Hi, guys. I'm unable to export to PDF using indesign CS6. However i can export other files to PDF its just that the only selective indesign file unable to export PDF. Please help. Its a merge indeisgn document file which have contact number and address eg.
It might be worth trying saving the InDesign file as an IDML version, renaming it and reopening the resulting InDesign doc and trying to export it again (using the PDF presets).
Which OS are you using?
Re: Closure of Indesign when I try to export a file
Hi Jackiec,
Were you able to export your file to PDF? Did Derek or George's solutions work for you?
Best,
Wren
