Hello Everyone,
I am having some issues with importing Alpha RGB titles in Avid Media Composer. I am importing these Alpha RGB transparent text and lower thirds into Avid than I am cutting them into the timeline and they are glitching the footage when I lay the text over the footage. I must be doing something wrong that is causing this issue. I know it's not a hardware issue. I am running windows by the way. I am editing in avid 1920X 1080 29.97. When I remove the Alpha text I don't get glitchy jumps in my video. ThankYou for your help.
These are my settings for Alpha RGB from AE
RGB+Alpha Quicktime
Color: Premultiplied Matted
Format Options Animation
Importing into Avid
Alpha Channel-Invert on import White=Opaque
Image Size Adjustment-Image Sized for Current Format
Color levels
Scale from Full Range to legal range
Autodetect sequentially numbered files
I have brought these in MXF 45 and 100 still same problem.
Do this: Go to the end of the timeline. set an out point. Go to the head of the Avid timeline. Set an in point. Right-click on the top of the timeline. Select Expert Render In To Out. Render it.
And learn to use Avid.
Bump any Avid user's with this issue?
Render again but this time In the output module settings change the color to "straight" instead of "premultiplied".
That is what I have been doing is rendering the matte RGB Alpha in the timeline in avid and setting in and out. The problem has gone away.
