LR 2015.9 CR 9.9 Windows 7x64 Pro i7-4790k 16gb mem
I just noticed that since the most recent update, there is a definite color shift in the image display when toggling the Crop tool ("R").
Here are two screenshots of an image, the only difference being that in the second one the Crop tool is selected while in the first one it is not. The shift is subtle, and seems to affect greens the most. On other shots with less green the shift is almost invisible. This happens on ALL images, regardless of whether any edits have been applied or any parameters changed. It is of course most obviously visible when actually toggling the Crop tool with the keyboard "R".
Note also that the color temperature settings do not change, which indicates to me that it's a preview rendering issue.
Crop tool not selected
Crop tool selected
Jim,
It may be happening. I have defective colour vision and can't see a difference. Normally one doesn't try to work on colour issues while in crop mode, so it isn't likely to make a difference in practice.
I notice on my copy of LR that the image shrinks slightly when entering crop mode. Perhaps this has a subtle effect on colour balance.
Hal
I see the visual difference you report. Can’t replicate on this end (Mac OS). It could be the current preference settings for GPU which you may wish to adjust and see if that helps. Look at the Performance preference options. You’ve hardware calibrated the display? If so, check that software and make sure you’re not making version 4 (V4) ICC display profiles. They sometimes don’t play nice with applications.
All good points.
GPU is disabled as it's a GeForce GTX 750 Ti/PCIe/SSE2 which LR doesn't seem to like much.
The display is calibrated and has a dE around 1.0
The profile is definitely v2 as I've encountered the v4 problem before
Here's the System Info from LR:
Lightroom version: CC 2015.9 [ 1106920 ]
License: Creative Cloud
Operating system: Windows 7
Version: 6.1
Application architecture: x64
System architecture: x64
Logical processor count: 8
Processor speed: 3.9 GHz
Built-in memory: 16325.4 MB
Real memory available to Lightroom: 16325.4 MB
Real memory used by Lightroom: 4078.7 MB (24.9%)
Virtual memory used by Lightroom: 4258.8 MB
GDI objects count: 1177
USER objects count: 3803
Process handles count: 2429
Memory cache size: 3209.3MB / 3825.3MB (83.9%)
Maximum thread count used by Camera Raw: 8
Camera Raw SIMD optimization: SSE2,AVX,AVX2
Camera Raw virtual memory: 1949MB / 8162MB (23%)
System DPI setting: 96 DPI
Desktop composition enabled: Yes
Displays: 1) 1920x1200, 2) 2560x1440
Input types: Multitouch: No, Integrated touch: No, Integrated pen: Yes, External touch: No, External pen: Yes, Keyboard: No
Graphics Processor Info:
Check OpenGL support: Passed
Vendor: NVIDIA Corporation
Version: 3.3.0 NVIDIA 368.81
Renderer: GeForce GTX 750 Ti/PCIe/SSE2
LanguageVersion: 3.30 NVIDIA via Cg compiler
Application folder: C:\Program Files\Adobe\Adobe Lightroom
Library Path: D:\Photo\Catalog\master.lrcat
Settings Folder: C:\Users\jim\AppData\Roaming\Adobe\Lightroom
Installed Plugins:
1) AdobeStock
2) Canon Tether Plugin
3) ColorChecker Passport
4) Export to Photomatix Pro
5) Facebook
6) Flickr
7) Leica Tether Plugin
8) LR/Enfuse
9) Nikon Tether Plugin
10) Show Focus Points
Config.lua flags: None
Adapter #1: Vendor : 10de
Device : 1380
Subsystem : 37533842
Revision : a2
Video Memory : 1992
AudioDeviceIOBlockSize: 1024
AudioDeviceName: Speakers (Realtek High Definition Audio)
AudioDeviceNumberOfChannels: 2
AudioDeviceSampleRate: 48000
Build: LR5x8
Direct2DEnabled: false
GL_ACCUM_ALPHA_BITS: 16
GL_ACCUM_BLUE_BITS: 16
GL_ACCUM_GREEN_BITS: 16
