Hi. please help me. I have a AS2 program called Main.swf. It loads another(not mine) program (call it Base.swf). Both of these files are located locally on my computer. I load into my program Mine.swf an external file load.swf.
//Main.swf
System.security.allowDomain('*');
this.createEmptyMovieClip('module', 0);
module.loadMovie('http://192.168.10.102/loaded.swf');
From the loaded.swf file, I try to access _root which should be equal to Base.swf. But I can not do it. Although from the file Main.swf I can access _root.
//Main.swf
_root.someFunctionFromBase(); //it work
module._root.someFunctionFromBase(); //even so works
//loaded.swf
_root.someFunctionFromBase(); //undefined
How can I access variables and functions in _root from the loaded file?
Main loads loaded and Main loads Base?
Sorry, probably not correctly explained. The sequence is as follows: Base <- Main <- loaded
if you want to reference objects in Main from loaded, use _parent.
no. I want to refer to objects in Base.swf from a loaded.swf
use _parent._parent
this does not work. Files Main.swf and Base.swf - local, and loaded.swf - remote. If I load a loaded.swf from the local, everything works. But if I load the file from the http server - I can not access _root. That is the problem.
then you probably have a timing issue. _parent._parent is the correct path if you explained the loading correctly.
It seems to me that the problem is with some limitations of security. Because the problem only occurs when load file from a remote location. I repeat that when I load file from a local location(from the same directory where Main.swf is located), I can access _root, _parent._parent, etc.
or timing.
This is not a timing. I see when the loaded.swf is added to the Main and only after that I try access to _root. I'm sure that at this point in time the file is already loaded.
what's the url to Base?
Base.swf and Main.swf are local files. They are located on my computer. And loaded.swf it remote file, located on my web server. I will try to explain in more detail: Base.swf is the main application (it is quite large and complex). Main.swf is simply a loader that loads an external file (loaded.swf) as a plug-in that will later work with objects and functions of Base.swf. But if I load a loaded.swf from a web server, and not from a local location, then I can not access _root from it. Sorry for my bad english =(
that is a security issue.
check the Security class'es allowDomain() method.
I have already tried everything that is possible with a security class. I guess that the problem is with security, but I can not understand what exactly will solve this problem.
