I've been searching for what I thought would be a seemingly simple solution and have not found it.
Does anyone know how to change the default values for stroke in After Effects? It's typically 3 point and red. I spend a lot of time changing it in many compositions to 5 point and black to match a corporate style. I know it's not a hard thing to change, but when you have to do it frequently, it really bogs down the creative process.
I imagine that if there is a solution to this, it's probably the same to change any of the default values for the layer styles available.
There is no such thing. This stuff is hard-coded and due to how AE inherited this stuff as sort of an afterthought from PS, the necessary infrastructure is incomplete, meaning you don't have style presets or any such thing.
Mylenium
Mylenium
The default can't be changed but AE remembers the values for the last use of the tool, so draw your initial shape and modify the values and those will be the defaults for that tool going forward.
That has not been my experience on any machine I've worked on. All my machines keep defaulting to 3 point, red.
I just re-verified the behavior of AE keeping the last values as the default for the next shape. To make sure we're talking about the same thing and procedure here's what I did:
Interesting, but doesn't work when the stroke you're creating is around a pre-existing image such as a photo. Thanks though.
If you're creating a stroke around a photo then this implies you're creating a mask. For masks there is no stroke width and the color of the mask is only for AE user organizational purposes rather than something that is actually rendered. By default AE cycles through colors for each new mask you create - you can change this via Edit > Preferences > Appearance, uncheck Cycle Mask Colors.
Sounds like you guys are talking about two different strokes. The shape tool will remember the previous settings but if you apply a stroke via "layer styles" it is always 3 point red & like Myl said, I think this is 'hard-coded'.
One thing you might try though is to use the stroke effect (under the "generate" effects). From there you save an effect preset to whatever you want. Like my Bobie used to say: "There is more than one way to stroke a cat".
You can build your effect, stroke, preset, whatever as prototyp and copy - paste it whenever you need it.
Advanced:
Include expressions for stroke width, color and whatever you want. Point those expression to a "controller" layer (typical a null object) and control those parameters at once on one location.
Nice catch Gutter-Fish​. A limitation with using a stroke effect though is that it only applies to a mask. If the OP is ok with that then you've given him a good solution.
I fo
Thanks, I forgot to mention that so nice catch back at ya'.
Simply selecting the layer and hitting Ctrl+Shift+N will create a mask that fits the layer exactly (assuming it's rectangular).
The stroke effect can then be applied.
Hi Buzzworthy Media,
Did you get a suitable response here? If so, please mark that one as the correct one. If you still need assistance, let us know.
Kevin
Thanks for the reminder to mark the closest answer as correct. The banter about masks was way off the mark. It does seem that this would be an easy thing to correct for the programmers. I don't know why red was chosen as the default for this tool as it's probably the most offensive in the spectrum. I guess I'll have to put in a feature request on the Adobe website.
While you wait for that feature request to process, How about the suggestion you got earlier - a preset:
1. Create your desired layer style
2. Highlight it and go to animation->save animation preset. Call it a name
3. anytime you want to add it, type the name in the effects & presets panel
think of it as creating a ×´style", same as you would do in photoshop. Actually, if I remember correctl, it's only until recently that Ps remembers the last layer style used or enabled you to set another as default.
Just to make up for getting off track with the discussion about masks, I wrote you a script that will enable the stroke effect for all selected layers, then change the stroke size to 5 and the color to black
Copy the following text and save it to a file named "LayerStroke.jsx". You can execute the script either by performing File -> Scripts -> Run Script File... or for faster access you can copy it to your AE scripts directory and run it via File -> Scripts -> LayerStroke
LayerStroke.jsx
Author: Horshack, 04/13/17Adds layer style "stroke" to all selected layers, then sets stroke size to 5
and stroke color to black
* script entry point
setSelectedLayersStrokeSizeAndColor([0,0,0,1] /* color: black */, 5 /* stroke size: 5 */);
* adds stroke to selected layers, then applies specified color
* and stroke size
function setSelectedLayersStrokeSizeAndColor(strokeColor, strokeSize) {/*
* verify an active composition
var activeComp = app.project.activeItem;
if (activeComp == null) {
alert("Error: No active composition");
return;
* verify at least one layer was selected
var countSelectedLayers = activeComp.selectedLayers.length;
if (countSelectedLayers == 0) {
alert("Error: No layers selected");
return;
* apply stroke to all selected layers by invoking menu command
* https://forums.creativecow.net/thread/227/19122
app.executeCommand(app.findMenuCommandId("Stroke"));/*
* now change the stroke size and color
for (var selectedLayerIndex=0; selectedLayerIndex < countSelectedLayers; selectedLayerIndex++) {
var layer = activeComp.selectedLayers[selectedLayerIndex];
layer.property("Layer Styles").property("Stroke")("Color").setValue(strokeColor);
layer.property("Layer Styles").property("Stroke")("Size").setValue(strokeSize);
There is a way to change the default Shape properties in After Effects (the 2021 version anyway). This is the Windows way.
