After CC 2017.1 update, scratch disk filling up fast
Apr 10, 2017 Apr 10, 2017
I updated Photoshop to 2017.1 yesterday, and all day today I keep getting a warning that the scratch disks are almost full.  There are 2 dedicated SSDs on my Windows 10 PC that have more than 200 GB each used for scratch, yet both rapidly become full (in about 30 minutes of working).  Closing Photoshop releases all of the temporary files and the drives go back to full capacity.  This has never been an issue with previous versions, even when working with massive files and multiple files open together.  What could be causing this crazy "scratch use on steroids"?!
2.4K
Adobe Employee , May 02, 2017 May 02, 2017
This issue is resolved in Photoshop 2017.1.1 (just released).
Jesper
Adobe
Adobe Employee ,
Hi jasonh,
Well, it shouldn't be the update issue, something else is causing this issue. Have put a check mark on all the available hard drive under the scratch disk option? also, refer: Scratch disk suddenly full after making tiny adjustments to photoshop file
Mohit
Yes, I've checked all of the usual suspects.  No changes were made other than upgrading.  Watching the contents of the scratch disks, a new temp file of about 67 GB is being created about every 5 minutes until both drives are to capacity.  If I were working on a massive composite, it might make a bit of sense (even though it has never been the case), but I am just working on basic edits of files that are no bigger than a couple hundred MB.  Any other recommendations?
Apr 11, 2017 Apr 11, 2017
I have Photoshop both my workplace and at home. I installed PS cc2017 at home recently.
Opening the same(!) ~200 Mb psd file my workplace and at home, te Photoshop generates different temp files.
On my workplace it generates ~3GB temp file but at home ~40GB(!)
Both computer has a ~20GB free space SSD width 6 and 8 GB RAM.
I tried to change the scratch disk to a HDD, but result was same.
So, I'm still trying to get to the root of this problem.  There is definitely an issue that began immediately after the 2017.1 update.  The PC I use has 64 GB of RAM, 80% of which is allotted for Photoshop use per the preferences.  I also have 2 250 GB SSD drives installed that are specifically reserved for scratch disk for Adobe products.  Here is how I tested the issue this morning...
I opened an image and sized it to 24x36 300dpi and duplicated the layer a few times just to increase the file size substantially.  I then began randomly using memory intensive tools like the patch tool and content aware filling in random areas.  I kept the performance tab of the task manager and the file manager with each of the scratch disks opened on a separate screen.  First off, over the course of a few minutes, RAM was to capacity.  Next, temp files began on scratch disk one.  These must be limited to 67 GB, because once that size was reached, a new temp file is created and promptly filled to capacity.  It's like the memory that is being allocated for a task is just being rewritten over and over, and since Photoshop won't release these allocations until the program is closed, all sources of memory in my case are exhausted in a short time!
I tried the same testing method on a different PC, one that only has 8 GB of RAM and uses a 140 GB HDD as a scratch disk... and is still using CC 2017.0.  The RAM is used up pretty quick, and a temp file is created at about 2 GB.  That temp file does increase in size when I do things like duplicate layers, but still may only get to about 5 GB max!  Nothing like the runaway train I am seeing on my PC.  There has to be something wrong with RAM and pagefile management in the new version, somehow the install was corrupted, or something else wicked is going on with my system.  Should not spill beyond the massive amounts of RAM... much less fill up 2 scratch disks.
Anyone know of something I could be overlooking?
I have to second that problem! I have 45GB of HDD free, which always fills up pretty quickly since the recent update. Even with closing ALL files, the space is not free'd up, until Photoshop is closed. And i did not change any settings since the update.
I figured there'd be more people having this issue.  Everything I'm seeing with faulty memory allocation smacked of a program issue.   Hopefully there can be a fix for this pretty quick.
Adobe Employee ,
I'm writing to acknowledge that I've seen your post and we're looking into this.
Can everyone provide your OS version?
regards,
steve
I'm on Win10 Pro.
Apr 12, 2017 Apr 12, 2017
Window 10 Home
Hi everyone,
After the last update I've installed 2 days ago, the swap file started to be HUGE, from 2-3GB to 20-30GB and even bigger.
What is happening? Does anyone know what the problem is? We have 2 ASUS laptops in the office and both started have the same problem. My colleague has 40gb free on C and 120 GB on D and the C gets FULL and D drops under 100GB when working at just one file. And there are less then 10 layers.
Before the update everything worked fine.
Dragos
Adobe Employee ,
Another ask: Can you go to Help> System Info... and provide the resulting text in a post?
regards,
steve
sorry, german install 🙂
Adobe Photoshop Version: 2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877  x64
Anzahl der Starts: 106
Version: 10 oder höher
Systemarchitektur: Intel CPU-Familie:6, Modell:12, Stepping:3 mit MMX, SSE (ganze Zahl), SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, AVX2, Hyper-Threading
Physischer Prozessor: 4
Logischer Prozessor: 8
Prozessor-Taktfrequenz: 2494 MHz
Eingebauter Speicher: 16296 MB
Freier Speicher: 6851 MB
Für Photoshop verfügbarer Arbeitsspeicher: 14390 MB
Von Photoshop verwendeter Arbeitsspeicher: 60 %
Verlaufsminiaturen: Aktiviert.
Touch Bar: Aktiviert.
Alias-Ebenen: Deaktiviert.
Zusatztasten-Palette: Aktiviert.
Fernlicht: Aktiviert.
Bildkachelgröße: 1024 KB
Bildcache: 5
Schriftvorschau: Mittel
TextComposer: Lateinisch
Anzeige: 1
Anzeigebegrenzungen: oben= 0, links= 0, unten= 1080, rechts= 1920
Mit OpenGL zeichnen: Aktiviert.
OpenGL – alte GPUs zulassen: Nicht erkannt.
OpenGL-Zeichnungsmodus: Einfach
OpenGL – normalen Modus zulassen: Wahr.
OpenGL – erweiterten Modus zulassen: Wahr.
