Gridify Isn't Working in InDesign CC
Mar 31, 2017 Mar 31, 2017
I am a student. I am using Windows 8 operating system and have the 2017 version of InDesign (InDesign CC).
My class project requires me to use the gridify feature to create multiple equally-spaced boxes within a rectangle frame. However, when I use the rectangle tool to draw out a rectangle and click the right arrow button (WITHOUT LETTING UP ON MY CURSOR) it automatically sets two boxes within the frame I drew and releases the frame - EVEN THOUGH I NEVER LET UP ON MY CURSOR. I have tried using the alt and shift buttons as well, and I cannot get the gridify feature to let me make more than two boxes before releasing. If I hit the right arrow button a second time while still holding down the cursor, it simply moves my two boxes over to the right.
PLEASE HELP!
2.0K
From your description, it sounds like you know how this is supposed to work. I can't recreate it, so I really have to review the steps.
How many images are loaded when you drag out the box?
Can you tap the other arrow keys (up to add rows, down to remove rows, left to remove the one column you can add)?
You can always use the Align and Distribute commands to get around this, if need be. We can help with that, too.
Hi Barb,
I don't have images loaded yet when I draw out the box with the rectangle frame tool. I draw the tool to the desired dimensions, then while still holding down the cursor, press an arrow key. It doesn't matter which arrow key I press, it creates two frames within my original rectangle, then deselects everything (despite my still holding down the cursor). Thus, if I hit an arrow key a second time (any arrow key), it simply moves the recently created frames a step in the direction of the arrow key I pressed.
I've used the transform, the step and repeat, and the align tools to try to recreate what gridify would have created, but since I will be required to use gridify again later in this course, I'm trying to ascertain why it's not working. Is it just not enabled in the 2017 version of InDesign? I looked online for help, but the only tutorials for gridify that I could find used InDesign versions CS6 and older (my textbook uses CS6).
Ah. Here's how gridify works when placing images...
  1. File > Place
  2. Select multiple images (let's say 6)
  3. Draw a rectangle with your loaded text cursor
  4. Tap the left arrow key to add columns, the right arrow key to add rows
  5. Release the mouse
  6. The loaded images flow into the grid.
You can also draw rectangles in advance without images loaded, and I'm slowly understanding that that is what you are asking about.
What I'm trying to do is draw the rectangles in advance without the images loaded (your last image). Can you send instructions for how to do that? Perhaps the ones in my textbook are outdated with the latest version.
Sorry, I took off in the wrong direction with the images. I'm on 2017 as well. Here is exactly what I am doing:
Select either of the rectangle tools (graphic or unassigned)
Draw a rectangle without letting go.
Without releasing the mouse button, I tap the right and up arrow keys.
Release
Am I saying anything different than what you are doing? It doesn't sound like it.
Here is a short video of Gridify. It is working for me in CC 2017, but I'm on a Mac. I wonder if it's a Windows bug if you are doing it correctly.
Also, try another keyboard.
http://monarchtraining.net/images/indesign_gridify.mp4
Apr 01, 2017 Apr 01, 2017
Hi Barb (and Jane),
The process you describe is precisely what I am doing. But when I hit any arrow key, it makes a second box and then deselects everything (as if I had let up on the mouse, although I haven't). If I try hitting a second arrow key (or the first arrow key a second time) still holding down the mouse, it simply moves my two boxes over a notch.
I have tried resetting the preferences, but it still isn't working. I can't use a different keyboard because my only computer is a laptop (so the keyboard is built in). I can't figure out what is going on, unless the app I downloaded from Adobe has a bug in it?
If you are using mouse, try the trackpad.
If you are using the trackpad, try a mouse.
This should work in CC 2017, and I am looking for anything that would make it not work!
Jane has two good points: it's working for us but we are both on Macs. It would be helpful for another Windows user to chime in. A different keyboard may also be helpful.
Also, the old standby, resetting preferences. We both teach gridify to numerous students on Macs and Windows, and speaking for myself, I've never seen it not work.
Troubleshooting 101: Replace, or "trash" your InDesign preferences
Mentor ,
In Windows, Gridify technique works exactly the same way You so nicely described. One can use Rectangle, Ellipse, Polygon, Text tools, you name it. Everything goes, what can draw a some kind of object.
At least, in Win7/CS6 and Win10/CC2017 it works for sure. I don’t believe there is any difference in Win8.
Enthusiast ,
Apr 02, 2017 Apr 02, 2017
It definitely sounds like a bug with OP's original configuration...or, as Barb mentioned, you might need to reset preferences. The proper steps are being taken, but something is going awry. I second the "If a Windows user with the same versions of the OS and CC could see if they have the same issue" train of thought.
Adobe Employee ,
Apr 17, 2017 Apr 17, 2017
Hi slarson4,
Were you able to find success with any of the suggestions given? Let us know if you need further assistance.
Best,
Wren
