Since the last update I have not been able to keep the 'Solo' mode in operation in the develop mod. When clicking on the option it will collapse the stack, but opening a module will not collapse a previous module, eventually all modules can be open.
I have tried renaming the adobe.lightroom6.plist file but this did not rectify the situation. This also appear when opening any of my other catalogues.
Am i missing something?
If you right click on a panel, is Solo Mode ticked?
My instinct would be to restart Lightroom.
renaming the plist doesn't quite work as it's still loaded in memory until a restart. You need to hold Shift and Option to reset preference after quitting and restarting Lightroom to reset preferences. You may even need to restart the computer so the in memory preferences are removed.
Alt/Option Click on a panel. Solo Mode could've been turned off accidentally with a passing right click.
Hi Sean,
Thank you for you response. I have tried this but still does not work. If I click on Basic module and select solo mode, then click on tone curve the basic module still remains open. This is the same if I then continue to click further modules.