AIFCoreInitialized=1
AIFOGLInitialized=1
OGLContextCreated=1
NumGLGPUs=1
NumCLGPUs=2
NumNativeGPUs=0
glgpu[0].GLVersion="4.1"
glgpu[0].IsIntegratedGLGPU=1
glgpu[0].GLMemoryMB=2048
glgpu[0].GLName="Intel(R) HD Graphics 4600"
glgpu[0].GLVendor="Intel"
glgpu[0].GLVendorID=32902
glgpu[0].GLDriverVersion="20.19.15.4531"
glgpu[0].GLRectTextureSize=16384
glgpu[0].GLRenderer="Intel(R) HD Graphics 4600"
glgpu[0].GLRendererID=1046
glgpu[0].HasGLNPOTSupport=1
glgpu[0].GLDriver="igdumdim64.dll,igd10iumd64.dll,igd10iumd64.dll,igd12umd64.dll,igdumdim32,igd10iumd32,igd10iumd32,igd12umd32"
glgpu[0].GLDriverDate="20160929000000.000000-000"
glgpu[0].CanCompileProgramGLSL=1
glgpu[0].GLFrameBufferOK=1
glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="1.30 - Build 20.19.15.4531"
glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[1447]
glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[8]
glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[192]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[32]
glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[32]
glgpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[4096]
glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[64]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
glgpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=0
clgpu[0].CLPlatformVersion="1.2 "
clgpu[0].CLDeviceVersion="1.2 "
clgpu[0].IsIntegratedCLGPU=1
clgpu[0].CLMemoryMB=1629
clgpu[0].CLName="Intel(R) HD Graphics 4600"
clgpu[0].CLVendor="Intel(R) Corporation"
clgpu[0].CLVendorID=32902
clgpu[0].CLDriverVersion="20.19.15.4531"
clgpu[0].CLBandwidth=1.52241e+10
clgpu[0].CLCompute=72.3209
clgpu[1].CLPlatformVersion="1.2"
clgpu[1].CLDeviceVersion="1.2 CUDA"
clgpu[1].IsIntegratedCLGPU=0
clgpu[1].CLMemoryMB=4096
clgpu[1].CLName="GeForce GTX 860M"
clgpu[1].CLVendor="NVIDIA Corporation"
clgpu[1].CLVendorID=4318
clgpu[1].CLDriverVersion="376.54"
clgpu[1].CLBandwidth=6.83829e+10
clgpu[1].CLCompute=392.798
Lizenztyp: Abonnement
Seriennummer: 96040865532394425397
GUIDBucket:
  bucket: 139
  test: ReduceUXFriction
Anwendungsordner: C:\Program Files\Adobe\Adobe Photoshop CC 2017\
Pfad für temporäre Dateien: C:\Users\Pierre\AppData\Local\Temp\
Der virtuelle Speicher von Photoshop hat asynchronen E/A aktiviert
Arbeitsvolume(s):
Start, 476,0 GB, 46,2 GB frei
Ordner für erforderliche Zusatzmodule: C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\Plug-ins\
Primärer Zusatzmodul-Ordner: C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\
Installierte Komponenten
   A3DLIBS.dll   A3DLIB Dynamic Link Library   9.2.0.112
   ACE.dll   ACE 2017/01/26-01:10:02   79.579975   79.579975
   AdbePM.dll   PatchMatch 2016/11/03:19:48:57   1.578146   1.578146
   AdobeLinguistic.dll   Adobe Linguisitc Library   10.0.0
   AdobeOwl.dll   Adobe Owl   5.2.11
   AdobePDFL.dll   PDFL 2016/08/10-16:53:20   79.195992   79.195992
   AdobePIP.dll   Adobe Product Improvement Program   7.4.1.60.45263
   AdobeSVGAGM.dll   AdobeSVGAGM   79.579975   79.579975
   AdobeXMP.dll   Adobe XMP Core 2016/09/14-01:09:01   79.159824   79.159824
   AdobeXMPFiles.dll   Adobe XMP Files 2016/09/14-01:09:01   79.159824   79.159824
   AdobeXMPScript.dll   Adobe XMP Script 2016/09/14-01:09:01   79.159824   79.159824
   adobe_caps.dll   Adobe CAPS   10,0,0,6
   AGM.dll   AGM 2017/01/26-01:10:02   79.579975   79.579975
   ahclient.dll    AdobeHelp Dynamic Link Library   2.2.0.1
   AIDE.dll   AIDE 2016/05/27-01:08:49   79.574279   79.574279
   amtlib.dll   AMTLib (64 Bit)   10.0.0.119 BuildVersion: 10.0; BuildDate: Thu Dec 22 2016 3:0:7)   1.000000
   ARE.dll   ARE 2017/01/26-01:10:02   79.579975   79.579975
   AXE8SharedExpat.dll   AXE8SharedExpat 2015/03/13-23:40:54   79.562390   79.562390
   AXEDOMCore.dll   AXEDOMCore 2015/03/13-23:40:54   79.562390   79.562390
   Bib.dll   BIB 2017/01/26-01:10:02   79.579975   79.579975
   BIBUtils.dll   BIBUtils 2017/01/26-01:10:02   79.579975   79.579975
   boost_date_time.dll   photoshopdva   10.0.0
   boost_signals.dll   photoshopdva   10.0.0
   boost_system.dll   photoshopdva   10.0.0
   boost_threads.dll   photoshopdva   10.0.0
   cg.dll   NVIDIA Cg Runtime   3.0.00007
   cgGL.dll   NVIDIA Cg Runtime   3.0.00007
   CITThreading.dll   Adobe CITThreading   2.1.0.1   2.1.0.1
   CoolType.dll   CoolType 2017/01/26-01:10:02   79.579975   79.579975
   dnssd.dll   Bonjour   3,0,0,2
   dvaaudiodevice.dll   photoshopdva   10.0.0
   dvacore.dll   photoshopdva   10.0.0
   dvacrashhandler.dll   Adobe Audition CC 2017   10.0.0
   dvamarshal.dll   photoshopdva   10.0.0
   dvamediatypes.dll   photoshopdva   10.0.0
   dvametadata.dll   photoshopdva   10.0.0
   dvametadataapi.dll   photoshopdva   10.0.0
   dvametadataui.dll   photoshopdva   10.0.0
   dvaplayer.dll   photoshopdva   10.0.0
   dvatransport.dll   photoshopdva   10.0.0
   dvaui.dll   photoshopdva   10.0.0
   dvaunittesting.dll   photoshopdva   10.0.0
   dynamiclink.dll   photoshopdva   10.0.0
   ExtendScript.dll   ExtendScript 2016/12/13-13:10:33   80.1089815   80.1089815
   icucnv40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
   icudt40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
   icuuc40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
   igestep30.dll   IGES Reader   9.3.0.113
   imslib.dll   IMSLib DLL   10.0.0.11
   JP2KLib.dll   JP2KLib 2016/05/26-01:08:58   79.262945   79.262945
   libifcoremd.dll   Intel(r) Visual Fortran Compiler   10.0 (Update A)
   libiomp5md.dll   Intel(R) OpenMP* Runtime Library   5.0
   libmmd.dll   Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler   12.0
   LogSession.dll   LogSession   7.4.1.60.45263
   mediacoreif.dll   photoshopdva   10.0.0
   MPS.dll   MPS 2016/09/14-15:20:26   79.577269   79.577269
   pdfsettings.dll   Adobe PDFSettings   1.04
   Photoshop.dll   Adobe Photoshop CC 2017   18.1.0
   Plugin.dll   Adobe Photoshop CC 2017   18.1.0
   PlugPlugExternalObject.dll   Adobe(R) CEP PlugPlugExternalObject Standard Dll (64 bit)   7.0.0
   PlugPlugOwl.dll   Adobe(R) CSXS PlugPlugOwl Standard Dll (64 bit)   7.0.0.67
   PSArt.dll   Adobe Photoshop CC 2017   18.1.0
   PSViews.dll   Adobe Photoshop CC 2017   18.1.0
   SCCore.dll   ScCore 2016/12/13-13:10:33   80.1089815   80.1089815
   SVGRE.dll   SVGRE   79.579975   79.579975
   svml_dispmd.dll   Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler   12.0
   tbb.dll   Intel(R) Threading Building Blocks for Windows   4, 4, 2016, 0412
   tbbmalloc.dll   Intel(R) Threading Building Blocks for Windows   4, 4, 2016, 0412
   TfFontMgr.dll   FontMgr   9.3.0.113
   TfKernel.dll   Kernel   9.3.0.113
