Paste in multiple files
Apr 15, 2017 Apr 15, 2017
Is there a way to paste across multiple files at once? I need to put my watermark on multiple images, but don't want to paste on every single file. Can I just open all of my files and paste on everything? Thanks!
284
Community Expert , Apr 15, 2017 Apr 15, 2017
Paste would not be a good way to batch process your watermark onto you images if you have different size and aspect ratio images. You most likely would want to size and position the watermark for the image being processed.  A simple action could watermark you image.  You could than use the image processor  script from Adobe Bridge menu  Tools>Photoshop>Images processor. Where you first select the thumbnails for the images files you want to watermark.  The image processor would then  process the
Adobe
Paste would not be a good way to batch process your watermark onto you images if you have different size and aspect ratio images. You most likely would want to size and position the watermark for the image being processed.  A simple action could watermark you image.  You could than use the image processor  script from Adobe Bridge menu  Tools>Photoshop>Images processor. Where you first select the thumbnails for the images files you want to watermark.  The image processor would then  process the files select in the bridge and save watermarked Image files of the image to where you want them saved fitted to any size you need. The action may be very simple like use is a script to watermark the current document. I have posted a script the is easy to modify to use your watermark. Your Watermark files will be placed onto the image sized for the image and position the the bottom right corner by my script.  The action could re-position the watermark layers and add a layer style if you wanted to.
PlaceWatermark.jsx
#target photoshop;
app.bringToFront();
var logoFile = "~/Desktop/JJMack.png"; // Watermark file should be large for resize down works better than up
var LogoSize = 10; // percent of document height to resize Watermark to
var LogoMargin = 1;                                         // percent of Document height the Watermark should have as a margin
placeWatermark(logoFile, LogoSize, LogoMargin);             // Place Watermark  into the bottom right of document
function placeWatermark(Image,Size,Margin){
  if(!documents.length) return;   // if no document return
  try{
  var doc = app.activeDocument; // set Doc object to active document
  app.displayDialogs = DialogModes.NO; // Dialog off
  var strtRulerUnits = app.preferences.rulerUnits; // Save Users ruler units
  var strtTypeUnits = app.preferences.typeUnits; // Save Users Type units
  app.preferences.rulerUnits = Units.PIXELS; // work with pixels
  app.preferences.typeUnits = TypeUnits.PIXELS; // work with pixels
  var fileObj = new File(Image);                 // the passed file
  if(!fileObj.exists){   // If file does not exits tell user
  alert(fileObj.name  + " does not exist!");
  return;
  placeFile(fileObj); // Place in file the Watermark png file
  activeDocument.activeLayer.resize(100 ,100,AnchorPosition.MIDDLECENTER); // Insure Place did not scale layer
  var SB = activeDocument.activeLayer.bounds; // get layers bounds
  var layerHeight = SB[3] - SB[1]; // get layers height
  var resizePercent = (100/layerHeight)*(Size/100*doc.height.value); // Percent to resize by
  activeDocument.activeLayer.resize(resizePercent ,resizePercent,AnchorPosition.MIDDLECENTER);  // Resize width and height by percentage
  SB = activeDocument.activeLayer.bounds; // get resized layers bounds
  activeDocument.activeLayer.translate(-SB[0].value,-SB[1].value); // Move resized layer to top left canvas corner
  var LayerWidth = (SB[2].value - SB[0].value);
  var LayerHeight = (SB[3].value - SB[1].value);
  marginSize = Margin/100*doc.height.value; // move resized watermark into the document lower right corner with some margin
  activeDocument.activeLayer.translate((doc.width.value -marginSize - LayerWidth),( doc.height.value -marginSize - LayerHeight));
  catch(e) { alert(e + ': on line ' + e.line); } // inform user of error
  finally{
  app.preferences.rulerUnits = strtRulerUnits; // Restore user ruler units
  app.preferences.typeUnits = strtTypeUnits; // Restore user type units
function placeFile(placeFile) {
    var desc21 = new ActionDescriptor();
    desc21.putPath( charIDToTypeID('null'), new File(placeFile) );
    desc21.putEnumerated( charIDToTypeID('FTcs'), charIDToTypeID('QCSt'), charIDToTypeID('Qcsa') );
    var desc22 = new ActionDescriptor();
    desc22.putUnitDouble( charIDToTypeID('Hrzn'), charIDToTypeID('#Pxl'), 0.000000 );
    desc22.putUnitDouble( charIDToTypeID('Vrtc'), charIDToTypeID('#Pxl'), 0.000000 );
    desc21.putObject( charIDToTypeID('Ofst'), charIDToTypeID('Ofst'), desc22 );
    executeAction( charIDToTypeID('Plc '), desc21, DialogModes.NO );
JJMack
