Anyone else seeing this error? (CC2015.9 Windows-10)
Has now occurred twice.
1. When Importing a folder of images using the 'ADD' option, the error tells me the destination is not available.
There is no destination!
2. When Synchronizing a folder in the Folders Panel (and allowing duplicates that exist in other folders)
again- There is no destination!
I have recently seen this error when you have had previously enabled a destination for "Make a Second Copy to:" and then when you open the Import window for subsequent Import and that 2nd hard drive/location is disconnected/unavailable resulting in the error.
If I recall it is triggered as soon as the Import window opens before you can modify your import type (Copy/Move/Add)
Well, give this a try: click on COPY, set the destination to someplace valid, go back to ADD and see if it works.
Dooooh! it is MY error
Yep I should have checked this. I had been experimenting days ago to answer a forum question.