   TFKGEOM.dll   Kernel Geom   9.3.0.113
   TFUGEOM.dll   Adobe, UGeom©   9.3.0.113
   updaternotifications.dll   Adobe Updater Notifications Library   10.0.0.1 (BuildVersion: 1.0; BuildDate: BUILDDATETIME)   10.0.0.1
   VulcanControl.dll   Vulcan Application Control Library   5.3.0.16
   VulcanMessage5.dll   Vulcan Message Library   5.3.0.16
   WRServices.dll   WRServices Thu Jan 07 2016 04:50:10   Build 0.21960   0.21960
   wu3d.dll   U3D Writer   9.3.0.113
Erforderliche Zusatzmodule:
   3D Studio 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - aus der Datei "“U3D.8bi”"
   Adaptive Weitwinkelkorrektur 18.1.0 - aus der Datei "“Adaptive Wide Angle.8bf”"
   Aquarell 18.1.0 - aus der Datei "“Filter Gallery.8bf”"
   Basrelief 18.1.0 - aus der Datei "“Filter Gallery.8bf”"
   Bereich 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - aus der Datei "“statistics.8ba”"
   Bildpaket-Filter 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - aus der Datei "“ChannelPort.8bf”"
   Blendenflecke 18.1.0 - aus der Datei "“Standard MultiPlugin.8bf”"
   BMP 18.1.0 - aus der Datei "“Standard MultiPlugin.8bf”"
   Buntglas-Mosaik 18.1.0 - aus der Datei "“Filter Gallery.8bf”"
   Buntstiftschraffur 18.1.0 - aus der Datei "“Filter Gallery.8bf”"
   Camera Raw 9.9 - aus der Datei "“Camera Raw.8bi”"
   Camera Raw-Filter 9.9 - aus der Datei "“Camera Raw.8bi”"
   Chrom 18.1.0 - aus der Datei "“Filter Gallery.8bf”"
   Cineon 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - aus der Datei "“Cineon.8bi”"
   Collada 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - aus der Datei "“U3D.8bi”"
   Color Lookup-Raster rendern 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - aus der Datei "“Export3DLUT.8be”"
   Color Lookup-Tabellen exportieren 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - aus der Datei "“Export3DLUT.8be”"
   CompuServe GIF 18.1.0 - aus der Datei "“Standard MultiPlugin.8bf”"
   Conté-Stifte 18.1.0 - aus der Datei "“Filter Gallery.8bf”"
   De-Interlace 18.1.0 - aus der Datei "“Standard MultiPlugin.8bf”"
   Diagonal verwischen 18.1.0 - aus der Datei "“Filter Gallery.8bf”"
   Dicom 18.1.0 - aus der Datei "“Dicom.8bi”"
   Differenz-Wolken 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - aus der Datei "“Clouds.8bf”"
   Distorsion 18.1.0 - aus der Datei "“Standard MultiPlugin.8bf”"
   Dunkle Malstriche 18.1.0 - aus der Datei "“Filter Gallery.8bf”"
   Durchschnitt 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - aus der Datei "“Average.8bf”"
   Eazel Acquire 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - aus der Datei "“EazelAcquire.8ba”"
   Entropie 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - aus der Datei "“statistics.8ba”"
   Erfassungsbereich 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - aus der Datei "“MeasurementCore.8me”"
   Extrudieren 18.1.0 - aus der Datei "“Standard MultiPlugin.8bf”"
   Farbpapier-Collage 18.1.0 - aus der Datei "“Filter Gallery.8bf”"
   Farbraster 18.1.0 - aus der Datei "“Standard MultiPlugin.8bf”"
   Fasern 18.1.0 - aus der Datei "“Standard MultiPlugin.8bf”"
   FastCore-Routinen 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - aus der Datei "“FastCore.8bx”"
   Feuchtes Papier 18.1.0 - aus der Datei "“Filter Gallery.8bf”"
   Filtergalerie 18.1.0 - aus der Datei "“Filter Gallery.8bf”"
   Flash 3D 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - aus der Datei "“U3D.8bi”"
   Fluchtpunkt 18.1.0 - aus der Datei "“VanishingPoint.8bf”"
   Fotokopie 18.1.0 - aus der Datei "“Filter Gallery.8bf”"
   Fotos freistellen und gerade ausrichten (Filter) 18.1.0 - aus der Datei "“Standard MultiPlugin.8bf”"
   Fotos freistellen und gerade ausrichten 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - aus der Datei "“CropPhotosAuto.8li”"
   Fresko 18.1.0 - aus der Datei "“Filter Gallery.8bf”"
   Für Web speichern 18.1.0 - aus der Datei "“Save for Web.8be”"
   Gekreuzte Malstriche 18.1.0 - aus der Datei "“Filter Gallery.8bf”"
   Gerissene Kanten 18.1.0 - aus der Datei "“Filter Gallery.8bf”"
   Glas 18.1.0 - aus der Datei "“Filter Gallery.8bf”"
   Google Earth 4 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - aus der Datei "“U3D.8bi”"
   Grobe Malerei 18.1.0 - aus der Datei "“Filter Gallery.8bf”"
   Grobes Pastell 18.1.0 - aus der Datei "“Filter Gallery.8bf”"
   HDRMergeUI 18.1.0 - aus der Datei "“HDRMergeUI.8bf”"
   HSB/HSL 18.1.0 - aus der Datei "“Standard MultiPlugin.8bf”"
   IFF-Format 18.1.0 - aus der Datei "“Standard MultiPlugin.8bf”"
   IGES 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - aus der Datei "“U3D.8bi”"
   JPEG 2000 18.1.0 - aus der Datei "“JPEG2000.8bi”"
   Kacheleffekt 18.1.0 - aus der Datei "“Standard MultiPlugin.8bf”"
   Kacheln 18.1.0 - aus der Datei "“Filter Gallery.8bf”"
   Kanten betonen 18.1.0 - aus der Datei "“Filter Gallery.8bf”"
   Kohleumsetzung 18.1.0 - aus der Datei "“Filter Gallery.8bf”"
   Konturen mit Tinte nachzeichnen 18.1.0 - aus der Datei "“Filter Gallery.8bf”"
   Körnung && Aufhellung 18.1.0 - aus der Datei "“Filter Gallery.8bf”"
   Körnung 18.1.0 - aus der Datei "“Filter Gallery.8bf”"
   Kräuseln 18.1.0 - aus der Datei "“Standard MultiPlugin.8bf”"
   Kreide && Kohle 18.1.0 - aus der Datei "“Filter Gallery.8bf”"
   Kreuzschraffur 18.1.0 - aus der Datei "“Filter Gallery.8bf”"
   Kristallisieren 18.1.0 - aus der Datei "“Standard MultiPlugin.8bf”"
   Kunststofffolie 18.1.0 - aus der Datei "“Filter Gallery.8bf”"
   Kurtosis 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - aus der Datei "“statistics.8ba”"
   LAGE 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - aus der Datei "“U3D.8bi”"
   Leuchtende Konturen 18.1.0 - aus der Datei "“Filter Gallery.8bf”"
   Malgrund 18.1.0 - aus der Datei "“Filter Gallery.8bf”"
   Malmesser 18.1.0 - aus der Datei "“Filter Gallery.8bf”"
   Matlab-Vorgang 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - aus der Datei "“ChannelPort.8bf”"
   Maximum 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - aus der Datei "“statistics.8ba”"
   Median 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - aus der Datei "“statistics.8ba”"
   Mehrprozessorunterstützung 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - aus der Datei "“MultiProcessor Support.8bx”"
   Mezzotint 18.1.0 - aus der Datei "“Standard MultiPlugin.8bf”"
   Minimum 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - aus der Datei "“statistics.8ba”"
   Mit Struktur versehen 18.1.0 - aus der Datei "“Filter Gallery.8bf”"
   Mittelwert 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - aus der Datei "“statistics.8ba”"
