I have a document with some colour swatches that I know to be and stay unused (Changed to spot->output PDF, in the PDF, there is no plate with that spot colour). But when selecting the unused swatches, they do not get selected. I was able to detect the culprit for 2 colours (unused character style). But now, I have no unused character or paragraph styles anymore and still colours that indicate usage.
Isn't there a find command to find those elements?
There are many places where those unused swatches can hide...
Here's probably the most common one:
About a method (script?) helping to clean this up, or at least to point those swatches, I'm not aware of any.
I'd be glad to hear about one...
try to save your file in idml.
then reopen it and select unused swatches
You may still find interesting this old thread, and the script in the last post.
It didn’t find simple colored text for me.
However: it found a line with 0 pt weight and ’filled’ with some test color. You’re right - such an object is simply invisible. However, script found it for me.
So: not a Swiss knife, but can be useful sometimes. Especially if you’re not going to get rid of a color, just want to find out where it is used.
A new update that is extremely useful is that you can now search for colours. You can just press CTRL + F and click Color.
You can also right click on the swatch in the swatches panel and select "find this colour".
