contents/MacOS/Activity Monitor
Parent:          launchd [1]
UID:             503
Task size:       373.21 MB
CPU Time:        <0.001
Note:            7 idle work queue threads omitted
  Thread 0x25c4e9           DispatchQueue 1           10 samples (1-10)         priority 46 (base 46)     cpu time <0.001
  <thread QoS user interactive (requested user interactive), process sudden termination clean, process unclamped, IO tier 0>
        10  -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 2796 (AppKit + 8136798) [0x7fffce0e285e] 1-10
          10  _DPSNextEvent + 1120 (AppKit + 290340) [0x7fffcd966e24] 1-10
            10  _BlockUntilNextEventMatchingListInModeWithFilter + 71 (HIToolbox + 199462) [0x7fffcf3cbb26] 1-10
              10  ReceiveNextEventCommon + 432 (HIToolbox + 199921) [0x7fffcf3cbcf1] 1-10
                10  RunCurrentEventLoopInMode + 240 (HIToolbox + 200380) [0x7fffcf3cbebc] 1-10
                         *7  ipc_mqueue_receive_continue + 0 (kernel + 862304) [0xffffff80002d2860] 1-7
  <process clamped>
                         *3  ipc_mqueue_receive_continue + 0 (kernel + 862304) [0xffffff80002d2860] 8-10
  Thread 0x25c62e           Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 46 (base 46)
  <process clamped>
  Thread 0x262df5           10 samples (1-10)         priority 31 (base 31)
  <process sudden termination clean, process unclamped, IO tier 0>
*7  wq_unpark_continue + 0 (pthread + 15190) [0xffffff7f81359b56] 1-7
  <process clamped>
*3  wq_unpark_continue + 0 (pthread + 15190) [0xffffff7f81359b56] 8-10
  Binary Images:
           0x107db3000 -        0x107e10fff  com.apple.ActivityMonitor 10.12 (968)  <24EC9622-8762-354D-B253-C56D902C8C69>  /Applications/Utilities/Activity Monitor.app/Contents/MacOS/Activity Monitor
Process:         Adobe CEF Helper [97708]
Path:            /Library/Application Support/Adobe/*/Adobe CEF Helper.app/Contents/MacOS/Adobe CEF Helper
Parent:          Creative Cloud [97699]
Responsible:     Creative Cloud [97699]
UID:             503
Task size:       12.22 MB
Process:         Adobe CEF Helper [97716]
UID:             503
Task size:       85.82 MB
CPU Time:        <0.001
Process:         Adobe Desktop Service [97717]
Path:            /Library/Application Support/Adobe/*/Adobe Desktop Service.app/Contents/MacOS/Adobe Desktop Service
Architecture:    i386
Parent:          launchd [1]
UID:             503
Task size:       35.70 MB
CPU Time:        <0.001
Process:         Adobe Installer [97824]
Path:            /Library/Application Support/Adobe/*/Adobe Installer
Architecture:    i386
Parent:          Adobe Desktop Service [97717]
Responsible:     Adobe Desktop Service [97717]
UID:             0
Task size:       3272 KB
Note:            1 idle work queue threads omitted
  Thread 0x238512           DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
  <thread QoS default (requested user interactive), IO tier 0>
  10  start + 53 (Adobe Installer + 3637) [0x78e35] 1-10
    10  ??? (Adobe Installer + 21097) [0x7d269] 1-10
      10  ??? (Adobe Installer + 22574) [0x7d82e] 1-10
        10  OOBEUtils::OOBEEventsIntl::WaitforEvntIntl(long long) + 241 (Adobe Installer + 141169) [0x9a771] 1-10
          10  pthread_cond_wait$UNIX2003 + 51 (libsystem_pthread.dylib + 26988) [0xa18bb96c] 1-10
            10  __psynch_cvwait + 10 (libsystem_kernel.dylib + 111374) [0xa17d530e] 1-10
  Thread 0x238543           10 samples (1-10)         priority 31 (base 31)
  <thread QoS default (requested default), IO tier 0>
  10  <truncated backtrace> 1-10
    10  __read + 10 (libsystem_kernel.dylib + 118022) [0xa17d6d06] 1-10
     *10  hndl_unix_scall + 216 (kernel + 645688) [0xffffff800029da38] 1-10
       *10  unix_syscall + 561 (kernel + 6443777) [0xffffff8000825301] 1-10
         *10  read_nocancel + 115 (kernel + 5884291) [0xffffff800079c983] 1-10
           *10  ??? (kernel + 5884954) [0xffffff800079cc1a] 1-10
             *10  ??? (kernel + 3393726) [0xffffff800053c8be] 1-10
               *10  fifo_read + 146 (kernel + 3493906) [0xffffff8000555012] 1-10
                 *10  soreceive + 2209 (kernel + 6080001) [0xffffff80007cc601] 1-10
                   *10  sbwait + 370 (kernel + 6119186) [0xffffff80007d5f12] 1-10
                     *10  msleep + 98 (kernel + 5802402) [0xffffff80007889a2] 1-10
                       *10  ??? (kernel + 5801187) [0xffffff80007884e3] 1-10
                         *10  lck_mtx_sleep + 132 (kernel + 1026980) [0xffffff80002faba4] 1-10
                           *10  thread_block_reason + 222 (kernel + 1069422) [0xffffff800030516e] 1-10
                             *10  ??? (kernel + 1073995) [0xffffff800030634b] 1-10
                               *10  machine_switch_context + 206 (kernel + 2082766) [0xffffff80003fc7ce] 1-10
  Binary Images:
               0x78000 -            0xdffff  Adobe Installer                    <5BD75843-8372-3BB3-8399-2473FEFDA625>  /Library/Application Support/Adobe/*/Adobe Installer
            0xa17ba000 -         0xa17dbfff  libsystem_kernel.dylib (3789.51.2) <50D0E6F1-6F9C-303F-BCD6-F72AD4485B6E>  /usr/lib/system/libsystem_kernel.dylib
            0xa18b5000 -         0xa18befff  libsystem_pthread.dylib (218.51.1) <71D501C2-F2CB-32C0-86B8-70AF68ACDC5F>  /usr/lib/system/libsystem_pthread.dylib
Process:         Adobe QT32 Server [99879]
Path:            /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Helpers/DynamicLinkMediaServer/application/dynamiclinkmediaserver.app/Contents/Adobe QT32 Server.app/Contents/MacOS/Adobe QT32 Server
Architecture:    i386
Parent:          launchd [1]
UID:             503
Task size:       18.74 MB
Process:         AdobeCrashDaemon [99848]
Path:            /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashDaemon.app/Contents/MacOS/AdobeCrashDaemon
Parent:          Adobe Lightroom (Lightroom) [99846]
Responsible:     Adobe Lightroom (Lightroom) [99846]
UID:             503
Task size:       4928 KB
CPU Time:        0.003
Process:         AdobeCRDaemon [97707]
Path:            /Applications/Utilities/Adobe Creative Cloud/*/Creative Cloud.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCRDaemon.app/Contents/MacOS/AdobeCRDaemon
UID:             503
Task size:       3852 KB
CPU Time:        0.002
Process:         AdobeCRDaemon [97724]
Path:            /Library/Application Support/Adobe/*/Adobe Desktop Service.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCRDaemon.app/Contents/MacOS/AdobeCRDaemon
UID:             503
Task size:       3844 KB
CPU Time:        0.002
Process:         AdobeCRDaemon [97732]
Path:            /Applications/Utilities/Adobe Creative Cloud/*/Core Sync.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCRDaemon.app/Contents/MacOS/AdobeCRDaemon
Parent:          Core Sync [97728]
Responsible:     Core Sync [97728]
UID:             503
Task size:       3732 KB
CPU Time:        0.002
Process:         AdobeIPCBroker [97701]
Path:            /Applications/Utilities/Adobe Application Manager/*/AdobeIPCBroker.app/Contents/MacOS/AdobeIPCBroker
Architecture:    i386
Parent:          launchd [1]
UID:             503
Task size:       10.29 MB
CPU Time:        <0.001
Process:         AdobeUpdateDaemon [97693]
Path:            /Library/Application Support/Adobe/*/AdobeUpdateDaemon
Architecture:    i386
Parent:          launchd [1]
UID:             0
Task size:       2764 KB
CPU Time:        0.002
  Thread 0x2376d7           DispatchQueue 1           10 samples (1-10)         priority 20 (base 20)     cpu time 0.002
  <thread QoS utility (requested utility), timers tier 3 (coalesced), IO tier 1>
  10  start + 53 (AdobeUpdateDaemon + 5141) [0xf0415] 1-10
    10  ??? (AdobeUpdateDaemon + 8964) [0xf1304] 1-10
      10  ??? (AdobeUpdateDaemon + 8409) [0xf10d9] 1-10
        10  ??? (AdobeUpdateDaemon + 11269) [0xf1c05] 1-10
          10  CommBridgeImpl::initCommBridge(CommunicationBridge::PipeContext, std::string const&, bool, unsigned int, void (*)(void*), void*) + 3000 (AdobeUpdateDaemon + 133912) [0x10fb18] 1-10
            10  usleep$UNIX2003 + 55 (libsystem_c.dylib + 496305) [0xa17542b1] 1-10
              10  __semwait_signal + 10 (libsystem_kernel.dylib + 112370) [0xa17d56f2] 1-10
  Thread 0x23791f           10 samples (1-10)         priority 20 (base 20)
  <thread QoS utility (requested default), timers tier 3 (coalesced), IO tier 1>
  Thread 0x237920           10 samples (1-10)         priority 20 (base 20)
  Binary Images:
               0xef000 -           0x1cdfff  AdobeUpdateDaemon                  <C22014B2-3A50-373A-A899-2C67FA9B466E>  /Library/Application Support/Adobe/*/AdobeUpdateDaemon
            0xa16db000 -         0xa1769fff  libsystem_c.dylib (1158.50.2)      <2252D116-215B-3C01-A85F-0AAC10DB36CC>  /usr/lib/system/libsystem_c.dylib
Process:         AGSService [90]
Path:            /Library/Application Support/Adobe/*/AGSService
Parent:          launchd [1]
UID:             0
Task size:       10024 KB
  Thread 0x2bd              DispatchQueue 1           10 samples (1-10)         priority 20 (base 20)
  10  start + 52 (AGSService + 5412) [0x100001524] 1-10
    10  ??? (AGSService + 30627) [0x1000077a3] 1-10
      10  ??? (AGSService + 105425) [0x100019bd1] 1-10
        10  -[NSRunLoop(NSRunLoop) run] + 76 (Foundation + 140362) [0x7fffd187c44a] 1-10
          10  -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 277 (Foundation + 140658) [0x7fffd187c572] 1-10
  Thread 0x5e1              10 samples (1-10)         priority 20 (base 20)
        10  ??? (AGSService + 30325) [0x100007675] 1-10
          10  sleep + 42 (libsystem_c.dylib + 526803) [0x7fffe56829d3] 1-10
            10  __semwait_signal + 10 (libsystem_kernel.dylib + 106310) [0x7fffe56fbf46] 1-10
  Thread 0x22a4b            Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 20 (base 20)
  Thread 0x22a4d            Thread name "com.apple.CFSocket.private"            10 samples (1-10)         priority 20 (base 20)
  Binary Images:
           0x100000000 -        0x10023ffff  AGSService                              <4EE77B93-276B-3660-BC65-BB91D37D6FAF>  /Library/Application Support/Adobe/*/AGSService
        0x7fffe5602000 -     0x7fffe568ffff  libsystem_c.dylib (1158.50.2)           <B03F8915-1E9B-3C84-AED5-68E2E0031630>  /usr/lib/system/libsystem_c.dylib
Process:         AirPlayUIAgent [508]
Path:            /System/Library/CoreServices/AirPlayUIAgent.app/Contents/MacOS/AirPlayUIAgent
Parent:          launchd [1]
UID:             503
Task size:       6548 KB
  Thread 0x1422             DispatchQueue 1           10 samples (1-10)         priority 46 (base 46)
  <process clamped>
  Thread 0x14cc             Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 46 (base 46)
  <process clamped>
  Binary Images:
           0x107efe000 -        0x107f08fff  com.apple.AirPlayUIAgent 2.0 (320.18)  <3F810C5B-8F96-3408-8567-B4225FF7F76E>  /System/Library/CoreServices/AirPlayUIAgent.app/Contents/MacOS/AirPlayUIAgent
Process:         AirPlayXPCHelper [129]
Path:            /usr/libexec/AirPlayXPCHelper
Parent:          launchd [1]
UID:             0
Task size:       2088 KB (-12 KB)
  Thread 0x679              DispatchQueue 11          10 samples (1-10)         priority 20 (base 20)
    10  __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 106982) [0x7fffe56fc1e6] 1-10
  Binary Images:
           0x100424000 -        0x100425fff  AirPlayXPCHelper (320.18)          <A2A06D93-12D1-30A2-959B-6D9ED81B0205>  /usr/libexec/AirPlayXPCHelper
Process:         airportd [72]
Path:            /usr/libexec/airportd
Parent:          launchd [1]
UID:             0
Task size:       31.77 MB (-68 KB)
Note:            6 idle work queue threads omitted
  Thread 0x2f4              DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
  <thread QoS default (requested default), process sudden termination dirty, process unclamped, process received importance donation from sharingd [411], process received importance donation from WiFiProxy [443], IO tier 0>
    10  ??? (airportd + 298142) [0x10939bc9e] 1-10
  Thread 0x6fe              Thread name "com.apple.CFSocket.private"            10 samples (1-10)         priority 31 (base 31)
  Binary Images:
           0x109353000 -        0x10946efff  airportd (1200.46)                     <1A52D6C7-F435-359B-A14B-23FCB2EBFEEA>  /usr/libexec/airportd
Process:         akd [253]
Path:            /System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/Support/akd
Parent:          launchd [1]
UID:             0
Task size:       1868 KB
  Thread 0x823              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  ??? (akd + 102357) [0x104556fd5] 1-10
  Thread 0x82b              Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x10453e000 -        0x1045befff  akd (141.0.1)                          <E8D1B327-73BF-3198-9DF3-E647964A26F9>  /System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/Support/akd
Process:         akd [422]
Parent:          launchd [1]
UID:             503
Task size:       4704 KB
  Thread 0xeed              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  ??? (akd + 102357) [0x1067a6fd5] 1-10
  Thread 0xf0c              Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x10678e000 -        0x10680efff  akd (141.0.1)                          <E8D1B327-73BF-3198-9DF3-E647964A26F9>  /System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/Support/akd
Process:         amfid [130]
Path:            /usr/libexec/amfid
Parent:          launchd [1]
UID:             0
Task size:       3872 KB
  Thread 0x362              DispatchQueue 11          10 samples (1-10)         priority 31 (base 31)
  <thread QoS default (requested default), process sudden termination clean, IO tier 0>
  Binary Images:
           0x103ab7000 -        0x103abdfff  amfid (225.50.12)                  <B6C62BC3-D705-354C-9A1B-68BB01970323>  /usr/libexec/amfid
Process:         AppActivity [513]
Path:            /Users/USER/Library/Application Support/AppPolicy/AppActivity
Parent:          launchd [1]
UID:             503
Task size:       1748 KB
  Thread 0x1426             DispatchQueue 1           10 samples (1-10)         priority 20 (base 20)
  10  start + 52 (AppActivity + 4548) [0x1000011c4] 1-10
    10  main + 7127 (AppActivity + 173127) [0x10002a447] 1-10
  Thread 0x93497            Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 20 (base 20)
  Binary Images:
           0x100000000 -        0x100041fff  AppActivity                            <55420A9F-ADC1-338F-A565-DFF617E08BE6>  /Users/USER/Library/Application Support/AppPolicy/AppActivity
   *0xffffff8000200000 - 0xffffff80009fffff  kernel (3789.51.2)                     <06F94FD7-451F-34A1-B13C-D68FF7EDE0A0>  /System/Library/Kernels/kernel
Process:         apple.DevicePropertyReader [99936]
Path:            /System/Library/Image Capture/Devices/PTPCamera.app/Contents/XPCServices/apple.DevicePropertyReader.xpc/Contents/MacOS/apple.DevicePropertyReader
Parent:          launchd [1]
Responsible:     PTPCamera [99933]
UID:             503
Task size:       2972 KB
  Thread 0x25a6fa           DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
  10  _dispatch_sig_thread + 41 (libdispatch.dylib + 62031) [0x7fffe55a524f] 1-10
  Binary Images:
           0x102635000 -        0x102636fff  com.apple.DevicePropertyReader 1.0 (1) <8F1632CD-59B4-31A2-94CB-C1DB2BDE17EB>  /System/Library/Image Capture/Devices/PTPCamera.app/Contents/XPCServices/apple.DevicePropertyReader.xpc/Contents/MacOS/apple.DevicePropertyReader
Process:         appleeventsd [57]
Path:            /System/Library/CoreServices/appleeventsd
Parent:          launchd [1]
UID:             55
Task size:       3608 KB
  Thread 0x511              DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
  <thread QoS background (requested default), thread darwinbg, process darwinbg, IO tier 2>
  Binary Images:
           0x10de30000 -        0x10de30fff  appleeventsd (712.5)               <04BA7041-9063-3F04-B0BB-5DE3ECB6C013>  /System/Library/CoreServices/appleeventsd
Process:         AppleIDAuthAgent [417]
Path:            /System/Library/CoreServices/AppleIDAuthAgent
Parent:          launchd [1]
UID:             503
Task size:       6984 KB
  Thread 0xee9              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  ??? (AppleIDAuthAgent + 10824) [0x10a8eca48] 1-10
      10  CFRunLoopRun + 97 (CoreFoundation + 814129) [0x7fffcfea9c31] 1-10
  Thread 0xef7              10 samples (1-10)         priority 4 (base 4)
  <thread QoS background (requested default, override user initiated), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2>
    10  semaphore_timedwait_trap + 10 (libsystem_kernel.dylib + 74654) [0x7fffe56f439e] 1-10
