Random images across repeated shape
Apr 13, 2017 Apr 13, 2017
I'm wondering if there would be a way to have different images on, let's say four squares, but I want the images to be randomly selected. For example if I had 8 images to choose from, I want four of them to be randomly chosen and randomly placed over the center of each square for the entire duration of the object
951
Enthusiast ,
This is a bit difficult to visualize.  Can you provide a better idea, perhaps a screenshot of how this is designed and then explain?
Eric
Well the design is really simple, each comp has four squares in them (ill be using more but this is only for an example), there would be 8 or more images in Project (dont have any images on desktop right now)
I want to randomly assign each square an image from Project. and in each of the following comp i want to randomly assign different pictures from Project. I am going to be making a lot of squares with randomly selected images in the center of each of them, and for every comp i want it to be a different randomized selection from the same set of photos. once i can get back to my main device ill try to give a more detailed example if you dont understand yet, sorry im not too good at explaining this
edit:"group1" "group2" etc. are meant to be the comps i mentioned sorry
Apr 14, 2017 Apr 14, 2017
You can make your random images inside their own precomp and have each one frame long and then sequence them. Then, apply a random value to a time remapping expression to make it randomly choose which image to display.
thanks that sounds like it would work, I haven't tried yet but how would I prevent the same ima from showing up in several boxes. Like what if one photo gets randomly selected for more than one square
Apr 22, 2017 Apr 22, 2017
You could randomly sort your photos in the precomp and then set the squares to grab a certain frame based on their layer index. That would make things random, but not repeated.
Adobe Employee ,
May 23, 2017 May 23, 2017
Hi BrandonG,
What did you end up doing? Did Szalam's advice help?
Kevin
