I am trying to generate a 3d mesh from a 2d image (easy) and then have multiple diffuse textures wrapped on it.
I cannot see how to do this, unless I'm missing something obvious.
I can duplicate the mesh and change the diffuse texture, but then I end up with multiple meshes and things look very messy.
Any suggestions?
Ian
Is there any reason why you cannot map the two (or more) textures onto a single diffuse texture using the UVs as a guide for placement?
Dave
I want to be able to switch the different textures in and out, sometimes viewing just one, sometimes viewing all.
That should not be a problem if it is just changes in the diffuse texture.
The diffuse texture opens up as a psb file. Build the various texture alternatives as layers in that psb file then switch the layer visibility on/off as required. To view on the model just hit save on the psb file (no need to close it). You could even use layer comps to switch between complex layer variations, as long as you save you will see the effect.
If your texture variation is more complex and involves simultaneous variations in bump/shine/opacity etc then , for Photoshop, duplicating the model and switching model visibility in the 3D panel is quicker.
Dave
Dave,
Thanks for the message, but I don't think that helps me.
My fault, I wasn't very clear. I want the user to be able to switch on one, more, or all of the textures, in the resulting 3D PDF.
If I understand correctly, your approach will change the visible texture in Photoshop, but not allow it to be changed in the PDF.
It still looks as if the only way I can get multiple switchable textures on the 'same' mesh is to have multiple identical meshes, with one texture per mesh.
Ian
Hi Ian,
Ps 3D layers only support 1 diffuse texture per material. As Dave suggested, you'll have to merge the texture data to a single file.
regards,
steve
Thanks for that. And it is, I guess, only one material per mesh?