  Thread 0x1753             10 samples (1-10)         priority 4 (base 4)
  Thread 0x17bc             Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x10a8ea000 -        0x10a92dfff  AppleIDAuthAgent (775.19)              <B4035FFE-7812-3E21-B2F5-02CEBDFC8171>  /System/Library/CoreServices/AppleIDAuthAgent
Process:         AppleSpell [1232]
Path:            /System/Library/Services/AppleSpell.service/Contents/MacOS/AppleSpell
Parent:          launchd [1]
UID:             503
Task size:       39.84 MB
  Thread 0x2f10             DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
  <thread QoS default (requested default), process sudden termination dirty, IO tier 0>
    10  ??? (AppleSpell + 8648) [0x10f4c91c8] 1-10
      10  -[NSSpellServer run] + 73 (Foundation + 2086692) [0x7fffd1a57724] 1-10
  Binary Images:
           0x10f4c7000 -        0x10f5c6fff  com.apple.AppleSpell 2.4 (389)         <00AE3ABF-3C83-33BF-8A49-17C38946F37F>  /System/Library/Services/AppleSpell.service/Contents/MacOS/AppleSpell
Process:         AppStatus [520]
Path:            /Users/USER/Library/Application Support/AppCommon/AppStatus
Parent:          launchd [1]
UID:             503
Task size:       3184 KB
  Thread 0x142b             DispatchQueue 1           10 samples (1-10)         priority 20 (base 20)
  10  start + 52 (AppStatus + 6948) [0x100001b24] 1-10
    10  main + 12591 (AppStatus + 451647) [0x10006e43f] 1-10
  Thread 0x5384             Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 20 (base 20)
  Thread 0x5387             Thread name "com.apple.CFSocket.private"            10 samples (1-10)         priority 20 (base 20)
  Binary Images:
           0x100000000 -        0x1000dafff  AppStatus                              <EC2E7301-9F78-3D8A-8C20-9FE1079414B4>  /Users/USER/Library/Application Support/AppCommon/AppStatus
Process:         apsd [101]
Path:            /System/Library/PrivateFrameworks/ApplePushService.framework/apsd
Parent:          launchd [1]
UID:             0
Task size:       11.01 MB
  Thread 0x2c2              DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
    10  ??? (apsd + 389558) [0x1094c21b6] 1-10
  Thread 0x118f             Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 31 (base 31)
  Thread 0x23dd             Thread name "com.apple.CFSocket.private"            10 samples (1-10)         priority 31 (base 31)
  Binary Images:
           0x109463000 -        0x10952dfff  apsd (305.1)                            <818B3867-774D-3408-B919-7F6346DAD6EA>  /System/Library/PrivateFrameworks/ApplePushService.framework/apsd
Process:         ARDAgent [368]
Path:            /System/Library/CoreServices/RemoteManagement/ARDAgent.app/Contents/MacOS/ARDAgent
Parent:          launchd [1]
UID:             503
Task size:       2212 KB
  Thread 0xcdf              DispatchQueue 1           10 samples (1-10)         priority 20 (base 20)
    10  ??? (ARDAgent + 6081) [0x103a617c1] 1-10
  Thread 0xdfe              10 samples (1-10)         priority 20 (base 20)
  Thread 0xe00              10 samples (1-10)         priority 97 (base 97)
  <thread QoS utility, timers tier 3 (coalesced), IO tier 1>
  Thread 0xe57              10 samples (1-10)         priority 20 (base 20)
  Thread 0xe58              10 samples (1-10)         priority 20 (base 20)
  Thread 0xe59              10 samples (1-10)         priority 20 (base 20)
    10  __accept + 10 (libsystem_kernel.dylib + 102594) [0x7fffe56fb0c2] 1-10
     *10  hndl_unix_scall64 + 22 (kernel + 646470) [0xffffff800029dd46] 1-10
       *10  unix_syscall64 + 597 (kernel + 6444693) [0xffffff8000825695] 1-10
         *10  accept_nocancel + 482 (kernel + 6133394) [0xffffff80007d9692] 1-10
  Binary Images:
           0x103a60000 -        0x103b63fff  com.apple.RemoteDesktopAgent 3.9.2 (3.9.2) <57C03F35-34ED-3521-ACD3-4B6A76423EAD>  /System/Library/CoreServices/RemoteManagement/ARDAgent.app/Contents/MacOS/ARDAgent
Process:         askpermissiond [426]
Path:            /System/Library/PrivateFrameworks/AskPermission.framework/Versions/A/Resources/askpermissiond
Parent:          launchd [1]
UID:             503
Task size:       1224 KB
  Thread 0xef2              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  ??? (askpermissiond + 52455) [0x102126ce7] 1-10
  Binary Images:
           0x10211a000 -        0x102134fff  askpermissiond (78)                    <1A812667-3249-33DD-B3AE-9F2C2E054177>  /System/Library/PrivateFrameworks/AskPermission.framework/Versions/A/Resources/askpermissiond
Process:         aslmanager [160]
Path:            /usr/sbin/aslmanager
Parent:          launchd [1]
UID:             0
Task size:       1780 KB
  Thread 0x382              DispatchQueue 11          10 samples (1-10)         priority 31 (base 31)
  <thread QoS default (requested default), process sudden termination clean, IO tier 3>
  Binary Images:
           0x10f10c000 -        0x10f115fff  aslmanager (349.50.5)              <3D79D9F7-A61E-33FB-A878-611D0123F7FA>  /usr/sbin/aslmanager
Process:         aslmanager [98287]
Parent:          launchd [1]
UID:             0
Task size:       600 KB
  Thread 0x241494           10 samples (1-10)         priority 20 (base 20)
  <thread QoS utility (requested default), process sudden termination clean, timers tier 3 (coalesced), IO tier 3>
  Binary Images:
           0x100ecb000 -        0x100ed4fff  aslmanager (349.50.5)              <3D79D9F7-A61E-33FB-A878-611D0123F7FA>  /usr/sbin/aslmanager
Process:         AssetCache [377]
Path:            /usr/libexec/AssetCache/AssetCache
Parent:          launchd [1]
UID:             235
Task size:       1960 KB
  Thread 0xd13              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  ??? (AssetCache + 6119) [0x10518f7e7] 1-10
      10  ??? (AssetCache + 76716) [0x1051a0bac] 1-10
        10  ??? (AssetCache + 79432) [0x1051a1648] 1-10
  Binary Images:
           0x10518e000 -        0x1054bffff  AssetCache (170)                       <192D7EAD-1094-3C68-A51A-C1CF04899F1A>  /usr/libexec/AssetCache/AssetCache
Process:         AssetCacheLocatorService [1042]
Path:            /System/Library/PrivateFrameworks/AssetCacheServices.framework/Versions/A/XPCServices/AssetCacheLocatorService.xpc/Contents/MacOS/AssetCacheLocatorService
Parent:          launchd [1]
UID:             503
Task size:       1464 KB
  Thread 0x21a6             DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  main + 71 (AssetCacheLocatorService + 34884) [0x104c7c844] 1-10
      10  -[AssetCacheLocatorService start] + 626 (AssetCacheLocatorService + 57455) [0x104c8206f] 1-10
  Binary Images:
           0x104c74000 -        0x104caefff  com.apple.AssetCacheLocatorService 48.3 (48.3) <6FD939E9-7C1D-37B8-9DB8-8850F5E1D431>  /System/Library/PrivateFrameworks/AssetCacheServices.framework/Versions/A/XPCServices/AssetCacheLocatorService.xpc/Contents/MacOS/AssetCacheLocatorService
Process:         assistant_service [1174]
Path:            /System/Library/PrivateFrameworks/AssistantServices.framework/assistant_service
Parent:          launchd [1]
UID:             503
Task size:       8164 KB
  Thread 0x26c3             DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  ??? (assistant_service + 5509) [0x1004d1585] 1-10
  Binary Images:
           0x1004d0000 -        0x1004dafff  assistant_service (1394.57)            <5740FA7A-C79C-3B98-B9B9-411330E05521>  /System/Library/PrivateFrameworks/AssistantServices.framework/assistant_service
Process:         assistantd [475]
Path:            /System/Library/PrivateFrameworks/AssistantServices.framework/assistantd
Parent:          launchd [1]
UID:             503
Task size:       11.71 MB
  Thread 0x123e             DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  ??? (assistantd + 31052) [0x105ff594c] 1-10
      10  ??? (assistantd + 32861) [0x105ff605d] 1-10
  Thread 0x2641             Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4 (base 4)
  Thread 0x264f             Thread name "com.apple.CFStream.LegacyThread"       10 samples (1-10)         priority 4 (base 4)
  Thread 0x17453b           Thread name "AVVC Rec Queue RunLoop"                10 samples (1-10)         priority 4 (base 4)
  <thread QoS background, process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2>
  Binary Images:
           0x105fee000 -        0x106397fff  assistantd (1394.57)                   <F039C269-B2F8-3262-9E6A-085B0BDDC644>  /System/Library/PrivateFrameworks/AssistantServices.framework/assistantd
Process:         auditd [1857]
Path:            /usr/sbin/auditd
Parent:          launchd [1]
UID:             0
Task size:       1692 KB
  Thread 0x2623c2           DispatchQueue 1           10 samples (1-10)         priority 20 (base 20)
    10  ??? (auditd + 11592) [0x101090d48] 1-10
      10  mach_msg_server + 441 (libsystem_kernel.dylib + 73867) [0x7fffe56f408b] 1-10
  Binary Images:
           0x10108e000 -        0x101091fff  auditd (34)                        <C5A51C96-F78E-3DB7-88E1-78736E4161F5>  /usr/sbin/auditd
Process:         authd [162]
Path:            /System/Library/Frameworks/Security.framework/Versions/A/XPCServices/authd.xpc/Contents/MacOS/authd
Parent:          launchd [1]
UID:             0
Task size:       3372 KB
  Thread 0x3b9              DispatchQueue 10          10 samples (1-10)         priority 4 (base 4)
  <thread QoS background (requested default), process sudden termination dirty, thread darwinbg, process darwinbg, IO tier 2>
        10  _dispatch_root_queue_drain + 917 (libdispatch.dylib + 14446) [0x7fffe559986e] 1-10
              10  ??? (authd + 13476) [0x10dc524a4] 1-10
                10  au_sdev_read_aia + 569 (libbsm.0.dylib + 60343) [0x7fffe414dbb7] 1-10
                  10  fgetc + 52 (libsystem_c.dylib + 253401) [0x7fffe563fdd9] 1-10
                    10  __srget + 14 (libsystem_c.dylib + 280754) [0x7fffe56468b2] 1-10
                      10  __srefill1 + 24 (libsystem_c.dylib + 280471) [0x7fffe5646797] 1-10
                        10  __read_nocancel + 10 (libsystem_kernel.dylib + 105926) [0x7fffe56fbdc6] 1-10
                                   *10  spec_read + 201 (kernel + 3497273) [0xffffff8000555d39] 1-10
                                     *10  ??? (kernel + 5438740) [0xffffff800072fd14] 1-10
  Thread 0x3bb              DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x10dc4f000 -        0x10dc66fff  com.apple.authd 1.0 ()             <D7484BAE-15D5-31A4-8C05-C4C939362366>  /System/Library/Frameworks/Security.framework/Versions/A/XPCServices/authd.xpc/Contents/MacOS/authd
        0x7fffe413f000 -     0x7fffe414ffff  libbsm.0.dylib (34)                <20084796-B04D-3B35-A003-EA11459557A9>  /usr/lib/libbsm.0.dylib
Process:         autofsd [115]
Path:            /usr/libexec/autofsd
Parent:          launchd [1]
UID:             0
Task size:       592 KB
  Thread 0x3c5              10 samples (1-10)         priority 20 (base 20)
  <thread QoS utility (requested default), process sudden termination clean, timers tier 3 (coalesced), IO tier 1>
  Binary Images:
           0x103045000 -        0x103045fff  autofsd (259.30.2)                 <36268EDC-126D-39D6-82FC-C9DADF0F6227>  /usr/libexec/autofsd
Process:         awacsd [196]
Path:            /usr/libexec/awacsd
Parent:          launchd [1]
UID:             0
Task size:       2816 KB
  Thread 0x5a3              10 samples (1-10)         priority 20 (base 20)
  <thread QoS utility (requested default), process sudden termination dirty, timers tier 3 (coalesced), IO tier 1>
  Thread 0x609              Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 20 (base 20)
  Thread 0x31a7             Thread name "com.apple.CFSocket.private"            10 samples (1-10)         priority 20 (base 20)
  <thread QoS utility (requested utility), process sudden termination dirty, timers tier 3 (coalesced), IO tier 1>
  Binary Images:
           0x1045ba000 -        0x104634fff  awacsd (118.20.1)                      <B125474E-010F-39C5-8A33-9A9854234F8A>  /usr/libexec/awacsd
Process:         awdd [229]
Path:            /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Support/awdd
Parent:          launchd [1]
UID:             0
Task size:       2268 KB
  Thread 0x6a1              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  ??? (awdd + 21475) [0x10c5813e3] 1-10
  Binary Images:
           0x10c57c000 -        0x10c661fff  awdd (869)                             <F49410F8-D2A5-366E-8D18-7FAA5BB521C6>  /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Support/awdd
Process:         bash [69]
Path:            /bin/bash
Parent:          launchd [1]
UID:             0
Task size:       408 KB
  Thread 0x2dd              10 samples (1-10)         priority 20 (base 20)
    10  ??? (bash + 7616) [0x108ea4dc0] 1-10
      10  ??? (bash + 116303) [0x108ebf64f] 1-10
        10  ??? (bash + 117276) [0x108ebfa1c] 1-10
          10  ??? (bash + 129203) [0x108ec28b3] 1-10
            10  ??? (bash + 157036) [0x108ec956c] 1-10
              10  __wait4 + 10 (libsystem_kernel.dylib + 107502) [0x7fffe56fc3ee] 1-10
  Binary Images:
           0x108ea3000 -        0x108f26fff  bash (103.50.1)                    <E16744EF-F6E7-3AAD-9D54-3CCE90F8ABA1>  /bin/bash
Process:         BetterTouchTool [1886]
Path:            /Applications/BetterTouchTool.app/Contents/MacOS/BetterTouchTool
Parent:          launchd [1]
UID:             503
Task size:       37.82 MB
Process:         biokitaggdd [258]
Path:            /usr/libexec/biokitaggdd
Parent:          launchd [1]
UID:             0
Task size:       1712 KB
  Thread 0x856              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
  <thread QoS background (requested background), thread darwinbg, process darwinbg, IO tier 2>
    10  ??? (biokitaggdd + 9608) [0x107d11588] 1-10
      10  ??? (biokitaggdd + 10398) [0x107d1189e] 1-10
  Binary Images:
           0x107d0f000 -        0x107d15fff  biokitaggdd (5.50.1)                   <5A3BD8E8-F140-34C5-97F2-3852AD0C5767>  /usr/libexec/biokitaggdd
Process:         biometrickitd [236]
Path:            /usr/libexec/biometrickitd
Parent:          launchd [1]
UID:             0
Task size:       3572 KB
  Thread 0x6ec              DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
    10  ??? (biometrickitd + 312949) [0x10d5ae675] 1-10
  Binary Images:
           0x10d562000 -        0x10d5e3fff  biometrickitd (424.16)                 <D9177D22-1466-34D4-98E4-72434F11E7CF>  /usr/libexec/biometrickitd
Process:         bird [362]
Path:            /System/Library/PrivateFrameworks/CloudDocsDaemon.framework/Versions/A/Support/bird
Parent:          launchd [1]
UID:             503
Task size:       10.96 MB
  Thread 0xcaa              DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
  <thread QoS default (requested default), process sudden termination dirty, process unclamped, process received importance donation from Microsoft Excel (Excel) [70302], process received importance donation from Finder [96276], IO tier 0>
    10  ??? (bird + 6002) [0x100817772] 1-10
  Binary Images:
           0x100816000 -        0x100817fff  bird (486.28)                          <4361594B-F3A5-3534-9E92-BAC5C54B6433>  /System/Library/PrivateFrameworks/CloudDocsDaemon.framework/Versions/A/Support/bird
Process:         blued [114]
Path:            /usr/sbin/blued
Parent:          launchd [1]
UID:             0
Task size:       3804 KB
  Thread 0x2cc              DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
    10  ??? (blued + 187775) [0x103eefd7f] 1-10
  Binary Images:
           0x103ec2000 -        0x103f95fff  blued (5004.4.18)                      <0675C360-4485-3399-A0D5-F7EBAB1DF761>  /usr/sbin/blued
Process:         BTTRelaunch [1887]
Path:            /Applications/BetterTouchTool.app/Contents/Resources/BTTRelaunch.app/Contents/MacOS/BTTRelaunch
Parent:          launchd [1]
UID:             503
Task size:       8852 KB
CPU Time:        <0.001
Process:         CalendarAgent [413]
Path:            /System/Library/PrivateFrameworks/CalendarAgent.framework/Executables/CalendarAgent
Parent:          launchd [1]
UID:             503
Task size:       30.57 MB
  Thread 0xeb7              DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
  <thread QoS default (requested default), process sudden termination dirty, process unclamped, process received importance donation from com.apple.dock.extra [410], IO tier 0>
    10  ??? (CalendarAgent + 6233) [0x10f7b5859] 1-10
  Thread 0x1d52             Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 31 (base 31)
  Binary Images:
           0x10f7b4000 -        0x10f7b5fff  CalendarAgent (386)                     <0EAFB1E4-7D3B-3122-AF64-2CD36B4CAA26>  /System/Library/PrivateFrameworks/CalendarAgent.framework/Executables/CalendarAgent
