Hi guys,
I've noticed that after last CC update my Lightroom (and photoshop - which I covered in different thread) started to act really weird, especially if in full screen mode (L keyboard shortcut). Also it's really slow when comes to reading photos from NASes (connected by cable, not wifi). The color photo shows the behaviour of clicking in "Develop mode" link.
Screenshots: Imgur: The most awesome images on the Internet
Of course I've tried restarting the station, restarting the NAS etc. etc.
Lightroom version: CC 2015.9 [ 1106920 ]
License: Creative Cloud
Operating system: Mac OS 10
Version: 10.11 [6]
Application architecture: x64
Logical processor count: 8
Processor speed: 4,0 GHz
Built-in memory: 32 768,0 MB
Real memory available to Lightroom: 32 768,0 MB
Real memory used by Lightroom: 1 035,1 MB (3,1%)
Virtual memory used by Lightroom: 1 815,7 MB
Memory cache size: 67,2MB / 7 936,0MB (0,8%)
Maximum thread count used by Camera Raw: 8
Camera Raw SIMD optimization: SSE2,AVX,AVX2
Camera Raw virtual memory: 2MB / 16383MB (0%)
Displays: 1) 5120x2880
Graphics Processor Info:
AMD Radeon R9 M395X OpenGL Engine
Check OpenGL support: Passed
Vendor: ATI Technologies Inc.
Version: 4.1 ATI-1.42.15
Renderer: AMD Radeon R9 M395X OpenGL Engine
LanguageVersion: 4.10
Application folder: /Applications/Adobe Lightroom
Library Path: /Users/eighty9/Photos/_LIGHTROOM  Catalog&Backup/2016-01-06 0108/Lightroom Catalog.lrcat
Settings Folder: /Users/eighty9/Library/Application Support/Adobe/Lightroom
Installed Plugins:
1) AdobeStock
2) Aperture/iPhoto Importer Plug-in
3) Canon Tether Plugin
4) Facebook
5) Flickr
6) Leica Tether Plugin
7) Nikon Tether Plugin
Config.lua flags: None
AudioDeviceIOBlockSize: 512
AudioDeviceName: Built-in Output
AudioDeviceNumberOfChannels: 2
AudioDeviceSampleRate: 48000
Build: LR5x4
CoreImage: true
GL_ACCUM_ALPHA_BITS: 0
GL_ACCUM_BLUE_BITS: 0
GL_ACCUM_GREEN_BITS: 0
GL_ACCUM_RED_BITS: 0
GL_ALPHA_BITS: 8
GL_BLUE_BITS: 8
GL_DEPTH_BITS: 24
GL_GREEN_BITS: 8
GL_MAX_3D_TEXTURE_SIZE: 16384
GL_MAX_TEXTURE_SIZE: 16384
GL_MAX_TEXTURE_UNITS: 8
GL_MAX_VIEWPORT_DIMS: 16384,16384
GL_RED_BITS: 8
GL_RENDERER: AMD Radeon R9 M395X OpenGL Engine
GL_SHADING_LANGUAGE_VERSION: 1.20
GL_STENCIL_BITS: 8
GL_VENDOR: ATI Technologies Inc.