   MMXCore-Routinen 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - aus der Datei "“MMXCore.8bx”"
   Neigung 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - aus der Datei "“statistics.8ba”"
   Neonschein 18.1.0 - aus der Datei "“Filter Gallery.8bf”"
   NTSC-Farben 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - aus der Datei "“NTSC Colors.8bf”"
   Objektivkorrektur 18.1.0 - aus der Datei "“Lens Correction.8bf”"
   Objektivunschärfe 18.1.0 - aus der Datei "“Lens Blur.8bf”"
   Ölfarbe getupft 18.1.0 - aus der Datei "“Filter Gallery.8bf”"
   OpenEXR 18.1.0 - aus der Datei "“Standard MultiPlugin.8bf”"
   Ozeanwellen 18.1.0 - aus der Datei "“Filter Gallery.8bf”"
   Patchwork 18.1.0 - aus der Datei "“Filter Gallery.8bf”"
   PCX 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - aus der Datei "“PCX.8bi”"
   Pfade -> Illustrator 18.1.0 - aus der Datei "“Standard MultiPlugin.8bf”"
   Photoshop 3D-Modul 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - aus der Datei "“Photoshop3DEngine.8bi”"
   Photoshop Touch 14.0 - aus der Datei "“PSDX.8bi”"
   Pixar 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - aus der Datei "“Pixar.8bi”"
   PNG 18.1.0 - aus der Datei "“Standard MultiPlugin.8bf”"
   Polarkoordinaten 18.1.0 - aus der Datei "“Standard MultiPlugin.8bf”"
   Portable Bit Map 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - aus der Datei "“PBM.8bi”"
   Prägepapier 18.1.0 - aus der Datei "“Filter Gallery.8bf”"
   PRC 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - aus der Datei "“U3D.8bi”"
   Punktieren 18.1.0 - aus der Datei "“Standard MultiPlugin.8bf”"
   Punktierstich 18.1.0 - aus der Datei "“Filter Gallery.8bf”"
   Radialer Weichzeichner 18.1.0 - aus der Datei "“Standard MultiPlugin.8bf”"
   Radiance 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - aus der Datei "“Radiance.8bi”"
   Rasterungseffekt 18.1.0 - aus der Datei "“Filter Gallery.8bf”"
   Risse 18.1.0 - aus der Datei "“Filter Gallery.8bf”"
   Schwamm 18.1.0 - aus der Datei "“Filter Gallery.8bf”"
   Schwingungen 18.1.0 - aus der Datei "“Standard MultiPlugin.8bf”"
   Selektiver Weichzeichner 18.1.0 - aus der Datei "“Standard MultiPlugin.8bf”"
   Solarisation 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - aus der Datei "“Solarize.8bf”"
   Spaces 18.1.0 - aus der Datei "“Spaces.8li”"
   Spritzer 18.1.0 - aus der Datei "“Filter Gallery.8bf”"
   Standardabweichung 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - aus der Datei "“statistics.8ba”"
   Stempel 18.1.0 - aus der Datei "“Filter Gallery.8bf”"
   STL 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - aus der Datei "“U3D.8bi”"
   Strichumsetzung 18.1.0 - aus der Datei "“Filter Gallery.8bf”"
   Strudel 18.1.0 - aus der Datei "“Standard MultiPlugin.8bf”"
   Stuck 18.1.0 - aus der Datei "“Filter Gallery.8bf”"
   Sumi-e 18.1.0 - aus der Datei "“Filter Gallery.8bf”"
   Summe 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - aus der Datei "“statistics.8ba”"
   Targa 18.1.0 - aus der Datei "“Standard MultiPlugin.8bf”"
   Tontrennung && Kantenbetonung 18.1.0 - aus der Datei "“Filter Gallery.8bf”"
   U3D 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - aus der Datei "“U3D.8bi”"
   Unterstützung für Skripten 18.1.0 - aus der Datei "“ScriptingSupport.8li”"
   Varianz 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - aus der Datei "“statistics.8ba”"
   Verbiegen 18.1.0 - aus der Datei "“Standard MultiPlugin.8bf”"
   Verflüssigen 18.1.0 - aus der Datei "“Liquify.8bf”"
   Versetzen 18.1.0 - aus der Datei "“Standard MultiPlugin.8bf”"
   Verwackelte Striche 18.1.0 - aus der Datei "“Filter Gallery.8bf”"
   Verwacklung reduzieren 18.1.0 - aus der Datei "“Shake Reduction.8bf”"
   Virtual Reality Modeling Language | VRML 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - aus der Datei "“U3D.8bi”"
   Wavefront|OBJ 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - aus der Datei "“U3D.8bi”"
   Weiches Licht 18.1.0 - aus der Datei "“Filter Gallery.8bf”"
   Wellen 18.1.0 - aus der Datei "“Standard MultiPlugin.8bf”"
   WIA-Unterstützung 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - aus der Datei "“WIASupport.8li”"
   Windeffekt 18.1.0 - aus der Datei "“Standard MultiPlugin.8bf”"
   Wireless Bitmap 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - aus der Datei "“WBMP.8bi”"
   Wölben 18.1.0 - aus der Datei "“Standard MultiPlugin.8bf”"
Optionale Zusatzmodule und Zusatzmodule von Drittanbietern:
   Analog Efex Pro 2 2.0.12.12 - aus der Datei "“C:\Program Files\Google\Nik Collection\Analog Efex Pro 2\Analog Efex Pro 2 (64-Bit)\Analog Efex Pro 2.8bf”"
   BackgroundFilter 2.2.21.12 - aus der Datei "“C:\Program Files\Google\Nik Collection\Dfine 2\Dfine 2 (64-Bit)\Background.8bf”"
   Color Efex Pro 4 4.3.24.12 - aus der Datei "“C:\Program Files\Google\Nik Collection\Color Efex Pro 4\Color Efex Pro 4 (64-Bit)\Color Efex Pro 4.8bf”"
   Dfine 2 2.2.21.12 - aus der Datei "“C:\Program Files\Google\Nik Collection\Dfine 2\Dfine 2 (64-Bit)\Dfine2.8bf”"
   FineStructuresFilter 2.2.21.12 - aus der Datei "“C:\Program Files\Google\Nik Collection\Dfine 2\Dfine 2 (64-Bit)\FineStructures.8bf”"
   HDR Efex Pro 2 2.2.24.12 - aus der Datei "“C:\Program Files\Google\Nik Collection\HDR Efex Pro 2\HDR Efex Pro 2 (64-Bit)\HDR Efex Pro 2.8bf”"
   HotPixelsFilter 2.2.21.12 - aus der Datei "“C:\Program Files\Google\Nik Collection\Dfine 2\Dfine 2 (64-Bit)\HotPixels.8bf”"
   Merge to HDR Efex Pro 2 2.2.24.12 - aus der Datei "“C:\Program Files\Google\Nik Collection\HDR Efex Pro 2\HDR Efex Pro 2 (64-Bit)\HDR Efex Pro 2.8bf”"
   Nik Collection Selective Tool 2.1.28 - aus der Datei "“C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\Google\Selective Tool\SelectivePalette.8li”"
   ShadowsFilter 2.2.21.12 - aus der Datei "“C:\Program Files\Google\Nik Collection\Dfine 2\Dfine 2 (64-Bit)\Shadows.8bf”"
   Sharpener Pro 3: (1) RAW Presharpener 3.1.21.12 - aus der Datei "“C:\Program Files\Google\Nik Collection\Sharpener Pro 3\Sharpener Pro 3 (64-Bit)\SHP3RPS.8bf”"
   Sharpener Pro 3: (2) Output Sharpener 3.1.21.12 - aus der Datei "“C:\Program Files\Google\Nik Collection\Sharpener Pro 3\Sharpener Pro 3 (64-Bit)\SHP3OS.8bf”"
   Silver Efex Pro 2 2.2.24.12 - aus der Datei "“C:\Program Files\Google\Nik Collection\Silver Efex Pro 2\Silver Efex Pro 2 (64-Bit)\Silver Efex Pro 2.8bf”"
   SkinFilter 2.2.21.12 - aus der Datei "“C:\Program Files\Google\Nik Collection\Dfine 2\Dfine 2 (64-Bit)\Skin.8bf”"
   SkyFilter 2.2.21.12 - aus der Datei "“C:\Program Files\Google\Nik Collection\Dfine 2\Dfine 2 (64-Bit)\Sky.8bf”"