GL_ACCUM_RED_BITS: 16
GL_ALPHA_BITS: 0
GL_BLUE_BITS: 8
GL_DEPTH_BITS: 24
GL_GREEN_BITS: 8
GL_MAX_3D_TEXTURE_SIZE: 2048
GL_MAX_TEXTURE_SIZE: 16384
GL_MAX_TEXTURE_UNITS: 4
GL_MAX_VIEWPORT_DIMS: 16384,16384
GL_RED_BITS: 8
GL_RENDERER: GeForce GTX 750 Ti/PCIe/SSE2
GL_SHADING_LANGUAGE_VERSION: 4.50 NVIDIA
GL_STENCIL_BITS: 8
GL_VENDOR: NVIDIA Corporation
GL_VERSION: 4.5.0 NVIDIA 368.81
GPUDeviceEnabled: false
OGLEnabled: true
GL_EXTENSIONS: GL_AMD_multi_draw_indirect
GL_AMD_seamless_cubemap_per_texture GL_ARB_arrays_of_arrays
GL_ARB_base_instance GL_ARB_bindless_texture GL_ARB_blend_func_extended
GL_ARB_buffer_storage GL_ARB_clear_buffer_object GL_ARB_clear_texture
GL_ARB_clip_control GL_ARB_color_buffer_float GL_ARB_compatibility
GL_ARB_compressed_texture_pixel_storage GL_ARB_conservative_depth
GL_ARB_compute_shader GL_ARB_compute_variable_group_size
GL_ARB_conditional_render_inverted GL_ARB_copy_buffer GL_ARB_copy_image
GL_ARB_cull_distance GL_ARB_debug_output GL_ARB_depth_buffer_float
GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_derivative_control
GL_ARB_direct_state_access GL_ARB_draw_buffers GL_ARB_draw_buffers_blend
GL_ARB_draw_indirect GL_ARB_draw_elements_base_vertex
GL_ARB_draw_instanced GL_ARB_enhanced_layouts GL_ARB_ES2_compatibility
GL_ARB_ES3_compatibility GL_ARB_ES3_1_compatibility
GL_ARB_ES3_2_compatibility GL_ARB_explicit_attrib_location
GL_ARB_explicit_uniform_location GL_ARB_fragment_coord_conventions
GL_ARB_fragment_layer_viewport GL_ARB_fragment_program
GL_ARB_fragment_program_shadow GL_ARB_fragment_shader
GL_ARB_framebuffer_no_attachments GL_ARB_framebuffer_object
GL_ARB_framebuffer_sRGB GL_ARB_geometry_shader4
GL_ARB_get_program_binary GL_ARB_get_texture_sub_image
GL_ARB_gpu_shader5 GL_ARB_gpu_shader_fp64 GL_ARB_gpu_shader_int64
GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_imaging
GL_ARB_indirect_parameters GL_ARB_instanced_arrays
GL_ARB_internalformat_query GL_ARB_internalformat_query2
GL_ARB_invalidate_subdata GL_ARB_map_buffer_alignment
GL_ARB_map_buffer_range GL_ARB_multi_bind GL_ARB_multi_draw_indirect
GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query
GL_ARB_occlusion_query2 GL_ARB_parallel_shader_compile
GL_ARB_pipeline_statistics_query GL_ARB_pixel_buffer_object
GL_ARB_point_parameters GL_ARB_point_sprite
GL_ARB_program_interface_query GL_ARB_provoking_vertex
GL_ARB_query_buffer_object GL_ARB_robust_buffer_access_behavior
GL_ARB_robustness GL_ARB_sample_shading GL_ARB_sampler_objects
GL_ARB_seamless_cube_map GL_ARB_seamless_cubemap_per_texture
GL_ARB_separate_shader_objects GL_ARB_shader_atomic_counter_ops
GL_ARB_shader_atomic_counters GL_ARB_shader_ballot
GL_ARB_shader_bit_encoding GL_ARB_shader_clock
GL_ARB_shader_draw_parameters GL_ARB_shader_group_vote
GL_ARB_shader_image_load_store GL_ARB_shader_image_size
GL_ARB_shader_objects GL_ARB_shader_precision
GL_ARB_shader_storage_buffer_object GL_ARB_shader_subroutine
GL_ARB_shader_texture_image_samples GL_ARB_shader_texture_lod
GL_ARB_shading_language_100 GL_ARB_shading_language_420pack
GL_ARB_shading_language_include GL_ARB_shading_language_packing
GL_ARB_shadow GL_ARB_sparse_buffer GL_ARB_sparse_texture
GL_ARB_stencil_texturing GL_ARB_sync GL_ARB_tessellation_shader
GL_ARB_texture_barrier GL_ARB_texture_border_clamp
GL_ARB_texture_buffer_object GL_ARB_texture_buffer_object_rgb32
GL_ARB_texture_buffer_range GL_ARB_texture_compression
GL_ARB_texture_compression_bptc GL_ARB_texture_compression_rgtc
GL_ARB_texture_cube_map GL_ARB_texture_cube_map_array
GL_ARB_texture_env_add GL_ARB_texture_env_combine
GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_float