GL_VERSION: 2.1 ATI-1.42.15
OGLEnabled: true
GL_EXTENSIONS: GL_ARB_color_buffer_float GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_draw_buffers GL_ARB_draw_elements_base_vertex GL_ARB_draw_instanced GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_imaging GL_ARB_instanced_arrays GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_provoking_vertex GL_ARB_seamless_cube_map GL_ARB_shader_objects GL_ARB_shader_texture_lod GL_ARB_shading_language_100 GL_ARB_shadow GL_ARB_shadow_ambient GL_ARB_sync GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_float GL_ARB_texture_mirrored_repeat GL_ARB_texture_non_power_of_two GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_transpose_matrix GL_ARB_vertex_array_bgra GL_ARB_vertex_blend GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_window_pos GL_EXT_abgr GL_EXT_bgra GL_EXT_bindable_uniform GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_clip_volume_hint GL_EXT_debug_label GL_EXT_debug_marker GL_EXT_depth_bounds_test GL_EXT_draw_buffers2 GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_framebuffer_object GL_EXT_framebuffer_sRGB GL_EXT_geometry_shader4 GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4 GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_specular_color GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture_array GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_s3tc GL_EXT_texture_env_add GL_EXT_texture_filter_anisotropic GL_EXT_texture_integer GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_rectangle GL_EXT_texture_shared_exponent GL_EXT_texture_sRGB GL_EXT_texture_sRGB_decode GL_EXT_timer_query GL_EXT_transform_feedback GL_EXT_vertex_array_bgra GL_APPLE_aux_depth_stencil GL_APPLE_client_storage GL_APPLE_element_array GL_APPLE_fence GL_APPLE_float_pixels GL_APPLE_flush_buffer_range GL_APPLE_flush_render GL_APPLE_object_purgeable GL_APPLE_packed_pixels GL_APPLE_pixel_buffer GL_APPLE_rgb_422 GL_APPLE_row_bytes GL_APPLE_specular_vector GL_APPLE_texture_range GL_APPLE_transform_hint GL_APPLE_vertex_array_object GL_APPLE_vertex_array_range GL_APPLE_vertex_point_size GL_APPLE_vertex_program_evaluators GL_APPLE_ycbcr_422 GL_ATI_blend_equation_separate GL_ATI_blend_weighted_minmax GL_ATI_separate_stencil GL_ATI_texture_compression_3dc GL_ATI_texture_env_combine3 GL_ATI_texture_float GL_ATI_texture_mirror_once GL_IBM_rasterpos_clip GL_NV_blend_square GL_NV_conditional_render GL_NV_depth_clamp GL_NV_fog_distance GL_NV_light_max_exponent GL_NV_texgen_reflection GL_NV_texture_barrier GL_SGI_color_matrix GL_SGIS_generate_mipmap GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod
Adobe has worked on some of these rendering issues and apparently the 2015.10/6.10 update contains some of these fixes: Lightroom CC 2015.10 now available . I had only seen the top screenshot in your link above and didn't notice there were others further down but those issues might be related so try the update released today. I've certainly seen similar issues recently.
FULL SCREEN mode is activated by the F key. You are using the L key and that is LIGHTS OUT mode and looks normal. If you are talking about the background color being gray instead of black than you can change that in preferences.
Bob, please take Your time and check the screenshots before assuming that I dont know what Lights mode does
Sorry, your original question said FULL SCREEN mode but the screen shot looked more like LIGHTS OUT mode with the white border and such. I assumed you were wanting BLACK around the outside which is the default. It doesnt look like the problem Jao is referring to which is a different issue.
I assume you're referring to the grid overlay outlines appearing in tandem with the Loupe or Compare view. My first thought would be to run the Optimize Catalog function from the File menu, this often flushes out odd behavior. If this doesn't work, then reset your preferences.
This is a known issue with LR 10.8 and 10.9 on MacOS Sierra. Adobe is working on a fix. See here: Lightroom UI panels appearing black on macOS
Lightroom being slow reading from a NAS is unlikely to be a Lightroom problem. More likely to be an OS/network issue.
The screenshot very clearly shows the black side panel problem though. Lightroom is clearly in a mode where they should be drawn and this is the system/lightroom combination that has the issue.
Upon a closer look I think you are correct
Guys, guys, guys - are we looking at different screenshots or what?...
Don't You see, let's say the last screenshot, there are clearly seen rendering issues? I've been using Lightroom for more than 8 years, 'been using the LIGHTS OUT/FULL SCREEN mode for the same time and ALSO I was using it 2-mins before such problem occured.
Let's get things straight - sometimes in LIGHTS OUT mode those borders and background of grid appear - how that can be normal to You if You can clearly see that on the second to last screenshot I got ONE photo visible ("E" keyboard shortcut) and in LIGHTS OUT mode there's a broken grid beneath or on the photo?
Let's get things easier:
Do You now understand what I mean?
(I had few health issues lately which correspond with my vocabulary issues right now so maybe I didn't explain it enough - that's why I posted the screenshot)
Thanks Jao, downloading the update right now!
Did the update fix your rendering issue?