Process:         CallHistoryPluginHelper [415]
Path:            /System/Library/PrivateFrameworks/CallHistory.framework/Support/CallHistoryPluginHelper
Parent:          launchd [1]
UID:             503
Task size:       3404 KB
  Thread 0xec2              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  ??? (CallHistoryPluginHelper + 5507) [0x10bf74583] 1-10
  Binary Images:
           0x10bf73000 -        0x10bf74fff  CallHistoryPluginHelper (676)          <65E39669-058F-3925-A072-FE0D4254EE09>  /System/Library/PrivateFrameworks/CallHistory.framework/Support/CallHistoryPluginHelper
Process:         CallHistorySyncHelper [421]
Path:            /System/Library/PrivateFrameworks/CallHistory.framework/Support/CallHistorySyncHelper
Parent:          launchd [1]
UID:             503
Task size:       6688 KB
  Thread 0xef0              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  ??? (CallHistorySyncHelper + 70400) [0x1090df300] 1-10
  Binary Images:
           0x1090ce000 -        0x1090eefff  CallHistorySyncHelper (676)            <13886907-B5B0-31D8-A466-75AB561E6B08>  /System/Library/PrivateFrameworks/CallHistory.framework/Support/CallHistorySyncHelper
Process:         callservicesd [347]
Path:            /System/Library/PrivateFrameworks/TelephonyUtilities.framework/callservicesd
Parent:          launchd [1]
UID:             503
Task size:       10.27 MB
  Thread 0xc35              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  ??? (callservicesd + 914458) [0x10d3a641a] 1-10
  Binary Images:
           0x10d2c7000 -        0x10d40afff  callservicesd (838.3.7)                <2447A0E6-3C5B-3415-842E-845B910A7195>  /System/Library/PrivateFrameworks/TelephonyUtilities.framework/callservicesd
Process:         CalNCService [416]
Path:            /System/Library/PrivateFrameworks/CalendarNotification.framework/Versions/A/XPCServices/CalNCService.xpc/Contents/MacOS/CalNCService
Parent:          launchd [1]
Responsible:     CalendarAgent [413]
UID:             503
Task size:       15.06 MB
  Thread 0xed2              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  main + 111 (CalNCService + 45654) [0x101427256] 1-10
      10  -[NSXPCListener resume] + 165 (Foundation + 524571) [0x7fffd18da11b] 1-10
        10  xpc_main + 494 (libxpc.dylib + 62180) [0x7fffe58252e4] 1-10
          10  _xpc_objc_main + 731 (libxpc.dylib + 67739) [0x7fffe582689b] 1-10
  Thread 0x262b28           10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x10141c000 -        0x10142afff  com.apple.CalendarNotification.CalNCService 1.0 (507.6) <18ED1256-D076-3514-A4DD-132269BDA25B>  /System/Library/PrivateFrameworks/CalendarNotification.framework/Versions/A/XPCServices/CalNCService.xpc/Contents/MacOS/CalNCService
        0x7fffe5816000 -     0x7fffe583ffff  libxpc.dylib (972.50.27)                                <ABC45890-DA23-3A4A-B50B-1384BD4CBBDF>  /usr/lib/system/libxpc.dylib
Process:         captiveagent [869]
Path:            /usr/libexec/captiveagent
Parent:          launchd [1]
UID:             258
Task size:       4564 KB
  Thread 0x1da3             DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
  <thread QoS default (requested default), process sudden termination clean, process unclamped, process received importance donation from configd [58], IO tier 0>
    10  ??? (captiveagent + 4477) [0x109c2617d] 1-10
  Thread 0x1db3             Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 31 (base 31)
  Thread 0x23d9             Thread name "com.apple.CFSocket.private"            10 samples (1-10)         priority 31 (base 31)
  Binary Images:
           0x109c25000 -        0x109c2cfff  captiveagent (346.50.1)                 <3DF3F257-09F4-302E-8ED2-81164EE81D86>  /usr/libexec/captiveagent
Process:         cdpd [16467]
Path:            /System/Library/PrivateFrameworks/CoreCDP.framework/Versions/A/Resources/cdpd
Parent:          launchd [1]
UID:             503
Task size:       1756 KB
  Thread 0x88f8e            DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  ??? (cdpd + 3840) [0x1009eaf00] 1-10
  Binary Images:
           0x1009ea000 -        0x1009eafff  cdpd (114.0.2)                         <FC4E54B9-A89E-36AA-B73E-94A365B693BE>  /System/Library/PrivateFrameworks/CoreCDP.framework/Versions/A/Resources/cdpd
Process:         cfprefsd [138]
Path:            /usr/sbin/cfprefsd
Parent:          launchd [1]
UID:             0
Task size:       5000 KB (-24 KB)
CPU Time:        <0.001
Note:            5 idle work queue threads omitted
  Thread 0x33a              DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
  Thread 0x262db5           10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x10f0aa000 -        0x10f0aafff  cfprefsd (1349.65)                 <1A1890FC-5C36-3055-A293-C955B09CBAB3>  /usr/sbin/cfprefsd
Process:         cfprefsd [323]
Parent:          launchd [1]
UID:             503
Task size:       11.68 MB
CPU Time:        <0.001
  Thread 0xadc              DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x10f13a000 -        0x10f13afff  cfprefsd (1349.65)                 <1A1890FC-5C36-3055-A293-C955B09CBAB3>  /usr/sbin/cfprefsd
Process:         Citations [532]
Path:            /Applications/Papers.app/Contents/SharedSupport/Citations.app/Contents/MacOS/Citations
Parent:          launchd [1]
UID:             503
Task size:       11.06 MB
Process:         CleanApp Daemon [97658]
Path:            /Library/Application Support/CleanApp/CleanApp Daemon.app/Contents/MacOS/CleanApp Daemon
Architecture:    i386
Parent:          launchd [1]
UID:             0
Task size:       30.29 MB
CPU Time:        0.210
Process:         cloudd [412]
Path:            /System/Library/PrivateFrameworks/CloudKitDaemon.framework/Support/cloudd
Parent:          launchd [1]
UID:             503
Task size:       20.81 MB
  Thread 0xeaf              DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
  <thread QoS default (requested default), process sudden termination clean, process unclamped, process received importance donation from bird [362], process received importance donation from Safari [2846], process received importance donation from Notes [71381], IO tier 0>
    10  ??? (cloudd + 10716) [0x10ff019dc] 1-10
  Thread 0x2654             Thread name "com.apple.CFStream.LegacyThread"       10 samples (1-10)         priority 31 (base 31)
        10  _legacyStreamRunLoop_workThread + 261 (CoreFoundation + 1435189) [0x7fffcff41635] 1-10
  Thread 0x2bc6             Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 31 (base 31)
  Binary Images:
           0x10feff000 -        0x10ff04fff  cloudd (651.14)                         <E0EF61B8-731F-3698-9707-0F2297737232>  /System/Library/PrivateFrameworks/CloudKitDaemon.framework/Support/cloudd
Process:         CloudKeychainProxy [471]
Path:            /System/Library/Frameworks/Security.framework/Versions/A/Resources/CloudKeychainProxy.bundle/Contents/MacOS/CloudKeychainProxy
Parent:          launchd [1]
UID:             503
Task size:       2792 KB
  Thread 0x1208             DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x108c0e000 -        0x108c22fff  com.apple.security.cloudkeychainproxy3 10.0 () <6A636FFB-2181-3E94-85AD-EB677C09D7F2>  /System/Library/Frameworks/Security.framework/Versions/A/Resources/CloudKeychainProxy.bundle/Contents/MacOS/CloudKeychainProxy
Process:         cloudpaird [509]
Path:            /System/Library/CoreServices/cloudpaird
Parent:          launchd [1]
UID:             503
Task size:       2744 KB
  Thread 0x1750             DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  ??? (cloudpaird + 64917) [0x10cc59d95] 1-10
  Binary Images:
           0x10cc4a000 -        0x10cc67fff  cloudpaird (5004.4.18)                 <AD97547C-2247-31C1-A4EA-2264E11ADA53>  /System/Library/CoreServices/cloudpaird
Process:         cloudphotosd [374]
Path:            /System/Library/CoreServices/cloudphotosd.app/Contents/MacOS/cloudphotosd
Parent:          launchd [1]
UID:             503
Task size:       8108 KB
  Thread 0xd12              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  main + 115 (cloudphotosd + 738778) [0x107cc65da] 1-10
  Thread 0xdd9              Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 4 (base 4)
  <thread QoS background (requested user interactive), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2>
  Thread 0x219f             10 samples (1-10)         priority 4 (base 4)
  Thread 0x21a0             10 samples (1-10)         priority 4 (base 4)
  Thread 0x21a9             Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x107c12000 -        0x107d04fff  com.apple.cloudphotosd 2.0 (3150.4.120) <1C223A5B-85FC-32B2-8E0F-D4A67FACE558>  /System/Library/CoreServices/cloudphotosd.app/Contents/MacOS/cloudphotosd
Process:         CMFSyncAgent [1241]
Path:            /System/Library/PrivateFrameworks/CommunicationsFilter.framework/CMFSyncAgent.app/Contents/MacOS/CMFSyncAgent
Parent:          launchd [1]
UID:             503
Task size:       920 KB
  Thread 0x3032             DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  ??? (CMFSyncAgent + 5277) [0x10980a49d] 1-10
  Binary Images:
           0x109809000 -        0x10980cfff  com.apple.cmfsyncagent 10.0 (1000)     <915C11FA-A8CE-345C-A28E-F06D7EB93CB3>  /System/Library/PrivateFrameworks/CommunicationsFilter.framework/CMFSyncAgent.app/Contents/MacOS/CMFSyncAgent
Process:         com.apple.accessibility.mediaaccessibilityd [2912]
Path:            /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/XPCServices/com.apple.accessibility.mediaaccessibilityd.xpc/Contents/MacOS/com.apple.accessibility.mediaaccessibilityd
Parent:          launchd [1]
UID:             503
Task size:       1844 KB
  Thread 0xfa16             10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x10c37f000 -        0x10c380fff  com.apple.accessibility.mediaaccessibilityd 1.0 (1) <98ACFA8C-EC73-3497-9644-32A817DC96A8>  /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/XPCServices/com.apple.accessibility.mediaaccessibilityd.xpc/Contents/MacOS/com.apple.accessibility.mediaaccessibilityd
Process:         com.apple.AccountPolicyHelper [304]
Path:            /System/Library/PrivateFrameworks/AccountPolicy.framework/XPCServices/com.apple.AccountPolicyHelper.xpc/Contents/MacOS/com.apple.AccountPolicyHelper
Parent:          launchd [1]
UID:             0
Task size:       588 KB
  Thread 0x9ef              10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x109fe3000 -        0x109fecfff  com.apple.AccountPolicyHelper 1.0 (1) <5A295718-2EDC-307E-A73F-FEF88E7427EB>  /System/Library/PrivateFrameworks/AccountPolicy.framework/XPCServices/com.apple.AccountPolicyHelper.xpc/Contents/MacOS/com.apple.AccountPolicyHelper
Process:         com.apple.AddressBook.FaceTimeService [69598]
Path:            /System/Library/Frameworks/AddressBook.framework/Versions/A/XPCServices/com.apple.AddressBook.FaceTimeService.xpc/Contents/MacOS/com.apple.AddressBook.FaceTimeService
Parent:          launchd [1]
Responsible:     Spotlight [434]
UID:             503
Task size:       1012 KB
  Thread 0x1877ad           DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  main + 163 (com.apple.AddressBook.FaceTimeService + 7730) [0x10535ae32] 1-10
  Binary Images:
           0x105359000 -        0x10535cfff  com.apple.AddressBook.FaceTimeService 10.0 (1756.20) <E115980D-9C09-3B0A-BA6C-5E7F84AA0638>  /System/Library/Frameworks/AddressBook.framework/Versions/A/XPCServices/com.apple.AddressBook.FaceTimeService.xpc/Contents/MacOS/com.apple.AddressBook.FaceTimeService
Process:         com.apple.AmbientDisplayAgent [255]
Path:            /System/Library/PrivateFrameworks/AmbientDisplay.framework/Versions/A/XPCServices/com.apple.AmbientDisplayAgent.xpc/Contents/MacOS/com.apple.AmbientDisplayAgent
Parent:          launchd [1]
UID:             0
Task size:       2808 KB
  Thread 0x831              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  main + 312 (com.apple.AmbientDisplayAgent + 8932) [0x1026712e4] 1-10
  Thread 0x8e8              10 samples (1-10)         priority 4 (base 4)
        10  ??? (com.apple.AmbientDisplayAgent + 10552) [0x102671938] 1-10
  Binary Images:
           0x10266f000 -        0x102675fff  com.apple.AmbientDisplayAgent 1.0 (1)  <13CCDBE2-0ED7-37A4-A05C-9662D6ED9280>  /System/Library/PrivateFrameworks/AmbientDisplay.framework/Versions/A/XPCServices/com.apple.AmbientDisplayAgent.xpc/Contents/MacOS/com.apple.AmbientDisplayAgent
Process:         com.apple.appkit.xpc.openAndSavePanelService [69776]
Path:            /System/Library/Frameworks/AppKit.framework/Versions/C/XPCServices/com.apple.appkit.xpc.openAndSavePanelService.xpc/Contents/MacOS/com.apple.appkit.xpc.openAndSavePanelService
Parent:          launchd [1]
Responsible:     Mail [27767]
UID:             503
Task size:       17.52 MB
  Thread 0x18885e           DispatchQueue 1           10 samples (1-10)         priority 4-46 (base 4-46)
  <thread QoS user interactive (requested user interactive), process sudden termination clean, process unclamped, IO tier 0, priority 46 (46)>
    10  main + 208 (com.apple.appkit.xpc.openAndSavePanelService + 26299) [0x1050d76bb] 1-10
      10  NSViewServiceApplicationMain + 2985 (ViewBridge + 67126) [0x7fffe3704636] 1-10
        10  -[NSXPCSharedListener resume] + 16 (ViewBridge + 221093) [0x7fffe3729fa5] 1-10
            10  _xpc_objc_main + 775 (libxpc.dylib + 67783) [0x7fffe58268c7] 1-10
                  10  -[NSViewServiceApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 100 (ViewBridge + 47432) [0x7fffe36ff948] 1-10
  <process clamped, process suppressed, timers tier 5 (throttled), IO tier 1, priority 4 (4)>
  Thread 0x18888a           Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 4-46 (base 4-46)
  Binary Images:
           0x1050d1000 -        0x1050dafff  com.apple.appkit.xpc.openAndSavePanelService 1.0 (1) <B56480F5-8991-356A-9A11-9C285BD10B21>  /System/Library/Frameworks/AppKit.framework/Versions/C/XPCServices/com.apple.appkit.xpc.openAndSavePanelService.xpc/Contents/MacOS/com.apple.appkit.xpc.openAndSavePanelService
        0x7fffe36f4000 -     0x7fffe37b4fff  com.apple.ViewBridge 282 (282)                       <71C6F456-E63F-3465-BCC7-377D29CF817D>  /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
Process:         com.apple.audio.ComponentHelper [65983]
Path:            /System/Library/Frameworks/AudioToolbox.framework/XPCServices/com.apple.audio.ComponentHelper.xpc/Contents/MacOS/com.apple.audio.ComponentHelper
Architecture:    x86_64
Parent:          launchd [1]
Responsible:     assistantd [475]
UID:             503
Task size:       1484 KB
  Thread 0x174533           10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x10ed9d000 -        0x10ed9efff  com.apple.audio.ComponentHelper 1.0.1 (1) <10948385-A27A-3918-8095-EBAFA2E5B0D2>  /System/Library/Frameworks/AudioToolbox.framework/XPCServices/com.apple.audio.ComponentHelper.xpc/Contents/MacOS/com.apple.audio.ComponentHelper
Process:         com.apple.audio.DriverHelper [215]
Path:            /System/Library/Frameworks/CoreAudio.framework/Versions/A/XPCServices/com.apple.audio.DriverHelper.xpc/Contents/MacOS/com.apple.audio.DriverHelper
Parent:          launchd [1]
Responsible:     coreaudiod [207]
UID:             202
Task size:       1208 KB
  Thread 0x5e8              DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x1087a2000 -        0x1087a4fff  com.apple.audio.DriverHelper 1.0 (1) <D25F3404-3146-39B9-A8BA-0ED1F4D0CF0C>  /System/Library/Frameworks/CoreAudio.framework/Versions/A/XPCServices/com.apple.audio.DriverHelper.xpc/Contents/MacOS/com.apple.audio.DriverHelper
Process:         com.apple.audio.SandboxHelper [301]
Path:            /System/Library/Frameworks/AudioToolbox.framework/XPCServices/com.apple.audio.SandboxHelper.xpc/Contents/MacOS/com.apple.audio.SandboxHelper
Parent:          launchd [1]
Responsible:     systemsoundserverd [300]
UID:             0
Task size:       528 KB
  Thread 0x9cf              10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x109666000 -        0x10966afff  com.apple.audio.SandboxHelper 1.0.1 (1) <4C1181EF-4313-3FDE-B8F9-F1D29E990E41>  /System/Library/Frameworks/AudioToolbox.framework/XPCServices/com.apple.audio.SandboxHelper.xpc/Contents/MacOS/com.apple.audio.SandboxHelper
Process:         com.apple.audio.SandboxHelper [478]
Parent:          launchd [1]
UID:             503
Task size:       500 KB
  Thread 0x1264             10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x10f0c3000 -        0x10f0c7fff  com.apple.audio.SandboxHelper 1.0.1 (1) <4C1181EF-4313-3FDE-B8F9-F1D29E990E41>  /System/Library/Frameworks/AudioToolbox.framework/XPCServices/com.apple.audio.SandboxHelper.xpc/Contents/MacOS/com.apple.audio.SandboxHelper
