I'm just wondering why Adobe won't fix the issue of slow previews?
As you can see here the problem is around since last november. If I haven't had the possibility to switch back to CC 2015 I would likely think about canceling the whole subscription - without a working preview AE is unusable.
In order to obviate any unkind answers:
Yes, I'm loading it into the RAM before playing the preview. The whole bar is green.
Still the preview is slow/laggy and it feels like 5fps and not 29,97fps. And the animation is very, very, very basic: It's a text moving up.
In CC 2015 it works like a charm.
My PC:
Intel Xeon 1230v3
20GB RAM
AMD 280x
Windows 10
AE: Latest version
I'm using a Dell U2515H. But I can't see why that could be important
I think Szalam was trying to see if this issue is related to preview problems in 5K displays which is an issue that comes up in the forums every once and a while.
the link you provided is broken.
1. set hardware acceleration off in the preferences->display and see if the issue is resolved.
2. make sure the preview settings are correct for caching into ram. I set mine to the old RAM preview behavior prior to CC2015:
it should look
...Copy link to clipboard
What kind of monitor are you using?
it should look something like this.
This one worked for me. Odd problem.
There is (at least) one model of Dell monitors (Dell (4k) P2715Q) that causes preview problems in AE unless you disable the Multi-Stream Transport (MST) option. Glad Roei's suggestion worked!
This seems to be working for the short term. Thank you. I'll let you know if the problem persists once I start a new composition project.