GL_ARB_texture_gather GL_ARB_texture_mirror_clamp_to_edge
GL_ARB_texture_mirrored_repeat GL_ARB_texture_multisample
GL_ARB_texture_non_power_of_two GL_ARB_texture_query_levels
GL_ARB_texture_query_lod GL_ARB_texture_rectangle GL_ARB_texture_rg
GL_ARB_texture_rgb10_a2ui GL_ARB_texture_stencil8 GL_ARB_texture_storage
GL_ARB_texture_storage_multisample GL_ARB_texture_swizzle
GL_ARB_texture_view GL_ARB_timer_query GL_ARB_transform_feedback2
GL_ARB_transform_feedback3 GL_ARB_transform_feedback_instanced
GL_ARB_transform_feedback_overflow_query GL_ARB_transpose_matrix
GL_ARB_uniform_buffer_object GL_ARB_vertex_array_bgra
GL_ARB_vertex_array_object GL_ARB_vertex_attrib_64bit
GL_ARB_vertex_attrib_binding GL_ARB_vertex_buffer_object
GL_ARB_vertex_program GL_ARB_vertex_shader
GL_ARB_vertex_type_10f_11f_11f_rev GL_ARB_vertex_type_2_10_10_10_rev
GL_ARB_viewport_array GL_ARB_window_pos GL_ATI_draw_buffers
GL_ATI_texture_float GL_ATI_texture_mirror_once GL_S3_s3tc
GL_EXT_texture_env_add GL_EXT_abgr GL_EXT_bgra GL_EXT_bindable_uniform
GL_EXT_blend_color GL_EXT_blend_equation_separate
GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract
GL_EXT_compiled_vertex_array GL_EXT_Cg_shader GL_EXT_depth_bounds_test
GL_EXT_direct_state_access GL_EXT_draw_buffers2 GL_EXT_draw_instanced
GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit
GL_EXT_framebuffer_multisample GL_EXTX_framebuffer_mixed_formats
GL_EXT_framebuffer_multisample_blit_scaled GL_EXT_framebuffer_object
GL_EXT_framebuffer_sRGB GL_EXT_geometry_shader4
GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4
GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float
GL_EXT_packed_pixels GL_EXT_pixel_buffer_object GL_EXT_point_parameters
GL_EXT_polygon_offset_clamp GL_EXT_provoking_vertex
GL_EXT_rescale_normal GL_EXT_secondary_color
GL_EXT_separate_shader_objects GL_EXT_separate_specular_color
GL_EXT_shader_image_load_formatted GL_EXT_shader_image_load_store
GL_EXT_shader_integer_mix GL_EXT_shadow_funcs GL_EXT_stencil_two_side
GL_EXT_stencil_wrap GL_EXT_texture3D GL_EXT_texture_array
GL_EXT_texture_buffer_object GL_EXT_texture_compression_dxt1
GL_EXT_texture_compression_latc GL_EXT_texture_compression_rgtc
GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map
GL_EXT_texture_edge_clamp GL_EXT_texture_env_combine
GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic
GL_EXT_texture_integer GL_EXT_texture_lod GL_EXT_texture_lod_bias
GL_EXT_texture_mirror_clamp GL_EXT_texture_object
GL_EXT_texture_shared_exponent GL_EXT_texture_sRGB
GL_EXT_texture_sRGB_decode GL_EXT_texture_storage GL_EXT_texture_swizzle
GL_EXT_timer_query GL_EXT_transform_feedback2 GL_EXT_vertex_array
GL_EXT_vertex_array_bgra GL_EXT_vertex_attrib_64bit
GL_EXT_import_sync_object GL_IBM_rasterpos_clip
GL_IBM_texture_mirrored_repeat GL_KHR_context_flush_control GL_KHR_debug
GL_KHR_no_error GL_KHR_robust_buffer_access_behavior GL_KHR_robustness
GL_KTX_buffer_region GL_NV_bindless_multi_draw_indirect
GL_NV_bindless_multi_draw_indirect_count GL_NV_bindless_texture
GL_NV_blend_equation_advanced GL_NV_blend_equation_advanced_coherent
GL_NV_blend_square GL_NV_command_list GL_NV_compute_program5
GL_NV_conditional_render GL_NV_copy_depth_to_color GL_NV_copy_image
GL_NV_depth_buffer_float GL_NV_depth_clamp GL_NV_draw_texture
GL_NV_draw_vulkan_image GL_NV_ES1_1_compatibility
GL_NV_ES3_1_compatibility GL_NV_explicit_multisample GL_NV_fence
GL_NV_float_buffer GL_NV_fog_distance GL_NV_fragment_program
GL_NV_fragment_program_option GL_NV_fragment_program2
GL_NV_framebuffer_multisample_coverage GL_NV_geometry_shader4
GL_NV_gpu_program4 GL_NV_internalformat_sample_query