Process:         com.apple.audio.SandboxHelper [35328]
Parent:          launchd [1]
UID:             503
Task size:       556 KB
  Thread 0xe1e77            10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x10ae7d000 -        0x10ae81fff  com.apple.audio.SandboxHelper 1.0.1 (1) <4C1181EF-4313-3FDE-B8F9-F1D29E990E41>  /System/Library/Frameworks/AudioToolbox.framework/XPCServices/com.apple.audio.SandboxHelper.xpc/Contents/MacOS/com.apple.audio.SandboxHelper
Process:         com.apple.audio.SandboxHelper [65986]
Parent:          launchd [1]
Responsible:     com.apple.speech.speechsynthesisd [65984]
UID:             503
Task size:       460 KB
  Thread 0x1745a2           10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x10962b000 -        0x10962ffff  com.apple.audio.SandboxHelper 1.0.1 (1) <4C1181EF-4313-3FDE-B8F9-F1D29E990E41>  /System/Library/Frameworks/AudioToolbox.framework/XPCServices/com.apple.audio.SandboxHelper.xpc/Contents/MacOS/com.apple.audio.SandboxHelper
Process:         com.apple.audio.SandboxHelper [69713]
Parent:          launchd [1]
Responsible:     Safari [2846]
UID:             503
Task size:       384 KB
  Thread 0x188347           10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x10b90c000 -        0x10b910fff  com.apple.audio.SandboxHelper 1.0.1 (1) <4C1181EF-4313-3FDE-B8F9-F1D29E990E41>  /System/Library/Frameworks/AudioToolbox.framework/XPCServices/com.apple.audio.SandboxHelper.xpc/Contents/MacOS/com.apple.audio.SandboxHelper
Process:         com.apple.audio.SandboxHelper [92702]
Parent:          launchd [1]
UID:             503
Task size:       520 KB
  Thread 0x2155f8           10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x10c240000 -        0x10c244fff  com.apple.audio.SandboxHelper 1.0.1 (1) <4C1181EF-4313-3FDE-B8F9-F1D29E990E41>  /System/Library/Frameworks/AudioToolbox.framework/XPCServices/com.apple.audio.SandboxHelper.xpc/Contents/MacOS/com.apple.audio.SandboxHelper
Process:         com.apple.CharacterPicker.FileService [590]
Path:            /System/Library/PrivateFrameworks/CharacterPicker.framework/Versions/A/XPCServices/com.apple.CharacterPicker.FileService.xpc/Contents/MacOS/com.apple.CharacterPicker.FileService
Parent:          launchd [1]
UID:             503
Task size:       1904 KB
  Thread 0x1658             DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  main + 16 (com.apple.CharacterPicker.FileService + 6174) [0x10e77581e] 1-10
  Binary Images:
           0x10e774000 -        0x10e77dfff  com.apple.CharacterPicker.FileService 1.0 (1) <71F01DD8-93D0-332D-9CA4-C3AD6EE25CC0>  /System/Library/PrivateFrameworks/CharacterPicker.framework/Versions/A/XPCServices/com.apple.CharacterPicker.FileService.xpc/Contents/MacOS/com.apple.CharacterPicker.FileService
Process:         com.apple.CloudPhotosConfiguration [399]
Path:            /System/Library/PrivateFrameworks/CloudPhotoServices.framework/Versions/A/Frameworks/CloudPhotosConfigurationXPC.framework/Versions/A/XPCServices/com.apple.CloudPhotosConfiguration.xpc/Contents/MacOS/com.apple.CloudPhotosConfiguration
Parent:          launchd [1]
UID:             503
Task size:       3336 KB
  Thread 0xdd5              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
  10  start + 1 (libdyld.dylib + 21045) [0x7fffe55cd235] 1-10
    10  main + 24 (com.apple.CloudPhotosConfiguration + 9956) [0x104da56e4] 1-10
      10  +[CPSConfigurationService run] + 53 (com.apple.CloudPhotosConfiguration + 10276) [0x104da5824] 1-10
        10  -[CPSConfigurationService run] + 199 (com.apple.CloudPhotosConfiguration + 10488) [0x104da58f8] 1-10
  Binary Images:
           0x104da3000 -        0x104db4fff  com.apple.CloudPhotosConfiguration 2.0 (3150.4.120) <468A73D0-DF3D-3E6C-83EC-C24BABCCD66A>  /System/Library/PrivateFrameworks/CloudPhotoServices.framework/Versions/A/Frameworks/CloudPhotosConfigurationXPC.framework/Versions/A/XPCServices/com.apple.CloudPhotosConfiguration.xpc/Contents/MacOS/com.apple.CloudPhotosConfiguration
Process:         com.apple.CodeSigningHelper [282]
Path:            /System/Library/Frameworks/Security.framework/Versions/A/XPCServices/com.apple.CodeSigningHelper.xpc/Contents/MacOS/com.apple.CodeSigningHelper
Parent:          launchd [1]
UID:             0
Task size:       2344 KB
  Thread 0x93b              DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x10c367000 -        0x10c368fff  com.apple.CodeSigningHelper 1.0 (1) <E659A190-F50B-3EAF-98A8-E69CD340B0EB>  /System/Library/Frameworks/Security.framework/Versions/A/XPCServices/com.apple.CodeSigningHelper.xpc/Contents/MacOS/com.apple.CodeSigningHelper
Process:         com.apple.ColorSyncXPCAgent [87890]
Path:            /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/XPCServices/com.apple.ColorSyncXPCAgent.xpc/Contents/MacOS/com.apple.ColorSyncXPCAgent
Parent:          launchd [1]
UID:             503
Task size:       340 KB
  Thread 0x1fa9c4           10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x104a5c000 -        0x104a5efff  com.apple.ColorSyncXPCAgent 1.0 (1) <A0E01710-46FE-338E-AAE4-55E4CFD5B873>  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/XPCServices/com.apple.ColorSyncXPCAgent.xpc/Contents/MacOS/com.apple.ColorSyncXPCAgent
Process:         com.apple.ColorSyncXPCAgent [1526]
Parent:          launchd [1]
UID:             503
Task size:       1844 KB
  Thread 0x260b30           DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x10dc52000 -        0x10dc54fff  com.apple.ColorSyncXPCAgent 1.0 (1) <A0E01710-46FE-338E-AAE4-55E4CFD5B873>  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/XPCServices/com.apple.ColorSyncXPCAgent.xpc/Contents/MacOS/com.apple.ColorSyncXPCAgent
Process:         com.apple.CommerceKit.TransactionService [1162]
Path:            /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/XPCServices/com.apple.CommerceKit.TransactionService.xpc/Contents/MacOS/com.apple.CommerceKit.TransactionService
Parent:          launchd [1]
Responsible:     storeaccountd [439]
UID:             503
Task size:       1320 KB
  Thread 0x2557             DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x10069e000 -        0x10087efff  com.apple.CommerceKit.TransactionService 1.0 (582.5) <F53996E7-9B29-32CD-962F-3BAC16B9C8DA>  /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/XPCServices/com.apple.CommerceKit.TransactionService.xpc/Contents/MacOS/com.apple.CommerceKit.TransactionService
Process:         com.apple.ctkpcscd [176]
Path:            /System/Library/Frameworks/PCSC.framework/Versions/A/XPCServices/com.apple.ctkpcscd.xpc/Contents/MacOS/com.apple.ctkpcscd
Parent:          launchd [1]
Responsible:     securityd [108]
UID:             0
Task size:       608 KB
  Thread 0x41f              10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x10591c000 -        0x105926fff  com.apple.ctkpcscd 1.0 (1)         <850303B0-91C7-33D5-98A2-43B2FE07DD42>  /System/Library/Frameworks/PCSC.framework/Versions/A/XPCServices/com.apple.ctkpcscd.xpc/Contents/MacOS/com.apple.ctkpcscd
Process:         com.apple.DFRSystemExtra.InputMenu [463]
Path:            /System/Library/CoreServices/ControlStrip.app/Contents/XPCServices/com.apple.DFRSystemExtra.InputMenu.xpc/Contents/MacOS/com.apple.DFRSystemExtra.InputMenu
Parent:          launchd [1]
Responsible:     ControlStrip [333]
UID:             503
Task size:       3364 KB
  Thread 0x11c5             DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
  <thread QoS default (requested user interactive), process sudden termination clean, process unclamped, IO tier 0>
    10  main + 21 (com.apple.DFRSystemExtra.InputMenu + 16051) [0x10be0aeb3] 1-10
      10  DFRSystemExtraMain + 254 (DFRFoundation + 7633) [0x7fffdbe65dd1] 1-10
            10  NSApplicationMain + 1237 (AppKit + 25054) [0x7fffcd9261de] 1-10
              10  -[NSApplication run] + 926 (AppKit + 243627) [0x7fffcd95b7ab] 1-10
  <process clamped>
  Thread 0x11d8             Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 31 (base 31)
  <process clamped>
  Binary Images:
           0x10be07000 -        0x10be0dfff  com.apple.DFRSystemExtra.InputMenu 1.0 (1)     <7CE861D7-5801-3E6C-9395-22474A8C160F>  /System/Library/CoreServices/ControlStrip.app/Contents/XPCServices/com.apple.DFRSystemExtra.InputMenu.xpc/Contents/MacOS/com.apple.DFRSystemExtra.InputMenu
        0x7fffdbe64000 -     0x7fffdbe6efff  com.apple.framework.DFRFoundation 1.0 (104.25) <A509BF55-7829-3633-A500-EF0B4E21F46B>  /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation
Process:         com.apple.DFRSystemExtra.Siri [65979]
Path:            /System/Library/CoreServices/ControlStrip.app/Contents/XPCServices/com.apple.DFRSystemExtra.Siri.xpc/Contents/MacOS/com.apple.DFRSystemExtra.Siri
Parent:          launchd [1]
UID:             503
Task size:       984 KB
  Thread 0x1744dc           DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  main + 102 (com.apple.DFRSystemExtra.Siri + 7146) [0x100ad6bea] 1-10
  Binary Images:
           0x100ad5000 -        0x100ad6fff  com.apple.DFRSystemExtra.Siri 1.0 (1)          <31B13320-9F1F-3B49-B2C6-889E523BDE56>  /System/Library/CoreServices/ControlStrip.app/Contents/XPCServices/com.apple.DFRSystemExtra.Siri.xpc/Contents/MacOS/com.apple.DFRSystemExtra.Siri
Process:         com.apple.DictionaryServiceHelper [864]
Path:            /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/XPCServices/com.apple.DictionaryServiceHelper.xpc/Contents/MacOS/com.apple.DictionaryServiceHelper
Parent:          launchd [1]
UID:             503
Task size:       448 KB
  Thread 0x1d80             10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x1004c5000 -        0x1004cafff  com.apple.DictionaryServiceHelper 1.0 (1) <A061ECBD-D1F9-3BFE-A1A4-DC8F6C3AC8A1>  /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/XPCServices/com.apple.DictionaryServiceHelper.xpc/Contents/MacOS/com.apple.DictionaryServiceHelper
Process:         com.apple.dock.extra [410]
Path:            /System/Library/CoreServices/Dock.app/Contents/XPCServices/com.apple.dock.extra.xpc/Contents/MacOS/com.apple.dock.extra
Parent:          launchd [1]
Responsible:     Dock [349]
UID:             503
Task size:       7964 KB
  Thread 0xe75              DispatchQueue 1           10 samples (1-10)         priority 46 (base 46)
  <thread QoS user interactive (requested user interactive), process sudden termination dirty, process unclamped, process received importance donation from Dock [349], IO tier 0>
    10  ??? (com.apple.dock.extra + 4131) [0x10a786023] 1-10
                        10  CFRunLoopRunSpecific + 420 (CoreFoundation + 553412) [0x7fffcfe6a1c4] 1-10
                          10  __CFRunLoopRun + 1361 (CoreFoundation + 555377) [0x7fffcfe6a971] 1-10
                            10  __CFRunLoopServiceMachPort + 212 (CoreFoundation + 558308) [0x7fffcfe6b4e4] 1-10
                              10  mach_msg_trap + 10 (libsystem_kernel.dylib + 74570) [0x7fffe56f434a] 1-10
                               *10  ipc_mqueue_receive_continue + 0 (kernel + 862304) [0xffffff80002d2860] 1-10
  Thread 0xe98              Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 46 (base 46)
  10  thread_start + 13 (libsystem_pthread.dylib + 12545) [0x7fffe57e6101] 1-10
    10  _pthread_start + 286 (libsystem_pthread.dylib + 14587) [0x7fffe57e68fb] 1-10
      10  _pthread_body + 180 (libsystem_pthread.dylib + 14767) [0x7fffe57e69af] 1-10
        10  _NSEventThread + 205 (AppKit + 1655506) [0x7fffcdab42d2] 1-10
  Binary Images:
           0x10a785000 -        0x10a788fff  com.apple.dock.extra 1.0 (1)           <1EC94376-9485-3284-BE07-E89BF598D04D>  /System/Library/CoreServices/Dock.app/Contents/XPCServices/com.apple.dock.extra.xpc/Contents/MacOS/com.apple.dock.extra
Process:         com.apple.geod [438]
Path:            /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/XPCServices/com.apple.geod.xpc/Contents/MacOS/com.apple.geod
Parent:          launchd [1]
UID:             503
Task size:       10.01 MB
  Thread 0xff6              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  main + 1148 (com.apple.geod + 72697) [0x10f50fbf9] 1-10
  Thread 0x1180             Thread name "NetworkLoad" 10 samples (1-10)         priority 4 (base 4)
  Thread 0x1186             Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x10f4fe000 -        0x10f514fff  com.apple.geod 1.0 (1228.24.9.30.34)   <FDF600BB-B52A-3AE8-A5D1-51474AB17023>  /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/XPCServices/com.apple.geod.xpc/Contents/MacOS/com.apple.geod
Process:         com.apple.geod [1307]
Parent:          launchd [1]
UID:             0
Task size:       6708 KB
  Thread 0x376e             DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  main + 1148 (com.apple.geod + 72697) [0x102103bf9] 1-10
  Thread 0x377e             Thread name "NetworkLoad" 10 samples (1-10)         priority 4 (base 4)
        10  _runNetworkThread + 445 (GeoServices + 4445674) [0x7fffde25c5ea] 1-10
  Thread 0x3786             Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4 (base 4)
        10  __NSThread__start__ + 1243 (Foundation + 207821) [0x7fffd188cbcd] 1-10
          10  +[NSURLConnection(Loader) _resourceLoadLoop:] + 313 (CFNetwork + 26116) [0x7fffcefa8604] 1-10
  Binary Images:
           0x1020f2000 -        0x102108fff  com.apple.geod 1.0 (1228.24.9.30.34)        <FDF600BB-B52A-3AE8-A5D1-51474AB17023>  /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/XPCServices/com.apple.geod.xpc/Contents/MacOS/com.apple.geod
        0x7fffdde1f000 -     0x7fffde4d1fff  com.apple.GeoServices 1.0 (1228.24.9.30.34) <B482AFD6-8E27-3204-A5AA-FD73A1F32B32>  /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/GeoServices
Process:         com.apple.GSSCred [310]
Path:            /System/Library/Frameworks/GSS.framework/Helpers/com.apple.GSSCred
Parent:          launchd [1]
UID:             0
Task size:       764 KB
  Thread 0xa19              DispatchQueue 8           10 samples (1-10)         priority 20 (base 20)
  <thread QoS utility (requested utility), process sudden termination clean, timers tier 3 (coalesced), IO tier 1>
  10  start_wqthread + 13 (libsystem_pthread.dylib + 12529) [0x7fffe57e60f1] 1-10
    10  _pthread_wqthread + 1299 (libsystem_pthread.dylib + 13846) [0x7fffe57e6616] 1-10
      10  _dispatch_worker_thread3 + 99 (libdispatch.dylib + 13452) [0x7fffe559948c] 1-10
          10  _dispatch_client_callout + 8 (libdispatch.dylib + 6396) [0x7fffe55978fc] 1-10
            10  _dispatch_call_block_and_release + 12 (libdispatch.dylib + 42276) [0x7fffe55a0524] 1-10
              10  ??? (com.apple.GSSCred + 11079) [0x10e0c4b47] 1-10
  Thread 0xa1b              10 samples (1-10)         priority 20 (base 20)
     *10  ??? (kernel + 5801776) [0xffffff8000788730] 1-10
  Binary Images:
           0x10e0c2000 -        0x10e0c9fff  com.apple.GSSCred (498.50.8)       <33AAE98E-BF59-3C7E-819E-3B9B02C60AC4>  /System/Library/Frameworks/GSS.framework/Helpers/com.apple.GSSCred
Process:         com.apple.hiservices-xpcservice [1212]
Path:            /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/XPCServices/com.apple.hiservices-xpcservice.xpc/Contents/MacOS/com.apple.hiservices-xpcservice
Parent:          launchd [1]
UID:             503
Task size:       1416 KB
  Thread 0x2d69             DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x107f66000 -        0x107f6afff  com.apple.hiservices-xpcservice 1.22 (591) <99A12FDF-2CB2-352E-88A3-C7B93308B79A>  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/XPCServices/com.apple.hiservices-xpcservice.xpc/Contents/MacOS/com.apple.hiservices-xpcservice
Process:         com.apple.iCloudHelper [98799]
Path:            /System/Library/PrivateFrameworks/AOSKit.framework/Versions/A/XPCServices/com.apple.iCloudHelper.xpc/Contents/MacOS/com.apple.iCloudHelper
Parent:          launchd [1]
UID:             503
Task size:       7724 KB
  Thread 0x252b2f           DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  main + 167 (com.apple.iCloudHelper + 14676) [0x10dbdd954] 1-10
  Binary Images:
           0x10dbda000 -        0x10dbecfff  com.apple.iCloudHelper 1.07 (245)      <587F020C-5AC5-3D42-B619-64FC1228BF97>  /System/Library/PrivateFrameworks/AOSKit.framework/Versions/A/XPCServices/com.apple.iCloudHelper.xpc/Contents/MacOS/com.apple.iCloudHelper
        0x7fffcfde3000 -     0x7fffd027cfff  com.apple.CoreFoundation 6.9 (1349.65) <F79384D1-FA3F-38CA-A847-B2625EBB790E>  /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
        0x7fffd185a000 -     0x7fffd1c00fff  com.apple.Foundation 6.9 (1349.64)     <49C8DA40-9E5B-33F9-B092-F50115B59E95>  /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
