I have been having issues when editing text fields. This one imparticular; How do I stop acrobat from re-numbering my paragraphs? I need this to stop. I do not want to retype 1000+ page publications
I have a paragraph with numbered headings, I hit EDIT and select in the field. No worries. I actually edit some text and then Acrobat changes the numbered paragraphs!!
Before:
AFTER I start editing
Message was edited by: ANTHONY RUEST
This is not a text field, but static text in the file. PDF files were never meant to be edited in such a way, and doing so is tricky and risky, and should be avoided as much as possible. Hopefully you can get access to the original file used to create this publication. If you do, edit that file in the native application that created it and then generate a new PDF from it.
If you can't do that, try exporting the PDF to a more suitable format for editing, like Word or InDesign. Edit the file there and then create a new PDF from it.
Trying to do this task in the PDF directly is a fool's errand, and will cost you a lot of time, efforts and headaches.
Hi anthonyr6944752 ,
Sorry for the issue you are facing. We are able to reproduce the issue at our end. Issue has been forwarded to the concerned team for investigation.
Priyanka
Can you also explain why this happens when using the Edit Text on pre-existing PDFs....
While making simple edits to paragraphs, I have noticed that on many occasions "letters" will be dropped from full words. Spellings were correct before I clicked into a text field.
Below are examples of words I found in 1 PDF that were changed by Acrobat to misspellings:
figur 1 to figure 1
Baffl to baffle
Fittin to fitting
Iockwashers to lockwashers
Filte to filter
identificatio to identification
arming-firin to arming-firing
flexibl to flexible
firewal to firewall
baffl to baffle
fille to filled.
Ventral fi to ventral fin
Confir to confirm
1-H1AAC to 01-H1AAC
Hellfir to hellfire
Fla washers to flat washers
Fixe to fixed
Aeriol ThixO to Aeriol Thixo
Flang to flange
Configuratio to configuration
