I have more than thousand images i need to update the metadata from CSV file. The CSV file having only file names and resolution and date. The script needs to match the file name from CSV and update the same to image meta
Is this possible via bridge scripting.
The common export/import options are mentioned here in my blogpost on the subject:
Prepression: Extracting Metadata to .CSV
I personally would use ExifTool as it is relatively fast and flexible (Iām happy to cover this in detail if required), however if you wish to use an Adobe Bridge script then you will need to see if the options you require have been put into the script (or modify the script if you have the knowledge to do so):
VRA Panel Export-Import Tool or Paul Riggottās Do It Yourself Metadata Input script.
If you search the Bridge and Bridge Scripting forums you will see that this comes up on a regular basis and that the answers are pretty much the same each time.
Some other forum posts on this topic include:
https://forums.adobe.com/message/9144026#9144026
https://forums.adobe.com/message/8745192#8745192
https://forums.adobe.com/message/8673766#8673766
https://forums.adobe.com/message/8684260#8684260
https://forums.adobe.com/message/8944230#8944230
Can you import metadata from an excel database to images (JPG, PSD, TIF) in bulk?
It is now the 23rd and this was urgent on the 11thā¦ So how did you go?
Sorry. Its done by manually.
More than a 1000 images done manually? Fun!
