I'm experiencing many problems in switching from Design View to Live View. I almost always work in Design View and preview in a browser, because editing content in Live View (except applying classes) is a royal PITA. I'm on Mac OS 10.11.6 El Capitan. Specifically:
On a responsive site (NOT built with Bootstrap), I open a page in Design View, as usual. Then after some editing, it may switch to Live View automatically for some mysterious reason. The Live link in top bar (Code Split Live) then does not offer the little pulldown arrow for switching to Design View. If I try the top menu bar (View/View Mode/Design), it will not switch back to Design View. It's stuck in Live.
If I close the page, and even quit Dreamweaver, relaunch and open the page -- it's STILL stuck in Live View with no way to switch. Yet I have edited these same pages for over a year previously without this problem. Yes, II'm using the absolute very latest version of Dreamweaver CC 2017. Maybe my page declaration is faulty?
<!doctype html>
<!--[if lt IE 7]> <html class="ie6 oldie"> <![endif]-->
<!--[if IE 7]> <html class="ie7 oldie"> <![endif]-->
<!--[if IE 8]> <html class="ie8 oldie"> <![endif]-->
<!--[if gt IE 8]><!-->
<html class="">
Please help!
Additionally, when I try to switch from Live to Design View I get a complete BLANK in the WYSIWYG panel. Just white space. If I click the Live button, still a blank -- no display at all (except Code View in Split).
You're saying which framework that you are not using. How about telling us what you are using, like Fluid Grid Layout.
Have a look at Is there any way to display the Design View in fluid grid pages?
Yes, it's an old fluid grid layout composed with earlier version of Dreamweaver (2014, I believe)
Thanks for that link. I echo these relevant quotes from it:
Also nearly impossible to copy and paste code on the same page. Text edited in Code window does not display in Live window. Many other problems, making my workflow in Live View slow, laborious, grossly inefficient, forcing me to hand code a lot of stuff.
How about showing us your entire code and not just fragments of code.
Nancy
Without pasting the entire code for very long page, here's the relevant beginning:
<!doctype html>
<html class="">
<head>…</head>
<body>
<div class="gridContainer clearfix">
<header class="fluid header">
<div class="fluid tagline">Moab's largest restaurant and only microbrewery
I've been editing these fluid grid pages in Dreamweaver CC (2017 for some time in Design View -- absolutely the most efficient way to edit these pages. Then, by some mysterious process, the page will switch Live View and I cannot get out of it. Closing and reopening page will still not permit Design View. Then I may open a different but very similar page, and Design View works.
It's an extremely aggravating flaw and needs to be fixed! I guess my only option would be to download CC (2014) and edit pages with it.
Legacy FGLayouts were removed from DW CC 2017 for a reason. The framework and it's CSS code is very temperamental to work with. Bootstrap is much better for responsive web design.
If you're married to FGLayouts, I would suggest dropping back to earlier CS6. If you don't have it, you can get it from your Creative Cloud Desktop App under All Apps > Previous Versions. See screenshot.
Nancy
Thanks so much, Nancy.
Ever since Dreamweaver incorporated Bootstrap, I've been using the new technology to build all my sites. Not married to FGlayouts, but clients are not going to pay me to rebuild their older sites using FG. They won't see the difference.
But I've also had the same problem (switching between Live and Design view) with Bootstrap pages.
IMO, Live View is an awkward, gimmicky, inefficient way to do basic editing of existing pages (which makes up about 75% of my work). I'm constantly finding myself resorting to hand coding in Split view make things happen. Often, I will copy and paste code in the Code window (in LIve/Split view), and it simply does not work! Paste doesn't work. Text edited in Code view does not show up in Live window! On and on...
I echo what a lot of users are saying -- editing exclusively in Live View is a royal PITA!
I mainly work with code in PHP, LESS/SASS & JS files so my workflow may be different from yours.
But my overall experience in CC 2017 on Win10 with Bootstrap files has been good. So I wonder if there's something different about your code that's causing DW to choke. You might want to validate and see what comes up.
Nancy
I'm primarily a designer, not a coder, working on Mac El Capitan. I'll check code validation, but I still think the whole Live/Design View issue is a major flaw that needs to be fixed. As one poster in a related thread said:
Ditto.
Live View and editing in Live View are not new features, though. So I wonder how old those remarks are and if they were about this version or an older one.
In Adobe's quest to make DW more "modern" they systematically removed the ability to work with Fluid Grid Layouts over a couple of versions. First, by removing Design View, then by giving them the name "Legacy Fluid Grids" (an omen of things to come) and finally, removing the option all together.
You can still get your Design View functionality back while working with them, but you will need to modify your LFGL's stylesheet file...
First, close all other files, open the Legacy Fluid Grid's .css file and add the X shown below:
Dreamweaver Fluid Grid Properties
dw-num-cols-mobile: X 4;
dw-num-cols-tablet: 8;
dw-num-cols-desktop: 12;
dw-gutter-percentage: 25;
Then save and close the file.
Restart DW and you should have Design View from there on out on any files using that particular LFGL's .css file.
