I received some footage 2944 x 2160 shot on Arrir Mini in 4:3. (Shot Optically Anamorphic at 2x).
The footage is "squeezed" in preview/quicktime (As it should be).
This has been my workflow.
- Import Footage > Interpret > Change Pixel to 2.0
- Drag Footage into new comp.
- Toggle Pixel Aspect Ration Correction
- Do needed work.
Now trying to export BACK the way it came, so it's easy for them to just re-link the file.
However, it's always being exported as "De-squeezed". (Same resolution just w/ a 2.0 pixel ratio).
How do i export it w/ a 1.0 pixel aspect ration the way it came to me.
-Thanks,
Make as new 2944 x 2160 comp in SQUARE pixels. Nest the anamorphic comp in it. Scale the anamorphic comp to fit the new comp. Render again.
You should be good.
Yea, I was afraid you would say that. I'm just hesitant w/ adding another process to it by scaling it.
Is there a different workflow I should do going forward?
p.s : I don't know HOW many messages/posts i have read form you over the many years. It's nice to finally meet you in a way.
-Thanks,
Jon
Nice to meet you, too.
That's the thing about non-square pixels -- they're intended to get stretched & squeezed. If the pixel dimensions of the footage & the comps are right, you shouldn't sustain any damage.... to the footage itself. I can't speak to anything else that may be in the comp -- I don't know what's in it.
Hi Maximus01701,
What did you end up doing with this footage? Let us know.
Kevin
