I have spent a couple of months to create a fillable form which now works fine.
I am about to release the document, however when the document is opened, filled out (or not) and SAVED and OPENED again a question (the second one) is duplicatied and repeated. I am not certain, but it has something to do with radio buttons I use....I have deleted them all and then the duplication has vanished, however I cannot get rid of all radio buttons since they are needed in the form, furhtermore it might also be somthing else.......I know it is a bit vague description but has anyone seen something like this and can someone please help?
Total Likes
I haven't seen this problem before, but there is an alternative you can try.
Try using Checkboxes rather than radio buttons. You can make them work the same as a radio button by making sure that when it is changes to checked, the rest of the checkboxes are unchecked. See if that makes a difference.
I have done this previously as i think the checkboxes look nicer
You might want to take a look at subform/field bindings, and initialize events.
If you have a binding to a repeating element, check your scripting and initializations.
It may be that you are appending to a structure each time you initialize the form - even if it already exists.
I have reviewed forms that had subforms set to repeat based on binding to elements, and a script that was adding an instance each time the form initialized.
Not saying that's happening here - just throwing it out there.
Sounds like you have narrowed it to the radio buttons - good luck
Mark
Dear Mark and MinusZ, thank you for your effort to come back to me with answer....
I have tried the method of elimination and came indeed down to the radio buttons....As far as I could see and count, the very first question involved a radio button was duplicated the in the amount of total number of radio buttons present in the document...
The sollution?
Get rid of binding !!!
It is now duplication free.....
Total Likes