Process:         com.apple.ifdreader [233]
Path:            /System/Library/CryptoTokenKit/com.apple.ifdreader.slotd/Contents/MacOS/com.apple.ifdreader
Parent:          launchd [1]
UID:             0
Task size:       684 KB
  Thread 0x6e5              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  main + 1179 (com.apple.ifdreader + 5165) [0x10629842d] 1-10
  Binary Images:
           0x106297000 -        0x1062a2fff  com.apple.ifdreader 1.0 (1)            <BD2FF633-DB68-3DB3-8B13-FBFB9D410CD1>  /System/Library/CryptoTokenKit/com.apple.ifdreader.slotd/Contents/MacOS/com.apple.ifdreader
        0x7fffe55c8000 -     0x7fffe55cdfff  libdyld.dylib (433.5)                  <129D3B44-FB21-3750-9A68-48B5C3DC632B>  /usr/lib/system/libdyld.dylib
        0x7fffe56e2000 -     0x7fffe5704fff  libsystem_kernel.dylib (3789.51.2)     <FC51D7B0-8292-3F6A-9231-64340B237EB7>  /usr/lib/system/libsystem_kernel.dylib
Process:         com.apple.iTunesLibraryService [477]
Path:            /Library/Frameworks/iTunesLibrary.framework/Versions/A/XPCServices/com.apple.iTunesLibraryService.xpc/Contents/MacOS/com.apple.iTunesLibraryService
Parent:          launchd [1]
UID:             503
Task size:       1040 KB
  Thread 0x125e             DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x10107e000 -        0x10113dfff  com.apple.iTunesLibraryService 12.6 (12.6.0) <A29FB373-FACB-3BD9-8014-A3042EC25704>  /Library/Frameworks/iTunesLibrary.framework/Versions/A/XPCServices/com.apple.iTunesLibraryService.xpc/Contents/MacOS/com.apple.iTunesLibraryService
Process:         com.apple.iTunesLibraryService [1205]
Parent:          launchd [1]
Responsible:     assistant_service [1174]
UID:             503
Sudden Term:     Tracked (allows idle exit)
Task size:       1208 KB
  Thread 0x2c03             10 samples (1-10)         priority 4 (base 4)
  <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2>
  Binary Images:
           0x1014f1000 -        0x1015b0fff  com.apple.iTunesLibraryService 12.6 (12.6.0) <A29FB373-FACB-3BD9-8014-A3042EC25704>  /Library/Frameworks/iTunesLibrary.framework/Versions/A/XPCServices/com.apple.iTunesLibraryService.xpc/Contents/MacOS/com.apple.iTunesLibraryService
Process:         com.apple.iTunesLibraryService [18283]
Parent:          launchd [1]
UID:             503
Task size:       1156 KB
  Thread 0x929e1            DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x10d5d2000 -        0x10d691fff  com.apple.iTunesLibraryService 12.6 (12.6.0) <A29FB373-FACB-3BD9-8014-A3042EC25704>  /Library/Frameworks/iTunesLibrary.framework/Versions/A/XPCServices/com.apple.iTunesLibraryService.xpc/Contents/MacOS/com.apple.iTunesLibraryService
Process:         com.apple.notificationcenterui.WeatherSummary [569]
Path:            /System/Library/CoreServices/NotificationCenter.app/Contents/XPCServices/com.apple.notificationcenterui.WeatherSummary.xpc/Contents/MacOS/com.apple.notificationcenterui.WeatherSummary
Parent:          launchd [1]
Responsible:     NotificationCenter (Notification Center) [497]
UID:             503
Task size:       744 KB
  Thread 0x15ca             DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  main + 147 (com.apple.notificationcenterui.WeatherSummary + 6316) [0x10c8a78ac] 1-10
  Binary Images:
           0x10c8a6000 -        0x10c8a8fff  com.apple.notificationcenterui.WeatherSummary 1.0 (552.27) <BFCC76C3-A7E0-359C-AB2C-41920F28997D>  /System/Library/CoreServices/NotificationCenter.app/Contents/XPCServices/com.apple.notificationcenterui.WeatherSummary.xpc/Contents/MacOS/com.apple.notificationcenterui.WeatherSummary
Process:         com.apple.PerformanceAnalysis.animationperfd [247]
Path:            /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/XPCServices/com.apple.PerformanceAnalysis.animationperfd.xpc/Contents/MacOS/com.apple.PerformanceAnalysis.animationperfd
Parent:          launchd [1]
UID:             0
Task size:       5264 KB
Note:            3 idle work queue threads omitted
  Thread 0x7d9              DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x10d590000 -        0x10d599fff  com.apple.PerformanceAnalysis.animationperfd 1.2 (2) <E1044B93-AC85-3D33-AF9A-9FD17D274584>  /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/XPCServices/com.apple.PerformanceAnalysis.animationperfd.xpc/Contents/MacOS/com.apple.PerformanceAnalysis.animationperfd
Process:         com.apple.PhotoIngestService [1038]
Path:            /System/Library/PrivateFrameworks/PhotoLibrary.framework/Versions/A/XPCServices/com.apple.PhotoIngestService.xpc/Contents/MacOS/com.apple.PhotoIngestService
Parent:          launchd [1]
Responsible:     cloudphotosd [374]
UID:             503
Task size:       860 KB
  Thread 0x2180             10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x1054e9000 -        0x1054f1fff  com.apple.PhotoIngestService 2.0 (3150.4.120) <EC18FB2E-5E2E-36AD-B976-4D52E040A633>  /System/Library/PrivateFrameworks/PhotoLibrary.framework/Versions/A/XPCServices/com.apple.PhotoIngestService.xpc/Contents/MacOS/com.apple.PhotoIngestService
Process:         com.apple.photomodel [96729]
Path:            /System/Library/PrivateFrameworks/PhotoLibraryPrivate.framework/Versions/A/Frameworks/PhotoLibraryServices.framework/Versions/A/XPCServices/com.apple.photomodel.xpc/Contents/MacOS/com.apple.photomodel
Parent:          launchd [1]
Responsible:     photolibraryd [458]
UID:             503
Task size:       1072 KB
Note:            1 idle work queue threads omitted
  Thread 0x2327fa           10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x10a730000 -        0x10a734fff  com.apple.photomodel 2.0 (3150.4.120) <32DE6235-68B4-333F-977B-EF8A5C2CEEDD>  /System/Library/PrivateFrameworks/PhotoLibraryPrivate.framework/Versions/A/Frameworks/PhotoLibraryServices.framework/Versions/A/XPCServices/com.apple.photomodel.xpc/Contents/MacOS/com.apple.photomodel
Process:         com.apple.photomoments [937]
Path:            /System/Library/PrivateFrameworks/PhotoLibraryPrivate.framework/Versions/A/Frameworks/PhotoLibraryServices.framework/Versions/A/XPCServices/com.apple.photomoments.xpc/Contents/MacOS/com.apple.photomoments
Parent:          launchd [1]
UID:             503
Task size:       2160 KB
  Thread 0x1f42             DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  main + 502 (com.apple.photomoments + 6307) [0x105ef18a3] 1-10
  Thread 0x2172             Thread name "NetworkLoad" 10 samples (1-10)         priority 4 (base 4)
  10  <truncated backtrace> 1-10
  Thread 0x1d3865           Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x105ef0000 -        0x105ef5fff  com.apple.photomoments 2.0 (3150.4.120) <B4C51E10-772C-3A4A-9601-11FF55EC3E23>  /System/Library/PrivateFrameworks/PhotoLibraryPrivate.framework/Versions/A/Frameworks/PhotoLibraryServices.framework/Versions/A/XPCServices/com.apple.photomoments.xpc/Contents/MacOS/com.apple.photomoments
Process:         com.apple.Preview.TrustedBookmarksService [474]
Path:            /Applications/Preview.app/Contents/XPCServices/com.apple.Preview.TrustedBookmarksService.xpc/Contents/MacOS/com.apple.Preview.TrustedBookmarksService
Parent:          launchd [1]
Responsible:     Preview [342]
UID:             503
Task size:       372 KB
  Thread 0x1237             10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x102bcd000 -        0x102bcffff  com.apple.Preview.TrustedBookmarksService 1.2 (1) <1F6E52D3-09C9-378E-A078-469904D68561>  /Applications/Preview.app/Contents/XPCServices/com.apple.Preview.TrustedBookmarksService.xpc/Contents/MacOS/com.apple.Preview.TrustedBookmarksService
Process:         com.apple.quicklook.ThumbnailsAgent [371]
Path:            /System/Library/PrivateFrameworks/QuickLookThumbnailing.framework/Support/com.apple.quicklook.ThumbnailsAgent
Parent:          launchd [1]
UID:             503
Task size:       1940 KB
  Thread 0xd0e              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  ??? (com.apple.quicklook.ThumbnailsAgent + 41096) [0x101e24088] 1-10
  Binary Images:
           0x101e1a000 -        0x101e29fff  com.apple.quicklook.ThumbnailsAgent (14.1) <D0787288-3D64-37FE-8AA0-AC62958E5D9E>  /System/Library/PrivateFrameworks/QuickLookThumbnailing.framework/Support/com.apple.quicklook.ThumbnailsAgent
Process:         com.apple.Safari.History [620]
Path:            /System/Library/PrivateFrameworks/SafariShared.framework/Versions/A/XPCServices/com.apple.Safari.History.xpc/Contents/MacOS/com.apple.Safari.History
Parent:          launchd [1]
UID:             503
Task size:       5032 KB
  Thread 0x177f             DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  ??? (com.apple.Safari.History + 2313) [0x10c3df909] 1-10
      10  WBSHistoryServiceMain + 77 (SafariShared + 1033594) [0x7fffe153a57a] 1-10
  Thread 0x1d51             10 samples (1-10)         priority 4 (base 4)
        10  void* std::__1::__thread_proxy<std::__1::tuple<void (*)(bmalloc::AsyncTask<bmalloc::Heap, void (bmalloc::Heap::*)()>*), bmalloc::AsyncTask<bmalloc::Heap, void (bmalloc::Heap::*)()>*> >(void*) + 93 (JavaScriptCore + 12002381) [0x7fffd2e7344d] 1-10
          10  bmalloc::AsyncTask<bmalloc::Heap, void (bmalloc::Heap::*)()>::threadEntryPoint(bmalloc::AsyncTask<bmalloc::Heap, void (bmalloc::Heap::*)()>*) + 29 (JavaScriptCore + 12001693) [0x7fffd2e7319d] 1-10
            10  bmalloc::AsyncTask<bmalloc::Heap, void (bmalloc::Heap::*)()>::threadRunLoop() + 155 (JavaScriptCore + 12001995) [0x7fffd2e732cb] 1-10
              10  void std::__1::condition_variable_any::wait<std::__1::unique_lock<bmalloc::Mutex> >(std::__1::unique_lock<bmalloc::Mutex>&) + 108 (JavaScriptCore + 12002124) [0x7fffd2e7334c] 1-10
                10  std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 47 (libc++.1.dylib + 29901) [0x7fffe41664cd] 1-10
                  10  __psynch_cvwait + 10 (libsystem_kernel.dylib + 105458) [0x7fffe56fbbf2] 1-10
                   *10  psynch_cvcontinue + 0 (pthread + 38973) [0xffffff7f8135f83d] 1-10
  Binary Images:
           0x10c3df000 -        0x10c3dffff  com.apple.Safari.History 12603 (12603.1.30.0.34) <59A2B232-DC88-3409-8987-09DDEC59B2A4>  /System/Library/PrivateFrameworks/SafariShared.framework/Versions/A/XPCServices/com.apple.Safari.History.xpc/Contents/MacOS/com.apple.Safari.History
        0x7fffd2301000 -     0x7fffd2f09fff  com.apple.JavaScriptCore 12603 (12603.1.30.0.34) <42993DA4-E18A-3A41-86F8-23A6656273F9>  /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
        0x7fffe143e000 -     0x7fffe177dfff  com.apple.Safari.Shared 12603 (12603.1.30.0.34)  <57945A48-56AD-315D-8747-036EC9A76E0C>  /System/Library/PrivateFrameworks/SafariShared.framework/Versions/A/SafariShared
        0x7fffe415f000 -     0x7fffe41b5fff  libc++.1.dylib (307.5)                           <0B43BB5D-E6EB-3464-8DE9-B41AC8ED9D1C>  /usr/lib/libc++.1.dylib
        0x7fffe57e3000 -     0x7fffe57edfff  libsystem_pthread.dylib (218.51.1)               <62A84A68-431D-3B54-A7B6-31367CCF2884>  /usr/lib/system/libsystem_pthread.dylib
   *0xffffff7f81356000 - 0xffffff7f81361fff  com.apple.kec.pthread 1.0 (1)                    <4EFF2F70-C9B9-3176-BF83-F1B660C42135>  /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread
Process:         com.apple.Safari.ImageDecoder [12641]
Path:            /System/Library/PrivateFrameworks/SafariShared.framework/Versions/A/XPCServices/com.apple.Safari.ImageDecoder.xpc/Contents/MacOS/com.apple.Safari.ImageDecoder
Parent:          launchd [1]
UID:             503
Task size:       912 KB
  Thread 0x6015a            DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  ??? (com.apple.Safari.ImageDecoder + 6550) [0x103af6996] 1-10
            10  -[NSRunLoop(NSRunLoop) run] + 76 (Foundation + 140362) [0x7fffd187c44a] 1-10
              10  -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 277 (Foundation + 140658) [0x7fffd187c572] 1-10
  Binary Images:
           0x103af5000 -        0x103af6fff  com.apple.Safari.ImageDecoder 12603 (12603.1.30.0.34) <9D41229D-27CE-33E5-8C94-F3D790B03B5A>  /System/Library/PrivateFrameworks/SafariShared.framework/Versions/A/XPCServices/com.apple.Safari.ImageDecoder.xpc/Contents/MacOS/com.apple.Safari.ImageDecoder
Process:         com.apple.Safari.SafeBrowsing.Service [2860]
Path:            /System/Library/PrivateFrameworks/SafariSafeBrowsing.framework/Versions/A/com.apple.Safari.SafeBrowsing.Service
Parent:          launchd [1]
UID:             503
Task size:       1772 KB
  Thread 0xf6d0             10 samples (1-10)         priority 4 (base 4)
  Thread 0x61e48            Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x105a68000 -        0x105a68fff  com.apple.Safari.SafeBrowsing.Service (7603.1.30.0.34) <850386CF-46C1-3F7F-9680-B22A722454D5>  /System/Library/PrivateFrameworks/SafariSafeBrowsing.framework/Versions/A/com.apple.Safari.SafeBrowsing.Service
Process:         com.apple.Safari.SearchHelper [12620]
Path:            /System/Library/PrivateFrameworks/SafariShared.framework/Versions/A/XPCServices/com.apple.Safari.SearchHelper.xpc/Contents/MacOS/com.apple.Safari.SearchHelper
Parent:          launchd [1]
UID:             503
Task size:       6628 KB
  Thread 0x60091            DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  ??? (com.apple.Safari.SearchHelper + 7075) [0x10f7d4ba3] 1-10
  Thread 0x60098            Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x10f7d3000 -        0x10f7d9fff  com.apple.Safari.SearchHelper 12603 (12603.1.30.0.34) <121B875A-6877-33AA-ACFA-9DB882C04611>  /System/Library/PrivateFrameworks/SafariShared.framework/Versions/A/XPCServices/com.apple.Safari.SearchHelper.xpc/Contents/MacOS/com.apple.Safari.SearchHelper
        0x7fffcefa2000 -     0x7fffcf37cfff  com.apple.CFNetwork 811.4.18 (811.4.18)               <9CE329E8-6177-3474-976D-F5C63FC875CD>  /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
Process:         com.apple.SafariServices [840]
Path:            /System/Library/Frameworks/SafariServices.framework/Versions/A/XPCServices/com.apple.SafariServices.xpc/Contents/MacOS/com.apple.SafariServices
Parent:          launchd [1]
UID:             503
Task size:       740 KB
  Thread 0x1cc6             DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  main + 16 (com.apple.SafariServices + 5426) [0x109464532] 1-10
  Binary Images:
           0x109463000 -        0x109465fff  com.apple.SafariServices 12603 (12603.1.30.0.34) <497E71C7-F37B-3995-A51D-B23AFA0B66BF>  /System/Library/Frameworks/SafariServices.framework/Versions/A/XPCServices/com.apple.SafariServices.xpc/Contents/MacOS/com.apple.SafariServices
Process:         com.apple.sbd [16465]
Path:            /System/Library/PrivateFrameworks/CloudServices.framework/Versions/A/XPCServices/com.apple.sbd.xpc/Contents/MacOS/com.apple.sbd
Parent:          launchd [1]
UID:             503
Task size:       6392 KB
  Thread 0x88f73            DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
    10  ??? (com.apple.sbd + 205787) [0x104f583db] 1-10
  Thread 0x88f90            Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x104f26000 -        0x104f70fff  com.apple.sbd 1.0 (222.51.1)           <BC39E313-2FC1-3C24-AEDC-617165CE605E>  /System/Library/PrivateFrameworks/CloudServices.framework/Versions/A/XPCServices/com.apple.sbd.xpc/Contents/MacOS/com.apple.sbd
Process:         com.apple.speech.speechsynthesisd [65984]
Path:            /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/Resources/com.apple.speech.speechsynthesisd
Parent:          launchd [1]
UID:             503
Task size:       2688 KB
  Thread 0x17453e           DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
  <thread QoS default (requested default), process sudden termination clean, IO tier 0>
    10  ??? (com.apple.speech.speechsynthesisd + 4317) [0x101ec30dd] 1-10
  Binary Images:
           0x101ec2000 -        0x101ed3fff  com.apple.speech.speechsynthesisd (6.3.3) <4F06A371-5B76-3B08-8F4E-1396325EBBA3>  /System/Library/Frameworks/ApplicationServices.framework/Frameworks/SpeechSynthesis.framework/Resources/com.apple.speech.speechsynthesisd
   *0xffffff8000200000 - 0xffffff80009fffff  kernel (3789.51.2)                        <06F94FD7-451F-34A1-B13C-D68FF7EDE0A0>  /System/Library/Kernels/kernel
Process:         com.apple.spotlight.IndexAgent [483]
Path:            /System/Library/PrivateFrameworks/CoreSpotlight.framework/Support/com.apple.spotlight.IndexAgent
Parent:          launchd [1]
UID:             503
Task size:       2720 KB
  Thread 0x1396             DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
  <thread QoS background (requested background), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2>
