Is this possible to restart the footnote number via script
I need to change the footnote number 9 to 9.1 and restart the 11 to 10
No. All you can do with footnotes with a script is the exact same stuff as you can do in the interface. Individual footnote numbering is not possible in that as well.
there is no custom footnote options
Is this a question? No, InDesign does not have that. See the online help: Create footnotes in InDesign (it also mentions "You cannot add footnotes to tables or to footnote text").
restart footnote numbering is possible by scripting.
But it comes with the same restrictions and the same feature set like you see in the UI. And that means it is not very flexible. Don't know what your version of InDesign is, here a link to DOM documentation with InDesign CS6:
http://jongware.mit.edu/idcs6js/pc_FootnoteOption.html
Adobe InDesign CS6 (8.0) Object Model JS: FootnoteRestarting
Sources for DOM documentation
Jongware:
Gregor Fellenz:
InDesign ExtendScript API (12.0)
Index of /extendscriptAPI
Also search this forum or the Adobe InDesign forum for: footnote renumbering
Footnotes question. How to add a point footnote: 16.1?
I think you cannot rely on automatic numbering or renumbering and you have to to do your numbering by changing text on the page and fake things. However if something is changing—footnote added, footnote removed—a hypothetical script should be run again for editing numbers in footnote texts and also changing the faked numbers that one can see in the main story.
Uwe
but Ms-office having custom footnote option. we can change the number what ever we want.
Also the footnote concept is not working inside tables
Hm…
Then you would work best without InDesign's footnote feature entirely.
A hypothetical script would add a second story for the footnote texts with threaded text frames at the bottom of every page when needed. The main story's text would be moved on by text wrap. The faked footnote markers would be formatted with a unique character style so that a script can identify it and it would do the numbering by changing the contents of the marked text.
Uwe
Hi Uwe,
Not so hypothetical!
It offers everything you mention, and a lot more beside...
Ariel
I will add this to indesign feature request
