Changing the Color of Pixels
Apr 11, 2017 Apr 11, 2017
I'm incredibly new in the world of coding with Premiere, so my apologies if I'm not using the right terms...
I'm trying to write a plugin that will scan every pixel in a clip. I want it to act almost like a FCP Broadcast Safe filter, making the pixels that are too bright darker. I assumed that using an If-Else structure would be the best way to do this, however I don't know what to declare in the If statement. I'm using the Simple_Video_Filter example from the SDK package. Here's the section of the code I'm working on (again, apologies for how bad it is...)
                    for(int vert = 0; vert < height; ++vert)
                        for(int horiz = 0; horiz < width; ++horiz)
                            // Save off alpha
                            alpha = *srcpix & 0xff000000;
                            // Separate colors
                            redSource = (*srcpix & 0x00ff0000) >> 16;
                            greenSource = (*srcpix & 0x0000ff00) >> 8;
                            blueSource = *srcpix & 0x000000ff;
                            if (redSource == 0x00ff0000) {
                                redSource = *srcpix & 0x000000ff;
                                OutputDebugString(TEXT("Red detected."));
                            else {
                                OutputDebugString(TEXT("No Red."));
                            *dstpix = (alpha | (redSource << 16) | (greenSource << 8) | blueSource);
                            ++dstpix;
                            ++srcpix;
                        srcpix += (rowbytes / 4) - width;
                        dstpix += (rowbytes / 4) - width;
                    } // else
On a colour matte with the value of FF0000, it still prints out "No Red."
Can someone please advise, or at least point me in the right direction?
Thanks.
-Josh
SDK
1.1K
Adobe Employee , Apr 21, 2017 Apr 21, 2017
Eddie, long time, great to see you on the forums!
Josh, stepping back a little further, I wanted to point out that the Simple_Video_Filter uses a legacy API and because of that it's been removed from the BuildAll .sln / .xcodeproj in the latest SDK.  We recommend starting from a sample effect project in the After Effects SDK.  For example the Portable sample is good if you just want 8-bit RGB.  Or the SDK_Noise sample if you want to support 32-bit float and even YUV-native processing.
Contributor ,
Apr 19, 2017 Apr 19, 2017
Change the line
to
if (redSource == 0x000000ff) {
and you will see the test "Red detected" if any of the pixels contain full red.
However, what you do with it also seems suspect.
Cheers
Eddie
Adobe Employee ,
Contributor ,
Apr 22, 2017 Apr 22, 2017
Hey Zac.
Yes, I'm still rattling around here.
Cheers
Eddie