    10  ??? (com.apple.spotlight.IndexAgent + 6487) [0x10719f957] 1-10
  Binary Images:
           0x10719e000 -        0x10719ffff  com.apple.spotlight.IndexAgent (144)   <A9703E1E-BB4A-374B-8D67-52EB6E24BBDA>  /System/Library/PrivateFrameworks/CoreSpotlight.framework/Support/com.apple.spotlight.IndexAgent
Process:         com.apple.WeatherKitService [834]
Path:            /System/Library/PrivateFrameworks/WeatherKit.framework/Versions/A/XPCServices/com.apple.WeatherKitService.xpc/Contents/MacOS/com.apple.WeatherKitService
Parent:          launchd [1]
UID:             503
Task size:       1600 KB
  Thread 0x1c84             10 samples (1-10)         priority 4 (base 4)
    10  __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 106982) [0x7fffe56fc1e6] 1-10
  Thread 0x1c91             Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4 (base 4)
  Binary Images:
           0x107e34000 -        0x107e52fff  com.apple.WeatherKitService 2.0 (153)  <9842A92C-1EC6-35E7-AEED-97F9A2D2D34F>  /System/Library/PrivateFrameworks/WeatherKit.framework/Versions/A/XPCServices/com.apple.WeatherKitService.xpc/Contents/MacOS/com.apple.WeatherKitService
Process:         com.apple.WebKit.Databases [2907]
Path:            /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.Databases.xpc/Contents/MacOS/com.apple.WebKit.Databases
Parent:          launchd [1]
UID:             503
Task size:       1388 KB
  Thread 0xf9de             DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
  <thread QoS default (requested default), process sudden termination dirty, process unclamped, process received importance donation from Safari [2846], IO tier 0>
    10  ??? (com.apple.WebKit.Databases + 6050) [0x102c647a2] 1-10
  Thread 0xf9e5             10 samples (1-10)         priority 37 (base 37)
  <thread QoS user initiated (requested user interactive), process sudden termination dirty, process unclamped, process received importance donation from Safari [2846], IO tier 0>
  Thread 0xf9f9             Thread name "IndexedDatabase Server"                10 samples (1-10)         priority 37 (base 37)
  <thread QoS user initiated (requested user initiated), process sudden termination dirty, process unclamped, process received importance donation from Safari [2846], IO tier 0>
  Binary Images:
           0x102c63000 -        0x102c64fff  com.apple.WebKit.Databases 12603 (12603.1.30.0.34) <7E736085-35E9-34DF-9562-DC20DBD00230>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.Databases.xpc/Contents/MacOS/com.apple.WebKit.Databases
Process:         com.apple.WebKit.Networking [846]
Path:            /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.Networking.xpc/Contents/MacOS/com.apple.WebKit.Networking
Parent:          launchd [1]
UID:             503
Task size:       2564 KB
  Thread 0x1ce8             DispatchQueue 1           10 samples (1-10)         priority 37 (base 37)
  <thread QoS user initiated (requested user initiated), process sudden termination dirty, process unclamped, process received importance donation from Spotlight [434], IO tier 0>
    10  ??? (com.apple.WebKit.Networking + 6050) [0x10ce577a2] 1-10
  Thread 0x1cfa             10 samples (1-10)         priority 37 (base 37)
  <thread QoS user initiated (requested user interactive), process sudden termination dirty, process unclamped, process received importance donation from Spotlight [434], IO tier 0>
  Thread 0x1d09             Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 37 (base 37)
  Thread 0xbf99d            Thread name "com.apple.CFNetwork.CustomProtocols"   10 samples (1-10)         priority 31 (base 31)
  <thread QoS default (requested default), process sudden termination dirty, process unclamped, process received importance donation from Spotlight [434], IO tier 0>
  Binary Images:
           0x10ce56000 -        0x10ce57fff  com.apple.WebKit.Networking 12603 (12603.1.30.0.34) <571EFBD1-6B28-3968-8AAE-14C61BBD30B1>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.Networking.xpc/Contents/MacOS/com.apple.WebKit.Networking
Process:         com.apple.WebKit.Networking [2851]
Parent:          launchd [1]
UID:             503
Task size:       30.25 MB
CPU Time:        <0.001
  Thread 0xf658             DispatchQueue 1           10 samples (1-10)         priority 37 (base 37)     cpu time <0.001
    10  ??? (com.apple.WebKit.Networking + 6050) [0x104f7b7a2] 1-10
  Thread 0xf660             10 samples (1-10)         priority 37 (base 37)
  Thread 0xf6aa             Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 37 (base 37)
  Thread 0x8fcbe            Thread name "WebCore: AsyncFileStream"              10 samples (1-10)         priority 37 (base 37)
  Thread 0x9268c            Thread name "com.apple.CFNetwork.CustomProtocols"   10 samples (1-10)         priority 31 (base 31)
  Binary Images:
           0x104f7a000 -        0x104f7bfff  com.apple.WebKit.Networking 12603 (12603.1.30.0.34) <571EFBD1-6B28-3968-8AAE-14C61BBD30B1>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.Networking.xpc/Contents/MacOS/com.apple.WebKit.Networking
Process:         com.apple.WebKit.Networking [27775]
Parent:          launchd [1]
UID:             503
Task size:       11.69 MB
  Thread 0xc621a            DispatchQueue 1           10 samples (1-10)         priority 37 (base 37)
  <thread QoS user initiated (requested user initiated), process sudden termination dirty, process unclamped, process received importance donation from Mail [27767], IO tier 0>
    10  ??? (com.apple.WebKit.Networking + 6050) [0x1008227a2] 1-10
  Thread 0xc6228            10 samples (1-10)         priority 37 (base 37)
  <thread QoS user initiated (requested user interactive), process sudden termination dirty, process unclamped, process received importance donation from Mail [27767], IO tier 0>
  Thread 0xc6234            Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 37 (base 37)
  Thread 0xd91ad            Thread name "com.apple.CFNetwork.CustomProtocols"   10 samples (1-10)         priority 31 (base 31)
  <thread QoS default (requested default), process sudden termination dirty, process unclamped, process received importance donation from Mail [27767], IO tier 0>
        10  _privateRunloopEmulationSet(void*) + 258 (CFNetwork + 2423154) [0x7fffcf1f1972] 1-10
  Binary Images:
           0x100821000 -        0x100822fff  com.apple.WebKit.Networking 12603 (12603.1.30.0.34) <571EFBD1-6B28-3968-8AAE-14C61BBD30B1>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.Networking.xpc/Contents/MacOS/com.apple.WebKit.Networking
Process:         com.apple.WebKit.Plugin.64 [87887]
Path:            /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.Plugin.64.xpc/Contents/MacOS/com.apple.WebKit.Plugin.64
Parent:          launchd [1]
UID:             503
Task size:       22.84 MB
CPU Time:        0.021
  Thread 0x1fa981           DispatchQueue 1           10 samples (1-10)         priority 4-46 (base 4-46) cpu time 0.021
  <thread QoS user interactive (requested user interactive), process sudden termination dirty, process unclamped, process received importance donation from WindowServer [198], IO tier 0, priority 46 (46)>
    10  ??? (com.apple.WebKit.Plugin.64 + 6050) [0x1096227a2] 1-10
              10  -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 2796 (AppKit + 8136798) [0x7fffce0e285e] 1-10
                10  _DPSNextEvent + 1120 (AppKit + 290340) [0x7fffcd966e24] 1-10
                  10  _BlockUntilNextEventMatchingListInModeWithFilter + 71 (HIToolbox + 199462) [0x7fffcf3cbb26] 1-10
                    10  ReceiveNextEventCommon + 432 (HIToolbox + 199921) [0x7fffcf3cbcf1] 1-10
                      10  RunCurrentEventLoopInMode + 240 (HIToolbox + 200380) [0x7fffcf3cbebc] 1-10
                          1  __CFRunLoopRun + 2065 (CoreFoundation + 556081) [0x7fffcfe6ac31] 1
                            1  __CFRunLoopDoTimers + 298 (CoreFoundation + 591082) [0x7fffcfe734ea] 1
                              1  __CFRunLoopDoTimer + 1071 (CoreFoundation + 592271) [0x7fffcfe7398f] 1
                                1  __CFRUNLOOP_IS_CALLING_OUT_TO_A_TIMER_CALLBACK_FUNCTION__ + 20 (CoreFoundation + 593156) [0x7fffcfe73d04] 1
                                  1  ??? (Acrobat + 1573964) [0x10dd8044c] 1
                                    1  ??? (Acrobat + 1152272) [0x10dd19510] 1
                                      1  -[NSApplication(NSScripting) _orderedWindowsWithPanels:] + 229 (AppKit + 1493169) [0x7fffcda8c8b1] 1
                                        1  NSWindowList + 48 (AppKit + 321990) [0x7fffcd96e9c6] 1
                                          1  NSCGSOnScreenWindowsForConnectionID + 210 (AppKit + 10003015) [0x7fffce2aa247] 1
                                            1  +[NSCGSWindow(NSCGSWindowCreation) windowWithWindowID:] + 117 (AppKit + 1498695) [0x7fffcda8de47] 1
                                              1  -[_NSCGSWindow initWithWindowID:] + 94 (AppKit + 11376595) [0x7fffce3f97d3] 1
                                                1  _GetWindowRightHolder + 143 (SkyLight + 1988579) [0x7fffe1ac07e3] 1
                                                  1  mach_msg_trap + 10 (libsystem_kernel.dylib + 74570) [0x7fffe56f434a] 1
                                                   *1  ipc_mqueue_receive_continue + 0 (kernel + 862304) [0xffffff80002d2860] 1
  <process dropped importance donation from WindowServer [198]>
                          9  __CFRunLoopRun + 1361 (CoreFoundation + 555377) [0x7fffcfe6a971] 2-10
                            9  __CFRunLoopServiceMachPort + 212 (CoreFoundation + 558308) [0x7fffcfe6b4e4] 2-10
                              9  mach_msg_trap + 10 (libsystem_kernel.dylib + 74570) [0x7fffe56f434a] 2-10
                               *6  ipc_mqueue_receive_continue + 0 (kernel + 862304) [0xffffff80002d2860] 2-7
                               *3  ipc_mqueue_receive_continue + 0 (kernel + 862304) [0xffffff80002d2860] 8-10
  Thread 0x1fa990           DispatchQueue 151         10 samples (1-10)         priority 4-46 (base 4-46) cpu time <0.001
        10  _dispatch_root_queue_drain + 476 (libdispatch.dylib + 14005) [0x7fffe55996b5] 1-10
          10  _dispatch_queue_invoke + 1046 (libdispatch.dylib + 41734) [0x7fffe55a0306] 1-10
            10  _dispatch_queue_serial_drain + 896 (libdispatch.dylib + 96672) [0x7fffe55ad9a0] 1-10
                10  __NSOQSchedule_f + 201 (Foundation + 255227) [0x7fffd18984fb] 1-10
                  10  -[__NSOperationInternal _start:] + 672 (Foundation + 271940) [0x7fffd189c644] 1-10
                    10  ??? (Acrobat + 17128887) [0x10ec55db7] 1-10
                      10  +[NSThread sleepForTimeInterval:] + 156 (Foundation + 904011) [0x7fffd1936b4b] 1-10
                        10  __semwait_signal + 10 (libsystem_kernel.dylib + 106310) [0x7fffe56fbf46] 1-10
                         *1  semaphore_wait_continue + 0 (kernel + 1118912) [0xffffff80003112c0] 1
                         *6  semaphore_wait_continue + 0 (kernel + 1118912) [0xffffff80003112c0] 2-7
                         *3  semaphore_wait_continue + 0 (kernel + 1118912) [0xffffff80003112c0] 8-10
  Thread 0x1fa9a2           Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 4-46 (base 4-46)
  Thread 0x1fa9a5           10 samples (1-10)         priority 4-46 (base 4-46)
     *1  psynch_cvcontinue + 0 (pthread + 38973) [0xffffff7f8135f83d] 1
     *6  psynch_cvcontinue + 0 (pthread + 38973) [0xffffff7f8135f83d] 2-7
     *3  psynch_cvcontinue + 0 (pthread + 38973) [0xffffff7f8135f83d] 8-10
  Thread 0x1fa9a6           10 samples (1-10)         priority 4-31 (base 4-31)
  <thread QoS default (requested default), process sudden termination dirty, process unclamped, process received importance donation from WindowServer [198], IO tier 0, priority 31 (31)>
  Thread 0x1fa9a7           10 samples (1-10)         priority 4-31 (base 4-31)
  Thread 0x1fa9a8           10 samples (1-10)         priority 4-31 (base 4-31)
  Thread 0x1fa9e8           10 samples (1-10)         priority 4-31 (base 4-31)
    10  semaphore_wait_trap + 10 (libsystem_kernel.dylib + 74630) [0x7fffe56f4386] 1-10
  Thread 0x1fa9e9           10 samples (1-10)         priority 4-31 (base 4-31)
  Thread 0x1fa9ea           10 samples (1-10)         priority 4-31 (base 4-31)
  Thread 0x1fa9eb           10 samples (1-10)         priority 4-31 (base 4-31)
  Thread 0x1fa9ec           10 samples (1-10)         priority 4-31 (base 4-31)
  Thread 0x1fa9ed           10 samples (1-10)         priority 4-31 (base 4-31)
  Thread 0x1fa9ee           10 samples (1-10)         priority 4-31 (base 4-31)
  Thread 0x1fa9ef           10 samples (1-10)         priority 4-31 (base 4-31)
  Thread 0x1faa14           10 samples (1-10)         priority 4-31 (base 4-31)
  <process sudden termination dirty, process unclamped, process received importance donation from WindowServer [198], IO tier 0, priority 31 (31)>
    10  kevent + 10 (libsystem_kernel.dylib + 109974) [0x7fffe56fcd96] 1-10
     *1  ??? (kernel + 5627984) [0xffffff800075e050] 1
     *6  ??? (kernel + 5627984) [0xffffff800075e050] 2-7
     *3  ??? (kernel + 5627984) [0xffffff800075e050] 8-10
  Thread 0x1faa59           10 samples (1-10)         priority 4-31 (base 4-31)
  Thread 0x1faae5           10 samples (1-10)         priority 4-31 (base 4-31)
          10  ??? (EFS + 104879) [0x11214a9af] 1-10
  Thread 0x1faaea           Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4-37 (base 4-37)
  <thread QoS user initiated (requested user initiated), process sudden termination dirty, process unclamped, process received importance donation from WindowServer [198], IO tier 0, priority 37 (37)>
  Binary Images:
           0x109621000 -        0x109622fff  com.apple.WebKit.Plugin.64 12603 (12603.1.30.0.34)      <5FBEBABE-BA92-359A-8AFD-B13D9DB6658C>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.Plugin.64.xpc/Contents/MacOS/com.apple.WebKit.Plugin.64
           0x10dc00000 -        0x10fe7ffff  com.adobe.Acrobat.framework 15.023.20056 (15.023.20056) <65042F30-9BDE-3916-AB0B-A67C5533C2D6>  /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/Acrobat.framework/Acrobat
           0x112131000 -        0x112153fff  com.adobe.AcrobatPlugin.EFS 15.023.20053 (15.023.20053) <0CA8EF99-20C8-3DFB-938D-757A680C0284>  /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Plugins/EFS.acroplugin/Contents/MacOS/EFS
        0x7fffcd920000 -     0x7fffce6f9fff  com.apple.AppKit 6.9 (1504.82.104)                      <C295FF09-9984-34C3-953B-B263EF2107AB>  /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
        0x7fffcf39b000 -     0x7fffcf6a4fff  com.apple.HIToolbox 2.1.1 (857.8)                       <40254D9A-E477-3F33-B2A2-807D399BF71C>  /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
        0x7fffe18db000 -     0x7fffe1b41fff  com.apple.SkyLight 1.600.0 (160.40)                     <BA7B7ACC-1B91-3E87-92EC-1C2969EF7088>  /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
        0x7fffe5596000 -     0x7fffe55c7fff  libdispatch.dylib (703.50.37)                           <D122E712-9593-31CA-BAC4-4A54410BF4A0>  /usr/lib/system/libdispatch.dylib
Process:         com.apple.WebKit.WebContent [68835]
Path:            /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
Parent:          launchd [1]
UID:             503
Task size:       10.50 MB
Note:            2 idle work queue threads omitted
  Thread 0x18278b           DispatchQueue 1           10 samples (1-10)         priority 4-46 (base 4-46)
  <thread QoS user interactive (requested user interactive), process sudden termination dirty, process unclamped, IO tier 0, priority 46 (46)>
    10  ??? (com.apple.WebKit.WebContent + 6050) [0x1065fa7a2] 1-10
                               *7  ipc_mqueue_receive_continue + 0 (kernel + 862304) [0xffffff80002d2860] 1-7
  Thread 0x18279f           Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 4-46 (base 4-46)
  Thread 0x1827a0           10 samples (1-10)         priority 4-46 (base 4-46)
     *7  psynch_cvcontinue + 0 (pthread + 38973) [0xffffff7f8135f83d] 1-7
  Thread 0x1827a2           Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4-37 (base 4-37)
  <thread QoS user initiated (requested user initiated), process sudden termination dirty, process unclamped, IO tier 0, priority 37 (37)>
  Thread 0x1827a8           Thread name "WebCore: Scrolling"                    10 samples (1-10)         priority 4-46 (base 4-46)
  Binary Images:
           0x1065f9000 -        0x1065fafff  com.apple.WebKit.WebContent 12603 (12603.1.30.0.34) <2F32DA20-F06C-340B-8F8A-A3FC8F85C19F>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
Process:         com.apple.WebKit.WebContent [69708]
Parent:          launchd [1]
