I just went to Best Buy and purchased Lightroom 6... Not the Cloud version that is a yearly subscription ( I specifically asked the guy to make sure). When I started installing the program off of the CD that came with it, when I got to the place that I had to go onto the website to type in the redemption code to get the serial number in order to install the rest of the program, it told me that a serial number was not needed at this time and it proceeded to install CC off of the website...
My main concern it that this will not continue to be my working program in a year and I have to buy it all over again... I only purchased this being that it was a 1 time deal and it is my program.
Can someone explain please?? THANK YOU IN ADVANCE!
Hi ,
Go to "https://www.adobe.com/"
- Clic on "Manage account" button and enter you password again .
- Clic on "Plans & Products" at the bottom
-> If you bought a subscription plan ,you'll see it there under Plans .
-> If you bought a perpetual license ,you'll see it under "View your products"
You do need a serial number for LR6. If you have a redemption code, convert it. The number must start with 1160 ... (do not post it here!)
The program is the same for LR6 and LR CC2015, so there is no need to reinstall. You only need to change the licensing mode. Here's how: How to convert a Lightroom CC trial to Lightroom 6
How do I convert the redemption code to the serial number? I did this before and typed it in and that when it told me it wasn't needed at this time then loaded CC?
Hi keiths,
Please refer the below article related to the same.
Serial numbers, redemption codes, and product codes | Student and Teacher editions
Mohit
Thanks for the help.. I assumed it worked but still no serial code... When I typed in my redemption code, the next box lit up that says "You're all set". Under that it said I had successfully redeemed Lightroom 6 and that a serial code was not needed. There was a box under that to download the product.. It also said I could come back at anytime to download it.
This is the same process I went through yesterday.. If Lightroom6 was successfully redeemed and downloaded from the website, why did I get a CD in the box?
Is there a way for me to check the program I have downloaded to make sure it is not just the free month trial?
This is what I was seeing...
The serial number is usually inside the box on the inner packaging or on the disk wrapper. It should be 24 digits commencing 1160 (all numbers and no letters)
In the box that I bought from best buy came an insert card with Serial number retrieval steps and instructions to go to Adobe website and type in my redemption code which is numbers and letters and then it is supposed to give me a serial number to enter when installing my product...
And that is the page up above that gave me the answer of I don't need a serial number
What version is installed? Can you launch the software? If so go to the menu:
Help > About Photoshop Lightroom
You should see the version number.
But you will definitely need a serial number; so check your bestbuy account or email them.
Hi keiths707,
I have PMed the 24 digits serial number of Lightroom 6. Please download via Download Photoshop Lightroom
Regards
Rajashree
I also just tried to follow the instructions from How to convert a Lightroom CC trial to Lightroom 6
It said to sign out of my email on my desktop LR then sign in with another account ID that is not linked to a CC and it would ask me if I want to license the software. So I did get there but at that point it is asking me for my serial number...
I tried to convert my redemption code to get a serial number but it won't give it to me....
Hi ,
Thank you, I went in and found that I have Adobe Photoshop Lightroom, Version 6, My serial number, and it says that the,platform is multiple... What does that mean?
Multiple platform means that your license is good for either Windows or Mac.
Im going through the same issue after purchasing lightroom 6 from best buy an hour ago! How do you get the serial number when it says you dont need it. in the apps it says i need to purchase again but i already bought the cd!
Look on the box for a 24 character number set starting with 1160. That is the serial number.
Or it has a Redemption code someplace on or in the box that you have to go to the Adobe site and punch in that code to get a real serial number.
There is no 24 character number starting with 1160 on the box, cd, or cd slip. When i enter the redemption code online it says that i dont need a serial number and directs me to a download app option which must be paid for.
Is what you saw the same as Keith showed in message 5? What does the next screen look like, after you click the big download button?
After the download button is clicked it asks me to open creative cloud desktop app.
Did you ever have a subscription using the Adobe ID you are using.
Install as a trial from CC desktop.
Launch Lightroom and go to the menu: Help >> Sign Out <your email address>
Quit Lightroom
Re-launch Lightroom and click the button “Sign In Now”
Click the button “License This Software”
Enter serial number & click Next
Lightroom will launch as LR6
https://helpx.adobe.com/lightroom/kb/serialize-lightroom-cc-trial-to-activate-as-lightroom-6.html
Contact the retailer if the serial number commencing 1160 does not get generated. That is essential for the above procedure.
Then I suggest you take it back to Best Buy and get a refund. You can buy LR 6 upgrade or Full version directly from Adobe.
Just click where it says Full License and select Upgrade if you have purchased a previous version of LR before. Please note that you will need a serial number from a previous version of LR to complete the install and registering.
