Hi, I've begun to use Publish Online FXL EPUBs for presentations with animations. They're, of course, better than Powerpoints.
What vexes me is how to use a remote clicker to "press" a button and essentially "go to next state," the animation.
Any advice appreciated.
I don't believe I've ever heard of remote clickers that work with EPUB files. Generally, EPUB is designed for individual reading rather than for presentations.
Do remote clickers work with Publish Online?
Yeah, this is pioneering. No reason why FXL EPUBs wouldn't make great presentations. I've done them by pecking at a laptop when I wanted to play an animation or go to next page, etc.
Just would be more convenient and businesslike to use the remote clicker everybody else does with PPTs.
It would be helpful if you could report back (to this forum) whether "clickers" can work with Publish Online as personally I can't test it as I haven't a clicker!
I've also never seen such clickers. I suspect that it's a Microsoft Office thing since so many people use PowerPoint for presentations.
I just spent a few minutes trying unsuccessfully to find out how the clicker interacts with the software. Some models mention support for not only Powerpoint, but also Apple Keynote and some sort of Google slide software. The category of hardware seems to be limited to presentation software only however.
Steve, yes, I also did some research on clickers on Amazon, and it seems you're right. But ...
One of the options on Buttons and Forms panel in INDD is "on click" (I think; don't actually have it open at the moment). Seems to me there should be some way to tie this back to a clicker.
But once that's solved, there's still the issue of order. Think of a 3-point PPT slide, for example. Click, and one bullet appears. Click, and the second appears, etc. How would a clicker -- if a clicker could click in InDesign -- know to start the photo zoom as opposed to the second line of text?
The On Click setting for a button or form field refers to when you view a button or form on a tablet or smart phone when you don't have a mouse.
In fact, it says On Release or Tap. That means that with a mouse-driven device, the event will occur when you press the mouse and then release (giving the viewer the option to click away instead of immediately causing an action). But if you're on a tablet or smartphone, you click on the button to cause the event.