UID:             503
Task size:       8832 KB
  Thread 0x1882ea           DispatchQueue 1           10 samples (1-10)         priority 4-46 (base 4-46)
    10  ??? (com.apple.WebKit.WebContent + 6050) [0x101ba67a2] 1-10
  Thread 0x188309           Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 4-46 (base 4-46)
  Thread 0x18830f           10 samples (1-10)         priority 4-46 (base 4-46)
  Thread 0x188314           Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4-37 (base 4-37)
  Thread 0x188315           Thread name "WebCore: Scrolling"                    10 samples (1-10)         priority 4-46 (base 4-46)
  Binary Images:
           0x101ba5000 -        0x101ba6fff  com.apple.WebKit.WebContent 12603 (12603.1.30.0.34) <2F32DA20-F06C-340B-8F8A-A3FC8F85C19F>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
Process:         com.apple.WebKit.WebContent [69709]
Parent:          launchd [1]
UID:             503
Task size:       10.63 MB
  Thread 0x1882e9           DispatchQueue 1           10 samples (1-10)         priority 4-46 (base 4-46)
    10  ??? (com.apple.WebKit.WebContent + 6050) [0x106a727a2] 1-10
  Thread 0x188308           Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 4-46 (base 4-46)
  Thread 0x18830e           10 samples (1-10)         priority 4-46 (base 4-46)
  Thread 0x188313           Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4-37 (base 4-37)
  Thread 0x188316           Thread name "WebCore: Scrolling"                    10 samples (1-10)         priority 4-46 (base 4-46)
  Binary Images:
           0x106a71000 -        0x106a72fff  com.apple.WebKit.WebContent 12603 (12603.1.30.0.34) <2F32DA20-F06C-340B-8F8A-A3FC8F85C19F>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
Process:         com.apple.WebKit.WebContent [85451]
Parent:          launchd [1]
UID:             503
Task size:       22.66 MB
  Thread 0x1ecdcf           DispatchQueue 1           10 samples (1-10)         priority 4-46 (base 4-46)
    10  ??? (com.apple.WebKit.WebContent + 6050) [0x1084077a2] 1-10
  Thread 0x1ecdeb           Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 4-46 (base 4-46)
  Thread 0x1ecdec           10 samples (1-10)         priority 4-46 (base 4-46)
  Thread 0x1ecdf1           Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4-37 (base 4-37)
  Thread 0x1ece00           Thread name "WebCore: Scrolling"                    10 samples (1-10)         priority 4-46 (base 4-46)
  Binary Images:
           0x108406000 -        0x108407fff  com.apple.WebKit.WebContent 12603 (12603.1.30.0.34) <2F32DA20-F06C-340B-8F8A-A3FC8F85C19F>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
        0x7fffe5816000 -     0x7fffe583ffff  libxpc.dylib (972.50.27)                            <ABC45890-DA23-3A4A-B50B-1384BD4CBBDF>  /usr/lib/system/libxpc.dylib
Process:         com.apple.WebKit.WebContent [85478]
Parent:          launchd [1]
UID:             503
Task size:       10.77 MB
  Thread 0x1ecfa4           DispatchQueue 1           10 samples (1-10)         priority 4-46 (base 4-46)
    10  ??? (com.apple.WebKit.WebContent + 6050) [0x10eef17a2] 1-10
      10  xpc_main + 494 (libxpc.dylib + 62180) [0x7fffe58252e4] 1-10
  Thread 0x1ecfb8           Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 4-46 (base 4-46)
  Thread 0x1ecfba           10 samples (1-10)         priority 4-46 (base 4-46)
  Thread 0x1ecfbf           Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4-37 (base 4-37)
  Thread 0x1ecfc0           Thread name "WebCore: Scrolling"                    10 samples (1-10)         priority 4-46 (base 4-46)
  Binary Images:
           0x10eef0000 -        0x10eef1fff  com.apple.WebKit.WebContent 12603 (12603.1.30.0.34) <2F32DA20-F06C-340B-8F8A-A3FC8F85C19F>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
Process:         com.apple.WebKit.WebContent [85510]
Parent:          launchd [1]
UID:             503
Task size:       8652 KB
  Thread 0x1ed11a           DispatchQueue 1           10 samples (1-10)         priority 4-46 (base 4-46)
    10  ??? (com.apple.WebKit.WebContent + 6050) [0x103bd77a2] 1-10
  Thread 0x1ed129           Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 4-46 (base 4-46)
  Thread 0x1ed12a           10 samples (1-10)         priority 4-46 (base 4-46)
  Thread 0x1ed12e           Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4-37 (base 4-37)
  Thread 0x1ed146           Thread name "WebCore: Scrolling"                    10 samples (1-10)         priority 4-46 (base 4-46)
  Binary Images:
           0x103bd6000 -        0x103bd7fff  com.apple.WebKit.WebContent 12603 (12603.1.30.0.34) <2F32DA20-F06C-340B-8F8A-A3FC8F85C19F>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
Process:         com.apple.WebKit.WebContent [85528]
Parent:          launchd [1]
UID:             503
Task size:       8740 KB
  Thread 0x1ed1b5           DispatchQueue 1           10 samples (1-10)         priority 4-46 (base 4-46)
    10  ??? (com.apple.WebKit.WebContent + 6050) [0x1021667a2] 1-10
  Thread 0x1ed1b7           10 samples (1-10)         priority 4-46 (base 4-46)
  Thread 0x1ed1c7           Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 4-46 (base 4-46)
  Thread 0x1ed1c8           10 samples (1-10)         priority 4-46 (base 4-46)
  Thread 0x1ed1ce           Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4-37 (base 4-37)
  Thread 0x1ed1d0           Thread name "WebCore: Scrolling"                    10 samples (1-10)         priority 4-46 (base 4-46)
  Binary Images:
           0x102165000 -        0x102166fff  com.apple.WebKit.WebContent 12603 (12603.1.30.0.34) <2F32DA20-F06C-340B-8F8A-A3FC8F85C19F>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
Process:         com.apple.WebKit.WebContent [85543]
Parent:          launchd [1]
UID:             503
Task size:       9244 KB
  Thread 0x1ed252           DispatchQueue 1           10 samples (1-10)         priority 4-46 (base 4-46)
    10  ??? (com.apple.WebKit.WebContent + 6050) [0x10e6167a2] 1-10
  Thread 0x1ed25c           Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 4-46 (base 4-46)
  Thread 0x1ed25e           10 samples (1-10)         priority 4-46 (base 4-46)
  Thread 0x1ed262           Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4-37 (base 4-37)
  Thread 0x1ed263           Thread name "WebCore: Scrolling"                    10 samples (1-10)         priority 4-46 (base 4-46)
  Binary Images:
           0x10e615000 -        0x10e616fff  com.apple.WebKit.WebContent 12603 (12603.1.30.0.34) <2F32DA20-F06C-340B-8F8A-A3FC8F85C19F>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
Process:         com.apple.WebKit.WebContent [87183]
Parent:          launchd [1]
UID:             503
Task size:       26.96 MB
  Thread 0x1f6234           DispatchQueue 1           10 samples (1-10)         priority 4-46 (base 4-46)
    10  ??? (com.apple.WebKit.WebContent + 6050) [0x1043f97a2] 1-10
  Thread 0x1f625f           Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 4-46 (base 4-46)
  Thread 0x1f6262           10 samples (1-10)         priority 4-46 (base 4-46)
  Thread 0x1f6265           Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4-37 (base 4-37)
  Thread 0x1f626c           Thread name "WebCore: Scrolling"                    10 samples (1-10)         priority 4-46 (base 4-46)
  Binary Images:
           0x1043f8000 -        0x1043f9fff  com.apple.WebKit.WebContent 12603 (12603.1.30.0.34) <2F32DA20-F06C-340B-8F8A-A3FC8F85C19F>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
Process:         com.apple.WebKit.WebContent [87200]
Parent:          launchd [1]
UID:             503
Task size:       30.01 MB
  Thread 0x1f6490           DispatchQueue 1           10 samples (1-10)         priority 4-46 (base 4-46)
    10  ??? (com.apple.WebKit.WebContent + 6050) [0x10f3967a2] 1-10
  Thread 0x1f649f           Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 4-46 (base 4-46)
  Thread 0x1f64a3           10 samples (1-10)         priority 4-46 (base 4-46)
  Thread 0x1f64a4           Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4-37 (base 4-37)
  Thread 0x1f64c0           Thread name "WebCore: Scrolling"                    10 samples (1-10)         priority 4-46 (base 4-46)
  Binary Images:
           0x10f395000 -        0x10f396fff  com.apple.WebKit.WebContent 12603 (12603.1.30.0.34) <2F32DA20-F06C-340B-8F8A-A3FC8F85C19F>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
Process:         com.apple.WebKit.WebContent [87207]
Parent:          launchd [1]
UID:             503
Task size:       9552 KB
  Thread 0x1f6503           DispatchQueue 1           10 samples (1-10)         priority 4-46 (base 4-46)
    10  ??? (com.apple.WebKit.WebContent + 6050) [0x105b117a2] 1-10
  Thread 0x1f650f           Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 4-46 (base 4-46)
  Thread 0x1f6513           10 samples (1-10)         priority 4-46 (base 4-46)
  Thread 0x1f6514           Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4-37 (base 4-37)
  Thread 0x1f6515           Thread name "WebCore: Scrolling"                    10 samples (1-10)         priority 4-46 (base 4-46)
  Binary Images:
           0x105b10000 -        0x105b11fff  com.apple.WebKit.WebContent 12603 (12603.1.30.0.34) <2F32DA20-F06C-340B-8F8A-A3FC8F85C19F>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
Process:         com.apple.WebKit.WebContent [87425]
Parent:          launchd [1]
UID:             503
Task size:       23.39 MB
  Thread 0x1f7f53           DispatchQueue 1           10 samples (1-10)         priority 4-46 (base 4-46)
    10  ??? (com.apple.WebKit.WebContent + 6050) [0x10153e7a2] 1-10
  Thread 0x1f7f6a           Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 4-46 (base 4-46)
  Thread 0x1f7f6c           10 samples (1-10)         priority 4-46 (base 4-46)
  Thread 0x1f7f72           Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4-37 (base 4-37)
  Thread 0x1f7f73           Thread name "WebCore: Scrolling"                    10 samples (1-10)         priority 4-46 (base 4-46)
  Binary Images:
           0x10153d000 -        0x10153efff  com.apple.WebKit.WebContent 12603 (12603.1.30.0.34) <2F32DA20-F06C-340B-8F8A-A3FC8F85C19F>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
Process:         com.apple.WebKit.WebContent [87604]
Parent:          launchd [1]
UID:             503
Task size:       26.46 MB
  Thread 0x1f8f17           DispatchQueue 1           10 samples (1-10)         priority 4-46 (base 4-46)
    10  ??? (com.apple.WebKit.WebContent + 6050) [0x10c09b7a2] 1-10
  Thread 0x1f8f3d           Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 4-46 (base 4-46)
  Thread 0x1f8f41           10 samples (1-10)         priority 4-46 (base 4-46)
  Thread 0x1f8f47           Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4-37 (base 4-37)
  Thread 0x1f8f4c           Thread name "WebCore: Scrolling"                    10 samples (1-10)         priority 4-46 (base 4-46)
  Binary Images:
           0x10c09a000 -        0x10c09bfff  com.apple.WebKit.WebContent 12603 (12603.1.30.0.34) <2F32DA20-F06C-340B-8F8A-A3FC8F85C19F>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
Process:         com.apple.WebKit.WebContent [88581]
Parent:          launchd [1]
UID:             503
Task size:       8076 KB
  Thread 0x1fe5c4           DispatchQueue 1           10 samples (1-10)         priority 4-46 (base 4-46)
    10  ??? (com.apple.WebKit.WebContent + 6050) [0x1007fe7a2] 1-10
  Thread 0x1fe5d7           Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 4-46 (base 4-46)
  Thread 0x1fe5de           10 samples (1-10)         priority 4-46 (base 4-46)
  Thread 0x1fe5df           Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4-37 (base 4-37)
  Thread 0x1fe5e0           Thread name "WebCore: Scrolling"                    10 samples (1-10)         priority 4-46 (base 4-46)
  Binary Images:
           0x1007fd000 -        0x1007fefff  com.apple.WebKit.WebContent 12603 (12603.1.30.0.34) <2F32DA20-F06C-340B-8F8A-A3FC8F85C19F>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
Process:         com.apple.WebKit.WebContent [88584]
Parent:          launchd [1]
UID:             503
Task size:       12.77 MB
  Thread 0x1fe5f6           DispatchQueue 1           10 samples (1-10)         priority 4-46 (base 4-46)
    10  ??? (com.apple.WebKit.WebContent + 6050) [0x10999b7a2] 1-10
  Thread 0x1fe604           Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 4-46 (base 4-46)
  Thread 0x1fe605           10 samples (1-10)         priority 4-46 (base 4-46)
  Thread 0x1fe609           Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4-37 (base 4-37)
  <process clamped, process suppressed, timers tier 5 (throttled), IO tier 1, priority 4 (4)>
  Thread 0x1fe60b           Thread name "WebCore: Scrolling"                    10 samples (1-10)         priority 4-46 (base 4-46)
  Binary Images:
           0x10999a000 -        0x10999bfff  com.apple.WebKit.WebContent 12603 (12603.1.30.0.34) <2F32DA20-F06C-340B-8F8A-A3FC8F85C19F>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
Process:         com.apple.WebKit.WebContent [88590]
Parent:          launchd [1]
UID:             503
Task size:       9204 KB
  Thread 0x1fe65b           DispatchQueue 1           10 samples (1-10)         priority 4-46 (base 4-46)
    10  ??? (com.apple.WebKit.WebContent + 6050) [0x1070007a2] 1-10
        10  _xpc_objc_main + 775 (libxpc.dylib + 67783) [0x7fffe58268c7] 1-10
  Thread 0x1fe66c           Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 4-46 (base 4-46)
  Thread 0x1fe66d           10 samples (1-10)         priority 4-46 (base 4-46)
  Thread 0x1fe66e           Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4-37 (base 4-37)
  Thread 0x1fe67b           Thread name "WebCore: Scrolling"                    10 samples (1-10)         priority 4-46 (base 4-46)
  Binary Images:
           0x106fff000 -        0x107000fff  com.apple.WebKit.WebContent 12603 (12603.1.30.0.34) <2F32DA20-F06C-340B-8F8A-A3FC8F85C19F>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
Process:         com.apple.WebKit.WebContent [88595]
Architecture:    x86_64
Parent:          launchd [1]
UID:             503
Task size:       8164 KB
  Thread 0x1fe6e2           DispatchQueue 1           10 samples (1-10)         priority 4-46 (base 4-46)
    10  ??? (com.apple.WebKit.WebContent + 6050) [0x1058677a2] 1-10
  Thread 0x1fe6fb           Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 4-46 (base 4-46)
  Thread 0x1fe6fc           10 samples (1-10)         priority 4-46 (base 4-46)
  Thread 0x1fe6fd           Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4-37 (base 4-37)
  Thread 0x1fe6fe           Thread name "WebCore: Scrolling"                    10 samples (1-10)         priority 4-46 (base 4-46)
  Binary Images:
           0x105866000 -        0x105867fff  com.apple.WebKit.WebContent 12603 (12603.1.30.0.34) <2F32DA20-F06C-340B-8F8A-A3FC8F85C19F>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
Process:         com.apple.WebKit.WebContent [89224]
Parent:          launchd [1]
UID:             503
Task size:       10.65 MB
  Thread 0x20159d           DispatchQueue 1           10 samples (1-10)         priority 4-46 (base 4-46)
    10  ??? (com.apple.WebKit.WebContent + 6050) [0x10087f7a2] 1-10
  Thread 0x2015c5           Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 4-46 (base 4-46)
  Thread 0x2015c8           10 samples (1-10)         priority 4-46 (base 4-46)
  Thread 0x2015ce           Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4-37 (base 4-37)
  Thread 0x2015d0           Thread name "WebCore: Scrolling"                    10 samples (1-10)         priority 4-46 (base 4-46)
  Binary Images:
           0x10087e000 -        0x10087ffff  com.apple.WebKit.WebContent 12603 (12603.1.30.0.34) <2F32DA20-F06C-340B-8F8A-A3FC8F85C19F>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
Process:         com.apple.WebKit.WebContent [90504]
Parent:          launchd [1]
UID:             503
Task size:       51.07 MB
CPU Time:        <0.001
  Thread 0x20836c           DispatchQueue 1           10 samples (1-10)         priority 4-46 (base 4-46) cpu time <0.001
    10  ??? (com.apple.WebKit.WebContent + 6050) [0x1013e77a2] 1-10
  Thread 0x208398           Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 4-46 (base 4-46)
  Thread 0x20839c           10 samples (1-10)         priority 4-46 (base 4-46)
  Thread 0x20839f           Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4-37 (base 4-37)
  Thread 0x2083a8           Thread name "WebCore: Scrolling"                    10 samples (1-10)         priority 4-46 (base 4-46)
