Hardly know where to start. I got a new computer. Ever since I can not get ADE to instal a book. I have a Mac OS 10.12.3 and ADE 4.5.4. My account does not show ADE.
To solved the no ready error should used this:
Windows:
Close all applications.
Press WINDOWS + R.
In the Open text box, type regedit and then press Enter. The Registry Editor opens.
In the left pane of the Registry Editor, locate the following registry key: HKEY_CURRENT_USER\Software\Adobe\Adept
Remove the Adept Folder.
In the Confirm Key Delete dialog, click OK.
Close the Registry Editor.
Open Adobe Digital Editions and reauthorize..
Macintosh:
quit Adobe Digital Edit
...Copy link to clipboard
Has you Digital Edition install on the new System?
Yes it did install and migrated the contents of my earlier version. When trying to get the book I get an E_Auth_not_ready message. When I try to follow the directions to rebuild the activation file I stall after step 3 with a message saying my password is not correct. I don't see any way to get beyond this as there is no "forgot passsword" option. I used the password I'm using to get to this forum.
Thanks for the quick response.
Windows:
Press WINDOWS + R.
Macintosh:
quit Adobe Digital Editions.
Navigate to /Users//Library/Application Support/Adobe/Digital Editions and drag the activation.dat file to the trash.
If you are using 10.7, see https://helpx.adobe.com/x-productkb/global/access-hidden-user-library-files.html
Thank you, thank you, thank you.
You are welcome
