Hello, I am very new to animate and I just dont know where to find the ability to compress my file
I am exporting animated gif and I cannot compress.
the file is approaching 1 MB needs be 50k or under
any help much appreciated
As Clay suggested, there are online ones. I had thought they were for GIFs and wouldn't do the right thing with animated gif. But this one does:
In my test case it did better than ImageOptim.
There is no such thing as a non-compressed animated GIF. The format is inherently compressed.
Now, what you can do is run your output through a GIF optimizer, which can attempt to make your animation more compressible by reducing the color depth, frame rate, resolution, and various other tweaks.
But if you're seriously trying to get a 1MB animation down to 50K yeah no that's not happening.
thanks for the feedback - is there any way to convert the swf into a gif? because the swf is only 50k
A SWF is a computer program, not a video format. That's how Flash animations can be so compact. When you convert one to video you're just recording its output as a sequence of frames, and animated GIF is the worst, most inefficient "video" format there is.
If you want a 50K GIF you're going to have to make your animation shorter and simpler.
Animate does have a problem when making animated gifs. It makes every frame unique instead of only storing what has changed. I haven't figured a way around that in Animate.
But, if you have a Mac you can use ImageOptim:
Drag your animated gif into its window, and in the Tools menu select Gifsicle. In my quick test I had a file go from 670k down to 56k.
If you don't have a Mac can you put the animated gif online somewhere, and I'll try?
There are many freely available online animated GIF optimizers. All she has to do is Google them.
I don't have mac - where would I put the file?
Thank you for your help. Very much appreciated.
The above link, BTW, is literally the first thing that comes up when you Google "animated gif optimizer".
That could be why I gave it!
I saw - I did google. Thanks for all of the efforts.