  Thread 0x208668           Thread name "com.apple.coremedia.imagequeue.coreanimation"                    10 samples (1-10)         priority 4-54 (base 4-54)
  <process sudden termination dirty, process unclamped, IO tier 0, priority 54 (54)>
        10  figThreadMain + 277 (CoreMedia + 277470) [0x7fffd0bedbde] 1-10
          10  ??? (MediaToolbox + 2147162) [0x7fffd33d435a] 1-10
            10  FigSemaphoreWaitRelative + 153 (CoreMedia + 274121) [0x7fffd0becec9] 1-10
              10  WaitOnCondition + 14 (CoreMedia + 275007) [0x7fffd0bed23f] 1-10
  Thread 0x208669           Thread name "com.apple.coremedia.videomediaconverter"                         10 samples (1-10)         priority 4-49 (base 4-49)
  <process sudden termination dirty, process unclamped, IO tier 0, priority 49 (49)>
          10  ??? (MediaToolbox + 2136766) [0x7fffd33d1abe] 1-10
  Thread 0x20866a           10 samples (1-10)         priority 4-31 (base 4-31)
  <thread QoS default (requested default), process sudden termination dirty, process unclamped, IO tier 0, priority 31 (31)>
        10  ??? (AppleGVA + 231729) [0x7fffd916c931] 1-10
          10  ??? (AppleGVA + 231938) [0x7fffd916ca02] 1-10
  Binary Images:
           0x1013e6000 -        0x1013e7fff  com.apple.WebKit.WebContent 12603 (12603.1.30.0.34) <2F32DA20-F06C-340B-8F8A-A3FC8F85C19F>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
        0x7fffd0baa000 -     0x7fffd0c5bfff  com.apple.CoreMedia 1.0 (1907.58)                   <9A25B3CA-A006-39D2-A405-194F2BBF9061>  /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
        0x7fffd31c8000 -     0x7fffd3701fff  com.apple.MediaToolbox 1.0 (1907.58)                <2BF8A414-F33A-333B-97F1-97D3807F96EB>  /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
        0x7fffd9134000 -     0x7fffd91fbfff  com.apple.AppleGVAFramework 10.1.16 (10.1.16)       <C0ACA3D7-F37F-337C-B686-CAFC53AD5D83>  /System/Library/PrivateFrameworks/AppleGVA.framework/Versions/A/AppleGVA
Process:         com.apple.WebKit.WebContent [90599]
Parent:          launchd [1]
Responsible:     Safari [2846]
UID:             503
Task size:       56.57 MB
CPU Time:        <0.001
  Thread 0x208c2f           DispatchQueue 1           10 samples (1-10)         priority 4-46 (base 4-46) cpu time <0.001
  10  start + 1 (libdyld.dylib + 21045) [0x7fffe55cd235] 1-10
    10  ??? (com.apple.WebKit.WebContent + 6050) [0x10987d7a2] 1-10
  Thread 0x208c59           Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 4-46 (base 4-46)
  Thread 0x208c5c           10 samples (1-10)         priority 4-46 (base 4-46)
  Thread 0x208c6a           Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4-37 (base 4-37)
  Thread 0x208c75           Thread name "WebCore: Scrolling"                    10 samples (1-10)         priority 4-46 (base 4-46)
  Thread 0x208e65           Thread name "com.apple.coremedia.imagequeue.coreanimation"                    10 samples (1-10)         priority 4-54 (base 4-54)
  Thread 0x208e66           Thread name "com.apple.coremedia.videomediaconverter"                         10 samples (1-10)         priority 4-49 (base 4-49)
  Thread 0x208e67           10 samples (1-10)         priority 4-31 (base 4-31)
  Binary Images:
           0x10987c000 -        0x10987dfff  com.apple.WebKit.WebContent 12603 (12603.1.30.0.34) <2F32DA20-F06C-340B-8F8A-A3FC8F85C19F>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
Process:         com.apple.WebKit.WebContent [91068]
Parent:          launchd [1]
UID:             503
Task size:       9808 KB
  Thread 0x20b811           DispatchQueue 1           10 samples (1-10)         priority 4-46 (base 4-46)
    10  ??? (com.apple.WebKit.WebContent + 6050) [0x1027b07a2] 1-10
  Thread 0x20b835           Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 4-46 (base 4-46)
  Thread 0x20b838           10 samples (1-10)         priority 4-46 (base 4-46)
  Thread 0x20b839           Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4-37 (base 4-37)
  Thread 0x20b83b           Thread name "WebCore: Scrolling"                    10 samples (1-10)         priority 4-46 (base 4-46)
  Binary Images:
           0x1027af000 -        0x1027b0fff  com.apple.WebKit.WebContent 12603 (12603.1.30.0.34) <2F32DA20-F06C-340B-8F8A-A3FC8F85C19F>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
Process:         com.apple.WebKit.WebContent [92199]
Parent:          launchd [1]
UID:             503
Task size:       68.35 MB
CPU Time:        0.002
  Thread 0x2120a4           DispatchQueue 1           10 samples (1-10)         priority 4-46 (base 4-46) cpu time <0.001
    10  ??? (com.apple.WebKit.WebContent + 6050) [0x10c52c7a2] 1-10
  Thread 0x2120d4           Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 4-46 (base 4-46)
  Thread 0x2120d8           10 samples (1-10)         priority 4-46 (base 4-46)
  Thread 0x2120df           Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4-37 (base 4-37)
  Thread 0x2120e2           Thread name "WebCore: Scrolling"                    10 samples (1-10)         priority 4-46 (base 4-46)
  Thread 0x2121d1           Thread name "com.apple.coremedia.imagequeue.coreanimation"                    10 samples (1-10)         priority 4-54 (base 4-54)
  Thread 0x2121d2           Thread name "com.apple.coremedia.videomediaconverter"                         10 samples (1-10)         priority 4-49 (base 4-49)
  Thread 0x2121d3           Thread name "com.apple.coremedia.vtremotedecompressionclient.notifier"        10 samples (1-10)         priority 4-47 (base 4-47) cpu time <0.001
  <process sudden termination dirty, process unclamped, IO tier 0, priority 47 (47)>
          10  ??? (VideoToolbox + 704848) [0x7fffd6931150] 1-10
  Thread 0x212293           Thread name "com.apple.coremedia.imagequeue.coreanimation"                    10 samples (1-10)         priority 4-54 (base 4-54) cpu time 0.001
            10  FigSemaphoreWaitRelative + 160 (CoreMedia + 274128) [0x7fffd0beced0] 1-10
              10  WaitOnConditionTimed + 85 (CoreMedia + 276136) [0x7fffd0bed6a8] 1-10
  Thread 0x212294           Thread name "com.apple.coremedia.videomediaconverter"                         10 samples (1-10)         priority 4-49 (base 4-49)
  Thread 0x2122a6           Thread name "com.apple.coremedia.vtremotedecompressionclient.notifier"        10 samples (1-10)         priority 4-47 (base 4-47) cpu time <0.001
  Binary Images:
           0x10c52b000 -        0x10c52cfff  com.apple.WebKit.WebContent 12603 (12603.1.30.0.34) <2F32DA20-F06C-340B-8F8A-A3FC8F85C19F>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
        0x7fffd6885000 -     0x7fffd6c33fff  com.apple.VideoToolbox 1.0 (1907.58)                <C0E96051-C97E-3A03-9EA7-312C0573BDE8>  /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
Process:         com.apple.WebKit.WebContent [92208]
Parent:          launchd [1]
UID:             503
Task size:       38.79 MB
CPU Time:        0.002
  Thread 0x21217c           DispatchQueue 1           10 samples (1-10)         priority 4-46 (base 4-46) cpu time <0.001
    10  ??? (com.apple.WebKit.WebContent + 6050) [0x1044d47a2] 1-10
          10  NSApplicationMain + 1237 (AppKit + 25054) [0x7fffcd9261de] 1-10
            10  -[NSApplication run] + 926 (AppKit + 243627) [0x7fffcd95b7ab] 1-10
  Thread 0x212187           Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 4-46 (base 4-46)
  Thread 0x212189           10 samples (1-10)         priority 4-46 (base 4-46)
  Thread 0x21218e           Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4-37 (base 4-37)
  Thread 0x212191           Thread name "WebCore: Scrolling"                    10 samples (1-10)         priority 4-46 (base 4-46)
  Thread 0x2121ee           Thread name "com.apple.coremedia.imagequeue.coreanimation"                    10 samples (1-10)         priority 4-54 (base 4-54) cpu time <0.001
  Thread 0x2121ef           Thread name "com.apple.coremedia.videomediaconverter"                         10 samples (1-10)         priority 4-49 (base 4-49)
  Thread 0x2121f0           10 samples (1-10)         priority 4-31 (base 4-31)
  Thread 0x212247           Thread name "com.apple.coremedia.imagequeue.coreanimation"                    10 samples (1-10)         priority 4-54 (base 4-54) cpu time <0.001
  Thread 0x212248           Thread name "com.apple.coremedia.videomediaconverter"                         10 samples (1-10)         priority 4-49 (base 4-49)
  Thread 0x212249           Thread name "com.apple.coremedia.vtremotedecompressionclient.notifier"        10 samples (1-10)         priority 4-47 (base 4-47) cpu time <0.001
  Binary Images:
           0x1044d3000 -        0x1044d4fff  com.apple.WebKit.WebContent 12603 (12603.1.30.0.34) <2F32DA20-F06C-340B-8F8A-A3FC8F85C19F>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
Process:         com.apple.WebKit.WebContent [92463]
Parent:          launchd [1]
UID:             503
Task size:       17.54 MB
  Thread 0x2138f6           DispatchQueue 1           10 samples (1-10)         priority 4-46 (base 4-46)
    10  ??? (com.apple.WebKit.WebContent + 6050) [0x10da437a2] 1-10
  Thread 0x214e10           DispatchQueue 600         10 samples (1-10)         priority 4-46 (base 4-46)
  Thread 0x214e11           DispatchQueue 601         10 samples (1-10)         priority 4-46 (base 4-46)
  Thread 0x213925           Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 4-46 (base 4-46)
  Thread 0x21392f           10 samples (1-10)         priority 4-46 (base 4-46)
  Thread 0x213930           Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4-37 (base 4-37)
  Thread 0x213932           Thread name "WebCore: Scrolling"                    10 samples (1-10)         priority 4-46 (base 4-46)
  Binary Images:
           0x10da42000 -        0x10da43fff  com.apple.WebKit.WebContent 12603 (12603.1.30.0.34) <2F32DA20-F06C-340B-8F8A-A3FC8F85C19F>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
Process:         com.apple.WebKit.WebContent [92685]
Parent:          launchd [1]
UID:             503
Task size:       12.60 MB
  Thread 0x2153b5           DispatchQueue 1           10 samples (1-10)         priority 4-46 (base 4-46)
    10  ??? (com.apple.WebKit.WebContent + 6050) [0x1066da7a2] 1-10
                        10  CFRunLoopRunSpecific + 420 (CoreFoundation + 553412) [0x7fffcfe6a1c4] 1-10
                          10  __CFRunLoopRun + 1361 (CoreFoundation + 555377) [0x7fffcfe6a971] 1-10
                            10  __CFRunLoopServiceMachPort + 212 (CoreFoundation + 558308) [0x7fffcfe6b4e4] 1-10
                              10  mach_msg_trap + 10 (libsystem_kernel.dylib + 74570) [0x7fffe56f434a] 1-10
  Thread 0x2153e6           Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 4-46 (base 4-46)
  10  thread_start + 13 (libsystem_pthread.dylib + 12545) [0x7fffe57e6101] 1-10
    10  _pthread_start + 286 (libsystem_pthread.dylib + 14587) [0x7fffe57e68fb] 1-10
      10  _pthread_body + 180 (libsystem_pthread.dylib + 14767) [0x7fffe57e69af] 1-10
        10  _NSEventThread + 205 (AppKit + 1655506) [0x7fffcdab42d2] 1-10
  Thread 0x2153e9           10 samples (1-10)         priority 4-46 (base 4-46)
  Thread 0x2153ee           Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4-37 (base 4-37)
  Thread 0x2153f0           Thread name "WebCore: Scrolling"                    10 samples (1-10)         priority 4-46 (base 4-46)
  Binary Images:
           0x1066d9000 -        0x1066dafff  com.apple.WebKit.WebContent 12603 (12603.1.30.0.34) <2F32DA20-F06C-340B-8F8A-A3FC8F85C19F>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
Process:         com.apple.WebKit.WebContent [92697]
Parent:          launchd [1]
UID:             503
Task size:       10.02 MB
  Thread 0x2155b8           DispatchQueue 1           10 samples (1-10)         priority 4-46 (base 4-46)
    10  ??? (com.apple.WebKit.WebContent + 6050) [0x10d78d7a2] 1-10
  Thread 0x2155ca           Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 4-46 (base 4-46)
  Thread 0x2155cb           10 samples (1-10)         priority 4-46 (base 4-46)
  Thread 0x2155cd           Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4-37 (base 4-37)
  Thread 0x2155ce           Thread name "WebCore: Scrolling"                    10 samples (1-10)         priority 4-46 (base 4-46)
  Binary Images:
           0x10d78c000 -        0x10d78dfff  com.apple.WebKit.WebContent 12603 (12603.1.30.0.34) <2F32DA20-F06C-340B-8F8A-A3FC8F85C19F>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
Process:         com.apple.WebKit.WebContent [92705]
Parent:          launchd [1]
UID:             503
Task size:       11.75 MB
  Thread 0x215638           DispatchQueue 1           10 samples (1-10)         priority 4-46 (base 4-46)
    10  ??? (com.apple.WebKit.WebContent + 6050) [0x1012827a2] 1-10
  Thread 0x215646           Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 4-46 (base 4-46)
  Thread 0x215647           10 samples (1-10)         priority 4-46 (base 4-46)
  Thread 0x215648           Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4-37 (base 4-37)
  Thread 0x215649           Thread name "WebCore: Scrolling"                    10 samples (1-10)         priority 4-46 (base 4-46)
  Binary Images:
           0x101281000 -        0x101282fff  com.apple.WebKit.WebContent 12603 (12603.1.30.0.34) <2F32DA20-F06C-340B-8F8A-A3FC8F85C19F>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
Process:         com.apple.WebKit.WebContent [92886]
Parent:          launchd [1]
UID:             503
Task size:       49.01 MB
CPU Time:        0.002
  Thread 0x21667d           DispatchQueue 1           10 samples (1-10)         priority 4-46 (base 4-46) cpu time <0.001
    10  ??? (com.apple.WebKit.WebContent + 6050) [0x10e0067a2] 1-10
  Thread 0x216695           Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 4-46 (base 4-46)
  Thread 0x216696           10 samples (1-10)         priority 4-46 (base 4-46) cpu time <0.001
            10  bmalloc::AsyncTask<bmalloc::Heap, void (bmalloc::Heap::*)()>::threadRunLoop() + 97 (JavaScriptCore + 12001937) [0x7fffd2e73291] 1-10
              10  bmalloc::Heap::concurrentScavenge() + 102 (JavaScriptCore + 11996166) [0x7fffd2e71c06] 1-10
                10  bmalloc::Heap::scavenge(std::__1::unique_lock<bmalloc::StaticMutex>&, std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000l> >) + 275 (JavaScriptCore + 11996755) [0x7fffd2e71e53] 1-10
                  10  std::__1::this_thread::sleep_for(std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l> > const&) + 80 (libc++.1.dylib + 296539) [0x7fffe41a765b] 1-10
                     *7  semaphore_wait_continue + 0 (kernel + 1118912) [0xffffff80003112c0] 1-7
  Thread 0x21669c           Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4-37 (base 4-37)
  Thread 0x2166aa           Thread name "WebCore: Scrolling"                    10 samples (1-10)         priority 4-46 (base 4-46)
  Thread 0x216759           Thread name "com.apple.coremedia.imagequeue.coreanimation"                    10 samples (1-10)         priority 4-54 (base 4-54) cpu time 0.001
  Thread 0x21675a           Thread name "com.apple.coremedia.videomediaconverter"                         10 samples (1-10)         priority 4-49 (base 4-49)
  Thread 0x21675b           Thread name "com.apple.coremedia.vtremotedecompressionclient.notifier"        10 samples (1-10)         priority 4-47 (base 4-47) cpu time <0.001
  Thread 0x216764           Thread name "com.apple.coremedia.imagequeue.coreanimation"                    10 samples (1-10)         priority 4-54 (base 4-54)
  Thread 0x216765           Thread name "com.apple.coremedia.videomediaconverter"                         10 samples (1-10)         priority 4-49 (base 4-49)
  Thread 0x21676c           Thread name "com.apple.coremedia.vtremotedecompressionclient.notifier"        10 samples (1-10)         priority 4-47 (base 4-47) cpu time <0.001
  Binary Images:
           0x10e005000 -        0x10e006fff  com.apple.WebKit.WebContent 12603 (12603.1.30.0.34) <2F32DA20-F06C-340B-8F8A-A3FC8F85C19F>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
        0x7fffcfde3000 -     0x7fffd027cfff  com.apple.CoreFoundation 6.9 (1349.65)              <F79384D1-FA3F-38CA-A847-B2625EBB790E>  /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
Process:         com.apple.WebKit.WebContent [92947]
Parent:          launchd [1]
UID:             503
Task size:       64.43 MB
CPU Time:        0.003
  Thread 0x216bcf           DispatchQueue 1           10 samples (1-10)         priority 4-46 (base 4-46) cpu time <0.001
    10  ??? (com.apple.WebKit.WebContent + 6050) [0x104d417a2] 1-10