   StrongNoiseFilter 2.2.21.12 - aus der Datei "“C:\Program Files\Google\Nik Collection\Dfine 2\Dfine 2 (64-Bit)\StrongNoise.8bf”"
   Viveza 2 2.1.21.12 - aus der Datei "“C:\Program Files\Google\Nik Collection\Viveza 2\Viveza 2 (64-Bit)\Viveza2.8bf”"
Doppelte und deaktivierte Zusatzmodule: KEINE
Nicht geladene Plug-Ins: KEINE
Erweiterungen:
   com.adobe.inapp.purchase  2.7.122 – aus der Datei “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.DesignLibraryPanel.html\purchase.html”
   Letzte Dateien  1.4.2 – aus der Datei “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CCX_START_EXTENSION_1_4_2_009\index.html”
   Bibliotheken  2.7.122 – aus der Datei “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.DesignLibraryPanel.html\index.html”
   Neues Dokument  1.4.2 – aus der Datei “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CCX_START_EXTENSION_1_4_2_009\fnft.html”
   Einstieg  1.4.2 – aus der Datei “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CCX_START_EXTENSION_1_4_2_009\index.html”
   com.adobe.experimentation.extension  2.0.0 – aus der Datei “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.experimentation.extension\index.html”
   Adobe Color-Themen  6.1.0 – aus der Datei “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.KulerPanel.html\index.html”
   Exportieren als  3.0.8 – aus der Datei “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.photoshop.crema\PSPanel\dialog.html”
   Device Preview  1.3.1 – aus der Datei “C:\Program Files\Common Files\Adobe\CEP\extensions\com.adobe.previewHD\PSPanel\panel.html”
   Retouching Toolkit  1.3.0 – aus der Datei “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\com.wallstrom.RetouchingToolkitPanel\index.html”
   com.adobe.preview.loader  1.3.1 – aus der Datei “C:\Program Files\Common Files\Adobe\CEP\extensions\com.adobe.previewHD\PSLoader\loader.html”
Installierte TWAIN-Geräte: OHNE
Number of Launches: 147
Version: 10 or greater
System architecture: Intel CPU Family:6, Model:14, Stepping:3 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, AVX2, HyperThreading
Physical processor count: 4
Logical processor count: 8
Processor speed: 2592 MHz
Built-in memory: 24515 MB
Free memory: 15605 MB
Memory available to Photoshop: 21970 MB
Memory used by Photoshop: 79 %
History Thumbnails: Enabled.
Touch Bar: Enabled.
Alias Layers: Disabled.
Modifier Palette: Enabled.
Highbeam: Enabled.
Image tile size: 1024K
Image cache levels: 4
Font Preview: Medium
TextComposer: Latin
Display: 1
Display Bounds: top=0, left=0, bottom=1080, right=1920
OpenGL Drawing: Enabled.
OpenGL Allow Old GPUs: Not Detected.
OpenGL Drawing Mode: Advanced
OpenGL Allow Normal Mode: True.
OpenGL Allow Advanced Mode: True.
AIFOGLInitialized=1
OGLContextCreated=1
NumGLGPUs=1
NumNativeGPUs=0
glgpu[0].IsIntegratedGLGPU=0
glgpu[0].GLMemoryMB=8192
glgpu[0].GLName="NVIDIA GeForce GTX 980M"
glgpu[0].GLVendor="NVIDIA Corporation"
glgpu[0].GLVendorID=4318
glgpu[0].GLDriverVersion="21.21.13.7254"
glgpu[0].GLRenderer="GeForce GTX 980M/PCIe/SSE2"
glgpu[0].GLRendererID=5655
glgpu[0].GLDriver="C:\Windows\System32\DriverStore\FileRepository\nvami.inf_amd64_dac0245a363caab4\nvd3dumx,C:\Windows\System32\DriverStore\FileRepository\nvami.inf_amd64_dac0245a363caab4\nvwgf2umx,C:\Windows\System32\DriverStore\FileRepository\nvami.inf_amd64_dac0245a363caab4\nvwgf2umx,C:\Windows\System32\DriverStore\FileRepository\nvami.inf_amd64_dac0245a363caab4\nvwgf2umx,C:\Windows\System32\DriverStore\FileRepository\nvami.inf_amd64_dac0245a363caab4\nvd3dum,C:\Windows\System32\DriverStore\FileRepository\nvami.inf_amd64_dac0245a363caab4\nvwgf2um,C:\Windows\System32\DriverStore\FileRepository\nvami.inf_amd64_dac0245a363caab4\nvwgf2um,C:\Windows\System32\DriverStore\FileRepository\nvami.inf_amd64_dac0245a363caab4\nvwgf2um"
glgpu[0].GLDriverDate="20160811000000.000000-000"
glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="4.50 NVIDIA"
glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[65536]
glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[4]
glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[124]
glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
License Type: Subscription
Serial number: 90970254820596653637
GUIDBucket:
  bucket: 211
  test: DocumentPanel
Application folder: C:\Program Files\Adobe\Adobe Photoshop CC 2017\
Temporary file path: C:\Users\conta\AppData\Local\Temp\
Photoshop scratch has async I/O enabled
Scratch volume(s):
  Startup, 118.5G, 19.2G free
Required Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\Plug-ins\
Primary Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\
Installed components:
Required plug-ins:
   3D Studio 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “U3D.8bi”
   Accented Edges 18.1.0 - from the file “Filter Gallery.8bf”
   Adaptive Wide Angle 18.1.0 - from the file “Adaptive Wide Angle.8bf”
   Angled Strokes 18.1.0 - from the file “Filter Gallery.8bf”
   Average 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “Average.8bf”
   Bas Relief 18.1.0 - from the file “Filter Gallery.8bf”
   BMP 18.1.0 - from the file “Standard MultiPlugin.8bf”
   Camera Raw 9.9 - from the file “Camera Raw.8bi”
   Camera Raw Filter 9.9 - from the file “Camera Raw.8bi”
   Chalk && Charcoal 18.1.0 - from the file “Filter Gallery.8bf”
   Chrome 18.1.0 - from the file “Filter Gallery.8bf”
   Cineon 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “Cineon.8bi”
   Clouds 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “Clouds.8bf”
   Collada 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “U3D.8bi”
   Color Halftone 18.1.0 - from the file “Standard MultiPlugin.8bf”
   Colored Pencil 18.1.0 - from the file “Filter Gallery.8bf”
   CompuServe GIF 18.1.0 - from the file “Standard MultiPlugin.8bf”
   Conté Crayon 18.1.0 - from the file “Filter Gallery.8bf”
   Craquelure 18.1.0 - from the file “Filter Gallery.8bf”
   Crop and Straighten Photos 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “CropPhotosAuto.8li”
   Crop and Straighten Photos Filter 18.1.0 - from the file “Standard MultiPlugin.8bf”
   Crosshatch 18.1.0 - from the file “Filter Gallery.8bf”
   Crystallize 18.1.0 - from the file “Standard MultiPlugin.8bf”
   Cutout 18.1.0 - from the file “Filter Gallery.8bf”
   Dark Strokes 18.1.0 - from the file “Filter Gallery.8bf”
   De-Interlace 18.1.0 - from the file “Standard MultiPlugin.8bf”
   Dicom 18.1.0 - from the file “Dicom.8bi”
   Difference Clouds 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “Clouds.8bf”
   Diffuse Glow 18.1.0 - from the file “Filter Gallery.8bf”
   Displace 18.1.0 - from the file “Standard MultiPlugin.8bf”
