I'm playing with adding FP functionality -- but prototype isn't working for me.
A code sample - I get an "a.indexOf is not a function" error. Anyone see why I'm getting that error? It works fine in a javascript editor.
main();
function main(){
var a=[4,9,16];
alert(a);
b=a.indexOf(9);
alert(b);
Array.prototype.indexOf = function (elem, fromIndex){
fromIndex = Number(fromIndex) || 0;
var len = this.length;
if (fromIndex < 0){
fromIndex += len;
for(var i=fromIndex;i<this.length;i++){
if(this == elem){
return i;
return -1;
declare your prototype inside of main() before using it.
This is working:
...main();
function main()
if (fromIndex < 0)
fromIndex += len;
if(this == elem)
return i;
return -1;
var a=[4,9,16];
al
This is working:
main();
function main()
if (fromIndex < 0)
fromIndex += len;
if(this == elem)
return i;
return -1;
var a=[4,9,16];
alert(a);
b=a.indexOf(9);
alert(b);
Or declare your prototype before everything else:
if (fromIndex < 0)
fromIndex += len;
if(this == elem)
return i;
return -1;
main();
function main()
var a=[4,9,16];
alert(a);
b=a.indexOf(9);
alert(b);
But e.g. this is not working:
main();
function main()
var a=[4,9,16];
alert(a);
b=a.indexOf(9);
alert(b);
if (fromIndex < 0)
fromIndex += len;
if(this == elem)
return i;
return -1;
ExtendScript is a bit picky on prototype.
BTW: You can use the forum's Advanced Editing feature to format your text as code.
>> Insert > Syntax Highlighting > javascript
Uwe
Thanks. I figured scope would take care of that...
