I'm learning Muse and for the life of me can't figure out why this is happening. When I click on the hamburger menu, I'm seeing ghostly submenu on the 'lightbox'? menu that opens.
http://thegourmetcyclistrmc.businesscatalyst.com
The destination selection is not a page but is there to access the 3 destinations. when you hover over 'destinations' you see the 3 destinations are behind the lightbox menu, not accessible. Can someone please shed some light on this issue - how to fix this? thanx
This is not the only issue with your mobile menu. You have this one too: https://forums.adobe.com/thread/2302134
Just read my answer, try the suggested solution and see, if your problem keeps showing.
If yes, do the following:
Reduce your existing site to only the elements, which demonstrate your issue (= the menu) and delete all other content (This is helpful, because it saves download- and analysing-time).
Upload this .muse file to Dropbox or a similar file sharing service and provide the download
...Copy link to clipboard
Upload this .muse file to Dropbox or a similar file sharing service and provide the download link here. Then we can have a closer look, and time consuming „question and answer“ games or pure guessing can be considerably reduced.
EDIT: I think, it is not necessary to give us the .muse file. Submenus apparently don’t work correctly in this constellation. Seems to be a bug related to the problem, which is discussed in the thread I linked above. I reported the issue in the Muse Prerelease forum.
A viable workaround: Build your own menu by using simple elements (text, rectangles or, best choice, state buttons).