GL_NV_gpu_program4_1 GL_NV_gpu_program5 GL_NV_gpu_program5_mem_extended
GL_NV_gpu_program_fp64 GL_NV_gpu_shader5 GL_NV_half_float
GL_NV_light_max_exponent GL_NV_multisample_coverage
GL_NV_multisample_filter_hint GL_NV_occlusion_query
GL_NV_packed_depth_stencil GL_NV_parameter_buffer_object
GL_NV_parameter_buffer_object2 GL_NV_path_rendering
GL_NV_pixel_data_range GL_NV_point_sprite GL_NV_primitive_restart
GL_NV_register_combiners GL_NV_register_combiners2
GL_NV_shader_atomic_counters GL_NV_shader_atomic_float
GL_NV_shader_atomic_int64 GL_NV_shader_buffer_load
GL_NV_shader_storage_buffer_object GL_NV_texgen_reflection
GL_NV_texture_barrier GL_NV_texture_compression_vtc
GL_NV_texture_env_combine4 GL_NV_texture_multisample
GL_NV_texture_rectangle GL_NV_texture_shader GL_NV_texture_shader2
GL_NV_texture_shader3 GL_NV_transform_feedback GL_NV_transform_feedback2
GL_NV_uniform_buffer_unified_memory GL_NV_vertex_array_range
GL_NV_vertex_array_range2 GL_NV_vertex_attrib_integer_64bit
GL_NV_vertex_buffer_unified_memory GL_NV_vertex_program
GL_NV_vertex_program1_1 GL_NV_vertex_program2
GL_NV_vertex_program2_option GL_NV_vertex_program3
GL_NVX_conditional_render GL_NVX_gpu_memory_info GL_NVX_multigpu_info
GL_NVX_nvenc_interop GL_NV_shader_thread_group
GL_NV_shader_thread_shuffle GL_KHR_blend_equation_advanced
GL_KHR_blend_equation_advanced_coherent GL_SGIS_generate_mipmap
GL_SGIS_texture_lod GL_SGIX_depth_texture GL_SGIX_shadow
GL_SUN_slice_accum GL_WIN_swap_hint WGL_EXT_swap_control
I see what you are seeing in your screen clips but I just did a test with a mostly multi green shaded photo and did screen clips with the crop tool on and off and then brought the clips into Photoshop and aligned the layers and set the blending mode to difference and the result is about 99.999% black with a few little scattered speckles I don't know what that slight difference is but I could not see a difference by just clicking the layers on and off quickly. cc2015.9 and OS X 10.11.6. BTW, if you try this there seems to be a bug in Photoshop were the Align-layers command does not align very well the first time it is used. Align a second time and it seems ok. This bug seems to happen on a regular basis
First thing to try when strange things happen is to reset the LR Preferences file. Place a copy of the Preferences file on your desktop so you can easily restore it if the issue remains.
https://www.lightroomqueen.com/articles-page/how-do-i-reset-lightrooms-preferences/
I tried and could not see the problem. Are you switching between library and develop module or just in develop module when you switch to crop tool?
Just in develop module. It is really hard to see unless the scene is primarily green. I can barely detect the color shift in typical photos of people.
I'm also on Windows 7 running LR CC2015.9 and see no difference between the normal and Crop tool previews. I checked this in PS using manually aligned screenshots with Levels applied to reveal subtle differences. This is most likely a Preferences file or monitor profile issue.
I have the same problem. IPad Pro, shooting with iPad Pro camera. I think in my case it has to do with that I used the “lens/filter” on the iPad Pro Lightroom in-app camera to get my captures to how I wanted them to look on screen. (The photos will only be used for my etsy shop). I think when clicking the crop tool it negates those lens/filters I used in shooting mode. If I save the file to my camera roll it will keep those color changes as well. I wound up ”Exporting original images” to save what I’d taken.
Im wondering what camera you used and if there was anything “pre-applied“ that could have caused that.
