I’m having an unusual problem with saved project using disc menus. I have a large project with scene markers but without any movie menus. It saves and opens correctly. I can add a menu, burn discs, and save the project. However when I open the project again (now with menus) PrE 15 fails.
The failure message is from Windows,
WeFault.exe – No Disk “There is no disk in the drive. Please insert a disk into drive F:
Cancel/Try Again/Continue
Both Cancel and Continue responses result in PrE terminating with Windows message “Adobe Premiere Elements 15 has stopped working”
The crazy thing is that I don’t have an F: drive and, per windows, drives F, G, H, and I are “USB drives”. I do use an external US flash drive, however it shows up as drive L. I also have an external USB hard drive that shows up as drive K.
This happens repeatedly. Does anyone have an explanation or workaround?
After losing my project the first time, I recreated it and saved it twice, once with menus, and once without. The version without menus works fine, and I can add menus and burn discs to it. But, the saved version with menus causes PrE to terminate.
Some details:
Video is hi-def, 1920x1080, of consisting of a dozen MP4 files. 1 hr 45 minutes in length
Menu is vanilla “Pan and Zoom” in the “Slideshow” category, without any modification, (i.e., no video, photo, or audio background)
18 Scene markers
Blu-ray disc
Environment: Windows 10 Pro 64 bit
Fast Computer: Intel Core i7-6700, 3.4GHz
Large memory: 32GB
Large disk storage – 2 TB D: drive for programs and data, plus 256BM C: flash drive for Windows
See if something here helps:
Premiere Elements 15: "no disk" error | Photoshop Family Customer Community
Does it happen with a different menu template?
Thanks for the advice.
1. The "no disk" error thread seems to be same problem. And, my F: disk also happens to be a mult-function card reader, however I don't have SD or SF card to test the work around, but will try to find one and test later.
2. Just tested with different menu, and also experienced failure. This time I used the "wedding" menu which had to be downloaded. After download, I saved project, closed PrE 15, then reopened saved project. This time error didn't occur at time of project load, but instead when I went to the movie menu tool. Error was same as before with PrE 15 terminating.
