In the Print module, and trying to print an 8x10 image. Everything looks normal, except that the Preview box in the upper left corner stays blank. I go ahead and print, but the image prints in the lower, right corner of the paper. It's almost as though it doesn't know the paper size. I double-check that in Page Setup and I am set for the right size paper. Each image I try to drop into the cell doesn't appear in that Preview box.
There's got to be something easy I am overlooking.
Help!
Don't know about the rest of the problem but the photos NEVER show in the navigator pane (upper left corner)
Bob is correct. The navigator panel only ever shows the template that is active.
I suggest you double-check the paper size in the Page Setup Printer dialog, then confirm that the Margins and Cell Size in the Layout panels do fill the paper as wanted.
