if I ad to my title (24px) a H1 tag the browsers (all) render it double the size.
I create a website with fixed breakpoints 1200,960, 600, 480px.
Does somebody had the same problem?
How to get out of it?
Thanks for help
Dirk
This has nothing to do with your h1 tag in your caption.
There is a conflict between your text styling and the MuseThemes widget "Sidebar Connect". If you delete this widget, text size works as expected..
I assume, you set a wrong configuration in the configuration spreadsheet or there is a n issue with this widget. So have a look at the spreadsheet and/orcontact the vendor.
One hint: If you want your site to spit out strange effects, issues and bugs, simply keep on flooding the pages with tons of
...Copy link to clipboard
Are you using a system font and hidpi setting? what font are you using?
I use WF Raleway
Again: Create a new .muse file with only one text line, formatted as you described, and give us a Dropbox link to this document.
If anyone can Guenter will figure this out... )
One hint: If you want your site to spit out strange effects, issues and bugs, simply keep on flooding the pages with tons of third party widgets! . I found 7 3rd party widgets from different vendors on your site – not to forget additionally some HTML objects …
Hi Günter,
so I´ll kick those third party widget´s out .
Thank you very much for your help.
Beste Grüsse
Dirk
Yes
I agree...many problems are poorly written or not updated third party widgets...thanks for helping Dixibody out...was pretty sure you could.