   Dry Brush 18.1.0 - from the file “Filter Gallery.8bf”
   Eazel Acquire 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “EazelAcquire.8ba”
   Entropy 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “statistics.8ba”
   Export Color Lookup Tables 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “Export3DLUT.8be”
   Extrude 18.1.0 - from the file “Standard MultiPlugin.8bf”
   FastCore Routines 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “FastCore.8bx”
   Fibers 18.1.0 - from the file “Standard MultiPlugin.8bf”
   Film Grain 18.1.0 - from the file “Filter Gallery.8bf”
   Filter Gallery 18.1.0 - from the file “Filter Gallery.8bf”
   Flash 3D 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “U3D.8bi”
   Fresco 18.1.0 - from the file “Filter Gallery.8bf”
   Glass 18.1.0 - from the file “Filter Gallery.8bf”
   Glowing Edges 18.1.0 - from the file “Filter Gallery.8bf”
   Google Earth 4 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “U3D.8bi”
   Graphic Pen 18.1.0 - from the file “Filter Gallery.8bf”
   Halftone Pattern 18.1.0 - from the file “Filter Gallery.8bf”
   HDRMergeUI 18.1.0 - from the file “HDRMergeUI.8bf”
   HSB/HSL 18.1.0 - from the file “Standard MultiPlugin.8bf”
   IFF Format 18.1.0 - from the file “Standard MultiPlugin.8bf”
   IGES 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “U3D.8bi”
   Ink Outlines 18.1.0 - from the file “Filter Gallery.8bf”
   JPEG 2000 18.1.0 - from the file “JPEG2000.8bi”
   Kurtosis 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “statistics.8ba”
   Lens Blur 18.1.0 - from the file “Lens Blur.8bf”
   Lens Correction 18.1.0 - from the file “Lens Correction.8bf”
   Lens Flare 18.1.0 - from the file “Standard MultiPlugin.8bf”
   Liquify 18.1.0 - from the file “Liquify.8bf”
   Matlab Operation 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “ChannelPort.8bf”
   Maximum 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “statistics.8ba”
   Mean 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “statistics.8ba”
   Measurement Core 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “MeasurementCore.8me”
   Median 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “statistics.8ba”
   Mezzotint 18.1.0 - from the file “Standard MultiPlugin.8bf”
   Minimum 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “statistics.8ba”
   MMXCore Routines 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “MMXCore.8bx”
   Mosaic Tiles 18.1.0 - from the file “Filter Gallery.8bf”
   Multiprocessor Support 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “MultiProcessor Support.8bx”
   Neon Glow 18.1.0 - from the file “Filter Gallery.8bf”
   Note Paper 18.1.0 - from the file “Filter Gallery.8bf”
   NTSC Colors 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “NTSC Colors.8bf”
   Ocean Ripple 18.1.0 - from the file “Filter Gallery.8bf”
   OpenEXR 18.1.0 - from the file “Standard MultiPlugin.8bf”
   Paint Daubs 18.1.0 - from the file “Filter Gallery.8bf”
   Palette Knife 18.1.0 - from the file “Filter Gallery.8bf”
   Patchwork 18.1.0 - from the file “Filter Gallery.8bf”
   Paths to Illustrator 18.1.0 - from the file “Standard MultiPlugin.8bf”
   PCX 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “PCX.8bi”
   Photocopy 18.1.0 - from the file “Filter Gallery.8bf”
   Photoshop 3D Engine 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “Photoshop3DEngine.8bi”
   Photoshop Touch 14.0 - from the file “PSDX.8bi”
   Picture Package Filter 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “ChannelPort.8bf”
   Pinch 18.1.0 - from the file “Standard MultiPlugin.8bf”
   Pixar 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “Pixar.8bi”
   Plaster 18.1.0 - from the file “Filter Gallery.8bf”
   Plastic Wrap 18.1.0 - from the file “Filter Gallery.8bf”
   PLY 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “U3D.8bi”
   PNG 18.1.0 - from the file “Standard MultiPlugin.8bf”
   Pointillize 18.1.0 - from the file “Standard MultiPlugin.8bf”
   Polar Coordinates 18.1.0 - from the file “Standard MultiPlugin.8bf”
   Portable Bit Map 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “PBM.8bi”
   Poster Edges 18.1.0 - from the file “Filter Gallery.8bf”
   PRC 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “U3D.8bi”
   Radial Blur 18.1.0 - from the file “Standard MultiPlugin.8bf”
   Radiance 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “Radiance.8bi”
   Range 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “statistics.8ba”
   Render Color Lookup Grid 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “Export3DLUT.8be”
   Reticulation 18.1.0 - from the file “Filter Gallery.8bf”
   Ripple 18.1.0 - from the file “Standard MultiPlugin.8bf”
   Rough Pastels 18.1.0 - from the file “Filter Gallery.8bf”
   Save for Web 18.1.0 - from the file “Save for Web.8be”
   ScriptingSupport 18.1.0 - from the file “ScriptingSupport.8li”
   Shake Reduction 18.1.0 - from the file “Shake Reduction.8bf”
   Shear 18.1.0 - from the file “Standard MultiPlugin.8bf”
   Skewness 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “statistics.8ba”
   Smart Blur 18.1.0 - from the file “Standard MultiPlugin.8bf”
   Smudge Stick 18.1.0 - from the file “Filter Gallery.8bf”
   Solarize 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “Solarize.8bf”
   Spaces 18.1.0 - from the file “Spaces.8li”
   Spatter 18.1.0 - from the file “Filter Gallery.8bf”
   Spherize 18.1.0 - from the file “Standard MultiPlugin.8bf”
   Sponge 18.1.0 - from the file “Filter Gallery.8bf”
   Sprayed Strokes 18.1.0 - from the file “Filter Gallery.8bf”
   Stained Glass 18.1.0 - from the file “Filter Gallery.8bf”
   Stamp 18.1.0 - from the file “Filter Gallery.8bf”
   Standard Deviation 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “statistics.8ba”
   STL 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “U3D.8bi”
   Sumi-e 18.1.0 - from the file “Filter Gallery.8bf”
   Summation 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “statistics.8ba”
   Targa 18.1.0 - from the file “Standard MultiPlugin.8bf”
   Texturizer 18.1.0 - from the file “Filter Gallery.8bf”
   Tiles 18.1.0 - from the file “Standard MultiPlugin.8bf”
   Torn Edges 18.1.0 - from the file “Filter Gallery.8bf”
   Twirl 18.1.0 - from the file “Standard MultiPlugin.8bf”
   U3D 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “U3D.8bi”
   Underpainting 18.1.0 - from the file “Filter Gallery.8bf”
   Vanishing Point 18.1.0 - from the file “VanishingPoint.8bf”
   Variance 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “statistics.8ba”
