Hi
Have updated lightroom and it now recognizes the new camera and raw format. Downloaded the 9.11 plug in raw installer and installed it under window 10 64 and photoshop and bridge don't recognize the new camera and raw, even though the T7i is listed in the plug in. anyone else have this issue and/or any suggestions.
thanks
Ron
You cannot install 9.10 in CS6. The last compatible version is 9.1.1. You need 9.10 for your camera but that is only compatible with Cloud versions.
Use Lightroom to convert to DNG then edit the DNG files in CS6.
Please confirm the exact version number of Camera Raw that you have installed. There is no version 9.11 (nine point one one or nine point eleven)
I suspect you mean 9.1.1 which is the last version of Camera Raw which is compatible with CS6. That means you'll never be able to open Raw T7i files in CS6.
In the unfortunate numbering scheme used by Adobe, 9.1.1 was followed by 9.2 through to 9.10 (current) and 9.10 is the version you need for the T7i.
However 9.2 onwards are only compatible with Cloud (CC) versions.
So your options:
Hi John
I miss wrote the number. downloaded ver 9.1.1 and the version number showing up under help and plugins is ver 9.1.1.461 I also tried ver 9.10
thanks
Ron
Hi John
Thanks for the info. I knew that I could edit through lightroom. It's unfortunate that Adobe is very transparent about wanting to sign everyone up for subscription software and is not updating CS6 along with CC. Running into same issue with Acrobat Pro; that have to buy subscription for software outright for DC. Not the raw issue.
When CS6 needs to be replaced on my computer, will look for another product Vs Photoshop.
thanks again.
Ron
Yes, Photoshop CS6 is obsolete an later updates are subscription only, you are four vesrsion behind.
No, Acrobat is available for permanent license as well as subscription. The permanent version will run behind the subscription But you can buy Acrobst DC.