   Virtual Reality Modeling Language | VRML 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “U3D.8bi”
   Water Paper 18.1.0 - from the file “Filter Gallery.8bf”
   Watercolor 18.1.0 - from the file “Filter Gallery.8bf”
   Wave 18.1.0 - from the file “Standard MultiPlugin.8bf”
   Wavefront|OBJ 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “U3D.8bi”
   WIA Support 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “WIASupport.8li”
   Wind 18.1.0 - from the file “Standard MultiPlugin.8bf”
   Wireless Bitmap 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “WBMP.8bi”
   ZigZag 18.1.0 - from the file “Standard MultiPlugin.8bf”
Optional and third party plug-ins:
   Canon Print Studio Pro 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\Canon\CNPSPP01.8li”
   Imagenomic Plug-in Console 1, 2, 0, 0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\Imagenomic\ImagenomicPluginConsole64.8li”
   Portraiture 2.3.0.8 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\Imagenomic\Portraiture64.8bf”
   PSP 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\Canon\CNPSPP02.8bf”
Duplicate and Disabled plug-ins: NONE
Plug-ins that failed to load:
   Canon Layout Plug-In for Print Studio Pro NO VERSION -  - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\Canon\CNPSPPLayout.8li”
Extensions:
   com.adobe.inapp.purchase  2.7.122 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.DesignLibraryPanel.html\purchase.html”
   Recent Files  1.4.2 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CCX_START_EXTENSION_1_4_2_009\index.html”
   Libraries  2.7.122 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.DesignLibraryPanel.html\index.html”
   New Document  1.4.2 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CCX_START_EXTENSION_1_4_2_009\fnft.html”
   Start  1.4.2 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CCX_START_EXTENSION_1_4_2_009\index.html”
   com.adobe.experimentation.extension  2.0.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.experimentation.extension\index.html”
   Adobe Color Themes  6.1.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.KulerPanel.html\index.html”
   Export As  3.0.8 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.photoshop.crema\PSPanel\dialog.html”
   Device Preview  1.3.1 - from the file “C:\Program Files\Common Files\Adobe\CEP\extensions\com.adobe.previewHD\PSPanel\panel.html”
   com.adobe.preview.loader  1.3.1 - from the file “C:\Program Files\Common Files\Adobe\CEP\extensions\com.adobe.previewHD\PSLoader\loader.html”
Installed TWAIN devices: NONE
Ok, so this IS a CC 2017.1 update issue, at least as it pertains to Windows 10 PCs.  Against my better judgement, I updated my assistants Photoshop from 2017.0 to 2017.1 and ran the same tests as earlier today.  The results were the same as my PC where the memory allocation runs like an out of control wildfire!  Now, my stupid desire to adhere to the scientific method has rendered both me and my assistant incredibly stifled in our workflow!
My question now is, do the moderators or administrators on this forum report directly to technical support when a bug is discovered in new updates?  If not, how can I bring this to their attention stat?!  This needs to be fixed ASAP, as I don't see this as just an annoying little bug that can just be ironed out in the future, rather a major malfunction to the software that will cause numerous users countless hours of downtime.
Adobe Employee ,
Hi Jason,
On this particular thread, you have the Ps development team's attention.
regards,
steve
If they want any help reproducing my condition... open any file of any size, use the patch tool to make a selection, move the selection to patch the source, repeat with another selection.  Do this over and over and watch the temp files on the scratch disk increase exponentially.
Windows 10 Pro
Number of Launches: 133
System architecture: Intel CPU Family:6, Model:15, Stepping:2 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, AVX2, HyperThreading
Physical processor count: 6
Logical processor count: 12
Processor speed: 3570 MHz
Built-in memory: 65436 MB
Free memory: 2 MB
Memory available to Photoshop: 59492 MB
Memory used by Photoshop: 80 %
Touch Bar: Enabled.
Highbeam: Enabled.
Image tile size: 1028K
Image cache levels: 8
Font Preview: Huge
TextComposer: Latin
Display: 1
Display Bounds: top=0, left=0, bottom=1200, right=1920
Display: 2
Display Bounds: top=0, left=-1920, bottom=1200, right=0
AIFOGLInitialized=1
OGLContextCreated=1
NumGLGPUs=1
NumCLGPUs=1
NumNativeGPUs=0
glgpu[0].GLMemoryMB=6144
glgpu[0].GLName="NVIDIA GeForce GTX 980 Ti"
glgpu[0].GLDriverVersion="21.21.13.7653"
glgpu[0].GLRenderer="GeForce GTX 980 Ti/PCIe/SSE2"
glgpu[0].GLRendererID=6088
glgpu[0].GLDriver="C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispiwu.inf_amd64_b67dc924fff8de6d\nvd3dumx,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispiwu.inf_amd64_b67dc924fff8de6d\nvwgf2umx,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispiwu.inf_amd64_b67dc924fff8de6d\nvwgf2umx,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispiwu.inf_amd64_b67dc924fff8de6d\nvwgf2umx,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispiwu.inf_amd64_b67dc924fff8de6d\nvd3dum,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispiwu.inf_amd64_b67dc924fff8de6d\nvwgf2um,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispiwu.inf_amd64_b67dc924fff8de6d\nvwgf2um,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispiwu.inf_amd64_b67dc924fff8de6d\nvwgf2um"
glgpu[0].GLDriverDate="20161229000000.000000-000"
clgpu[0].CLPlatformVersion="1.2"
clgpu[0].CLDeviceVersion="1.2 CUDA"
clgpu[0].IsIntegratedCLGPU=0
clgpu[0].CLMemoryMB=6144
clgpu[0].CLName="GeForce GTX 980 Ti"
clgpu[0].CLVendor="NVIDIA Corporation"
clgpu[0].CLVendorID=4318
clgpu[0].CLDriverVersion="376.53"
clgpu[0].CLBandwidth=2.47183e+11
clgpu[0].CLCompute=2407.2
Serial number: 90970331993383548140
GUIDBucket:
  bucket: 168
Temporary file path: C:\Users\Jason\AppData\Local\Temp\
Scratch volume(s):
  E:\, 232.8G, 210.4G free
  D:\, 232.8G, 199.8G free
Required plug-ins:
   Hidden NO VERSION - from the file “TopazRemaskAutomation.8li”
   Topaz Adjust 5 10.0 - from the file “tladjust5ps_x64.8bf”
   Topaz B&W Effects 2 10.0 - from the file “tlbw2ps_x64.8bf”
   Topaz Clarity 10.0 - from the file “tlclarityps_x64.8bf”
   Topaz Clean 3 10.0 - from the file “tlclean3ps_x64.8bf”
   Topaz DeJpeg 4 10.0 - from the file “tldejpeg4ps_x64.8bf”
   Topaz DeNoise 6 10.0 - from the file “tldenoise6ps_x64.8bf”
   Topaz Detail 3 10.0 - from the file “tldetail3ps_x64.8bf”
   Topaz Glow 2 10.0 - from the file “tlglow2ps_x64.8bf”
   Topaz Impression 2 10.0 - from the file “tlimpression2ps_x64.8bf”
   Topaz InFocus 10.0 - from the file “tlinfocusps_x64.8bf”
   Topaz Lens Effects 10.0 - from the file “tllenseffectsps_x64.8bf”
   Topaz photoFXlab 10.0 - from the file “tlphotoFXlabps_x64.8bf”
   Topaz ReMask 5 10.0 - from the file “tlremask5ps_x64.8bf”
   Topaz ReStyle 10.0 - from the file “tlrestyleps_x64.8bf”
   Topaz Simplify 4 10.0 - from the file “tlsimplify4ps_x64.8bf”
   Topaz Star Effects 10.0 - from the file “tlstareffectsps_x64.8bf”
   Topaz Texture Effects 2 10.0 - from the file “tltextureeffects2ps_x64.8bf”
   Analog Efex Pro 2 2.0.12.12 - from the file “C:\Program Files\Google\Nik Collection\Analog Efex Pro 2\Analog Efex Pro 2 (64-Bit)\Analog Efex Pro 2.8bf”
   BackgroundFilter 2.2.21.12 - from the file “C:\Program Files\Google\Nik Collection\Dfine 2\Dfine 2 (64-Bit)\Background.8bf”
   Color Efex Pro 4 4.3.24.12 - from the file “C:\Program Files\Google\Nik Collection\Color Efex Pro 4\Color Efex Pro 4 (64-Bit)\Color Efex Pro 4.8bf”
   Dfine 2 2.2.21.12 - from the file “C:\Program Files\Google\Nik Collection\Dfine 2\Dfine 2 (64-Bit)\Dfine2.8bf”
   FineStructuresFilter 2.2.21.12 - from the file “C:\Program Files\Google\Nik Collection\Dfine 2\Dfine 2 (64-Bit)\FineStructures.8bf”
   HDR Efex Pro 2 2.2.24.12 - from the file “C:\Program Files\Google\Nik Collection\HDR Efex Pro 2\HDR Efex Pro 2 (64-Bit)\HDR Efex Pro 2.8bf”
   HotPixelsFilter 2.2.21.12 - from the file “C:\Program Files\Google\Nik Collection\Dfine 2\Dfine 2 (64-Bit)\HotPixels.8bf”
   Merge to HDR Efex Pro 2 2.2.24.12 - from the file “C:\Program Files\Google\Nik Collection\HDR Efex Pro 2\HDR Efex Pro 2 (64-Bit)\HDR Efex Pro 2.8bf”
   Nik Collection Selective Tool 2.1.28 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\Google\Selective Tool\SelectivePalette.8li”
   Portraiture 2.3.4.2 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\Imagenomic\Portraiture64.8bf”
   ShadowsFilter 2.2.21.12 - from the file “C:\Program Files\Google\Nik Collection\Dfine 2\Dfine 2 (64-Bit)\Shadows.8bf”
   Sharpener Pro 3: (1) RAW Presharpener 3.1.21.12 - from the file “C:\Program Files\Google\Nik Collection\Sharpener Pro 3\Sharpener Pro 3 (64-Bit)\SHP3RPS.8bf”
   Sharpener Pro 3: (2) Output Sharpener 3.1.21.12 - from the file “C:\Program Files\Google\Nik Collection\Sharpener Pro 3\Sharpener Pro 3 (64-Bit)\SHP3OS.8bf”
   Silver Efex Pro 2 2.2.24.12 - from the file “C:\Program Files\Google\Nik Collection\Silver Efex Pro 2\Silver Efex Pro 2 (64-Bit)\Silver Efex Pro 2.8bf”
   SkinFilter 2.2.21.12 - from the file “C:\Program Files\Google\Nik Collection\Dfine 2\Dfine 2 (64-Bit)\Skin.8bf”
   SkyFilter 2.2.21.12 - from the file “C:\Program Files\Google\Nik Collection\Dfine 2\Dfine 2 (64-Bit)\Sky.8bf”
   StrongNoiseFilter 2.2.21.12 - from the file “C:\Program Files\Google\Nik Collection\Dfine 2\Dfine 2 (64-Bit)\StrongNoise.8bf”
   Viveza 2 2.1.21.12 - from the file “C:\Program Files\Google\Nik Collection\Viveza 2\Viveza 2 (64-Bit)\Viveza2.8bf”
Plug-ins that failed to load: NONE
Extensions:
   Extensis  1.0.0 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\Extensis_Photoshop_HTML\index.html”
Rolling back to the previous version of Photoshop resolved my issue... well, it didn't "resolve" the issue, rather took me back to the good ol' days before "the issue".  Kudos to Steve who informed me that this was even possible.  I guess since every upgrade has been stable for me, there has never been a need to do so.  Who says you can't teach old dogs new tricks.  Ha!  If anyone needs to roll back, but doesn't know how, here is some info from the Adobe blogs...
1. Click the Creative Cloud icon, located in the taskbar (Windows) or Apple menu bar (Mac OS), to open the Adobe Creative Cloud desktop app. If it’s not already selected, click the Apps tab at the top of the window.
2. In the Find Additional Apps section, choose Previous Versions > View Previous Versions.
3. Scroll to the app you want to download and click the Install button. Choose an available version to install.
4. Find the application you wish to revert to in the list, click on the Install menu button, and choose the application you wish to revert to  (in this case 18.0.1).
5. The former version of the application is now installed.
Before doing this, if you want to preserve your preferences navigate to C:\Users\username\AppData\Roaming\Adobe\Adobe Photoshop CC 2017 (at least for you Windows users... Mac guys, you're on your own). Then copy that folder some where on your computer. After installing the 18.0.1 version you can move this back to that location, thus replacing the defaults.
Hopefully the software engineers get a fix for this quickly and take down the update in the mean time.  I'm starting to see variations of this problem pop up on other forums and it has the potential to become a major problem.
Adobe Employee ,
The macOS path is: /Users/username/Library/Preferences/Adobe Photoshop CC 2017 Settings
If you have a hidden user Library, check these steps: Access hidden Mac OS library files
regards,
steve
Adobe Employee ,
Hi Jason,
Good to hear that worked for you and you're unblocked.
cheers,
steve
  1. I'm having the same problem after installing the latest update on a Mac Book Pro with 500gb storage filling up with the scratch drive  - moved 100gb of images and within minutes I'm getting a message saying my disk is almost full
Participant ,
Apr 14, 2017 Apr 14, 2017
I too am having this issue. I updated earlier this week. I have spent at least 40 hours working within this update before this problem suddenly surfaced a few hours ago after working the past 10 hours or so. Did nothing out of my normal workflow before it started.
Maxed out Macbook Pro Mid 2012 with 500GB SSD running OS 10.11.6. Remaining 100GB fills up within a few minutes of working on a single image.
Also started receiving an error message when I closed PS after receiving my first disk full messages. It says, "Selective palette Error, XML parsing error: 'no element found' at line 1." Internet searches point to Nik Pro Contrast issue. Which makes sense as the entire suite is acting strangely after updating. Restarting the system makes the message stop until my HDD fills up again. Apparently this update broke more than one thing.
Will be "rolling back" to previous version as soon as i click Add Reply.
Apr 19, 2017 Apr 19, 2017
Both me and my colleague we've uninstalled the latest PS update.
Everything is back to normal and working fine now.
Let us know please when the issue will be solved so we can update again
